path: root/arch/x86/kernel/pci-calgary_64.c
2010-08-26x86, calgary: Make Calgary IOMMU use IOMMU_INIT_* macros.Konrad Rzeszutek Wilk
We utilize the IOMMU_INIT macros to create this dependency: [pci_xen_swiotlb_detect] | [pci_swiotlb_detect_override] | [pci_swiotlb_detect_4gb] | [detect_calgary] Meaning that 'detect_calgary' is going to be called after 'pci_swiotlb_detect'. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> LKML-Reference: <1282845485-8991-8-git-send-email-konrad.wilk@oracle.com> CC: Muli Ben-Yehuda <muli@il.ibm.com> CC: "Jon D. Mason" <jdmason@kudzu.us> CC: "Darrick J. Wong" <djwong@us.ibm.com> CC: Fujita Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-08-26x86, iommu: Make all IOMMU's detection routines return a value.Konrad Rzeszutek Wilk
We return 1 if the IOMMU has been detected. Zero or an error number if we failed to find it. This is in preperation of using the IOMMU_INIT so that we can detect whether an IOMMU is present. I have not tested this for regression on Calgary, nor on AMD Vi chipsets as I don't have that hardware. CC: Muli Ben-Yehuda <muli@il.ibm.com> CC: "Jon D. Mason" <jdmason@kudzu.us> CC: "Darrick J. Wong" <djwong@us.ibm.com> CC: Jesse Barnes <jbarnes@virtuousgeek.org> CC: David Woodhouse <David.Woodhouse@intel.com> CC: Chris Wright <chrisw@sous-sol.org> CC: Yinghai Lu <yinghai@kernel.org> CC: Joerg Roedel <joerg.roedel@amd.com> CC: H. Peter Anvin <hpa@zytor.com> CC: Fujita Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> LKML-Reference: <1282845485-8991-3-git-send-email-konrad.wilk@oracle.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-06-30x86, Calgary: Limit the max PHB number to 256Darrick J. Wong
The x3950 family can have as many as 256 PCI buses in a single system, so change the limits to the maximum. Since there can only be 256 PCI buses in one domain, we no longer need the BUG_ON check. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> LKML-Reference: <20100701004519.GQ15515@tux1.beaverton.ibm.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-06-25x86, Calgary: Increase max PHB numberDarrick J. Wong
Newer systems (x3950M2) can have 48 PHBs per chassis and 8 chassis, so bump the limits up and provide an explanation of the requirements for each class. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Corinna Schultz <cschultz@linux.vnet.ibm.com> Cc: <stable@kernel.org> LKML-Reference: <20100624212647.GI15515@tux1.beaverton.ibm.com> [ v2: Fixed build bug, added back PHBS_PER_CALGARY == 4 ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-16iommu-helper: use bitmap libraryAkinobu Mita
Use bitmap library and kill some unused iommu helper functions. 1. s/iommu_area_free/bitmap_clear/ 2. s/iommu_area_reserve/bitmap_set/ 3. Use bitmap_find_next_zero_area instead of find_next_zero_area This cannot be simple substitution because find_next_zero_area doesn't check the last bit of the limit in bitmap 4. Remove iommu_area_free, iommu_area_reserve, and find_next_zero_area Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-03x86, Calgary IOMMU quirk: Find nearest matching Calgary while walking up the ↵Darrick J. Wong
PCI tree On a multi-node x3950M2 system, there's a slight oddity in the PCI device tree for all secondary nodes: 30:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1) \-33:00.0 PCI bridge: IBM CalIOC2 PCI-E Root Port (rev 01) \-34:00.0 RAID bus controller: LSI Logic / Symbios Logic MegaRAID SAS 1078 (rev 04) ...as compared to the primary node: 00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1) \-01:00.0 VGA compatible controller: ATI Technologies Inc ES1000 (rev 02) 03:00.0 PCI bridge: IBM CalIOC2 PCI-E Root Port (rev 01) \-04:00.0 RAID bus controller: LSI Logic / Symbios Logic MegaRAID SAS 1078 (rev 04) In both nodes, the LSI RAID controller hangs off a CalIOC2 device, but on the secondary nodes, the BIOS hides the VGA device and substitutes the device tree ending with the disk controller. It would seem that Calgary devices don't necessarily appear at the top of the PCI tree, which means that the current code to find the Calgary IOMMU that goes with a particular device is buggy. Rather than walk all the way to the top of the PCI device tree and try to match bus number with Calgary descriptor, the code needs to examine each parent of the particular device; if it encounters a Calgary with a matching bus number, simply use that. Otherwise, we BUG() when the bus number of the Calgary doesn't match the bus number of whatever's at the top of the device tree. Extra note: This patch appears to work correctly for the x3950 that came before the x3950 M2. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Joerg Roedel <joerg.roedel@amd.com> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Cc: Jon D. Mason <jdmason@kudzu.us> Cc: Corinna Schultz <coschult@us.ibm.com> Cc: <stable@kernel.org> LKML-Reference: <20091202230556.GG10295@tux1.beaverton.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-17x86: Calgary: Remove unnecessary DMA_ERROR_CODE usageFUJITA Tomonori
This cleans up iommu_alloc() a bit and removes unnecessary DMA_ERROR_CODE usage. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: muli@il.ibm.com Cc: joerg.roedel@amd.com LKML-Reference: <1258287594-8777-4-git-send-email-fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-17x86: Kill bad_dma_address variableFUJITA Tomonori
This kills bad_dma_address variable, the old mechanism to enable IOMMU drivers to make dma_mapping_error() work in IOMMU's specific way. bad_dma_address variable was introduced to enable IOMMU drivers to make dma_mapping_error() work in IOMMU's specific way. However, it can't handle systems that use both swiotlb and HW IOMMU. SO we introduced dma_map_ops->mapping_error to solve that case. Intel VT-d, GART, and swiotlb already use dma_map_ops->mapping_error. Calgary, AMD IOMMU, and nommu use zero for an error dma address. This adds DMA_ERROR_CODE and converts them to use it (as SPARC and POWER does). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: muli@il.ibm.com Cc: joerg.roedel@amd.com LKML-Reference: <1258287594-8777-3-git-send-email-fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-15x86: Make calgary_iommu_init() staticFUJITA Tomonori
This makes calgary_iommu_init() static and moves it to remove the forward declaration. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: muli@il.ibm.com LKML-Reference: <20091114212603U.fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-10x86: Handle HW IOMMU initialization failure gracefullyFUJITA Tomonori
If HW IOMMU initialization fails (Intel VT-d often does this, typically due to BIOS bugs), we fall back to nommu. It doesn't work for the majority since nowadays we have more than 4GB memory so we must use swiotlb instead of nommu. The problem is that it's too late to initialize swiotlb when HW IOMMU initialization fails. We need to allocate swiotlb memory earlier from bootmem allocator. Chris explained the issue in detail: http://marc.info/?l=linux-kernel&m=125657444317079&w=2 The current x86 IOMMU initialization sequence is too complicated and handling the above issue makes it more hacky. This patch changes x86 IOMMU initialization sequence to handle the above issue cleanly. The new x86 IOMMU initialization sequence are: 1. we initialize the swiotlb (and setting swiotlb to 1) in the case of (max_pfn > MAX_DMA32_PFN && !no_iommu). dma_ops is set to swiotlb_dma_ops or nommu_dma_ops. if swiotlb usage is forced by the boot option, we finish here. 2. we call the detection functions of all the IOMMUs 3. the detection function sets x86_init.iommu.iommu_init to the IOMMU initialization function (so we can avoid calling the initialization functions of all the IOMMUs needlessly). 4. if the IOMMU initialization function doesn't need to swiotlb then sets swiotlb to zero (e.g. the initialization is sucessful). 5. if we find that swiotlb is set to zero, we free swiotlb resource. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: chrisw@sous-sol.org Cc: dwmw2@infradead.org Cc: joerg.roedel@amd.com Cc: muli@il.ibm.com LKML-Reference: <1257849980-22640-10-git-send-email-fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-10x86: Calgary: Convert detect_calgary() to use iommu_init hookFUJITA Tomonori
This changes detect_calgary() to set init_calgary() to iommu_init hook if detect_calgary() finds the Calgary IOMMU. We can kill the code to check if we found the IOMMU in init_calgary() since detect_calgary() sets init_calgary() only when it found the IOMMU. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Cc: chrisw@sous-sol.org Cc: dwmw2@infradead.org Cc: joerg.roedel@amd.com LKML-Reference: <1257849980-22640-3-git-send-email-fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-14x86: calgary: remove IOMMU_DEBUGFUJITA Tomonori
CONFIG_IOMMU_DEBUG has depends on CONFIG_GART_IOMMU: config IOMMU_DEBUG bool "Enable IOMMU debugging" depends on GART_IOMMU && DEBUG_KERNEL depends on X86_64 So it's not useful to have CONFIG_IOMMU_DEBUG in Calgary IOMMU code, which does the extra checking of the bitmap space management. And Calgary uses the iommu helper for the bitmap space management now so it would be better to have the extra checking feature in the iommu helper rather than Calgary code (if necessary). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Joerg Roedel <joerg.roedel@amd.com> Cc: alexisb@us.ibm.com LKML-Reference: <20090414120827G.fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-06x86, ia64: convert to use generic dma_map_ops structFUJITA Tomonori
This converts X86 and IA64 to use include/linux/dma-mapping.h. It's a bit large but pretty boring. The major change for X86 is converting 'int dir' to 'enum dma_data_direction dir' in DMA mapping operations. The major changes for IA64 is using map_page and unmap_page instead of map_single and unmap_single. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-06x86: remove map_single and unmap_single in struct dma_mapping_opsFUJITA Tomonori
This patch converts dma_map_single and dma_unmap_single to use map_page and unmap_page respectively and removes unnecessary map_single and unmap_single in struct dma_mapping_ops. This leaves intel-iommu's dma_map_single and dma_unmap_single since IA64 uses them. They will be removed after the unification. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-06x86, calgary: add map_page and unmap_pageFUJITA Tomonori
This is a preparation of struct dma_mapping_ops unification. We use map_page and unmap_page instead of map_single and unmap_single. We will remove map_single and unmap_single hooks in the last patch in this patchset. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-25arch/x86/kernel/pci-calgary_64.c: change simple_strtol to simple_strtoulJulia Lawall
Impact: fix theoretical option string parsing overflow Since bridge is unsigned, it would seem better to use simple_strtoul that simple_strtol. A simplified version of the semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r2@ long e; position p; @@ e = simple_strtol@p(...) @@ position p != r2.p; type T; T e; @@ e = - simple_strtol@p + simple_strtoul (...) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: muli@il.ibm.com Cc: jdmason@kudzu.us Cc: discuss@x86-64.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-16x86: convert Calgary IOMMU driver to generic iommu_num_pages functionJoerg Roedel
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-22iommu: export iommu_area_reserve helper functionFUJITA Tomonori
x86 has set_bit_string() that does the exact same thing that set_bit_area() in lib/iommu-helper.c does. This patch exports set_bit_area() in lib/iommu-helper.c as iommu_area_reserve(), converts GART, Calgary, and AMD IOMMU to use it. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-14x86: avoid unnecessary low zone allocation in Calgary's alloc_coherentFUJITA Tomonori
x86's common alloc_coherent (dma_alloc_coherent in dma-mapping.h) sets up the gfp flag according to the device dma_mask but Calgary doesn't need it because of virtual mappings. This patch avoids unnecessary low zone allocation. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-10Merge commit 'v2.6.27-rc6' into x86/iommuIngo Molnar
2008-08-22x86: add free_coherent dma_ops callback to Calgary IOMMU driverJoerg Roedel
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-21x86: use WARN() in arch/x86/kernelArjan van de Ven
Use WARN() instead of a printk+WARN_ON() pair; this way the message becomes part of the warning section for better reporting/collection. This also allowed the folding of some if()'s into the WARN() Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: akpm@linux-foundation.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-21werror: fix pci calgaryDavid Howells
Fix an integer comparison always false warning in the PCI Calgary 64 driver. A u8 is being compared to something that's 512 by default, resulting in the following warning: arch/x86/kernel/pci-calgary_64.c:1285: warning: comparison is always false due to limited range of data type This was introduced by patch b34e90b8f0f30151349134f87b5dc6ef75a5218c. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-18x86, calgary: fix section mismatch warning - get_tce_space_from_tarMarcin Slusarz
WARNING: vmlinux.o(.text+0x27032): Section mismatch in reference from the function get_tce_space_from_tar() to the function .init.text:calgary_bus_has_devices() The function get_tce_space_from_tar() references the function __init calgary_bus_has_devices(). This is often because get_tce_space_from_tar lacks a __init annotation or the annotation of calgary_bus_has_devices is wrong. get_tce_space_from_tar is called only from __init function (calgary_init) and calls __init function (calgary_bus_has_devices). So annotate it properly. Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Chandru Siddalingappa <chandru@in.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-11x86, pci-calgary: fix function declarationRandy Dunlap
Fix function declaration: linux-next-20080807/arch/x86/kernel/pci-calgary_64.c:1353:36: warning: non-ANSI function declaration of function 'get_tce_space_from_tar' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-26x86 calgary: fix handling of devices that aren't behind the CalgaryAlexis Bruemmer
The calgary code can give drivers addresses above 4GB which is very bad for hardware that is only 32bit DMA addressable. With this patch, the calgary code sets the global dma_ops to swiotlb or nommu properly, and the dma_ops of devices behind the Calgary/CalIOC2 to calgary_dma_ops. So the calgary code can handle devices safely that aren't behind the Calgary/CalIOC2. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Alexis Bruemmer <alexisb@us.ibm.com> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26dma-mapping: add the device argument to dma_mapping_error()FUJITA Tomonori
Add per-device dma_mapping_ops support for CONFIG_X86_64 as POWER architecture does: This enables us to cleanly fix the Calgary IOMMU issue that some devices are not behind the IOMMU (http://lkml.org/lkml/2008/5/8/423). I think that per-device dma_mapping_ops support would be also helpful for KVM people to support PCI passthrough but Andi thinks that this makes it difficult to support the PCI passthrough (see the above thread). So I CC'ed this to KVM camp. Comments are appreciated. A pointer to dma_mapping_ops to struct dev_archdata is added. If the pointer is non NULL, DMA operations in asm/dma-mapping.h use it. If it's NULL, the system-wide dma_ops pointer is used as before. If it's useful for KVM people, I plan to implement a mechanism to register a hook called when a new pci (or dma capable) device is created (it works with hot plugging). It enables IOMMUs to set up an appropriate dma_mapping_ops per device. The major obstacle is that dma_mapping_error doesn't take a pointer to the device unlike other DMA operations. So x86 can't have dma_mapping_ops per device. Note all the POWER IOMMUs use the same dma_mapping_error function so this is not a problem for POWER but x86 IOMMUs use different dma_mapping_error functions. The first patch adds the device argument to dma_mapping_error. The patch is trivial but large since it touches lots of drivers and dma-mapping.h in all the architecture. This patch: dma_mapping_error() doesn't take a pointer to the device unlike other DMA operations. So we can't have dma_mapping_ops per device. Note that POWER already has dma_mapping_ops per device but all the POWER IOMMUs use the same dma_mapping_error function. x86 IOMMUs use device argument. [akpm@linux-foundation.org: fix sge] [akpm@linux-foundation.org: fix svc_rdma] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix bnx2x] [akpm@linux-foundation.org: fix s2io] [akpm@linux-foundation.org: fix pasemi_mac] [akpm@linux-foundation.org: fix sdhci] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix sparc] [akpm@linux-foundation.org: fix ibmvscsi] Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25calgary iommu: use the first kernels TCE tables in kdumpChandru
kdump kernel fails to boot with calgary iommu and aacraid driver on a x366 box. The ongoing dma's of aacraid from the first kernel continue to exist until the driver is loaded in the kdump kernel. Calgary is initialized prior to aacraid and creation of new tce tables causes wrong dma's to occur. Here we try to get the tce tables of the first kernel in kdump kernel and use them. While in the kdump kernel we do not allocate new tce tables but instead read the base address register contents of calgary iommu and use the tables that the registers point to. With these changes the kdump kernel and hence aacraid now boots normally. Signed-off-by: Chandru Siddalingappa <chandru@in.ibm.com> Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-11x86: make only GART code include gart.hFUJITA Tomonori
gart.h has only GART-specific stuff. Only GART code needs it. Other IOMMU stuff should include iommu.h instead of gart.h. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: remove end_pfn in 64bitYinghai Lu
and use max_pfn directly. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-26x86: remove duplicate get_bios_ebda() from rio.hAkinobu Mita
get_bios_ebda() exists in asm/rio.h and asm/bios_ebda.h. This patch removes the one in asm/rio.h. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/pci-2.6: (42 commits) PCI: Change PCI subsystem MAINTAINER PCI: pci-iommu-iotlb-flushing-speedup PCI: pci_setup_bridge() mustn't be __devinit PCI: pci_bus_size_cardbus() mustn't be __devinit PCI: pci_scan_device() mustn't be __devinit PCI: pci_alloc_child_bus() mustn't be __devinit PCI: replace remaining __FUNCTION__ occurrences PCI: Hotplug: fakephp: Return success, not ENODEV, when bus rescan is triggered PCI: Hotplug: Fix leaks in IBM Hot Plug Controller Driver - ibmphp_init_devno() PCI: clean up resource alignment management PCI: aerdrv_acpi.c: remove unneeded NULL check PCI: Update VIA CX700 quirk PCI: Expose PCI VPD through sysfs PCI: iommu: iotlb flushing PCI: simplify quirk debug output PCI: iova RB tree setup tweak PCI: parisc: use generic pci_enable_resources() PCI: ppc: use generic pci_enable_resources() PCI: powerpc: use generic pci_enable_resources() PCI: ia64: use generic pci_enable_resources() ...
2008-04-20PCI: remove pci_get_device_reverse from calgary driverGreg Kroah-Hartman
This isn't needed, we can just walk the devices in bus order with no problems at all, as we really want to remove pci_get_device_reverse from the kernel tree. Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Jon Mason <jdmason@kudzu.us> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19x86: dma-ops on highmem fixIngo Molnar
Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-05iommu sg: x86: convert calgary IOMMU to use the IOMMU helperFUJITA Tomonori
This patch converts calgary IOMMU to use the IOMMU helper functions. The IOMMU doesn't allocate a memory area spanning LLD's segment boundary anymore. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Muli Ben-Yehuda <mulix@mulix.org> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01x86: fix section mismatch warning in kernel/pci-calgarySam Ravnborg
Fix following warning: WARNING: arch/x86/kernel/built-in.o(.text+0x1eb41): Section mismatch in reference from the function calgary_handle_quirks() to the function .init.text:calgary_set_split_completion_timeout() calgary_handle_quirks() are only called at __init time (in calgary_init_one() via handle_quirks ops). So annotate this function and the sister function __init. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30x86: remove duplicate includesLucas Woods
Signed-off-by: Lucas Woods <woodzy@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: pci-calgary_64.c: make a variable staticAdrian Bunk
"debugging" is a horrible name for a global variable - thankfully it can become static. Also put it out of __read_mostly so that gcc no longer has to emit it at all. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-30x86 gart: rename iommu.h to gart.hJoerg Roedel
This patch renames the include file asm-x86/iommu.h to asm-x86/gart.h to make clear to which IOMMU implementation it belongs. The patch also adds "GART" to the Kconfig line. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-22Update arch/ to use sg helpersJens Axboe
2007-10-17x86: calgary get rid of translate_phbMuli Ben-Yehuda
Now that we check for translation enabled/disabled based on the presence of the IOMMU translation table, we can get rid of translate_phb. Signed-off-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-17x86: Calgary: fix disable busnum for CalIOC2Muli Ben-Yehuda
The old check we used based on dev->bus->number is wrong for devices on CalIOC2. Instead look whether we have an IOMMU table for that bus - if not, translation is disabled. Thanks to Murillo Fernandes Bernardes <bernarde@br.ibm.com> for spotting, suggesting a fix and testing. Signed-off-by: Muli Ben-Yehuda <muli@il.ibm.com> Acked-by: Murillo Fernandes Bernardes <bernarde@br.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-16x86-64: update calgary iommu to sg helpersJens Axboe
Acked-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-11x86_64: move kernelThomas Gleixner
