Pull x86 timer updates from Thomas Gleixner:
"These updates are related to TSC handling:
- Support platforms which have synchronized TSCs but the boot CPU has
a non zero TSC_ADJUST value, which is considered a firmware bug on
normal systems.
This applies to HPE/SGI UV platforms where the platform firmware
uses TSC_ADJUST to ensure TSC synchronization across a huge number
of sockets, but due to power on timings the boot CPU cannot be
guaranteed to have a zero TSC_ADJUST register value.
- Fix the ordering of udelay calibration and kvmclock_init()
- Cleanup the udelay and calibration code"
* 'x86-timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/tsc: Mark cyc2ns_init() and detect_art() __init
x86/platform/UV: Mark tsc_check_sync as an init function
x86/tsc: Make CONFIG_X86_TSC=n build work again
x86/platform/UV: Add check of TSC state set by UV BIOS
x86/tsc: Provide a means to disable TSC ART
x86/tsc: Drastically reduce the number of firmware bug warnings
x86/tsc: Skip TSC test and error messages if already unstable
x86/tsc: Add option that TSC on Socket 0 being non-zero is valid
x86/timers: Move simple_udelay_calibration() past kvmclock_init()
x86/timers: Make recalibrate_cpu_khz() void
x86/timers: Move the simple udelay calibration to tsc.h
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
recalibrate_cpu_khz() is called from powernow K7 and Pentium 4/Xeon
CPU freq driver. It recalibrates cpu frequency in case of SMP = n
and doesn't need to return anything.
Mark it void, also remove the #else branch.
Signed-off-by: Dou Liyang <douly.fnst@cn.fujitsu.com>
Link: https://lkml.kernel.org/r/1500003247-17368-2-git-send-email-douly.fnst@cn.fujitsu.com
Replace the custom multi-value scheme with the more regular
seqcount_latch() scheme. Along with scrapping a lot of lines, the latch
scheme is better documented and used in more places.
The immediate benefit however is not being limited on the update side.
The current code has a limit where the writers block which is hit by
future changes.
People reported that commit:
5680d8094ffa ("sched/clock: Provide better clock continuity")
broke "perf test tsc".
That commit added another offset to the reported clock value; so
take that into account when computing the provided offset values.
Reported-by: Adrian Hunter <adrian.hunter@intel.com>
Reported-by: Arnaldo Carvalho de Melo <acme@kernel.org>
Tested-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Fixes: 5680d8094ffa ("sched/clock: Provide better clock continuity")
Pull x86 cleanups from Ingo Molnar:
"Misc cleanups"
* 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, cpu, amd: Fix a shadowed variable situation
um, x86: Fix vDSO build
x86: Delete non-required instances of include <linux/init.h>
x86, realmode: Pointer walk cleanups, pull out invariant use of __pa()
x86/traps: Clean up error exception handler definitions
Use a ring-buffer like multi-version object structure which allows
always having a coherent object; we use this to avoid having to
disable IRQs while reading sched_clock() and avoids a problem when
getting an NMI while changing the cyc2ns data.
MAINLINE PRE POST
sched_clock_stable: 1 1 1
(cold) sched_clock: 329841 331312 257223
(cold) local_clock: 301773 310296 309889
(warm) sched_clock: 38375 38247 25280
(warm) local_clock: 100371 102713 85268
(warm) rdtsc: 27340 27289 24247
sched_clock_stable: 0 0 0
(cold) sched_clock: 382634 372706 301224
(cold) local_clock: 396890 399275 399870
(warm) sched_clock: 38194 38124 25630
(warm) local_clock: 143452 148698 129629
(warm) rdtsc: 27345 27365 24307
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/n/tip-s567in1e5ekq2nlyhn8f987r@git.kernel.org
There are no __cycles_2_ns() users outside of arch/x86/kernel/tsc.c,
so move it there.
There are no cycles_2_ns() users.
Link: http://lkml.kernel.org/n/tip-01lslnavfgo3kmbo4532zlcj@git.kernel.org
Use mul_u64_u32_shr() so that x86_64 can use a single 64x64->128 mul.
Before:
0000000000000560 <native_sched_clock>:
560: 44 8b 1d 00 00 00 00 mov 0x0(%rip),%r11d # 567 <native_sched_clock+0x7>
567: 55 push %rbp
568: 48 89 e5 mov %rsp,%rbp
56b: 45 85 db test %r11d,%r11d
56e: 75 4f jne 5bf <native_sched_clock+0x5f>
570: 0f 31 rdtsc
572: 89 c0 mov %eax,%eax
574: 48 c1 e2 20 shl $0x20,%rdx
578: 48 c7 c1 00 00 00 00 mov $0x0,%rcx
57f: 48 09 c2 or %rax,%rdx
582: 48 c7 c7 00 00 00 00 mov $0x0,%rdi
589: 65 8b 04 25 00 00 00 mov %gs:0x0,%eax
590: 00
591: 48 98 cltq
593: 48 8b 34 c5 00 00 00 mov 0x0(,%rax,8),%rsi
59a: 00
59b: 48 89 d0 mov %rdx,%rax
59e: 81 e2 ff 03 00 00 and $0x3ff,%edx
5a4: 48 c1 e8 0a shr $0xa,%rax
5a8: 48 0f af 14 0e imul (%rsi,%rcx,1),%rdx
5ad: 48 0f af 04 0e imul (%rsi,%rcx,1),%rax
5b2: 5d pop %rbp
5b3: 48 03 04 3e add (%rsi,%rdi,1),%rax
5b7: 48 c1 ea 0a shr $0xa,%rdx
5bb: 48 01 d0 add %rdx,%rax
5be: c3 retq
After:
0000000000000550 <native_sched_clock>:
550: 8b 3d 00 00 00 00 mov 0x0(%rip),%edi # 556 <native_sched_clock+0x6>
556: 55 push %rbp
557: 48 89 e5 mov %rsp,%rbp
55a: 48 83 e4 f0 and $0xfffffffffffffff0,%rsp
55e: 85 ff test %edi,%edi
560: 75 2c jne 58e <native_sched_clock+0x3e>
562: 0f 31 rdtsc
564: 89 c0 mov %eax,%eax
566: 48 c1 e2 20 shl $0x20,%rdx
56a: 48 09 c2 or %rax,%rdx
56d: 65 48 8b 04 25 00 00 mov %gs:0x0,%rax
574: 00 00
576: 89 c0 mov %eax,%eax
578: 48 f7 e2 mul %rdx
57b: 65 48 8b 0c 25 00 00 mov %gs:0x0,%rcx
582: 00 00
584: c9 leaveq
585: 48 0f ac d0 0a shrd $0xa,%rdx,%rax
58a: 48 01 c8 add %rcx,%rax
58d: c3 retq
MAINLINE POST
Link: http://lkml.kernel.org/n/tip-piu203ses5y1g36bnyw2n16x@git.kernel.org
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
[ hpa: undid incorrect removal from arch/x86/kernel/head_32.S ]
Link: http://lkml.kernel.org/r/1389054026-12947-1-git-send-email-paul.gortmaker@windriver.com
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
When a machine boots up, the TSC generally gets reset. However,
when kexec is used to boot into a kernel, the TSC value would be
carried over from the previous kernel. The computation of
cycns_offset in set_cyc2ns_scale is prone to an overflow, if the
machine has been up more than 208 days prior to the kexec. The
overflow happens when we multiply *scale, even though there is
enough room to store the final answer.
We fix this issue by decomposing tsc_now into the quotient and
remainder of division by CYC2NS_SCALE_FACTOR and then performing
the multiplication separately on the two components.
Refactor code to share the calculation with the previous
fix in __cycles_2_ns().
Signed-off-by: Salman Qazi <sqazi@google.com>
Acked-by: John Stultz <john.stultz@linaro.org>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Paul Turner <pjt@google.com>
Cc: john stultz <johnstul@us.ibm.com>
Link: http://lkml.kernel.org/r/20120310004027.19291.88460.stgit@dungbeetle.mtv.corp.google.com
(Added the missing signed-off-by line)
In hundreds of days, the __cycles_2_ns calculation in sched_clock
has an overflow. cyc * per_cpu(cyc2ns, cpu) exceeds 64 bits, causing
the final value to become zero. We can solve this without losing
any precision.
We can decompose TSC into quotient and remainder of division by the
scale factor, and then use this to convert TSC into nanoseconds.
Acked-by: John Stultz <johnstul@us.ibm.com>
Reviewed-by: Paul Turner <pjt@google.com>
Cc: stable@kernel.org
Link: http://lkml.kernel.org/r/20111115221121.7262.88871.stgit@dungbeetle.mtv.corp.google.com
Now that the bulk of the old nmi_watchdog is gone, remove all
the stub variables and hooks associated with it.
This touches lots of files mainly because of how the io_apic
nmi_watchdog was implemented. Now that the io_apic nmi_watchdog
is forever gone, remove all its fingers.
Most of this code was not being exercised by virtue of
nmi_watchdog != NMI_IO_APIC, so there shouldn't be anything to
risky here.
Signed-off-by: Don Zickus <dzickus@redhat.com>
Cc: fweisbec@gmail.com
Cc: gorcunov@openvz.org
LKML-Reference: <1289578944-28564-3-git-send-email-dzickus@redhat.com>
TSC calibration is modified by the vmware hypervisor and paravirt by
separate means. Moorestown wants to add its own calibration routine as
well. So make calibrate_tsc a proper x86_init_ops function and
override it by paravirt or by the early setup of the vmware
hypervisor.
Let the compiler optimize the timer_ack magic away in the 32bit timer
interrupt and put the same code into time_64.c. It's optimized out for
CONFIG_X86_IO_APIC on 32bit and for 64bit because timer_ack is const 0
in both cases.
The timer init code is convoluted with several quirks and the paravirt
timer chooser. Figuring out which code path is actually taken is not
for the faint hearted.
Move the numaq TSC quirk to tsc_pre_init x86_init_ops function and
replace the paravirt time chooser and the remaining x86 quirk with a
simple x86_init_ops function.
For freqency dependent TSCs we only scale the cycles, we do not account
for the discrepancy in absolute value.
Our current formula is: time = cycles * mult
(where mult is a function of the cpu-speed on variable tsc machines)
Suppose our current cycle count is 10, and we have a multiplier of 5,
then our time value would end up being 50.
Now cpufreq comes along and changes the multiplier to say 3 or 7,
which would result in our time being resp. 30 or 70.
That means that we can observe random jumps in the time value due to
frequency changes in both fwd and bwd direction.
So what this patch does is change the formula to:
time = cycles * frequency + offset
And we calculate offset so that time_before == time_after, thereby
ridding us of these jumps in time.
[ Impact: fix/reduce sched_clock() jumps across frequency changing events ]
LKML-Reference: <new-submission>
Chucked-on-by: Thomas Gleixner <tglx@linutronix.de>
Impact: cleanup
Make x86_quirks support more transparent. The highlevel
methods are now named:
extern void x86_quirk_pre_intr_init(void);
extern void x86_quirk_intr_init(void);
extern void x86_quirk_trap_init(void);
extern void x86_quirk_pre_time_init(void);
extern void x86_quirk_time_init(void);
This makes it clear that if some platform extension has to
do something here that it is considered ... weird, and is
discouraged.
Also remove arch_hooks.h and move it into setup.h (and other
header files where appropriate).
Change header guards named "ASM_X86__*" to "_ASM_X86_*" since:
a. the double underscore is ugly and pointless.
b. no leading underscore violates namespace constraints.
