Huge amounts of help from Andy Lutomirski and Borislav Petkov to
produce this. Andy provided the inspiration to add classes to the
exception table with a clever bit-squeezing trick, Boris pointed
out how much cleaner it would all be if we just had a new field.
Linus Torvalds blessed the expansion with:
' I'd rather not be clever in order to save just a tiny amount of space
in the exception table, which isn't really criticial for anybody. '
The third field is another relative function pointer, this one to a
handler that executes the actions.
We start out with three handlers:
1: Legacy - just jumps the to fixup IP
2: Fault - provide the trap number in %ax to the fixup code
3: Cleaned up legacy for the uaccess error hack
Signed-off-by: Tony Luck <tony.luck@intel.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
Link: http://lkml.kernel.org/r/f6af78fcbd348cf4939875cfda9c19689b5e50b8.1455732970.git.tony.luck@intel.com
Pull it up into the header and kill duplicate versions.
Separately, both macros are identical:
35948b2bd3431aee7149e85cfe4becbc /tmp/a
35948b2bd3431aee7149e85cfe4becbc /tmp/b
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Link: http://lkml.kernel.org/r/1431538944-27724-3-git-send-email-bp@alien8.de
Introduce NOKPROBE_SYMBOL() macro which builds a kprobes
blacklist at kernel build time.
The usage of this macro is similar to EXPORT_SYMBOL(),
placed after the function definition:
NOKPROBE_SYMBOL(function);
Since this macro will inhibit inlining of static/inline
functions, this patch also introduces a nokprobe_inline macro
for static/inline functions. In this case, we must use
NOKPROBE_SYMBOL() for the inline function caller.
When CONFIG_KPROBES=y, the macro stores the given function
address in the "_kprobe_blacklist" section.
Since the data structures are not fully initialized by the
macro (because there is no "size" information), those
are re-initialized at boot time by using kallsyms.
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Link: http://lkml.kernel.org/r/20140417081705.26341.96719.stgit@ltc230.yrl.intra.hitachi.co.jp
Cc: Alok Kataria <akataria@vmware.com>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
Cc: Christopher Li <sparse@chrisli.org>
Cc: Chris Wright <chrisw@sous-sol.org>
Cc: Jan-Simon Möller <dl9pf@gmx.de>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: linux-doc@vger.kernel.org
Cc: linux-sparse@vger.kernel.org
Cc: virtualization@lists.linux-foundation.org
The __ASM_* macros (e.g. __ASM_DX) are used to return the proper
register name (e.g. edx for 32bit / rdx for 64bit). We want to use
this also in arch/x86/include/asm/uaccess.h / get_user() . For this
to work, we need a raw form as both gcc and clang choke on the
whitespace in a register asm() statement, and the __ASM_FORM macro
surrounds the argument with blanks. A new macro, __ASM_FORM_RAW was
added and we change __ASM_REG to use the new RAW form.
Signed-off-by: Jan-Simon Möller <dl9pf@gmx.de>
Link: http://lkml.kernel.org/r/1377803585-5913-2-git-send-email-dl9pf@gmx.de
Switch to using relative exception table entries on x86. On i386,
this has the advantage that the exception table entries don't need to
be relocated; on x86-64 this means the exception table entries take up
only half the space.
In either case, a 32-bit delta is sufficient, as the range of kernel
code addresses is limited.
Since part of the goal is to avoid needing to adjust the entries when
the kernel is relocated, the old trick of using addresses in the NULL
pointer range to indicate uaccess_err no longer works (and unlike RISC
architectures we can't use a flag bit); instead use an delta just
below +2G to indicate these special entries. The reach is still
limited to a single instruction.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Cc: David Daney <david.daney@cavium.com>
Link: http://lkml.kernel.org/r/CA%2B55aFyijf43qSu3N9nWHEBwaGbb7T2Oq9A=9EyR=Jtyqfq_cQ@mail.gmail.com
Add _ASM_EXTABLE_EX() to generate the special extable entries that are
associated with uaccess_err. This allows us to change the protocol
associated with these special entries.
Nothing should use them anymore; only _ASM_EXTABLE() should ever be
used.
Instead of using .section ... .previous, use .pushsection
... .popsection; this is (hopefully) a bit more robust, especially in
complex assembly code.
With the write lock path simply subtracting RW_LOCK_BIAS there
is, on large systems, the theoretical possibility of overflowing
the 32-bit value that was used so far (namely if 128 or more
CPUs manage to do the subtraction, but don't get to do the
inverse addition in the failure path quickly enough).
A first measure is to modify RW_LOCK_BIAS itself - with the new
value chosen, it is good for up to 2048 CPUs each allowed to
nest over 2048 times on the read path without causing an issue.
Quite possibly it would even be sufficient to adjust the bias a
little further, assuming that allowing for significantly less
nesting would suffice.
However, as the original value chosen allowed for even more
nesting levels, to support more than 2048 CPUs (possible
currently only for 64-bit kernels) the lock itself gets widened
to 64 bits.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Link: http://lkml.kernel.org/r/4E258E0D020000780004E3F0@nat28.tlf.novell.com
Rather than having two functionally identical implementations
for 32- and 64-bit configurations, extend the existing assembly
abstractions enough to fold the two rwlock implementations into
a shared one.
Link: http://lkml.kernel.org/r/4E258DD7020000780004E3EA@nat28.tlf.novell.com
We have had this convenient macro _ASM_EXTABLE() to generate exception
table entry in inline assembly. Make it also usable for pure
assembly.
Change header guards named "ASM_X86__*" to "_ASM_X86_*" since:
a. the double underscore is ugly and pointless.
b. no leading underscore violates namespace constraints.
