arch/um/drivers/chan_kern.c:643: error: conflicting types for 'chan_interrupt'
arch/um/include/chan_kern.h:31: error: previous declaration of 'chan_interrupt'
Cc: Jeff Dike <jdike@addtoit.com>
Real fix for UML pt_regs stuff. Note set_irq_regs() logics in there...
The patch below corrects multiple occurances of "the the"
typos across several files, both in source comments and KConfig files.
There is no actual code changed, only text. Note this only affects the /arch
directory, and I believe I could find many more elsewhere. :)
As part of an SMP cleanliness pass over UML, I consted a bunch of
structures in order to not have to document their locking. One of these
structures was a struct tty_operations. In order to const it in UML
without introducing compiler complaints, the declaration of
tty_set_operations needs to be changed, and then all of its callers need to
be fixed.
This patch declares all struct tty_operations in the tree as const. In all
cases, they are static and used only as input to tty_set_operations. As an
extra check, I ran an i386 allyesconfig build which produced no extra
warnings.
53 drivers are affected. I checked the history of a bunch of them, and in
most cases, there have been only a handful of maintenance changes in the
last six months. serial_core.c was the busiest one that I looked at.
Signed-off-by: Jeff Dike <jdike@addtoit.com>
Acked-by: Alan Cox <alan@redhat.com>
Make lots of structures const in order to make it obvious that they need no
locking.
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Use the new IRQF_ constants and remove the SA_INTERRUPT define
Also fixes all drivers that set this field.
Also fixes up all files that #include it.
Fix some simple sparse warnings - a lot more staticness and a misplaced
__user.
Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Code cleanup - unregister_winch and winch_cleanup had some duplicate code.
This is now abstracted out into free_winch.
This patch cleans up the umid code:
- The only_if_set argument to get_umid is gone.
- get_umid returns an empty string rather than NULL if there is no umid.
- umid_is_random is gone since its users went away.
- Some printfs were turned into printks because the code runs late enough
that printk is working.
- Error paths were cleaned up.
- Some functions now return an error and let the caller print the error
message rather than printing it themselves. This eliminates the practice of
passing a pointer to printf or printk in, depending on where in the boot
process we are.
- Major tidying of not_dead_yet - mostly error path cleanup, plus a comment
explaining why it doesn't react to errors the way you might expect.
- Calls to os_* interfaces that were moved under os are changed back to
their native libc forms.
- snprintf, strlcpy, and their bounds-checking friends are used more often,
replacing by-hand bounds checking in some places.
This patch adds support for throttling and unthrottling input when the tty
driver can't handle it.
This patch simplifies the opening and closing of host console devices and the
registration and deregistration of IRQs. The intent is to make it obvious
that an IRQ can't exist without an open file descriptor.
chan_enable will now open the channel, and when both opening and IRQ
registration are desired, this should be used. Opening only is done for the
initial console, so that interface still needs to exist.
The free_irqs_later interface is now gone. It was intended to avoid freeing
an IRQ while it was being processed. It did this, but it didn't eliminate the
possiblity of free_irq being called from an interrupt, which is bad. In its
place is a list of irqs to be freed, which is processed by the signal handler
just before exiting. close_one_chan now disables irqs.
When a host device disappears, it is just closed, and that disables IRQs.
The device id registered with the IRQ is now the chan structure, not the tty.
This is because the interrupt arrives on a descriptor associated with the
channel. This caused equivalent changes in the arguments to line_timer_cb.
line_disable is gone since it is not used any more.
The count field in the line structure is gone. tty->count is used instead.
The complicated logic in sigio_handler with freeing IRQs when necessary and
making sure its idea of the next irq is correct is now much simpler. The irq
list can't be rearranged underneath it, so it is now a simple list walk.
This patch changes when console devices are configured in order to prepare the
ground for the next patch.
parse_chan_pair is now done earlier, when initcalls are run, rather than when
the device is opened.
When a host device disappears, the channel list is closed, but not freed.
This is required by the previous change. line_config now takes the options
structure as an argument, and line_open doesn't.
line_setup is changed to return the device which it set up, rather than just
success or failure. This will be important in the line-config patch.
Some structure fields were being dynamically initialized when they could be
initialized at compile-time instead. This also makes some declarations static
(in the C sense).
A bit of restructuring which eliminates the all_allowed argument (which is
mconsole-specific) to line_setup. That logic is moved to the mconsole
callback.
This removes a structure field which turned out to be pointless, and
references to it.
This patch makes a bunch of non-functional changes -
return(foo); becomes return foo;
some statements are broken across lines for readability
some trailing whitespace is cleaned up
open_one_chan took four arguments, three of which could be
deduced from the first. Accordingly, they were eliminated.
some examples of "} else {" had a newline added
some whitespace cleanup in the indentation
lines_init got some control flow cleanup
some long lines were broken
removed another emacs-specific C formatting comment
There were a bunch of calls to uml_strdup dating from before kstrdup was
introduced. This changes those calls. It doesn't eliminate the definition
since there is still a couple of calls in userspace code (which should
probably call the libc strdup).
Replace a semaphore (winch_handler_sem) used in atomic code with a
spinlock, and reduces as needed the amount of protected code to the bare
minimum (for instance no kmalloc calls are needed).
This fixes the last problems with spinlocking (in UP mode with DEBUG
options); the semaphore, taken inside spinlocks, caused a "spin_lock was
already locked" warning, without this patch.
Clean up the hot-unplugging code. There is now an id procedure which is
called to figure out what device we're talking to. The error messages from
that are now done from mconsole_remove instead of the driver. remove is now
called with the device number, after it has been checked, so doesn't need to
do sanity checking on it.
Cc: Paolo Giarrusso <blaisorblade@yahoo.it>
This occurrence of free_irq_by_irq_and_dev() was missed when converting UML
to the use of hw_controller_type->release.
With Chris Wedgwood <cw@f00f.org>
Currently UML must explicitly call the UML-specific
free_irq_by_irq_and_dev() for each free_irq call it's done.
This is needed because ->shutdown and/or ->disable are only called when the
last "action" for that irq is removed.
Instead, for UML shared IRQs (UML IRQs are very often, if not always,
shared), for each dev_id some setup is done, which must be cleared on the
release of that fd. For instance, for each open console a new instance
(i.e. new dev_id) of the same IRQ is requested().
Exactly, a fd is stored in an array (pollfds), which is after read by a
host thread and passed to poll(). Each event registered by poll() triggers
an interrupt. So, for each free_irq() we must remove the corresponding
host fd from the table, which we do via this -release() method.
In this patch we add an appropriate hook for this, and remove all uses of
it by pointing the hook to the said procedure; this is safe to do since the
said procedure.
Also some cosmetic improvements are included.
This is heavily based on some work by Chris Wedgwood, which however didn't
get the patch merged for something I'd call a "misunderstanding" (the need
for this patch wasn't cleanly explained, thus adding the generic hook was
felt as undesirable).
CC: Ingo Molnar <mingo@redhat.com>
This makes SIGWINCH work again, and fixes a couple of SIGWINCH-associated
crashes. First, the sigio thread disables SIGWINCH because all hell breaks
loose if it ever gets one and tries to call the signal handling code. Second,
there was a problem with deferencing tty structs after they were freed. The
SIGWINCH support for a tty wasn't being turned off or freed after the tty went
away.
Fix some console locking problems (including scheduling in atomic) and various
reorderings and cleanup in that code. Not yet ready for 2.6.12 probably.
infrastructure for it.
Let it rip!
