path: root/arch/um/sys-x86_64/unmap.c
2007-10-16uml: throw out CONFIG_MODE_TTJeff Dike
This patchset throws out tt mode, which has been non-functional for a while. This is done in phases, interspersed with code cleanups on the affected files. The removal is done as follows: remove all code, config options, and files which depend on CONFIG_MODE_TT get rid of the CHOOSE_MODE macro, which decided whether to call tt-mode or skas-mode code, and replace invocations with their skas portions replace all now-trivial procedures with their skas equivalents There are now a bunch of now-redundant pieces of data structures, including mode-specific pieces of the thread structure, pt_regs, and mm_context. These are all replaced with their skas-specific contents. As part of the ongoing style compliance project, I made a style pass over all files that were changed. There are three such patches, one for each phase, covering the files affected by that phase but no later ones. I noticed that we weren't freeing the LDT state associated with a process when it exited, so that's fixed in one of the later patches. The last patch is a tidying patch which I've had for a while, but which caused inexplicable crashes under tt mode. Since that is no longer a problem, this can now go in. This patch: Start getting rid of tt mode support. This patch throws out CONFIG_MODE_TT and all config options, code, and files which depend on it. CONFIG_MODE_SKAS is gone and everything that depends on it is included unconditionally. The few changed lines are in re-written Kconfig help, lines which needed something skas-related removed from them, and a few more which weren't strictly deletions. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-30[PATCH] Fix "Remove the use of _syscallX macros in UML"Paolo 'Blaisorblade' Giarrusso
Fix commit 5f4c6bc1f369f20807a8e753c2308d1629478c61: it spits out warnings about missing syscall prototype (it is in <unistd.h>) and it does not recognize that two uses of _syscallX are to be resolved against kernel headers in the source tree, not against _syscallX; they in fact do not compile and would not work anyway. If _syscallX macros will be removed from the kernel tree altogether, the only reasonable solution for that piece of code is switching to open-coded inline assembly (it's remapping the whole executable from memory, except the page containing this code). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] Remove the use of _syscallX macros in UMLArnd Bergmann
User mode linux uses _syscallX() to call into the host kernel. The recommended way to do this is to use the syscall() function from libc. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-14[PATCH] uml: workaround host bug in "TT mode vs. NPTL link fix"Paolo 'Blaisorblade' Giarrusso
A big bug has been diagnosed on hosts running the SKAS patch and built with CONFIG_REGPARM, due to some missing prevent_tail_call(). On these hosts, this workaround is needed to avoid triggering that bug, because "to" is kept by GCC only in EBX, which is corrupted at the return of mmap2(). Since to trigger this bug int 0x80 must be used when doing the call, it rarely manifests itself, so I'd prefer to get this merged to workaround that host bug, since it should cause no functional change. Still, you might prefer to drop it, I'll leave this to you. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] uml: fix linkage of tt mode against NPTLPaolo 'Blaisorblade' Giarrusso
With Al Viro <viro@parcelfarce.linux.theplanet.co.uk> To make sure switcheroo() can execute when we remap all the executable image, we used a trick to make it use a local copy of errno... this trick does not work with NPTL glibc, only with LinuxThreads, so use another (simpler) one to make it work anyway. Hopefully, a lot improved thanks to merging with the version of Al Viro (which had his part of problems, though, i.e. removing a fix to another bug and not fixing the problem on i386). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
