path: root/arch/x86/mm/pageattr.c
2012-06-11x86/mm: Fix some kernel-doc warningsWanpeng Li
Fix kernel-doc warnings in arch/x86/mm/ioremap.c and arch/x86/mm/pageattr.c, just like this one: Warning(arch/x86/mm/ioremap.c:204): No description found for parameter 'phys_addr' Warning(arch/x86/mm/ioremap.c:204): Excess function parameter 'offset' description in 'ioremap_nocache' Signed-off-by: Wanpeng Li <liwp@linux.vnet.ibm.com> Cc: Gavin Shan <shangw@linux.vnet.ibm.com> Cc: Wanpeng Li <liwp.linux@gmail.com> Link: http://lkml.kernel.org/r/1339296652-2935-1-git-send-email-liwp.linux@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-01-11Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/numa: Add constraints check for nid parameters mm, x86: Remove debug_pagealloc_enabled x86/mm: Initialize high mem before free_all_bootmem() arch/x86/kernel/e820.c: quiet sparse noise about plain integer as NULL pointer arch/x86/kernel/e820.c: Eliminate bubble sort from sanitize_e820_map() x86: Fix mmap random address range x86, mm: Unify zone_sizes_init() x86, mm: Prepare zone_sizes_init() for unification x86, mm: Use max_low_pfn for ZONE_NORMAL on 64-bit x86, mm: Wrap ZONE_DMA32 with CONFIG_ZONE_DMA32 x86, mm: Use max_pfn instead of highend_pfn x86, mm: Move zone init from paging_init() on 64-bit x86, mm: Use MAX_DMA_PFN for ZONE_DMA on 32-bit
2011-12-06mm, x86: Remove debug_pagealloc_enabledStanislaw Gruszka
When (no)bootmem finish operation, it pass pages to buddy allocator. Since debug_pagealloc_enabled is not set, we will do not protect pages, what is not what we want with CONFIG_DEBUG_PAGEALLOC=y. To fix remove debug_pagealloc_enabled. That variable was introduced by commit 12d6f21e "x86: do not PSE on CONFIG_DEBUG_PAGEALLOC=y" to get more CPA (change page attribude) code testing. But currently we have CONFIG_CPA_DEBUG, which test CPA. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Mel Gorman <mgorman@suse.de> Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/1322582711-14571-1-git-send-email-sgruszka@redhat.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-05arch/x86/mm/pageattr.c: Quiet sparse noise; local functions should be staticH Hartley Sweeten
Local functions should be marked static.  This also quiets the following sparse noise: warning: symbol '_set_memory_array' was not declared. Should it be static? Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: hartleys@visionengravers.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-18x86: Fix common misspellingsLucas De Marchi
They were generated by 'codespell' and then manually reviewed. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Cc: trivial@kernel.org LKML-Reference: <1300389856-1099-3-git-send-email-lucas.demarchi@profusion.mobi> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-10x86/mm: Fix pgd_lock deadlockAndrea Arcangeli
It's forbidden to take the page_table_lock with the irq disabled or if there's contention the IPIs (for tlb flushes) sent with the page_table_lock held will never run leading to a deadlock. Nobody takes the pgd_lock from irq context so the _irqsave can be removed. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: <stable@kernel.org> LKML-Reference: <201102162345.p1GNjMjm021738@imap1.linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-02-02x86, nx: Don't force pages RW when setting NX bitsMatthieu CASTET
Xen want page table pages read only. But the initial page table (from head_*.S) live in .data or .bss. That was broken by 64edc8ed5ffae999d8d413ba006850e9e34166cb. There is absolutely no reason to force these pages RW after they have already been marked RO. Signed-off-by: Matthieu CASTET <castet.matthieu@free.fr> Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-11-18x86: Add NX protection for kernel dataMatthieu Castet
This patch expands functionality of CONFIG_DEBUG_RODATA to set main (static) kernel data area as NX. The following steps are taken to achieve this: 1. Linker script is adjusted so .text always starts and ends on a page bound 2. Linker script is adjusted so .rodata always start and end on a page boundary 3. NX is set for all pages from _etext through _end in mark_rodata_ro. 4. free_init_pages() sets released memory NX in arch/x86/mm/init.c 5. bios rom is set to x when pcibios is used. The results of patch application may be observed in the diff of kernel page table dumps: pcibios: -- data_nx_pt_before.txt 2009-10-13 07:48:59.000000000 -0400 ++ data_nx_pt_after.txt 2009-10-13 07:26:46.000000000 -0400 0x00000000-0xc0000000 3G pmd ---[ Kernel Mapping ]--- -0xc0000000-0xc0100000 1M RW GLB x pte +0xc0000000-0xc00a0000 640K RW GLB NX pte +0xc00a0000-0xc0100000 384K RW GLB x pte -0xc0100000-0xc03d7000 2908K ro GLB x pte +0xc0100000-0xc0318000 2144K ro GLB x pte +0xc0318000-0xc03d7000 764K ro GLB NX pte -0xc03d7000-0xc0600000 2212K RW GLB x pte +0xc03d7000-0xc0600000 2212K RW GLB NX pte 0xc0600000-0xf7a00000 884M RW PSE GLB NX pmd 0xf7a00000-0xf7bfe000 2040K RW GLB NX pte 0xf7bfe000-0xf7c00000 8K pte No pcibios: -- data_nx_pt_before.txt 2009-10-13 07:48:59.000000000 -0400 ++ data_nx_pt_after.txt 2009-10-13 07:26:46.000000000 -0400 0x00000000-0xc0000000 3G pmd ---[ Kernel Mapping ]--- -0xc0000000-0xc0100000 1M RW GLB x pte +0xc0000000-0xc0100000 1M RW GLB NX pte -0xc0100000-0xc03d7000 2908K ro GLB x pte +0xc0100000-0xc0318000 2144K ro GLB x pte +0xc0318000-0xc03d7000 764K ro GLB NX pte -0xc03d7000-0xc0600000 2212K RW GLB x pte +0xc03d7000-0xc0600000 2212K RW GLB NX pte 0xc0600000-0xf7a00000 884M RW PSE GLB NX pmd 0xf7a00000-0xf7bfe000 2040K RW GLB NX pte 0xf7bfe000-0xf7c00000 8K pte The patch has been originally developed for Linux 2.6.34-rc2 x86 by Siarhei Liakh <sliakh.lkml@gmail.com> and Xuxian Jiang <jiang@cs.ncsu.edu>. -v1: initial patch for 2.6.30 -v2: patch for 2.6.31-rc7 -v3: moved all code into arch/x86, adjusted credits -v4: fixed ifdef, removed credits from CREDITS -v5: fixed an address calculation bug in mark_nxdata_nx() -v6: added acked-by and PT dump diff to commit log -v7: minor adjustments for -tip -v8: rework with the merge of "Set first MB as RW+NX" Signed-off-by: Siarhei Liakh <sliakh.lkml@gmail.com> Signed-off-by: Xuxian Jiang <jiang@cs.ncsu.edu> Signed-off-by: Matthieu CASTET <castet.matthieu@free.fr> Cc: Arjan van de Ven <arjan@infradead.org> Cc: James Morris <jmorris@namei.org> Cc: Andi Kleen <ak@muc.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Dave Jones <davej@redhat.com> Cc: Kees Cook <kees.cook@canonical.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <4CE2F82E.60601@free.fr> [ minor cleanliness edits ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-18x86: Fix improper large page preservationmatthieu castet
This patch fixes a bug in try_preserve_large_page() which may result in improper large page preservation and improper application of page attributes to the memory area outside of the original change request. More specifically, the problem manifests itself when set_memory_*() is called for several pages at the beginning of the large page and try_preserve_large_page() erroneously concludes that the change can be applied to whole large page. The fix consists of 3 parts: 1. Addition of "required" protection attributes in static_protections(), so .data and .bss can be guaranteed to stay "RW" 2. static_protections() is now called for every small page within large page to determine compatibility of new protection attributes (instead of just small pages within the requested range). 3. Large page can be preserved only if attribute change is large-page-aligned and covers whole large page. -v1: Try_preserve_large_page() patch for Linux 2.6.34-rc2 -v2: Replaced pfn check with address check for kernel rw-data Signed-off-by: Siarhei Liakh <sliakh.lkml@gmail.com> Signed-off-by: Xuxian Jiang <jiang@cs.ncsu.edu> Reviewed-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Arjan van de Ven <arjan@infradead.org> Cc: James Morris <jmorris@namei.org> Cc: Andi Kleen <ak@muc.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Dave Jones <davej@redhat.com> Cc: Kees Cook <kees.cook@canonical.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <4CE2F7F3.8030809@free.fr> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-20Merge branch 'drm-ttm-pool' into drm-core-nextDave Airlie
* drm-ttm-pool: drm/ttm: using kmalloc/kfree requires including slab.h drm/ttm: include linux/seq_file.h for seq_printf drm/ttm: Add sysfs interface to control pool allocator. drm/ttm: Use set_pages_array_wc instead of set_memory_wc. arch/x86: Add array variants for setting memory to wc caching. drm/nouveau: Add ttm page pool debugfs file. drm/radeon/kms: Add ttm page pool debugfs file. drm/ttm: Add debugfs output entry to pool allocator. drm/ttm: add pool wc/uc page allocator V3
2010-04-06arch/x86: Add array variants for setting memory to wc caching.Pauli Nieminen
Setting single memory pages at a time to wc takes a lot time in cache flush. To reduce number of cache flush set_pages_array_wc and set_memory_array_wc can be used to set multiple pages to WC with single cache flush. This improves allocation performance for wc cached pages in drm/ttm. CC: Suresh Siddha <suresh.b.siddha@intel.com> CC: Venkatesh Pallipadi <venkatesh.pallipadi@gmail.com> Signed-off-by: Pauli Nieminen <suokkos@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-22x86_64, cpa: Don't work hard in preserving kernel 2M mappings when using 4K ↵Suresh Siddha
already We currently enforce the !RW mapping for the kernel mapping that maps holes between different text, rodata and data sections. However, kernel identity mappings will have different RWX permissions to the pages mapping to text and to the pages padding (which are freed) the text, rodata sections. Hence kernel identity mappings will be broken to smaller pages. For 64-bit, kernel text and kernel identity mappings are different, so we can enable protection checks that come with CONFIG_DEBUG_RODATA, as well as retain 2MB large page mappings for kernel text. Konrad reported a boot failure with the Linux Xen paravirt guest because of this. In this paravirt guest case, the kernel text mapping and the kernel identity mapping share the same page-table pages. Thus forcing the !RW mapping for some of the kernel mappings also cause the kernel identity mappings to be read-only resulting in the boot failure. Linux Xen paravirt guest also uses 4k mappings and don't use 2M mapping. Fix this issue and retain large page performance advantage for native kernels by not working hard and not enforcing !RW for the kernel text mapping, if the current mapping is already using small page mapping. Reported-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <1266522700.2909.34.camel@sbs-t61.sc.intel.com> Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: stable@kernel.org [2.6.32, 2.6.33] Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-11-16x86, pageattr: Make set_memory_(x|nx) aware of NX supportH. Peter Anvin
Make set_memory_x/set_memory_nx directly aware of if NX is supported in the system or not, rather than requiring that every caller assesses that support independently. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Huang Ying <ying.huang@intel.com> Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tejun Heo <tj@kernel.org> Cc: Tim Starling <tstarling@wikimedia.org> Cc: Hannes Eder <hannes@hanneseder.net> LKML-Reference: <1258154897-6770-4-git-send-email-hpa@zytor.com> Acked-by: Kees Cook <kees.cook@canonical.com>
2009-11-02x86_64, ftrace: Make ftrace use kernel identity mapping to modify codeSuresh Siddha
On x86_64, kernel text mappings are mapped read-only with CONFIG_DEBUG_RODATA. So use the kernel identity mapping instead of the kernel text mapping to modify the kernel text. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Tested-by: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <20091029024821.080941108@sbs-t61.sc.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-02x86, cpa: Fix kernel text RO checks in static_protection()Suresh Siddha
Steven Rostedt reported that we are unconditionally making the kernel text mapping as read-only. i.e., if someone does cpa() to the kernel text area for setting/clearing any page table attribute, we unconditionally clear the read-write attribute for the kernel text mapping that is set at compile time. We should delay (to forbid the write attribute) and enforce only after the kernel has mapped the text as read-only. Reported-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Tested-by: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <20091029024820.996634347@sbs-t61.sc.intel.com> [ marked kernel_set_to_readonly as __read_mostly ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-27tracing: allow to change permissions for text with dynamic ftrace enabledSteven Rostedt
The commit 74e081797bd9d2a7d8005fe519e719df343a2ba8 x86-64: align RODATA kernel section to 2MB with CONFIG_DEBUG_RODATA prevents text sections from becoming read/write using set_memory_rw. The dynamic ftrace changes all text pages to read/write just before converting the calls to tracing to nops, and vice versa. I orginally just added a flag to allow this transaction when ftrace did the change, but I also found that when the CPA testing was running it would remove the read/write as well, and ftrace does not do the text conversion on boot up, and the CPA changes caused the dynamic tracer to fail on self tests. The current solution I have is to simply not to prevent change_page_attr from setting the RW bit for kernel text pages. Reported-by: Ingo Molnar <mingo@elte.hu> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-10-20x86-64: align RODATA kernel section to 2MB with CONFIG_DEBUG_RODATASuresh Siddha
CONFIG_DEBUG_RODATA chops the large pages spanning boundaries of kernel text/rodata/data to small 4KB pages as they are mapped with different attributes (text as RO, RODATA as RO and NX etc). On x86_64, preserve the large page mappings for kernel text/rodata/data boundaries when CONFIG_DEBUG_RODATA is enabled. This is done by allowing the RODATA section to be hugepage aligned and having same RWX attributes for the 2MB page boundaries Extra Memory pages padding the sections will be freed during the end of the boot and the kernel identity mappings will have different RWX permissions compared to the kernel text mappings. Kernel identity mappings to these physical pages will be mapped with smaller pages but large page mappings are still retained for kernel text,rodata,data mappings. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <20091014220254.190119924@sbs-t61.sc.intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-09-24Merge branch 'drm-intel-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel * 'drm-intel-next' of git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel: (57 commits) drm/i915: Handle ERESTARTSYS during page fault drm/i915: Warn before mmaping a purgeable buffer. drm/i915: Track purged state. drm/i915: Remove eviction debug spam drm/i915: Immediately discard any backing storage for uneeded objects drm/i915: Do not mis-classify clean objects as purgeable drm/i915: Whitespace correction for madv drm/i915: BUG_ON page refleak during unbind drm/i915: Search harder for a reusable object drm/i915: Clean up evict from list. drm/i915: Add tracepoints drm/i915: framebuffer compression for GM45+ drm/i915: split display functions by chip type drm/i915: Skip the sanity checks if the current relocation is valid drm/i915: Check that the relocation points to within the target drm/i915: correct FBC update when pipe base update occurs drm/i915: blacklist Acer AspireOne lid status ACPI: make ACPI button funcs no-ops if not built in drm/i915: prevent FIFO calculation overflows on 32 bits with high dotclocks drm/i915: intel_display.c handle latency variable efficiently ... Fix up trivial conflicts in drivers/gpu/drm/i915/{i915_dma.c|i915_drv.h}
2009-09-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (46 commits) powerpc64: convert to dynamic percpu allocator sparc64: use embedding percpu first chunk allocator percpu: kill lpage first chunk allocator x86,percpu: use embedding for 64bit NUMA and page for 32bit NUMA percpu: update embedding first chunk allocator to handle sparse units percpu: use group information to allocate vmap areas sparsely vmalloc: implement pcpu_get_vm_areas() vmalloc: separate out insert_vmalloc_vm() percpu: add chunk->base_addr percpu: add pcpu_unit_offsets[] percpu: introduce pcpu_alloc_info and pcpu_group_info percpu: move pcpu_lpage_build_unit_map() and pcpul_lpage_dump_cfg() upward percpu: add @align to pcpu_fc_alloc_fn_t percpu: make @dyn_size mandatory for pcpu_setup_first_chunk() percpu: drop @static_size from first chunk allocators percpu: generalize first chunk allocator selection percpu: build first chunk allocators selectively percpu: rename 4k first chunk allocator to page percpu: improve boot messages percpu: fix pcpu_reclaim() locking ... Fix trivial conflict as by Tejun Heo in kernel/sched.c
2009-09-11agp/intel: Fix the pre-9xx chipset flush.Eric Anholt
Ever since we enabled GEM, the pre-9xx chipsets (particularly 865) have had serious stability issues. Back in May a wbinvd was added to the DRM to work around much of the problem. Some failure remained -- easily visible by dragging a window around on an X -retro desktop, or by looking at bugzilla. The chipset flush was on the right track -- hitting the right amount of memory, and it appears to be the only way to flush on these chipsets, but the flush page was mapped uncached. As a result, the writes trying to clear the writeback cache ended up bypassing the cache, and not flushing anything! The wbinvd would flush out other writeback data and often cause the data we wanted to get flushed, but not always. By removing the setting of the page to UC and instead just clflushing the data we write to try to flush it, we get the desired behavior with no wbinvd. This exports clflush_cache_range(), which was laying around and happened to basically match the code I was otherwise going to copy from the DRM. Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Brice Goglin <Brice.Goglin@ens-lyon.org> Cc: stable@kernel.org
2009-09-09x86, pat: Fix cacheflush address in change_page_attr_set_clr()Jack Steiner
Fix address passed to cpa_flush_range() when changing page attributes from WB to UC. The address (*addr) is modified by __change_page_attr_set_clr(). The result is that the pages being flushed start at the _end_ of the changed range instead of the beginning. This should be considered for 2.6.30-stable and 2.6.31-stable. Signed-off-by: Jack Steiner <steiner@sgi.com> Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Stable team <stable@kernel.org>
2009-08-14percpu: kill lpage first chunk allocatorTejun Heo
With x86 converted to embedding allocator, lpage doesn't have any user left. Kill it along with cpa handling code. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jan Beulich <JBeulich@novell.com>
2009-08-14Merge branch 'percpu-for-linus' into percpu-for-nextTejun Heo
Conflicts: arch/sparc/kernel/smp_64.c arch/x86/kernel/cpu/perf_counter.c arch/x86/kernel/setup_percpu.c drivers/cpufreq/cpufreq_ondemand.c mm/percpu.c Conflicts in core and arch percpu codes are mostly from commit ed78e1e078dd44249f88b1dd8c76dafb39567161 which substituted many num_possible_cpus() with nr_cpu_ids. As for-next branch has moved all the first chunk allocators into mm/percpu.c, the changes are moved from arch code to mm/percpu.c. Signed-off-by: Tejun Heo <tj@kernel.org>
2009-08-03x86: Fix CPA memtype reserving in the set_pages_array*() casesThomas Hellstrom
The code was incorrectly reserving memtypes using the page virtual address instead of the physical address. Furthermore, the code was not ignoring highmem pages as it ought to. ( upstream does not pass in highmem pages yet - but upcoming graphics code will do it and there's no reason to not handle this properly in the CPA APIs.) Fixes: http://bugzilla.kernel.org/show_bug.cgi?id=13884 Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: <stable@kernel.org> Cc: dri-devel@lists.sourceforge.net Cc: venkatesh.pallipadi@intel.com LKML-Reference: <1249284345-7654-1-git-send-email-thellstrom@vmware.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-30x86, pat: Fix set_memory_wc related corruptionPallipadi, Venkatesh
Changeset 3869c4aa18835c8c61b44bd0f3ace36e9d3b5bd0 that went in after 2.6.30-rc1 was a seemingly small change to _set_memory_wc() to make it complaint with SDM requirements. But, introduced a nasty bug, which can result in crash and/or strange corruptions when set_memory_wc is used. One such crash reported here http://lkml.org/lkml/2009/7/30/94 Actually, that changeset introduced two bugs. * change_page_attr_set() takes &addr as first argument and can the addr value might have changed on return, even for single page change_page_attr_set() call. That will make the second change_page_attr_set() in this routine operate on unrelated addr, that can eventually cause strange corruptions and bad page state crash. * The second change_page_attr_set() call, before setting _PAGE_CACHE_WC, should clear the earlier _PAGE_CACHE_UC_MINUS, as otherwise cache attribute will not be WC (will be UC instead). The patch below fixes both these problems. Sending a single patch to fix both the problems, as the change is to the same line of code. The change to have a addr_copy is not very clean. But, it is simpler than making more changes through various routines in pageattr.c. A huge thanks to Jerome for reporting this problem and providing a simple test case that helped us root cause the problem. Reported-by: Jerome Glisse <glisse@freedesktop.org> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <20090730214319.GA1889@linux-os.sc.intel.com> Acked-by: Dave Airlie <airlied@redhat.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-07-04x86,percpu: generalize lpage first chunk allocatorTejun Heo
Generalize and move x86 setup_pcpu_lpage() into pcpu_lpage_first_chunk(). setup_pcpu_lpage() now is a simple wrapper around the generalized version. Other than taking size parameters and using arch supplied callbacks to allocate/free/map memory, pcpu_lpage_first_chunk() is identical to the original implementation. This simplifies arch code and will help converting more archs to dynamic percpu allocator. While at it, factor out pcpu_calc_fc_sizes() which is common to pcpu_embed_first_chunk() and pcpu_lpage_first_chunk(). [ Impact: code reorganization and generalization ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@elte.hu>
2009-06-22x86: fix pageattr handling for lpage percpu allocator and re-enable itTejun Heo
lpage allocator aliases a PMD page for each cpu and returns whatever is unused to the page allocator. When the pageattr of the recycled pages are changed, this makes the two aliases point to the overlapping regions with different attributes which isn't allowed and known to cause subtle data corruption in certain cases. This can be handled in simliar manner to the x86_64 highmap alias. pageattr code should detect if the target pages have PMD alias and split the PMD alias and synchronize the attributes. pcpur allocator is updated to keep the allocated PMD pages map sorted in ascending address order and provide pcpu_lpage_remapped() function which binary searches the array to determine whether the given address is aliased and if so to which address. pageattr is updated to use pcpu_lpage_remapped() to detect the PMD alias and split it up as necessary from cpa_process_alias(). Jan Beulich spotted the original problem and incorrect usage of vaddr instead of laddr for lookup. With this, lpage percpu allocator should work correctly. Re-enable it. [ Impact: fix subtle lpage pageattr bug and re-enable lpage ] Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Jan Beulich <JBeulich@novell.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu>
2009-06-22x86: reorganize cpa_process_alias()Tejun Heo
Reorganize cpa_process_alias() so that new alias condition can be added easily. Jan Beulich spotted problem in the original cleanup thread which incorrectly assumed the two existing conditions were mutially exclusive. [ Impact: code reorganization ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jan Beulich <JBeulich@novell.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu>
2009-06-15kmemcheck: don't track page tablesVegard Nossum
As these are allocated using the page allocator, we need to pass __GFP_NOTRACK before we add page allocator support to kmemcheck. Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
2009-06-10Merge branch 'x86-xen-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-xen-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (42 commits) xen: cache cr0 value to avoid trap'n'emulate for read_cr0 xen/x86-64: clean up warnings about IST-using traps xen/x86-64: fix breakpoints and hardware watchpoints xen: reserve Xen start_info rather than e820 reserving xen: add FIX_TEXT_POKE to fixmap lguest: update lazy mmu changes to match lguest's use of kvm hypercalls xen: honour VCPU availability on boot xen: add "capabilities" file xen: drop kexec bits from /sys/hypervisor since kexec isn't implemented yet xen/sys/hypervisor: change writable_pt to features xen: add /sys/hypervisor support xen/xenbus: export xenbus_dev_changed xen: use device model for suspending xenbus devices xen: remove suspend_cancel hook xen/dev-evtchn: clean up locking in evtchn xen: export ioctl headers to userspace xen: add /dev/xen/evtchn driver xen: add irq_from_evtchn xen: clean up gate trap/interrupt constants xen: set _PAGE_NX in __supported_pte_mask before pagetable construction ...
2009-05-26x86: avoid back to back on_each_cpu in cpa_flush_arrayPallipadi, Venkatesh
Cleanup cpa_flush_array() to avoid back to back on_each_cpu() calls. [ Impact: optimizes fix 0af48f42df15b97080b450d24219dd95db7b929a ] Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-05-22x86: cpa_flush_array wbinvd should be done on all CPUsvenkatesh.pallipadi@intel.com
cpa_flush_array seems to prefer wbinvd() over clflush at 4M threshold. clflush needs to be done on only one CPU as per instruction definition. wbinvd() however, should be done on all CPUs. [ Impact: fix missing flush which could cause data corruption ] Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-05-22x86: bugfix wbinvd() model check instead of family checkvenkatesh.pallipadi@intel.com
wbinvd is supported on all CPUs 486 or later. But, pageattr.c is checking x86_model >= 4 before wbinvd(), which looks like an oversight bug. It was first introduced at one place by changeset d7c8f21a8cad0228c7c5ce2bb6dbd95d1ee49d13 and got copied over to second place in the same file later. [ Impact: fix missing cache flush on early-model CPUs, potential data corruption ] Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-05-08Merge branch 'x86/urgent' into x86/xenIngo Molnar
Conflicts: arch/frv/include/asm/pgtable.h arch/x86/include/asm/required-features.h arch/x86/xen/mmu.c Merge reason: x86/xen was on a .29 base still, move it to a fresher branch and pick up Xen fixes as well, plus resolve conflicts Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-10x86, PAT: Changing memtype to WC ensuring no WB aliasvenkatesh.pallipadi@intel.com
As per SDM, there should not be any aliasing of a WC with any cacheable type across CPUs. That is if one CPU is changing the identity map memtype to _WC, no other CPU at the time of this change should not have a TLB for this page that carries a WB attribute. SDM suggests to make the page not present. But for that we will have to handle any page faults that can potentially happen due to these pages being not present. Other way to deal with this without having any WB mapping is to change the page first to UC and then to WC. This ensures that we meet the SDM requirement of no cacheable alais to WC page. This also has same or lower overhead than marking the page not present and making it present later. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <20090409212708.797481000@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-10x86, PAT: Handle faults cleanly in set_memory_ APIsvenkatesh.pallipadi@intel.com
Handle faults and do proper cleanups in set_memory_*() functions. In some cases, these functions were not doing proper free on failure paths. With the changes to tracking memtype of RAM pages in struct page instead of pat list, we do not need the changes in commits c5e147. This patch reverts that change. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <20090409212708.653222000@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-10x86, PAT: Change order of cpa and free in set_memory_wbvenkatesh.pallipadi@intel.com
To be free of aliasing due to races, set_memory_* interfaces should follow ordering of reserving, changing memtype to UC/WC, changing memtype back to WB followed by free. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <20090409212708.512280000@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-07Merge commit 'origin/master' into for-linus/xen/masterJeremy Fitzhardinge
* commit 'origin/master': (4825 commits) Fix build errors due to CONFIG_BRANCH_TRACER=y parport: Use the PCI IRQ if offered tty: jsm cleanups Adjust path to gpio headers KGDB_SERIAL_CONSOLE check for module Change KCONFIG name tty: Blackin CTS/RTS Change hardware flow control from poll to interrupt driven Add support for the MAX3100 SPI UART. lanana: assign a device name and numbering for MAX3100 serqt: initial clean up pass for tty side tty: Use the generic RS485 ioctl on CRIS tty: Correct inline types for tty_driver_kref_get() splice: fix deadlock in splicing to file nilfs2: support nanosecond timestamp nilfs2: introduce secondary super block nilfs2: simplify handling of active state of segments nilfs2: mark minor flag for checkpoint created by internal operation nilfs2: clean up sketch file nilfs2: super block operations fix endian bug ... Conflicts: arch/x86/include/asm/thread_info.h arch/x86/lguest/boot.c drivers/xen/manage.c
2009-03-29x86/paravirt: remove lazy mode in interruptsJeremy Fitzhardinge
Impact: simplification, robustness Make paravirt_lazy_mode() always return PARAVIRT_LAZY_NONE when in an interrupt. This prevents interrupt code from accidentally inheriting an outer lazy state, and instead does everything synchronously. Outer batched operations are left deferred. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de>
2009-03-27Merge branch 'core/percpu' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/parisc/kernel/irq.c arch/x86/include/asm/fixmap_64.h arch/x86/include/asm/setup.h kernel/irq/handle.c Semantic merge: arch/x86/include/asm/fixmap.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-20x86, CPA: Add set_pages_arrayuc and set_pages_array_wbvenkatesh.pallipadi@intel.com
Add new interfaces: set_pages_array_uc() set_pages_array_wb() that can be used change the page attribute for a bunch of pages with flush etc done once at the end of all the changes. These interfaces are similar to existing set_memory_array_uc() and set_memory_array_wc(). Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: arjan@infradead.org Cc: eric@anholt.net Cc: airlied@redhat.com LKML-Reference: <20090319215358.901545000@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-20x86, PAT: Add support for struct page pointer array in cpa set_clrvenkatesh.pallipadi@intel.com
Add struct page array pointer to cpa struct and CPA_PAGES_ARRAY. With that we can add change_page_attr_set_clr() a parameter to pass struct page array pointer and that can be handled by the underlying cpa code. cpa_flush_array() is also changed to support both addr array or struct page pointer array, depending on the flag. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: arjan@infradead.org Cc: eric@anholt.net Cc: airlied@redhat.com LKML-Reference: <20090319215358.758513000@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-20x86, CPA: Add a flag parameter to cpa set_clr()venkatesh.pallipadi@intel.com
Change change_page_attr_set_clr() array parameter to a flag. This helps following patches which adds an interface to change attr to uc/wb over a set of pages referred by struct page. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: arjan@infradead.org Cc: eric@anholt.net Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: airlied@redhat.com LKML-Reference: <20090319215358.611346000@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-14x86: add brk allocation for very, very early allocationsJeremy Fitzhardinge
Impact: new interface Add a brk()-like allocator which effectively extends the bss in order to allow very early code to do dynamic allocations. This is better than using statically allocated arrays for data in subsystems which may never get used. The space for brk allocations is in the bss ELF segment, so that the space is mapped properly by the code which maps the kernel, and so that bootloaders keep the space free rather than putting a ramdisk or something into it. The bss itself, delimited by __bss_stop, ends before the brk area (__brk_base to __brk_limit). The kernel text, data and bss is reserved up to __bss_stop. Any brk-allocated data is reserved separately just before the kernel pagetable is built, as that code allocates from unreserved spaces in the e820 map, potentially allocating from any unused brk memory. Ultimately any unused memory in the brk area is used in the general kernel memory pool. Initially the brk space is set to 1MB, which is probably much larger than any user needs (the largest current user is i386 head_32.S's code to build the pagetables to map the kernel, which can get fairly large with a big kernel image and no PSE support). So long as the system has sufficient memory for the bootloader to reserve the kernel+1MB brk, there are no bad effects resulting from an over-large brk. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-03-12Merge branches 'x86/asm', 'x86/debug', 'x86/mm', 'x86/setup', 'x86/urgent' ↵Ingo Molnar
and 'linus' into x86/core
2009-03-11x86: work around Fedora-11 x86-32 kernel failures on Intel Atom CPUsIngo Molnar
Impact: work around boot crash Work around Intel Atom erratum AAH41 (probabilistically) - it's triggering in the field. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Tested-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-20x86, pat: add large-PAT check to split_large_page()Ingo Molnar
Impact: future-proof the split_large_page() function Linus noticed that split_large_page() is not safe wrt. the PAT bit: it is bit 12 on the 1GB and 2MB page table level (_PAGE_BIT_PAT_LARGE), and it is bit 7 on the 4K page table level (_PAGE_BIT_PAT). Currently it is not a problem because we never set _PAGE_BIT_PAT_LARGE on any of the large-page mappings - but should this happen in the future the split_large_page() would silently lift bit 12 into the lowlevel 4K pte and would start corrupting the physical page frame offset. Not fun. So add a debug warning, to make sure if something ever sets the PAT bit then this function gets updated too. Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-20x86: use the right protections for split-up pagetablesIngo Molnar
Steven Rostedt found a bug in where in his modified kernel ftrace was unable to modify the kernel text, due to the PMD itself having been marked read-only as well in split_large_page(). The fix, suggested by Linus, is to not try to 'clone' the reference protection of a huge-page, but to use the standard (and permissive) page protection bits of KERNPG_TABLE. The 'cloning' makes sense for the ptes but it's a confused and incorrect concept at the page table level - because the pagetable entry is a set of all ptes and hence cannot 'clone' any single protection attribute - the ptes can be any mixture of protections. With the permissive KERNPG_TABLE, even if the pte protections get changed after this point (due to ftrace doing code-patching or other similar activities like kprobes), the resulting combined protections will still be correct and the pte's restrictive (or permissive) protections will control it. Also update the comment. This bug was there for a long time but has not caused visible problems before as it needs a rather large read-only area to trigger. Steve possibly hacked his kernel with some really large arrays or so. Anyway, the bug is definitely worth fixing. [ Huang Ying also experienced problems in this area when writing the EFI code, but the real bug in split_large_page() was not realized back then. ] Reported-by: Steven Rostedt <rostedt@goodmis.org> Reported-by: Huang Ying <ying.huang@intel.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-12x86: CPA avoid repeated lazy mmu flushThomas Gleixner
Impact: Flush the lazy MMU only once Pending mmu updates only need to be flushed once to bring the in-memory pagetable state up to date. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
