* 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
clockevent: Prevent dead lock on clockevents_lock
timers: Drop write permission on /proc/timer_list
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Fix build with older binutils and consolidate linker script
x86: Fix an incorrect argument of reserve_bootmem()
x86: add vmlinux.lds to targets in arch/x86/boot/compressed/Makefile
xen: rearrange things to fix stackprotector
x86: make sure load_percpu_segment has no stackprotector
i386: Fix section mismatches for init code with !HOTPLUG_CPU
x86, pat: Allow ISA memory range uncacheable mapping requests
binutils prior to 2.17 can't deal with the currently possible
situation of a new segment following the per-CPU segment, but
that new segment being empty - objcopy misplaces the .bss (and
perhaps also the .brk) sections outside of any segment.
However, the current ordering of sections really just appears
to be the effect of cumulative unrelated changes; re-ordering
things allows to easily guarantee that the segment following
the per-CPU one is non-empty, and at once eliminates the need
for the bogus data.init2 segment.
Once touching this code, also use the various data section
helper macros from include/asm-generic/vmlinux.lds.h.
-v2: fix !SMP builds.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Cc: <sam@ravnborg.org>
LKML-Reference: <4A94085D02000078000119A5@vpn.id2.novell.com>
The default_send_IPI_mask_logical() function uses the "flat" APIC mode
to send an IPI to a set of CPU's at once, but if that set happens to be
empty, some older local APIC's will apparently be rather unhappy. So
just warn if a caller gives us an empty mask, and ignore it.
This fixes a regression in 2.6.30.x, due to commit 4595f9620 ("x86:
change flush_tlb_others to take a const struct cpumask"), documented
here:
http://bugzilla.kernel.org/show_bug.cgi?id=13933
which causes a silent lock-up. It only seems to happen on PPro, P2, P3
and Athlon XP cores. Most developers sadly (or not so sadly, if you're
a developer..) have more modern CPU's. Also, on x86-64 we don't use the
flat APIC mode, so it would never trigger there even if the APIC didn't
like sending an empty IPI mask.
Reported-by: Pavel Vilim <wylda@volny.cz>
Reported-and-tested-by: Thomas Björnell <thomas.bjornell@gmail.com>
Reported-and-tested-by: Martin Rogge <marogge@onlinehome.de>
Cc: Mike Travis <travis@sgi.com>
Cc: stable@kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen into x86/urgent
load_percpu_segment() is used to set up the per-cpu segment registers,
which are also used for -fstack-protector. Make sure that the
load_percpu_segment() function doesn't have stackprotector enabled.
[ Impact: allow percpu setup before calling stack-protected functions ]
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Currently clockevents_notify() is called with interrupts enabled at
some places and interrupts disabled at some other places.
This results in a deadlock in this scenario.
cpu A holds clockevents_lock in clockevents_notify() with irqs enabled
cpu B waits for clockevents_lock in clockevents_notify() with irqs disabled
cpu C doing set_mtrr() which will try to rendezvous of all the cpus.
This will result in C and A come to the rendezvous point and waiting
for B. B is stuck forever waiting for the spinlock and thus not
reaching the rendezvous point.
Fix the clockevents code so that clockevents_lock is taken with
interrupts disabled and thus avoid the above deadlock.
Also call lapic_timer_propagate_broadcast() on the destination cpu so
that we avoid calling smp_call_function() in the clockevents notifier
chain.
This issue left us wondering if we need to change the MTRR rendezvous
logic to use stop machine logic (instead of smp_call_function) or add
a check in spinlock debug code to see if there are other spinlocks
which gets taken under both interrupts enabled/disabled conditions.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Cc: "Pallipadi Venkatesh" <venkatesh.pallipadi@intel.com>
Cc: "Brown Len" <len.brown@intel.com>
LKML-Reference: <1250544899.2709.210.camel@sbs-t61.sc.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: use the right flag for get_vm_area()
percpu, sparc64: fix sparse possible cpu map handling
init: set nr_cpu_ids before setup_per_cpu_areas()
Commit 0e83815be719d3391bf5ea24b7fe696c07dbd417 changed the
section the initial_code variable gets allocated in, in an
attempt to address a section conflict warning. This, however
created a new section conflict when building without
HOTPLUG_CPU. The apparently only (reasonable) way to address
this is to always use __REFDATA.
Once at it, also fix a second section mismatch when not using
HOTPLUG_CPU.
Cc: Robert Richter <robert.richter@amd.com>
LKML-Reference: <4A8AE7CD020000780001054B@vpn.id2.novell.com>
An older test-box started hanging at the following point during
bootup:
[ 0.022996] Mount-cache hash table entries: 512
[ 0.024996] Initializing cgroup subsys debug
[ 0.025996] Initializing cgroup subsys cpuacct
[ 0.026995] Initializing cgroup subsys devices
[ 0.027995] Initializing cgroup subsys freezer
[ 0.028995] mce: CPU supports 5 MCE banks
I've bisected it down to commit 4efc0670 ("x86, mce: use 64bit
machine check code on 32bit"), which utilizes the MCE code on
32-bit systems too.
The problem is caused by this detail in my config:
# CONFIG_CPU_SUP_INTEL is not set
This disables the quirks in mce_cpu_quirks() but still enables
MCE support - which then hangs due to the missing quirk
workaround needed on this CPU:
if (c->x86 == 6 && c->x86_model < 0x1A && banks > 0)
mce_banks[0].init = 0;
The safe solution is to not initialize MCEs if we dont know on
what CPU we are running (or if that CPU's support code got
disabled in the config).
Also be a bit more defensive on 32-bit systems: dont do a
boot-time dump of pending MCEs not just on the specific system
that we found a problem with (Pentium-M), but earlier ones as
well.
Now this problem is probably not common and disabling CPU
support is rare - but still being more defensive in something
we turned on for a wide range of CPUs is prudent.
Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
LKML-Reference: Message-ID: <4A88E3E4.40506@jp.fujitsu.com>
On my legacy Pentium M laptop (Acer Extensa 2900) I get bogus MCE on a cold
boot with CONFIG_X86_NEW_MCE enabled, i.e. (after decoding it with mcelog):
MCE 0
HARDWARE ERROR. This is *NOT* a software problem!
Please contact your hardware vendor
CPU 0 BANK 1 MCG status:
MCi status:
Error overflow
Uncorrected error
Error enabled
Processor context corrupt
MCA: Data CACHE Level-1 UNKNOWN Error
STATUS f200000000000195 MCGSTATUS 0
[ The other STATUS values observed: f2000000000001b5 (... UNKNOWN error)
and f200000000000115 (... READ Error).
To verify that this is not a CONFIG_X86_NEW_MCE bug I also modified
the CONFIG_X86_OLD_MCE code (which doesn't log any MCEs) to dump
content of STATUS MSR before it is cleared during initialization. ]
Since the bogus MCE results in a kernel taint (which in turn disables
lockdep support) don't log boot MCEs on Pentium M (model == 13) CPUs
by default ("mce=bootlog" boot parameter can be be used to get the old
behavior).
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Reviewed-by: Andi Kleen <andi@firstfloor.org>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
The function uv_acpi_madt_oem_check() has been marked __init,
the struct apic_x2apic_uv_x has been marked __refdata.
The aim is to address the following section mismatch messages:
WARNING: arch/x86/kernel/apic/built-in.o(.data+0x1368): Section mismatch in reference from the variable apic_x2apic_uv_x to the function .cpuinit.text:uv_wakeup_secondary()
The variable apic_x2apic_uv_x references
the function __cpuinit uv_wakeup_secondary()
If the reference is valid then annotate the
variable with __init* or __refdata (see linux/init.h) or name the variable:
*driver, *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console,
WARNING: arch/x86/kernel/built-in.o(.data+0x68e8): Section mismatch in reference from the variable apic_x2apic_uv_x to the function .cpuinit.text:uv_wakeup_secondary()
WARNING: arch/x86/built-in.o(.text+0x7b36f): Section mismatch in reference from the function uv_acpi_madt_oem_check() to the function .init.text:early_ioremap()
The function uv_acpi_madt_oem_check() references
the function __init early_ioremap().
This is often because uv_acpi_madt_oem_check lacks a __init
annotation or the annotation of early_ioremap is wrong.
WARNING: arch/x86/built-in.o(.text+0x7b38d): Section mismatch in reference from the function uv_acpi_madt_oem_check() to the function .init.text:early_iounmap()
the function __init early_iounmap().
annotation or the annotation of early_iounmap is wrong.
WARNING: arch/x86/built-in.o(.data+0x8668): Section mismatch in reference from the variable apic_x2apic_uv_x to the function .cpuinit.text:uv_wakeup_secondary()
Signed-off-by: Leonardo Potenza <lpotenza@inwind.it>
LKML-Reference: <200908161855.48302.lpotenza@inwind.it>
0d01f31439c1e4d602bf9fdc924ab66f407f5e38 "x86, mce: therm_throt
- change when we print messages" removed redundant
announcements of "Temperature/speed normal".
They're not worth logging and remove their accompanying
"Machine check events logged" messages as well from the
console.
Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Dmitry Torokhov <dtor@mail.ru>
LKML-Reference: <Pine.LNX.4.64.0908161544100.7929@sister.anvils>
The SGI UV Broadcast Assist Unit is used to send TLB shootdown
messages to remote nodes of the system. The header of the
message must contain the subnode id of the block in the
receiving hub that handles such messages. It should always be
0x10, the id of the "LB" block.
It had previously been documented as a "must be zero" field.
Signed-off-by: Cliff Wickman <cpw@sgi.com>
Acked-by: Jack Steiner <steiner@sgi.com>
LKML-Reference: <E1Mc1x7-0005Ce-6t@eag09.americas.sgi.com>
percpu code has been assuming num_possible_cpus() == nr_cpu_ids which
is incorrect if cpu_possible_map contains holes. This causes percpu
code to access beyond allocated memories and vmalloc areas. On a
sparc64 machine with cpus 0 and 2 (u60), this triggers the following
warning or fails boot.
WARNING: at /devel/tj/os/work/mm/vmalloc.c:106 vmap_page_range_noflush+0x1f0/0x240()
Modules linked in:
Call Trace:
[00000000004b17d0] vmap_page_range_noflush+0x1f0/0x240
[00000000004b1840] map_vm_area+0x20/0x60
[00000000004b1950] __vmalloc_area_node+0xd0/0x160
[0000000000593434] deflate_init+0x14/0xe0
[0000000000583b94] __crypto_alloc_tfm+0xd4/0x1e0
[00000000005844f0] crypto_alloc_base+0x50/0xa0
[000000000058b898] alg_test_comp+0x18/0x80
[000000000058dad4] alg_test+0x54/0x180
[000000000058af00] cryptomgr_test+0x40/0x60
[0000000000473098] kthread+0x58/0x80
[000000000042b590] kernel_thread+0x30/0x60
[0000000000472fd0] kthreadd+0xf0/0x160
---[ end trace 429b268a213317ba ]---
This patch fixes generic percpu functions and sparc64
setup_per_cpu_areas() so that they handle sparse cpu_possible_map
properly.
Please note that on x86, cpu_possible_map() doesn't contain holes and
thus num_possible_cpus() == nr_cpu_ids and this patch doesn't cause
any behavior difference.
* 'perfcounters-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf_counter: Report the cloning task as parent on perf_counter_fork()
perf_counter: Fix an ipi-deadlock
perf: Rework/fix the whole read vs group stuff
perf_counter: Fix swcounter context invariance
perf report: Don't show unresolved DSOs and symbols when -S/-d is used
perf tools: Add a general option to enable raw sample records
perf tools: Add a per tracepoint counter attribute to get raw sample
perf_counter: Provide hw_perf_counter_setup_online() APIs
perf list: Fix large list output by using the pager
perf_counter, x86: Fix/improve apic fallback
perf record: Add missing -C option support for specifying profile cpu
perf tools: Fix dso__new handle() to handle deleted DSOs
perf tools: Fix fallback to cplus_demangle() when bfd_demangle() is not available
perf report: Show the tid too in -D
perf record: Fix .tid and .pid fill-in when synthesizing events
perf_counter, x86: Fix generic cache events on P6-mobile CPUs
perf_counter, x86: Fix lapic printk message
Johannes Stezenbach reported that his Pentium-M based
laptop does not have the local APIC enabled by default,
and hence perfcounters do not get initialized.
Add a fallback for this case: allow non-sampled counters
and return with an error on sampled counters. This allows
'perf stat' to work out of box - and allows 'perf top'
and 'perf record' to fall back on a hrtimer based sampling
method.
( Passing 'lapic' on the boot line will allow hardware
sampling to occur - but if the APIC is disabled
permanently by the hardware then this fallback still
allows more systems to use perfcounters. )
Also decouple perfcounter support from X86_LOCAL_APIC.
-v2: fix typo breaking counters on all other systems ...
Reported-by: Johannes Stezenbach <js@sig21.net>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
LKML-Reference: <new-submission>
Kernel is broken for x86 CPUs without CPUID since 2.6.28. It
crashes with NULL pointer dereference in identify_cpu():
766 generic_identify(c);
767
768--> if (this_cpu->c_identify)
769 this_cpu->c_identify(c);
this_cpu is NULL. This is because it's only initialized in
get_cpu_vendor() function, which is not called if the CPU has
no CPUID instruction.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
LKML-Reference: <200908112000.15993.linux@rainbow-software.org>
Due to an erratum with certain AMD Athlon 64 processors, the
BIOS may need to force enable the LAHF_LM capability.
Unfortunately, in at least one case, the BIOS does this even
for processors that do not support the functionality.
Add a specific check that will clear the feature bit for
processors known not to support the LAHF/SAHF instructions.
Signed-off-by: Kevin Winchester <kjwinchester@gmail.com>
Acked-by: Borislav Petkov <petkovbb@googlemail.com>
LKML-Reference: <4A80A5AD.2000209@gmail.com>
Johannes Stezenbach reported that 'perf stat' does not count
cache-miss and cache-references events on his Pentium-M based
laptop.
This is because we left them blank in p6_perfmon_event_map[],
fill them in.
Instead of this garbled bootup on UP Pentium-M systems:
[ 0.015048] Performance Counters:
[ 0.016004] no Local APIC, try rebooting with lapicno PMU driver, software counters only.
Print:
[ 0.015050] Performance Counters:
[ 0.016004] no APIC, boot with the "lapic" boot parameter to force-enable it.
[ 0.017003] no PMU driver, software counters only.
Cf: Frederic Weisbecker <fweisbec@gmail.com>
My Latitude d630 seems to be handling thermal events in SMI by
lowering the max frequency of the CPU till it cools down but
still leaks the "everything is normal" events.
This spams the console and with high priority printks.
Adjust therm_throt driver to only print messages about the fact
that temperatire returned back to normal when leaving the
throttling state.
Also lower the severity of "back to normal" message from
KERN_CRIT to KERN_INFO.
Acked-by: H. Peter Anvin <hpa@zytor.com>
LKML-Reference: <20090810051513.0558F526EC9@mailhub.coreip.homeip.net>
Reboot does not work on my MacBook Pro 13 inch (MacBookPro5,5)
too. It seems all unibody MacBook and MacBookPro require
PCI reboot handling, i guess.
Following model/machine ID list shows unibody MacBook/Pro have
the 5 series of model number:
http://www.everymac.com/systems/by_capability/macs-by-machine-model-machine-id.html
Signed-off-by: Shunichi Fuji <palglowr@gmail.com>
Cc: Ozan Çağlayan <ozan@pardus.org.tr>
LKML-Reference: <30046e3b0908101134p6487ddbftd8776e4ddef204be@mail.gmail.com>
Wei Chong Tan reported a fast-PIT-calibration corner-case:
| pit_expect_msb() is vulnerable to SMI disturbance corner case
| in some platforms which causes /proc/cpuinfo to show wrong
| CPU MHz value when quick_pit_calibrate() jumps to success
| section.
I think that the real issue isn't even an SMI - but the fact
that in the very last iteration of the loop, there's no
serializing instruction _after_ the last 'rdtsc'. So even in
the absense of SMI's, we do have a situation where the cycle
counter was read without proper serialization.
The last check should be done outside the outer loop, since
_inside_ the outer loop, we'll be testing that the PIT has
the right MSB value has the right value in the next iteration.
So only the _last_ iteration is special, because that's the one
that will not check the PIT MSB value any more, and because the
final 'get_cycles()' isn't serialized.
In other words:
- I'd like to move the PIT MSB check to after the last
iteration, rather than in every iteration
- I think we should comment on the fact that it's also a
serializing instruction and so 'fences in' the TSC read.
Here's a suggested replacement.
Reported-by: "Tan, Wei Chong" <wei.chong.tan@intel.com>
Tested-by: "Tan, Wei Chong" <wei.chong.tan@intel.com>
LKML-Reference: <B28277FD4E0F9247A3D55704C440A140D5D683F3@pgsmsx504.gar.corp.intel.com>
If the vendor name (from c16) can be longer than 100 bytes (or missing a
terminating null), then the null is written past the end of vendor[].
Found with Parfait, http://research.sun.com/projects/parfait/
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Cc: Huang Ying <ying.huang@intel.com>
MacBookPro5,1 is not able to reboot unless reboot=pci is set.
This patch forces it through a DMI quirk specific to this
device.
Signed-off-by: Ozan Çağlayan <ozan@pardus.org.tr>
LKML-Reference: <1249403971-6543-1-git-send-email-ozan@pardus.org.tr>
found a system where x2apic reports an MSI-X irq initialization
failure:
[ 302.859446] igbvf 0000:81:10.4: enabling device (0000 -> 0002)
[ 302.874369] igbvf 0000:81:10.4: using 64bit DMA mask
[ 302.879023] igbvf 0000:81:10.4: using 64bit consistent DMA mask
[ 302.894386] igbvf 0000:81:10.4: enabling bus mastering
[ 302.898171] igbvf 0000:81:10.4: setting latency timer to 64
[ 302.914050] reserve_memtype added 0xefb08000-0xefb0c000, track uncached-minus, req uncached-minus, ret uncached-minus
[ 302.933839] reserve_memtype added 0xefb28000-0xefb29000, track uncached-minus, req uncached-minus, ret uncached-minus
[ 302.940367] alloc irq_desc for 265 on node 4
[ 302.956874] alloc kstat_irqs on node 4
[ 302.959452] alloc irq_2_iommu on node 0
[ 302.974328] igbvf 0000:81:10.4: irq 265 for MSI/MSI-X
[ 302.977778] alloc irq_desc for 266 on node 4
[ 302.980347] alloc kstat_irqs on node 4
[ 302.995312] free_memtype request 0xefb28000-0xefb29000
[ 302.998816] igbvf 0000:81:10.4: Failed to initialize MSI-X interrupts.
... it turns out that when trying to enable MSI-X,
__assign_irq_vector(new, cfg_new, apic->target_cpus()) can not
get vector because for x2apic target-cpus returns cpumask_of(0)
Update that to online_mask like xapic.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
LKML-Reference: <4A785AFF.3050902@kernel.org>
With CONFIG_STACK_PROTECTOR turned on, VMI doesn't boot with
more than one processor. The problem is with the gs value not
being initialized correctly when registering the secondary
processor for VMI's case.
The patch below initializes the gs value for the AP to
__KERNEL_STACK_CANARY. Without this the secondary processor
keeps on taking a GP on every gs access.
Signed-off-by: Alok N Kataria <akataria@vmware.com>
Cc: <stable@kernel.org> # for v2.6.30.x
LKML-Reference: <1249425262.18955.40.camel@ank32.eng.vmware.com>
The following fix was initially inspired by David Howells fix
few days back:
http://lkml.org/lkml/2009/7/9/109
However, Ingo disapproves such fixes as it's dangerous (it can
hide future, relevant warnings) - in something as
performance-uncritical.
So, initialize 'err' to '0' to work around a GCC false positive
warning:
http://lkml.org/lkml/2009/7/18/89
Signed-off-by: Subrata Modak<subrata@linux.vnet.ibm.com>
Cc: Sachin P Sant <sachinp@linux.vnet.ibm.com>
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
LKML-Reference: <20090721023226.31855.67236.sendpatchset@subratamodak.linux.ibm.com>
In uv_setup_irq(), the call to create_irq() initially assigns
IRQ vectors to cpu 0. The subsequent call to
assign_irq_vector() in arch_enable_uv_irq() migrates the IRQ to
another cpu and frees the cpu 0 vector - at least it will be
freed as soon as the "IRQ move" completes.
arch_enable_uv_irq() needs to send a cleanup IPI to complete
the IRQ move. Otherwise, assignment of GRU interrupts on large
systems (>200 cpus) will exhaust the cpu 0 interrupt vectors
and initialization of the GRU driver will fail.
Signed-off-by: Jack Steiner <steiner@sgi.com>
LKML-Reference: <20090720142840.GA8885@sgi.com>
One system has socket 1 come up as BSP.
kexeced kernel reports BSP as:
[ 1.524550] Initializing cgroup subsys cpuacct
[ 1.536064] initial_apicid:20
[ 1.537135] ht_mask_width:1
[ 1.538128] core_select_mask:f
[ 1.539126] core_plus_mask_width:5
[ 1.558479] CPU: Physical Processor ID: 0
[ 1.559501] CPU: Processor Core ID: 0
[ 1.560539] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 1.579098] CPU: L2 cache: 256K
[ 1.580085] CPU: L3 cache: 24576K
[ 1.581108] CPU 0/0x20 -> Node 0
[ 1.596193] CPU 0 microcode level: 0xffff0008
It doesn't have correct physical processor id and will get an
error:
[ 38.840859] CPU0 attaching sched-domain:
[ 38.848287] domain 0: span 0,8,72 level SIBLING
[ 38.851151] groups: 0 8 72
[ 38.858137] domain 1: span 0,8-15,72-79 level MC
[ 38.868944] groups: 0,8,72 9,73 10,74 11,75 12,76 13,77 14,78 15,79
[ 38.881383] ERROR: parent span is not a superset of domain->span
[ 38.890724] domain 2: span 0-7,64-71 level CPU
[ 38.899237] ERROR: domain->groups does not contain CPU0
[ 38.909229] groups: 8-15,72-79
[ 38.912547] ERROR: groups don't span domain->span
[ 38.919665] domain 3: span 0-127 level NODE
[ 38.930739] groups: 0-7,64-71 8-15,72-79 16-23,80-87 24-31,88-95 32-39,96-103 40-47,104-111 48-55,112-119 56-63,120-127
it turns out: we can not use current_cpu_data in phys_pgd_id
for x2apic.
identify_boot_cpu() is called by check_bugs() before
smp_prepare_cpus() and till smp_prepare_cpus() current_cpu_data
for bsp is assigned with boot_cpu_data.
Just make phys_pkg_id for x2apic is aligned to xapic.
LKML-Reference: <4A6ADD0D.10002@kernel.org>
Change SGI UV default apicid mode to "physical". This is
required to match settings in the UV hub chip.
LKML-Reference: <20090727143856.GA8905@sgi.com>
The UV BIOS has added additional MMR ranges that are mapped via
EFI virtual mode mappings. These ranges should be deleted from
ranges mapped by uv_system_init().
Cc: linux-mm@kvack.org
LKML-Reference: <20090727143656.GA7698@sgi.com>
UV blades may not have any blade-local memory. Add a field
(nid) to the UV blade structure to indicates whether the node
has local memory. This is needed by the GRU driver (pushed
separately).
LKML-Reference: <20090727143507.GA7006@sgi.com>
Older versions of binutils did not accept the naked "ASSERT" syntax;
it is considered an expression whose value needs to be assigned to
something.
Reported-tested-and-fixed-by: Jean Delvare <khali@linux-fr.org>
Booting current 64-bit x86 kernels on the latest Apple MacBook
(MacBook5,2) via EFI gives the following warning:
[ 0.182209] ------------[ cut here ]------------
[ 0.182222] WARNING: at arch/x86/mm/pageattr.c:581 __cpa_process_fault+0x44/0xa0()
[ 0.182227] Hardware name: MacBook5,2
[ 0.182231] CPA: called for zero pte. vaddr = ffff8800ffe00000 cpa->vaddr = ffff8800ffe00000
[ 0.182236] Modules linked in:
[ 0.182242] Pid: 0, comm: swapper Not tainted 2.6.31-rc4 #6
[ 0.182246] Call Trace:
[ 0.182254] [<ffffffff8102c754>] ? __cpa_process_fault+0x44/0xa0
[ 0.182261] [<ffffffff81048668>] warn_slowpath_common+0x78/0xd0
[ 0.182266] [<ffffffff81048744>] warn_slowpath_fmt+0x64/0x70
[ 0.182272] [<ffffffff8102c7ec>] ? update_page_count+0x3c/0x50
[ 0.182280] [<ffffffff818d25c5>] ? phys_pmd_init+0x140/0x22e
[ 0.182286] [<ffffffff8102c754>] __cpa_process_fault+0x44/0xa0
[ 0.182292] [<ffffffff8102ce60>] __change_page_attr_set_clr+0x5f0/0xb40
[ 0.182301] [<ffffffff810d1035>] ? vm_unmap_aliases+0x175/0x190
[ 0.182307] [<ffffffff8102d4ae>] change_page_attr_set_clr+0xfe/0x3d0
[ 0.182314] [<ffffffff8102dcca>] _set_memory_uc+0x2a/0x30
[ 0.182319] [<ffffffff8102dd4b>] set_memory_uc+0x7b/0xb0
[ 0.182327] [<ffffffff818afe31>] efi_enter_virtual_mode+0x2ad/0x2c9
[ 0.182334] [<ffffffff818a1c66>] start_kernel+0x2db/0x3f4
[ 0.182340] [<ffffffff818a1289>] x86_64_start_reservations+0x99/0xb9
[ 0.182345] [<ffffffff818a1389>] x86_64_start_kernel+0xe0/0xf2
[ 0.182357] ---[ end trace 4eaa2a86a8e2da22 ]---
[ 0.182982] init_memory_mapping: 00000000ffffc000-0000000100000000
[ 0.182993] 00ffffc000 - 0100000000 page 4k
This happens because the 64-bit version of efi_ioremap calls
init_memory_mapping for all addresses, regardless of whether they are
RAM or MMIO. The EFI tables on this machine ask for runtime access to
some MMIO regions:
[ 0.000000] EFI: mem195: type=11, attr=0x8000000000000000, range=[0x0000000093400000-0x0000000093401000) (0MB)
[ 0.000000] EFI: mem196: type=11, attr=0x8000000000000000, range=[0x00000000ffc00000-0x00000000ffc40000) (0MB)
[ 0.000000] EFI: mem197: type=11, attr=0x8000000000000000, range=[0x00000000ffc40000-0x00000000ffc80000) (0MB)
[ 0.000000] EFI: mem198: type=11, attr=0x8000000000000000, range=[0x00000000ffc80000-0x00000000ffca4000) (0MB)
[ 0.000000] EFI: mem199: type=11, attr=0x8000000000000000, range=[0x00000000ffca4000-0x00000000ffcb4000) (0MB)
[ 0.000000] EFI: mem200: type=11, attr=0x8000000000000000, range=[0x00000000ffcb4000-0x00000000ffffc000) (3MB)
[ 0.000000] EFI: mem201: type=11, attr=0x8000000000000000, range=[0x00000000ffffc000-0x0000000100000000) (0MB)
This arranges to pass the EFI memory type through to efi_ioremap, and
makes efi_ioremap use ioremap rather than init_memory_mapping if the
type is EFI_MEMORY_MAPPED_IO. With this, the above warning goes away.
LKML-Reference: <19062.55858.533494.471153@cargo.ozlabs.ibm.com>
The latest Apple MacBook (MacBook5,2) doesn't reboot successfully
under Linux; neither the EFI reboot method nor the default method
using the keyboard controller works (the system just hangs and doesn't
reset). However, the method using the "PCI reset register" at 0xcf9
does work.
This adds a quirk to detect this machine via DMI and force the
reboot_type to BOOT_CF9. With this it reboots successfully without
requiring a command-line option. Note that the EFI code forces
reboot_type to BOOT_EFI when the machine is booted via EFI, but this
overrides that since the core_initcall runs after the EFI
initialization code.
LKML-Reference: <19062.56420.501516.316181@cargo.ozlabs.ibm.com>
Startup code for i386 in arch/x86/kernel/head_32.S is using the
reference variable initial_code that is located in the .cpuinit.data
section. If CONFIG_HOTPLUG_CPU is enabled, startup code is not in an
init section and can be called later too. In this case the reference
initial_code must be kept too. This patch fixes this. See below for
the section mismatch warning.
WARNING: vmlinux.o(.cpuinit.data+0x0): Section mismatch in reference
from the variable initial_code to the function
.init.text:i386_start_kernel()
The variable __cpuinitdata initial_code references
a function __init i386_start_kernel().
If i386_start_kernel is only used by initial_code then
annotate i386_start_kernel with a matching annotation.
Signed-off-by: Robert Richter <robert.richter@amd.com>
LKML-Reference: <1248716632-26844-1-git-send-email-robert.richter@amd.com>
x86: geode: Mark mfgpt irq IRQF_TIMER to prevent resume failure
x86, amd: Don't probe for extended APIC ID if APICs are disabled
x86, mce: Rename incorrect macro name "CONFIG_X86_THRESHOLD"
x86-64: Fix bad_srat() to clear all state
x86, mce: Fix set_trigger() accessor
x86: Fix movq immediate operand constraints in uaccess.h
x86: Fix movq immediate operand constraints in uaccess_64.h
x86: Add reboot fixup for SBC-fitPC2
x86: Include all of .data.* sections in _edata on 64-bit
x86: Add quirk for Intel DG45ID board to avoid low memory corruption
Timer interrupts are excluded from being disabled during suspend. The
clock events code manages the disabling of clock events on its own
because the timer interrupt needs to be functional before the resume
code reenables the device interrupts.
The mfgpt timer request its interrupt without setting the IRQF_TIMER
flag so suspend_device_irqs() disables it as well which results in a
fatal resume failure.
Adding IRQF_TIMER to the interupt flags when requesting the mrgpt
timer interrupt solves the problem.
Cc: Andres Salomon <dilinger@debian.org>
git://git.kernel.org/pub/scm/linux/kernel/git/peterz/linux-2.6-perf
* 'perf-counters-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/peterz/linux-2.6-perf: (31 commits)
perf_counter tools: Give perf top inherit option
perf_counter tools: Fix vmlinux symbol generation breakage
perf_counter: Detect debugfs location
perf_counter: Add tracepoint support to perf list, perf stat
perf symbol: C++ demangling
perf: avoid structure size confusion by using a fixed size
perf_counter: Fix throttle/unthrottle event logging
perf_counter: Improve perf stat and perf record option parsing
perf_counter: PERF_SAMPLE_ID and inherited counters
perf_counter: Plug more stack leaks
perf: Fix stack data leak
perf_counter: Remove unused variables
perf_counter: Make call graph option consistent
perf_counter: Add perf record option to log addresses
perf_counter: Log vfork as a fork event
perf_counter: Synthesize VDSO mmap event
perf_counter: Make sure we dont leak kernel memory to userspace
perf_counter tools: Fix index boundary check
perf_counter: Fix the tracepoint channel to perfcounters
perf_counter, x86: Extend perf_counter Pentium M support
If we've logically disabled apics, don't probe the PCI space for the
AMD extended APIC ID.
[ Impact: prevent boot crash under Xen. ]
Reported-by: Bastian Blank <bastian@waldi.eu.org>
Fix a gcc unused variables warning.
CONFIG_X86_THRESHOLD used in arch/x86/kernel/irqinit.c is always
undefined. Rename it to the correct name "CONFIG_X86_MCE_THRESHOLD".
Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com>
Reviewed-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
LKML-Reference: <4A667FD4.3010509@hitachi.com>
Fix the condition checking the result of strchr() (which previously
could result in an oops), and make the function return the number of
bytes actively used.
[ Impact: fix oops ]
LKML-Reference: <4A5F04B7020000780000AB59@vpn.id2.novell.com>
The CompuLab SBC-fitPC2 board needs to reboot via BIOS.
Signed-off-by: Denis Turischev <denis@compulab.co.il>
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
The .data.read_mostly and .data.cacheline_aligned sections
aren't covered by the _sdata .. _edata range on x86-64. This
affects kmemleak reporting leading to possible false
positives by not scanning the whole data section.
Tested-by: Alexey Fisher <bug-track@fisher-privat.net>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
LKML-Reference: <1247565175.28240.37.camel@pc1117.cambridge.arm.com>
AMI BIOS with low memory corruption was found on Intel DG45ID
board (Bug 13710). Add this board to the blacklist - in the
(somewhat optimistic) hope of future boards/BIOSes from Intel
not having this bug.
Also see:
http://bugzilla.kernel.org/show_bug.cgi?id=13736
Signed-off-by: Alexey Fisher <bug-track@fisher-privat.net>
Cc: ykzhao <yakui.zhao@intel.com>
Cc: alan@lxorguk.ukuu.org.uk
LKML-Reference: <1247660169-4503-1-git-send-email-bug-track@fisher-privat.net>
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
x86/pci: insert ioapic resource before assigning unassigned resources
when building 32-bit, I see this ..
arch/x86/kernel/pvclock.c:63:7: warning: "__x86_64__" is not defined
Signed-off-by: Dave Jones <davej@redhat.com>
LKML-Reference: <20090713201437.GA12165@redhat.com>
