path: root/arch/x86/math-emu
2019-01-03Remove 'type' argument from access_ok() functionLinus Torvalds
Nobody has actually used the type (VERIFY_READ vs VERIFY_WRITE) argument of the user address range verification function since we got rid of the old racy i386-only code to walk page tables by hand. It existed because the original 80386 would not honor the write protect bit when in kernel mode, so you had to do COW by hand before doing any user access. But we haven't supported that in a long time, and these days the 'type' argument is a purely historical artifact. A discussion about extending 'user_access_begin()' to do the range checking resulted this patch, because there is no way we're going to move the old VERIFY_xyz interface to that model. And it's best done at the end of the merge window when I've done most of my merges, so let's just get this done once and for all. This patch was mostly done with a sed-script, with manual fix-ups for the cases that weren't of the trivial 'access_ok(VERIFY_xyz' form. There were a couple of notable cases: - csky still had the old "verify_area()" name as an alias. - the iter_iov code had magical hardcoded knowledge of the actual values of VERIFY_{READ,WRITE} (not that they mattered, since nothing really used it) - microblaze used the type argument for a debug printout but other than those oddities this should be a total no-op patch. I tried to fix up all architectures, did fairly extensive grepping for access_ok() uses, and the changes are trivial, but I may have missed something. Any missed conversion should be trivially fixable, though. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-26x86/fpu: Rename fpu__activate_curr() to fpu__initialize()Ingo Molnar
Rename this function to better express that it's all about initializing the FPU state of a task which goes hand in hand with the fpu::initialized field. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Link: http://lkml.kernel.org/r/20170923130016.21448-33-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-09-04Merge branch 'x86-apic-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 apic updates from Thomas Gleixner: "This update provides: - Cleanup of the IDT management including the removal of the extra tracing IDT. A first step to cleanup the vector management code. - The removal of the paravirt op adjust_exception_frame. This is a XEN specific issue, but merged through this branch to avoid nasty merge collisions - Prevent dmesg spam about the TSC DEADLINE bug, when the CPU has disabled the TSC DEADLINE timer in CPUID. - Adjust a debug message in the ioapic code to print out the information correctly" * 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (51 commits) x86/idt: Fix the X86_TRAP_BP gate x86/xen: Get rid of paravirt op adjust_exception_frame x86/eisa: Add missing include x86/idt: Remove superfluous ALIGNment x86/apic: Silence "FW_BUG TSC_DEADLINE disabled due to Errata" on CPUs without the feature x86/idt: Remove the tracing IDT leftovers x86/idt: Hide set_intr_gate() x86/idt: Simplify alloc_intr_gate() x86/idt: Deinline setup functions x86/idt: Remove unused functions/inlines x86/idt: Move interrupt gate initialization to IDT code x86/idt: Move APIC gate initialization to tables x86/idt: Move regular trap init to tables x86/idt: Move IST stack based traps to table init x86/idt: Move debug stack init to table based x86/idt: Switch early trap init to IDT tables x86/idt: Prepare for table based init x86/idt: Move early IDT setup out of 32-bit asm x86/idt: Move early IDT handler setup to IDT code x86/idt: Consolidate IDT invalidation ...
2017-08-29x86/fpu/math-emu: Add ENDPROC to functionsJiri Slaby
Functions in math-emu are annotated as ENTRY() symbols, but their ends are not annotated at all. But these are standard functions called from C, with proper stack register update etc. Omitting the ends means: * the annotations are not paired and we cannot deal with such functions e.g. in objtool * the symbols are not marked as functions in the object file * there are no sizes of the functions in the object file So fix this by adding ENDPROC() to each such case in math-emu. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20170824080624.7768-1-jslaby@suse.cz Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-08-29x86/gdt: Use bitfields for initializationThomas Gleixner
The GDT entry related code uses two ways to access entries via union fields: - bitfields - macros which initialize the two 16-bit parts of the entry by magic shift and mask operations. Clean it up and only use the bitfields to initialize and access entries. ( The old access patterns were partly done due to GCC optimizing bitfield accesses in a horrible way - that's mostly fixed these days and clarity of code in such low level accessors is very important. ) Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/20170828064958.197673367@linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-08-29x86/fpu: Use bitfield accessors for desc_structThomas Gleixner
desc_struct is a union of u32 fields and bitfields. The access to the u32 fields is done with magic macros. Convert it to use the bitfields and replace the macro magic with parseable inline functions. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/20170828064958.042406718@linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-07-20x86/fpu/math-emu: Avoid bogus -Wint-in-bool-context warningArnd Bergmann
gcc-7.1.1 produces this warning: arch/x86/math-emu/reg_add_sub.c: In function 'FPU_add': arch/x86/math-emu/reg_add_sub.c:80:48: error: ?: using integer constants in boolean context [-Werror=int-in-bool-context] This appears to be a bug in gcc-7.1.1, and I have reported it as PR81484. The compiler suggests that code written as if (a & b ? c : d) is usually incorrect and should have been if (a & (b ? c : d)) However, in this case, we correctly write if ((a & b) ? c : d) and should not get a warning for it. This adds a dirty workaround for the problem, adding a comparison with zero inside of the macro. The warning is currently disabled in the kernel, so we may decide not to apply the patch, and instead wait for future gcc releases to fix the problem. On the other hand, it seems to be the only instance of this particular problem. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Bill Metzenthen <billm@melbpc.org.au> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20170719125310.2487451-4-arnd@arndb.de Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=81484 Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-07-20x86/fpu/math-emu: Fix possible uninitialized variable useArnd Bergmann
When building the kernel with "make EXTRA_CFLAGS=...", this overrides the "PARANOID" preprocessor macro defined in arch/x86/math-emu/Makefile, and we run into a build warning: arch/x86/math-emu/reg_compare.c: In function ‘compare_i_st_st’: arch/x86/math-emu/reg_compare.c:254:6: error: ‘f’ may be used uninitialized in this function [-Werror=maybe-uninitialized] This fixes the implementation to work correctly even without the PARANOID flag, and also fixes the Makefile to not use the EXTRA_CFLAGS variable but instead use the ccflags-y variable in the Makefile that is meant for this purpose. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Bill Metzenthen <billm@melbpc.org.au> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20170719125310.2487451-3-arnd@arndb.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-06-08x86/ldt: Rename ldt_struct::size to ::nr_entriesBorislav Petkov
... because this is exactly what it is: the number of entries in the LDT. Calling it "size" is simply confusing and it is actually begging to be called "nr_entries" or somesuch, especially if you see constructs like: alloc_size = size * LDT_ENTRY_SIZE; since LDT_ENTRY_SIZE is the size of a single entry. There should be no functionality change resulting from this patch, as the before/after output from tools/testing/selftests/x86/ldt_gdt.c shows. Signed-off-by: Borislav Petkov <bp@suse.de> Acked-by: Andy Lutomirski <luto@amacapital.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20170606173116.13977-1-bp@alien8.de [ Renamed 'n_entries' to 'nr_entries' ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-12-24Replace <asm/uaccess.h> with <linux/uaccess.h> globallyLinus Torvalds
This was entirely automated, using the script by Al: PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>' sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \ $(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h) to do the replacement at the end of the merge window. Requested-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-03Merge branch 'x86-headers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 sigcontext header cleanups from Ingo Molnar: "This series reorganizes and cleans up various aspects of the main sigcontext UAPI headers, such as unifying the data structures and updating/adding lots of comments to explain all the ABI details and quirks. The headers can now also be built in user-space standalone" * 'x86-headers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/headers: Clean up too long lines x86/headers: Remove <asm/sigcontext.h> references on the kernel side x86/headers: Remove direct sigcontext32.h uses x86/headers: Convert sigcontext_ia32 uses to sigcontext_32 x86/headers: Unify 'struct sigcontext_ia32' and 'struct sigcontext_32' x86/headers: Make sigcontext pointers bit independent x86/headers: Move the 'struct sigcontext' definitions into the UAPI header x86/headers: Clean up the kernel's struct sigcontext types to be ABI-clean x86/headers: Convert uses of _fpstate_ia32 to _fpstate_32 x86/headers: Unify 'struct _fpstate_ia32' and i386 struct _fpstate x86/headers: Unify register type definitions between 32-bit compat and i386 x86/headers: Use ABI types consistently in sigcontext*.h x86/headers: Separate out legacy user-space structure definitions x86/headers: Clean up and better document uapi/asm/sigcontext.h x86/headers: Clean up uapi/asm/sigcontext32.h x86/headers: Fix (old) header file dependency bug in uapi/asm/sigcontext32.h
2015-09-20x86/fpu/math-emu: Add support for FISTTP instructionsDenys Vlasenko
These FPU instructions were added in SSE3-enabled CPUs. Run-tested by booting with "no387 nofxsr" and running test program: [RUN] Testing fisttp instructions [OK] fisttp Signed-off-by: Denys Vlasenko <dvlasenk@redhat.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Kees Cook <keescook@chromium.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Shuah Khan <shuahkh@osg.samsung.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Link: http://lkml.kernel.org/r/1442600614-28428-1-git-send-email-dvlasenk@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-20x86/fpu/math-emu: Add support for FCMOVcc insnsDenys Vlasenko
Run-tested by booting with "no387 nofxsr" and running test program: [RUN] Testing fcmovCC instructions [OK] fcmovCC Signed-off-by: Denys Vlasenko <dvlasenk@redhat.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Kees Cook <keescook@chromium.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Link: http://lkml.kernel.org/r/1442588010-20055-3-git-send-email-dvlasenk@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-20x86/fpu/math-emu: Add support for F[U]COMI[P] insnsDenys Vlasenko
Run-tested by booting with "no387 nofxsr" and running test program: [RUN] Testing f[u]comi[p] instructions [OK] f[u]comi[p] Signed-off-by: Denys Vlasenko <dvlasenk@redhat.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Kees Cook <keescook@chromium.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Link: http://lkml.kernel.org/r/1442588010-20055-2-git-send-email-dvlasenk@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-20x86/fpu/math-emu: Remove define layer for undocumented opcodesDenys Vlasenko
No code changes. Signed-off-by: Denys Vlasenko <dvlasenk@redhat.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Kees Cook <keescook@chromium.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Link: http://lkml.kernel.org/r/1442588010-20055-1-git-send-email-dvlasenk@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-15x86/fpu/math-emu: Remove !NO_UNDOC_CODEDenys Vlasenko
We always want to support all FPU opcodes, including undocumented ones. That define was fully justified ~20 years ago but not today. Let's not complicate the code with it. Signed-off-by: Denys Vlasenko <dvlasenk@redhat.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Kees Cook <keescook@chromium.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1440699330-1305-1-git-send-email-dvlasenk@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-08x86/headers: Remove <asm/sigcontext.h> references on the kernel sideIngo Molnar
Now that all type definitions are in the UAPI header, include it directly, instead of through <asm/sigcontext.h>. [ We still keep asm/sigcontext.h, so that uapi/asm/sigcontext32.h can include <asm/sigcontext.h>. ] Acked-by: Mikko Rapeli <mikko.rapeli@iki.fi> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Link: http://lkml.kernel.org/r/1441438363-9999-16-git-send-email-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-08-18Merge branch 'x86/urgent' into x86/asm to fix up conflicts and to pick up fixesIngo Molnar
Conflicts: arch/x86/entry/entry_64_compat.S arch/x86/math-emu/get_address.c Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-08-16x86/ldt: Further fix FPU emulationAndy Lutomirski
The previous fix confused a selector with a segment prefix. Fix it. Compile-tested only. Cc: stable@vger.kernel.org Cc: Juergen Gross <jgross@suse.com> Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Fixes: 4809146b86c3 ("x86/ldt: Correct FPU emulation access to LDT") Signed-off-by: Andy Lutomirski <luto@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-08-08x86/ldt: Correct FPU emulation access to LDTJuergen Gross
Commit 37868fe113ff ("x86/ldt: Make modify_ldt synchronous") introduced a new struct ldt_struct anchored at mm->context.ldt. Adapt the x86 fpu emulation code to use that new structure. Signed-off-by: Juergen Gross <jgross@suse.com> Reviewed-by: Andy Lutomirski <luto@kernel.org> Cc: <stable@vger.kernel.org> # On top of: 37868fe113ff: x86/ldt: Make modify_ldt synchronous Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: billm@melbpc.org.au Link: http://lkml.kernel.org/r/1438883674-1240-1-git-send-email-jgross@suse.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-31x86/vm86: Clean up vm86.h includesBrian Gerst
vm86.h was being implicitly included in alot of places via processor.h, which in turn got it from math_emu.h. Break that chain and explicitly include vm86.h in all files that need it. Also remove unused vm86 field from math_emu_info. Signed-off-by: Brian Gerst <brgerst@gmail.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1438148483-11932-7-git-send-email-brgerst@gmail.com [ Fixed build failure. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-19x86/fpu: Harmonize FPU register state typesIngo Molnar
Use these consistent names: struct fregs_state # was: i387_fsave_struct struct fxregs_state # was: i387_fxsave_struct struct swregs_state # was: i387_soft_struct struct xregs_state # was: xsave_struct union fpregs_state # was: thread_xstate Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-19x86/fpu: Harmonize the names of the fpstate_init() helper functionsIngo Molnar
Harmonize the inconsistent naming of these related functions: fpstate_init() finit_soft_fpu() => fpstate_init_fsoft() fx_finit() => fpstate_init_fxstate() fx_finit() => fpstate_init_fstate() # split out Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-19x86/fpu: Simplify fpstate_init_curr() usageIngo Molnar
Now that fpstate_init_curr() is not doing implicit allocations anymore, almost all uses of it involve a very simple pattern: if (!fpu->fpstate_active) fpstate_init_curr(fpu); which is basically activating the FPU fpstate if it was not active before. So propagate the check into the function itself, and rename the function according to its new purpose: fpu__activate_curr(fpu); Reviewed-by: Borislav Petkov <bp@alien8.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-19x86/fpu: Rename fpstate_alloc_init() to fpstate_init_curr()Ingo Molnar
Now that there are no FPU context allocations, rename fpstate_alloc_init() to fpstate_init_curr(), to signal that it initializes the fpstate and marks it active, for the current task. Reviewed-by: Borislav Petkov <bp@alien8.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-19x86/fpu: Remove failure return from fpstate_alloc_init()Ingo Molnar
Remove the failure code and propagate this down to callers. Note that this function still has an 'init' aspect, which must be called. Reviewed-by: Borislav Petkov <bp@alien8.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-19x86/fpu: Simplify FPU handling by embedding the fpstate in task_struct (again)Ingo Molnar
So 6 years ago we made the FPU fpstate dynamically allocated: aa283f49276e ("x86, fpu: lazy allocation of FPU area - v5") 61c4628b5386 ("x86, fpu: split FPU state from task struct - v5") In hindsight this was a mistake: - it complicated context allocation failure handling, such as: /* kthread execs. TODO: cleanup this horror. */ if (WARN_ON(fpstate_alloc_init(fpu))) force_sig(SIGKILL, tsk); - it caused us to enable irqs in fpu__restore(): local_irq_enable(); /* * does a slab alloc which can sleep */ if (fpstate_alloc_init(fpu)) { /* * ran out of memory! */ do_group_exit(SIGKILL); return; } local_irq_disable(); - it (slightly) slowed down task creation/destruction by adding slab allocation/free pattens. - it made access to context contents (slightly) slower by adding one more pointer dereference. The motivation for the dynamic allocation was two-fold: - reduce memory consumption by non-FPU tasks - allocate and handle only the necessary amount of context for various XSAVE processors that have varying hardware frame sizes. These days, with glibc using SSE memcpy by default and GCC optimizing for SSE/AVX by default, the scope of FPU using apps on an x86 system is much larger than it was 6 years ago. For example on a freshly installed Fedora 21 desktop system, with a recent kernel, all non-kthread tasks have used the FPU shortly after bootup. Also, even modern embedded x86 CPUs try to support the latest vector instruction set - so they'll too often use the larger xstate frame sizes. So remove the dynamic allocation complication by embedding the FPU fpstate in task_struct again. This should make the FPU a lot more accessible to all sorts of atomic contexts. We could still optimize for the xstate frame size in the future, by moving the state structure to the last element of task_struct, and allocating only a part of that. This change is kept minimal by still keeping the ctx_alloc()/free() routines (that now do nothing substantial) - we'll remove them in the following patches. Reviewed-by: Borislav Petkov <bp@alien8.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-19x86/fpu: Move various internal function prototypes to fpu/internal.hIngo Molnar
There are a number of FPU internal function prototypes and an inline function in fpu/api.h, mostly placed so historically as the code grew over the years. Move them over into fpu/internal.h where they belong. (Add sched.h include to stackprotector.h which incorrectly relied on getting it from fpu/api.h.) fpu/api.h is now a pure file that only contains FPU APIs intended for driver use. Reviewed-by: Borislav Petkov <bp@alien8.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-19x86/fpu: Rename i387.h to fpu/api.hIngo Molnar
We already have fpu/types.h, move i387.h to fpu/api.h. The file name has become a misnomer anyway: it offers generic FPU APIs, but is not limited to i387 functionality. Reviewed-by: Borislav Petkov <bp@alien8.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-19x86/fpu: Use 'struct fpu' in fpstate_alloc_init()Ingo Molnar
Migrate this function to pure 'struct fpu' usage. Reviewed-by: Borislav Petkov <bp@alien8.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-19x86/fpu: Get rid of PF_USED_MATH usage, convert it to fpu->fpstate_activeIngo Molnar
Introduce a simple fpu->fpstate_active flag in the fpu context data structure and use that instead of PF_USED_MATH in task->flags. Testing for this flag byte should be slightly more efficient than testing a bit in a bitmask, but the main advantage is that most FPU functions can now be performed on a 'struct fpu' alone, they don't need access to 'struct task_struct' anymore. There's a slight linecount increase, mostly due to the 'fpu' local variables and due to extra comments. The local variables will go away once we move most of the FPU methods to pure 'struct fpu' parameters. Reviewed-by: Borislav Petkov <bp@alien8.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-19x86/fpu: Open code PF_USED_MATH usagesIngo Molnar
PF_USED_MATH is used directly, but also in a handful of helper inlines. To ease the elimination of PF_USED_MATH, convert all inline helpers to open-coded PF_USED_MATH usage. Reviewed-by: Borislav Petkov <bp@alien8.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-19x86/fpu: Split an fpstate_alloc_init() function out of init_fpu()Ingo Molnar
Most init_fpu() users don't want the register-saving aspect of the function, they are calling it for 'current' and when FPU registers are not allocated and initialized yet. Split out a simplified API that does just that (and add debug-checks for these conditions): fpstate_alloc_init(). Use it where appropriate. Reviewed-by: Borislav Petkov <bp@alien8.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-05asmlinkage, x86: Add explicit __visible to arch/x86/*Andi Kleen
As requested by Linus add explicit __visible to the asmlinkage users. This marks all functions visible to assembler. Tree sweep for arch/x86/* Signed-off-by: Andi Kleen <ak@linux.intel.com> Link: http://lkml.kernel.org/r/1398984278-29319-3-git-send-email-andi@firstfloor.org Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-01-27x86: math-emu: Drop already-disabled print of build dateJosh Triplett
The kernel already has this information, so other bits of kernel code shouldn't duplicate that. This also eliminates the use of __DATE__, which makes the build non-deterministic. This message was already disabled at build time, with PRINT_MESSAGES undef'd at the top of the file. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-03-13x86: Rename trap_no to trap_nr in thread_structSrikar Dronamraju
There are precedences of trap number being referred to as trap_nr. However thread struct refers trap number as trap_no. Change it to trap_nr. Also use enum instead of left-over literals for trap values. This is pure cleanup, no functional change intended. Suggested-by: Ingo Molnar <mingo@eltu.hu> Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jim Keniston <jkenisto@linux.vnet.ibm.com> Cc: Linux-mm <linux-mm@kvack.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20120312092555.5379.942.sendpatchset@srdronam.in.ibm.com [ Fixed the math-emu build ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-10x86, fpu: Unbreak FPU emulationH. Peter Anvin
Unbreak FPU emulation, broken by checkin 86603283326c9e95e5ad4e9fdddeec93cac5d9ad: x86: Introduce 'struct fpu' and related API Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Avi Kivity <avi@redhat.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <1273135546-29690-3-git-send-email-avi@redhat.com>
2010-05-10x86: Introduce 'struct fpu' and related APIAvi Kivity
Currently all fpu state access is through tsk->thread.xstate. Since we wish to generalize fpu access to non-task contexts, wrap the state in a new 'struct fpu' and convert existing access to use an fpu API. Signal frame handlers are not converted to the API since they will remain task context only things. Signed-off-by: Avi Kivity <avi@redhat.com> Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <1273135546-29690-3-git-send-email-avi@redhat.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-03-27Merge branch 'core/percpu' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/parisc/kernel/irq.c arch/x86/include/asm/fixmap_64.h arch/x86/include/asm/setup.h kernel/irq/handle.c Semantic merge: arch/x86/include/asm/fixmap.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-04x86, math-emu: fix init_fpu for task != currentDaniel Glöckner
Impact: fix math-emu related crash while using GDB/ptrace init_fpu() calls finit to initialize a task's xstate, while finit always works on the current task. If we use PTRACE_GETFPREGS on another process and both processes did not already use floating point, we get a null pointer exception in finit. This patch creates a new function finit_task that takes a task_struct parameter. finit becomes a wrapper that simply calls finit_task with current. On the plus side this avoids many calls to get_current which would each resolve to an inline assembler mov instruction. An empty finit_task has been added to i387.h to avoid linker errors in case the compiler still emits the call in init_fpu when CONFIG_MATH_EMULATION is not defined. The declaration of finit in i387.h has been removed as the remaining code using this function gets its prototype from fpu_proto.h. Signed-off-by: Daniel Glöckner <dg@emlix.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: "Pallipadi Venkatesh" <venkatesh.pallipadi@intel.com> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Bill Metzenthen <billm@melbpc.org.au> LKML-Reference: <E1Lew31-0004il-Fg@mailer.emlix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-10x86: add %gs accessors for x86_32Tejun Heo
Impact: cleanup On x86_32, %gs is handled lazily. It's not saved and restored on kernel entry/exit but only when necessary which usually is during task switch but there are few other places. Currently, it's done by calling savesegment() and loadsegment() explicitly. Define get_user_gs(), set_user_gs() and task_user_gs() and use them instead. While at it, clean up register access macros in signal.c. This cleans up code a bit and will help future changes. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-10x86: fix math_emu register frame accessTejun Heo
do_device_not_available() is the handler for #NM and it declares that it takes a unsigned long and calls math_emu(), which takes a long argument and surprisingly expects the stack frame starting at the zero argument would match struct math_emu_info, which isn't true regardless of configuration in the current code. This patch makes do_device_not_available() take struct pt_regs like other exception handlers and initialize struct math_emu_info with pointer to it and pass pointer to the math_emu_info to math_emulate() like normal C functions do. This way, unless gcc makes a copy of struct pt_regs in do_device_not_available(), the register frame is correctly accessed regardless of kernel configuration or compiler used. This doesn't fix all math_emu problems but it at least gets it somewhat working. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-09x86: math_emu info cleanupTejun Heo
Impact: cleanup * Come on, struct info? s/struct info/struct math_emu_info/ * Use struct pt_regs and kernel_vm86_regs instead of defining its own register frame structure. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-18x86: coding style fixes to arch/x86/math-emu/reg_constantPaolo Ciarrocchi
Before: total: 6 errors, 1 warnings, 117 lines checked After: total: 0 errors, 1 warnings, 117 lines checked paolo@paolo-desktop:~/linux.trees.git$ md5sum /tmp/reg_constant.o.* 780388a3056d58fb759efaf190d5d3d1 /tmp/reg_constant.o.after 780388a3056d58fb759efaf190d5d3d1 /tmp/reg_constant.o.before paolo@paolo-desktop:~/linux.trees.git$ size /tmp/reg_constant.o.* text data bss dec hex filename 457 0 0 457 1c9 /tmp/reg_constant.o.after 457 0 0 457 1c9 /tmp/reg_constant.o.before Signed-off-by: Paolo Ciarrocchi <paolo.ciarrocchi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-04x86: fix broken math-emu with lazy allocation of fpu areaSuresh Siddha
Fix the math emulation that got broken with the recent lazy allocation of FPU area. init_fpu() need to be added for the math-emulation path aswell for the FPU area allocation. math emulation enabled kernel booted fine with this, in the presence of "no387 nofxsr" boot param. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: hpa@zytor.com Cc: mingo@elte.hu Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-19x86, fpu: split FPU state from task struct - v5Suresh Siddha
Split the FPU save area from the task struct. This allows easy migration of FPU context, and it's generally cleaner. It also allows the following two optimizations: 1) only allocate when the application actually uses FPU, so in the first lazy FPU trap. This could save memory for non-fpu using apps. Next patch does this lazy allocation. 2) allocate the right size for the actual cpu rather than 512 bytes always. Patches enabling xsave/xrstor support (coming shortly) will take advantage of this. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-17i386: arch/x86/math-emu/reg_ld_str.c: fix warningAndrew Morton
arch/x86/math-emu/reg_ld_str.c:380: warning: 'l[0]' may be used uninitialized in this function arch/x86/math-emu/reg_ld_str.c:380: warning: 'l[1]' may be used uninitialized in this function I can't actually spot the bug here. There's one obvious place, but fixing that didn't shut the warning up. Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17i386: arch/x86/math-emu/fpu_entry.c warning fixAndrew Morton
arch/x86/math-emu/fpu_entry.c:555: warning: 'entry_sel_off.empty' is used uninitialized in this function Presumably it's harmless, but I'll sleep better at night knowing that we initialised it. Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30x86: arch/x86/math-emu/errors.c: fix printk warningsAndrew Morton
arch/x86/math-emu/errors.c:163: warning: format '%ld' expects type 'long int', but argument 3 has type 'u32' arch/x86/math-emu/errors.c:175: warning: format '%ld' expects type 'long int', but argument 3 has type 'u32' arch/x86/math-emu/errors.c:175: warning: format '%ld' expects type 'long int', but argument 4 has type 'u32' arch/x86/math-emu/errors.c:175: warning: format '%ld' expects type 'long int', but argument 5 has type 'u32' arch/x86/math-emu/errors.c:175: warning: format '%ld' expects type 'long int', but argument 6 has type 'u32' Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
