path: root/arch/um
2006-09-27[PATCH] uml: fix allocation sizeJeff Dike
Fix an instance of ptr=alloc(sizeof(ptr)). Grepping showed no more instances of this pattern. Also fixed the formatting in the area. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] uml: fix sleep length bugJeff Dike
um_timer shouldn't add local_offset to the host time since get_time already did it. This threw off sleep when a settimeofday or equivalent had happened. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] uml: add an exportJeff Dike
Some modules need strnlen_user_skas. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] uml: file renamingJeff Dike
Move some foo_kern.c files to foo.c now that the old foo.c files are out of the way. Also cleaned up some whitespace and an emacs formatting comment. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] uml: thread creation tidyingJeff Dike
fork on UML has always somewhat subtle. The underlying cause has been the need to initialize a stack for the new process. The only portable way to initialize a new stack is to set it as the alternate signal stack and take a signal. The signal handler does whatever initialization is needed and jumps back to the original stack, where the fork processing is finished. The basic context switching mechanism is a jmp_buf for each process. You switch to a new process by longjmping to its jmp_buf. Now that UML has its own implementation of setjmp and longjmp, and I can poke around inside a jmp_buf without fear that libc will change the structure, a much simpler mechanism is possible. The jmpbuf can simply be initialized by hand. This eliminates - the need to set up and remove the alternate signal stack sending and handling a signal the signal blocking needed around the stack switching, since there is no stack switching setting up the jmp_buf needed to jump back to the original stack after the new one is set up In addition, since jmp_buf is now defined by UML, and not by libc, it can be embedded in the thread struct. This makes it unnecessary to have it exist on the stack, where it used to be. It also simplifies interfaces, since the switch jmp_buf used to be a void * inside the thread struct, and functions which took it as an argument needed to define a jmp_buf variable and assign it from the void *. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] uml: mark some tt-mode codeJeff Dike
Mark a symbol and file as being tt-mode only. This shrinks the binary slightly when tt mode support is compiled out and makes it easier to identity stuff when tt mode is removed. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] uml: use correct SIGBUS handlerJeff Dike
BB noticed that we had the wrong bus error handler. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] uml: fix gcov supportJeff Dike
Make __bb_init_func weak in order to avoid a link failure with some libcs and/or gccs. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] uml: fix missing x86_64 register definitionsJeff Dike
The UML/x86_64 headers were missing ptrace support for some segment registers. The underlying problem was that the x86_64 kernel uses user_regs_struct rather than the ptrace register definitions in ptrace. This patch switches UML/x86_64 to using user_regs_struct for its definitions of the host's registers. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] uml: get rid of ZONE_DMA useJeff Dike
ZONE_DMA might become dependent on CONFIG_ZONE_DMA, which UML doesn't define (we're still arguing about this) So, let's change ZONE_DMA to ZONE_NORMAL. This is prompted by optional-zone_dma-in-the-vm.patch, but should be harmless on its own. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Christoph Lameter <clameter@engr.sgi.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] uml: const more dataJeff Dike
Make lots of structures const in order to make it obvious that they need no locking. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] uml: fix proc-vs-interrupt context spinlock deadlockPaolo 'Blaisorblade' Giarrusso
This spinlock can be taken on interrupt too, so spin_lock_irq[save] must be used. However, Documentation/networking/netdevices.txt explains we are called with rtnl_lock() held - so we don't need to care about other concurrent opens. Verified also in LDD3 and by direct checking. Also verified that the network layer (through a state machine) guarantees us that nobody will close the interface while it's being used. Please correct me if I'm wrong. Also, we must check we don't sleep with irqs disabled!!! But anyway, this is not news - we already can't sleep while holding a spinlock. Who says this is guaranted really by the present code? Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] uml: use -mcmodel=kernel for x86_64Paolo 'Blaisorblade' Giarrusso
We have never used this flag and recently one user experienced a complaining warning about this (there was a symbol in the positive half of the address space IIRC). So fix it. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (225 commits) [PATCH] Don't set calgary iommu as default y [PATCH] i386/x86-64: New Intel feature flags [PATCH] x86: Add a cumulative thermal throttle event counter. [PATCH] i386: Make the jiffies compares use the 64bit safe macros. [PATCH] x86: Refactor thermal throttle processing [PATCH] Add 64bit jiffies compares (for use with get_jiffies_64) [PATCH] Fix unwinder warning in traps.c [PATCH] x86: Allow disabling early pci scans with pci=noearly or disallowing conf1 [PATCH] x86: Move direct PCI scanning functions out of line [PATCH] i386/x86-64: Make all early PCI scans dependent on CONFIG_PCI [PATCH] Don't leak NT bit into next task [PATCH] i386/x86-64: Work around gcc bug with noreturn functions in unwinder [PATCH] Fix some broken white space in ia32_signal.c [PATCH] Initialize argument registers for 32bit signal handlers. [PATCH] Remove all traces of signal number conversion [PATCH] Don't synchronize time reading on single core AMD systems [PATCH] Remove outdated comment in x86-64 mmconfig code [PATCH] Use string instructions for Core2 copy/clear [PATCH] x86: - restore i8259A eoi status on resume [PATCH] i386: Split multi-line printk in oops output. ...
2006-09-26[PATCH] UML: tty lockingAlan Cox
Ensure current->signal->tty doesn't get freed during log_exec(). Signed-off-by: Alan Cox <alan@redhat.com> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] uml: stack usage reductionJeff Dike
The KSTK_* macros used an inordinate amount of stack. In order to overcome an impedance mismatch between their interface, which just returns a single register value, and the interface of get_thread_regs, which took a full pt_regs, the implementation created an on-stack pt_regs, filled it in, and returned one field. do_task_stat calls KSTK_* twice, resulting in two local pt_regs, blowing out the stack. This patch changes the interface (and name) of get_thread_regs to just return a single register from a jmp_buf. The include of archsetjmp.h" in registers.h to get the definition of jmp_buf exposed a bogus include of <setjmp.h> in start_up.c. <setjmp.h> shouldn't be used anywhere any more since UML uses the klibc setjmp/longjmp. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] uml: clean our set_ether_macPaolo 'Blaisorblade' Giarrusso
Clean set_ether_mac usage. Maybe could also be removed, but surely it can't be a global function taking a void* argument. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] uml: Remove unused variableJeff Dike
timer_irq_inited was useless, so it is removed. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] uml: timer cleanupsJeff Dike
set_interval returns an error instead of panicing if setitimer fails. Some of its callers now check the return. enable_timer is largely tt-mode-specific, so it is marked as such, and the only skas-mode caller is made to call set-interval instead. user_time_init was a no-value-added wrapper around set_interval, so it is gone. Since set_interval is now called from kernel code, callers no longer pass ITIMER_* to it. Instead, they pass a flag which is converted into ITIMER_REAL or ITIMER_VIRTUAL. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] uml: Move signal handlers to arch codeJeff Dike
Have most signals go through an arch-provided handler which recovers the sigcontext and then calls a generic handler. This replaces the ARCH_GET_SIGCONTEXT macro, which was somewhat fragile. On x86_64, recovering %rdx (which holds the sigcontext pointer) must be the first thing that happens. sig_handler duly invokes that first, but there is no guarantee that I can see that instructions won't be reordered such that %rdx is used before that. Having the arch provide the handler seems much more robust. Some signals in some parts of UML require their own handlers - these places don't call set_handler any more. They call sigaction or signal themselves. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] uml: SIGIO cleanupsJeff Dike
- Various cleanups in the sigio code. - Removed explicit zero-initializations of a few structures. - Improved some error messages. - An API change - there was an asymmetry between reactivate_fd calling maybe_sigio_broken, which goes through all the machinery of figuring out if a file descriptor supports SIGIO and applying the workaround to it if not, and deactivate_fd, which just turns off the descriptor. This is changed so that only activate_fd calls maybe_sigio_broken, when the descriptor is first seen. reactivate_fd now calls add_sigio_fd, which is symmetric with ignore_sigio_fd. This removes a recursion which makes a critical section look more critical than it really was, obsoleting a big comment to that effect. This requires keeping track of all descriptors which are getting the SIGIO treatment, not just the ones being polled at any given moment, so that reactivate_fd, through add_sigio_fd, doesn't try to tell the SIGIO thread about descriptors it doesn't care about. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] uml: Improve SIGBUS diagnosticsJeff Dike
UML can get a SIGBUS anywhere if the tmpfs mount being used for its memory runs out of space. This patch adds a printk before the panic to provide a clue as to what likely went wrong. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] uml: Fix handling of failed execs of helpersJeff Dike
There were some bugs in handling failures to exec helper programs. errno was passed back from the child with the wrong sign. It was also ignored. In the case where it mattered, the errno from the (successful) read in the parent was used instead. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] uml: Whitespace fixesJeff Dike
arch/um/kernel/tlb.c had some pretty serious whitespace problems. I also fixed some returns. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] uml: Fix stack alignmentJeff Dike
Stack randomization needs to be conditional on the personality allowing it. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] uml: Use ARRAY_SIZE more assiduouslyJeff Dike
There were a bunch of missed ARRAY_SIZE opportunities. Also, some formatting fixes in the affected areas of code. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] uml: Use klibc setjmp/longjmpJeff Dike
This patch adds an implementation of setjmp and longjmp to UML, allowing access to the inside of a jmpbuf without needing the access macros formerly provided by libc. The implementation is stolen from klibc. I copy the relevant files into arch/um. I have another patch which avoids the copying, but requires klibc be in the tree. setjmp and longjmp users required some tweaking. Includes of <setjmp.h> were removed and includes of the UML longjmp.h were added where necessary. There are also replacements of siglongjmp with UML_LONGJMP which I somehow missed earlier. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] Standardize pxx_page macrosDave McCracken
One of the changes necessary for shared page tables is to standardize the pxx_page macros. pte_page and pmd_page have always returned the struct page associated with their entry, while pte_page_kernel and pmd_page_kernel have returned the kernel virtual address. pud_page and pgd_page, on the other hand, return the kernel virtual address. Shared page tables needs pud_page and pgd_page to return the actual page structures. There are very few actual users of these functions, so it is simple to standardize their usage. Since this is basic cleanup, I am submitting these changes as a standalone patch. Per Hugh Dickins' comments about it, I am also changing the pxx_page_kernel macros to pxx_page_vaddr to clarify their meaning. Signed-off-by: Dave McCracken <dmccr@us.ibm.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] reduce MAX_NR_ZONES: make ZONE_HIGHMEM optionalChristoph Lameter
Make ZONE_HIGHMEM optional - ifdef out code and definitions related to CONFIG_HIGHMEM - __GFP_HIGHMEM falls back to normal allocations if there is no ZONE_HIGHMEM - GFP_ZONEMASK becomes 0x01 if there is no DMA32 and no HIGHMEM zone. [jdike@addtoit.com: build fix] Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Christoph Lameter <clameter@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] reduce MAX_NR_ZONES: move HIGHMEM counters into highmem.c/.hChristoph Lameter
Move totalhigh_pages and nr_free_highpages() into highmem.c/.h Move the totalhigh_pages definition into highmem.c/.h. Move the nr_free_highpages function into highmem.c [yoichi_yuasa@tripeaks.co.jp: build fix] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] i386: Redo semaphore and rwlock assembly helpersAndi Kleen
- Move them to a pure assembly file. Previously they were in a C file that only consisted of inline assembly. Doing it in pure assembler is much nicer. - Add a frame.i include with FRAME/ENDFRAME macros to easily add frame pointers to assembly functions - Add dwarf2 annotation to them so that the new dwarf2 unwinder doesn't get stuck on them - Random cleanups Includes feedback from Jan Beulich and a UML build fix from Andrew Morton. Cc: jbeulich@novell.com Cc: jdike@addtoit.com Signed-off-by: Andi Kleen <ak@suse.de>
2006-07-31[PATCH] vDSO hash-style fixRoland McGrath
The latest toolchains can produce a new ELF section in DSOs and dynamically-linked executables. The new section ".gnu.hash" replaces ".hash", and allows for more efficient runtime symbol lookups by the dynamic linker. The new ld option --hash-style={sysv|gnu|both} controls whether to produce the old ".hash", the new ".gnu.hash", or both. In some new systems such as Fedora Core 6, gcc by default passes --hash-style=gnu to the linker, so that a standard invocation of "gcc -shared" results in producing a DSO with only ".gnu.hash". The new ".gnu.hash" sections need to be dealt with the same way as ".hash" sections in all respects; only the dynamic linker cares about their contents. To work with older dynamic linkers (i.e. preexisting releases of glibc), a binary must have the old ".hash" section. The --hash-style=both option produces binaries that a new dynamic linker can use more efficiently, but an old dynamic linker can still handle. The new section runs afoul of the custom linker scripts used to build vDSO images for the kernel. On ia64, the failure mode for this is a boot-time panic because the vDSO's PT_IA_64_UNWIND segment winds up ill-formed. This patch addresses the problem in two ways. First, it mentions ".gnu.hash" in all the linker scripts alongside ".hash". This produces correct vDSO images with --hash-style=sysv (or old tools), with --hash-style=gnu, or with --hash-style=both. Second, it passes the --hash-style=sysv option when building the vDSO images, so that ".gnu.hash" is not actually produced. This is the most conservative choice for compatibility with any old userland. There is some concern that some ancient glibc builds (though not any known old production system) might choke on --hash-style=both binaries. The optimizations provided by the new style of hash section do not really matter for a DSO with a tiny number of symbols, as the vDSO has. If someone wants to use =gnu or =both for their vDSO builds and worry less about that compatibility, just change the option and the linker script changes will make any choice work fine. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Andi Kleen <ak@muc.de> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-15[PATCH] UML - fix utsname build breakageJeff Dike
Some -mm-only material leaked into a patch destined for mainline, and I didn't notice. This was the replacement of system_utsname with utsname() that's required by the uts namespace patch. This patch reverts those changes (which are correct in -mm) so that mainline UML builds again. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] uml: header formatting cleanupsJeff Dike
Clean up whitespace and return syntax in os.h. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] uml: tidy biarch gcc supportJeff Dike
On top of the previous biarch changes for UML, this makes the preprocessor changes a bit cleaner. Specify the 64-bit build in CPPFLAGS on the x86_64 SUBARCH, rather than #undef'ing i386. Compile-tested with i386 and x86_64 SUBARCHs. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] uml: tidy longjmp macroJeff Dike
The UML_SETJMP macro was requiring its users to pass in a argument which it could supply itself, since it wasn't used outside that invocation of the macro. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: make mconsole version requests happen in a processJeff Dike
Handling a host mconsole version request must be done in a process context rather than interrupt context now that utsname information can be process-specific rather than global. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: remove unused variableJeff Dike
The dedevfsification of UML left an unused variable behind. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: add some EINTR protectionJeff Dike
Add some more uses of the CATCH_EINTR wrapper. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: formatting fixesJeff Dike
Fix a bunch of formatting problems. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: move _kern.c filesJeff Dike
Move most *_kern.c files in arch/um/kernel to *.c. This makes UML somewhat more closely resemble the other arches. [akpm@osdl.org: use the new INTF_* flags] Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: remove syscall debuggingJeff Dike
Eliminate an unused debug option. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: make some symbols staticJeff Dike
A few sigio-related things can be made static. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: fix exitcall ordering bugJeff Dike
This fixes an exitcall ordering bug - calls to ignore_sigio_fd can come from exitcalls that come after the sigio thread has been killed. This would cause shutdown to hang or crash. Fixed by having ignore_sigio_fd check that the thread is present before trying to communicate with it. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: remove os_isattyJeff Dike
os_isatty can be made to disappear by moving maybe_sigio_broken from kernel to user code. This also lets write_sigio_workaround become static. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: remove spinlock wrapper functionsJeff Dike
The irq_spinlock is not needed from user code any more, so the irq_lock and irq_unlock wrappers can go away. This also changes the name of the lock to irq_lock. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: mark forward_interrupts as being mode-specificJeff Dike
Mark forward_interrupts as being tt-mode only. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: ifdef a mode-specific functionJeff Dike
uml_idle_timer is tt-mode only, so ifdef it as such to make it easier to spot when tt mode is killed. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: timer handler tidyingJeff Dike
Get rid of a user of timer_irq_inited (and first_tick) by observing that prev_ticks can be used to decide if this is the first call. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: signal initialization cleanupJeff Dike
It turns out that init_new_thread_signals is always called with altstack == 1, so we can eliminate the parameter. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
