path: root/arch/um/sys-x86_64/Makefile
2011-11-02um: merge arch/um/sys-{i386,x86_64}Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Richard Weinberger <richard@nod.at>
2011-11-02um: -include user.h for USER_OBJ, trim includesAl Viro
2011-07-25um: implement a x86_64 vDSORichard Weinberger
Until now UML had no x86_64 vDSO. So glibc always used the vsyscall page for gettimeday() and friends. Calls to gettimeday() returned falsely the host time and confused some programs. This patch adds a vDSO which turns all __vdso_* calls into a system call so that UML can trap them. As glibc still uses the vsyscall page for static binaries this patch improves the situation only for dynamic binaries. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um: set __HAVE_ARCH_GATE_AREA for x86_64Richard Weinberger
Implement arch_vma_name() and make get_gate_vma(), in_gate_area() and in_gate_area_no_mm() a nop. We need arch_vma_name() to support vDSO. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um: clean up vm-flags.hRichard Weinberger
There is no need to define VM_{STACK,DATA}_DEFAULT_FLAGS as variable. It's also useless to test for TIF_IA32 as 64bit UML has no IA32 emulation. Signed-off-by: Richard Weinberger <richard@nod.at> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-21x86: Unify rwsem assembly implementationJan Beulich
Rather than having two functionally identical implementations for 32- and 64-bit configurations, use the previously extended assembly abstractions to fold the rwsem two implementations into a shared one. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/4E258DF3020000780004E3ED@nat28.tlf.novell.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-17x86: Fix breakage of UML from the changes in the rwsem systemLinus Torvalds
The patches 5d0b7235d83eefdafda300656e97d368afcafc9a and bafaecd11df15ad5b1e598adc7736afcd38ee13d broke the UML build: On Sun, 17 Jan 2010, Ingo Molnar wrote: > > FYI, -tip testing found that these changes break the UML build: > > kernel/built-in.o: In function `__up_read': > /home/mingo/tip/arch/x86/include/asm/rwsem.h:192: undefined reference to `call_rwsem_wake' > kernel/built-in.o: In function `__up_write': > /home/mingo/tip/arch/x86/include/asm/rwsem.h:210: undefined reference to `call_rwsem_wake' > kernel/built-in.o: In function `__downgrade_write': > /home/mingo/tip/arch/x86/include/asm/rwsem.h:228: undefined reference to `call_rwsem_downgrade_wake' > kernel/built-in.o: In function `__down_read': > /home/mingo/tip/arch/x86/include/asm/rwsem.h:112: undefined reference to `call_rwsem_down_read_failed' > kernel/built-in.o: In function `__down_write_nested': > /home/mingo/tip/arch/x86/include/asm/rwsem.h:154: undefined reference to `call_rwsem_down_write_failed' > collect2: ld returned 1 exit status Add lib/rwsem_64.o to the UML subarch objects to fix. LKML-Reference: <alpine.LFD.2.00.1001171023440.13231@localhost.localdomain> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-06-12uml module: fix uml build process due to this mergeAmerigo Wang
Due to the previous merge, uml needs to be fixed. Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-04-26x86, UML: remove x86-specific implementations of find_first_bitAlexander van Heukelum
x86 has been switched to the generic versions of find_first_bit and find_first_zero_bit, but the original versions were retained. This patch just removes the now unused x86-specific versions. also update UML. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-16uml: style fixes in FP codeJeff Dike
Tidy the code affected by the floating point fixes. A bunch of unused stuff is gone, including two sigcontext.c files, which turned out to be entirely unneeded. There are the usual fixes - whitespace and style cleanups copyright updates emacs formatting comments gone include cleanups adding severities to printks Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: throw out CONFIG_MODE_TTJeff Dike
This patchset throws out tt mode, which has been non-functional for a while. This is done in phases, interspersed with code cleanups on the affected files. The removal is done as follows: remove all code, config options, and files which depend on CONFIG_MODE_TT get rid of the CHOOSE_MODE macro, which decided whether to call tt-mode or skas-mode code, and replace invocations with their skas portions replace all now-trivial procedures with their skas equivalents There are now a bunch of now-redundant pieces of data structures, including mode-specific pieces of the thread structure, pt_regs, and mm_context. These are all replaced with their skas-specific contents. As part of the ongoing style compliance project, I made a style pass over all files that were changed. There are three such patches, one for each phase, covering the files affected by that phase but no later ones. I noticed that we weren't freeing the LDT state associated with a process when it exited, so that's fixed in one of the later patches. The last patch is a tidying patch which I've had for a while, but which caused inexplicable crashes under tt mode. Since that is no longer a problem, this can now go in. This patch: Start getting rid of tt mode support. This patch throws out CONFIG_MODE_TT and all config options, code, and files which depend on it. CONFIG_MODE_SKAS is gone and everything that depends on it is included unconditionally. The few changed lines are in re-written Kconfig help, lines which needed something skas-related removed from them, and a few more which weren't strictly deletions. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-13minimal build fixes for uml (fallout from x86 merge)Al Viro
a) include/asm-um/arch can't just point to include/asm-$(SUBARCH) now b) arch/{i386,x86_64}/crypto are merged now c) subarch-obj needed changes d) cpufeature_64.h should pull "cpufeature_32.h", not <asm/cpufeature_32.h> since it can be included from asm-um/cpufeature.h e) in case of uml-i386 we need CONFIG_X86_32 for make and gcc, but not for Kconfig f) sysctl.c shouldn't do vdso_enabled for uml-i386 (actually, that one should be registered from corresponding arch/*/kernel/*, with ifdef going away; that's a separate patch, though). With that and with Stephen's patch ("[PATCH net-2.6] uml: hard_header fix") we have uml allmodconfig building both on i386 and amd64. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] UML: add generic BUG supportJeff Dike
The BUG changes in -mm3 need some arch support. This patch adds the UML support needed. For the most part, it was stolen from the underlying architecture. The exception is the kernel eip < PAGE_OFFSET test, which is wrong for skas mode UMLs. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] uml: Use klibc setjmp/longjmpJeff Dike
This patch adds an implementation of setjmp and longjmp to UML, allowing access to the inside of a jmpbuf without needing the access macros formerly provided by libc. The implementation is stolen from klibc. I copy the relevant files into arch/um. I have another patch which avoids the copying, but requires klibc be in the tree. setjmp and longjmp users required some tweaking. Includes of <setjmp.h> were removed and includes of the UML longjmp.h were added where necessary. There are also replacements of siglongjmp with UML_LONGJMP which I somehow missed earlier. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] uml: cleanup unprofile expression and build infrastructurePaolo 'Blaisorblade' Giarrusso
*) Rather than duplicate in various buggy ways the application of CFLAGS_NO_HARDENING and UNPROFILE (which apply to the same files), centralize it in Makefile.rules. UNPROFILE_OBJS mustn't be listed in USER_OBJS but are compiled as such. I've also verified that unprofile didn't work in the current form, because we set _c_flags directly (using CFLAGS and not USER_CFLAGS, which is wrong), which is normally used by c_flags, but we also override c_flags for all USER_OBJS, and there we don't call unprofile. Instead it only worked for unmap.o, the only one which wasn't a USER_OBJ. We need to set c_flags (which is not a public Kbuild API) to clear a lot of compilation flags like -nostdinc which Kbuild forces on everything. *) Rather than $(CFLAGS_$(notdir $@)), which expands to CFLAGS_anObj.s when building "anObj.s", use $(CFLAGS_$(*F).o) which always accesses CFLAGS_anObj.o, like done by Kbuild. *) Make c_flags apply to all targets having the same basename, rather than listing .s, .i, .lst and .o, with the use (which I tested) of $(USER_OBJS:.o=.%): c_flags = ... and of - $(obj)/unmap.c: _c_flags = ... + $(obj)/unmap.%: _c_flags = ... Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] uml: fix compilation and execution with hardened GCCPaolo 'Blaisorblade' Giarrusso
To make some half-assembly stubs compile, disable various "hardened" GCC features: *) we can't make it build PIC code as we need %ebx to do syscalls and GCC wants it free for PIC *) we can't leave stack protection as the stub is moved (not relocated!) in memory so the RIP-relative access to the canary tries reading from an unmapped address and causes a segfault, since we move the stub of various megabytes (the exact amount will be decided at runtime) away from the link-time address. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] uml: use Kbuild tracking for all files and fix compilation outputPaolo 'Blaisorblade' Giarrusso
Move the build of user-offsets to arch/um/sys-$(SUBARCH), where it's located. So we can also build it via Kbuild with its dependency tracking rather than by hand. While hacking here, fix also a lot of little cosmetic things. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] uml: implement {get,set}_thread_area for i386Paolo 'Blaisorblade' Giarrusso
Implement sys_[gs]et_thread_area and the corresponding ptrace operations for UML. This is the main chunk, additional parts follow. This implementation is now well tested and has run reliably for some time, and we've understood all the previously existing problems. Their implementation saves the new GDT content and then forwards the call to the host when appropriate, i.e. immediately when the target process is running or on context switch otherwise (i.e. on fork and on ptrace() calls). In SKAS mode, we must switch registers on each context switch (because SKAS does not switches tls_array together with current->mm). Also, added get_cpu() locking; this has been done for SKAS mode, since TT does not need it (it does not use smp_processor_id()). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] uml: clean up remapping code build magicAl Viro
kills unmap magic Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] uml: eliminate symlinks to host archAl Viro
kills symlinks in arch/um/sys-* Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-29[PATCH] uml: fix compilation with CONFIG_MODE_TT disabledPaolo 'Blaisorblade' Giarrusso
Fix UML compilation when SKAS mode is disabled. Indeed, we were compiling SKAS-only object files, which failed due to some SKAS-only headers being excluded from the search path. Thanks to the bug report from Pekka J Enberg. Acked-by: Pekka J Enberg <penberg (at) cs ! helsinki ! fi> Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-22[PATCH] uml: properly invoke x86_64 system callsJeff Dike
This patch makes stub_segv use the stub_syscall macros. This was needed anyway, but the bug that prompted this was the discovery that gcc was storing stuff in RCX, which is trashed across a system call. This is exactly the sort of problem that the new macros fix. There is a stub_syscall0 for getpid. stub_segv was changed to be a libc file, and that caused some include changes. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] uml: maintain own LDT entriesBodo Stroesser
Patch imlements full LDT handling in SKAS: * UML holds it's own LDT table, used to deliver data on modify_ldt(READ) * UML disables the default_ldt, inherited from the host (SKAS3) or resets LDT entries, set by host's clib and inherited in SKAS0 * A new global variable skas_needs_stub is inserted, that can be used to decide, whether stub-pages must be supported or not. * Uses the syscall-stub to replace missing PTRACE_LDT (therefore, write_ldt_entry needs to be modified) Signed-off-by: Bodo Stroesser <bstroesser@fujitsu-siemens.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-29[PATCH] uml makefiles sanitizedAl Viro
UML makefiles sanitized: - number of generated headers reduced to 2 (from user-offsets.c and kernel-offsets.c resp.). The rest is made constant and simply includes those two. - mk_... helpers are gone now that we don't need to generate these headers - arch/um/include2 removed since everything under arch/um/include/sysdep is constant now and symlink can point straight to source tree. - dependencies seriously simplified. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] uml: build cleanupsAl Viro
Added missing include list to uml AFLAGS Killed magic for stubs. [So] - it was needed only because of messed AFLAGS Switched segv_stubs.c to kernel CFLAGS sans profile, instead of user ones Killed STUBS_CFLAGS - it's not needed and the only remaining use had been gratitious - it only polluted CFLAGS Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] uml: build cleanupAl Viro
Build cleanups Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] unify x86/x86-64 semaphore codeBenjamin LaHaise
This patch moves the common code in x86 and x86-64's semaphore.c into a single file in lib/semaphore-sleepers.c. The arch specific asm stubs are left in the arch tree (in semaphore.c for i386 and in the asm for x86-64). There should be no changes in code/functionality with this patch. Signed-off-by: Benjamin LaHaise <benjamin.c.lahaise@intel.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] uml: skas0 - separate kernel address space on stock hostsJeff Dike
UML has had two modes of operation - an insecure, slow mode (tt mode) in which the kernel is mapped into every process address space which requires no host kernel modifications, and a secure, faster mode (skas mode) in which the UML kernel is in a separate host address space, which requires a patch to the host kernel. This patch implements something very close to skas mode for hosts which don't support skas - I'm calling this skas0. It provides the security of the skas host patch, and some of the performance gains. The two main things that are provided by the skas patch, /proc/mm and PTRACE_FAULTINFO, are implemented in a way that require no host patch. For the remote address space changing stuff (mmap, munmap, and mprotect), we set aside two pages in the process above its stack, one of which contains a little bit of code which can call mmap et al. To update the address space, the system call information (system call number and arguments) are written to the stub page above the code. The %esp is set to the beginning of the data, the %eip is set the the start of the stub, and it repeatedly pops the information into its registers and makes the system call until it sees a system call number of zero. This is to amortize the cost of the context switch across multiple address space updates. When the updates are done, it SIGSTOPs itself, and the kernel process continues what it was doing. For a PTRACE_FAULTINFO replacement, we set up a SIGSEGV handler in the child, and let it handle segfaults rather than nullifying them. The handler is in the same page as the mmap stub. The second page is used as the stack. The handler reads cr2 and err from the sigcontext, sticks them at the base of the stack in a faultinfo struct, and SIGSTOPs itself. The kernel then reads the faultinfo and handles the fault. A complication on x86_64 is that this involves resetting the registers to the segfault values when the process is inside the kill system call. This breaks on x86_64 because %rcx will contain %rip because you tell SYSRET where to return to by putting the value in %rcx. So, this corrupts $rcx on return from the segfault. To work around this, I added an arch_finish_segv, which on x86 does nothing, but which on x86_64 ptraces the child back through the sigreturn. This causes %rcx to be restored by sigreturn and avoids the corruption. Ultimately, I think I will replace this with the trick of having it send itself a blocked signal which will be unblocked by the sigreturn. This will allow it to be stopped just after the sigreturn, and PTRACE_SYSCALLed without all the back-and-forth of PTRACE_SYSCALLing it through sigreturn. This runs on a stock host, so theoretically (and hopefully), tt mode isn't needed any more. We need to make sure that this is better in every way than tt mode, though. I'm concerned about the speed of address space updates and page fault handling, since they involve extra round-trips to the child. We can amortize the round-trip cost for large address space updates by writing all of the operations to the data page and having the child execute them all at the same time. This will help fork and exec, but not page faults, since they involve only one page. I can't think of any way to help page faults, except to add something like PTRACE_FAULTINFO to the host. There is PTRACE_SIGINFO, but UML doesn't use siginfo for SIGSEGV (or anything else) because there isn't enough information in the siginfo struct to handle page faults (the faulting operation type is missing). Adding that would make PTRACE_SIGINFO a usable equivalent to PTRACE_FAULTINFO. As for the code itself: - The system call stub is in arch/um/kernel/sys-$(SUBARCH)/stub.S. It is put in its own section of the binary along with stub_segv_handler in arch/um/kernel/skas/process.c. This is manipulated with run_syscall_stub in arch/um/kernel/skas/mem_user.c. syscall_stub will execute any system call at all, but it's only used for mmap, munmap, and mprotect. - The x86_64 stub calls sigreturn by hand rather than allowing the normal sigreturn to happen, because the normal sigreturn is a SA_RESTORER in UML's address space provided by libc. Needless to say, this is not available in the child's address space. Also, it does a couple of odd pops before that which restore the stack to the state it was in at the time the signal handler was called. - There is a new field in the arch mmu_context, which is now a union. This is the pid to be manipulated rather than the /proc/mm file descriptor. Code which deals with this now checks proc_mm to see whether it should use the usual skas code or the new code. - userspace_tramp is now used to create a new host process for every UML process, rather than one per UML processor. It checks proc_mm and ptrace_faultinfo to decide whether to map in the pages above its stack. - start_userspace now makes CLONE_VM conditional on proc_mm since we need separate address spaces now. - switch_mm_skas now just sets userspace_pid[0] to the new pid rather than PTRACE_SWITCH_MM. There is an addition to userspace which updates its idea of the pid being manipulated each time around the loop. This is important on exec, when the pid will change underneath userspace(). - The stub page has a pte, but it can't be mapped in using tlb_flush because it is part of tlb_flush. This is why it's required for it to be mapped in by userspace_tramp. Other random things: - The stub section in uml.lds.S is page aligned. This page is written out to the backing vm file in setup_physmem because it is mapped from there into user processes. - There's some confusion with TASK_SIZE now that there are a couple of extra pages that the process can't use. TASK_SIZE is considered by the elf code to be the usable process memory, which is reasonable, so it is decreased by two pages. This confuses the definition of USER_PGDS_IN_LAST_PML4, making it too small because of the rounding down of the uneven division. So we round it to the nearest PGDIR_SIZE rather than the lower one. - I added a missing PT_SYSCALL_ARG6_OFFSET macro. - um_mmu.h was made into a userspace-usable file. - proc_mm and ptrace_faultinfo are globals which say whether the host supports these features. - There is a bad interaction between the mm.nr_ptes check at the end of exit_mmap, stack randomization, and skas0. exit_mmap will stop freeing pages at the PGDIR_SIZE boundary after the last vma. If the stack isn't on the last page table page, the last pte page won't be freed, as it should be since the stub ptes are there, and exit_mmap will BUG because there is an unfreed page. To get around this, TASK_SIZE is set to the next lowest PGDIR_SIZE boundary and mm->nr_ptes is decremented after the calls to init_stub_pte. This ensures that we know the process stack (and all other process mappings) will be below the top page table page, and thus we know that mm->nr_ptes will be one too many, and can be decremented. Things that need fixing: - We may need better assurrences that the stub code is PIC. - The stub pte is set up in init_new_context_skas. - alloc_pgdir is probably the right place. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] uml: fix linkage of tt mode against NPTLPaolo 'Blaisorblade' Giarrusso
With Al Viro <viro@parcelfarce.linux.theplanet.co.uk> To make sure switcheroo() can execute when we remap all the executable image, we used a trick to make it use a local copy of errno... this trick does not work with NPTL glibc, only with LinuxThreads, so use another (simpler) one to make it work anyway. Hopefully, a lot improved thanks to merging with the version of Al Viro (which had his part of problems, though, i.e. removing a fix to another bug and not fixing the problem on i386). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-20[PATCH] uml: small fixes left over from rc4Jeff Dike
Some changes that I sent in didn't make 2.6.12-rc4 for some reason. This adds them back. We have an x86_64 definition of TOP_ADDR a reimplementation of the x86_64 csum_partial_copy_from_user some syntax fixes in arch/um/kernel/ptrace.c removal of a CFLAGS definition in the x86_64 Makefile some include changes in the x86_64 ptrace.c and user-offsets.h a syntax fix in elf-x86_64.h Also moved an include in the i386 and x86_64 Makefiles to make the symlinks work, and some small fixes from Al Viro. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] uml: fix missing subdir in x86_64Al Viro
make distclean et.al. are missing arch/um/sys-x86_64/utils; fixed the same way we have it done for sys-i386 counterpart. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] uml kbuild: avoid useless rebuildsPaolo 'Blaisorblade' Giarrusso
- Fix some problems with usage of $(targets) (sometimes missing, sometimes used badly) that trigger partial rebuilds when doing a rebuild. - At that purpose, also factor out some common code for symlinks creation. - Fix a x86-64 build warning, caused by -L/usr/lib, which is anyway useless, and invalid in the x86-64 case. Tested on x86_64 and x86. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] uml: kludgy compilation fixes for x86-64 subarch modules supportPaolo 'Blaisorblade' Giarrusso
These are some trivial fixes for the x86-64 subarch module support. The only potential problem is that I have to modify arch/x86_64/kernel/module.c, to avoid copying the whole of it. I can't use it verbatim because it depends on a special vmalloc-like area for modules, which for now (maybe that's to fix, I guess not) UML/x86-64 has not. I went the easy way and reused the i386 vmalloc()-based allocator. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] uml: fix syscall table by including $(SUBARCH)'s one, for x86-64Paolo 'Blaisorblade' Giarrusso
Reuse asm-x86-64/unistd.h to build our syscall table, like x86-64 already does. Like for i386, we must add some #defines for all the (right!) changes UML does to x86-64 syscall table. Note: I noted a bogus: [ __NR_sched_yield ] = (syscall_handler_t *) yield, while doing this patch (which could only be a workaround for some strange bug, but I would ignore this possibility). I'm changing this without notice. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] uml: fix syscall table by including $(SUBARCH)'s one, for i386Paolo 'Blaisorblade' Giarrusso
Split the i386 entry.S files into entry.S and syscall_table.S which is included in the previous one (so actually there is no difference between them) and use the syscall_table.S in the UML build, instead of tracking by hand the syscall table changes (which is inherently error-prone). We must only insert the right #defines to inject the changes we need from the i386 syscall table (for instance some different function names); also, we don't implement some i386 syscalls, as ioperm(), nor some TLS-related ones (yet to provide). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
