path: root/arch/x86/kernel
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-18x86/microcode/intel: Disable late loading on model 79Borislav Petkov
Blacklist Broadwell X model 79 for late loading due to an erratum. Signed-off-by: Borislav Petkov <bp@suse.de> Acked-by: Tony Luck <tony.luck@intel.com> Cc: <stable@vger.kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20171018111225.25635-1-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-10-16x86/idt: Initialize early IDT before cr4_init_shadow()Thomas Gleixner
Moving the early IDT setup out of assembly code breaks the boot on first generation 486 systems. The reason is that the call of idt_setup_early_handler, which sets up the early handlers was added after the call to cr4_init_shadow(). cr4_init_shadow() tries to read CR4 which is not available on those systems. The accessor function uses a extable fixup to handle the resulting fault. As the IDT is not set up yet, the cr4 read exception causes an instantaneous reboot for obvious reasons. Call idt_setup_early_handler() before cr4_init_shadow() so IDT is set up before the first exception hits. Fixes: 87e81786b13b ("x86/idt: Move early IDT setup out of 32-bit asm") Reported-and-tested-by: Matthew Whitehead <whiteheadm@acm.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andy Lutomirski <luto@kernel.org> Link: https://lkml.kernel.org/r/alpine.DEB.2.20.1710161210290.1973@nanos
2017-10-16x86/cpu/intel_cacheinfo: Remove redundant assignment to 'this_leaf'Colin Ian King
The 'this_leaf' variable is assigned a value that is never read and it is updated a little later with a newer value, hence we can remove the redundant assignment. Cleans up the following Clang warning: Value stored to 'this_leaf' is never read Signed-off-by: Colin Ian King <colin.king@canonical.com> Reviewed-by: Borislav Petkov <bp@suse.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: kernel-janitors@vger.kernel.org Link: http://lkml.kernel.org/r/20171015160203.12332-1-colin.king@canonical.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-10-14Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "A landry list of fixes: - fix reboot breakage on some PCID-enabled system - fix crashes/hangs on some PCID-enabled systems - fix microcode loading on certain older CPUs - various unwinder fixes - extend an APIC quirk to more hardware systems and disable APIC related warning on virtualized systems - various Hyper-V fixes - a macro definition robustness fix - remove jprobes IRQ disabling - various mem-encryption fixes" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/microcode: Do the family check first x86/mm: Flush more aggressively in lazy TLB mode x86/apic: Update TSC_DEADLINE quirk with additional SKX stepping x86/apic: Silence "FW_BUG TSC_DEADLINE disabled due to Errata" on hypervisors x86/mm: Disable various instrumentations of mm/mem_encrypt.c and mm/tlb.c x86/hyperv: Fix hypercalls with extended CPU ranges for TLB flushing x86/hyperv: Don't use percpu areas for pcpu_flush/pcpu_flush_ex structures x86/hyperv: Clear vCPU banks between calls to avoid flushing unneeded vCPUs x86/unwind: Disable unwinder warnings on 32-bit x86/unwind: Align stack pointer in unwinder dump x86/unwind: Use MSB for frame pointer encoding on 32-bit x86/unwind: Fix dereference of untrusted pointer x86/alternatives: Fix alt_max_short macro to really be a max() x86/mm/64: Fix reboot interaction with CR4.PCIDE kprobes/x86: Remove IRQ disabling from jprobe handlers kprobes/x86: Set up frame pointer in kprobe trampoline
2017-10-14Merge branch 'ras-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RAS fixes from Ingo Molnar: "A boot parameter fix, plus a header export fix" * 'ras-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/mce: Hide mca_cfg RAS/CEC: Use the right length for "cec_disable"
2017-10-14x86/microcode: Do the family check firstBorislav Petkov
On CPUs like AMD's Geode, for example, we shouldn't even try to load microcode because they do not support the modern microcode loading interface. However, we do the family check *after* the other checks whether the loader has been disabled on the command line or whether we're running in a guest. So move the family checks first in order to exit early if we're being loaded on an unsupported family. Reported-and-tested-by: Sven Glodowski <glodi1@arcor.de> Signed-off-by: Borislav Petkov <bp@suse.de> Cc: <stable@vger.kernel.org> # 4.11.. Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://bugzilla.suse.com/show_bug.cgi?id=1061396 Link: http://lkml.kernel.org/r/20171012112316.977-1-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-10-12x86/apic: Update TSC_DEADLINE quirk with additional SKX steppingLen Brown
SKX stepping-3 fixed the TSC_DEADLINE issue in a different ucode version number than stepping-4. Linux needs to know this stepping-3 specific version number to also enable the TSC_DEADLINE on stepping-3. The steppings and ucode versions are documented in the SKX BIOS update: https://downloadmirror.intel.com/26978/eng/ReleaseNotes_R00.01.0004.txt Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: peterz@infradead.org Link: https://lkml.kernel.org/r/60f2bbf7cf617e212b522e663f84225bfebc50e5.1507756305.git.len.brown@intel.com
2017-10-12x86/apic: Silence "FW_BUG TSC_DEADLINE disabled due to Errata" on hypervisorsPaolo Bonzini
Commit 594a30fb1242 ("x86/apic: Silence "FW_BUG TSC_DEADLINE disabled due to Errata" on CPUs without the feature", 2017-08-30) was also about silencing the warning on VirtualBox; however, KVM does expose the TSC deadline timer, and it's virtualized so that it is immune from CPU errata. Therefore, booting 4.13 with "-cpu Haswell" shows this in the logs: [ 0.000000] [Firmware Bug]: TSC_DEADLINE disabled due to Errata; please update microcode to version: 0xb2 (or later) Even if you had a hypervisor that does _not_ virtualize the TSC deadline and rather exposes the hardware one, it should be the hypervisors task to update microcode and possibly hide the flag from CPUID. So just hide the message when running on _any_ hypervisor, not just those that do not support the TSC deadline timer. The older check still makes sense, so keep it. Fixes: bd9240a18e ("x86/apic: Add TSC_DEADLINE quirk due to errata") Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Hans de Goede <hdegoede@redhat.com> Cc: kvm@vger.kernel.org Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/1507630377-54471-1-git-send-email-pbonzini@redhat.com
2017-10-10x86/unwind: Disable unwinder warnings on 32-bitJosh Poimboeuf
x86-32 doesn't have stack validation, so in most cases it doesn't make sense to warn about bad frame pointers. Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Byungchul Park <byungchul.park@lge.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: LKP <lkp@01.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/a69658760800bf281e6353248c23e0fa0acf5230.1507597785.git.jpoimboe@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-10-10x86/unwind: Align stack pointer in unwinder dumpJosh Poimboeuf
When printing the unwinder dump, the stack pointer could be unaligned, for one of two reasons: - stack corruption; or - GCC created an unaligned stack. There's no way for the unwinder to tell the difference between the two, so we have to assume one or the other. GCC unaligned stacks are very rare, and have only been spotted before GCC 5. Presumably, if we're doing an unwinder stack dump, stack corruption is more likely than a GCC unaligned stack. So always align the stack before starting the dump. Reported-and-tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Byungchul Park <byungchul.park@lge.com> Cc: LKP <lkp@01.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/2f540c515946ab09ed267e1a1d6421202a0cce08.1507597785.git.jpoimboe@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-10-10x86/unwind: Use MSB for frame pointer encoding on 32-bitJosh Poimboeuf
On x86-32, Tetsuo Handa and Fengguang Wu reported unwinder warnings like: WARNING: kernel stack regs at f60bb9c8 in swapper:1 has bad 'bp' value 0ba00000 And also there were some stack dumps with a bunch of unreliable '?' symbols after an apic_timer_interrupt symbol, meaning the unwinder got confused when it tried to read the regs. The cause of those issues is that, with GCC 4.8 (and possibly older), there are cases where GCC misaligns the stack pointer in a leaf function for no apparent reason: c124a388 <acpi_rs_move_data>: c124a388: 55 push %ebp c124a389: 89 e5 mov %esp,%ebp c124a38b: 57 push %edi c124a38c: 56 push %esi c124a38d: 89 d6 mov %edx,%esi c124a38f: 53 push %ebx c124a390: 31 db xor %ebx,%ebx c124a392: 83 ec 03 sub $0x3,%esp ... c124a3e3: 83 c4 03 add $0x3,%esp c124a3e6: 5b pop %ebx c124a3e7: 5e pop %esi c124a3e8: 5f pop %edi c124a3e9: 5d pop %ebp c124a3ea: c3 ret If an interrupt occurs in such a function, the regs on the stack will be unaligned, which breaks the frame pointer encoding assumption. So on 32-bit, use the MSB instead of the LSB to encode the regs. This isn't an issue on 64-bit, because interrupts align the stack before writing to it. Reported-and-tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Byungchul Park <byungchul.park@lge.com> Cc: LKP <lkp@01.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/279a26996a482ca716605c7dbc7f2db9d8d91e81.1507597785.git.jpoimboe@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-10-10x86/unwind: Fix dereference of untrusted pointerJosh Poimboeuf
Tetsuo Handa and Fengguang Wu reported a panic in the unwinder: BUG: unable to handle kernel NULL pointer dereference at 000001f2 IP: update_stack_state+0xd4/0x340 *pde = 00000000 Oops: 0000 [#1] PREEMPT SMP CPU: 0 PID: 18728 Comm: 01-cpu-hotplug Not tainted 4.13.0-rc4-00170-gb09be67 #592 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.9.3-20161025_171302-gandalf 04/01/2014 task: bb0b53c0 task.stack: bb3ac000 EIP: update_stack_state+0xd4/0x340 EFLAGS: 00010002 CPU: 0 EAX: 0000a570 EBX: bb3adccb ECX: 0000f401 EDX: 0000a570 ESI: 00000001 EDI: 000001ba EBP: bb3adc6b ESP: bb3adc3f DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068 CR0: 80050033 CR2: 000001f2 CR3: 0b3a7000 CR4: 00140690 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 DR6: fffe0ff0 DR7: 00000400 Call Trace: ? unwind_next_frame+0xea/0x400 ? __unwind_start+0xf5/0x180 ? __save_stack_trace+0x81/0x160 ? save_stack_trace+0x20/0x30 ? __lock_acquire+0xfa5/0x12f0 ? lock_acquire+0x1c2/0x230 ? tick_periodic+0x3a/0xf0 ? _raw_spin_lock+0x42/0x50 ? tick_periodic+0x3a/0xf0 ? tick_periodic+0x3a/0xf0 ? debug_smp_processor_id+0x12/0x20 ? tick_handle_periodic+0x23/0xc0 ? local_apic_timer_interrupt+0x63/0x70 ? smp_trace_apic_timer_interrupt+0x235/0x6a0 ? trace_apic_timer_interrupt+0x37/0x3c ? strrchr+0x23/0x50 Code: 0f 95 c1 89 c7 89 45 e4 0f b6 c1 89 c6 89 45 dc 8b 04 85 98 cb 74 bc 88 4d e3 89 45 f0 83 c0 01 84 c9 89 04 b5 98 cb 74 bc 74 3b <8b> 47 38 8b 57 34 c6 43 1d 01 25 00 00 02 00 83 e2 03 09 d0 83 EIP: update_stack_state+0xd4/0x340 SS:ESP: 0068:bb3adc3f CR2: 00000000000001f2 ---[ end trace 0d147fd4aba8ff50 ]--- Kernel panic - not syncing: Fatal exception in interrupt On x86-32, after decoding a frame pointer to get a regs address, regs_size() dereferences the regs pointer when it checks regs->cs to see if the regs are user mode. This is dangerous because it's possible that what looks like a decoded frame pointer is actually a corrupt value, and we don't want the unwinder to make things worse. Instead of calling regs_size() on an unsafe pointer, just assume they're kernel regs to start with. Later, once it's safe to access the regs, we can do the user mode check and corresponding safety check for the remaining two regs. Reported-and-tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Byungchul Park <byungchul.park@lge.com> Cc: LKP <lkp@01.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: 5ed8d8bb38c5 ("x86/unwind: Move common code into update_stack_state()") Link: http://lkml.kernel.org/r/7f95b9a6993dec7674b3f3ab3dcd3294f7b9644d.1507597785.git.jpoimboe@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-10-09x86/mm/64: Fix reboot interaction with CR4.PCIDEAndy Lutomirski
Trying to reboot via real mode fails with PCID on: long mode cannot be exited while CR4.PCIDE is set. (No, I have no idea why, but the SDM and actual CPUs are in agreement here.) The result is a GPF and a hang instead of a reboot. I didn't catch this in testing because neither my computer nor my VM reboots this way. I can trigger it with reboot=bios, though. Fixes: 660da7c9228f ("x86/mm: Enable CR4.PCIDE on supported systems") Reported-and-tested-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Andy Lutomirski <luto@kernel.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Borislav Petkov <bp@alien8.de> Link: https://lkml.kernel.org/r/f1e7d965998018450a7a70c2823873686a8b21c0.1507524746.git.luto@kernel.org
2017-10-05x86/mce: Hide mca_cfgBorislav Petkov
Now that lguest is gone, put it in the internal header which should be used only by MCA/RAS code. Add missing header guards while at it. No functional change. Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: https://lkml.kernel.org/r/20171002092836.22971-3-bp@alien8.de
2017-10-04kvm/x86: Avoid async PF preempting the kernel incorrectlyBoqun Feng
Currently, in PREEMPT_COUNT=n kernel, kvm_async_pf_task_wait() could call schedule() to reschedule in some cases. This could result in accidentally ending the current RCU read-side critical section early, causing random memory corruption in the guest, or otherwise preempting the currently running task inside between preempt_disable and preempt_enable. The difficulty to handle this well is because we don't know whether an async PF delivered in a preemptible section or RCU read-side critical section for PREEMPT_COUNT=n, since preempt_disable()/enable() and rcu_read_lock/unlock() are both no-ops in that case. To cure this, we treat any async PF interrupting a kernel context as one that cannot be preempted, preventing kvm_async_pf_task_wait() from choosing the schedule() path in that case. To do so, a second parameter for kvm_async_pf_task_wait() is introduced, so that we know whether it's called from a context interrupting the kernel, and the parameter is set properly in all the callsites. Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Wanpeng Li <wanpeng.li@hotmail.com> Cc: stable@vger.kernel.org Signed-off-by: Boqun Feng <boqun.feng@gmail.com> Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
2017-10-03kprobes/x86: Remove IRQ disabling from jprobe handlersMasami Hiramatsu
Jprobes actually don't need to disable IRQs while calling handlers, because of how we specify the kernel interface in Documentation/kprobes.txt: ----- Probe handlers are run with preemption disabled. Depending on the architecture and optimization state, handlers may also run with interrupts disabled (e.g., kretprobe handlers and optimized kprobe handlers run without interrupt disabled on x86/x86-64). ----- So let's remove IRQ disabling from jprobes too. Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Alexei Starovoitov <ast@fb.com> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E . McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/150701508194.32266.14458959863314097305.stgit@devbox Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-10-03kprobes/x86: Set up frame pointer in kprobe trampolineJosh Poimboeuf
Richard Weinberger saw an unwinder warning when running bcc's opensnoop: WARNING: kernel stack frame pointer at ffff99ef4076bea0 in opensnoop:2008 has bad value 0000000000000008 unwind stack type:0 next_sp: (null) mask:0x2 graph_idx:0 ... ffff99ef4076be88: ffff99ef4076bea0 (0xffff99ef4076bea0) ffff99ef4076be90: ffffffffac442721 (optimized_callback +0x81/0x90) ... A lockdep stack trace was initiated from inside a kprobe handler, when the unwinder noticed a bad frame pointer on the stack. The bad frame pointer is related to the fact that the kprobe optprobe trampoline doesn't save the frame pointer before calling into optimized_callback(). Reported-and-tested-by: Richard Weinberger <richard@sigma-star.at> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Acked-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S . Miller <davem@davemloft.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/7aef2f8ecd75c2f505ef9b80490412262cf4a44c.1507038547.git.jpoimboe@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-10-01Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Thomas Gleixner: "This contains the following fixes and improvements: - Avoid dereferencing an unprotected VMA pointer in the fault signal generation code - Fix inline asm call constraints for GCC 4.4 - Use existing register variable to retrieve the stack pointer instead of forcing the compiler to create another indirect access which results in excessive extra 'mov %rsp, %<dst>' instructions - Disable branch profiling for the memory encryption code to prevent an early boot crash - Fix a sparse warning caused by casting the __user annotation in __get_user_asm_u64() away - Fix an off by one error in the loop termination of the error patch in the x86 sysfs init code - Add missing CPU IDs to various Intel specific drivers to enable the functionality on recent hardware - More (init) constification in the numachip code" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/asm: Use register variable to get stack pointer value x86/mm: Disable branch profiling in mem_encrypt.c x86/asm: Fix inline asm call constraints for GCC 4.4 perf/x86/intel/uncore: Correct num_boxes for IIO and IRP perf/x86/intel/rapl: Add missing CPU IDs perf/x86/msr: Add missing CPU IDs perf/x86/intel/cstate: Add missing CPU IDs x86: Don't cast away the __user in __get_user_asm_u64() x86/sysfs: Fix off-by-one error in loop termination x86/mm: Fix fault error path using unsafe vma pointer x86/numachip: Add const and __initconst to numachip2_clockevent
2017-09-29Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm fixes from Paolo Bonzini: "Mixed bugfixes. Perhaps the most interesting one is a latent bug that was finally triggered by PCID support" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: kvm/x86: Handle async PF in RCU read-side critical sections KVM: nVMX: Fix nested #PF intends to break L1's vmlauch/vmresume KVM: VMX: use cmpxchg64 KVM: VMX: simplify and fix vmx_vcpu_pi_load KVM: VMX: avoid double list add with VT-d posted interrupts KVM: VMX: extract __pi_post_block KVM: PPC: Book3S HV: Check for updated HDSISR on P9 HDSI exception KVM: nVMX: fix HOST_CR3/HOST_CR4 cache
2017-09-29x86/asm: Use register variable to get stack pointer valueAndrey Ryabinin
Currently we use current_stack_pointer() function to get the value of the stack pointer register. Since commit: f5caf621ee35 ("x86/asm: Fix inline asm call constraints for Clang") ... we have a stack register variable declared. It can be used instead of current_stack_pointer() function which allows to optimize away some excessive "mov %rsp, %<dst>" instructions: -mov %rsp,%rdx -sub %rdx,%rax -cmp $0x3fff,%rax -ja ffffffff810722fd <ist_begin_non_atomic+0x2d> +sub %rsp,%rax +cmp $0x3fff,%rax +ja ffffffff810722fa <ist_begin_non_atomic+0x2a> Remove current_stack_pointer(), rename __asm_call_sp to current_stack_pointer and use it instead of the removed function. Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20170929141537.29167-1-aryabinin@virtuozzo.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-09-29kvm/x86: Handle async PF in RCU read-side critical sectionsBoqun Feng
Sasha Levin reported a WARNING: | WARNING: CPU: 0 PID: 6974 at kernel/rcu/tree_plugin.h:329 | rcu_preempt_note_context_switch kernel/rcu/tree_plugin.h:329 [inline] | WARNING: CPU: 0 PID: 6974 at kernel/rcu/tree_plugin.h:329 | rcu_note_context_switch+0x16c/0x2210 kernel/rcu/tree.c:458 ... | CPU: 0 PID: 6974 Comm: syz-fuzzer Not tainted 4.13.0-next-20170908+ #246 | Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS | 1.10.1-1ubuntu1 04/01/2014 | Call Trace: ... | RIP: 0010:rcu_preempt_note_context_switch kernel/rcu/tree_plugin.h:329 [inline] | RIP: 0010:rcu_note_context_switch+0x16c/0x2210 kernel/rcu/tree.c:458 | RSP: 0018:ffff88003b2debc8 EFLAGS: 00010002 | RAX: 0000000000000001 RBX: 1ffff1000765bd85 RCX: 0000000000000000 | RDX: 1ffff100075d7882 RSI: ffffffffb5c7da20 RDI: ffff88003aebc410 | RBP: ffff88003b2def30 R08: dffffc0000000000 R09: 0000000000000001 | R10: 0000000000000000 R11: 0000000000000000 R12: ffff88003b2def08 | R13: 0000000000000000 R14: ffff88003aebc040 R15: ffff88003aebc040 | __schedule+0x201/0x2240 kernel/sched/core.c:3292 | schedule+0x113/0x460 kernel/sched/core.c:3421 | kvm_async_pf_task_wait+0x43f/0x940 arch/x86/kernel/kvm.c:158 | do_async_page_fault+0x72/0x90 arch/x86/kernel/kvm.c:271 | async_page_fault+0x22/0x30 arch/x86/entry/entry_64.S:1069 | RIP: 0010:format_decode+0x240/0x830 lib/vsprintf.c:1996 | RSP: 0018:ffff88003b2df520 EFLAGS: 00010283 | RAX: 000000000000003f RBX: ffffffffb5d1e141 RCX: ffff88003b2df670 | RDX: 0000000000000001 RSI: dffffc0000000000 RDI: ffffffffb5d1e140 | RBP: ffff88003b2df560 R08: dffffc0000000000 R09: 0000000000000000 | R10: ffff88003b2df718 R11: 0000000000000000 R12: ffff88003b2df5d8 | R13: 0000000000000064 R14: ffffffffb5d1e140 R15: 0000000000000000 | vsnprintf+0x173/0x1700 lib/vsprintf.c:2136 | sprintf+0xbe/0xf0 lib/vsprintf.c:2386 | proc_self_get_link+0xfb/0x1c0 fs/proc/self.c:23 | get_link fs/namei.c:1047 [inline] | link_path_walk+0x1041/0x1490 fs/namei.c:2127 ... This happened when the host hit a page fault, and delivered it as in an async page fault, while the guest was in an RCU read-side critical section. The guest then tries to reschedule in kvm_async_pf_task_wait(), but rcu_preempt_note_context_switch() would treat the reschedule as a sleep in RCU read-side critical section, which is not allowed (even in preemptible RCU). Thus the WARN. To cure this, make kvm_async_pf_task_wait() go to the halt path if the PF happens in a RCU read-side critical section. Reported-by: Sasha Levin <levinsasha928@gmail.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: stable@vger.kernel.org Signed-off-by: Boqun Feng <boqun.feng@gmail.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2017-09-26Merge branch 'WIP.x86/fpu' into x86/fpu, because it's readyIngo Molnar
2017-09-26x86/fpu: Use using_compacted_format() instead of open coded X86_FEATURE_XSAVESEric Biggers
This is the canonical method to use. Signed-off-by: Eric Biggers <ebiggers@google.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Kees Cook <keescook@chromium.org> Cc: Kevin Hao <haokexin@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael Halcrow <mhalcrow@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wanpeng Li <wanpeng.li@hotmail.com> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Cc: kernel-hardening@lists.openwall.com Link: http://lkml.kernel.org/r/20170924105913.9157-11-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-09-26x86/fpu: Use validate_xstate_header() to validate the xstate_header in ↵Eric Biggers
copy_user_to_xstate() Tighten the checks in copy_user_to_xstate(). Signed-off-by: Eric Biggers <ebiggers@google.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Kees Cook <keescook@chromium.org> Cc: Kevin Hao <haokexin@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael Halcrow <mhalcrow@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wanpeng Li <wanpeng.li@hotmail.com> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Cc: kernel-hardening@lists.openwall.com Link: http://lkml.kernel.org/r/20170924105913.9157-10-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-09-26x86/fpu: Eliminate the 'xfeatures' local variable in copy_user_to_xstate()Eric Biggers
We now have this field in hdr.xfeatures. Signed-off-by: Eric Biggers <ebiggers@google.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Kees Cook <keescook@chromium.org> Cc: Kevin Hao <haokexin@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael Halcrow <mhalcrow@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wanpeng Li <wanpeng.li@hotmail.com> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Cc: kernel-hardening@lists.openwall.com Link: http://lkml.kernel.org/r/20170924105913.9157-9-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-09-26x86/fpu: Copy the full header in copy_user_to_xstate()Eric Biggers
This is in preparation to verify the full xstate header as supplied by user-space. Signed-off-by: Eric Biggers <ebiggers@google.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Kees Cook <keescook@chromium.org> Cc: Kevin Hao <haokexin@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael Halcrow <mhalcrow@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wanpeng Li <wanpeng.li@hotmail.com> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Cc: kernel-hardening@lists.openwall.com Link: http://lkml.kernel.org/r/20170924105913.9157-8-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
copy_kernel_to_xstate() Tighten the checks in copy_kernel_to_xstate(). Signed-off-by: Eric Biggers <ebiggers@google.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Kees Cook <keescook@chromium.org> Cc: Kevin Hao <haokexin@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael Halcrow <mhalcrow@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wanpeng Li <wanpeng.li@hotmail.com> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Cc: kernel-hardening@lists.openwall.com Link: http://lkml.kernel.org/r/20170924105913.9157-7-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-09-26x86/fpu: Eliminate the 'xfeatures' local variable in copy_kernel_to_xstate()Eric Biggers
We have this information in the xstate_header. Signed-off-by: Eric Biggers <ebiggers@google.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Kees Cook <keescook@chromium.org> Cc: Kevin Hao <haokexin@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael Halcrow <mhalcrow@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wanpeng Li <wanpeng.li@hotmail.com> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Cc: kernel-hardening@lists.openwall.com Link: http://lkml.kernel.org/r/20170924105913.9157-6-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-09-26x86/fpu: Copy the full state_header in copy_kernel_to_xstate()Eric Biggers
This is in preparation to verify the full xstate header as supplied by user-space. Signed-off-by: Eric Biggers <ebiggers@google.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Kees Cook <keescook@chromium.org> Cc: Kevin Hao <haokexin@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael Halcrow <mhalcrow@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wanpeng Li <wanpeng.li@hotmail.com> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Cc: kernel-hardening@lists.openwall.com Link: http://lkml.kernel.org/r/20170924105913.9157-5-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
__fpu__restore_sig() Tighten the checks in __fpu__restore_sig() and update comments. Signed-off-by: Eric Biggers <ebiggers@google.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Kees Cook <keescook@chromium.org> Cc: Kevin Hao <haokexin@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael Halcrow <mhalcrow@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wanpeng Li <wanpeng.li@hotmail.com> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Cc: kernel-hardening@lists.openwall.com Link: http://lkml.kernel.org/r/20170924105913.9157-4-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
xstateregs_set() Tighten the checks in xstateregs_set(). Signed-off-by: Eric Biggers <ebiggers@google.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Kees Cook <keescook@chromium.org> Cc: Kevin Hao <haokexin@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael Halcrow <mhalcrow@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wanpeng Li <wanpeng.li@hotmail.com> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Cc: kernel-hardening@lists.openwall.com Link: http://lkml.kernel.org/r/20170924105913.9157-3-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-09-26x86/fpu: Introduce validate_xstate_header()Eric Biggers
Move validation of user-supplied xstate_header into a helper function, in preparation of calling it from both the ptrace and sigreturn syscall paths. The new function also considers it to be an error if *any* reserved bits are set, whereas before we were just clearing most of them silently. This should reduce the chance of bugs that fail to correctly validate user-supplied XSAVE areas. It also will expose any broken userspace programs that set the other reserved bits; this is desirable because such programs will lose compatibility with future CPUs and kernels if those bits are ever used for anything. (There shouldn't be any such programs, and in fact in the case where the compacted format is in use we were already validating xfeatures. But you never know...) Signed-off-by: Eric Biggers <ebiggers@google.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Kees Cook <keescook@chromium.org> Cc: Kevin Hao <haokexin@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael Halcrow <mhalcrow@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wanpeng Li <wanpeng.li@hotmail.com> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Cc: kernel-hardening@lists.openwall.com Link: http://lkml.kernel.org/r/20170924105913.9157-2-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-09-26x86/fpu: Rename fpu__activate_fpstate_read/write() to ↵Ingo Molnar
fpu__prepare_[read|write]() As per the new nomenclature we don't 'activate' the FPU state anymore, we initialize it. So drop the _activate_fpstate name from these functions, which were a bit of a mouthful anyway, and name them: fpu__prepare_read() fpu__prepare_write() Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-09-26x86/fpu: Rename fpu__activate_curr() to fpu__initialize()Ingo Molnar
Rename this function to better express that it's all about initializing the FPU state of a task which goes hand in hand with the fpu::initialized field. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Link: http://lkml.kernel.org/r/20170923130016.21448-33-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-09-26x86/fpu: Simplify and speed up fpu__copy()Ingo Molnar
fpu__copy() has a preempt_disable()/enable() pair, which it had to do to be able to atomically unlazy the current task when doing an FNSAVE. But we don't unlazy tasks anymore, we always do direct saves/restores of FPU context. So remove both the unnecessary critical section, and update the comments. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Link: http://lkml.kernel.org/r/20170923130016.21448-32-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-09-26x86/fpu: Fix stale comments about lazy FPU logicIngo Molnar
We don't do any lazy restore anymore, what we have are two pieces of optimization: - no-FPU tasks that don't save/restore the FPU context (kernel threads are such) - cached FPU registers maintained via the fpu->last_cpu field. This means that if an FPU task context switches to a non-FPU task then we can maintain the FPU registers as an in-FPU copies (cache), and skip the restoration of them once we switch back to the original FPU-using task. Update all the comments that still referred to old 'lazy' and 'unlazy' concepts. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Link: http://lkml.kernel.org/r/20170923130016.21448-31-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-09-26x86/fpu: Rename fpu::fpstate_active to fpu::initializedIngo Molnar
The x86 FPU code used to have a complex state machine where both the FPU registers and the FPU state context could be 'active' (or inactive) independently of each other - which enabled features like lazy FPU restore. Much of this complexity is gone in the current code: now we basically can have FPU-less tasks (kernel threads) that don't use (and save/restore) FPU state at all, plus full FPU users that save/restore directly with no laziness whatsoever. But the fpu::fpstate_active still carries bits of the old complexity - meanwhile this flag has become a simple flag that shows whether the FPU context saving area in the thread struct is initialized and used, or not. Rename it to fpu::initialized to express this simplicity in the name as well. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Link: http://lkml.kernel.org/r/20170923130016.21448-30-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-09-26x86/fpu: Remove fpu__current_fpstate_write_begin/end()Ingo Molnar
These functions are not used anymore, so remove them. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Bobby Powers <bobbypowers@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Link: http://lkml.kernel.org/r/20170923130016.21448-29-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-09-26x86/fpu: Fix fpu__activate_fpstate_read() and update commentsIngo Molnar
fpu__activate_fpstate_read() can be called for the current task when coredumping - or for stopped tasks when ptrace-ing. Implement this properly in the code and update the comments. This also fixes an incorrect (but harmless) warning introduced by one of the earlier patches. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Link: http://lkml.kernel.org/r/20170923130016.21448-28-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-09-25x86/sysfs: Fix off-by-one error in loop terminationSean Fu
An off-by-one error in loop terminantion conditions in create_setup_data_nodes() will lead to memory leak when create_setup_data_node() failed. Signed-off-by: Sean Fu <fxinrong@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1505090001-1157-1-git-send-email-fxinrong@gmail.com
2017-09-25x86/fpu: Don't let userspace set bogus xcomp_bvEric Biggers
On x86, userspace can use the ptrace() or rt_sigreturn() system calls to set a task's extended state (xstate) or "FPU" registers. ptrace() can set them for another task using the PTRACE_SETREGSET request with NT_X86_XSTATE, while rt_sigreturn() can set them for the current task. In either case, registers can be set to any value, but the kernel assumes that the XSAVE area itself remains valid in the sense that the CPU can restore it. However, in the case where the kernel is using the uncompacted xstate format (which it does whenever the XSAVES instruction is unavailable), it was possible for userspace to set the xcomp_bv field in the xstate_header to an arbitrary value. However, all bits in that field are reserved in the uncompacted case, so when switching to a task with nonzero xcomp_bv, the XRSTOR instruction failed with a #GP fault. This caused the WARN_ON_FPU(err) in copy_kernel_to_xregs() to be hit. In addition, since the error is otherwise ignored, the FPU registers from the task previously executing on the CPU were leaked. Fix the bug by checking that the user-supplied value of xcomp_bv is 0 in the uncompacted case, and returning an error otherwise. The reason for validating xcomp_bv rather than simply overwriting it with 0 is that we want userspace to see an error if it (incorrectly) provides an XSAVE area in compacted format rather than in uncompacted format. Note that as before, in case of error we clear the task's FPU state. This is perhaps non-ideal, especially for PTRACE_SETREGSET; it might be better to return an error before changing anything. But it seems the "clear on error" behavior is fine for now, and it's a little tricky to do otherwise because it would mean we couldn't simply copy the full userspace state into kernel memory in one __copy_from_user(). This bug was found by syzkaller, which hit the above-mentioned WARN_ON_FPU(): WARNING: CPU: 1 PID: 0 at ./arch/x86/include/asm/fpu/internal.h:373 __switch_to+0x5b5/0x5d0 CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.13.0 #453 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 task: ffff9ba2bc8e42c0 task.stack: ffffa78cc036c000 RIP: 0010:__switch_to+0x5b5/0x5d0 RSP: 0000:ffffa78cc08bbb88 EFLAGS: 00010082 RAX: 00000000fffffffe RBX: ffff9ba2b8bf2180 RCX: 00000000c0000100 RDX: 00000000ffffffff RSI: 000000005cb10700 RDI: ffff9ba2b8bf36c0 RBP: ffffa78cc08bbbd0 R08: 00000000929fdf46 R09: 0000000000000001 R10: 0000000000000000 R11: 0000000000000000 R12: ffff9ba2bc8e42c0 R13: 0000000000000000 R14: ffff9ba2b8bf3680 R15: ffff9ba2bf5d7b40 FS: 00007f7e5cb10700(0000) GS:ffff9ba2bf400000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00000000004005cc CR3: 0000000079fd5000 CR4: 00000000001406e0 Call Trace: Code: 84 00 00 00 00 00 e9 11 fd ff ff 0f ff 66 0f 1f 84 00 00 00 00 00 e9 e7 fa ff ff 0f ff 66 0f 1f 84 00 00 00 00 00 e9 c2 fa ff ff <0f> ff 66 0f 1f 84 00 00 00 00 00 e9 d4 fc ff ff 66 66 2e 0f 1f Here is a C reproducer. The expected behavior is that the program spin forever with no output. However, on a buggy kernel running on a processor with the "xsave" feature but without the "xsaves" feature (e.g. Sandy Bridge through Broadwell for Intel), within a second or two the program reports that the xmm registers were corrupted, i.e. were not restored correctly. With CONFIG_X86_DEBUG_FPU=y it also hits the above kernel warning. #define _GNU_SOURCE #include <stdbool.h> #include <inttypes.h> #include <linux/elf.h> #include <stdio.h> #include <sys/ptrace.h> #include <sys/uio.h> #include <sys/wait.h> #include <unistd.h> int main(void) { int pid = fork(); uint64_t xstate[512]; struct iovec iov = { .iov_base = xstate, .iov_len = sizeof(xstate) }; if (pid == 0) { bool tracee = true; for (int i = 0; i < sysconf(_SC_NPROCESSORS_ONLN) && tracee; i++) tracee = (fork() != 0); uint32_t xmm0[4] = { [0 ... 3] = tracee ? 0x00000000 : 0xDEADBEEF }; asm volatile(" movdqu %0, %%xmm0\n" " mov %0, %%rbx\n" "1: movdqu %%xmm0, %0\n" " mov %0, %%rax\n" " cmp %%rax, %%rbx\n" " je 1b\n" : "+m" (xmm0) : : "rax", "rbx", "xmm0"); printf("BUG: xmm registers corrupted! tracee=%d, xmm0=%08X%08X%08X%08X\n", tracee, xmm0[0], xmm0[1], xmm0[2], xmm0[3]); } else { usleep(100000); ptrace(PTRACE_ATTACH, pid, 0, 0); wait(NULL); ptrace(PTRACE_GETREGSET, pid, NT_X86_XSTATE, &iov); xstate[65] = -1; ptrace(PTRACE_SETREGSET, pid, NT_X86_XSTATE, &iov); ptrace(PTRACE_CONT, pid, 0, 0); wait(NULL); } return 1; } Note: the program only tests for the bug using the ptrace() system call. The bug can also be reproduced using the rt_sigreturn() system call, but only when called from a 32-bit program, since for 64-bit programs the kernel restores the FPU state from the signal frame by doing XRSTOR directly from userspace memory (with proper error checking). Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Reviewed-by: Kees Cook <keescook@chromium.org> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: <stable@vger.kernel.org> [v3.17+] Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Kevin Hao <haokexin@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael Halcrow <mhalcrow@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wanpeng Li <wanpeng.li@hotmail.com> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Cc: kernel-hardening@lists.openwall.com Fixes: 0b29643a5843 ("x86/xsaves: Change compacted format xsave area header") Link: http://lkml.kernel.org/r/20170922174156.16780-2-ebiggers3@gmail.com Link: http://lkml.kernel.org/r/20170923130016.21448-25-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-09-24x86/fpu: Fix boolreturn.cocci warningskbuild test robot
arch/x86/kernel/fpu/xstate.c:931:9-10: WARNING: return of 0/1 in function 'xfeatures_mxcsr_quirk' with return type bool Return statements in functions returning bool should use true/false instead of 1/0. Generated by: scripts/coccinelle/misc/boolreturn.cocci Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Borislav Petkov <bp@suse.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Cc: kbuild-all@01.org Cc: tipbuild@zytor.com Link: http://lkml.kernel.org/r/20170306004553.GA25764@lkp-wsm-ep1 Link: http://lkml.kernel.org/r/20170923130016.21448-23-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-09-24x86/fpu: Add FPU state copying quirk to handle XRSTOR failure on Intel ↵Rik van Riel
Skylake CPUs On Skylake CPUs I noticed that XRSTOR is unable to deal with states created by copyout_from_xsaves() if the xstate has only SSE/YMM state, and no FP state. That is, xfeatures had XFEATURE_MASK_SSE set, but not XFEATURE_MASK_FP. The reason is that part of the SSE/YMM state lives in the MXCSR and MXCSR_FLAGS fields of the FP state. Ensure that whenever we copy SSE or YMM state around, the MXCSR and MXCSR_FLAGS fields are also copied around. Signed-off-by: Rik van Riel <riel@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Borislav Petkov <bp@suse.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Link: http://lkml.kernel.org/r/20170210085445.0f1cc708@annuminas.surriel.com Link: http://lkml.kernel.org/r/20170923130016.21448-22-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-09-24x86/fpu: Remove struct fpu::fpregs_activeIngo Molnar
The previous changes paved the way for the removal of the fpu::fpregs_active state flag - we now only have the fpu::fpstate_active and fpu::last_cpu fields left. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Link: http://lkml.kernel.org/r/20170923130016.21448-21-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-09-24x86/fpu: Decouple fpregs_activate()/fpregs_deactivate() from fpu->fpregs_activeIngo Molnar
The fpregs_activate()/fpregs_deactivate() are currently called in such a pattern: if (!fpu->fpregs_active) fpregs_activate(fpu); ... if (fpu->fpregs_active) fpregs_deactivate(fpu); But note that it's actually safe to call them without checking the flag first. This further decouples the fpu->fpregs_active flag from actual FPU logic. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Link: http://lkml.kernel.org/r/20170923130016.21448-20-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-09-24x86/fpu: Change fpu->fpregs_active users to fpu->fpstate_activeIngo Molnar
We want to simplify the FPU state machine by eliminating fpu->fpregs_active, and we can do that because the two state flags (::fpregs_active and ::fpstate_active) are set essentially together. The old lazy FPU switching code used to make a distinction - but there's no lazy switching code anymore, we always switch in an 'eager' fashion. Do this by first changing all substantial uses of fpu->fpregs_active to fpu->fpstate_active and adding a few debug checks to double check our assumption is correct. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Link: http://lkml.kernel.org/r/20170923130016.21448-19-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-09-24x86/fpu: Split the state handling in fpu__drop()Ingo Molnar
Prepare fpu__drop() to use fpu->fpregs_active. There are two distinct usecases for fpu__drop() in this context: exit_thread() when called for 'current' in exit(), and when called for another task in fork(). This patch does not change behavior, it only adds a couple of debug checks and structures the code to make the ->fpregs_active change more obviously correct. All the complications will be removed later on. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Link: http://lkml.kernel.org/r/20170923130016.21448-18-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-09-24x86/fpu: Make the fpu state change in fpu__clear() scheduler-atomicIngo Molnar
Do this temporarily only, to make it easier to change the FPU state machine, in particular this change couples the fpu->fpregs_active and fpu->fpstate_active states: they are only set/cleared together (as far as the scheduler sees them). This will be removed by later patches. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Link: http://lkml.kernel.org/r/20170923130016.21448-17-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-09-24x86/fpu: Simplify fpu->fpregs_active useIngo Molnar
The fpregs_active() inline function is pretty pointless - in almost all the callsites it can be replaced with a direct fpu->fpregs_active access. Do so and eliminate the extra layer of obfuscation. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Eric Biggers <ebiggers3@gmail.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Yu-cheng Yu <yu-cheng.yu@intel.com> Link: http://lkml.kernel.org/r/20170923130016.21448-16-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
