path: root/arch/x86/crypto
2013-06-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto fix from Herbert Xu: "This fixes an unaligned crash in XTS mode when using aseni_intel" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: aesni_intel - fix accessing of unaligned memory
2013-06-13crypto: aesni_intel - fix accessing of unaligned memoryJussi Kivilinna
The new XTS code for aesni_intel uses input buffers directly as memory operands for pxor instructions, which causes crash if those buffers are not aligned to 16 bytes. Patch changes XTS code to handle unaligned memory correctly, by loading memory with movdqu instead. Reported-by: Dave Jones <davej@redhat.com> Tested-by: Dave Jones <davej@redhat.com> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-05-31Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Peter Anvin: - Three EFI-related fixes - Two early memory initialization fixes - build fix for older binutils - fix for an eager FPU performance regression -- currently we don't allow the use of the FPU at interrupt time *at all* in eager mode, which is clearly wrong. * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Allow FPU to be used at interrupt time even with eagerfpu x86, crc32-pclmul: Fix build with older binutils x86-64, init: Fix a possible wraparound bug in switchover in head_64.S x86, range: fix missing merge during add range x86, efi: initial the local variable of DataSize to zero efivar: fix oops in efivar_update_sysfs_entries() caused by memory reuse efivarfs: Never return ENOENT from firmware again
2013-05-30x86, crc32-pclmul: Fix build with older binutilsJan Beulich
binutils prior to 2.18 (e.g. the ones found on SLE10) don't support assembling PEXTRD, so a macro based approach like the one for PCLMULQDQ in the same file should be used. This requires making the helper macros capable of recognizing 32-bit general purpose register operands. [ hpa: tagging for stable as it is a low risk build fix ] Signed-off-by: Jan Beulich <jbeulich@suse.com> Link: http://lkml.kernel.org/r/51A6142A02000078000D99D8@nat28.tlf.novell.com Cc: Alexander Boyko <alexander_boyko@xyratex.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Huang Ying <ying.huang@intel.com> Cc: <stable@vger.kernel.org> v3.9 Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-05-28crypto: sha256_ssse3 - fix stack corruption with SSSE3 and AVX implementationsJussi Kivilinna
The _XFER stack element size was set too small, 8 bytes, when it needs to be 16 bytes. As _XFER is the last stack element used by these implementations, the 16 byte stores with 'movdqa' corrupt the stack where the value of register %r12 is temporarily stored. As these implementations align the stack pointer to 16 bytes, this corruption did not happen every time. Patch corrects this issue. Reported-by: Julian Wollrath <jwollrath@web.de> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Tested-by: Julian Wollrath <jwollrath@web.de> Acked-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: camellia - add AVX2/AES-NI/x86_64 assembler implementation of ↵Jussi Kivilinna
camellia cipher Patch adds AVX2/AES-NI/x86-64 implementation of Camellia cipher, requiring 32 parallel blocks for input (512 bytes). Compared to AVX implementation, this version is extended to use the 256-bit wide YMM registers. For AES-NI instructions data is split to two 128-bit registers and merged afterwards. Even with this additional handling, performance should be higher compared to the AES-NI/AVX implementation. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: serpent - add AVX2/x86_64 assembler implementation of serpent cipherJussi Kivilinna
Patch adds AVX2/x86-64 implementation of Serpent cipher, requiring 16 parallel blocks for input (256 bytes). Implementation is based on the AVX implementation and extends to use the 256-bit wide YMM registers. Since serpent does not use table look-ups, this implementation should be close to two times faster than the AVX implementation. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: twofish - add AVX2/x86_64 assembler implementation of twofish cipherJussi Kivilinna
Patch adds AVX2/x86-64 implementation of Twofish cipher, requiring 16 parallel blocks for input (256 bytes). Table look-ups are performed using vpgatherdd instruction directly from vector registers and thus should be faster than earlier implementations. Implementation also uses 256-bit wide YMM registers, which should give additional speed up compared to the AVX implementation. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: blowfish - add AVX2/x86_64 implementation of blowfish cipherJussi Kivilinna
Patch adds AVX2/x86-64 implementation of Blowfish cipher, requiring 32 parallel blocks for input (256 bytes). Table look-ups are performed using vpgatherdd instruction directly from vector registers and thus should be faster than earlier implementations. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: aesni_intel - add more optimized XTS mode for x86-64Jussi Kivilinna
Add more optimized XTS code for aesni_intel in 64-bit mode, for smaller stack usage and boost for speed. tcrypt results, with Intel i5-2450M: 256-bit key enc dec 16B 0.98x 0.99x 64B 0.64x 0.63x 256B 1.29x 1.32x 1024B 1.54x 1.58x 8192B 1.57x 1.60x 512-bit key enc dec 16B 0.98x 0.99x 64B 0.60x 0.59x 256B 1.24x 1.25x 1024B 1.39x 1.42x 8192B 1.38x 1.42x I chose not to optimize smaller than block size of 256 bytes, since XTS is practically always used with data blocks of size 512 bytes. This is why performance is reduced in tcrypt for 64 byte long blocks. Cc: Huang Ying <ying.huang@intel.com> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: x86/camellia-aesni-avx - add more optimized XTS codeJussi Kivilinna
Add more optimized XTS code for camellia-aesni-avx, for smaller stack usage and small boost for speed. tcrypt results, with Intel i5-2450M: enc dec 16B 1.10x 1.01x 64B 0.82x 0.77x 256B 1.14x 1.10x 1024B 1.17x 1.16x 8192B 1.10x 1.11x Since XTS is practically always used with data blocks of size 512 bytes or more, I chose to not make use of camellia-2way for block sized smaller than 256 bytes. This causes slower result in tcrypt for 64 bytes. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: cast6-avx: use new optimized XTS codeJussi Kivilinna
Change cast6-avx to use the new XTS code, for smaller stack usage and small boost to performance. tcrypt results, with Intel i5-2450M: enc dec 16B 1.01x 1.01x 64B 1.01x 1.00x 256B 1.09x 1.02x 1024B 1.08x 1.06x 8192B 1.08x 1.07x Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: x86/twofish-avx - use optimized XTS codeJussi Kivilinna
Change twofish-avx to use the new XTS code, for smaller stack usage and small boost to performance. tcrypt results, with Intel i5-2450M: enc dec 16B 1.03x 1.02x 64B 0.91x 0.91x 256B 1.10x 1.09x 1024B 1.12x 1.11x 8192B 1.12x 1.11x Since XTS is practically always used with data blocks of size 512 bytes or more, I chose to not make use of twofish-3way for block sized smaller than 128 bytes. This causes slower result in tcrypt for 64 bytes. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: x86 - add more optimized XTS-mode for serpent-avxJussi Kivilinna
This patch adds AVX optimized XTS-mode helper functions/macros and converts serpent-avx to use the new facilities. Benefits are slightly improved speed and reduced stack usage as use of temporary IV-array is avoided. tcrypt results, with Intel i5-2450M: enc dec 16B 1.00x 1.00x 64B 1.00x 1.00x 256B 1.04x 1.06x 1024B 1.09x 1.09x 8192B 1.10x 1.09x Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: crc32-pclmul - Use gas macro for pclmulqdqSandy Wu
Occurs when CONFIG_CRYPTO_CRC32C_INTEL=y and CONFIG_CRYPTO_CRC32C_INTEL=y. Older versions of bintuils do not support the pclmulqdq instruction. The PCLMULQDQ gas macro is used instead. Signed-off-by: Sandy Wu <sandyw@twitter.com> Cc: stable@vger.kernel.org # 3.8+ Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: sha512 - Create module providing optimized SHA512 routines using ↵Tim Chen
SSSE3, AVX or AVX2 instructions. We added glue code and config options to create crypto module that uses SSE/AVX/AVX2 optimized SHA512 x86_64 assembly routines. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: sha512 - Optimized SHA512 x86_64 assembly routine using AVX2 RORX ↵Tim Chen
instruction. Provides SHA512 x86_64 assembly routine optimized with SSE, AVX and AVX2's RORX instructions. Speedup of 70% or more has been measured over the generic implementation. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: sha512 - Optimized SHA512 x86_64 assembly routine using AVX ↵Tim Chen
instructions. Provides SHA512 x86_64 assembly routine optimized with SSE and AVX instructions. Speedup of 60% or more has been measured over the generic implementation. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: sha512 - Optimized SHA512 x86_64 assembly routine using Supplemental ↵Tim Chen
SSE3 instructions. Provides SHA512 x86_64 assembly routine optimized with SSSE3 instructions. Speedup of 40% or more has been measured over the generic implementation. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: sha256 - Create module providing optimized SHA256 routines using ↵Tim Chen
SSSE3, AVX or AVX2 instructions. We added glue code and config options to create crypto module that uses SSE/AVX/AVX2 optimized SHA256 x86_64 assembly routines. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-03crypto: sha256 - Optimized sha256 x86_64 routine using AVX2's RORX instructionsTim Chen
Provides SHA256 x86_64 assembly routine optimized with SSE, AVX and AVX2's RORX instructions. Speedup of 70% or more has been measured over the generic implementation. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-03crypto: sha256 - Optimized sha256 x86_64 assembly routine with AVX instructions.Tim Chen
Provides SHA256 x86_64 assembly routine optimized with SSE and AVX instructions. Speedup of 60% or more has been measured over the generic implementation. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-03crypto: sha256 - Optimized sha256 x86_64 assembly routine using Supplemental ↵Tim Chen
SSE3 instructions. Provides SHA256 x86_64 assembly routine optimized with SSSE3 instructions. Speedup of 40% or more has been measured over the generic implementation. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-03crypto: x86 - build AVX block cipher implementations only if assembler ↵Jussi Kivilinna
supports AVX instructions These modules require AVX support in assembler, so add new check to Makefile for this. Other option would be to use CONFIG_AS_AVX inside source files, but that would result dummy/empty/no-fuctionality modules being created. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-03crypto: x86/crc32-pclmul - assembly clean-ups: use ENTRY/ENDPROCJussi Kivilinna
2013-03-10crypto: crc32c - Update the links to the white papers on CRC32C calculations ↵Tim Chen
with PCLMULQDQ instructions. Herbert, The following patch update the stale link to the CRC32C white paper that was referenced. Tim Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-02-26crypto: crc32c - Kill pointless CRYPTO_CRC32C_X86_64 optionHerbert Xu
This bool option can never be set to anything other than y. So let's just kill it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-02-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: "Here is the crypto update for 3.9: - Added accelerated implementation of crc32 using pclmulqdq. - Added test vector for fcrypt. - Added support for OMAP4/AM33XX cipher and hash. - Fixed loose crypto_user input checks. - Misc fixes" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (43 commits) crypto: user - ensure user supplied strings are nul-terminated crypto: user - fix empty string test in report API crypto: user - fix info leaks in report API crypto: caam - Added property fsl,sec-era in SEC4.0 device tree binding. crypto: use ERR_CAST crypto: atmel-aes - adjust duplicate test crypto: crc32-pclmul - Kill warning on x86-32 crypto: x86/twofish - assembler clean-ups: use ENTRY/ENDPROC, localize jump labels crypto: x86/sha1 - assembler clean-ups: use ENTRY/ENDPROC crypto: x86/serpent - use ENTRY/ENDPROC for assember functions and localize jump targets crypto: x86/salsa20 - assembler cleanup, use ENTRY/ENDPROC for assember functions and rename ECRYPT_* to salsa20_* crypto: x86/ghash - assembler clean-up: use ENDPROC at end of assember functions crypto: x86/crc32c - assembler clean-up: use ENTRY/ENDPROC crypto: cast6-avx: use ENTRY()/ENDPROC() for assembler functions crypto: cast5-avx: use ENTRY()/ENDPROC() for assembler functions and localize jump targets crypto: camellia-x86_64/aes-ni: use ENTRY()/ENDPROC() for assembler functions and localize jump targets crypto: blowfish-x86_64: use ENTRY()/ENDPROC() for assembler functions and localize jump targets crypto: aesni-intel - add ENDPROC statements for assembler functions crypto: x86/aes - assembler clean-ups: use ENTRY/ENDPROC, localize jump targets crypto: testmgr - add test vector for fcrypt ...
2013-01-20crypto: crc32-pclmul - Kill warning on x86-32Herbert Xu
This patch removes a gratuitous warning on x86-32: arch/x86/crypto/crc32-pclmul_asm.S:87:2: warning: #warning Using 32bit code support [-Wcpp] Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-01-20crypto: x86/twofish - assembler clean-ups: use ENTRY/ENDPROC, localize jump ↵Jussi Kivilinna
labels Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-01-20crypto: x86/sha1 - assembler clean-ups: use ENTRY/ENDPROCJussi Kivilinna
2013-01-20crypto: x86/serpent - use ENTRY/ENDPROC for assember functions and localize ↵Jussi Kivilinna
jump targets Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-01-20crypto: x86/salsa20 - assembler cleanup, use ENTRY/ENDPROC for assember ↵Jussi Kivilinna
functions and rename ECRYPT_* to salsa20_* Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-01-20crypto: x86/ghash - assembler clean-up: use ENDPROC at end of assember functionsJussi Kivilinna
Signed-off-by: Jussi Kivilinna <jussi.kivilinn@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-01-20crypto: x86/crc32c - assembler clean-up: use ENTRY/ENDPROCJussi Kivilinna
2013-01-20crypto: cast6-avx: use ENTRY()/ENDPROC() for assembler functionsJussi Kivilinna
2013-01-20crypto: cast5-avx: use ENTRY()/ENDPROC() for assembler functions and ↵Jussi Kivilinna
localize jump targets Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-01-20crypto: camellia-x86_64/aes-ni: use ENTRY()/ENDPROC() for assembler ↵Jussi Kivilinna
functions and localize jump targets Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-01-20crypto: blowfish-x86_64: use ENTRY()/ENDPROC() for assembler functions and ↵Jussi Kivilinna
2013-01-20crypto: aesni-intel - add ENDPROC statements for assembler functionsJussi Kivilinna
2013-01-20crypto: x86/aes - assembler clean-ups: use ENTRY/ENDPROC, localize jump targetsJussi Kivilinna
2013-01-20crypto: crc32 - add crc32 pclmulqdq implementation and wrappers for table ↵Alexander Boyko
implementation This patch adds crc32 algorithms to shash crypto api. One is wrapper to gerneric crc32_le function. Second is crc32 pclmulqdq implementation. It use hardware provided PCLMULQDQ instruction to accelerate the CRC32 disposal. This instruction present from Intel Westmere and AMD Bulldozer CPUs. For intel core i5 I got 450MB/s for table implementation and 2100MB/s for pclmulqdq implementation. Signed-off-by: Alexander Boyko <alexander_boyko@xyratex.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-01-08crypto: aesni-intel - remove rfc3686(ctr(aes)), utilize rfc3686 from ↵Jussi Kivilinna
ctr-module instead rfc3686 in CTR module is now able of using asynchronous ctr(aes) from aesni-intel, so rfc3686(ctr(aes)) in aesni-intel is no longer needed. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2012-12-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: - Added aesni/avx/x86_64 implementations for camellia. - Optimised AVX code for cast5/serpent/twofish/cast6. - Fixed vmac bug with unaligned input. - Allow compression algorithms in FIPS mode. - Optimised crc32c implementation for Intel. - Misc fixes. * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (32 commits) crypto: caam - Updated SEC-4.0 device tree binding for ERA information. crypto: testmgr - remove superfluous initializers for xts(aes) crypto: testmgr - allow compression algs in fips mode crypto: testmgr - add larger crc32c test vector to test FPU path in crc32c_intel crypto: testmgr - clean alg_test_null entries in alg_test_descs[] crypto: testmgr - remove fips_allowed flag from camellia-aesni null-tests crypto: cast5/cast6 - move lookup tables to shared module padata: use __this_cpu_read per-cpu helper crypto: s5p-sss - Fix compilation error crypto: picoxcell - Add terminating entry for platform_device_id table crypto: omap-aes - select BLKCIPHER2 crypto: camellia - add AES-NI/AVX/x86_64 assembler implementation of camellia cipher crypto: camellia-x86_64 - share common functions and move structures and function definitions to header file crypto: tcrypt - add async speed test for camellia cipher crypto: tegra-aes - fix error-valued pointer dereference crypto: tegra - fix missing unlock on error case crypto: cast5/avx - avoid using temporary stack buffers crypto: serpent/avx - avoid using temporary stack buffers crypto: twofish/avx - avoid using temporary stack buffers crypto: cast6/avx - avoid using temporary stack buffers ...
2012-12-06crypto: cast5/cast6 - move lookup tables to shared moduleJussi Kivilinna
CAST5 and CAST6 both use same lookup tables, which can be moved shared module 'cast_common'. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-11-09crypto: camellia - add AES-NI/AVX/x86_64 assembler implementation of ↵Jussi Kivilinna
camellia cipher This patch adds AES-NI/AVX/x86_64 assembler implementation of Camellia block cipher. Implementation process data in sixteen block chunks, which are byte-sliced and AES SubBytes is reused for Camellia s-box with help of pre- and post-filtering. Patch has been tested with tcrypt and automated filesystem tests. tcrypt test results: Intel Core i5-2450M: camellia-aesni-avx vs camellia-asm-x86_64-2way: 128bit key: (lrw:256bit) (xts:256bit) size ecb-enc ecb-dec cbc-enc cbc-dec ctr-enc ctr-dec lrw-enc lrw-dec xts-enc xts-dec 16B 0.98x 0.96x 0.99x 0.96x 0.96x 0.95x 0.95x 0.94x 0.97x 0.98x 64B 0.99x 0.98x 1.00x 0.98x 0.98x 0.99x 0.98x 0.93x 0.99x 0.98x 256B 2.28x 2.28x 1.01x 2.29x 2.25x 2.24x 1.96x 1.97x 1.91x 1.90x 1024B 2.57x 2.56x 1.00x 2.57x 2.51x 2.53x 2.19x 2.17x 2.19x 2.22x 8192B 2.49x 2.49x 1.00x 2.53x 2.48x 2.49x 2.17x 2.17x 2.22x 2.22x 256bit key: (lrw:384bit) (xts:512bit) size ecb-enc ecb-dec cbc-enc cbc-dec ctr-enc ctr-dec lrw-enc lrw-dec xts-enc xts-dec 16B 0.97x 0.98x 0.99x 0.97x 0.97x 0.96x 0.97x 0.98x 0.98x 0.99x 64B 1.00x 1.00x 1.01x 0.99x 0.98x 0.99x 0.99x 0.99x 0.99x 0.99x 256B 2.37x 2.37x 1.01x 2.39x 2.35x 2.33x 2.10x 2.11x 1.99x 2.02x 1024B 2.58x 2.60x 1.00x 2.58x 2.56x 2.56x 2.28x 2.29x 2.28x 2.29x 8192B 2.50x 2.52x 1.00x 2.56x 2.51x 2.51x 2.24x 2.25x 2.26x 2.29x Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-11-09crypto: camellia-x86_64 - share common functions and move structures and ↵Jussi Kivilinna
function definitions to header file Prepare camellia-x86_64 functions to be reused from AVX/AESNI implementation module. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-10-24crypto: cast5/avx - avoid using temporary stack buffersJussi Kivilinna
Introduce new assembler functions to avoid use temporary stack buffers in glue code. This also allows use of vector instructions for xoring output in CTR and CBC modes and construction of IVs for CTR mode. ECB mode sees ~0.5% decrease in speed because added one extra function call. CBC mode decryption and CTR mode benefit from vector operations and gain ~5%. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-10-24crypto: serpent/avx - avoid using temporary stack buffersJussi Kivilinna
Introduce new assembler functions to avoid use temporary stack buffers in glue code. This also allows use of vector instructions for xoring output in CTR and CBC modes and construction of IVs for CTR mode. ECB mode sees ~0.5% decrease in speed because added one extra function call. CBC mode decryption and CTR mode benefit from vector operations and gain ~3%. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-10-24crypto: twofish/avx - avoid using temporary stack buffersJussi Kivilinna
Introduce new assembler functions to avoid use temporary stack buffers in glue code. This also allows use of vector instructions for xoring output in CTR and CBC modes and construction of IVs for CTR mode. ECB mode sees ~0.2% decrease in speed because added one extra function call. CBC mode decryption and CTR mode benefit from vector operations and gain ~3%. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
