path: root/arch/x86/kernel/microcode.c
2008-09-23x86: moved microcode.c to microcode_intel.cDmitry Adamushko
Combine both generic and arch-specific parts of microcode into a single module (arch-specific parts are config-dependent). Also while we are at it, move arch-specific parts from microcode.h into their respective arch-specific .c files. Signed-off-by: Dmitry Adamushko <dmitry.adamushko@gmail.com> Cc: "Peter Oruba" <peter.oruba@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-14x86, microcode rework, v2, fixIngo Molnar
based on patch from Dmitry Adamushko. - add missing vfree() - update debug printks Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-12x86, microcode rework, v2Dmitry Adamushko
this is a rework of the microcode splitup in tip/x86/microcode (1) I think this new interface is cleaner (look at the changes in 'struct microcode_ops' in microcode.h); (2) it's -64 lines of code; Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-20x86-microcode: generic interface refactoringDmitry Adamushko
This is the 1st patch in the series. Here the aim was to avoid any significant changes, logically-wise. So it's mainly about generic interface refactoring: e.g. make microcode_{intel,amd}.c more about arch-specific details and less about policies like make-sure-we-run-on-a-target-cpu (no more set_cpus_allowed_ptr() here) and generic synchronization (no more microcode_mutex here). All in all, more line have been deleted than added. 4 files changed, 145 insertions(+), 198 deletions(-) Signed-off-by: Dmitry Adamushko <dmitry.adamushko@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-15x86: Fixed NULL function pointer dereference in AMD microcode patch loader.Peter Oruba
Dereference took place in code part responsible for manual installation of microcode patches through /dev/cpu/microcode. Signed-off-by: Peter Oruba <peter.oruba@amd.com> Cc: Peter Oruba <peter.oruba@amd.com> Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-15x86: Microcode patch loader style correctionsPeter Oruba
Style corrections to main microcode module. Signed-off-by: Peter Oruba <peter.oruba@amd.com> Cc: Peter Oruba <peter.oruba@amd.com> Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-29Merge commit 'v2.6.27-rc1' into x86/microcodeIngo Molnar
Conflicts: arch/x86/kernel/microcode.c Manual resolutions: arch/x86/kernel/microcode_amd.c arch/x86/kernel/microcode_intel.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-29x86, microcode: fix symbol exportsIngo Molnar
fix tons of build errors: arch/x86/kernel/built-in.o: In function `microcode_fini_cpu': microcode_intel.c:(.text+0x11598): undefined reference to `microcode_mutex' microcode_intel.c:(.text+0x115a4): undefined reference to `ucode_cpu_info' microcode_intel.c:(.text+0x115ae): undefined reference to `ucode_cpu_info' microcode_intel.c:(.text+0x115bc): undefined reference to `microcode_mutex' [...] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-29x86, microcode support: fix build errorIngo Molnar
fix: arch/x86/kernel/microcode.c:412: error: static declaration of ‘microcode_init’ follows non-static declaration include/asm/microcode.h:1: error: previous declaration of ‘microcode_init’ was here arch/x86/kernel/microcode.c:454: error: static declaration of ‘microcode_exit’ follows non-static declaration include/asm/microcode.h:2: error: previous declaration of ‘microcode_exit’ was here Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-28x86: major refactoringPeter Oruba
Refactored code by introducing a two-module solution. There is one general module in which vendor specific modules can hook into. However, that is exclusive, there is only one vendor specific module allowed at a time. A CPU vendor check makes sure only the correct module for the underlying system gets called. Functinally in terms of patch loading itself there are no changes. This refactoring provides a basis for future implementations of other vendors' patch loaders. Signed-off-by: Peter Oruba <peter.oruba@amd.com> Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-28x86: code split to two partsPeter Oruba
Split off existing code into two seperate files. One file holds general code, the other file vendor specific parts. No functional changes, only refactoring. Temporarily Introduced a new module name 'ucode' for result, due to already taken name 'microcode'. Signed-off-by: Peter Oruba <peter.oruba@amd.com> Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-28x86: move microcode.c to microcode_intel.cPeter Oruba
2008-07-28x86: move per CPU microcode structure declaration to header filePeter Oruba
This structure will be later used by other modules as well and needs therfore to be moved out to a header file. Signed-off-by: Peter Oruba <peter.oruba@amd.com> Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-28x86: typedef removalPeter Oruba
Removed typedefs. No functional changes to the code. Signed-off-by: Peter Oruba <peter.oruba@amd.com> Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-28x86: moved Intel microcode patch loader declarations to seperate header filePeter Oruba
Intel specific microcode declarations have been moved to a seperate header file. There are no code changes to the code itself and no side effects to other parts. Signed-off-by: Peter Oruba <peter.oruba@amd.com> Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-26cpumask: change cpumask_of_cpu_ptr to use new cpumask_of_cpuMike Travis
* Replace previous instances of the cpumask_of_cpu_ptr* macros with a the new (lvalue capable) generic cpumask_of_cpu(). Signed-off-by: Mike Travis <travis@sgi.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jack Steiner <steiner@sgi.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-23Merge branch 'cpus4096-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'cpus4096-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (31 commits) NR_CPUS: Replace NR_CPUS in speedstep-centrino.c cpumask: Provide a generic set of CPUMASK_ALLOC macros, FIXUP NR_CPUS: Replace NR_CPUS in cpufreq userspace routines NR_CPUS: Replace per_cpu(..., smp_processor_id()) with __get_cpu_var NR_CPUS: Replace NR_CPUS in arch/x86/kernel/genapic_flat_64.c NR_CPUS: Replace NR_CPUS in arch/x86/kernel/genx2apic_uv_x.c NR_CPUS: Replace NR_CPUS in arch/x86/kernel/cpu/proc.c NR_CPUS: Replace NR_CPUS in arch/x86/kernel/cpu/mcheck/mce_64.c cpumask: Optimize cpumask_of_cpu in lib/smp_processor_id.c, fix cpumask: Use optimized CPUMASK_ALLOC macros in the centrino_target cpumask: Provide a generic set of CPUMASK_ALLOC macros cpumask: Optimize cpumask_of_cpu in lib/smp_processor_id.c cpumask: Optimize cpumask_of_cpu in kernel/time/tick-common.c cpumask: Optimize cpumask_of_cpu in drivers/misc/sgi-xp/xpc_main.c cpumask: Optimize cpumask_of_cpu in arch/x86/kernel/ldt.c cpumask: Optimize cpumask_of_cpu in arch/x86/kernel/io_apic_64.c cpumask: Replace cpumask_of_cpu with cpumask_of_cpu_ptr Revert "cpumask: introduce new APIs" cpumask: make for_each_cpu_mask a bit smaller net: Pass reference to cpumask variable in net/sunrpc/svc.c ... Fix up trivial conflicts in drivers/cpufreq/cpufreq.c manually
2008-07-21sysdev: Pass the attribute to the low level sysdev show/store functionAndi Kleen
This allow to dynamically generate attributes and share show/store functions between attributes. Right now most attributes are generated by special macros and lots of duplicated code. With the attribute passed it's instead possible to attach some data to the attribute and then use that in shared low level functions to do different things. I need this for the dynamically generated bank attributes in the x86 machine check code, but it'll allow some further cleanups. I converted all users in tree to the new show/store prototype. It's a single huge patch to avoid unbisectable sections. Runtime tested: x86-32, x86-64 Compiled only: ia64, powerpc Not compile tested/only grep converted: sh, arm, avr32 Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-18cpumask: Replace cpumask_of_cpu with cpumask_of_cpu_ptrMike Travis
* This patch replaces the dangerous lvalue version of cpumask_of_cpu with new cpumask_of_cpu_ptr macros. These are patterned after the node_to_cpumask_ptr macros. In general terms, if there is a cpumask_of_cpu_map[] then a pointer to the cpumask_of_cpu_map[cpu] entry is used. The cpumask_of_cpu_map is provided when there is a large NR_CPUS count, reducing greatly the amount of code generated and stack space used for cpumask_of_cpu(). The pointer to the cpumask_t value is needed for calling set_cpus_allowed_ptr() to reduce the amount of stack space needed to pass the cpumask_t value. If there isn't a cpumask_of_cpu_map[], then a temporary variable is declared and filled in with value from cpumask_of_cpu(cpu) as well as a pointer variable pointing to this temporary variable. Afterwards, the pointer is used to reference the cpumask value. The compiler will optimize out the extra dereference through the pointer as well as the stack space used for the pointer, resulting in identical code. A good example of the orthogonal usages is in net/sunrpc/svc.c: case SVC_POOL_PERCPU: { unsigned int cpu = m->pool_to[pidx]; cpumask_of_cpu_ptr(cpumask, cpu); *oldmask = current->cpus_allowed; set_cpus_allowed_ptr(current, cpumask); return 1; } case SVC_POOL_PERNODE: { unsigned int node = m->pool_to[pidx]; node_to_cpumask_ptr(nodecpumask, node); *oldmask = current->cpus_allowed; set_cpus_allowed_ptr(current, nodecpumask); return 1; } Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-14Merge branch 'for-2.6.27' of git://git.infradead.org/users/dwmw2/firmware-2.6Linus Torvalds
* 'for-2.6.27' of git://git.infradead.org/users/dwmw2/firmware-2.6: (64 commits) firmware: convert sb16_csp driver to use firmware loader exclusively dsp56k: use request_firmware edgeport-ti: use request_firmware() edgeport: use request_firmware() vicam: use request_firmware() dabusb: use request_firmware() cpia2: use request_firmware() ip2: use request_firmware() firmware: convert Ambassador ATM driver to request_firmware() whiteheat: use request_firmware() ti_usb_3410_5052: use request_firmware() emi62: use request_firmware() emi26: use request_firmware() keyspan_pda: use request_firmware() keyspan: use request_firmware() ttusb-budget: use request_firmware() kaweth: use request_firmware() smctr: use request_firmware() firmware: convert ymfpci driver to use firmware loader exclusively firmware: convert maestro3 driver to use firmware loader exclusively ... Fix up trivial conflicts with BKL removal in drivers/char/dsp56k.c and drivers/char/ip2/ip2main.c manually.
2008-07-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.gitDavid Woodhouse
Conflicts: sound/pci/Kconfig
2008-07-14Merge branch 'bkl-removal' of git://git.lwn.net/linux-2.6Linus Torvalds
* 'bkl-removal' of git://git.lwn.net/linux-2.6: (146 commits) IB/umad: BKL is not needed for ib_umad_open() IB/uverbs: BKL is not needed for ib_uverbs_open() bf561-coreb: BKL unneeded for open() Call fasync() functions without the BKL snd/PCM: fasync BKL pushdown ipmi: fasync BKL pushdown ecryptfs: fasync BKL pushdown Bluetooth VHCI: fasync BKL pushdown tty_io: fasync BKL pushdown tun: fasync BKL pushdown i2o: fasync BKL pushdown mpt: fasync BKL pushdown Remove BKL from remote_llseek v2 Make FAT users happier by not deadlocking x86-mce: BKL pushdown vmwatchdog: BKL pushdown vmcp: BKL pushdown via-pmu: BKL pushdown uml-random: BKL pushdown uml-mmapper: BKL pushdown ...
2008-07-10x86 microcode: firmware data is constGreg Kroah-Hartman
Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-07-03x86: microcode: cosmetic changesBen Castricum
First announce ourself, then start working. Currently this module reports itself when all is completed which is not most modules do. Plus some cosmetic/whitespace cleanups. Signed-off-by: Ben Castricum <lk0806@bencastricum.nl> Cc: trivial@kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-20microcode: BKL pushdownArnd Bergmann
2008-04-19x86: use new set_cpus_allowed_ptr functionMike Travis
* Use new set_cpus_allowed_ptr() function added by previous patch, which instead of passing the "newly allowed cpus" cpumask_t arg by value, pass it by pointer: -int set_cpus_allowed(struct task_struct *p, cpumask_t new_mask) +int set_cpus_allowed_ptr(struct task_struct *p, const cpumask_t *new_mask) * Cleanup uses of CPU_MASK_ALL. * Collapse other NR_CPUS changes to arch/x86/kernel/cpu/cpufreq/acpi-cpufreq.c Use pointers to cpumask_t arguments whenever possible. Depends on: [sched-devel]: sched: add new set_cpus_allowed_ptr function Cc: Len Brown <len.brown@intel.com> Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: microcode: show results on success tooBen Castricum
Report when microcode was successfully updated. It used to be there but now with DEBUG unset it becomes very silent. Also some cosmetic fixes. Signed-off-by: Ben Castricum <lk08@bencastricum.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-01x86: fix section mismatch warnings when referencing notifiersSam Ravnborg
Fix the following warnings: WARNING: arch/x86/kernel/built-in.o(.exit.text+0xf8): Section mismatch in reference from the function msr_exit() to the variable .cpuinit.data:msr_class_cpu_notifier WARNING: arch/x86/kernel/built-in.o(.exit.text+0x158): Section mismatch in reference from the function cpuid_exit() to the variable .cpuinit.data:cpuid_class_cpu_notifier WARNING: arch/x86/kernel/built-in.o(.exit.text+0x171): Section mismatch in reference from the function microcode_exit() to the variable .cpuinit.data:mc_cpu_notifier In all three cases there were a function annotated __exit that referenced a variable annotated __cpuinitdata. The fix was to replace the annotation of the notifier with __refdata to tell modpost that the reference to a _cpuinit function in the notifier are OK. The unregister call that references the notifier variable will simple delete the function pointer so there is no problem ignoring the reference. Note: This looks like another case where __cpuinit has been used as replacement for proper use of CONFIG_HOTPLUG_CPU to decide what code are used for HOTPLUG_CPU. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30x86: remove unneded castsJan Engelhardt
x86: remove unneeded casts Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-25cpu-hotplug: replace lock_cpu_hotplug() with get_online_cpus()Gautham R Shenoy
Replace all lock_cpu_hotplug/unlock_cpu_hotplug from the kernel and use get_online_cpus and put_online_cpus instead as it highlights the refcount semantics in these operations. The new API guarantees protection against the cpu-hotplug operation, but it doesn't guarantee serialized access to any of the local data structures. Hence the changes needs to be reviewed. In case of pseries_add_processor/pseries_remove_processor, use cpu_maps_update_begin()/cpu_maps_update_done() as we're modifying the cpu_present_map there. Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-19x86: convert cpuinfo_x86 array to a per_cpu arrayMike Travis
cpu_data is currently an array defined using NR_CPUS. This means that we overallocate since we will rarely really use maximum configured cpus. When NR_CPU count is raised to 4096 the size of cpu_data becomes 3,145,728 bytes. These changes were adopted from the sparc64 (and ia64) code. An additional field was added to cpuinfo_x86 to be a non-ambiguous cpu index. This corresponds to the index into a cpumask_t as well as the per_cpu index. It's used in various places like show_cpuinfo(). cpu_data is defined to be the boot_cpu_data structure for the NON-SMP case. Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Mark M. Hoffman <mhoffman@lightlink.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-11i386: move kernelThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
