path: root/arch/um/drivers/cow_user.c
2019-12-18um: ubd: use 64-bit time_t where possibleArnd Bergmann
The ubd code suffers from a possible y2038 overflow on 32-bit architectures, both for the cow header and the os_file_modtime() function. Replace time_t with time64_t to extend the ubd_kern side as much as possible. Whether this makes a difference for the user side depends on the host libc implementation that may use either 32-bit or 64-bit time_t. For the cow file format, the header contains an unsigned 32-bit timestamp, which is good until y2106, passing this through a 'long long' gives us a consistent interpretation between 32-bit and 64-bit um kernels. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2019-09-15um: Add SPDX headers for files in arch/um/driversAlex Dewar
Convert files to use SPDX header. All files are licensed under the GPLv2. Signed-off-by: Alex Dewar <alex.dewar@gmx.co.uk> Signed-off-by: Richard Weinberger <richard@nod.at>
2012-04-10um: switch cow_user.h to htobe{32,64}/betoh{32,64}Al Viro
... rather than open-coding the 64bit versions. endian.h has those guys. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Richard Weinberger <richard@nod.at>
2011-07-25uml: cow_user.c warning correctionsVitaliy Ivanov
Fix this warning: arch/um/drivers/cow_user.c: In function `absolutize': arch/um/drivers/cow_user.c:189:7: warning: ignoring return value of `chdir', declared with attribute warn_unused_result [richard@nod.at: happens only with -D_FORTIFY_SOURCE=2] Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: arch/um/drivers formattingJeff Dike
Style fixes for the rest of the drivers. arch/um/drivers should be pretty CodingStyle-compliant now. Except for the ubd driver, which will have to be treated separately. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-05-01[PATCH] uml: fix patch mismergePaolo 'Blaisorblade' Giarrusso
I sent a patch, it was applied as cda402b283c34a24b091f78eee116963e9494762, then it was applied again as 181ae4005d0a4010802be534d929b38c42b9ac06 by mistake. But while the 1st time it modified (correctly) cow_header_v3, the 2nd it modified cow_header_v3_broken. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-19[PATCH] uml: make 64-bit COW files compatible with 32-bit onesPaolo 'Blaisorblade' Giarrusso
This is the minimal fix to make 64-bit UML binaries create 32-bit compatible COW files and read them. I've indeed tested that current code doesn't do this - the code gets SIGFPE for a division by a value read at the wrong place, where 0 is found. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] uml: fix 2 harmless cast warnings for 64-bitPaolo 'Blaisorblade' Giarrusso
Fix two harmless warnings in 64-bit compilation (the 2nd doesn't trigger for now because of a missing __attribute((format)) for cow_printf, but next patches fix that). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] uml: safe migration path to the correct V3 COW formatPaolo 'Blaisorblade' Giarrusso
- Correct the layout of all header versions - make all them well-specified for any external event. As we don't have 1-byte or 2-byte wide fields, the 32-bit layout (historical one) has no extra padding, so we can safely add __attribute__((packed)). - Add detection and reading of the broken 64-bit COW format which has been around for a while - to allow safe migration to the correct 32-bit format. Safe detection is possible, thanks to some luck with the existing format, and it works in practice. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] uml: make 64-bit COW files compatible with 32-bit onesPaolo 'Blaisorblade' Giarrusso
2006-02-24[PATCH] uml: tidying COW codePaolo 'Blaisorblade' Giarrusso
Improve (especially for coherence) some prototypes, and return code of init_cow_file in error case - for a short write return -EINVAL, otherwise return the error we got! Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-24[PATCH] uml: correct error messages in COW driverPaolo 'Blaisorblade' Giarrusso
Improve some error messages in the COW driver, and say V3, not V2, when talking about V3 format. Also resync with our userspace code utility a bit more. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-10[PATCH] uml: cleanup byte order macros for COW driverPaolo 'Blaisorblade' Giarrusso
After restoring the existing code, make it work also when included in kernelspace code (which isn't currently the case, but at least this will prevent people from "fixing" it as just happened). Whitespace is fixed in next patch - it cluttered the diff too much. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
