path: root/arch/x86/kvm/x86.h
2016-09-20KVM: x86: introduce get_kvmclock_nsPaolo Bonzini
Introduce a function that reads the exact nanoseconds value that is provided to the guest in kvmclock. This crystallizes the notion of kvmclock as a thin veneer over a stable TSC, that the guest will (hopefully) convert with NTP. In other words, kvmclock is *not* a paravirtualized host-to-guest NTP. Drop the get_kernel_ns() function, that was used both to get the base value of the master clock and to get the current value of kvmclock. The former use is replaced by ktime_get_boot_ns(), the latter is the purpose of get_kernel_ns(). This also allows KVM to provide a Hyper-V time reference counter that is synchronized with the time that is computed from the TSC page. Reviewed-by: Roman Kagan <rkagan@virtuozzo.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-06-27KVM: x86: move nsec_to_cycles from x86.c to x86.hMarcelo Tosatti
Move the inline function nsec_to_cycles from x86.c to x86.h, as the next patch uses it from lapic.c. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-03-22KVM, pkeys: add pkeys support for xsave stateHuaitong Han
This patch adds pkeys support for xsave state. Signed-off-by: Huaitong Han <huaitong.han@intel.com> Reviewed-by: Xiao Guangrong <guangrong.xiao@linux.intel.com> Signed-off-by: Xiao Guangrong <guangrong.xiao@linux.intel.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-02-09KVM: x86: Use vector-hashing to deliver lowest-priority interruptsFeng Wu
Use vector-hashing to deliver lowest-priority interrupts, As an example, modern Intel CPUs in server platform use this method to handle lowest-priority interrupts. Signed-off-by: Feng Wu <feng.wu@intel.com> Reviewed-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-02-09KVM: x86: introduce do_shl32_div32Paolo Bonzini
This is similar to the existing div_frac function, but it returns the remainder too. Unlike div_frac, it can be used to implement long division, e.g. (a << 64) / b for 32-bit a and b. Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-09-14x86/fpu: Rename XSAVE macrosDave Hansen
There are two concepts that have some confusing naming: 1. Extended State Component numbers (currently called XFEATURE_BIT_*) 2. Extended State Component masks (currently called XSTATE_*) The numbers are (currently) from 0-9. State component 3 is the bounds registers for MPX, for instance. But when we want to enable "state component 3", we go set a bit in XCR0. The bit we set is 1<<3. We can check to see if a state component feature is enabled by looking at its bit. The current 'xfeature_bit's are at best xfeature bit _numbers_. Calling them bits is at best inconsistent with ending the enum list with 'XFEATURES_NR_MAX'. This patch renames the enum to be 'xfeature'. These also happen to be what the Intel documentation calls a "state component". We also want to differentiate these from the "XSTATE_*" macros. The "XSTATE_*" macros are a mask, and we rename them to match. These macros are reasonably widely used so this patch is a wee bit big, but this really is just a rename. The only non-mechanical part of this is the s/XSTATE_EXTEND_MASK/XFEATURE_MASK_EXTEND/ We need a better name for it, but that's another patch. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: dave@sr71.net Cc: linux-kernel@vger.kernel.org Link: http://lkml.kernel.org/r/20150902233126.38653250@viggo.jf.intel.com [ Ported to v4.3-rc1. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-23kvm/x86: move Hyper-V MSR's/hypercall code into hyperv.c fileAndrey Smetanin
This patch introduce Hyper-V related source code file - hyperv.c and per vm and per vcpu hyperv context structures. All Hyper-V MSR's and hypercall code moved into hyperv.c. All Hyper-V kvm/vcpu fields moved into appropriate hyperv context structures. Copyrights and authors information copied from x86.c to hyperv.c. Signed-off-by: Andrey Smetanin <asmetanin@virtuozzo.com> Signed-off-by: Denis V. Lunev <den@openvz.org> Reviewed-by: Peter Hornyack <peterhornyack@google.com> CC: Paolo Bonzini <pbonzini@redhat.com> CC: Gleb Natapov <gleb@kernel.org> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-07-23KVM: x86: introduce kvm_check_has_quirkPaolo Bonzini
The logic of the disabled_quirks field usually results in a double negation. Wrap it in a simple function that checks the bit and negates it. Based on a patch from Xiao Guangrong. Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-06-19KVM: MTRR: do not map huge page for non-consistent rangeXiao Guangrong
Based on Intel's SDM, mapping huge page which do not have consistent memory cache for each 4k page will cause undefined behavior In order to avoiding this kind of undefined behavior, we force to use 4k pages under this case Signed-off-by: Xiao Guangrong <guangrong.xiao@linux.intel.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-06-19KVM: MTRR: sort variable MTRRsXiao Guangrong
Sort all valid variable MTRRs based on its base address, it will help us to check a range to see if it's fully contained in variable MTRRs Signed-off-by: Xiao Guangrong <guangrong.xiao@linux.intel.com> [Fix list insertion sort, simplify var_mtrr_range_is_valid to just test the V bit. - Paolo] Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-06-19KVM: x86: move MTRR related code to a separate fileXiao Guangrong
MTRR code locates in x86.c and mmu.c so that move them to a separate file to make the organization more clearer and it will be the place where we fully implement vMTRR Signed-off-by: Xiao Guangrong <guangrong.xiao@linux.intel.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-05-07KVM: x86: fix initial PAT valueRadim Krčmář
PAT should be 0007_0406_0007_0406h on RESET and not modified on INIT. VMX used a wrong value (host's PAT) and while SVM used the right one, it never got to arch.pat. This is not an issue with QEMU as it will force the correct value. Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-01-08kvm: x86: Remove kvm_make_request from lapic.cNicholas Krause
Adds a function kvm_vcpu_set_pending_timer instead of calling kvm_make_request in lapic.c. Signed-off-by: Nicholas Krause <xerofoify@gmail.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-01-08KVM: x86: add option to advance tscdeadline hrtimer expirationMarcelo Tosatti
For the hrtimer which emulates the tscdeadline timer in the guest, add an option to advance expiration, and busy spin on VM-entry waiting for the actual expiration time to elapse. This allows achieving low latencies in cyclictest (or any scenario which requires strict timing regarding timer expiration). Reduces average cyclictest latency from 12us to 8us on Core i5 desktop. Note: this option requires tuning to find the appropriate value for a particular hardware/guest combination. One method is to measure the average delay between apic_timer_fn and VM-entry. Another method is to start with 1000ns, and increase the value in say 500ns increments until avg cyclictest numbers stop decreasing. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-11-03KVM: x86: Enable Intel AVX-512 for guestChao Peng
Expose Intel AVX-512 feature bits to guest. Also add checks for xcr0 AVX512 related bits according to spec: http://download-software.intel.com/sites/default/files/managed/71/2e/319433-017.pdf Signed-off-by: Chao Peng <chao.p.peng@linux.intel.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-09-24KVM: vmx: Inject #GP on invalid PAT CRNadav Amit
Guest which sets the PAT CR to invalid value should get a #GP. Currently, if vmx supports loading PAT CR during entry, then the value is not checked. This patch makes the required check in that case. Signed-off-by: Nadav Amit <namit@cs.technion.ac.il> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-09-03kvm: x86: fix stale mmio cache bugDavid Matlack
The following events can lead to an incorrect KVM_EXIT_MMIO bubbling up to userspace: (1) Guest accesses gpa X without a memory slot. The gfn is cached in struct kvm_vcpu_arch (mmio_gfn). On Intel EPT-enabled hosts, KVM sets the SPTE write-execute-noread so that future accesses cause EPT_MISCONFIGs. (2) Host userspace creates a memory slot via KVM_SET_USER_MEMORY_REGION covering the page just accessed. (3) Guest attempts to read or write to gpa X again. On Intel, this generates an EPT_MISCONFIG. The memory slot generation number that was incremented in (2) would normally take care of this but we fast path mmio faults through quickly_check_mmio_pf(), which only checks the per-vcpu mmio cache. Since we hit the cache, KVM passes a KVM_EXIT_MMIO up to userspace. This patch fixes the issue by using the memslot generation number to validate the mmio cache. Cc: stable@vger.kernel.org Signed-off-by: David Matlack <dmatlack@google.com> [xiaoguangrong: adjust the code to make it simpler for stable-tree fix.] Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Reviewed-by: David Matlack <dmatlack@google.com> Reviewed-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Tested-by: David Matlack <dmatlack@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-06-19KVM: vmx: vmx instructions handling does not consider cs.lNadav Amit
VMX instructions use 32-bit operands in 32-bit mode, and 64-bit operands in 64-bit mode. The current implementation is broken since it does not use the register operands correctly, and always uses 64-bit for reads and writes. Moreover, write to memory in vmwrite only considers long-mode, so it ignores cs.l. This patch fixes this behavior. Signed-off-by: Nadav Amit <namit@cs.technion.ac.il> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-06-19KVM: x86: check DR6/7 high-bits are clear only on long-modeNadav Amit
When the guest sets DR6 and DR7, KVM asserts the high 32-bits are clear, and otherwise injects a #GP exception. This exception should only be injected only if running in long-mode. Signed-off-by: Nadav Amit <namit@cs.technion.ac.il> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-03-17KVM: x86: introduce kvm_supported_xcr0()Paolo Bonzini
XSAVE support for KVM is already using host_xcr0 & KVM_SUPPORTED_XCR0 as a "dynamic" version of KVM_SUPPORTED_XCR0. However, this is not enough because the MPX bits should not be presented to the guest unless kvm_x86_ops confirms the support. So, replace all instances of host_xcr0 & KVM_SUPPORTED_XCR0 with a new function kvm_supported_xcr0() that also has this check. Note that here: if (xstate_bv & ~KVM_SUPPORTED_XCR0) return -EINVAL; if (xstate_bv & ~host_cr0) return -EINVAL; the code is equivalent to if ((xstate_bv & ~KVM_SUPPORTED_XCR0) || (xstate_bv & ~host_cr0) return -EINVAL; i.e. "xstate_bv & (~KVM_SUPPORTED_XCR0 | ~host_cr0)" which is in turn equal to "xstate_bv & ~(KVM_SUPPORTED_XCR0 & host_cr0)". So we should also use the new function there. Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-02-25KVM: x86: Enable Intel MPX for guestLiu, Jinsong
From 44c2abca2c2eadc6f2f752b66de4acc8131880c4 Mon Sep 17 00:00:00 2001 From: Liu Jinsong <jinsong.liu@intel.com> Date: Mon, 24 Feb 2014 18:12:31 +0800 Subject: [PATCH v5 3/3] KVM: x86: Enable Intel MPX for guest This patch enable Intel MPX feature to guest. Signed-off-by: Xudong Hao <xudong.hao@intel.com> Signed-off-by: Liu Jinsong <jinsong.liu@intel.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-01-15KVM: x86: limit PIT timer frequencyMarcelo Tosatti
Limit PIT timer frequency similarly to the limit applied by LAPIC timer. Cc: stable@kernel.org Reviewed-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-10-03KVM: x86: mask unsupported XSAVE entries from leaf 0Dh index 0Paolo Bonzini
XSAVE entries that KVM does not support are reported by KVM_GET_SUPPORTED_CPUID for leaf 0Dh index 0 if the host supports them; they should be left out unless there is also hypervisor support for them. Sub-leafs are correctly handled in supported_xcr0_bit, fix index 0 to match. Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2012-11-30KVM: x86: Add code to track call origin for msr assignmentWill Auld
In order to track who initiated the call (host or guest) to modify an msr value I have changed function call parameters along the call path. The specific change is to add a struct pointer parameter that points to (index, data, caller) information rather than having this information passed as individual parameters. The initial use for this capability is for updating the IA32_TSC_ADJUST msr while setting the tsc value. It is anticipated that this capability is useful for other tasks. Signed-off-by: Will Auld <will.auld@intel.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-08-06KVM: use jump label to optimize checking for in kernel local apic presenceGleb Natapov
Usually all vcpus have local apic pointer initialized, so the check may be completely skipped. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-04-08KVM: x86: add paging gcc optimizationDavidlohr Bueso
Since most guests will have paging enabled for memory management, add likely() optimization around CR0.PG checks. Signed-off-by: Davidlohr Bueso <dave@gnu.org> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-27KVM: Move cpuid code to new fileAvi Kivity
The cpuid code has grown; put it into a separate file. Signed-off-by: Avi Kivity <avi@redhat.com>
2011-07-24KVM: MMU: cache mmio info on page fault pathXiao Guangrong
If the page fault is caused by mmio, we can cache the mmio info, later, we do not need to walk guest page table and quickly know it is a mmio fault while we emulate the mmio instruction Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-07-12KVM: nVMX: Implement VMPTRSTNadav Har'El
This patch implements the VMPTRST instruction. Signed-off-by: Nadav Har'El <nyh@il.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-07-12KVM: nVMX: Decoding memory operands of VMX instructionsNadav Har'El
This patch includes a utility function for decoding pointer operands of VMX instructions issued by L1 (a guest hypervisor) Signed-off-by: Nadav Har'El <nyh@il.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-05-11KVM: fix push of wrong eip when doing softintSerge E. Hallyn
When doing a soft int, we need to bump eip before pushing it to the stack. Otherwise we'll do the int a second time. [apw@canonical.com: merged eip update as per Jan's recommendation.] Signed-off-by: Serge E. Hallyn <serge.hallyn@ubuntu.com> Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-12-08KVM: SVM: Do not report xsave in supported cpuidJoerg Roedel
To support xsave properly for the guest the SVM module need software support for it. As long as this is not present do not report the xsave as supported feature in cpuid. As a side-effect this patch moves the bit() helper function into the x86.h file so that it can be used in svm.c too. KVM-Stable-Tag. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24KVM: Add kvm_inject_realmode_interrupt() wrapperMohammed Gamal
This adds a wrapper function kvm_inject_realmode_interrupt() around the emulator function emulate_int_real() to allow real mode interrupt injection. [avi: initialize operand and address sizes before emulating interrupts] [avi: initialize rip for real mode interrupt injection] [avi: clear interrupt pending flag after emulating interrupt injection] Signed-off-by: Mohammed Gamal <m.gamal005@gmail.com> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-10-24KVM: MMU: Implement nested gva_to_gpa functionsJoerg Roedel
This patch adds the functions to do a nested l2_gva to l1_gpa page table walk. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24KVM: x86: Move TSC offset writes to common codeZachary Amsden
Also, ensure that the storing of the offset and the reading of the TSC are never preempted by taking a spinlock. While the lock is overkill now, it is useful later in this patch series. Signed-off-by: Zachary Amsden <zamsden@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-01KVM: Remove memory alias supportAvi Kivity
As advertised in feature-removal-schedule.txt. Equivalent support is provided by overlapping memory regions. Signed-off-by: Avi Kivity <avi@redhat.com>
2010-05-17KVM: use the correct RCU API for PROVE_RCU=yLai Jiangshan
The RCU/SRCU API have already changed for proving RCU usage. I got the following dmesg when PROVE_RCU=y because we used incorrect API. This patch coverts rcu_deference() to srcu_dereference() or family API. =================================================== [ INFO: suspicious rcu_dereference_check() usage. ] --------------------------------------------------- arch/x86/kvm/mmu.c:3020 invoked rcu_dereference_check() without protection! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 2 locks held by qemu-system-x86/8550: #0: (&kvm->slots_lock){+.+.+.}, at: [<ffffffffa011a6ac>] kvm_set_memory_region+0x29/0x50 [kvm] #1: (&(&kvm->mmu_lock)->rlock){+.+...}, at: [<ffffffffa012262d>] kvm_arch_commit_memory_region+0xa6/0xe2 [kvm] stack backtrace: Pid: 8550, comm: qemu-system-x86 Not tainted 2.6.34-rc4-tip-01028-g939eab1 #27 Call Trace: [<ffffffff8106c59e>] lockdep_rcu_dereference+0xaa/0xb3 [<ffffffffa012f6c1>] kvm_mmu_calculate_mmu_pages+0x44/0x7d [kvm] [<ffffffffa012263e>] kvm_arch_commit_memory_region+0xb7/0xe2 [kvm] [<ffffffffa011a5d7>] __kvm_set_memory_region+0x636/0x6e2 [kvm] [<ffffffffa011a6ba>] kvm_set_memory_region+0x37/0x50 [kvm] [<ffffffffa015e956>] vmx_set_tss_addr+0x46/0x5a [kvm_intel] [<ffffffffa0126592>] kvm_arch_vm_ioctl+0x17a/0xcf8 [kvm] [<ffffffff810a8692>] ? unlock_page+0x27/0x2c [<ffffffff810bf879>] ? __do_fault+0x3a9/0x3e1 [<ffffffffa011b12f>] kvm_vm_ioctl+0x364/0x38d [kvm] [<ffffffff81060cfa>] ? up_read+0x23/0x3d [<ffffffff810f3587>] vfs_ioctl+0x32/0xa6 [<ffffffff810f3b19>] do_vfs_ioctl+0x495/0x4db [<ffffffff810e6b2f>] ? fget_light+0xc2/0x241 [<ffffffff810e416c>] ? do_sys_open+0x104/0x116 [<ffffffff81382d6d>] ? retint_swapgs+0xe/0x13 [<ffffffff810f3ba6>] sys_ioctl+0x47/0x6a [<ffffffff810021db>] system_call_fastpath+0x16/0x1b Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-04-19KVM: Implement perf callbacks for guest samplingZhang, Yanmin
Below patch implements the perf_guest_info_callbacks on kvm. Signed-off-by: Zhang Yanmin <yanmin_zhang@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: Rename vcpu->shadow_efer to eferAvi Kivity
None of the other registers have the shadow_ prefix. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-03-01KVM: Move cr0/cr4/efer related helpers to x86.hAvi Kivity
They have more general scope than the mmu. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-03-01KVM: Add a helper for checking if the guest is in protected modeAvi Kivity
2009-09-10KVM: Add Directed EOI support to APIC emulationGleb Natapov
Directed EOI is specified by x2APIC, but is available even when lapic is in xAPIC mode. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: Do not re-execute INTn instruction.Gleb Natapov
Re-inject event instead. This is what Intel suggest. Also use correct instruction length when re-injecting soft fault/interrupt. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: Remove irq_pending bitmapGleb Natapov
Only one interrupt vector can be injected from userspace irqchip at any given time so no need to store it in a bitmap. Put it into interrupt queue directly. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: Unprotect a page if #PF happens during NMI injection.Gleb Natapov
It is done for exception and interrupt already. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: Remove kvm_push_irq()Gleb Natapov
No longer used. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: reuse (pop|push)_irq from svm.c in vmx.cGleb Natapov
The prioritized bit vector manipulation functions are useful in both vmx and svm. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: Add a pending interrupt queueAvi Kivity
Similar to the exception queue, this hold interrupts that have been accepted by the virtual processor core but not yet injected. Not yet used. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: Clear exception queue before emulating an instructionAvi Kivity
If we're emulating an instruction, either it will succeed, in which case any previously queued exception will be spurious, or we will requeue the same exception. Signed-off-by: Avi Kivity <avi@qumranet.com>
