commit 447ae316670230d7d29430e2cbf1f5db4f49d14c upstream
The next patch in this series will have to make the definition of
irq_cpustat_t available to entering_irq().
Inclusion of asm/hardirq.h into asm/apic.h would cause circular header
dependencies like
asm/smp.h
asm/apic.h
asm/hardirq.h
linux/irq.h
linux/topology.h
linux/smp.h
asm/smp.h
or
linux/gfp.h
linux/mmzone.h
asm/mmzone.h
asm/mmzone_64.h
asm/smp.h
asm/apic.h
asm/hardirq.h
linux/irq.h
linux/irqdesc.h
linux/kobject.h
linux/sysfs.h
linux/kernfs.h
linux/idr.h
linux/gfp.h
and others.
This causes compilation errors because of the header guards becoming
effective in the second inclusion: symbols/macros that had been defined
before wouldn't be available to intermediate headers in the #include chain
anymore.
A possible workaround would be to move the definition of irq_cpustat_t
into its own header and include that from both, asm/hardirq.h and
asm/apic.h.
However, this wouldn't solve the real problem, namely asm/harirq.h
unnecessarily pulling in all the linux/irq.h cruft: nothing in
asm/hardirq.h itself requires it. Also, note that there are some other
archs, like e.g. arm64, which don't have that #include in their
asm/hardirq.h.
Remove the linux/irq.h #include from x86' asm/hardirq.h.
Fix resulting compilation errors by adding appropriate #includes to *.c
files as needed.
Note that some of these *.c files could be cleaned up a bit wrt. to their
set of #includes, but that should better be done from separate patches, if
at all.
Signed-off-by: Nicolai Stange <nstange@suse.de>
[dwmw2: More fixes for EFI and Xen in 4.9]
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
[ Upstream commit 7ee06cb2f840a96be46233181ed4557901a74385 ]
The classic PC rtc-coms driver has a workaround for broken ACPI device
nodes for it which lack an irq resource. This workaround used to
unconditionally hardcode the irq to 8 in these cases.
This was causing irq conflict problems on systems without a legacy-pic
so a recent patch added an if (nr_legacy_irqs()) guard to the
workaround to avoid this irq conflict.
nr_legacy_irqs() uses the legacy_pic symbol under the hood causing
an undefined symbol error if the rtc-cmos code is build as a module.
This commit exports the legacy_pic symbol to fix this.
Cc: rtc-linux@googlegroups.com
Cc: alexandre.belloni@free-electrons.com
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Commit d32932d02e18 ("x86/irq: Convert IOAPIC to use hierarchical irqdomain
interfaces") brought a regression for Hyper-V Gen2 instances. These
instances don't have i8259 legacy PIC but they use legacy IRQs for serial
port, rtc, and acpi. With this commit included we end up with these IRQs
not initialized. Earlier, there was a special workaround for legacy IRQs
in mp_map_pin_to_irq() doing mp_irqdomain_map() without looking at
nr_legacy_irqs() and now we fail in __irq_domain_alloc_irqs() when
irq_domain_alloc_descs() returns -EEXIST.
The essence of the issue seems to be that early_irq_init() calls
arch_probe_nr_irqs() to figure out the number of legacy IRQs before
we probe for i8259 and gets 16. Later when init_8259A() is called we switch
to NULL legacy PIC and nr_legacy_irqs() starts to return 0 but we already
have 16 descs allocated.
Solve the issue by separating i8259 probe from init and calling it in
arch_probe_nr_irqs() before we actually use nr_legacy_irqs() information.
Fixes: d32932d02e18 ("x86/irq: Convert IOAPIC to use hierarchical irqdomain interfaces")
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
Cc: K. Y. Srinivasan <kys@microsoft.com>
Cc: stable@vger.kernel.org
Link: http://lkml.kernel.org/r/1446543614-3621-1-git-send-email-vkuznets@redhat.com
Since the ISA irqs are in a single block, use
ISA_IRQ_VECTOR(irq) instead of individual macros.
Signed-off-by: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Link: http://lkml.kernel.org/r/1431185813-15413-5-git-send-email-brgerst@gmail.com
Fix duplicate XT-PIC seen in /proc/interrupts on x86 systems
that make use of 8259A Programmable Interrupt Controllers.
Specifically convert output like this:
CPU0
0: 76573 XT-PIC-XT-PIC timer
1: 11 XT-PIC-XT-PIC i8042
2: 0 XT-PIC-XT-PIC cascade
4: 8 XT-PIC-XT-PIC serial
6: 3 XT-PIC-XT-PIC floppy
7: 0 XT-PIC-XT-PIC parport0
8: 1 XT-PIC-XT-PIC rtc0
10: 448 XT-PIC-XT-PIC fddi0
12: 23 XT-PIC-XT-PIC eth0
14: 2464 XT-PIC-XT-PIC ide0
NMI: 0 Non-maskable interrupts
ERR: 0
to one like this:
CPU0
0: 122033 XT-PIC timer
1: 11 XT-PIC i8042
2: 0 XT-PIC cascade
4: 8 XT-PIC serial
6: 3 XT-PIC floppy
7: 0 XT-PIC parport0
8: 1 XT-PIC rtc0
10: 145 XT-PIC fddi0
12: 31 XT-PIC eth0
14: 2245 XT-PIC ide0
ERR: 0
that is one like we used to have from ~2.2 till it was changed
sometime.
The rationale is there is no value in this duplicate
information, it merely clutters output and looks ugly. We only
have one handler for 8259A interrupts so there is no need to
give it a name separate from the name already given to
irq_chip.
We could define meaningful names for handlers based on bits in
the ELCR register on systems that have it or the value of the
LTIM bit we use in ICW1 otherwise (hardcoded to 0 though with
MCA support gone), to tell edge-triggered and level-triggered
inputs apart. While that information does not affect 8259A
interrupt handlers it could help people determine which lines
are shareable and which are not. That is material for a
separate change though.
Any tools that parse /proc/interrupts are supposed not to be
affected since it was many years we used the format this change
converts back to.
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org>
Link: http://lkml.kernel.org/r/alpine.LFD.2.11.1410260147190.21390@eddie.linux-mips.org
The legacy PIC may or may not be available and we need a mechanism to
detect the existence of the legacy PIC that is applicable for all
hardware (both physical as well as virtual) currently supported by
Linux.
On Hyper-V, when our legacy firmware presented to the guests, emulates
the legacy PIC while when our EFI based firmware is presented we do
not emulate the PIC. To support Hyper-V EFI firmware, we had to set
the legacy_pic to the null_legacy_pic since we had to bypass PIC based
calibration in the early boot code. While, on the EFI firmware, we
know we don't emulate the legacy PIC, we need a generic mechanism to
detect the presence of the legacy PIC that is not based on boot time
state - this became apparent when we tried to get kexec to work on
Hyper-V EFI firmware.
This patch implements the proposal put forth by H. Peter Anvin
<hpa@linux.intel.com>: Write a known value to the PIC data port and
read it back. If the value read is the value written, we do have the
PIC, if not there is no PIC and we can safely set the legacy_pic to
null_legacy_pic. Since the read from an unconnected I/O port returns
0xff, we will use ~(1 << PIC_CASCADE_IR) (0xfb: mask all lines except
the cascade line) to probe for the existence of the PIC.
In version V1 of the patch, I had cleaned up the code based on comments from Peter.
In version V2 of the patch, I have addressed additional comments from Peter.
In version V3 of the patch, I have addressed Jan's comments (JBeulich@suse.com).
In version V4 of the patch, I have addressed additional comments from Peter.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
Link: http://lkml.kernel.org/r/1397501029-29286-1-git-send-email-kys@microsoft.com
0x30-0x3f have been used for ISA interrupts on i386 as well
since 5 years ago, but old comments about i8259 initialization
were still referring to the old i386 usage of this port range.
Signed-off-by: Yanchuan Nian <ycnian@gmail.com>
Cc: yinghai@kernel.org
Cc: pavel@suse.cz
Link: http://lkml.kernel.org/r/1378257924-29446-1-git-send-email-ycnian@gmail.com
Signed-off-by: Yuanhan Liu <yliu.null@gmail.com>
Disintegrate asm/system.h for X86.
Acked-by: H. Peter Anvin <hpa@zytor.com>
cc: x86@kernel.org
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
Some subsystems in the x86 tree need to carry out suspend/resume and
shutdown operations with one CPU on-line and interrupts disabled and
they define sysdev classes and sysdevs or sysdev drivers for this
purpose. This leads to unnecessarily complicated code and excessive
memory usage, so switch them to using struct syscore_ops objects for
this purpose instead.
Generally, there are three categories of subsystems that use
sysdevs for implementing PM operations: (1) subsystems whose
suspend/resume callbacks ignore their arguments entirely (the
majority), (2) subsystems whose suspend/resume callbacks use their
struct sys_device argument, but don't really need to do that,
because they can be implemented differently in an arguably simpler
way (io_apic.c), and (3) subsystems whose suspend/resume callbacks
use their struct sys_device argument, but the value of that argument
is always the same and could be ignored (microcode_core.c). In all
of these cases the subsystems in question may be readily converted to
using struct syscore_ops objects for power management and shutdown.
genirq is switching to a consistent name space for the irq related
functions. Convert x86. Conversion was done with coccinelle.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
My platform makes use of the null_legacy_pic choice and oopses when doing
a shutdown as the shutdown code goes through all the registered sysdevs
and calls their shutdown method which in my case poke on a non-existing
i8259. Imho the i8259 specific sysdev should only be registered if the
i8259 is actually there.
Do not register the sysdev function when the null_legacy_pic is used so
that the i8259 resume, suspend and shutdown functions are not called.
Signed-off-by: Adam Lackorzynski <adam@os.inf.tu-dresden.de>
LKML-Reference: <201007202218.o6KMIJ3m020955@imap1.linux-foundation.org>
Cc: Jacob Pan <jacob.jun.pan@intel.com>
Cc: <stable@kernel.org> 2.6.34
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Move legacy_pic chip dummy functions out of init section as they might
be referenced at run time.
Signed-off-by: Jacob Pan <jacob.jun.pan@intel.com>
LKML-Reference: <43F901BD926A4E43B106BF17856F0755A318D3AA@orsmsx508.amr.corp.intel.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
arch/x86/kernel/apic/io_apic.c
This patch replaces legacy PIC-related global variable and functions
with the new legacy_pic abstraction.
LKML-Reference: <43F901BD926A4E43B106BF17856F07559FB80D04@orsmsx508.amr.corp.intel.com>
This patch makes i8259A like legacy programmable interrupt controller
code into a driver so that legacy pic functions can be selected at
runtime based on platform information, such as HW subarchitecure ID.
Default structure of legacy_pic maintains the current code path for
x86pc.
LKML-Reference: <43F901BD926A4E43B106BF17856F07559FB80D03@orsmsx508.amr.corp.intel.com>
Impact: cleanup
Make x86_quirks support more transparent. The highlevel
methods are now named:
extern void x86_quirk_pre_intr_init(void);
extern void x86_quirk_intr_init(void);
extern void x86_quirk_trap_init(void);
extern void x86_quirk_pre_time_init(void);
extern void x86_quirk_time_init(void);
This makes it clear that if some platform extension has to
do something here that it is considered ... weird, and is
discouraged.
Also remove arch_hooks.h and move it into setup.h (and other
header files where appropriate).
Impact: cleanup
Fix:
WARNING: Use #include <linux/acpi.h> instead of <asm/acpi.h>
WARNING: Use #include <linux/io.h> instead of <asm/io.h>
WARNING: Use #include <linux/delay.h> instead of <asm/delay.h>
ERROR: code indent should use tabs where possible
total: 1 errors, 3 warnings
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
8259 specific mask/unmask routines which be used later while enabling
interrupt-remapping.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: akpm@linux-foundation.org
Cc: arjan@linux.intel.com
Cc: andi@firstfloor.org
Cc: ebiederm@xmission.com
Cc: jbarnes@virtuousgeek.org
Cc: steiner@sgi.com
Introduce IRQx_VECTOR on 32-bit, so that #ifdef noise is kept
down. There should be no object code change.
[ mingo@elte.hu: merged to x86/irq not x86/i8259 due to x86/irq having
restructured the vector code into asm-x86/irq_vectors.h, which this
patch touches. ]
Signed-off-by: Pavel Machek <pavel@suse.cz>
Cc: macro@ds2.pg.gda.pl
Remove #ifdefs where the only difference is formatting of comments.
Remove #ifdefs around includes; including too much should be always
safe.
Make conversion of i8259 very mechanical -- i8259 was generated by
diff -D, with too different parts left in i8259_32 and
i8259_64.c. Only "by hand" changes were removal of #ifdef from middle
of the comment (prevented compilation) and removal of one static to
allow splitting into files.
Of course, it will need some cleanups now, and those will follow.
Signed-of-by: Pavel Machek <pavel@suse.cz>
