path: root/arch/x86/mm/kmmio.c
2010-06-18x86, kmmio/mmiotrace: Fix double free of kmmio_fault_pagesMarcin Slusarz
After every iounmap mmiotrace has to free kmmio_fault_pages, but it can't do it directly, so it defers freeing by RCU. It usually works, but when mmiotraced code calls ioremap-iounmap multiple times without sleeping between (so RCU won't kick in and start freeing) it can be given the same virtual address, so at every iounmap mmiotrace will schedule the same pages for release. Obviously it will explode on second free. Fix it by marking kmmio_fault_pages which are scheduled for release and not adding them second time. Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Tested-by: Marcin Kocielnicki <koriakin@0x04.net> Tested-by: Shinpei KATO <shinpei@il.is.s.u-tokyo.ac.jp> Acked-by: Pekka Paalanen <pq@iki.fi> Cc: Stuart Bennett <stuart@freedesktop.org> Cc: Marcin Kocielnicki <koriakin@0x04.net> Cc: nouveau@lists.freedesktop.org Cc: <stable@kernel.org> LKML-Reference: <20100613215654.GA3829@joi.lan> Signed-off-by: Ingo Molnar <mingo@elte.hu>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-17hw-breakpoints, perf: Fix broken mmiotrace due to dr6 by reference changeLuca Barbieri
Commit 62edab9056a6cf0c9207339c8892c923a5217e45 (from June 2009 but merged in 2.6.33) changes notify_die to pass dr6 by reference. However, it forgets to fix the check for DR_STEP in kmmio.c, breaking mmiotrace. It also passes a wrong value to the post handler. This simple fix makes mmiotrace work again. Signed-off-by: Luca Barbieri <luca@luca-barbieri.com> Acked-by: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <1263634770-14578-1-git-send-email-luca@luca-barbieri.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-11Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86/amd-iommu: Fix PCI hotplug with passthrough mode x86/amd-iommu: Fix passthrough mode x86: mmio-mod.c: Use pr_fmt x86: kmmio.c: Add and use pr_fmt(fmt) x86: i8254.c: Add pr_fmt(fmt) x86: setup_percpu.c: Use pr_<level> and add pr_fmt(fmt) x86: es7000_32.c: Use pr_<level> and add pr_fmt(fmt) x86: Print DMI_BOARD_NAME as well as DMI_PRODUCT_NAME from __show_regs() x86: Factor duplicated code out of __show_regs() into show_regs_common() arch/x86/kernel/microcode*: Use pr_fmt() and remove duplicated KERN_ERR prefix x86, mce: fix confusion between bank attributes and mce attributes x86/mce: Set up timer unconditionally x86: Fix bogus warning in apic_noop.apic_write() x86: Fix typo in arch/x86/mm/kmmio.c x86: ASUS P4S800 reboot=bios quirk
2009-12-10x86: kmmio.c: Add and use pr_fmt(fmt)Joe Perches
- Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt - Strip "kmmio: " from pr_<level>s Signed-off-by: Joe Perches <joe@perches.com> LKML-Reference: <7aa509f8a23933036d39f54bd51e9acc52068049.1260383912.git.joe@perches.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-07Merge branch 'linus' into x86/urgentIngo Molnar
Merge reason: we want to queue up a dependent fix. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-06x86: Fix typo in arch/x86/mm/kmmio.cShaun Patterson
Signed-off-by: Shaun Patterson <shaunpatterson@gmail.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: pq@iki.fi LKML-Reference: <1260027694.10074.170.camel@linux-4lgc.site> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-02hw-breakpoints: reset bits in dr6 after the corresponding exception is handledK.Prasad
This patch resets the bit in dr6 after the corresponding exception is handled in code, so that we keep a clean track of the current virtual debug status register. [ Impact: keep track of breakpoints triggering completion ] Signed-off-by: K.Prasad <prasad@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-05-07Merge branch 'linus' into tracing/coreIngo Molnar
Merge reason: tracing/core was on a .30-rc1 base and was missing out on on a handful of tracing fixes present in .30-rc5-almost. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-29tracing: x86, mmiotrace: only register for die notifier when tracer activeStuart Bennett
Follow up to afcfe024aebd74b0984a41af9a34e009cf5badaf in Linus' tree ("x86: mmiotrace: quieten spurious warning message") Signed-off-by: Stuart Bennett <stuart@freedesktop.org> Acked-by: Pekka Paalanen <pq@iki.fi> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1240946271-7083-5-git-send-email-stuart@freedesktop.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-29tracing: x86, mmiotrace: refactor clearing/restore of page presenceStuart Bennett
* change function names to clear_* from set_*: in reality we only clear and restore page presence, and never unconditionally set present. Using clear_*({true, false}, ...) is therefore more honest than set_*({false, true}, ...) * upgrade presence storage to pteval_t: doing user-space tracing will require saving and manipulation of the _PAGE_PROTNONE bit, in addition to the existing _PAGE_PRESENT changes, and having multiple bools stored and passed around does not seem optimal [ Impact: refactor, clean up mmiotrace code ] Signed-off-by: Stuart Bennett <stuart@freedesktop.org> Acked-by: Pekka Paalanen <pq@iki.fi> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1240946271-7083-4-git-send-email-stuart@freedesktop.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-29tracing: x86, mmiotrace: code consistency/legibility improvementStuart Bennett
kmmio_probe being *p and kmmio_fault_page being sometimes *f and sometimes *p is not helpful. [ Impact: cleanup ] Signed-off-by: Stuart Bennett <stuart@freedesktop.org> Acked-by: Pekka Paalanen <pq@iki.fi> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1240946271-7083-3-git-send-email-stuart@freedesktop.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-29tracing: x86, mmiotrace: fix range testStuart Bennett
Matching on (addr == (p->addr + p->len)) causes problems when mappings are adjacent. [ Impact: fix mmiotrace confusion on adjacent iomaps ] Signed-off-by: Stuart Bennett <stuart@freedesktop.org> Acked-by: Pekka Paalanen <pq@iki.fi> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1240946271-7083-2-git-send-email-stuart@freedesktop.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-11x86: mmiotrace: quieten spurious warning messageStuart Bennett
This message was being incorrectly emitted when using gdb, so compile it out by default for now; there will be a better fix in v2.6.30. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Stuart Bennett <stuart@freedesktop.org> Acked-by: Pekka Paalanen <pq@iki.fi> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-08x86 mmiotrace: fix remove_kmmio_fault_pages()Stuart Bennett
Impact: fix race+crash in mmiotrace The list manipulation in remove_kmmio_fault_pages() was broken. If more than one consecutive kmmio_fault_page was re-added during the grace period between unregister_kmmio_probe() and remove_kmmio_fault_pages(), the list manipulation failed to remove pages from the release list. After a second grace period the pages get into rcu_free_kmmio_fault_pages() and raise a BUG_ON() kernel crash. The list manipulation is fixed to properly remove pages from the release list. This bug has been present from the very beginning of mmiotrace in the mainline kernel. It was introduced in 0fd0e3da ("x86: mmiotrace full patch, preview 1"); An urgent fix for Linus. Tested by Stuart (on 32-bit) and Pekka (on amd and intel 64-bit systems, nouveau and nvidia proprietary). Signed-off-by: Stuart Bennett <stuart@freedesktop.org> Signed-off-by: Pekka Paalanen <pq@iki.fi> LKML-Reference: <20090308202135.34933feb@daedalus.pq.iki.fi> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-02x86 mmiotrace: fix race with release_kmmio_fault_page()Pekka Paalanen
There was a theoretical possibility to a race between arming a page in post_kmmio_handler() and disarming the page in release_kmmio_fault_page(): cpu0 cpu1 ------------------------------------------------------------------ mmiotrace shutdown enter release_kmmio_fault_page fault on the page disarm the page disarm the page handle the MMIO access re-arm the page put the page on release list remove_kmmio_fault_pages() fault on the page page not known to mmiotrace fall back to do_page_fault() *KABOOM* (This scenario also shows the double disarm case which is allowed.) Fixed by acquiring kmmio_lock in post_kmmio_handler() and checking if the page is being released from mmiotrace. Signed-off-by: Pekka Paalanen <pq@iki.fi> Cc: Stuart Bennett <stuart@freedesktop.org> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-02x86 mmiotrace: improve handling of secondary faultsStuart Bennett
Upgrade some kmmio.c debug messages to warnings. Allow secondary faults on probed pages to fall through, and only log secondary faults that are not due to non-present pages. Patch edited by Pekka Paalanen. Signed-off-by: Stuart Bennett <stuart@freedesktop.org> Signed-off-by: Pekka Paalanen <pq@iki.fi> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-02x86 mmiotrace: split set_page_presence()Pekka Paalanen
From 36772dcb6ffbbb68254cbfc379a103acd2fbfefc Mon Sep 17 00:00:00 2001 From: Pekka Paalanen <pq@iki.fi> Date: Sat, 28 Feb 2009 21:34:59 +0200 Split set_page_presence() in kmmio.c into two more functions set_pmd_presence() and set_pte_presence(). Purely code reorganization, no functional changes. Signed-off-by: Pekka Paalanen <pq@iki.fi> Cc: Stuart Bennett <stuart@freedesktop.org> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-02x86 mmiotrace: fix save/restore page table statePekka Paalanen
From baa99e2b32449ec7bf147c234adfa444caecac8a Mon Sep 17 00:00:00 2001 From: Pekka Paalanen <pq@iki.fi> Date: Sun, 22 Feb 2009 20:02:43 +0200 Blindly setting _PAGE_PRESENT in disarm_kmmio_fault_page() overlooks the possibility, that the page was not present when it was armed. Make arm_kmmio_fault_page() store the previous page presence in struct kmmio_fault_page and use it on disarm. This patch was originally written by Stuart Bennett, but Pekka Paalanen rewrote it a little different. Signed-off-by: Pekka Paalanen <pq@iki.fi> Cc: Stuart Bennett <stuart@freedesktop.org> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-02x86 mmiotrace: WARN_ONCE if dis/arming a page failsStuart Bennett
Print a full warning once, if arming or disarming a page fails. Also, if initial arming fails, do not handle the page further. This avoids the possibility of a page failing to arm and then later claiming to have handled any fault on that page. WARN_ONCE added by Pekka Paalanen. Signed-off-by: Stuart Bennett <stuart@freedesktop.org> Signed-off-by: Pekka Paalanen <pq@iki.fi> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-25- fix mmioftrace + rcu merge interactionIngo Molnar
2008-05-24x86 mmiotrace: page level is unsignedPekka Paalanen
Fixes some sparse warnings. Signed-off-by: Pekka Paalanen <pq@iki.fi> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-24x86 mmiotrace: fix page-unaligned ioremapsPekka Paalanen
mmiotrace_ioremap() expects to receive the original unaligned map phys address and size. Also fix {un,}register_kmmio_probe() to deal properly with unaligned size. Signed-off-by: Pekka Paalanen <pq@iki.fi> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-24mmiotrace: code style cleanupsPekka Paalanen
From c2da03771e29159627c5c7b9509ec70bce9f91ee Mon Sep 17 00:00:00 2001 From: Pekka Paalanen <pq@iki.fi> Date: Mon, 28 Apr 2008 21:25:22 +0300 Signed-off-by: Pekka Paalanen <pq@iki.fi> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-24x86 mmiotrace: move files into arch/x86/mm/.Pekka Paalanen
Signed-off-by: Pekka Paalanen <pq@iki.fi> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
