path: root/arch/x86/kernel/kvm.c
2011-07-24KVM guest: KVM Steal time registrationGlauber Costa
This patch implements the kvm bits of the steal time infrastructure. The most important part of it, is the steal time clock. It is an continuous clock that shows the accumulated amount of steal time since vcpu creation. It is supposed to survive cpu offlining/onlining. [marcelo: fix build with CONFIG_KVM_GUEST=n] Signed-off-by: Glauber Costa <glommer@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Tested-by: Eric B Munson <emunson@mgebm.net> CC: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> CC: Peter Zijlstra <peterz@infradead.org> CC: Avi Kivity <avi@redhat.com> CC: Anthony Liguori <aliguori@us.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-03-17KVM guest: Fix section mismatch derived from kvm_guest_cpu_online()Sedat Dilek
WARNING: arch/x86/built-in.o(.text+0x1bb74): Section mismatch in reference from the function kvm_guest_cpu_online() to the function .cpuinit.text:kvm_guest_cpu_init() The function kvm_guest_cpu_online() references the function __cpuinit kvm_guest_cpu_init(). This is often because kvm_guest_cpu_online lacks a __cpuinit annotation or the annotation of kvm_guest_cpu_init is wrong. This patch fixes the warning. Tested with linux-next (next-20101231) Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM guest: Fix kvm clock initialization when it's configured outAvi Kivity
2011-01-12KVM: Let host know whether the guest can handle async PF in non-userspace ↵Gleb Natapov
context. If guest can detect that it runs in non-preemptable context it can handle async PFs at any time, so let host know that it can send async PF even if guest cpu is not in userspace. Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM paravirt: Handle async PF in non preemptable contextGleb Natapov
If async page fault is received by idle task or when preemp_count is not zero guest cannot reschedule, so do sti; hlt and wait for page to be ready. vcpu can still process interrupts while it waits for the page to be ready. Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Handle async PF in a guest.Gleb Natapov
When async PF capability is detected hook up special page fault handler that will handle async page fault events and bypass other page faults to regular page fault handler. Also add async PF handling to nested SVM emulation. Async PF always generates exit to L1 where vcpu thread will be scheduled out until page is available. Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM paravirt: Add async PF initialization to PV guest.Gleb Natapov
Enable async PF in a guest if async PF capability is discovered. Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM paravirt: Move kvm_smp_prepare_boot_cpu() from kvmclock.c to kvm.c.Gleb Natapov
Async PF also needs to hook into smp_prepare_boot_cpu so move the hook into generic code. Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-09-10KVM guest: do not batch pte updates from interrupt contextMarcelo Tosatti
Commit b8bcfe997e4 made paravirt pte updates synchronous in interrupt context. Unfortunately the KVM pv mmu code caches the lazy/nonlazy mode internally, so a pte update from interrupt context during a lazy mmu operation can be batched while it should be performed synchronously. https://bugzilla.redhat.com/show_bug.cgi?id=518022 Drop the internal mode variable and use paravirt_get_lazy_mode(), which returns the correct state. Cc: stable@kernel.org Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-07-03x86, kvm: Fix section mismatches in kvm.cRakib Mullick
The function paravirt_ops_setup() has been refering the variable no_timer_check, which is a __initdata. Thus generates the following warning. paravirt_ops_setup() function is called from kvm_guest_init() which is a __init function. So to fix this we mark paravirt_ops_setup as __init. The sections-check output that warned us about this was: LD arch/x86/built-in.o WARNING: arch/x86/built-in.o(.text+0x166ce): Section mismatch in reference from the function paravirt_ops_setup() to the variable .init.data:no_timer_check The function paravirt_ops_setup() references the variable __initdata no_timer_check. This is often because paravirt_ops_setup lacks a __initdata annotation or the annotation of no_timer_check is wrong. Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com> Acked-by: Avi Kivity <avi@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <b9df5fa10907012240y356427b8ta4bd07f0efc6a049@mail.gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-11Merge branch 'kvm-updates/2.6.31' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.31' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (138 commits) KVM: Prevent overflow in largepages calculation KVM: Disable large pages on misaligned memory slots KVM: Add VT-x machine check support KVM: VMX: Rename rmode.active to rmode.vm86_active KVM: Move "exit due to NMI" handling into vmx_complete_interrupts() KVM: Disable CR8 intercept if tpr patching is active KVM: Do not migrate pending software interrupts. KVM: inject NMI after IRET from a previous NMI, not before. KVM: Always request IRQ/NMI window if an interrupt is pending KVM: Do not re-execute INTn instruction. KVM: skip_emulated_instruction() decode instruction if size is not known KVM: Remove irq_pending bitmap KVM: Do not allow interrupt injection from userspace if there is a pending event. KVM: Unprotect a page if #PF happens during NMI injection. KVM: s390: Verify memory in kvm run KVM: s390: Sanity check on validity intercept KVM: s390: Unlink vcpu on destroy - v2 KVM: s390: optimize float int lock: spin_lock_bh --> spin_lock KVM: s390: use hrtimer for clock wakeup from idle - v2 KVM: s390: Fix memory slot versus run - v3 ...
2009-06-10KVM: x86: paravirt skip pit-through-ioapic boot checkMarcelo Tosatti
Skip the test which checks if the PIT is properly routed when using the IOAPIC, aimed at buggy hardware. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-04-07Merge commit 'origin/master' into for-linus/xen/masterJeremy Fitzhardinge
* commit 'origin/master': (4825 commits) Fix build errors due to CONFIG_BRANCH_TRACER=y parport: Use the PCI IRQ if offered tty: jsm cleanups Adjust path to gpio headers KGDB_SERIAL_CONSOLE check for module Change KCONFIG name tty: Blackin CTS/RTS Change hardware flow control from poll to interrupt driven Add support for the MAX3100 SPI UART. lanana: assign a device name and numbering for MAX3100 serqt: initial clean up pass for tty side tty: Use the generic RS485 ioctl on CRIS tty: Correct inline types for tty_driver_kref_get() splice: fix deadlock in splicing to file nilfs2: support nanosecond timestamp nilfs2: introduce secondary super block nilfs2: simplify handling of active state of segments nilfs2: mark minor flag for checkpoint created by internal operation nilfs2: clean up sketch file nilfs2: super block operations fix endian bug ... Conflicts: arch/x86/include/asm/thread_info.h arch/x86/lguest/boot.c drivers/xen/manage.c
2009-03-29x86/paravirt: flush pending mmu updates on context switchJeremy Fitzhardinge
Impact: allow preemption during lazy mmu updates If we're in lazy mmu mode when context switching, leave lazy mmu mode, but remember the task's state in TIF_LAZY_MMU_UPDATES. When we resume the task, check this flag and re-enter lazy mmu mode if its set. This sets things up for allowing lazy mmu mode while preemptible, though that won't actually be active until the next change. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
2009-03-19x86: with the last user gone, remove set_pte_presentJeremy Fitzhardinge
Impact: cleanup set_pte_present() is no longer used, directly or indirectly, so remove it. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Xen-devel <xen-devel@lists.xensource.com> Cc: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Alok Kataria <akataria@vmware.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Avi Kivity <avi@redhat.com> LKML-Reference: <1237406613-2929-2-git-send-email-jeremy@goop.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-22x86, paravirt_ops: use unsigned long instead of u32 for alloc_p*() pfn argsEduardo Habkost
This patch changes the pfn args from 'u32' to 'unsigned long' on alloc_p*() functions on paravirt_ops, and the corresponding implementations for Xen and VMI. The prototypes for CONFIG_PARAVIRT=n are already using unsigned long, so paravirt.h now matches the prototypes on asm-x86/pgalloc.h. It shouldn't result in any changes on generated code on 32-bit, with or without CONFIG_PARAVIRT. On both cases, 'codiff -f' didn't show any change after applying this patch. On 64-bit, there are (expected) binary changes only when CONFIG_PARAVIRT is enabled, as the patch is really supposed to change the size of the pfn args. [ v2: KVM_GUEST: use the right parameter type on kvm_release_pt() ] Signed-off-by: Eduardo Habkost <ehabkost@redhat.com> Acked-by: Jeremy Fitzhardinge <jeremy@goop.org> Acked-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-27x86: KVM guest: hypercall batchingMarcelo Tosatti
Batch pte updates and tlb flushes in lazy MMU mode. [avi: - adjust to mmu_op - helper for getting para_state without debug warnings] Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27x86: KVM guest: hypercall based pte updates and TLB flushesMarcelo Tosatti
Hypercall based pte updates are faster than faults, and also allow use of the lazy MMU mode to batch operations. Don't report the feature if two dimensional paging is enabled. [avi: - guest/host split - fix 32-bit truncation issues - adjust to mmu_op - adjust to ->release_*() renamed - add ->release_pud()] Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27x86: KVM guest: add basic paravirt supportMarcelo Tosatti
Add basic KVM paravirt support. Avoid vm-exits on IO delays. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
