path: root/arch/x86/lib
2015-01-09x86: Fix off-by-one in instruction decoderPeter Zijlstra
Stephane reported that the PEBS fixup was broken by the recent commit to the instruction decoder. The thing had an off-by-one which resulted in not being able to decode the last instruction and always bail. Reported-by: Stephane Eranian <eranian@google.com> Fixes: 6ba48ff46f76 ("x86: Remove arbitrary instruction size limit in instruction decoder") Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: stable@vger.kernel.org # 3.18 Cc: <ak@linux.intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Liang Kan <kan.liang@intel.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Link: http://lkml.kernel.org/r/20141216104614.GV3337@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-12-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) New offloading infrastructure and example 'rocker' driver for offloading of switching and routing to hardware. This work was done by a large group of dedicated individuals, not limited to: Scott Feldman, Jiri Pirko, Thomas Graf, John Fastabend, Jamal Hadi Salim, Andy Gospodarek, Florian Fainelli, Roopa Prabhu 2) Start making the networking operate on IOV iterators instead of modifying iov objects in-situ during transfers. Thanks to Al Viro and Herbert Xu. 3) A set of new netlink interfaces for the TIPC stack, from Richard Alpe. 4) Remove unnecessary looping during ipv6 routing lookups, from Martin KaFai Lau. 5) Add PAUSE frame generation support to gianfar driver, from Matei Pavaluca. 6) Allow for larger reordering levels in TCP, which are easily achievable in the real world right now, from Eric Dumazet. 7) Add a variable of napi_schedule that doesn't need to disable cpu interrupts, from Eric Dumazet. 8) Use a doubly linked list to optimize neigh_parms_release(), from Nicolas Dichtel. 9) Various enhancements to the kernel BPF verifier, and allow eBPF programs to actually be attached to sockets. From Alexei Starovoitov. 10) Support TSO/LSO in sunvnet driver, from David L Stevens. 11) Allow controlling ECN usage via routing metrics, from Florian Westphal. 12) Remote checksum offload, from Tom Herbert. 13) Add split-header receive, BQL, and xmit_more support to amd-xgbe driver, from Thomas Lendacky. 14) Add MPLS support to openvswitch, from Simon Horman. 15) Support wildcard tunnel endpoints in ipv6 tunnels, from Steffen Klassert. 16) Do gro flushes on a per-device basis using a timer, from Eric Dumazet. This tries to resolve the conflicting goals between the desired handling of bulk vs. RPC-like traffic. 17) Allow userspace to ask for the CPU upon what a packet was received/steered, via SO_INCOMING_CPU. From Eric Dumazet. 18) Limit GSO packets to half the current congestion window, from Eric Dumazet. 19) Add a generic helper so that all drivers set their RSS keys in a consistent way, from Eric Dumazet. 20) Add xmit_more support to enic driver, from Govindarajulu Varadarajan. 21) Add VLAN packet scheduler action, from Jiri Pirko. 22) Support configurable RSS hash functions via ethtool, from Eyal Perry. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1820 commits) Fix race condition between vxlan_sock_add and vxlan_sock_release net/macb: fix compilation warning for print_hex_dump() called with skb->mac_header net/mlx4: Add support for A0 steering net/mlx4: Refactor QUERY_PORT net/mlx4_core: Add explicit error message when rule doesn't meet configuration net/mlx4: Add A0 hybrid steering net/mlx4: Add mlx4_bitmap zone allocator net/mlx4: Add a check if there are too many reserved QPs net/mlx4: Change QP allocation scheme net/mlx4_core: Use tasklet for user-space CQ completion events net/mlx4_core: Mask out host side virtualization features for guests net/mlx4_en: Set csum level for encapsulated packets be2net: Export tunnel offloads only when a VxLAN tunnel is created gianfar: Fix dma check map error when DMA_API_DEBUG is enabled cxgb4/csiostor: Don't use MASTER_MUST for fw_hello call net: fec: only enable mdio interrupt before phy device link up net: fec: clear all interrupt events to support i.MX6SX net: fec: reset fep link status in suspend function net: sock: fix access via invalid file descriptor net: introduce helper macro for_each_cmsghdr ...
2014-12-10net, lib: kill arch_fast_hash library bitsDaniel Borkmann
As there are now no remaining users of arch_fast_hash(), lets kill it entirely. This basically reverts commit 71ae8aac3e19 ("lib: introduce arch optimized hash library") and follow-up work, that is f.e., commit 237217546d44 ("lib: hash: follow-up fixups for arch hash"), commit e3fec2f74f7f ("lib: Add missing arch generic-y entries for asm-generic/hash.h") and last but not least commit 6a02652df511 ("perf tools: Fix include for non x86 architectures"). Cc: Francesco Fusco <fusco@ntop.org> Cc: Thomas Graf <tgraf@suug.ch> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-10Merge branch 'x86-mpx-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 MPX support from Thomas Gleixner: "This enables support for x86 MPX. MPX is a new debug feature for bound checking in user space. It requires kernel support to handle the bound tables and decode the bound violating instruction in the trap handler" * 'x86-mpx-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: asm-generic: Remove asm-generic arch_bprm_mm_init() mm: Make arch_unmap()/bprm_mm_init() available to all architectures x86: Cleanly separate use of asm-generic/mm_hooks.h x86 mpx: Change return type of get_reg_offset() fs: Do not include mpx.h in exec.c x86, mpx: Add documentation on Intel MPX x86, mpx: Cleanup unused bound tables x86, mpx: On-demand kernel allocation of bounds tables x86, mpx: Decode MPX instruction to get bound violation information x86, mpx: Add MPX-specific mmap interface x86, mpx: Introduce VM_MPX to indicate that a VMA is MPX specific x86, mpx: Add MPX to disabled features ia64: Sync struct siginfo with general version mips: Sync struct siginfo with general version mpx: Extend siginfo structure to include bound violation information x86, mpx: Rename cfg_reg_u and status_reg x86: mpx: Give bndX registers actual names x86: Remove arbitrary instruction size limit in instruction decoder
2014-11-18x86: Remove arbitrary instruction size limit in instruction decoderDave Hansen
The current x86 instruction decoder steps along through the instruction stream but always ensures that it never steps farther than the largest possible instruction size (MAX_INSN_SIZE). The MPX code is now going to be doing some decoding of userspace instructions. We copy those from userspace in to the kernel and they're obviously completely untrusted coming from userspace. In addition to the constraint that instructions can only be so long, we also have to be aware of how long the buffer is that came in from userspace. This _looks_ to be similar to what the perf and kprobes is doing, but it's unclear to me whether they are affected. The whole reason we need this is that it is perfectly valid to be executing an instruction within MAX_INSN_SIZE bytes of an unreadable page. We should be able to gracefully handle short reads in those cases. This adds support to the decoder to record how long the buffer being decoded is and to refuse to "validate" the instruction if we would have gone over the end of the buffer to decode it. The kprobes code probably needs to be looked at here a bit more carefully. This patch still respects the MAX_INSN_SIZE limit there but the kprobes code does look like it might be able to be a bit more strict than it currently is. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Acked-by: Jim Keniston <jkenisto@us.ibm.com> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: x86@kernel.org Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: "David S. Miller" <davem@davemloft.net> Link: http://lkml.kernel.org/r/20141114153957.E6B01535@viggo.jf.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-11-16x86-64: make csum_partial_copy_from_user() error handling consistentLinus Torvalds
Al Viro pointed out that the x86-64 csum_partial_copy_from_user() is somewhat confused about what it should do on errors, notably it mostly clears the uncopied end result buffer, but misses that for the initial alignment case. All users should check for errors, so it's dubious whether the clearing is even necessary, and Al also points out that we should probably clean up the calling conventions, but regardless of any future changes to this function, the fact that it is inconsistent is just annoying. So make the __get_user() failure path use the same error exit as all the other errors do. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Cc: David Miller <davem@davemloft.net> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-13Merge branch 'x86-asm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 asm updates from Ingo Molnar: "The changes in this cycle were: - Speed up the x86 __preempt_schedule() implementation - Fix/improve low level asm code debug info annotations" * 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Unwind-annotate thunk_32.S x86: Improve cmpxchg8b_emu.S x86: Improve cmpxchg16b_emu.S x86/lib/Makefile: Remove the unnecessary "+= thunk_64.o" x86: Speed up ___preempt_schedule*() by using THUNK helpers
2014-10-08x86: Unwind-annotate thunk_32.SJan Beulich
Signed-off-by: Jan Beulich <jbeulich@suse.com> Link: http://lkml.kernel.org/r/542291CA0200007800038085@mail.emea.novell.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-10-08x86: Improve cmpxchg8b_emu.SJan Beulich
- don't include unneeded headers - drop redundant entry point label - complete unwind annotations - use .L prefix on local labels to not clutter the symbol table Signed-off-by: Jan Beulich <jbeulich@suse.com> Link: http://lkml.kernel.org/r/5422917E0200007800038081@mail.emea.novell.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-10-08x86: Improve cmpxchg16b_emu.SJan Beulich
- don't include unneeded headers - don't open-code PER_CPU_VAR() - drop redundant entry point label - complete unwind annotations - use .L prefix on local label to not clutter the symbol table Signed-off-by: Jan Beulich <jbeulich@suse.com> Link: http://lkml.kernel.org/r/542290BC020000780003807D@mail.emea.novell.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-09-24x86/lib/Makefile: Remove the unnecessary "+= thunk_64.o"Oleg Nesterov
Trivial. We have "lib-y += thunk_$(BITS).o" at the start, no need to add thunk_64.o if !CONFIG_X86_32. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Andy Lutomirski <luto@amacapital.net> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20140921184232.GB23727@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-09-24x86: Speed up ___preempt_schedule*() by using THUNK helpersOleg Nesterov
___preempt_schedule() does SAVE_ALL/RESTORE_ALL but this is suboptimal, we do not need to save/restore the callee-saved register. And we already have arch/x86/lib/thunk_*.S which implements the similar asm wrappers, so it makes sense to redefine ___preempt_schedule() as "THUNK ..." and remove preempt.S altogether. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Andy Lutomirski <luto@amacapital.net> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20140921184153.GA23727@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-09-10locking/rwlock, x86: Delete unused asm/rwlock.h and rwlock.SWaiman Long
This patch removes the unused asm/rwlock.h and rwlock.S files. Signed-off-by: Waiman Long <Waiman.Long@hp.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Link: http://lkml.kernel.org/r/1408037251-45918-3-git-send-email-Waiman.Long@hp.com Cc: Scott J Norton <scott.norton@hp.com> Cc: Borislav Petkov <bp@suse.de> Cc: Daniel Borkmann <dborkman@redhat.com> Cc: David S. Miller <davem@davemloft.net> Cc: Francesco Fusco <ffusco@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Thomas Graf <tgraf@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-12Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull more perf updates from Ingo Molnar: "A second round of perf updates: - wide reaching kprobes sanitization and robustization, with the hope of fixing all 'probe this function crashes the kernel' bugs, by Masami Hiramatsu. - uprobes updates from Oleg Nesterov: tmpfs support, corner case fixes and robustization work. - perf tooling updates and fixes from Jiri Olsa, Namhyung Ki, Arnaldo et al: * Add support to accumulate hist periods (Namhyung Kim) * various fixes, refactorings and enhancements" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (101 commits) perf: Differentiate exec() and non-exec() comm events perf: Fix perf_event_comm() vs. exec() assumption uprobes/x86: Rename arch_uprobe->def to ->defparam, minor comment updates perf/documentation: Add description for conditional branch filter perf/x86: Add conditional branch filtering support perf/tool: Add conditional branch filter 'cond' to perf record perf: Add new conditional branch filter 'PERF_SAMPLE_BRANCH_COND' uprobes: Teach copy_insn() to support tmpfs uprobes: Shift ->readpage check from __copy_insn() to uprobe_register() perf/x86: Use common PMU interrupt disabled code perf/ARM: Use common PMU interrupt disabled code perf: Disable sampled events if no PMU interrupt perf: Fix use after free in perf_remove_from_context() perf tools: Fix 'make help' message error perf record: Fix poll return value propagation perf tools: Move elide bool into perf_hpp_fmt struct perf tools: Remove elide setup for SORT_MODE__MEMORY mode perf tools: Fix "==" into "=" in ui_browser__warning assignment perf tools: Allow overriding sysfs and proc finding with env var perf tools: Consider header files outside perf directory in tags target ...
2014-06-06Merge branch 'perf/urgent' into perf/core, to resolve conflict and to ↵Ingo Molnar
prepare for new patches Conflicts: arch/x86/kernel/traps.c Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-20x86, boot: Carve out early cmdline parsing functionBorislav Petkov
Carve out early cmdline parsing function into .../lib/cmdline.c so it can be used by early code in the kernel proper as well. Adapted from arch/x86/boot/cmdline.c. Signed-off-by: Borislav Petkov <bp@suse.de> Link: http://lkml.kernel.org/r/1400525957-11525-2-git-send-email-bp@alien8.de Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2014-05-09x86: Fix typo preventing msr_set/clear_bit from having an effectAndres Freund
Due to a typo the msr accessor function introduced in 22085a66c2fab6cf9b9393c056a3600a6b4735de didn't have any lasting effects because they accidentally wrote the old value back. After c0a639ad0bc6b178b46996bd1f821a04643e2bde this at the very least this causes cpuid limits not to be lifted on some cpus leading to missing capabilities for those. Signed-off-by: Andres Freund <andres@anarazel.de> Link: http://lkml.kernel.org/r/1399598957-7011-2-git-send-email-andres@anarazel.de Cc: Borislav Petkov <bp@suse.de> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2014-04-24kprobes, x86: Prohibit probing on thunk functions and restoreMasami Hiramatsu
thunk/restore functions are also used for tracing irqoff etc. and those are involved in kprobe's exception handling. Prohibit probing on them to avoid kernel crash. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Reviewed-by: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/20140417081726.26341.3872.stgit@ltc230.yrl.intra.hitachi.co.jp Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-03-31Merge branch 'x86-asmlinkage-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 LTO changes from Peter Anvin: "More infrastructure work in preparation for link-time optimization (LTO). Most of these changes is to make sure symbols accessed from assembly code are properly marked as visible so the linker doesn't remove them. My understanding is that the changes to support LTO are still not upstream in binutils, but are on the way there. This patchset should conclude the x86-specific changes, and remaining patches to actually enable LTO will be fed through the Kbuild tree (other than keeping up with changes to the x86 code base, of course), although not necessarily in this merge window" * 'x86-asmlinkage-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (25 commits) Kbuild, lto: Handle basic LTO in modpost Kbuild, lto: Disable LTO for asm-offsets.c Kbuild, lto: Add a gcc-ld script to let run gcc as ld Kbuild, lto: add ld-version and ld-ifversion macros Kbuild, lto: Drop .number postfixes in modpost Kbuild, lto, workaround: Don't warn for initcall_reference in modpost lto: Disable LTO for sys_ni lto: Handle LTO common symbols in module loader lto, workaround: Add workaround for initcall reordering lto: Make asmlinkage __visible x86, lto: Disable LTO for the x86 VDSO initconst, x86: Fix initconst mistake in ts5500 code initconst: Fix initconst mistake in dcdbas asmlinkage: Make trace_hardirqs_on/off_caller visible asmlinkage, x86: Fix 32bit memcpy for LTO asmlinkage Make __stack_chk_failed and memcmp visible asmlinkage: Mark rwsem functions that can be called from assembler asmlinkage asmlinkage: Make main_extable_sort_needed visible asmlinkage, mutex: Mark __visible asmlinkage: Make trace_hardirq visible ...
2014-03-31Merge branch 'x86-hash-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 hashing changes from Ingo Molnar: "Small fixes and cleanups to the librarized arch_fast_hash() methods, used by the net/openvswitch code" * 'x86-hash-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, hash: Simplify switch, add __init annotation x86, hash: Swap arguments passed to crc32_u32() x86, hash: Fix build failure with older binutils
2014-03-19x86, hash: Simplify switch, add __init annotationJan Beulich
Minor cleanups: - simplify switch statement - add __init annotation to setup_arch_fast_hash() Signed-off-by: Jan Beulich <jbeulich@suse.com> Link: http://lkml.kernel.org/r/530F09CE020000780011FBEF@nat28.tlf.novell.com Cc: Francesco Fusco <ffusco@redhat.com> Cc: Thomas Graf <tgraf@redhat.com> Cc: David S. Miller <davem@davemloft.net> Acked-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-03-19x86, hash: Swap arguments passed to crc32_u32()Jan Beulich
... to match the function's parameters. While reportedly commutative, using the proper order allows for leveraging the instruction permitting the source operand to be in memory. [ hpa: This code originated in the dpdk toolkit. This was a bug in dpdk which has recently been fixed in part due to an earlier version of this patch. ] Signed-off-by: Jan Beulich <jbeulich@suse.com> Link: http://lkml.kernel.org/r/530F09B6020000780011FBEB@nat28.tlf.novell.com Acked-by: Daniel Borkmann <dborkman@redhat.com> Cc: Francesco Fusco <ffusco@redhat.com> Cc: Thomas Graf <tgraf@redhat.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-03-19x86, hash: Fix build failure with older binutilsJan Beulich
Just like for other ISA extension instruction uses we should check whether the assembler actually supports them. The fallback here simply is to encode an instruction with fixed operands (%eax and %ecx). [ hpa: tagging for -stable as a build fix ] Signed-off-by: Jan Beulich <jbeulich@suse.com> Link: http://lkml.kernel.org/r/530F0996020000780011FBE7@nat28.tlf.novell.com Cc: Francesco Fusco <ffusco@redhat.com> Cc: Thomas Graf <tgraf@redhat.com> Cc: David S. Miller <davem@davemloft.net> Acked-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: <stable@vger.kernel.org> # v3.14
2014-03-13x86: Add another set of MSR accessor functionsBorislav Petkov
We very often need to set or clear a bit in an MSR as a result of doing some sort of a hardware configuration. Add generic versions of that repeated functionality in order to save us a bunch of duplicated code in the early CPU vendor detection/config code. Signed-off-by: Borislav Petkov <bp@suse.de> Link: http://lkml.kernel.org/r/1394384725-10796-2-git-send-email-bp@alien8.de Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-02-13asmlinkage, x86: Fix 32bit memcpy for LTOAndi Kleen
These functions can be called implicitely from gcc, and thus need to be visible. Signed-off-by: Andi Kleen <ak@linux.intel.com> Link: http://lkml.kernel.org/r/1391845930-28580-11-git-send-email-ak@linux.intel.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) BPF debugger and asm tool by Daniel Borkmann. 2) Speed up create/bind in AF_PACKET, also from Daniel Borkmann. 3) Correct reciprocal_divide and update users, from Hannes Frederic Sowa and Daniel Borkmann. 4) Currently we only have a "set" operation for the hw timestamp socket ioctl, add a "get" operation to match. From Ben Hutchings. 5) Add better trace events for debugging driver datapath problems, also from Ben Hutchings. 6) Implement auto corking in TCP, from Eric Dumazet. Basically, if we have a small send and a previous packet is already in the qdisc or device queue, defer until TX completion or we get more data. 7) Allow userspace to manage ipv6 temporary addresses, from Jiri Pirko. 8) Add a qdisc bypass option for AF_PACKET sockets, from Daniel Borkmann. 9) Share IP header compression code between Bluetooth and IEEE802154 layers, from Jukka Rissanen. 10) Fix ipv6 router reachability probing, from Jiri Benc. 11) Allow packets to be captured on macvtap devices, from Vlad Yasevich. 12) Support tunneling in GRO layer, from Jerry Chu. 13) Allow bonding to be configured fully using netlink, from Scott Feldman. 14) Allow AF_PACKET users to obtain the VLAN TPID, just like they can already get the TCI. From Atzm Watanabe. 15) New "Heavy Hitter" qdisc, from Terry Lam. 16) Significantly improve the IPSEC support in pktgen, from Fan Du. 17) Allow ipv4 tunnels to cache routes, just like sockets. From Tom Herbert. 18) Add Proportional Integral Enhanced packet scheduler, from Vijay Subramanian. 19) Allow openvswitch to mmap'd netlink, from Thomas Graf. 20) Key TCP metrics blobs also by source address, not just destination address. From Christoph Paasch. 21) Support 10G in generic phylib. From Andy Fleming. 22) Try to short-circuit GRO flow compares using device provided RX hash, if provided. From Tom Herbert. The wireless and netfilter folks have been busy little bees too. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2064 commits) net/cxgb4: Fix referencing freed adapter ipv6: reallocate addrconf router for ipv6 address when lo device up fib_frontend: fix possible NULL pointer dereference rtnetlink: remove IFLA_BOND_SLAVE definition rtnetlink: remove check for fill_slave_info in rtnl_have_link_slave_info qlcnic: update version to 5.3.55 qlcnic: Enhance logic to calculate msix vectors. qlcnic: Refactor interrupt coalescing code for all adapters. qlcnic: Update poll controller code path qlcnic: Interrupt code cleanup qlcnic: Enhance Tx timeout debugging. qlcnic: Use bool for rx_mac_learn. bonding: fix u64 division rtnetlink: add missing IFLA_BOND_AD_INFO_UNSPEC sfc: Use the correct maximum TX DMA ring size for SFC9100 Add Shradha Shah as the sfc driver maintainer. net/vxlan: Share RX skb de-marking and checksum checks with ovs tulip: cleanup by using ARRAY_SIZE() ip_tunnel: clear IPCB in ip_tunnel_xmit() in case dst_link_failure() is called net/cxgb4: Don't retrieve stats during recovery ...
2014-01-20Merge branch 'x86/mpx' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tipLinus Torvalds
Pull x86 cpufeature and mpx updates from Peter Anvin: "This includes the basic infrastructure for MPX (Memory Protection Extensions) support, but does not include MPX support itself. It is, however, a prerequisite for KVM support for MPX, which I believe will be pushed later this merge window by the KVM team. This includes moving the functionality in futex_atomic_cmpxchg_inatomic() into a new function in uaccess.h so it can be reused - this will be used by the final MPX patches. The actual MPX functionality (map management and so on) will be pushed in a future merge window, when ready" * 'x86/mpx' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/intel/mpx: Remove unused LWP structure x86, mpx: Add MPX related opcodes to the x86 opcode map x86: replace futex_atomic_cmpxchg_inatomic() with user_atomic_cmpxchg_inatomic x86: add user_atomic_cmpxchg_inatomic at uaccess.h x86, xsave: Support eager-only xsave features, add MPX support x86, cpufeature: Define the Intel MPX feature flag
2014-01-20Merge branch 'x86-cleanups-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 cleanups from Ingo Molnar: "Misc cleanups" * 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, cpu, amd: Fix a shadowed variable situation um, x86: Fix vDSO build x86: Delete non-required instances of include <linux/init.h> x86, realmode: Pointer walk cleanups, pull out invariant use of __pa() x86/traps: Clean up error exception handler definitions
2014-01-17x86, mpx: Add MPX related opcodes to the x86 opcode mapQiaowei Ren
This patch adds all the MPX instructions to x86 opcode map, so the x86 instruction decoder can decode MPX instructions. Signed-off-by: Qiaowei Ren <qiaowei.ren@intel.com> Link: http://lkml.kernel.org/r/1389518403-7715-4-git-send-email-qiaowei.ren@intel.com Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-01-06x86: Delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. [ hpa: undid incorrect removal from arch/x86/kernel/head_32.S ] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Link: http://lkml.kernel.org/r/1389054026-12947-1-git-send-email-paul.gortmaker@windriver.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2013-12-17lib: introduce arch optimized hash libraryFrancesco Fusco
We introduce a new hashing library that is meant to be used in the contexts where speed is more important than uniformity of the hashed values. The hash library leverages architecture specific implementation to achieve high performance and fall backs to jhash() for the generic case. On Intel-based x86 architectures, the library can exploit the crc32l instruction, part of the Intel SSE4.2 instruction set, if the instruction is supported by the processor. This implementation is twice as fast as the jhash() implementation on an i7 processor. Additional architectures, such as Arm64 provide instructions for accelerating the computation of CRC, so they could be added as well in follow-up work. Signed-off-by: Francesco Fusco <ffusco@redhat.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Thomas Graf <tgraf@redhat.com> Cc: linux-kernel@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-20x86-64, copy_user: Use leal to produce 32-bit resultsH. Peter Anvin
When we are using lea to produce a 32-bit result, we can use the leal form, rather than using leaq and worry about truncation elsewhere. Make the leal explicit, both to be more obvious and since that is what gcc generates and thus is less likely to trigger obscure gas bugs. Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1384634221-6006-1-git-send-email-fenghua.yu@intel.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-11-16x86-64, copy_user: Remove zero byte check before copy user buffer.Fenghua Yu
Operation of rep movsb instruction handles zero byte copy. As pointed out by Linus, there is no need to check zero size in kernel. Removing this redundant check saves a few cycles in copy user functions. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Link: http://lkml.kernel.org/r/1384634221-6006-1-git-send-email-fenghua.yu@intel.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-11-14Merge tag 'pm+acpi-3.13-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael J Wysocki: - New power capping framework and the the Intel Running Average Power Limit (RAPL) driver using it from Srinivas Pandruvada and Jacob Pan. - Addition of the in-kernel switching feature to the arm_big_little cpufreq driver from Viresh Kumar and Nicolas Pitre. - cpufreq support for iMac G5 from Aaro Koskinen. - Baytrail processors support for intel_pstate from Dirk Brandewie. - cpufreq support for Midway/ECX-2000 from Mark Langsdorf. - ARM vexpress/TC2 cpufreq support from Sudeep KarkadaNagesha. - ACPI power management support for the I2C and SPI bus types from Mika Westerberg and Lv Zheng. - cpufreq core fixes and cleanups from Viresh Kumar, Srivatsa S Bhat, Stratos Karafotis, Xiaoguang Chen, Lan Tianyu. - cpufreq drivers updates (mostly fixes and cleanups) from Viresh Kumar, Aaro Koskinen, Jungseok Lee, Sudeep KarkadaNagesha, Lukasz Majewski, Manish Badarkhe, Hans-Christian Egtvedt, Evgeny Kapaev. - intel_pstate updates from Dirk Brandewie and Adrian Huang. - ACPICA update to version 20130927 includig fixes and cleanups and some reduction of divergences between the ACPICA code in the kernel and ACPICA upstream in order to improve the automatic ACPICA patch generation process. From Bob Moore, Lv Zheng, Tomasz Nowicki, Naresh Bhat, Bjorn Helgaas, David E Box. - ACPI IPMI driver fixes and cleanups from Lv Zheng. - ACPI hotplug fixes and cleanups from Bjorn Helgaas, Toshi Kani, Zhang Yanfei, Rafael J Wysocki. - Conversion of the ACPI AC driver to the platform bus type and multiple driver fixes and cleanups related to ACPI from Zhang Rui. - ACPI processor driver fixes and cleanups from Hanjun Guo, Jiang Liu, Bartlomiej Zolnierkiewicz, Mathieu Rhéaume, Rafael J Wysocki. - Fixes and cleanups and new blacklist entries related to the ACPI video support from Aaron Lu, Felipe Contreras, Lennart Poettering, Kirill Tkhai. - cpuidle core cleanups from Viresh Kumar and Lorenzo Pieralisi. - cpuidle drivers fixes and cleanups from Daniel Lezcano, Jingoo Han, Bartlomiej Zolnierkiewicz, Prarit Bhargava. - devfreq updates from Sachin Kamat, Dan Carpenter, Manish Badarkhe. - Operation Performance Points (OPP) core updates from Nishanth Menon. - Runtime power management core fix from Rafael J Wysocki and update from Ulf Hansson. - Hibernation fixes from Aaron Lu and Rafael J Wysocki. - Device suspend/resume lockup detection mechanism from Benoit Goby. - Removal of unused proc directories created for various ACPI drivers from Lan Tianyu. - ACPI LPSS driver fix and new device IDs for the ACPI platform scan handler from Heikki Krogerus and Jarkko Nikula. - New ACPI _OSI blacklist entry for Toshiba NB100 from Levente Kurusa. - Assorted fixes and cleanups related to ACPI from Andy Shevchenko, Al Stone, Bartlomiej Zolnierkiewicz, Colin Ian King, Dan Carpenter, Felipe Contreras, Jianguo Wu, Lan Tianyu, Yinghai Lu, Mathias Krause, Liu Chuansheng. - Assorted PM fixes and cleanups from Andy Shevchenko, Thierry Reding, Jean-Christophe Plagniol-Villard. * tag 'pm+acpi-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (386 commits) cpufreq: conservative: fix requested_freq reduction issue ACPI / hotplug: Consolidate deferred execution of ACPI hotplug routines PM / runtime: Use pm_runtime_put_sync() in __device_release_driver() ACPI / event: remove unneeded NULL pointer check Revert "ACPI / video: Ignore BIOS initial backlight value for HP 250 G1" ACPI / video: Quirk initial backlight level 0 ACPI / video: Fix initial level validity test intel_pstate: skip the driver if ACPI has power mgmt option PM / hibernate: Avoid overflow in hibernate_preallocate_memory() ACPI / hotplug: Do not execute "insert in progress" _OST ACPI / hotplug: Carry out PCI root eject directly ACPI / hotplug: Merge device hot-removal routines ACPI / hotplug: Make acpi_bus_hot_remove_device() internal ACPI / hotplug: Simplify device ejection routines ACPI / hotplug: Fix handle_root_bridge_removal() ACPI / hotplug: Refuse to hot-remove all objects with disabled hotplug ACPI / scan: Start matching drivers after trying scan handlers ACPI: Remove acpi_pci_slot_init() headers from internal.h ACPI / blacklist: fix name of ThinkPad Edge E530 PowerCap: Fix build error with option -Werror=format-security ... Conflicts: arch/arm/mach-omap2/opp.c drivers/Kconfig drivers/spi/spi.c
2013-11-12Merge branch 'x86-boot-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 boot changes from Ingo Molnar: "Two changes that prettify and compactify the SMP bootup output from: smpboot: Booting Node 0, Processors #1 #2 #3 OK smpboot: Booting Node 1, Processors #4 #5 #6 #7 OK smpboot: Booting Node 2, Processors #8 #9 #10 #11 OK smpboot: Booting Node 3, Processors #12 #13 #14 #15 OK Brought up 16 CPUs to something like: x86: Booting SMP configuration: .... node #0, CPUs: #1 #2 #3 .... node #1, CPUs: #4 #5 #6 #7 .... node #2, CPUs: #8 #9 #10 #11 .... node #3, CPUs: #12 #13 #14 #15 x86: Booted up 4 nodes, 16 CPUs" * 'x86-boot-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/boot: Further compress CPUs bootup message x86: Improve the printout of the SMP bootup CPU table
2013-11-12Merge branch 'x86-asm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 user access changes from Ingo Molnar: "This tree contains two copy_[from/to]_user() build time checking changes/enhancements from Jan Beulich. The desired outcome is to get better compiler warnings with CONFIG_DEBUG_STRICT_USER_COPY_CHECKS=y, to keep people from introducing bugs such as overflows and information leaks" * 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Unify copy_to_user() and add size checking to it x86: Unify copy_from_user() size checking
2013-11-06perf: Fix arch_perf_out_copy_user defaultPeter Zijlstra
The arch_perf_output_copy_user() default of __copy_from_user_inatomic() returns bytes not copied, while all other argument functions given DEFINE_OUTPUT_COPY() return bytes copied. Since copy_from_user_nmi() is the odd duck out by returning bytes copied where all other *copy_{to,from}* functions return bytes not copied, change it over and ammend DEFINE_OUTPUT_COPY() to expect bytes not copied. Oddly enough DEFINE_OUTPUT_COPY() already returned bytes not copied while expecting its worker functions to return bytes copied. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: will.deacon@arm.com Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20131030201622.GR16117@laptop.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-29perf/x86: Further optimize copy_from_user_nmi()Peter Zijlstra
Now that we can deal with nested NMI due to IRET re-enabling NMIs and can deal with faults from NMI by making sure we preserve CR2 over NMIs we can in fact simply access user-space memory from NMI context. So rewrite copy_from_user_nmi() to use __copy_from_user_inatomic() and rework the fault path to do the minimal required work before taking the in_atomic() fault handler. In particular avoid perf_sw_event() which would make perf recurse on itself (it should be harmless as our recursion protections should be able to deal with this -- but why tempt fate). Also rename notify_page_fault() to kprobes_fault() as that is a much better name; there is no notifier in it and its specific to kprobes. Don measured that his worst case NMI path shrunk from ~300K cycles to ~150K cycles. Cc: Stephane Eranian <eranian@google.com> Cc: jmario@redhat.com Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andi Kleen <ak@linux.intel.com> Cc: dave.hansen@linux.intel.com Tested-by: Don Zickus <dzickus@redhat.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20131024105206.GM2490@laptop.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-26x86: Unify copy_to_user() and add size checking to itJan Beulich
Similarly to copy_from_user(), where the range check is to protect against kernel memory corruption, copy_to_user() can benefit from such checking too: Here it protects against kernel information leaks. Signed-off-by: Jan Beulich <jbeulich@suse.com> Cc: <arjan@linux.intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/5265059502000078000FC4F6@nat28.tlf.novell.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Arjan van de Ven <arjan@linux.intel.com>
2013-10-26x86: Unify copy_from_user() size checkingJan Beulich
Commits 4a3127693001c61a21d1ce680db6340623f52e93 ("x86: Turn the copy_from_user check into an (optional) compile time warning") and 63312b6a6faae3f2e5577f2b001e3b504f10a2aa ("x86: Add a Kconfig option to turn the copy_from_user warnings into errors") touched only the 32-bit variant of copy_from_user(), whereas the original commit 9f0cf4adb6aa0bfccf675c938124e68f7f06349d ("x86: Use __builtin_object_size() to validate the buffer size for copy_from_user()") also added the same code to the 64-bit one. Further the earlier conversion from an inline WARN() to the call to copy_from_user_overflow() went a little too far: When the number of bytes to be copied is not a constant (e.g. [looking at 3.11] in drivers/net/tun.c:__tun_chr_ioctl() or drivers/pci/pcie/aer/aer_inject.c:aer_inject_write()), the compiler will always have to keep the funtion call, and hence there will always be a warning. By using __builtin_constant_p() we can avoid this. And then this slightly extends the effect of CONFIG_DEBUG_STRICT_USER_COPY_CHECKS in that apart from converting warnings to errors in the constant size case, it retains the (possibly wrong) warnings in the non-constant size case, such that if someone is prepared to get a few false positives, (s)he'll be able to recover the current behavior (except that these diagnostics now will never be converted to errors). Since the 32-bit variant (intentionally) didn't call might_fault(), the unification results in this being called twice now. Adding a suitable #ifdef would be the alternative if that's a problem. I'd like to point out though that with __compiletime_object_size() being restricted to gcc before 4.6, the whole construct is going to become more and more pointless going forward. I would question however that commit 2fb0815c9ee6b9ac50e15dd8360ec76d9fa46a2 ("gcc4: disable __compiletime_object_size for GCC 4.6+") was really necessary, and instead this should have been dealt with as is done here from the beginning. Signed-off-by: Jan Beulich <jbeulich@suse.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Guenter Roeck <linux@roeck-us.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/5265056D02000078000FC4F3@nat28.tlf.novell.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-17x86 / msr: add 64bit _on_cpu access functionsJacob Pan
Having 64-bit MSR access methods on given CPU can avoid shifting and simplify MSR content manipulation. We already have other combinations of rdmsrl_xxx and wrmsrl_xxx but missing the _on_cpu version. Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Jacob Pan <jacob.jun.pan@linux.intel.com> Reviewed-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-01x86/boot: Further compress CPUs bootup messageBorislav Petkov
Turn it into (for example): [ 0.073380] x86: Booting SMP configuration: [ 0.074005] .... node #0, CPUs: #1 #2 #3 #4 #5 #6 #7 [ 0.603005] .... node #1, CPUs: #8 #9 #10 #11 #12 #13 #14 #15 [ 1.200005] .... node #2, CPUs: #16 #17 #18 #19 #20 #21 #22 #23 [ 1.796005] .... node #3, CPUs: #24 #25 #26 #27 #28 #29 #30 #31 [ 2.393005] .... node #4, CPUs: #32 #33 #34 #35 #36 #37 #38 #39 [ 2.996005] .... node #5, CPUs: #40 #41 #42 #43 #44 #45 #46 #47 [ 3.600005] .... node #6, CPUs: #48 #49 #50 #51 #52 #53 #54 #55 [ 4.202005] .... node #7, CPUs: #56 #57 #58 #59 #60 #61 #62 #63 [ 4.811005] .... node #8, CPUs: #64 #65 #66 #67 #68 #69 #70 #71 [ 5.421006] .... node #9, CPUs: #72 #73 #74 #75 #76 #77 #78 #79 [ 6.032005] .... node #10, CPUs: #80 #81 #82 #83 #84 #85 #86 #87 [ 6.648006] .... node #11, CPUs: #88 #89 #90 #91 #92 #93 #94 #95 [ 7.262005] .... node #12, CPUs: #96 #97 #98 #99 #100 #101 #102 #103 [ 7.865005] .... node #13, CPUs: #104 #105 #106 #107 #108 #109 #110 #111 [ 8.466005] .... node #14, CPUs: #112 #113 #114 #115 #116 #117 #118 #119 [ 9.073006] .... node #15, CPUs: #120 #121 #122 #123 #124 #125 #126 #127 [ 9.679901] x86: Booted up 16 nodes, 128 CPUs and drop useless elements. Change num_digits() to hpa's division-avoiding, cell-phone-typed version which he went at great lengths and pains to submit on a Saturday evening. Signed-off-by: Borislav Petkov <bp@suse.de> Cc: huawei.libin@huawei.com Cc: wangyijing@huawei.com Cc: fenghua.yu@intel.com Cc: guohanjun@huawei.com Cc: paul.gortmaker@windriver.com Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20130930095624.GB16383@pd.tnic Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-28x86: Improve the printout of the SMP bootup CPU tableBorislav Petkov
As the new x86 CPU bootup printout format code maintainer, I am taking immediate action to improve and clean (and thus indulge my OCD) the reporting of the cores when coming up online. Fix padding to a right-hand alignment, cleanup code and bind reporting width to the max number of supported CPUs on the system, like this: [ 0.074509] smpboot: Booting Node 0, Processors: #1 #2 #3 #4 #5 #6 #7 OK [ 0.644008] smpboot: Booting Node 1, Processors: #8 #9 #10 #11 #12 #13 #14 #15 OK [ 1.245006] smpboot: Booting Node 2, Processors: #16 #17 #18 #19 #20 #21 #22 #23 OK [ 1.864005] smpboot: Booting Node 3, Processors: #24 #25 #26 #27 #28 #29 #30 #31 OK [ 2.489005] smpboot: Booting Node 4, Processors: #32 #33 #34 #35 #36 #37 #38 #39 OK [ 3.093005] smpboot: Booting Node 5, Processors: #40 #41 #42 #43 #44 #45 #46 #47 OK [ 3.698005] smpboot: Booting Node 6, Processors: #48 #49 #50 #51 #52 #53 #54 #55 OK [ 4.304005] smpboot: Booting Node 7, Processors: #56 #57 #58 #59 #60 #61 #62 #63 OK [ 4.961413] Brought up 64 CPUs and this: [ 0.072367] smpboot: Booting Node 0, Processors: #1 #2 #3 #4 #5 #6 #7 OK [ 0.686329] Brought up 8 CPUs Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Libin <huawei.libin@huawei.com> Cc: wangyijing@huawei.com Cc: fenghua.yu@intel.com Cc: guohanjun@huawei.com Cc: paul.gortmaker@windriver.com Link: http://lkml.kernel.org/r/20130927143554.GF4422@pd.tnic Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-04Merge branch 'x86-smap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 SMAP fixes from Ingo Molnar: "Fixes for Intel SMAP support, to fix SIGSEGVs during bootup" * 'x86-smap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: Introduce [compat_]save_altstack_ex() to unbreak x86 SMAP x86, smap: Handle csum_partial_copy_*_user()
2013-09-04Merge branch 'x86-asmlinkage-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86/asmlinkage changes from Ingo Molnar: "As a preparation for Andi Kleen's LTO patchset (link time optimizations using GCC's -flto which build time optimization has steadily increased in quality over the past few years and might eventually be usable for the kernel too) this tree includes a handful of preparatory patches that make function calling convention annotations consistent again: - Mark every function without arguments (or 64bit only) that is used by assembly code with asmlinkage() - Mark every function with parameters or variables that is used by assembly code as __visible. For the vanilla kernel this has documentation, consistency and debuggability advantages, for the time being" * 'x86-asmlinkage-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/asmlinkage: Fix warning in xen asmlinkage change x86, asmlinkage, vdso: Mark vdso variables __visible x86, asmlinkage, power: Make various symbols used by the suspend asm code visible x86, asmlinkage: Make dump_stack visible x86, asmlinkage: Make 64bit checksum functions visible x86, asmlinkage, paravirt: Add __visible/asmlinkage to xen paravirt ops x86, asmlinkage, apm: Make APM data structure used from assembler visible x86, asmlinkage: Make syscall tables visible x86, asmlinkage: Make several variables used from assembler/linker script visible x86, asmlinkage: Make kprobes code visible and fix assembler code x86, asmlinkage: Make various syscalls asmlinkage x86, asmlinkage: Make 32bit/64bit __switch_to visible x86, asmlinkage: Make _*_start_kernel visible x86, asmlinkage: Make all interrupt handlers asmlinkage / __visible x86, asmlinkage: Change dotraplinkage into __visible on 32bit x86: Fix sys_call_table type in asm/syscall.h
2013-09-01x86, smap: Handle csum_partial_copy_*_user()H. Peter Anvin
Add SMAP annotations to csum_partial_copy_to/from_user(). These functions legitimately access user space and thus need to set the AC flag. TODO: add explicit checks that the side with the kernel space pointer really points into kernel space. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/n/tip-2aps0u00eer658fd5xyanan7@git.kernel.org Cc: <stable@vger.kernel.org> # v3.7+
2013-08-06x86, asmlinkage: Make several variables used from assembler/linker script ↵Andi Kleen
visible Plus one function, load_gs_index(). Signed-off-by: Andi Kleen <ak@linux.intel.com> Link: http://lkml.kernel.org/r/1375740170-7446-10-git-send-email-andi@firstfloor.org Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-08-06x86, insn: Add new opcodes as of June, 2013Masami Hiramatsu
Add TSX-NI related instructions and new instructions to x86-opcode-map.txt according to the Intel(R) 64 and IA-32 Architectures Software Developer's Manual Vol2C (June, 2013). This also includes below updates. - Fix a typo of MWAIT (the lack of (11B)). - Change NOP Ev to prefetchw Ev - Add CRC32 new prefix style (66&F2) - Add ADCX, ADOX, RDSEED, CLAC and STAC instructions Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Link: http://lkml.kernel.org/r/20130806073750.4049.12365.stgit@udc4-manage.rcp.hitachi.co.jp Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-04-30Kconfig: consolidate CONFIG_DEBUG_STRICT_USER_COPY_CHECKSStephen Boyd
The help text for this config is duplicated across the x86, parisc, and s390 Kconfig.debug files. Arnd Bergman noted that the help text was slightly misleading and should be fixed to state that enabling this option isn't a problem when using pre 4.4 gcc. To simplify the rewording, consolidate the text into lib/Kconfig.debug and modify it there to be more explicit about when you should say N to this config. Also, make the text a bit more generic by stating that this option enables compile time checks so we can cover architectures which emit warnings vs. ones which emit errors. The details of how an architecture decided to implement the checks isn't as important as the concept of compile time checking of copy_from_user() calls. While we're doing this, remove all the copy_from_user_overflow() code that's duplicated many times and place it into lib/ so that any architecture supporting this option can get the function for free. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Ingo Molnar <mingo@kernel.org> Acked-by: H. Peter Anvin <hpa@zytor.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Helge Deller <deller@gmx.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30Merge branch 'x86-cleanups-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 cleanups from Ingo Molnar: "Misc smaller cleanups" * 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/lib: Fix spelling, put space between a numeral and its units x86/lib: Fix spelling in the comments x86, quirks: Shut-up a long-standing gcc warning x86, msr: Unify variable names x86-64, docs, mm: Add vsyscall range to virtual address space layout x86: Drop KERNEL_IMAGE_START x86_64: Use __BOOT_DS instead_of __KERNEL_DS for safety
