path: root/arch/x86/boot/boot.h
2017-05-20x86/boot: Fix BSS corruption/overwrite bug in early x86 kernel startupAshish Kalra
commit d594aa0277e541bb997aef0bc0a55172d8138340 upstream. The minimum size for a new stack (512 bytes) setup for arch/x86/boot components when the bootloader does not setup/provide a stack for the early boot components is not "enough". The setup code executing as part of early kernel startup code, uses the stack beyond 512 bytes and accidentally overwrites and corrupts part of the BSS section. This is exposed mostly in the early video setup code, where it was corrupting BSS variables like force_x, force_y, which in-turn affected kernel parameters such as screen_info (screen_info.orig_video_cols) and later caused an exception/panic in console_init(). Most recent boot loaders setup the stack for early boot components, so this stack overwriting into BSS section issue has not been exposed. Signed-off-by: Ashish Kalra <ashish@bluestacks.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20170419152015.10011-1-ashishkalra@Ashishs-MacBook-Pro.local Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-07-15Merge branch 'x86/asm' into x86/mm, to resolve conflictsIngo Molnar
Conflicts: tools/testing/selftests/x86/Makefile Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-07-13x86/mm: Disallow running with 32-bit PTEs to work around erratumDave Hansen
The Intel(R) Xeon Phi(TM) Processor x200 Family (codename: Knights Landing) has an erratum where a processor thread setting the Accessed or Dirty bits may not do so atomically against its checks for the Present bit. This may cause a thread (which is about to page fault) to set A and/or D, even though the Present bit had already been atomically cleared. These bits are truly "stray". In the case of the Dirty bit, the thread associated with the stray set was *not* allowed to write to the page. This means that we do not have to launder the bit(s); we can simply ignore them. If the PTE is used for storing a swap index or a NUMA migration index, the A bit could be misinterpreted as part of the swap type. The stray bits being set cause a software-cleared PTE to be interpreted as a swap entry. In some cases (like when the swap index ends up being for a non-existent swapfile), the kernel detects the stray value and WARN()s about it, but there is no guarantee that the kernel can always detect it. When we have 64-bit PTEs (64-bit mode or 32-bit PAE), we were able to move the swap PTE format around to avoid these troublesome bits. But, 32-bit non-PAE is tight on bits. So, disallow it from running on this hardware. I can't imagine anyone wanting to run 32-bit non-highmem kernels on this hardware, but disallowing them from running entirely is surely the safe thing to do. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave@sr71.net> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Luis R. Rodriguez <mcgrof@suse.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Toshi Kani <toshi.kani@hp.com> Cc: dave.hansen@intel.com Cc: linux-mm@kvack.org Cc: mhocko@suse.com Link: http://lkml.kernel.org/r/20160708001914.D0B50110@viggo.jf.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-06-08x86, asm, boot: Use CC_SET()/CC_OUT() in arch/x86/boot/boot.hH. Peter Anvin
Remove open-coded uses of set instructions to use CC_SET()/CC_OUT() in arch/x86/boot/boot.h. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/1465414726-197858-10-git-send-email-hpa@linux.intel.com Reviewed-by: Andy Lutomirski <luto@kernel.org> Reviewed-by: Borislav Petkov <bp@suse.de> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
2016-06-08x86, asm: use bool for bitops and other assembly outputsH. Peter Anvin
The gcc people have confirmed that using "bool" when combined with inline assembly always is treated as a byte-sized operand that can be assumed to be 0 or 1, which is exactly what the SET instruction emits. Change the output types and intermediate variables of as many operations as practical to "bool". Signed-off-by: H. Peter Anvin <hpa@zytor.com> Link: http://lkml.kernel.org/r/1465414726-197858-3-git-send-email-hpa@linux.intel.com Reviewed-by: Andy Lutomirski <luto@kernel.org> Reviewed-by: Borislav Petkov <bp@suse.de> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
2015-12-04x86/mm: Fix regression with huge pages on PAEKirill A. Shutemov
Recent PAT patchset has caused issue on 32-bit PAE machines: page:eea45000 count:0 mapcount:-128 mapping: (null) index:0x0 flags: 0x40000000() page dumped because: VM_BUG_ON_PAGE(page_mapcount(page) < 0) ------------[ cut here ]------------ kernel BUG at /home/build/linux-boris/mm/huge_memory.c:1485! invalid opcode: 0000 [#1] SMP [...] Call Trace: unmap_single_vma ? __wake_up unmap_vmas unmap_region do_munmap vm_munmap SyS_munmap do_fast_syscall_32 ? __do_page_fault sysenter_past_esp Code: ... EIP: [<c11bde80>] zap_huge_pmd+0x240/0x260 SS:ESP 0068:f6459d98 The problem is in pmd_pfn_mask() and pmd_flags_mask(). These helpers use PMD_PAGE_MASK to calculate resulting mask. PMD_PAGE_MASK is 'unsigned long', not 'unsigned long long' as phys_addr_t is on 32-bit PAE (ARCH_PHYS_ADDR_T_64BIT). As a result, the upper bits of resulting mask get truncated. pud_pfn_mask() and pud_flags_mask() aren't problematic since we don't have PUD page table level on 32-bit systems, but it's reasonable to keep them consistent with PMD counterpart. Introduce PHYSICAL_PMD_PAGE_MASK and PHYSICAL_PUD_PAGE_MASK in addition to existing PHYSICAL_PAGE_MASK and reworks helpers to use them. Reported-and-Tested-by: Boris Ostrovsky <boris.ostrovsky@oracle.com> Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> [ Fix -Woverflow warnings from the realmode code. ] Signed-off-by: Borislav Petkov <bp@suse.de> Reviewed-by: Toshi Kani <toshi.kani@hpe.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jürgen Gross <jgross@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: elliott@hpe.com Cc: konrad.wilk@oracle.com Cc: linux-mm <linux-mm@kvack.org> Fixes: f70abb0fc3da ("x86/asm: Fix pud/pmd interfaces to handle large PAT bit") Link: http://lkml.kernel.org/r/1448878233-11390-2-git-send-email-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-21x86/boot: Obsolete the MCA sys_desc_tablePaolo Pisati
The kernel does not support the MCA bus anymroe, so mark sys_desc_table as obsolete: remove any reference from the code together with the remaining of MCA logic. bloat-o-meter output: add/remove: 0/0 grow/shrink: 0/2 up/down: 0/-55 (-55) function old new delta i386_start_kernel 128 119 -9 setup_arch 1421 1375 -46 Signed-off-by: Paolo Pisati <p.pisati@gmail.com> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1437409430-8491-1-git-send-email-p.pisati@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-03-19x86, boot: Move memcmp() into string.h and string.cVivek Goyal
Try to treat memcmp() in same way as memcpy() and memset(). Provide a declaration in boot/string.h and by default user gets a memcmp() which maps to builtin function. Move optimized definition of memcmp() in boot/string.c. Now a user can do #undef memcmp and link against string.c to use optimzied memcmp(). It also simplifies boot/compressed/string.c where we had to redefine memcmp(). That extra definition is gone now. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Link: http://lkml.kernel.org/r/1395170800-11059-5-git-send-email-vgoyal@redhat.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-03-19x86, boot: Create a separate string.h file to provide standard string functionsVivek Goyal
Create a separate arch/x86/boot/string.h file to provide declaration of some of the common string functions. By default memcpy, memset and memcmp functions will default to gcc builtin functions. If code wants to use an optimized version of any of these functions, they need to #undef the respective macro and link against a local file providing definition of undefed function. For example, arch/x86/boot/* code links against copy.S to get memcpy() and memcmp() definitions. arch/86/boot/compressed/* links against compressed/string.c. There are quite a few places in arch/x86/ where these functions are used. Idea is to try to consilidate their declaration and possibly definitions so that it can be reused. I am planning to reuse boot/string.h in arch/x86/purgatory/ and use gcc builtin functions for memcpy, memset and memcmp. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Link: http://lkml.kernel.org/r/1395170800-11059-3-git-send-email-vgoyal@redhat.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-10-13x86, boot: Move CPU flags out of cpucheckKees Cook
Refactor the CPU flags handling out of the cpucheck routines so that they can be reused by the future ASLR routines (in order to detect CPU features like RDRAND and RDTSC). This reworks has_eflag() and has_fpu() to be used on both 32-bit and 64-bit, and refactors the calls to cpuid to make them PIC-safe on 32-bit. Signed-off-by: Kees Cook <keescook@chromium.org> Link: http://lkml.kernel.org/r/1381450698-28710-2-git-send-email-keescook@chromium.org Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-08-13x86, boot: Fix warning due to undeclared strlen()Fred Chen
Below is a patch that fixes sparse error "arch/x86/boot/string.c:119:8: warning: symbol 'strlen' was not declared." by declaring it in arch/x86/boot/boot.h. Signed-off-by: Fred Chen <fchen@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1376417580-11554-1-git-send-email-fchen@linux.vnet.ibm.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-01-29x86, boot: Pass cmd_line_ptr with unsigned long insteadYinghai Lu
boot/compressed/misc.c is used for bzImage in 64bit and 32bit, and cmd_line_ptr could point to buffer that is above 4g, cmd_line_ptr should be 64bit otherwise high 32bit will be capped out. So need to change data type to unsigned long, that will be 64bit get correct address of command line buffer. And it is still ok with 32bit bzImage, because unsigned long on 32bit kernel is still 32bit. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Link: http://lkml.kernel.org/r/1359058816-7615-19-git-send-email-yinghai@kernel.org Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-01-29x86, boot: Move checking of cmd_line_ptr out of common pathYinghai Lu
cmdline.c::__cmdline_find_option... are shared between 16-bit setup code and 32/64 bit decompressor code. for 32/64 only path via kexec, we should not check if ptr is less 1M. as those cmdline could be put above 1M, or even 4G. Move out accessible checking out of __cmdline_find_option() So decompressor in misc.c can parse cmdline correctly. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Link: http://lkml.kernel.org/r/1359058816-7615-18-git-send-email-yinghai@kernel.org Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2012-01-31x86, boot: Fix port argument to inl() functionHe Chunhui
"u32 port" in inl() should be "u16 port". [ hpa: it's a bug, but it doesn't produce incorrect code, so no need to put this into urgent or stable. ] Signed-off-by: He Chunhui <hchunhui@mail.ustc.edu.cn> Link: http://lkml.kernel.org/r/32892299.2931391328028508117.JavaMail.coremail@mailweb Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-08-02x86, setup: move isdigit.h to ctype.h, header files on top.H. Peter Anvin
It is a subset of <ctype.h> functionality, so name it ctype.h. Also, reorganize header files so #include statements are clustered near the top as they should be. Signed-off-by: H. Peter Anvin <hpa@zytor.com> LKML-Reference: <4C5752F2.8030206@kernel.org>
2010-08-02x86, setup: reorganize the early console setupYinghai Lu
Separate early_serial_console from tty.c This allows for reuse of early_serial_console.c/string.c/printf.c/cmdline.c in boot/compressed/. -v2: according to hpa, don't include string.c etc -v3: compressed/misc.c must have early_serial_base as static, so move it back to tty.c for setup code Signed-off-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <4C568D2B.205@kernel.org> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-07-12x86, setup: Early-boot serial I/O supportPekka Enberg
This patch adds serial I/O support to the real-mode setup (very early boot) printf(). It's useful for debugging boot code when running Linux under KVM, for example. The actual code was lifted from early printk. Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> LKML-Reference: <1278835617-11368-1-git-send-email-penberg@cs.helsinki.fi> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2009-04-09x86, setup: "glove box" BIOS calls -- infrastructureH. Peter Anvin
Impact: new interfaces (not yet used) For all the platforms out there, there is an infinite number of buggy BIOSes. This adds infrastructure to treat BIOS interrupts more like toxic waste and "glove box" them -- we switch out the register set, perform the BIOS interrupt, and then restore the previous state. LKML-Reference: <49DE7F79.4030106@zytor.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Rafael J. Wysocki <rjw@sisk.pl>
2009-02-23x86: remove the Voyager 32-bit subarchIngo Molnar
Impact: remove unused/broken code The Voyager subarch last built successfully on the v2.6.26 kernel and has been stale since then and does not build on the v2.6.27, v2.6.28 and v2.6.29-rc5 kernels. No actual users beyond the maintainer reported this breakage. Patches were sent and most of the fixes were accepted but the discussion around how to do a few remaining issues cleanly fizzled out with no resolution and the code remained broken. In the v2.6.30 x86 tree development cycle 32-bit subarch support has been reworked and removed - and the Voyager code, beyond the build problems already known, needs serious and significant changes and probably a rewrite to support it. CONFIG_X86_VOYAGER has been marked BROKEN then. The maintainer has been notified but no patches have been sent so far to fix it. While all other subarchs have been converted to the new scheme, voyager is still broken. We'd prefer to receive patches which clean up the current situation in a constructive way, but even in case of removal there is no obstacle to add that support back after the issues have been sorted out in a mutually acceptable fashion. So remove this inactive code for now. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-18x86: fix build warnings in real mode codeAndi Kleen
This recent patch commit c3965bd15118742d72b4bc1a290d37b3f081eb98 Author: Paul Jackson <pj@sgi.com> Date: Wed May 14 08:15:34 2008 -0700 x86 boot: proper use of ARRAY_SIZE instead of repeated E820MAX constant caused these new warnings during a normal build: In file included from linux-2.6/arch/x86/boot/memory.c:17: linux-2.6/include/linux/log2.h: In function '__ilog2_u32': linux-2.6/include/linux/log2.h:34: warning: implicit declaration of function 'fls' linux-2.6/include/linux/log2.h: In function '__ilog2_u64': linux-2.6/include/linux/log2.h:42: warning: implicit declaration of function 'fls64' linux-2.6/include/linux/log2.h: In function '__roundup_pow_of_two ': linux-2.6/include/linux/log2.h:63: warning: implicit declaration of function 'fls_long' I tried to fix them in log2.h, but it's difficult because the real mode environment is completely different from a normal kernel environment. Instead define an own ARRAY_SIZE macro in boot.h, similar to the other private macros there. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-14x86: cleanup for setup code crashes during IST probeH. Peter Anvin
Clean up the code for crashes during SpeedStep probing on older machines. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-13x86: fix setup code crashes on my old 486 boxJoerg Roedel
yesterday I tried to reactivate my old 486 box and wanted to install a current Linux with latest kernel on it. But it turned out that the latest kernel does not boot because the machine crashes early in the setup code. After some debugging it turned out that the problem is the query_ist() function. If this interrupt with that function is called the machine simply locks up. It looks like a BIOS bug. Looking for a workaround for this problem I wrote the attached patch. It checks for the CPUID instruction and if it is not implemented it does not call the speedstep BIOS function. As far as I know speedstep should be available since some Pentium earliest. Alan Cox observed that it's available since the Pentium II, so cpuid levels 4 and 5 can be excluded altogether. H. Peter Anvin cleaned up the code some more: > Right in concept, but I dislike the implementation (duplication of the > CPU detect code we already have). Could you try this patch and see if > it works for you? which, with a small modification to fix a build error with it the resulting kernel boots on my machine. Signed-off-by: Joerg Roedel <joro@8bytes.org> Signed-off-by: "H. Peter Anvin" <hpa@zytor.com> Cc: <stable@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19x86: remove pointless commentsWANG Cong
Remove old comments that include the old arch/i386 directory. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-17x86: move suspend wakeup code to CPavel Machek
Move wakeup code to .c, so that video mode setting code can be shared between boot and wakeup. Remove nasty assembly code in 64-bit case by re-using trampoline code. Stack setup was fixed to clear high 16bits of %esp, maybe that fixes some machines. .c code sharing and morse code was done H. Peter Anvin, Sam Ravnborg reviewed kbuild related stuff, and it seems okay to him. Rafael did some cleanups. [rjw: * Made the patch stop breaking compilation on x86-32 * Added arch/x86/kernel/acpi/sleep.h * Got rid of compiler warnings in arch/x86/kernel/acpi/sleep.c * Fixed 32-bit compilation on x86-64 systems * Added include/asm-x86/trampoline.h and fixed the non-SMP compilation on 64-bit x86 * Removed arch/x86/kernel/acpi/sleep_32.c which was not used * Fixed some breakage caused by the integration of smpboot.c done under us in the meantime] Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30x86 setup: add missing prototype; formatting fixH. Peter Anvin
Add prototype for cmdline_find_option_bool() missing from: x86 setup: early cmdline parser handle boolean options Also, fix up a minor formatting error in that patch. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86 setup: fix constraints in segment accessor functionsH. Peter Anvin
Fix the operand constraints for the segment accessor functions, {rd,wr}{fs,gs}*. In particular, the 8-bit functions used "r" constraints instead of "q" constraints. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-25x86 setup: sizeof() is unsigned, unbreak comparisonsH. Peter Anvin
We use signed values for limit checking since the values can go negative under certain circumstances. However, sizeof() is unsigned and forces the comparison to be unsigned, so move the comparison into the heap_free() macros so we can ensure it is a signed comparison. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2007-10-25x86 setup: handle boot loaders which set up the stack incorrectlyH. Peter Anvin
Apparently some specific versions of LILO enter the kernel with a stack pointer that doesn't match the rest of the segments. Make our best attempt at untangling the resulting mess. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2007-10-23x86: clean up setup.h and the boot codeH. Peter Anvin
Make <asm/setup.h> usable by the boot code. Clean up vestiges of the old command-line protocol from setup.h and head_32.S (it is still supported from the boot loader point of view, since it is converted to the new command-line protocol by the boot code.) Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-11i386: move bootThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
