Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Blacklist Broadwell X model 79 for late loading due to an erratum.
Acked-by: Tony Luck <tony.luck@intel.com>
Cc: <stable@vger.kernel.org>
Link: http://lkml.kernel.org/r/20171018111225.25635-1-bp@alien8.de
Moving the early IDT setup out of assembly code breaks the boot on first
generation 486 systems.
The reason is that the call of idt_setup_early_handler, which sets up the
early handlers was added after the call to cr4_init_shadow().
cr4_init_shadow() tries to read CR4 which is not available on those
systems. The accessor function uses a extable fixup to handle the resulting
fault. As the IDT is not set up yet, the cr4 read exception causes an
instantaneous reboot for obvious reasons.
Call idt_setup_early_handler() before cr4_init_shadow() so IDT is set up
before the first exception hits.
Fixes: 87e81786b13b ("x86/idt: Move early IDT setup out of 32-bit asm")
Reported-and-tested-by: Matthew Whitehead <whiteheadm@acm.org>
Link: https://lkml.kernel.org/r/alpine.DEB.2.20.1710161210290.1973@nanos
The 'this_leaf' variable is assigned a value that is never
read and it is updated a little later with a newer value,
hence we can remove the redundant assignment.
Cleans up the following Clang warning:
Value stored to 'this_leaf' is never read
Reviewed-by: Borislav Petkov <bp@suse.de>
Cc: kernel-janitors@vger.kernel.org
Link: http://lkml.kernel.org/r/20171015160203.12332-1-colin.king@canonical.com
Pull x86 fixes from Ingo Molnar:
"A landry list of fixes:
- fix reboot breakage on some PCID-enabled system
- fix crashes/hangs on some PCID-enabled systems
- fix microcode loading on certain older CPUs
- various unwinder fixes
- extend an APIC quirk to more hardware systems and disable APIC
related warning on virtualized systems
- various Hyper-V fixes
- a macro definition robustness fix
- remove jprobes IRQ disabling
- various mem-encryption fixes"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/microcode: Do the family check first
x86/mm: Flush more aggressively in lazy TLB mode
x86/apic: Update TSC_DEADLINE quirk with additional SKX stepping
x86/apic: Silence "FW_BUG TSC_DEADLINE disabled due to Errata" on hypervisors
x86/mm: Disable various instrumentations of mm/mem_encrypt.c and mm/tlb.c
x86/hyperv: Fix hypercalls with extended CPU ranges for TLB flushing
x86/hyperv: Don't use percpu areas for pcpu_flush/pcpu_flush_ex structures
x86/hyperv: Clear vCPU banks between calls to avoid flushing unneeded vCPUs
x86/unwind: Disable unwinder warnings on 32-bit
x86/unwind: Align stack pointer in unwinder dump
x86/unwind: Use MSB for frame pointer encoding on 32-bit
x86/unwind: Fix dereference of untrusted pointer
x86/alternatives: Fix alt_max_short macro to really be a max()
x86/mm/64: Fix reboot interaction with CR4.PCIDE
kprobes/x86: Remove IRQ disabling from jprobe handlers
kprobes/x86: Set up frame pointer in kprobe trampoline
Pull RAS fixes from Ingo Molnar:
"A boot parameter fix, plus a header export fix"
* 'ras-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/mce: Hide mca_cfg
RAS/CEC: Use the right length for "cec_disable"
On CPUs like AMD's Geode, for example, we shouldn't even try to load
microcode because they do not support the modern microcode loading
interface.
However, we do the family check *after* the other checks whether the
loader has been disabled on the command line or whether we're running in
a guest.
So move the family checks first in order to exit early if we're being
loaded on an unsupported family.
Reported-and-tested-by: Sven Glodowski <glodi1@arcor.de>
Cc: <stable@vger.kernel.org> # 4.11..
Link: http://bugzilla.suse.com/show_bug.cgi?id=1061396
Link: http://lkml.kernel.org/r/20171012112316.977-1-bp@alien8.de
SKX stepping-3 fixed the TSC_DEADLINE issue in a different ucode
version number than stepping-4. Linux needs to know this stepping-3
specific version number to also enable the TSC_DEADLINE on stepping-3.
The steppings and ucode versions are documented in the SKX BIOS update:
https://downloadmirror.intel.com/26978/eng/ReleaseNotes_R00.01.0004.txt
Signed-off-by: Len Brown <len.brown@intel.com>
Cc: peterz@infradead.org
Link: https://lkml.kernel.org/r/60f2bbf7cf617e212b522e663f84225bfebc50e5.1507756305.git.len.brown@intel.com
Commit 594a30fb1242 ("x86/apic: Silence "FW_BUG TSC_DEADLINE disabled
due to Errata" on CPUs without the feature", 2017-08-30) was also about
silencing the warning on VirtualBox; however, KVM does expose the TSC
deadline timer, and it's virtualized so that it is immune from CPU errata.
Therefore, booting 4.13 with "-cpu Haswell" shows this in the logs:
[ 0.000000] [Firmware Bug]: TSC_DEADLINE disabled due to Errata;
please update microcode to version: 0xb2 (or later)
Even if you had a hypervisor that does _not_ virtualize the TSC deadline
and rather exposes the hardware one, it should be the hypervisors task
to update microcode and possibly hide the flag from CPUID. So just
hide the message when running on _any_ hypervisor, not just those that
do not support the TSC deadline timer.
The older check still makes sense, so keep it.
Fixes: bd9240a18e ("x86/apic: Add TSC_DEADLINE quirk due to errata")
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: kvm@vger.kernel.org
Cc: stable@vger.kernel.org
Link: https://lkml.kernel.org/r/1507630377-54471-1-git-send-email-pbonzini@redhat.com
x86-32 doesn't have stack validation, so in most cases it doesn't make
sense to warn about bad frame pointers.
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Byungchul Park <byungchul.park@lge.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: LKP <lkp@01.org>
Link: http://lkml.kernel.org/r/a69658760800bf281e6353248c23e0fa0acf5230.1507597785.git.jpoimboe@redhat.com
When printing the unwinder dump, the stack pointer could be unaligned,
for one of two reasons:
- stack corruption; or
- GCC created an unaligned stack.
There's no way for the unwinder to tell the difference between the two,
so we have to assume one or the other. GCC unaligned stacks are very
rare, and have only been spotted before GCC 5. Presumably, if we're
doing an unwinder stack dump, stack corruption is more likely than a
GCC unaligned stack. So always align the stack before starting the
dump.
Reported-and-tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com>
Link: http://lkml.kernel.org/r/2f540c515946ab09ed267e1a1d6421202a0cce08.1507597785.git.jpoimboe@redhat.com
On x86-32, Tetsuo Handa and Fengguang Wu reported unwinder warnings
like:
WARNING: kernel stack regs at f60bb9c8 in swapper:1 has bad 'bp' value 0ba00000
And also there were some stack dumps with a bunch of unreliable '?'
symbols after an apic_timer_interrupt symbol, meaning the unwinder got
confused when it tried to read the regs.
The cause of those issues is that, with GCC 4.8 (and possibly older),
there are cases where GCC misaligns the stack pointer in a leaf function
for no apparent reason:
c124a388 <acpi_rs_move_data>:
c124a388: 55 push %ebp
c124a389: 89 e5 mov %esp,%ebp
c124a38b: 57 push %edi
c124a38c: 56 push %esi
c124a38d: 89 d6 mov %edx,%esi
c124a38f: 53 push %ebx
c124a390: 31 db xor %ebx,%ebx
c124a392: 83 ec 03 sub $0x3,%esp
c124a3e3: 83 c4 03 add $0x3,%esp
c124a3e6: 5b pop %ebx
c124a3e7: 5e pop %esi
c124a3e8: 5f pop %edi
c124a3e9: 5d pop %ebp
c124a3ea: c3 ret
If an interrupt occurs in such a function, the regs on the stack will be
unaligned, which breaks the frame pointer encoding assumption. So on
32-bit, use the MSB instead of the LSB to encode the regs.
This isn't an issue on 64-bit, because interrupts align the stack before
writing to it.
Link: http://lkml.kernel.org/r/279a26996a482ca716605c7dbc7f2db9d8d91e81.1507597785.git.jpoimboe@redhat.com
Tetsuo Handa and Fengguang Wu reported a panic in the unwinder:
BUG: unable to handle kernel NULL pointer dereference at 000001f2
IP: update_stack_state+0xd4/0x340
*pde = 00000000
Oops: 0000 [#1] PREEMPT SMP
CPU: 0 PID: 18728 Comm: 01-cpu-hotplug Not tainted 4.13.0-rc4-00170-gb09be67 #592
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.9.3-20161025_171302-gandalf 04/01/2014
task: bb0b53c0 task.stack: bb3ac000
EIP: update_stack_state+0xd4/0x340
EFLAGS: 00010002 CPU: 0
EAX: 0000a570 EBX: bb3adccb ECX: 0000f401 EDX: 0000a570
ESI: 00000001 EDI: 000001ba EBP: bb3adc6b ESP: bb3adc3f
DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068
CR0: 80050033 CR2: 000001f2 CR3: 0b3a7000 CR4: 00140690
DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
DR6: fffe0ff0 DR7: 00000400
Call Trace:
? unwind_next_frame+0xea/0x400
? __unwind_start+0xf5/0x180
? __save_stack_trace+0x81/0x160
? save_stack_trace+0x20/0x30
? __lock_acquire+0xfa5/0x12f0
? lock_acquire+0x1c2/0x230
? tick_periodic+0x3a/0xf0
? _raw_spin_lock+0x42/0x50
? debug_smp_processor_id+0x12/0x20
? tick_handle_periodic+0x23/0xc0
? local_apic_timer_interrupt+0x63/0x70
? smp_trace_apic_timer_interrupt+0x235/0x6a0
? trace_apic_timer_interrupt+0x37/0x3c
? strrchr+0x23/0x50
Code: 0f 95 c1 89 c7 89 45 e4 0f b6 c1 89 c6 89 45 dc 8b 04 85 98 cb 74 bc 88 4d e3 89 45 f0 83 c0 01 84 c9 89 04 b5 98 cb 74 bc 74 3b <8b> 47 38 8b 57 34 c6 43 1d 01 25 00 00 02 00 83 e2 03 09 d0 83
EIP: update_stack_state+0xd4/0x340 SS:ESP: 0068:bb3adc3f
CR2: 00000000000001f2
---[ end trace 0d147fd4aba8ff50 ]---
Kernel panic - not syncing: Fatal exception in interrupt
On x86-32, after decoding a frame pointer to get a regs address,
regs_size() dereferences the regs pointer when it checks regs->cs to see
if the regs are user mode. This is dangerous because it's possible that
what looks like a decoded frame pointer is actually a corrupt value, and
we don't want the unwinder to make things worse.
Instead of calling regs_size() on an unsafe pointer, just assume they're
kernel regs to start with. Later, once it's safe to access the regs, we
can do the user mode check and corresponding safety check for the
remaining two regs.
Fixes: 5ed8d8bb38c5 ("x86/unwind: Move common code into update_stack_state()")
Link: http://lkml.kernel.org/r/7f95b9a6993dec7674b3f3ab3dcd3294f7b9644d.1507597785.git.jpoimboe@redhat.com
Trying to reboot via real mode fails with PCID on: long mode cannot
be exited while CR4.PCIDE is set. (No, I have no idea why, but the
SDM and actual CPUs are in agreement here.) The result is a GPF and
a hang instead of a reboot.
I didn't catch this in testing because neither my computer nor my VM
reboots this way. I can trigger it with reboot=bios, though.
Fixes: 660da7c9228f ("x86/mm: Enable CR4.PCIDE on supported systems")
Reported-and-tested-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Link: https://lkml.kernel.org/r/f1e7d965998018450a7a70c2823873686a8b21c0.1507524746.git.luto@kernel.org
Now that lguest is gone, put it in the internal header which should be
used only by MCA/RAS code.
Add missing header guards while at it.
No functional change.
Link: https://lkml.kernel.org/r/20171002092836.22971-3-bp@alien8.de
Currently, in PREEMPT_COUNT=n kernel, kvm_async_pf_task_wait() could call
schedule() to reschedule in some cases. This could result in
accidentally ending the current RCU read-side critical section early,
causing random memory corruption in the guest, or otherwise preempting
the currently running task inside between preempt_disable and
preempt_enable.
The difficulty to handle this well is because we don't know whether an
async PF delivered in a preemptible section or RCU read-side critical section
for PREEMPT_COUNT=n, since preempt_disable()/enable() and rcu_read_lock/unlock()
are both no-ops in that case.
To cure this, we treat any async PF interrupting a kernel context as one
that cannot be preempted, preventing kvm_async_pf_task_wait() from choosing
the schedule() path in that case.
To do so, a second parameter for kvm_async_pf_task_wait() is introduced,
so that we know whether it's called from a context interrupting the
kernel, and the parameter is set properly in all the callsites.
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Wanpeng Li <wanpeng.li@hotmail.com>
Signed-off-by: Boqun Feng <boqun.feng@gmail.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
Jprobes actually don't need to disable IRQs while calling
handlers, because of how we specify the kernel interface in
Documentation/kprobes.txt:
Probe handlers are run with preemption disabled. Depending on the
architecture and optimization state, handlers may also run with
interrupts disabled (e.g., kretprobe handlers and optimized kprobe
handlers run without interrupt disabled on x86/x86-64).
So let's remove IRQ disabling from jprobes too.
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Alexei Starovoitov <ast@fb.com>
Cc: Alexei Starovoitov <ast@kernel.org>
Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com>
Cc: Paul E . McKenney <paulmck@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/150701508194.32266.14458959863314097305.stgit@devbox
Richard Weinberger saw an unwinder warning when running bcc's opensnoop:
WARNING: kernel stack frame pointer at ffff99ef4076bea0 in opensnoop:2008 has bad value 0000000000000008
unwind stack type:0 next_sp: (null) mask:0x2 graph_idx:0
ffff99ef4076be88: ffff99ef4076bea0 (0xffff99ef4076bea0)
ffff99ef4076be90: ffffffffac442721 (optimized_callback +0x81/0x90)
A lockdep stack trace was initiated from inside a kprobe handler, when
the unwinder noticed a bad frame pointer on the stack. The bad frame
pointer is related to the fact that the kprobe optprobe trampoline
doesn't save the frame pointer before calling into optimized_callback().
Reported-and-tested-by: Richard Weinberger <richard@sigma-star.at>
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
Cc: David S . Miller <davem@davemloft.net>
Link: http://lkml.kernel.org/r/7aef2f8ecd75c2f505ef9b80490412262cf4a44c.1507038547.git.jpoimboe@redhat.com
Pull x86 fixes from Thomas Gleixner:
"This contains the following fixes and improvements:
- Avoid dereferencing an unprotected VMA pointer in the fault signal
generation code
- Fix inline asm call constraints for GCC 4.4
- Use existing register variable to retrieve the stack pointer
instead of forcing the compiler to create another indirect access
which results in excessive extra 'mov %rsp, %<dst>' instructions
- Disable branch profiling for the memory encryption code to prevent
an early boot crash
- Fix a sparse warning caused by casting the __user annotation in
__get_user_asm_u64() away
- Fix an off by one error in the loop termination of the error patch
in the x86 sysfs init code
- Add missing CPU IDs to various Intel specific drivers to enable the
functionality on recent hardware
- More (init) constification in the numachip code"
x86/asm: Use register variable to get stack pointer value
x86/mm: Disable branch profiling in mem_encrypt.c
x86/asm: Fix inline asm call constraints for GCC 4.4
perf/x86/intel/uncore: Correct num_boxes for IIO and IRP
perf/x86/intel/rapl: Add missing CPU IDs
perf/x86/msr: Add missing CPU IDs
perf/x86/intel/cstate: Add missing CPU IDs
x86: Don't cast away the __user in __get_user_asm_u64()
x86/sysfs: Fix off-by-one error in loop termination
x86/mm: Fix fault error path using unsafe vma pointer
x86/numachip: Add const and __initconst to numachip2_clockevent
Pull kvm fixes from Paolo Bonzini:
"Mixed bugfixes. Perhaps the most interesting one is a latent bug that
was finally triggered by PCID support"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
kvm/x86: Handle async PF in RCU read-side critical sections
KVM: nVMX: Fix nested #PF intends to break L1's vmlauch/vmresume
KVM: VMX: use cmpxchg64
KVM: VMX: simplify and fix vmx_vcpu_pi_load
KVM: VMX: avoid double list add with VT-d posted interrupts
KVM: VMX: extract __pi_post_block
KVM: PPC: Book3S HV: Check for updated HDSISR on P9 HDSI exception
KVM: nVMX: fix HOST_CR3/HOST_CR4 cache
Currently we use current_stack_pointer() function to get the value
of the stack pointer register. Since commit:
f5caf621ee35 ("x86/asm: Fix inline asm call constraints for Clang")
... we have a stack register variable declared. It can be used instead of
current_stack_pointer() function which allows to optimize away some
excessive "mov %rsp, %<dst>" instructions:
-mov %rsp,%rdx
-sub %rdx,%rax
-cmp $0x3fff,%rax
-ja ffffffff810722fd <ist_begin_non_atomic+0x2d>
+sub %rsp,%rax
+cmp $0x3fff,%rax
+ja ffffffff810722fa <ist_begin_non_atomic+0x2a>
Remove current_stack_pointer(), rename __asm_call_sp to current_stack_pointer
and use it instead of the removed function.
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
Link: http://lkml.kernel.org/r/20170929141537.29167-1-aryabinin@virtuozzo.com
Sasha Levin reported a WARNING:
| WARNING: CPU: 0 PID: 6974 at kernel/rcu/tree_plugin.h:329
| rcu_preempt_note_context_switch kernel/rcu/tree_plugin.h:329 [inline]
| rcu_note_context_switch+0x16c/0x2210 kernel/rcu/tree.c:458
| CPU: 0 PID: 6974 Comm: syz-fuzzer Not tainted 4.13.0-next-20170908+ #246
| 1.10.1-1ubuntu1 04/01/2014
| Call Trace:
| RIP: 0010:rcu_preempt_note_context_switch kernel/rcu/tree_plugin.h:329 [inline]
| RIP: 0010:rcu_note_context_switch+0x16c/0x2210 kernel/rcu/tree.c:458
| RSP: 0018:ffff88003b2debc8 EFLAGS: 00010002
| RAX: 0000000000000001 RBX: 1ffff1000765bd85 RCX: 0000000000000000
| RDX: 1ffff100075d7882 RSI: ffffffffb5c7da20 RDI: ffff88003aebc410
| RBP: ffff88003b2def30 R08: dffffc0000000000 R09: 0000000000000001
| R10: 0000000000000000 R11: 0000000000000000 R12: ffff88003b2def08
| R13: 0000000000000000 R14: ffff88003aebc040 R15: ffff88003aebc040
| __schedule+0x201/0x2240 kernel/sched/core.c:3292
| schedule+0x113/0x460 kernel/sched/core.c:3421
| kvm_async_pf_task_wait+0x43f/0x940 arch/x86/kernel/kvm.c:158
| do_async_page_fault+0x72/0x90 arch/x86/kernel/kvm.c:271
| async_page_fault+0x22/0x30 arch/x86/entry/entry_64.S:1069
| RIP: 0010:format_decode+0x240/0x830 lib/vsprintf.c:1996
| RSP: 0018:ffff88003b2df520 EFLAGS: 00010283
| RAX: 000000000000003f RBX: ffffffffb5d1e141 RCX: ffff88003b2df670
| RDX: 0000000000000001 RSI: dffffc0000000000 RDI: ffffffffb5d1e140
| RBP: ffff88003b2df560 R08: dffffc0000000000 R09: 0000000000000000
| R10: ffff88003b2df718 R11: 0000000000000000 R12: ffff88003b2df5d8
| R13: 0000000000000064 R14: ffffffffb5d1e140 R15: 0000000000000000
| vsnprintf+0x173/0x1700 lib/vsprintf.c:2136
| sprintf+0xbe/0xf0 lib/vsprintf.c:2386
| proc_self_get_link+0xfb/0x1c0 fs/proc/self.c:23
| get_link fs/namei.c:1047 [inline]
| link_path_walk+0x1041/0x1490 fs/namei.c:2127
This happened when the host hit a page fault, and delivered it as in an
async page fault, while the guest was in an RCU read-side critical
section. The guest then tries to reschedule in kvm_async_pf_task_wait(),
but rcu_preempt_note_context_switch() would treat the reschedule as a
sleep in RCU read-side critical section, which is not allowed (even in
preemptible RCU). Thus the WARN.
To cure this, make kvm_async_pf_task_wait() go to the halt path if the
PF happens in a RCU read-side critical section.
Reported-by: Sasha Levin <levinsasha928@gmail.com>
This is the canonical method to use.
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Eric Biggers <ebiggers3@gmail.com>
Cc: Kevin Hao <haokexin@gmail.com>
Cc: Michael Halcrow <mhalcrow@google.com>
Cc: Yu-cheng Yu <yu-cheng.yu@intel.com>
Cc: kernel-hardening@lists.openwall.com
Link: http://lkml.kernel.org/r/20170924105913.9157-11-mingo@kernel.org
copy_user_to_xstate()
Tighten the checks in copy_user_to_xstate().
Link: http://lkml.kernel.org/r/20170924105913.9157-10-mingo@kernel.org
We now have this field in hdr.xfeatures.
Link: http://lkml.kernel.org/r/20170924105913.9157-9-mingo@kernel.org
This is in preparation to verify the full xstate header as supplied by user-space.
Link: http://lkml.kernel.org/r/20170924105913.9157-8-mingo@kernel.org
copy_kernel_to_xstate()
Tighten the checks in copy_kernel_to_xstate().
Link: http://lkml.kernel.org/r/20170924105913.9157-7-mingo@kernel.org
We have this information in the xstate_header.
Link: http://lkml.kernel.org/r/20170924105913.9157-6-mingo@kernel.org
Link: http://lkml.kernel.org/r/20170924105913.9157-5-mingo@kernel.org
__fpu__restore_sig()
Tighten the checks in __fpu__restore_sig() and update comments.
Link: http://lkml.kernel.org/r/20170924105913.9157-4-mingo@kernel.org
xstateregs_set()
Tighten the checks in xstateregs_set().
Link: http://lkml.kernel.org/r/20170924105913.9157-3-mingo@kernel.org
Move validation of user-supplied xstate_header into a helper function,
in preparation of calling it from both the ptrace and sigreturn syscall
paths.
The new function also considers it to be an error if *any* reserved bits
are set, whereas before we were just clearing most of them silently.
This should reduce the chance of bugs that fail to correctly validate
user-supplied XSAVE areas. It also will expose any broken userspace
programs that set the other reserved bits; this is desirable because
such programs will lose compatibility with future CPUs and kernels if
those bits are ever used for anything. (There shouldn't be any such
programs, and in fact in the case where the compacted format is in use
we were already validating xfeatures. But you never know...)
Link: http://lkml.kernel.org/r/20170924105913.9157-2-mingo@kernel.org
fpu__prepare_[read|write]()
As per the new nomenclature we don't 'activate' the FPU state
anymore, we initialize it. So drop the _activate_fpstate name
from these functions, which were a bit of a mouthful anyway,
and name them:
fpu__prepare_read()
fpu__prepare_write()
Rename this function to better express that it's all about
initializing the FPU state of a task which goes hand in hand
with the fpu::initialized field.
Link: http://lkml.kernel.org/r/20170923130016.21448-33-mingo@kernel.org
fpu__copy() has a preempt_disable()/enable() pair, which it had to do to
be able to atomically unlazy the current task when doing an FNSAVE.
But we don't unlazy tasks anymore, we always do direct saves/restores of
FPU context.
So remove both the unnecessary critical section, and update the comments.
Link: http://lkml.kernel.org/r/20170923130016.21448-32-mingo@kernel.org
We don't do any lazy restore anymore, what we have are two pieces of optimization:
- no-FPU tasks that don't save/restore the FPU context (kernel threads are such)
- cached FPU registers maintained via the fpu->last_cpu field. This means that
if an FPU task context switches to a non-FPU task then we can maintain the
FPU registers as an in-FPU copies (cache), and skip the restoration of them
once we switch back to the original FPU-using task.
Update all the comments that still referred to old 'lazy' and 'unlazy' concepts.
Link: http://lkml.kernel.org/r/20170923130016.21448-31-mingo@kernel.org
The x86 FPU code used to have a complex state machine where both the FPU
registers and the FPU state context could be 'active' (or inactive)
independently of each other - which enabled features like lazy FPU restore.
Much of this complexity is gone in the current code: now we basically can
have FPU-less tasks (kernel threads) that don't use (and save/restore) FPU
state at all, plus full FPU users that save/restore directly with no laziness
whatsoever.
But the fpu::fpstate_active still carries bits of the old complexity - meanwhile
this flag has become a simple flag that shows whether the FPU context saving
area in the thread struct is initialized and used, or not.
Rename it to fpu::initialized to express this simplicity in the name as well.
Link: http://lkml.kernel.org/r/20170923130016.21448-30-mingo@kernel.org
These functions are not used anymore, so remove them.
Cc: Bobby Powers <bobbypowers@gmail.com>
Link: http://lkml.kernel.org/r/20170923130016.21448-29-mingo@kernel.org
fpu__activate_fpstate_read() can be called for the current task
when coredumping - or for stopped tasks when ptrace-ing.
Implement this properly in the code and update the comments.
This also fixes an incorrect (but harmless) warning introduced by
one of the earlier patches.
Link: http://lkml.kernel.org/r/20170923130016.21448-28-mingo@kernel.org
An off-by-one error in loop terminantion conditions in
create_setup_data_nodes() will lead to memory leak when
create_setup_data_node() failed.
Signed-off-by: Sean Fu <fxinrong@gmail.com>
Link: http://lkml.kernel.org/r/1505090001-1157-1-git-send-email-fxinrong@gmail.com
On x86, userspace can use the ptrace() or rt_sigreturn() system calls to
set a task's extended state (xstate) or "FPU" registers. ptrace() can
set them for another task using the PTRACE_SETREGSET request with
NT_X86_XSTATE, while rt_sigreturn() can set them for the current task.
In either case, registers can be set to any value, but the kernel
assumes that the XSAVE area itself remains valid in the sense that the
CPU can restore it.
However, in the case where the kernel is using the uncompacted xstate
format (which it does whenever the XSAVES instruction is unavailable),
it was possible for userspace to set the xcomp_bv field in the
xstate_header to an arbitrary value. However, all bits in that field
are reserved in the uncompacted case, so when switching to a task with
nonzero xcomp_bv, the XRSTOR instruction failed with a #GP fault. This
caused the WARN_ON_FPU(err) in copy_kernel_to_xregs() to be hit. In
addition, since the error is otherwise ignored, the FPU registers from
the task previously executing on the CPU were leaked.
Fix the bug by checking that the user-supplied value of xcomp_bv is 0 in
the uncompacted case, and returning an error otherwise.
The reason for validating xcomp_bv rather than simply overwriting it
with 0 is that we want userspace to see an error if it (incorrectly)
provides an XSAVE area in compacted format rather than in uncompacted
format.
Note that as before, in case of error we clear the task's FPU state.
This is perhaps non-ideal, especially for PTRACE_SETREGSET; it might be
better to return an error before changing anything. But it seems the
"clear on error" behavior is fine for now, and it's a little tricky to
do otherwise because it would mean we couldn't simply copy the full
userspace state into kernel memory in one __copy_from_user().
This bug was found by syzkaller, which hit the above-mentioned
WARN_ON_FPU():
WARNING: CPU: 1 PID: 0 at ./arch/x86/include/asm/fpu/internal.h:373 __switch_to+0x5b5/0x5d0
CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.13.0 #453
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
task: ffff9ba2bc8e42c0 task.stack: ffffa78cc036c000
RIP: 0010:__switch_to+0x5b5/0x5d0
RSP: 0000:ffffa78cc08bbb88 EFLAGS: 00010082
RAX: 00000000fffffffe RBX: ffff9ba2b8bf2180 RCX: 00000000c0000100
RDX: 00000000ffffffff RSI: 000000005cb10700 RDI: ffff9ba2b8bf36c0
RBP: ffffa78cc08bbbd0 R08: 00000000929fdf46 R09: 0000000000000001
R10: 0000000000000000 R11: 0000000000000000 R12: ffff9ba2bc8e42c0
R13: 0000000000000000 R14: ffff9ba2b8bf3680 R15: ffff9ba2bf5d7b40
FS: 00007f7e5cb10700(0000) GS:ffff9ba2bf400000(0000) knlGS:0000000000000000
CR2: 00000000004005cc CR3: 0000000079fd5000 CR4: 00000000001406e0
Call Trace:
Code: 84 00 00 00 00 00 e9 11 fd ff ff 0f ff 66 0f 1f 84 00 00 00 00 00 e9 e7 fa ff ff 0f ff 66 0f 1f 84 00 00 00 00 00 e9 c2 fa ff ff <0f> ff 66 0f 1f 84 00 00 00 00 00 e9 d4 fc ff ff 66 66 2e 0f 1f
Here is a C reproducer. The expected behavior is that the program spin
forever with no output. However, on a buggy kernel running on a
processor with the "xsave" feature but without the "xsaves" feature
(e.g. Sandy Bridge through Broadwell for Intel), within a second or two
the program reports that the xmm registers were corrupted, i.e. were not
restored correctly. With CONFIG_X86_DEBUG_FPU=y it also hits the above
kernel warning.
#define _GNU_SOURCE
#include <stdbool.h>
#include <inttypes.h>
#include <linux/elf.h>
#include <stdio.h>
#include <sys/ptrace.h>
#include <sys/uio.h>
#include <sys/wait.h>
#include <unistd.h>
int main(void)
int pid = fork();
uint64_t xstate[512];
struct iovec iov = { .iov_base = xstate, .iov_len = sizeof(xstate) };
if (pid == 0) {
bool tracee = true;
for (int i = 0; i < sysconf(_SC_NPROCESSORS_ONLN) && tracee; i++)
tracee = (fork() != 0);
uint32_t xmm0[4] = { [0 ... 3] = tracee ? 0x00000000 : 0xDEADBEEF };
asm volatile(" movdqu %0, %%xmm0\n"
" mov %0, %%rbx\n"
"1: movdqu %%xmm0, %0\n"
" mov %0, %%rax\n"
" cmp %%rax, %%rbx\n"
" je 1b\n"
: "+m" (xmm0) : : "rax", "rbx", "xmm0");
printf("BUG: xmm registers corrupted! tracee=%d, xmm0=%08X%08X%08X%08X\n",
tracee, xmm0[0], xmm0[1], xmm0[2], xmm0[3]);
} else {
usleep(100000);
ptrace(PTRACE_ATTACH, pid, 0, 0);
wait(NULL);
ptrace(PTRACE_GETREGSET, pid, NT_X86_XSTATE, &iov);
xstate[65] = -1;
ptrace(PTRACE_SETREGSET, pid, NT_X86_XSTATE, &iov);
ptrace(PTRACE_CONT, pid, 0, 0);
wait(NULL);
return 1;
Note: the program only tests for the bug using the ptrace() system call.
The bug can also be reproduced using the rt_sigreturn() system call, but
only when called from a 32-bit program, since for 64-bit programs the
kernel restores the FPU state from the signal frame by doing XRSTOR
directly from userspace memory (with proper error checking).
Acked-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: <stable@vger.kernel.org> [v3.17+]
Fixes: 0b29643a5843 ("x86/xsaves: Change compacted format xsave area header")
Link: http://lkml.kernel.org/r/20170922174156.16780-2-ebiggers3@gmail.com
Link: http://lkml.kernel.org/r/20170923130016.21448-25-mingo@kernel.org
arch/x86/kernel/fpu/xstate.c:931:9-10: WARNING: return of 0/1 in function 'xfeatures_mxcsr_quirk' with return type bool
Return statements in functions returning bool should use true/false instead of 1/0.
Generated by: scripts/coccinelle/misc/boolreturn.cocci
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: kbuild-all@01.org
Cc: tipbuild@zytor.com
Link: http://lkml.kernel.org/r/20170306004553.GA25764@lkp-wsm-ep1
Link: http://lkml.kernel.org/r/20170923130016.21448-23-mingo@kernel.org
Skylake CPUs
On Skylake CPUs I noticed that XRSTOR is unable to deal with states
created by copyout_from_xsaves() if the xstate has only SSE/YMM state, and
no FP state. That is, xfeatures had XFEATURE_MASK_SSE set, but not
XFEATURE_MASK_FP.
The reason is that part of the SSE/YMM state lives in the MXCSR and
MXCSR_FLAGS fields of the FP state.
Ensure that whenever we copy SSE or YMM state around, the MXCSR and
MXCSR_FLAGS fields are also copied around.
Signed-off-by: Rik van Riel <riel@redhat.com>
Link: http://lkml.kernel.org/r/20170210085445.0f1cc708@annuminas.surriel.com
Link: http://lkml.kernel.org/r/20170923130016.21448-22-mingo@kernel.org
The previous changes paved the way for the removal of the
fpu::fpregs_active state flag - we now only have the
fpu::fpstate_active and fpu::last_cpu fields left.
Link: http://lkml.kernel.org/r/20170923130016.21448-21-mingo@kernel.org
The fpregs_activate()/fpregs_deactivate() are currently called in such a pattern:
if (!fpu->fpregs_active)
fpregs_activate(fpu);
if (fpu->fpregs_active)
fpregs_deactivate(fpu);
But note that it's actually safe to call them without checking the flag first.
This further decouples the fpu->fpregs_active flag from actual FPU logic.
Link: http://lkml.kernel.org/r/20170923130016.21448-20-mingo@kernel.org
We want to simplify the FPU state machine by eliminating fpu->fpregs_active,
and we can do that because the two state flags (::fpregs_active and
::fpstate_active) are set essentially together.
The old lazy FPU switching code used to make a distinction - but there's
no lazy switching code anymore, we always switch in an 'eager' fashion.
Do this by first changing all substantial uses of fpu->fpregs_active
to fpu->fpstate_active and adding a few debug checks to double check
our assumption is correct.
Link: http://lkml.kernel.org/r/20170923130016.21448-19-mingo@kernel.org
Prepare fpu__drop() to use fpu->fpregs_active.
There are two distinct usecases for fpu__drop() in this context:
exit_thread() when called for 'current' in exit(), and when called
for another task in fork().
This patch does not change behavior, it only adds a couple of
debug checks and structures the code to make the ->fpregs_active
change more obviously correct.
All the complications will be removed later on.
Link: http://lkml.kernel.org/r/20170923130016.21448-18-mingo@kernel.org
Do this temporarily only, to make it easier to change the FPU state machine,
in particular this change couples the fpu->fpregs_active and fpu->fpstate_active
states: they are only set/cleared together (as far as the scheduler sees them).
This will be removed by later patches.
Link: http://lkml.kernel.org/r/20170923130016.21448-17-mingo@kernel.org
The fpregs_active() inline function is pretty pointless - in almost
all the callsites it can be replaced with a direct fpu->fpregs_active
access.
Do so and eliminate the extra layer of obfuscation.
Link: http://lkml.kernel.org/r/20170923130016.21448-16-mingo@kernel.org
