The EC in the OLPC XO-1 delivers GPE events to provide various
notifications. Add the basic code for GPE/EC event processing and
enable the ebook switch, which can be used as a wakeup source.
Signed-off-by: Daniel Drake <dsd@laptop.org>
Link: http://lkml.kernel.org/r/1309019658-1712-8-git-send-email-dsd@laptop.org
Acked-by: Andres Salomon <dilinger@queued.net>
Update the EC SCI masks with recent additions.
Add functions to query SCI events and set the wakeup mask, to be used by
followup patches.
Add functions to tweak an event mask used to select certain EC events as
a system wakeup source. Also add a function to determine if EC wakeup
functionality is available, as this depends on child drivers (different
for each laptop model) to configure the SCI interrupt.
Link: http://lkml.kernel.org/r/1309019658-1712-7-git-send-email-dsd@laptop.org
Add code needed for basic suspend/resume of the XO-1 laptop.
Based on earlier work by Jordan Crouse, Andres Salomon, and others.
This patch incorporates all earlier feedback from Thomas Gleixner. To
clarify a certain point (now more obvious in the code itself):
On resume, OpenFirmware returns execution to Linux in protected mode
with a kernel-compatible GDT already set up. The changes and
simplifications suggested have all been included.
Link: http://lkml.kernel.org/r/1309019658-1712-5-git-send-email-dsd@laptop.org
They were generated by 'codespell' and then manually reviewed.
Cc: trivial@kernel.org
LKML-Reference: <1300389856-1099-3-git-send-email-lucas.demarchi@profusion.mobi>
Drop the old geode_gpio crud, as well as the raw outl() calls; instead,
use the Linux GPIO API where possible, and the cs5535_gpio API in other
places.
Note that we don't actually clean up the driver properly yet (once loaded,
it always remains loaded). That'll come later..
This patch is necessary for building the driver.
Signed-off-by: Andres Salomon <dilinger@queued.net>
Cc: Greg KH <greg@kroah.com>
Add a software rfkill switch for the WLAN interface in the OLPC XO-1
laptop. It uses the OLPC embedded controller to cut/restore power to
the Marvell WLAN chip on the motherboard.
Replace the #ifdef'ed OLPC-specific init functions by a conditional
x86_init function. If the function returns 0 we leave pci_arch_init,
otherwise we continue.
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Andres Salomon <dilinger@collabora.co.uk>
LKML-Reference: <43F901BD926A4E43B106BF17856F0755A318CE89@orsmsx508.amr.corp.intel.com>
Signed-off-by: Jacob Pan <jacob.jun.pan@intel.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Previously, OLPC support for the mic extensions was only enabled in the
ALSA driver if CONFIG_OLPC and CONFIG_MGEODE_LX were both set. This was
because the old geode GPIO code was written in a manner that assumed
CONFIG_MGEODE_LX. With the new cs553x-gpio driver, this is no longer the
case; as such, we can drop the requirement on CONFIG_MGEODE_LX and instead
include a requirement on GPIOLIB.
We use the generic GPIO API rather than the cs553x-specific API.
Signed-off-by: Andres Salomon <dilinger@collabora.co.uk>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Jordan Crouse <jordan@cosmicpenguin.net>
Cc: David Brownell <david-b@pacbell.net>
Change header guards named "ASM_X86__*" to "_ASM_X86_*" since:
a. the double underscore is ugly and pointless.
b. no leading underscore violates namespace constraints.
