commit 0e1b869fff60c81b510c2d00602d778f8f59dd9a upstream.
Some guests OSes (including Windows 10) write to MSR 0xc001102c
on some cases (possibly while trying to apply a CPU errata).
Make KVM ignore reads and writes to that MSR, so the guest won't
crash.
The MSR is documented as "Execution Unit Configuration (EX_CFG)",
at AMD's "BIOS and Kernel Developer's Guide (BKDG) for AMD Family
15h Models 00h-0Fh Processors".
Cc: stable@vger.kernel.org
Signed-off-by: Eduardo Habkost <ehabkost@redhat.com>
commit 7aa54be2976550f17c11a1c3e3630002dea39303 upstream.
On x86 we cannot do fetch_or() with a single instruction and thus end up
using a cmpxchg loop, this reduces determinism. Replace the fetch_or()
with a composite operation: tas-pending + load.
Using two instructions of course opens a window we previously did not
have. Consider the scenario:
CPU0 CPU1 CPU2
1) lock
trylock -> (0,0,1)
2) lock
trylock /* fail */
3) unlock -> (0,0,0)
4) lock
trylock -> (0,0,1)
5) tas-pending -> (0,1,1)
load-val <- (0,1,0) from 3
6) clear-pending-set-locked -> (0,0,1)
FAIL: _2_ owners
where 5) is our new composite operation. When we consider each part of
the qspinlock state as a separate variable (as we can when
_Q_PENDING_BITS == 8) then the above is entirely possible, because
tas-pending will only RmW the pending byte, so the later load is able
to observe prior tail and lock state (but not earlier than its own
trylock, which operates on the whole word, due to coherence).
To avoid this we need 2 things:
- the load must come after the tas-pending (obviously, otherwise it
can trivially observe prior state).
- the tas-pending must be a full word RmW instruction, it cannot be an XCHGB for
example, such that we cannot observe other state prior to setting
pending.
On x86 we can realize this by using "LOCK BTS m32, r32" for
tas-pending followed by a regular load.
Note that observing later state is not a problem:
- if we fail to observe a later unlock, we'll simply spin-wait for
that store to become visible.
- if we observe a later xchg_tail(), there is no difference from that
xchg_tail() having taken place before the tas-pending.
Suggested-by: Will Deacon <will.deacon@arm.com>
Reported-by: Thomas Gleixner <tglx@linutronix.de>
Reviewed-by: Will Deacon <will.deacon@arm.com>
Cc: andrea.parri@amarulasolutions.com
Cc: longman@redhat.com
Fixes: 59fb586b4a07 ("locking/qspinlock: Remove unbounded cmpxchg() loop from locking slowpath")
Link: https://lkml.kernel.org/r/20181003130957.183726335@infradead.org
[bigeasy: GEN_BINARY_RMWcc macro redo]
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
commit 326e742533bf0a23f0127d8ea62fb558ba665f08 upstream.
Since commit e79f245ddec1 ("X86/KVM: Properly update 'tsc_offset' to
represent the running guest"), vcpu->arch.tsc_offset meaning was
changed to always reflect the tsc_offset value set on active VMCS.
Regardless if vCPU is currently running L1 or L2.
However, above mentioned commit failed to also change
kvm_vcpu_write_tsc_offset() to set vcpu->arch.tsc_offset correctly.
This is because vmx_write_tsc_offset() could set the tsc_offset value
in active VMCS to given offset parameter *plus vmcs12->tsc_offset*.
However, kvm_vcpu_write_tsc_offset() just sets vcpu->arch.tsc_offset
to given offset parameter. Without taking into account the possible
addition of vmcs12->tsc_offset. (Same is true for SVM case).
Fix this issue by changing kvm_x86_ops->write_tsc_offset() to return
actually set tsc_offset in active VMCS and modify
kvm_vcpu_write_tsc_offset() to set returned value in
vcpu->arch.tsc_offset.
In addition, rename write_tsc_offset() callback to write_l1_tsc_offset()
to make it clear that it is meant to set L1 TSC offset.
Fixes: e79f245ddec1 ("X86/KVM: Properly update 'tsc_offset' to represent the running guest")
Reviewed-by: Liran Alon <liran.alon@oracle.com>
Reviewed-by: Mihai Carabas <mihai.carabas@oracle.com>
Reviewed-by: Krish Sadhukhan <krish.sadhukhan@oracle.com>
Signed-off-by: Leonid Shatz <leonid.shatz@oracle.com>
commit 6b3e64c237c072797a9ec918654a60e3a46488e2 upstream
If 'prctl' mode of user space protection from spectre v2 is selected
on the kernel command-line, STIBP and IBPB are applied on tasks which
restrict their indirect branch speculation via prctl.
SECCOMP enables the SSBD mitigation for sandboxed tasks already, so it
makes sense to prevent spectre v2 user space to user space attacks as
well.
The Intel mitigation guide documents how STIPB works:
Setting bit 1 (STIBP) of the IA32_SPEC_CTRL MSR on a logical processor
prevents the predicted targets of indirect branches on any logical
processor of that core from being controlled by software that executes
(or executed previously) on another logical processor of the same core.
Ergo setting STIBP protects the task itself from being attacked from a task
running on a different hyper-thread and protects the tasks running on
different hyper-threads from being attacked.
While the document suggests that the branch predictors are shielded between
the logical processors, the observed performance regressions suggest that
STIBP simply disables the branch predictor more or less completely. Of
course the document wording is vague, but the fact that there is also no
requirement for issuing IBPB when STIBP is used points clearly in that
direction. The kernel still issues IBPB even when STIBP is used until Intel
clarifies the whole mechanism.
IBPB is issued when the task switches out, so malicious sandbox code cannot
mistrain the branch predictor for the next user space task on the same
logical processor.
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Cc: Tom Lendacky <thomas.lendacky@amd.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: David Woodhouse <dwmw@amazon.co.uk>
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Cc: Casey Schaufler <casey.schaufler@intel.com>
Cc: Asit Mallick <asit.k.mallick@intel.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Jon Masters <jcm@redhat.com>
Cc: Waiman Long <longman9394@gmail.com>
Cc: Greg KH <gregkh@linuxfoundation.org>
Cc: Dave Stewart <david.c.stewart@intel.com>
Link: https://lkml.kernel.org/r/20181125185006.051663132@linutronix.de
commit 9137bb27e60e554dab694eafa4cca241fa3a694f upstream
Add the PR_SPEC_INDIRECT_BRANCH option for the PR_GET_SPECULATION_CTRL and
PR_SET_SPECULATION_CTRL prctls to allow fine grained per task control of
indirect branch speculation via STIBP and IBPB.
Invocations:
Check indirect branch speculation status with
- prctl(PR_GET_SPECULATION_CTRL, PR_SPEC_INDIRECT_BRANCH, 0, 0, 0);
Enable indirect branch speculation with
- prctl(PR_SET_SPECULATION_CTRL, PR_SPEC_INDIRECT_BRANCH, PR_SPEC_ENABLE, 0, 0);
Disable indirect branch speculation with
- prctl(PR_SET_SPECULATION_CTRL, PR_SPEC_INDIRECT_BRANCH, PR_SPEC_DISABLE, 0, 0);
Force disable indirect branch speculation with
- prctl(PR_SET_SPECULATION_CTRL, PR_SPEC_INDIRECT_BRANCH, PR_SPEC_FORCE_DISABLE, 0, 0);
See Documentation/userspace-api/spec_ctrl.rst.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Link: https://lkml.kernel.org/r/20181125185005.866780996@linutronix.de
commit 6d991ba509ebcfcc908e009d1db51972a4f7a064 upstream
The seccomp speculation control operates on all tasks of a process, but
only the current task of a process can update the MSR immediately. For the
other threads the update is deferred to the next context switch.
This creates the following situation with Process A and B:
Process A task 2 and Process B task 1 are pinned on CPU1. Process A task 2
does not have the speculation control TIF bit set. Process B task 1 has the
CPU0 CPU1
MSR bit is set
ProcB.T1 schedules out
ProcA.T2 schedules in
MSR bit is cleared
ProcA.T1
seccomp_update()
set TIF bit on ProcA.T2
ProcB.T1 schedules in
MSR is not updated <-- FAIL
This happens because the context switch code tries to avoid the MSR update
if the speculation control TIF bits of the incoming and the outgoing task
are the same. In the worst case ProcB.T1 and ProcA.T2 are the only tasks
scheduling back and forth on CPU1, which keeps the MSR stale forever.
In theory this could be remedied by IPIs, but chasing the remote task which
could be migrated is complex and full of races.
The straight forward solution is to avoid the asychronous update of the TIF
bit and defer it to the next context switch. The speculation control state
is stored in task_struct::atomic_flags by the prctl and seccomp updates
already.
Add a new TIF_SPEC_FORCE_UPDATE bit and set this after updating the
atomic_flags. Check the bit on context switch and force a synchronous
update of the speculation control if set. Use the same mechanism for
updating the current task.
Reported-by: Tim Chen <tim.c.chen@linux.intel.com>
Link: https://lkml.kernel.org/r/alpine.DEB.2.21.1811272247140.1875@nanos.tec.linutronix.de
commit 4c71a2b6fd7e42814aa68a6dec88abf3b42ea573 upstream
The IBPB speculation barrier is issued from switch_mm() when the kernel
switches to a user space task with a different mm than the user space task
which ran last on the same CPU.
An additional optimization is to avoid IBPB when the incoming task can be
ptraced by the outgoing task. This optimization only works when switching
directly between two user space tasks. When switching from a kernel task to
a user space task the optimization fails because the previous task cannot
be accessed anymore. So for quite some scenarios the optimization is just
adding overhead.
The upcoming conditional IBPB support will issue IBPB only for user space
tasks which have the TIF_SPEC_IB bit set. This requires to handle the
following cases:
1) Switch from a user space task (potential attacker) which has
TIF_SPEC_IB set to a user space task (potential victim) which has
TIF_SPEC_IB not set.
2) Switch from a user space task (potential attacker) which has
TIF_SPEC_IB not set to a user space task (potential victim) which has
TIF_SPEC_IB set.
This needs to be optimized for the case where the IBPB can be avoided when
only kernel threads ran in between user space tasks which belong to the
same process.
The current check whether two tasks belong to the same context is using the
tasks context id. While correct, it's simpler to use the mm pointer because
it allows to mangle the TIF_SPEC_IB bit into it. The context id based
mechanism requires extra storage, which creates worse code.
When a task is scheduled out its TIF_SPEC_IB bit is mangled as bit 0 into
the per CPU storage which is used to track the last user space mm which was
running on a CPU. This bit can be used together with the TIF_SPEC_IB bit of
the incoming task to make the decision whether IBPB needs to be issued or
not to cover the two cases above.
As conditional IBPB is going to be the default, remove the dubious ptrace
check for the IBPB always case and simply issue IBPB always when the
process changes.
Move the storage to a different place in the struct as the original one
created a hole.
Link: https://lkml.kernel.org/r/20181125185005.466447057@linutronix.de
commit 5635d99953f04b550738f6f4c1c532667c3fd872 upstream
The TIF_SPEC_IB bit does not need to be evaluated in the decision to invoke
__switch_to_xtra() when:
- CONFIG_SMP is disabled
- The conditional STIPB mode is disabled
The TIF_SPEC_IB bit still controls IBPB in both cases so the TIF work mask
checks might invoke __switch_to_xtra() for nothing if TIF_SPEC_IB is the
only set bit in the work masks.
Optimize it out by masking the bit at compile time for CONFIG_SMP=n and at
run time when the static key controlling the conditional STIBP mode is
disabled.
Link: https://lkml.kernel.org/r/20181125185005.374062201@linutronix.de
commit ff16701a29cba3aafa0bd1656d766813b2d0a811 upstream
Move the conditional invocation of __switch_to_xtra() into an inline
function so the logic can be shared between 32 and 64 bit.
Remove the handthrough of the TSS pointer and retrieve the pointer directly
in the bitmap handling function. Use this_cpu_ptr() instead of the
per_cpu() indirection.
This is a preparatory change so integration of conditional indirect branch
speculation optimization happens only in one place.
Link: https://lkml.kernel.org/r/20181125185005.280855518@linutronix.de
commit 5bfbe3ad5840d941b89bcac54b821ba14f50a0ba upstream
To avoid the overhead of STIBP always on, it's necessary to allow per task
control of STIBP.
Add a new task flag TIF_SPEC_IB and evaluate it during context switch if
SMT is active and flag evaluation is enabled by the speculation control
code. Add the conditional evaluation to x86_virt_spec_ctrl() as well so the
guest/host switch works properly.
This has no effect because TIF_SPEC_IB cannot be set yet and the static key
which controls evaluation is off. Preparatory patch for adding the control
code.
[ tglx: Simplify the context switch logic and make the TIF evaluation
depend on SMP=y and on the static key controlling the conditional
update. Rename it to TIF_SPEC_IB because it controls both STIBP and
IBPB ]
Link: https://lkml.kernel.org/r/20181125185005.176917199@linutronix.de
commit fa1202ef224391b6f5b26cdd44cc50495e8fab54 upstream
Add command line control for user space indirect branch speculation
mitigations. The new option is: spectre_v2_user=
The initial options are:
- on: Unconditionally enabled
- off: Unconditionally disabled
-auto: Kernel selects mitigation (default off for now)
When the spectre_v2= command line argument is either 'on' or 'off' this
implies that the application to application control follows that state even
if a contradicting spectre_v2_user= argument is supplied.
Originally-by: Tim Chen <tim.c.chen@linux.intel.com>
Link: https://lkml.kernel.org/r/20181125185005.082720373@linutronix.de
commit 26c4d75b234040c11728a8acb796b3a85ba7507c upstream
During context switch, the SSBD bit in SPEC_CTRL MSR is updated according
to changes of the TIF_SSBD flag in the current and next running task.
Currently, only the bit controlling speculative store bypass disable in
SPEC_CTRL MSR is updated and the related update functions all have
"speculative_store" or "ssb" in their names.
For enhanced mitigation control other bits in SPEC_CTRL MSR need to be
updated as well, which makes the SSB names inadequate.
Rename the "speculative_store*" functions to a more generic name. No
functional change.
Link: https://lkml.kernel.org/r/20181125185004.058866968@linutronix.de
commit 8eb729b77faf83ac4c1f363a9ad68d042415f24c upstream
"Reduced Data Speculation" is an obsolete term. The correct new name is
"Speculative store bypass disable" - which is abbreviated into SSBD.
Link: https://lkml.kernel.org/r/20181125185003.593893901@linutronix.de
commit ef014aae8f1cd2793e4e014bbb102bed53f852b7 upstream
Now that CONFIG_RETPOLINE hard depends on compiler support, there is no
reason to keep the minimal retpoline support around which only provided
basic protection in the assembly files.
Suggested-by: Peter Zijlstra <peterz@infradead.org>
Signed-off-by: Zhenzhong Duan <zhenzhong.duan@oracle.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: <srinivas.eeda@oracle.com>
Link: https://lkml.kernel.org/r/f06f0a89-5587-45db-8ed2-0a9d6638d5c0@default
commit 4cd24de3a0980bf3100c9dcb08ef65ca7c31af48 upstream
Since retpoline capable compilers are widely available, make
CONFIG_RETPOLINE hard depend on the compiler capability.
Break the build when CONFIG_RETPOLINE is enabled and the compiler does not
support it. Emit an error message in that case:
"arch/x86/Makefile:226: *** You are building kernel with non-retpoline
compiler, please update your compiler.. Stop."
[dwmw: Fail the build with non-retpoline compiler]
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Michal Marek <michal.lkml@markovi.net>
Link: https://lkml.kernel.org/r/cca0cb20-f9e2-4094-840b-fb0f8810cd34@default
commit 0cbb76d6285794f30953bfa3ab831714b59dd700 upstream
..so that they match their asm counterpart.
Add the missing ANNOTATE_NOSPEC_ALTERNATIVE in CALL_NOSPEC, while at it.
Cc: Wang YanQing <udknight@gmail.com>
Cc: dhaval.giani@oracle.com
Cc: srinivas.eeda@oracle.com
Link: http://lkml.kernel.org/r/c3975665-173e-4d70-8dee-06c926ac26ee@default
commit d52888aa2753e3063a9d3a0c9f72f94aa9809c15 upstream
On 5-level paging the LDT remap area is placed in the middle of the KASLR
randomization region and it can overlap with the direct mapping, the
vmalloc or the vmap area.
The LDT mapping is per mm, so it cannot be moved into the P4D page table
next to the CPU_ENTRY_AREA without complicating PGD table allocation for
5-level paging.
The 4 PGD slot gap just before the direct mapping is reserved for
hypervisors, so it cannot be used.
Move the direct mapping one slot deeper and use the resulting gap for the
LDT remap area. The resulting layout is the same for 4 and 5 level paging.
[ tglx: Massaged changelog ]
Fixes: f55f0501cbf6 ("x86/pti: Put the LDT in its own PGD if PTI is on")
Reviewed-by: Andy Lutomirski <luto@kernel.org>
Cc: bp@alien8.de
Cc: hpa@zytor.com
Cc: dave.hansen@linux.intel.com
Cc: peterz@infradead.org
Cc: boris.ostrovsky@oracle.com
Cc: jgross@suse.com
Cc: bhe@redhat.com
Cc: willy@infradead.org
Cc: linux-mm@kvack.org
Link: https://lkml.kernel.org/r/20181026122856.66224-2-kirill.shutemov@linux.intel.com
commit e8a308e5f47e545e0d41d0686c00f5f5217c5f61 upstream.
The NFIT machine check handler uses the physical address from the mce
structure, and compares it against information in the ACPI NFIT table
to determine whether that location lies on an NVDIMM. The mce->addr
field however may not always be valid, and this is indicated by the
MCI_STATUS_ADDRV bit in the status field.
Export mce_usable_address() which already performs validation for the
address, and use it in the NFIT handler.
Fixes: 6839a6d96f4e ("nfit: do an ARS scrub on hitting a latent media error")
Reported-by: Robert Elliott <elliott@hpe.com>
Signed-off-by: Vishal Verma <vishal.l.verma@intel.com>
CC: Arnd Bergmann <arnd@arndb.de>
Cc: Dan Williams <dan.j.williams@intel.com>
CC: Dave Jiang <dave.jiang@intel.com>
CC: elliott@hpe.com
CC: "H. Peter Anvin" <hpa@zytor.com>
CC: Ingo Molnar <mingo@redhat.com>
CC: Len Brown <lenb@kernel.org>
CC: linux-acpi@vger.kernel.org
CC: linux-edac <linux-edac@vger.kernel.org>
CC: linux-nvdimm@lists.01.org
CC: Qiuxu Zhuo <qiuxu.zhuo@intel.com>
CC: "Rafael J. Wysocki" <rjw@rjwysocki.net>
CC: Ross Zwisler <zwisler@kernel.org>
CC: stable <stable@vger.kernel.org>
CC: Thomas Gleixner <tglx@linutronix.de>
CC: Tony Luck <tony.luck@intel.com>
CC: x86-ml <x86@kernel.org>
CC: Yazen Ghannam <yazen.ghannam@amd.com>
Link: http://lkml.kernel.org/r/20181026003729.8420-2-vishal.l.verma@intel.com
commit 5d96c9342c23ee1d084802dcf064caa67ecaa45b upstream.
The MCE handler for nfit devices is called for memory errors on a
Non-Volatile DIMM and adds the error location to a 'badblocks' list.
This list is used by the various NVDIMM drivers to avoid consuming known
poison locations during IO.
The MCE handler gets called for both corrected and uncorrectable errors.
Until now, both kinds of errors have been added to the badblocks list.
However, corrected memory errors indicate that the problem has already
been fixed by hardware, and the resulting interrupt is merely a
notification to Linux.
As far as future accesses to that location are concerned, it is
perfectly fine to use, and thus doesn't need to be included in the above
badblocks list.
Add a check in the nfit MCE handler to filter out corrected mce events,
and only process uncorrectable errors.
Reported-by: Omar Avelar <omar.avelar@intel.com>
CC: Dan Williams <dan.j.williams@intel.com>
CC: elliott@hpe.com
Link: http://lkml.kernel.org/r/20181026003729.8420-1-vishal.l.verma@intel.com
[ Upstream commit cfb634fe3052aefc4e1360fa322018c9a0b49755 ]
According to volume 3 of the SDM, bits 63:15 and 12:4 of the exit
qualification field for debug exceptions are reserved (cleared to
0). However, the SDM is incorrect about bit 16 (corresponding to
DR6.RTM). This bit should be set if a debug exception (#DB) or a
breakpoint exception (#BP) occurred inside an RTM region while
advanced debugging of RTM transactional regions was enabled. Note that
this is the opposite of DR6.RTM, which "indicates (when clear) that a
debug exception (#DB) or breakpoint exception (#BP) occurred inside an
RTM region while advanced debugging of RTM transactional regions was
enabled."
There is still an issue with stale DR6 bits potentially being
misreported for the current debug exception. DR6 should not have been
modified before vectoring the #DB exception, and the "new DR6 bits"
should be available somewhere, but it was and they aren't.
Fixes: b96fb439774e1 ("KVM: nVMX: fixes to nested virt interrupt injection")
Signed-off-by: Jim Mattson <jmattson@google.com>
Reviewed-by: Sean Christopherson <sean.j.christopherson@intel.com>
commit f77084d96355f5fba8e2c1fb3a51a393b1570de7 upstream.
The WARN_ON_ONCE(__read_cr3() != build_cr3()) in switch_mm_irqs_off()
triggers every once in a while during a snapshotted system upgrade.
The warning triggers since commit decab0888e6e ("x86/mm: Remove
preempt_disable/enable() from __native_flush_tlb()"). The callchain is:
get_page_from_freelist() -> post_alloc_hook() -> __kernel_map_pages()
with CONFIG_DEBUG_PAGEALLOC enabled.
Disable preemption during CR3 reset / __flush_tlb_all() and add a comment
why preemption has to be disabled so it won't be removed accidentaly.
Add another preemptible() check in __flush_tlb_all() to catch callers with
enabled preemption when PGE is enabled, because PGE enabled does not
trigger the warning in __native_flush_tlb(). Suggested by Andy Lutomirski.
Fixes: decab0888e6e ("x86/mm: Remove preempt_disable/enable() from __native_flush_tlb()")
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Link: https://lkml.kernel.org/r/20181017103432.zgv46nlu3hc7k4rq@linutronix.de
switch if there is an FPU
Booting an i486 with "no387 nofxsr" ends with with the following crash:
math_emulate: 0060:c101987d
Kernel panic - not syncing: Math emulation needed in kernel
on the first context switch in user land.
The reason is that copy_fpregs_to_fpstate() tries FNSAVE which does not work
as the FPU is turned off.
This bug was introduced in:
f1c8cd0176078 ("x86/fpu: Change fpu->fpregs_active users to fpu->fpstate_active")
Add a check for X86_FEATURE_FPU before trying to save FPU registers (we
have such a check in switch_fpu_finish() already).
Fixes: f1c8cd0176078 ("x86/fpu: Change fpu->fpregs_active users to fpu->fpstate_active")
Link: http://lkml.kernel.org/r/20181016202525.29437-4-bigeasy@linutronix.de
Eric reported that a sequence count loop using this_cpu_read() got
optimized out. This is wrong, this_cpu_read() must imply READ_ONCE()
because the interface is IRQ-safe, therefore an interrupt can have
changed the per-cpu value.
Fixes: 7c3576d261ce ("[PATCH] i386: Convert PDA into the percpu section")
Reported-by: Eric Dumazet <edumazet@google.com>
Cc: hpa@zytor.com
Cc: eric.dumazet@gmail.com
Cc: bp@alien8.de
Link: https://lkml.kernel.org/r/20181011104019.748208519@infradead.org
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm
Dan writes:
"libnvdimm/dax 4.19-rc8
* Fix a livelock in dax_layout_busy_page() present since v4.18. The
lockup triggers when truncating an actively mapped huge page out of
a mapping pinned for direct-I/O.
* Fix mprotect() clobbers of _PAGE_DEVMAP. Broken since v4.5
mprotect() clears this flag that is needed to communicate the
liveness of device pages to the get_user_pages() path."
* tag 'libnvdimm-fixes-4.19-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm:
mm: Preserve _PAGE_DEVMAP across mprotect() calls
filesystem-dax: Fix dax_layout_busy_page() livelock
Currently _PAGE_DEVMAP bit is not preserved in mprotect(2) calls. As a
result we will see warnings such as:
BUG: Bad page map in process JobWrk0013 pte:800001803875ea25 pmd:7624381067
addr:00007f0930720000 vm_flags:280000f9 anon_vma: (null) mapping:ffff97f2384056f0 index:0
file:457-000000fe00000030-00000009-000000ca-00000001_2001.fileblock fault:xfs_filemap_fault [xfs] mmap:xfs_file_mmap [xfs] readpage: (null)
CPU: 3 PID: 15848 Comm: JobWrk0013 Tainted: G W 4.12.14-2.g7573215-default #1 SLE12-SP4 (unreleased)
Hardware name: Intel Corporation S2600WFD/S2600WFD, BIOS SE5C620.86B.01.00.0833.051120182255 05/11/2018
Call Trace:
dump_stack+0x5a/0x75
print_bad_pte+0x217/0x2c0
? enqueue_task_fair+0x76/0x9f0
_vm_normal_page+0xe5/0x100
zap_pte_range+0x148/0x740
unmap_page_range+0x39a/0x4b0
unmap_vmas+0x42/0x90
unmap_region+0x99/0xf0
? vma_gap_callbacks_rotate+0x1a/0x20
do_munmap+0x255/0x3a0
vm_munmap+0x54/0x80
SyS_munmap+0x1d/0x30
do_syscall_64+0x74/0x150
entry_SYSCALL_64_after_hwframe+0x3d/0xa2
when mprotect(2) gets used on DAX mappings. Also there is a wide variety
of other failures that can result from the missing _PAGE_DEVMAP flag
when the area gets used by get_user_pages() later.
Fix the problem by including _PAGE_DEVMAP in a set of flags that get
preserved by mprotect(2).
Fixes: 69660fd797c3 ("x86, mm: introduce _PAGE_DEVMAP")
Fixes: ebd31197931d ("powerpc/mm: Add devmap support for ppc64")
Cc: <stable@vger.kernel.org>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Ingo writes:
"perf fixes:
- fix a CPU#0 hot unplug bug and a PCI enumeration bug in the x86 Intel uncore PMU driver
- fix a CPU event enumeration bug in the x86 AMD PMU driver
- fix a perf ring-buffer corruption bug when using tracepoints
- fix a PMU unregister locking bug"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf/x86/amd/uncore: Set ThreadMask and SliceMask for L3 Cache perf events
perf/x86/intel/uncore: Fix PCI BDF address of M3UPI on SKX
perf/ring_buffer: Prevent concurent ring buffer access
perf/x86/intel/uncore: Use boot_cpu_data.phys_proc_id instead of hardcorded physical package ID 0
perf/core: Fix perf_pmu_unregister() locking
Introduce is_early_uv_system() which uses efi.uv_systab to decide early
in the boot process whether the kernel runs on a UV system.
This is needed to skip other early setup/init code that might break
the UV platform if done too early such as before necessary ACPI tables
parsing takes place.
Suggested-by: Hedi Berriche <hedi.berriche@hpe.com>
Signed-off-by: Mike Travis <mike.travis@hpe.com>
Reviewed-by: Russ Anderson <rja@hpe.com>
Reviewed-by: Dimitri Sivanich <sivanich@hpe.com>
Cc: Russ Anderson <russ.anderson@hpe.com>
Cc: Dimitri Sivanich <dimitri.sivanich@hpe.com>
Cc: Kate Stewart <kstewart@linuxfoundation.org>
Cc: Philippe Ombredanne <pombredanne@nexb.com>
Cc: Pavel Tatashin <pasha.tatashin@oracle.com>
Cc: Len Brown <len.brown@intel.com>
Cc: Dou Liyang <douly.fnst@cn.fujitsu.com>
Cc: Xiaoming Gao <gxm.linux.kernel@gmail.com>
Cc: Rajvi Jingar <rajvi.jingar@intel.com>
Link: https://lkml.kernel.org/r/20181002180144.801700401@stormcage.americas.sgi.com
In Family 17h, some L3 Cache Performance events require the ThreadMask
and SliceMask to be set. For other events, these fields do not affect
the count either way.
Set ThreadMask and SliceMask to 0xFF and 0xF respectively.
Signed-off-by: Janakarajan Natarajan <Janakarajan.Natarajan@amd.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: H . Peter Anvin <hpa@zytor.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Stephane Eranian <eranian@google.com>
Cc: Suravee <Suravee.Suthikulpanit@amd.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Link: http://lkml.kernel.org/r/Message-ID:
Thomas writes:
"A set of fixes for x86:
- Resolve the kvmclock regression on AMD systems with memory
encryption enabled. The rework of the kvmclock memory allocation
during early boot results in encrypted storage, which is not
shareable with the hypervisor. Create a new section for this data
which is mapped unencrypted and take care that the later
allocations for shared kvmclock memory is unencrypted as well.
- Fix the build regression in the paravirt code introduced by the
recent spectre v2 updates.
- Ensure that the initial static page tables cover the fixmap space
correctly so early console always works. This worked so far by
chance, but recent modifications to the fixmap layout can -
depending on kernel configuration - move the relevant entries to a
different place which is not covered by the initial static page
tables.
- Address the regressions and issues which got introduced with the
recent extensions to the Intel Recource Director Technology code.
- Update maintainer entries to document reality"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/mm: Expand static page table for fixmap space
MAINTAINERS: Add X86 MM entry
x86/intel_rdt: Add Reinette as co-maintainer for RDT
MAINTAINERS: Add Borislav to the x86 maintainers
x86/paravirt: Fix some warning messages
x86/intel_rdt: Fix incorrect loop end condition
x86/intel_rdt: Fix exclusive mode handling of MBA resource
x86/intel_rdt: Do not allow pseudo-locking of MBA resource
x86/intel_rdt: Fix unchecked MSR access
x86/intel_rdt: Fix invalid mode warning when multiple resources are managed
x86/intel_rdt: Global closid helper to support future fixes
x86/intel_rdt: Fix size reporting of MBA resource
x86/intel_rdt: Fix data type in parsing callbacks
x86/kvm: Use __bss_decrypted attribute in shared variables
x86/mm: Add .bss..decrypted section to hold shared variables
We met a kernel panic when enabling earlycon, which is due to the fixmap
address of earlycon is not statically setup.
Currently the static fixmap setup in head_64.S only covers 2M virtual
address space, while it actually could be in 4M space with different
kernel configurations, e.g. when VSYSCALL emulation is disabled.
So increase the static space to 4M for now by defining FIXMAP_PMD_NUM to 2,
and add a build time check to ensure that the fixmap is covered by the
initial static page tables.
Fixes: 1ad83c858c7d ("x86_64,vsyscall: Make vsyscall emulation configurable")
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: Feng Tang <feng.tang@intel.com>
Tested-by: kernel test robot <rong.a.chen@intel.com>
Reviewed-by: Juergen Gross <jgross@suse.com> (Xen parts)
Cc: H Peter Anvin <hpa@linux.intel.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Andy Lutomirsky <luto@kernel.org>
Link: https://lkml.kernel.org/r/20180920025828.23699-1-feng.tang@intel.com
Add KVM_CAP_MSR_PLATFORM_INFO so that userspace can disable guest access
to reads of MSR_PLATFORM_INFO.
Disabling access to reads of this MSR gives userspace the control to "expose"
this platform-dependent information to guests in a clear way. As it exists
today, guests that read this MSR would get unpopulated information if userspace
hadn't already set it (and prior to this patch series, only the CPUID faulting
information could have been populated). This existing interface could be
confusing if guests don't handle the potential for incorrect/incomplete
information gracefully (e.g. zero reported for base frequency).
Signed-off-by: Drew Schmitt <dasch@google.com>
In case L1 do not intercept L2 HLT or enter L2 in HLT activity-state,
it is possible for a vCPU to be blocked while it is in guest-mode.
According to Intel SDM 26.6.5 Interrupt-Window Exiting and
Virtual-Interrupt Delivery: "These events wake the logical processor
if it just entered the HLT state because of a VM entry".
Therefore, if L1 enters L2 in HLT activity-state and L2 has a pending
deliverable interrupt in vmcs12->guest_intr_status.RVI, then the vCPU
should be waken from the HLT state and injected with the interrupt.
In addition, if while the vCPU is blocked (while it is in guest-mode),
it receives a nested posted-interrupt, then the vCPU should also be
waken and injected with the posted interrupt.
To handle these cases, this patch enhances kvm_vcpu_has_events() to also
check if there is a pending interrupt in L2 virtual APICv provided by
L1. That is, it evaluates if there is a pending virtual interrupt for L2
by checking RVI[7:4] > VPPR[7:4] as specified in Intel SDM 29.2.1
Evaluation of Pending Interrupts.
Note that this also handles the case of nested posted-interrupt by the
fact RVI is updated in vmx_complete_nested_posted_interrupt() which is
called from kvm_vcpu_check_block() -> kvm_arch_vcpu_runnable() ->
kvm_vcpu_running() -> vmx_check_nested_events() ->
vmx_complete_nested_posted_interrupt().
Reviewed-by: Nikita Leshenko <nikita.leshchenko@oracle.com>
Reviewed-by: Darren Kenny <darren.kenny@oracle.com>
Signed-off-by: Liran Alon <liran.alon@oracle.com>
These structures are going to be used from KVM code so let's make
their names reflect their Hyper-V origin.
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Reviewed-by: Roman Kagan <rkagan@virtuozzo.com>
Acked-by: K. Y. Srinivasan <kys@microsoft.com>
A VMX preemption timer value of '0' is guaranteed to cause a VMExit
prior to the CPU executing any instructions in the guest. Use the
preemption timer (if it's supported) to trigger immediate VMExit
in place of the current method of sending a self-IPI. This ensures
that pending VMExit injection to L1 occurs prior to executing any
instructions in the guest (regardless of nesting level).
When deferring VMExit injection, KVM generates an immediate VMExit
from the (possibly nested) guest by sending itself an IPI. Because
hardware interrupts are blocked prior to VMEnter and are unblocked
(in hardware) after VMEnter, this results in taking a VMExit(INTR)
before any guest instruction is executed. But, as this approach
relies on the IPI being received before VMEnter executes, it only
works as intended when KVM is running as L0. Because there are no
architectural guarantees regarding when IPIs are delivered, when
running nested the INTR may "arrive" long after L2 is running e.g.
L0 KVM doesn't force an immediate switch to L1 to deliver an INTR.
For the most part, this unintended delay is not an issue since the
events being injected to L1 also do not have architectural guarantees
regarding their timing. The notable exception is the VMX preemption
timer[1], which is architecturally guaranteed to cause a VMExit prior
to executing any instructions in the guest if the timer value is '0'
at VMEnter. Specifically, the delay in injecting the VMExit causes
the preemption timer KVM unit test to fail when run in a nested guest.
Note: this approach is viable even on CPUs with a broken preemption
timer, as broken in this context only means the timer counts at the
wrong rate. There are no known errata affecting timer value of '0'.
[1] I/O SMIs also have guarantees on when they arrive, but I have
no idea if/how those are emulated in KVM.
Signed-off-by: Sean Christopherson <sean.j.christopherson@intel.com>
[Use a hook for SVM instead of leaving the default in x86.c - Paolo]
When VMX is used with flexpriority disabled (because of no support or
if disabled with module parameter) MMIO interface to lAPIC is still
available in x2APIC mode while it shouldn't be (kvm-unit-tests):
PASS: apic_disable: Local apic enabled in x2APIC mode
PASS: apic_disable: CPUID.1H:EDX.APIC[bit 9] is set
FAIL: apic_disable: *0xfee00030: 50014
The issue appears because we basically do nothing while switching to
x2APIC mode when APIC access page is not used. apic_mmio_{read,write}
only check if lAPIC is disabled before proceeding to actual write.
When APIC access is virtualized we correctly manipulate with VMX controls
in vmx_set_virtual_apic_mode() and we don't get vmexits from memory writes
in x2APIC mode so there's no issue.
Disabling MMIO interface seems to be easy. The question is: what do we
do with these reads and writes? If we add apic_x2apic_mode() check to
apic_mmio_in_range() and return -EOPNOTSUPP these reads and writes will
go to userspace. When lAPIC is in kernel, Qemu uses this interface to
inject MSIs only (see kvm_apic_mem_write() in hw/i386/kvm/apic.c). This
somehow works with disabled lAPIC but when we're in xAPIC mode we will
get a real injected MSI from every write to lAPIC. Not good.
The simplest solution seems to be to just ignore writes to the region
and return ~0 for all reads when we're in x2APIC mode. This is what this
patch does. However, this approach is inconsistent with what currently
happens when flexpriority is enabled: we allocate APIC access page and
create KVM memory region so in x2APIC modes all reads and writes go to
this pre-allocated page which is, btw, the same for all vCPUs.
kvmclock defines few static variables which are shared with the
hypervisor during the kvmclock initialization.
When SEV is active, memory is encrypted with a guest-specific key, and
if the guest OS wants to share the memory region with the hypervisor
then it must clear the C-bit before sharing it.
Currently, we use kernel_physical_mapping_init() to split large pages
before clearing the C-bit on shared pages. But it fails when called from
the kvmclock initialization (mainly because the memblock allocator is
not ready that early during boot).
Add a __bss_decrypted section attribute which can be used when defining
such shared variable. The so-defined variables will be placed in the
.bss..decrypted section. This section will be mapped with C=0 early
during boot.
The .bss..decrypted section has a big chunk of memory that may be unused
when memory encryption is not active, free it when memory encryption is
not active.
Signed-off-by: Brijesh Singh <brijesh.singh@amd.com>
Cc: Sean Christopherson <sean.j.christopherson@intel.com>
Cc: Radim Krčmář<rkrcmar@redhat.com>
Cc: kvm@vger.kernel.org
Link: https://lkml.kernel.org/r/1536932759-12905-2-git-send-email-brijesh.singh@amd.com
This reverts commit 1f40a46cf47c12d93a5ad9dccd82bd36ff8f956a.
It turned out that this patch is not sufficient to enable PTI on 32 bit
systems with legacy 2-level page-tables. In this paging mode the huge-page
PTEs are in the top-level page-table directory, where also the mirroring to
the user-space page-table happens. So every huge PTE exits twice, in the
kernel and in the user page-table.
That means that accessed/dirty bits need to be fetched from two PTEs in
this mode to be safe, but this is not trivial to implement because it needs
changes to generic code just for the sake of enabling PTI with 32-bit
legacy paging. As all systems that need PTI should support PAE anyway,
remove support for PTI when 32-bit legacy paging is used.
Fixes: 7757d607c6b3 ('x86/pti: Allow CONFIG_PAGE_TABLE_ISOLATION for x86_32')
Reported-by: Meelis Roos <mroos@linux.ee>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
Cc: hpa@zytor.com
Link: https://lkml.kernel.org/r/1536922754-31379-1-git-send-email-joro@8bytes.org
Pull x86 fixes from Thomas Gleixner:
- Prevent multiplication result truncation on 32bit. Introduced with
the early timestamp reworrk.
- Ensure microcode revision storage to be consistent under all
circumstances
- Prevent write tearing of PTEs
- Prevent confusion of user and kernel reegisters when dumping fatal
signals verbosely
- Make an error return value in a failure path of the vector
allocation negative. Returning EINVAL might the caller assume
success and causes further wreckage.
- A trivial kernel doc warning fix"
x86/mm: Use WRITE_ONCE() when setting PTEs
x86/apic/vector: Make error return value negative
x86/process: Don't mix user/kernel regs in 64bit __show_regs()
x86/tsc: Prevent result truncation on 32bit
x86: Fix kernel-doc atomic.h warnings
x86/microcode: Update the new microcode revision unconditionally
x86/microcode: Make sure boot_cpu_data.microcode is up-to-date
When page-table entries are set, the compiler might optimize their
assignment by using multiple instructions to set the PTE. This might
turn into a security hazard if the user somehow manages to use the
interim PTE. L1TF does not make our lives easier, making even an interim
non-present PTE a security hazard.
Using WRITE_ONCE() to set PTEs and friends should prevent this potential
security hazard.
I skimmed the differences in the binary with and without this patch. The
differences are (obviously) greater when CONFIG_PARAVIRT=n as more
code optimizations are possible. For better and worse, the impact on the
binary with this patch is pretty small. Skimming the code did not cause
anything to jump out as a security hazard, but it seems that at least
move_soft_dirty_pte() caused set_pte_at() to use multiple writes.
Signed-off-by: Nadav Amit <namit@vmware.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: Michal Hocko <mhocko@suse.com>
Link: https://lkml.kernel.org/r/20180902181451.80520-1-namit@vmware.com
Dan Carpenter reported that the untrusted data returns from kvm_register_read()
results in the following static checker warning:
arch/x86/kvm/lapic.c:576 kvm_pv_send_ipi()
error: buffer underflow 'map->phys_map' 's32min-s32max'
KVM guest can easily trigger this by executing the following assembly sequence
in Ring0:
mov $10, %rax
mov $0xFFFFFFFF, %rbx
mov $0xFFFFFFFF, %rdx
mov $0, %rsi
vmcall
As this will cause KVM to execute the following code-path:
vmx_handle_exit() -> handle_vmcall() -> kvm_emulate_hypercall() -> kvm_pv_send_ipi()
which will reach out-of-bounds access.
This patch fixes it by adding a check to kvm_pv_send_ipi() against map->max_apic_id,
ignoring destinations that are not present and delivering the rest. We also check
whether or not map->phys_map[min + i] is NULL since the max_apic_id is set to the
max apic id, some phys_map maybe NULL when apic id is sparse, especially kvm
unconditionally set max_apic_id to 255 to reserve enough space for any xAPIC ID.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: Liran Alon <liran.alon@oracle.com>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Wanpeng Li <wanpengli@tencent.com>
[Add second "if (min > map->max_apic_id)" to complete the fix. -Radim]
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm
Fixes for KVM/ARM for Linux v4.19 v2:
- Fix a VFP corruption in 32-bit guest
- Add missing cache invalidation for CoW pages
- Two small cleanups
git://git.kernel.org/pub/scm/linux/kernel/git/kvms390/linux
KVM: s390: Fixes for 4.19
- Fallout from the hugetlbfs support: pfmf interpretion and locking
- VSIE: fix keywrapping for nested guests
kvm_unmap_hva is long gone, and we only have kvm_unmap_hva_range to
deal with. Drop the now obsolete code.
Fixes: fb1522e099f0 ("KVM: update to new mmu_notifier semantic v2")
Cc: James Hogan <jhogan@kernel.org>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Signed-off-by: Christoffer Dall <christoffer.dall@arm.com>
When the kernel.print-fatal-signals sysctl has been enabled, a simple
userspace crash will cause the kernel to write a crash dump that contains,
among other things, the kernel gsbase into dmesg.
As suggested by Andy, limit output to pt_regs, FS_BASE and KERNEL_GS_BASE
in this case.
This also moves the bitness-specific logic from show_regs() into
process_{32,64}.c.
Fixes: 45807a1df9f5 ("vdso: print fatal signals")
Signed-off-by: Jann Horn <jannh@google.com>
Cc: Borislav Petkov <bpetkov@suse.de>
Link: https://lkml.kernel.org/r/20180831194151.123586-1-jannh@google.com
Fix kernel-doc warnings in arch/x86/include/asm/atomic.h that are caused by
having a #define macro between the kernel-doc notation and the function
name. Fixed by moving the #define macro to after the function
implementation.
Make the same change for atomic64_{32,64}.h for consistency even though
there were no kernel-doc warnings found in these header files, but there
would be if they were used in generation of documentation.
Fixes these kernel-doc warnings:
../arch/x86/include/asm/atomic.h:84: warning: Excess function parameter 'i' description in 'arch_atomic_sub_and_test'
../arch/x86/include/asm/atomic.h:84: warning: Excess function parameter 'v' description in 'arch_atomic_sub_and_test'
../arch/x86/include/asm/atomic.h:96: warning: Excess function parameter 'v' description in 'arch_atomic_inc'
../arch/x86/include/asm/atomic.h:109: warning: Excess function parameter 'v' description in 'arch_atomic_dec'
../arch/x86/include/asm/atomic.h:124: warning: Excess function parameter 'v' description in 'arch_atomic_dec_and_test'
../arch/x86/include/asm/atomic.h:138: warning: Excess function parameter 'v' description in 'arch_atomic_inc_and_test'
../arch/x86/include/asm/atomic.h:153: warning: Excess function parameter 'i' description in 'arch_atomic_add_negative'
../arch/x86/include/asm/atomic.h:153: warning: Excess function parameter 'v' description in 'arch_atomic_add_negative'
Fixes: 18cc1814d4e7 ("atomics/treewide: Make test ops optional")
Cc: Mark Rutland <mark.rutland@arm.com>
Link: https://lkml.kernel.org/r/0a1e678d-c8c5-b32c-2640-ed4e94d399d2@infradead.org
"Speculation:
- Make the microcode check more robust
- Make the L1TF memory limit depend on the internal cache physical
address space and not on the CPUID advertised physical address
space, which might be significantly smaller. This avoids disabling
L1TF on machines which utilize the full physical address space.
- Fix the GDT mapping for EFI calls on 32bit PTI
- Fix the MCE nospec implementation to prevent #GP
Fixes and robustness:
- Use the proper operand order for LSL in the VDSO
- Prevent NMI uaccess race against CR3 switching
- Add a lockdep check to verify that text_mutex is held in
text_poke() functions
- Repair the fallout of giving native_restore_fl() a prototype
- Prevent kernel memory dumps based on usermode RIP
- Wipe KASAN shadow stack before rewinding the stack to prevent false
positives
- Move the AMS GOTO enforcement to the actual build stage to allow
user API header extraction without a compiler
- Fix a section mismatch introduced by the on demand VDSO mapping
change
Miscellaneous:
- Trivial typo, GCC quirk removal and CC_SET/OUT() cleanups"
x86/pti: Fix section mismatch warning/error
x86/vdso: Fix lsl operand order
x86/mce: Fix set_mce_nospec() to avoid #GP fault
x86/efi: Load fixmap GDT in efi_call_phys_epilog()
x86/nmi: Fix NMI uaccess race against CR3 switching
x86: Allow generating user-space headers without a compiler
x86/dumpstack: Don't dump kernel memory based on usermode RIP
x86/asm: Use CC_SET()/CC_OUT() in __gen_sigismember()
x86/alternatives: Lockdep-enforce text_mutex in text_poke*()
x86/entry/64: Wipe KASAN stack shadow before rewind_stack_do_exit()
x86/irqflags: Mark native_restore_fl extern inline
x86/build: Remove jump label quirk for GCC older than 4.5.2
x86/Kconfig: Fix trivial typo
x86/speculation/l1tf: Increase l1tf memory limit for Nehalem+
x86/spectre: Add missing family 6 check to microcode check
In the __getcpu function, lsl is using the wrong target and destination
registers. Luckily, the compiler tends to choose %eax for both variables,
so it has been working so far.
Fixes: a582c540ac1b ("x86/vdso: Use RDPID in preference to LSL when available")
Signed-off-by: Samuel Neves <sneves@dei.uc.pt>
Acked-by: Andy Lutomirski <luto@kernel.org>
Link: https://lkml.kernel.org/r/20180901201452.27828-1-sneves@dei.uc.pt
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen fixes from Juergen Gross:
- minor cleanup avoiding a warning when building with new gcc
- a patch to add a new sysfs node for Xen frontend/backend drivers to
make it easier to obtain the state of a pv device
- two fixes for 32-bit pv-guests to avoid intermediate L1TF vulnerable
PTEs
* tag 'for-linus-4.19b-rc2-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
x86/xen: remove redundant variable save_pud
xen: export device state to sysfs
x86/pae: use 64 bit atomic xchg function in native_ptep_get_and_clear
x86/xen: don't write ptes directly in 32-bit PV guests
A NMI can hit in the middle of context switching or in the middle of
switch_mm_irqs_off(). In either case, CR3 might not match current->mm,
which could cause copy_from_user_nmi() and friends to read the wrong
memory.
Fix it by adding a new nmi_uaccess_okay() helper and checking it in
copy_from_user_nmi() and in __copy_from_user_nmi()'s callers.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Reviewed-by: Rik van Riel <riel@surriel.com>
Cc: Nadav Amit <nadav.amit@gmail.com>
Cc: Jann Horn <jannh@google.com>
Link: https://lkml.kernel.org/r/dd956eba16646fd0b15c3c0741269dfd84452dac.1535557289.git.luto@kernel.org
show_opcodes() is used both for dumping kernel instructions and for dumping
user instructions. If userspace causes #PF by jumping to a kernel address,
show_opcodes() can be reached with regs->ip controlled by the user,
pointing to kernel code. Make sure that userspace can't trick us into
dumping kernel memory into dmesg.
Fixes: 7cccf0725cf7 ("x86/dumpstack: Add a show_ip() function")
Reviewed-by: Borislav Petkov <bp@suse.de>
Cc: security@kernel.org
Link: https://lkml.kernel.org/r/20180828154901.112726-1-jannh@google.com
