git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"PCI changes for the v3.14 merge window:
Resource management
- Change pci_bus_region addresses to dma_addr_t (Bjorn Helgaas)
- Support 64-bit AGP BARs (Bjorn Helgaas, Yinghai Lu)
- Add pci_bus_address() to get bus address of a BAR (Bjorn Helgaas)
- Use pci_resource_start() for CPU address of AGP BARs (Bjorn Helgaas)
- Enforce bus address limits in resource allocation (Yinghai Lu)
- Allocate 64-bit BARs above 4G when possible (Yinghai Lu)
- Convert pcibios_resource_to_bus() to take pci_bus, not pci_dev (Yinghai Lu)
PCI device hotplug
- Major rescan/remove locking update (Rafael J. Wysocki)
- Make ioapic builtin only (not modular) (Yinghai Lu)
- Fix release/free issues (Yinghai Lu)
- Clean up pciehp (Bjorn Helgaas)
- Announce pciehp slot info during enumeration (Bjorn Helgaas)
MSI
- Add pci_msi_vec_count(), pci_msix_vec_count() (Alexander Gordeev)
- Add pci_enable_msi_range(), pci_enable_msix_range() (Alexander Gordeev)
- Deprecate "tri-state" interfaces: fail/success/fail+info (Alexander Gordeev)
- Export MSI mode using attributes, not kobjects (Greg Kroah-Hartman)
- Drop "irq" param from *_restore_msi_irqs() (DuanZhenzhong)
SR-IOV
- Clear NumVFs when disabling SR-IOV in sriov_init() (ethan.zhao)
Virtualization
- Add support for save/restore of extended capabilities (Alex Williamson)
- Add Virtual Channel to save/restore support (Alex Williamson)
- Never treat a VF as a multifunction device (Alex Williamson)
- Add pci_try_reset_function(), et al (Alex Williamson)
AER
- Ignore non-PCIe error sources (Betty Dall)
- Support ACPI HEST error sources for domains other than 0 (Betty Dall)
- Consolidate HEST error source parsers (Bjorn Helgaas)
- Add a TLP header print helper (Borislav Petkov)
Freescale i.MX6
- Remove unnecessary code (Fabio Estevam)
- Make reset-gpio optional (Marek Vasut)
- Report "link up" only after link training completes (Marek Vasut)
- Start link in Gen1 before negotiating for Gen2 mode (Marek Vasut)
- Fix PCIe startup code (Richard Zhu)
Marvell MVEBU
- Remove duplicate of_clk_get_by_name() call (Andrew Lunn)
- Drop writes to bridge Secondary Status register (Jason Gunthorpe)
- Obey bridge PCI_COMMAND_MEM and PCI_COMMAND_IO bits (Jason Gunthorpe)
- Support a bridge with no IO port window (Jason Gunthorpe)
- Use max_t() instead of max(resource_size_t,) (Jingoo Han)
- Remove redundant of_match_ptr (Sachin Kamat)
- Call pci_ioremap_io() at startup instead of dynamically (Thomas Petazzoni)
NVIDIA Tegra
- Disable Gen2 for Tegra20 and Tegra30 (Eric Brower)
Renesas R-Car
- Add runtime PM support (Valentine Barshak)
- Fix rcar_pci_probe() return value check (Wei Yongjun)
Synopsys DesignWare
- Fix crash in dw_msi_teardown_irq() (Bjørn Erik Nilsen)
- Remove redundant call to pci_write_config_word() (Bjørn Erik Nilsen)
- Fix missing MSI IRQs (Harro Haan)
- Add dw_pcie prefix before cfg_read/write (Pratyush Anand)
- Fix I/O transfers by using CPU (not realio) address (Pratyush Anand)
- Whitespace cleanup (Jingoo Han)
EISA
- Call put_device() if device_register() fails (Levente Kurusa)
- Revert EISA initialization breakage ((Bjorn Helgaas)
Miscellaneous
- Remove unused code, including PCIe 3.0 interfaces (Stephen Hemminger)
- Prevent bus conflicts while checking for bridge apertures (Bjorn Helgaas)
- Stop clearing bridge Secondary Status when setting up I/O aperture (Bjorn Helgaas)
- Use dev_is_pci() to identify PCI devices (Yijing Wang)
- Deprecate DEFINE_PCI_DEVICE_TABLE (Joe Perches)
- Update documentation 00-INDEX (Erik Ekman)"
* tag 'pci-v3.14-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (119 commits)
Revert "EISA: Initialize device before its resources"
Revert "EISA: Log device resources in dmesg"
vfio-pci: Use pci "try" reset interface
PCI: Check parent kobject in pci_destroy_dev()
xen/pcifront: Use global PCI rescan-remove locking
powerpc/eeh: Use global PCI rescan-remove locking
PCI: Fix pci_check_and_unmask_intx() comment typos
PCI: Add pci_try_reset_function(), pci_try_reset_slot(), pci_try_reset_bus()
MPT / PCI: Use pci_stop_and_remove_bus_device_locked()
platform / x86: Use global PCI rescan-remove locking
PCI: hotplug: Use global PCI rescan-remove locking
pcmcia: Use global PCI rescan-remove locking
ACPI / hotplug / PCI: Use global PCI rescan-remove locking
ACPI / PCI: Use global PCI rescan-remove locking in PCI root hotplug
PCI: Add global pci_lock_rescan_remove()
PCI: Cleanup pci.h whitespace
PCI: Reorder so actual code comes before stubs
PCI/AER: Support ACPI HEST AER error sources for PCI domains other than 0
ACPICA: Add helper macros to extract bus/segment numbers from HEST table.
PCI: Make local functions static
[sfr@canb.auug.org.au: fix powerpc build]
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
Reviewed-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Cc: "Rafael J . Wysocki" <rjw@sisk.pl>
Cc: Chen Tang <imtangchen@gmail.com>
Cc: Gong Chen <gong.chen@linux.intel.com>
Cc: Jiang Liu <jiang.liu@huawei.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Larry Woodman <lwoodman@redhat.com>
Cc: Len Brown <lenb@kernel.org>
Cc: Liu Jiang <jiang.liu@huawei.com>
Cc: Michal Nazarewicz <mina86@mina86.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Taku Izumi <izumi.taku@jp.fujitsu.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Thomas Renninger <trenn@suse.de>
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: Vasilis Liaskovitis <vasilis.liaskovitis@profitbricks.com>
Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Cc: Wen Congyang <wency@cn.fujitsu.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Pull core locking changes from Ingo Molnar:
- futex performance increases: larger hashes, smarter wakeups
- mutex debugging improvements
- lots of SMP ordering documentation updates
- introduce the smp_load_acquire(), smp_store_release() primitives.
(There are WIP patches that make use of them - not yet merged)
- lockdep micro-optimizations
- lockdep improvement: better cover IRQ contexts
- liblockdep at last. We'll continue to monitor how useful this is
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (34 commits)
futexes: Fix futex_hashsize initialization
arch: Re-sort some Kbuild files to hopefully help avoid some conflicts
futexes: Avoid taking the hb->lock if there's nothing to wake up
futexes: Document multiprocessor ordering guarantees
futexes: Increase hash table size for better performance
futexes: Clean up various details
arch: Introduce smp_load_acquire(), smp_store_release()
arch: Clean up asm/barrier.h implementations using asm-generic/barrier.h
arch: Move smp_mb__{before,after}_atomic_{inc,dec}.h into asm/atomic.h
locking/doc: Rename LOCK/UNLOCK to ACQUIRE/RELEASE
mutexes: Give more informative mutex warning in the !lock->owner case
powerpc: Full barrier for smp_mb__after_unlock_lock()
rcu: Apply smp_mb__after_unlock_lock() to preserve grace periods
Documentation/memory-barriers.txt: Downgrade UNLOCK+BLOCK
locking: Add an smp_mb__after_unlock_lock() for UNLOCK+BLOCK barrier
Documentation/memory-barriers.txt: Document ACCESS_ONCE()
Documentation/memory-barriers.txt: Prohibit speculative writes
Documentation/memory-barriers.txt: Add long atomic examples to memory-barriers.txt
Documentation/memory-barriers.txt: Add needed ACCESS_ONCE() calls to memory-barriers.txt
Revert "smp/cpumask: Make CONFIG_CPUMASK_OFFSTACK=y usable without debug dependency"
At first Jakub Zawadzki noticed that some divisions by reciprocal_divide
were not correct. (off by one in some cases)
http://www.wireshark.org/~darkjames/reciprocal-buggy.c
He could also show this with BPF:
http://www.wireshark.org/~darkjames/set-and-dump-filter-k-bug.c
The reciprocal divide in linux kernel is not generic enough,
lets remove its use in BPF, as it is not worth the pain with
current cpus.
Reported-by: Jakub Zawadzki <darkjames-ws@darkjames.pl>
Cc: Mircea Gherzan <mgherzan@gmail.com>
Cc: Daniel Borkmann <dxchgb@gmail.com>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: Matt Evans <matt@ozlabs.org>
Refresh the tree with the latest fixes, before applying new changes.
A number of situations currently require the heavyweight smp_mb(),
even though there is no need to order prior stores against later
loads. Many architectures have much cheaper ways to handle these
situations, but the Linux kernel currently has no portable way
to make use of them.
This commit therefore supplies smp_load_acquire() and
smp_store_release() to remedy this situation. The new
smp_load_acquire() primitive orders the specified load against
any subsequent reads or writes, while the new smp_store_release()
primitive orders the specifed store against any prior reads or
writes. These primitives allow array-based circular FIFOs to be
implemented without an smp_mb(), and also allow a theoretical
hole in rcu_assign_pointer() to be closed at no additional
expense on most architectures.
In addition, the RCU experience transitioning from explicit
smp_read_barrier_depends() and smp_wmb() to rcu_dereference()
and rcu_assign_pointer(), respectively resulted in substantial
improvements in readability. It therefore seems likely that
replacing other explicit barriers with smp_load_acquire() and
smp_store_release() will provide similar benefits. It appears
that roughly half of the explicit barriers in core kernel code
might be so replaced.
[Changelog by PaulMck]
Reviewed-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: Michael Ellerman <michael@ellerman.id.au>
Cc: Michael Neuling <mikey@neuling.org>
Cc: Victor Kaplansky <VICTORK@il.ibm.com>
Link: http://lkml.kernel.org/r/20131213150640.908486364@infradead.org
We're going to be adding a few new barrier primitives, and in order to
avoid endless duplication make more agressive use of
asm-generic/barrier.h.
Change the asm-generic/barrier.h such that it allows partial barrier
definitions and fills out the rest with defaults.
There are a few architectures (m32r, m68k) that could probably
do away with their barrier.h file entirely but are kept for now due to
their unconventional nop() implementation.
Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Link: http://lkml.kernel.org/r/20131213150640.846368594@infradead.org
* pci/resource:
PCI: Allocate 64-bit BARs above 4G when possible
PCI: Enforce bus address limits in resource allocation
PCI: Split out bridge window override of minimum allocation address
agp/ati: Use PCI_COMMAND instead of hard-coded 4
agp/intel: Use CPU physical address, not bus address, for ioremap()
agp/intel: Use pci_bus_address() to get GTTADR bus address
agp/intel: Use pci_bus_address() to get MMADR bus address
agp/intel: Support 64-bit GMADR
agp/intel: Rename gtt_bus_addr to gtt_phys_addr
drm/i915: Rename gtt_bus_addr to gtt_phys_addr
agp: Use pci_resource_start() to get CPU physical address for BAR
agp: Support 64-bit APBASE
PCI: Add pci_bus_address() to get bus address of a BAR
PCI: Convert pcibios_resource_to_bus() to take a pci_bus, not a pci_dev
PCI: Change pci_bus_region addresses to dma_addr_t
Pull sparc bugfixes from David Miller:
1) Missing include can lead to build failure, from Kirill Tkhai.
2) Use dev_is_pci() where applicable, from Yijing Wang.
3) Enable irqs after we enable preemption in cpu startup path, from
Kirill Tkhai.
4) Revert a __copy_{to,from}_user_inatomic change that broke
iov_iter_copy_from_user_atomic() and thus several tests in xfstests
and LTP. From Dave Kleikamp.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc:
Revert "sparc64: Fix __copy_{to,from}_user_inatomic defines."
sparc64: smp_callin: Enable irqs after preemption is disabled
sparc/PCI: Use dev_is_pci() to identify PCI devices
sparc64: Fix build regression
This reverts commit 145e1c0023585e0e8f6df22316308ec61c5066b2.
This commit broke the behavior of __copy_from_user_inatomic when
it is only partially successful. Instead of returning the number
of bytes not copied, it now returns 1. This translates to the
wrong value being returned by iov_iter_copy_from_user_atomic.
xfstests generic/246 and LTP writev01 both fail on btrfs and nfs
because of this.
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
Cc: sparclinux@vger.kernel.org
Most of other architectures have below suggested order.
So lets do the same to fit generic idle loop scheme better.
Signed-off-by: Kirill Tkhai <tkhai@yandex.ru>
Use dev_is_pci() instead of checking bus type directly.
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
These interfaces:
pcibios_resource_to_bus(struct pci_dev *dev, *bus_region, *resource)
pcibios_bus_to_resource(struct pci_dev *dev, *resource, *bus_region)
took a pci_dev, but they really depend only on the pci_bus. And we want to
use them in resource allocation paths where we have the bus but not a
device, so this patch converts them to take the pci_bus instead of the
pci_dev:
pcibios_resource_to_bus(struct pci_bus *bus, *bus_region, *resource)
pcibios_bus_to_resource(struct pci_bus *bus, *resource, *bus_region)
In fact, with standard PCI-PCI bridges, they only depend on the host
bridge, because that's the only place address translation occurs, but
we aren't going that far yet.
[bhelgaas: changelog]
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
There are a few subtle races, between change_protection_range (used by
mprotect and change_prot_numa) on one side, and NUMA page migration and
compaction on the other side.
The basic race is that there is a time window between when the PTE gets
made non-present (PROT_NONE or NUMA), and the TLB is flushed.
During that time, a CPU may continue writing to the page.
This is fine most of the time, however compaction or the NUMA migration
code may come in, and migrate the page away.
When that happens, the CPU may continue writing, through the cached
translation, to what is no longer the current memory location of the
process.
This only affects x86, which has a somewhat optimistic pte_accessible.
All other architectures appear to be safe, and will either always flush,
or flush whenever there is a valid mapping, even with no permissions
(SPARC).
The basic race looks like this:
CPU A CPU B CPU C
load TLB entry
make entry PTE/PMD_NUMA
fault on entry
read/write old page
start migrating page
change PTE/PMD to new page
read/write old page [*]
flush TLB
reload TLB from new entry
read/write new page
lose data
[*] the old page may belong to a new user at this point!
The obvious fix is to flush remote TLB entries, by making sure that
pte_accessible aware of the fact that PROT_NONE and PROT_NUMA memory may
still be accessible if there is a TLB flush pending for the mm.
This should fix both NUMA migration and compaction.
[mgorman@suse.de: fix build]
Signed-off-by: Rik van Riel <riel@redhat.com>
Cc: Alex Thorlton <athorlton@sgi.com>
Cc: <stable@vger.kernel.org>
This patch fixes build error which was introduced by commit
812cb83a56a908729c453a7db3fb2c262119bc9d (Implement HAVE_CONTEXT_TRACKING).
[*]https://lkml.org/lkml/2013/11/23/103
CC: David Miller <davem@davemloft.net>
Pull sparc fixes from David Miller:
"Two merge window fallout build fixes"
sparc64: merge fix
sparc64: fix build regession
Pull irq cleanups from Ingo Molnar:
"This is a multi-arch cleanup series from Thomas Gleixner, which we
kept to near the end of the merge window, to not interfere with
architecture updates.
This series (motivated by the -rt kernel) unifies more aspects of IRQ
handling and generalizes PREEMPT_ACTIVE"
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
preempt: Make PREEMPT_ACTIVE generic
sparc: Use preempt_schedule_irq
ia64: Use preempt_schedule_irq
m32r: Use preempt_schedule_irq
hardirq: Make hardirq bits generic
m68k: Simplify low level interrupt handling code
genirq: Prevent spurious detection for unconditionally polled interrupts
After merging the final tree, today's linux-next build (sparc64 defconfig)
failed like this:
arch/sparc/mm/init_64.c: In function 'pte_alloc_one':
arch/sparc/mm/init_64.c:2568:9: error: unused variable 'pte' [-Werror=unused-variable]
Caused by the merge between commit 37b3a8ff3e08 ("sparc64: Move from 4MB
to 8MB huge pages") and commit 1ae9ae5f7df7 ("sparc: handle
pgtable_page_ctor() fail") (I had the following merge fix in linux-next,
but it didn't seem to propagate upstream - may have forgotten to point it
out :-().
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Commit ea1e7ed33708 triggers build regression on sparc64.
include/linux/mm.h:1391:2: error: implicit declaration of function 'pgtable_cache_init' [-Werror=implicit-function-declaration]
arch/sparc/include/asm/pgtable_64.h:978:13: error: conflicting types for 'pgtable_cache_init' [-Werror]
It happens due headers include loop:
<linux/mm.h> -> <asm/pgtable.h> -> <asm/pgtable_64.h> ->
<asm/tlbflush.h> -> <asm/tlbflush_64.h> -> <linux/mm.h>
Let's drop <linux/mm.h> include from asm/tlbflush_64.h.
Build tested with allmodconfig.
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Pull trivial tree updates from Jiri Kosina:
"Usual earth-shaking, news-breaking, rocket science pile from
trivial.git"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (23 commits)
doc: usb: Fix typo in Documentation/usb/gadget_configs.txt
doc: add missing files to timers/00-INDEX
timekeeping: Fix some trivial typos in comments
mm: Fix some trivial typos in comments
irq: Fix some trivial typos in comments
NUMA: fix typos in Kconfig help text
mm: update 00-INDEX
doc: Documentation/DMA-attributes.txt fix typo
DRM: comment: `halve' -> `half'
Docs: Kconfig: `devlopers' -> `developers'
doc: typo on word accounting in kprobes.c in mutliple architectures
treewide: fix "usefull" typo
treewide: fix "distingush" typo
mm/Kconfig: Grammar s/an/a/
kexec: Typo s/the/then/
Documentation/kvm: Update cpuid documentation for steal time and pv eoi
treewide: Fix common typo in "identify"
__page_to_pfn: Fix typo in comment
Correct some typos for word frequency
clk: fixed-factor: Fix a trivial typo
Pull Kconfig cleanups from Mark Salter:
"Remove some unused config options from C6X and clean up PC_PARPORT
dependencies. The latter was discussed here:
https://lkml.org/lkml/2013/10/8/12"
* tag 'for-linus' of git://linux-c6x.org/git/projects/linux-c6x-upstreaming:
c6x: remove unused COMMON_CLKDEV Kconfig parameter
Kconfig cleanup (PARPORT_PC dependencies)
x86: select ARCH_MIGHT_HAVE_PC_PARPORT
unicore32: select ARCH_MIGHT_HAVE_PC_PARPORT
sparc: select ARCH_MIGHT_HAVE_PC_PARPORT
sh: select ARCH_MIGHT_HAVE_PC_PARPORT
powerpc: select ARCH_MIGHT_HAVE_PC_PARPORT
parisc: select ARCH_MIGHT_HAVE_PC_PARPORT
mips: select ARCH_MIGHT_HAVE_PC_PARPORT
microblaze: select ARCH_MIGHT_HAVE_PC_PARPORT
m68k: select ARCH_MIGHT_HAVE_PC_PARPORT
ia64: select ARCH_MIGHT_HAVE_PC_PARPORT
arm: select ARCH_MIGHT_HAVE_PC_PARPORT
alpha: select ARCH_MIGHT_HAVE_PC_PARPORT
c6x: remove unused parameter in Kconfig
Pull sparc update from David Miller:
1) Implement support for up to 47-bit physical addresses on sparc64.
2) Support HAVE_CONTEXT_TRACKING on sparc64, from Kirill Tkhai.
3) Fix Simba bridge window calculations, from Kjetil Oftedal.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next:
sparc64: Implement HAVE_CONTEXT_TRACKING
sparc64: Add self-IPI support for smp_send_reschedule()
sparc: PCI: Fix incorrect address calculation of PCI Bridge windows on Simba-bridges
sparc64: Encode huge PMDs using PTE encoding.
sparc64: Move to 64-bit PGDs and PMDs.
sparc64: Move from 4MB to 8MB huge pages.
sparc64: Make PAGE_OFFSET variable.
sparc64: Fix inconsistent max-physical-address defines.
sparc64: Document the shift counts used to validate linear kernel addresses.
sparc64: Define PAGE_OFFSET in terms of physical address bits.
sparc64: Use PAGE_OFFSET instead of a magic constant.
sparc64: Clean up 64-bit mmap exclusion defines.
We've switched over every architecture that supports SMP to it, so
remove the new useless config variable.
Cc: Jan Kara <jack@suse.cz>
Currently mm->pmd_huge_pte protected by page table lock. It will not
work with split lock. We have to have per-pmd pmd_huge_pte for proper
access serialization.
For now, let's just introduce wrapper to access mm->pmd_huge_pte.
Tested-by: Alex Thorlton <athorlton@sgi.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: "Eric W . Biederman" <ebiederm@xmission.com>
Cc: "Paul E . McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Robin Holt <robinmholt@gmail.com>
Cc: Sedat Dilek <sedat.dilek@gmail.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Mark the places when the system are in user or are in kernel.
This is used to make full dynticks system (tickless) --
CONFIG_NO_HZ_FULL dependence.
CONFIG_NO_HZ_FULL requires possibility of smp_send_reschedule()
for the calling CPU. Currently, it is used in inc_nr_running()
scheduler primitive only.
Nobody calls smp_send_reschedule() from preemptible context
(furthermore, it looks like it will be save if anybody use it
another way in the future). But anyway I add WARN_ON() here
just to return here if anything changes.
Simba-bridges
The SIMBA APB Bridges lacks the 'ranges' of-property describing the
PCI I/O and memory areas located beneath the bridge. Faking this
information has been performed by reading range registers in the
APB bridge, and calculating the corresponding areas.
In commit 01f94c4a6ced476ce69b895426fc29bfc48c69bd
("Fix sabre pci controllers with new probing scheme.") a bug was
introduced into this calculation, causing the PCI memory areas
to be calculated incorrectly: The shift size was set to be
identical for I/O and MEM ranges, which is incorrect.
This patch set the shift size of the MEM range back to the
value used before 01f94c4a6ced476ce69b895426fc29bfc48c69bd.
Signed-off-by: Kjetil Oftedal <oftedal@gmail.com>
Now that we have 64-bits for PMDs we can stop using special encodings
for the huge PMD values, and just put real PTEs in there.
We allocate a _PAGE_PMD_HUGE bit to distinguish between plain PMDs and
huge ones. It is the same for both 4U and 4V PTE layouts.
We also use _PAGE_SPECIAL to indicate the splitting state, since a
huge PMD cannot also be special.
All of the PMD --> PTE translation code disappears, and most of the
huge PMD bit modifications and tests just degenerate into the PTE
operations. In particular USER_PGTABLE_CHECK_PMD_HUGE becomes
trivial.
As a side effect, normal PMDs don't shift the physical address around.
This also speeds up the page table walks in the TLB miss paths since
they don't have to do the shifts any more.
Another non-trivial aspect is that pte_modify() has to be changed
to preserve the _PAGE_PMD_HUGE bits as well as the page size field
of the pte.
No point in having this bit defined by architecture.
Acked-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/20130917183629.090698799@linutronix.de
The low level preemption code fiddles with the PREEMPT_ACTIVE bit for
no reason and calls schedule() with interrupts disabled, which is
wrong to begin with. Remove the PREEMPT_ACTIVE fiddling and call the
proper schedule_preempt_irq() function.
Link: http://lkml.kernel.org/r/20130917183628.966769884@linutronix.de
There is no reason for per arch hardirq bits. Make them all generic
Link: http://lkml.kernel.org/r/20130917183628.534494408@linutronix.de
Pull networking updates from David Miller:
1) The addition of nftables. No longer will we need protocol aware
firewall filtering modules, it can all live in userspace.
At the core of nftables is a, for lack of a better term, virtual
machine that executes byte codes to inspect packet or metadata
(arriving interface index, etc.) and make verdict decisions.
Besides support for loading packet contents and comparing them, the
interpreter supports lookups in various datastructures as
fundamental operations. For example sets are supports, and
therefore one could create a set of whitelist IP address entries
which have ACCEPT verdicts attached to them, and use the appropriate
byte codes to do such lookups.
Since the interpreted code is composed in userspace, userspace can
do things like optimize things before giving it to the kernel.
Another major improvement is the capability of atomically updating
portions of the ruleset. In the existing netfilter implementation,
one has to update the entire rule set in order to make a change and
this is very expensive.
Userspace tools exist to create nftables rules using existing
netfilter rule sets, but both kernel implementations will need to
co-exist for quite some time as we transition from the old to the
new stuff.
Kudos to Patrick McHardy, Pablo Neira Ayuso, and others who have
worked so hard on this.
2) Daniel Borkmann and Hannes Frederic Sowa made several improvements
to our pseudo-random number generator, mostly used for things like
UDP port randomization and netfitler, amongst other things.
In particular the taus88 generater is updated to taus113, and test
cases are added.
3) Support 64-bit rates in HTB and TBF schedulers, from Eric Dumazet
and Yang Yingliang.
4) Add support for new 577xx tigon3 chips to tg3 driver, from Nithin
Sujir.
5) Fix two fatal flaws in TCP dynamic right sizing, from Eric Dumazet,
Neal Cardwell, and Yuchung Cheng.
6) Allow IP_TOS and IP_TTL to be specified in sendmsg() ancillary
control message data, much like other socket option attributes.
From Francesco Fusco.
7) Allow applications to specify a cap on the rate computed
automatically by the kernel for pacing flows, via a new
SO_MAX_PACING_RATE socket option. From Eric Dumazet.
8) Make the initial autotuned send buffer sizing in TCP more closely
reflect actual needs, from Eric Dumazet.
9) Currently early socket demux only happens for TCP sockets, but we
can do it for connected UDP sockets too. Implementation from Shawn
Bohrer.
10) Refactor inet socket demux with the goal of improving hash demux
performance for listening sockets. With the main goals being able
to use RCU lookups on even request sockets, and eliminating the
listening lock contention. From Eric Dumazet.
11) The bonding layer has many demuxes in it's fast path, and an RCU
conversion was started back in 3.11, several changes here extend the
RCU usage to even more locations. From Ding Tianhong and Wang
Yufen, based upon suggestions by Nikolay Aleksandrov and Veaceslav
Falico.
12) Allow stackability of segmentation offloads to, in particular, allow
segmentation offloading over tunnels. From Eric Dumazet.
13) Significantly improve the handling of secret keys we input into the
various hash functions in the inet hashtables, TCP fast open, as
well as syncookies. From Hannes Frederic Sowa. The key fundamental
operation is "net_get_random_once()" which uses static keys.
Hannes even extended this to ipv4/ipv6 fragmentation handling and
our generic flow dissector.
14) The generic driver layer takes care now to set the driver data to
NULL on device removal, so it's no longer necessary for drivers to
explicitly set it to NULL any more. Many drivers have been cleaned
up in this way, from Jingoo Han.
15) Add a BPF based packet scheduler classifier, from Daniel Borkmann.
16) Improve CRC32 interfaces and generic SKB checksum iterators so that
SCTP's checksumming can more cleanly be handled. Also from Daniel
Borkmann.
17) Add a new PMTU discovery mode, IP_PMTUDISC_INTERFACE, which forces
using the interface MTU value. This helps avoid PMTU attacks,
particularly on DNS servers. From Hannes Frederic Sowa.
18) Use generic XPS for transmit queue steering rather than internal
(re-)implementation in virtio-net. From Jason Wang.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1622 commits)
random32: add test cases for taus113 implementation
random32: upgrade taus88 generator to taus113 from errata paper
random32: move rnd_state to linux/random.h
random32: add prandom_reseed_late() and call when nonblocking pool becomes initialized
random32: add periodic reseeding
random32: fix off-by-one in seeding requirement
PHY: Add RTL8201CP phy_driver to realtek
xtsonic: add missing platform_set_drvdata() in xtsonic_probe()
macmace: add missing platform_set_drvdata() in mace_probe()
ethernet/arc/arc_emac: add missing platform_set_drvdata() in arc_emac_probe()
ipv6: protect for_each_sk_fl_rcu in mem_check with rcu_read_lock_bh
vlan: Implement vlan_dev_get_egress_qos_mask as an inline.
ixgbe: add warning when max_vfs is out of range.
igb: Update link modes display in ethtool
netfilter: push reasm skb through instead of original frag skbs
ip6_output: fragment outgoing reassembled skb properly
MAINTAINERS: mv643xx_eth: take over maintainership from Lennart
net_sched: tbf: support of 64bit rates
ixgbe: deleting dfwd stations out of order can cause null ptr deref
ixgbe: fix build err, num_rx_queues is only available with CONFIG_RPS
Merge first patch-bomb from Andrew Morton:
"Quite a lot of other stuff is banked up awaiting further
next->mainline merging, but this batch contains:
- Lots of random misc patches
- OCFS2
- Most of MM
- backlight updates
- lib/ updates
- printk updates
- checkpatch updates
- epoll tweaking
- rtc updates
- hfs
- hfsplus
- documentation
- procfs
- update gcov to gcc-4.7 format
- IPC"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (269 commits)
ipc, msg: fix message length check for negative values
ipc/util.c: remove unnecessary work pending test
devpts: plug the memory leak in kill_sb
./Makefile: export initial ramdisk compression config option
init/Kconfig: add option to disable kernel compression
drivers: w1: make w1_slave::flags long to avoid memory corruption
drivers/w1/masters/ds1wm.cuse dev_get_platdata()
drivers/memstick/core/ms_block.c: fix unreachable state in h_msb_read_page()
drivers/memstick/core/mspro_block.c: fix attributes array allocation
drivers/pps/clients/pps-gpio.c: remove redundant of_match_ptr
kernel/panic.c: reduce 1 byte usage for print tainted buffer
gcov: reuse kbasename helper
kernel/gcov/fs.c: use pr_warn()
kernel/module.c: use pr_foo()
gcov: compile specific gcov implementation based on gcc version
gcov: add support for gcc 4.7 gcov format
gcov: move gcov structs definitions to a gcc version specific file
kernel/taskstats.c: return -ENOMEM when alloc memory fails in add_del_listener()
kernel/taskstats.c: add nla_nest_cancel() for failure processing between nla_nest_start() and nla_nest_end()
kernel/sysctl_binary.c: use scnprintf() instead of snprintf()
Pull vfs updates from Al Viro:
"All kinds of stuff this time around; some more notable parts:
- RCU'd vfsmounts handling
- new primitives for coredump handling
- files_lock is gone
- Bruce's delegations handling series
- exportfs fixes
plus misc stuff all over the place"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (101 commits)
ecryptfs: ->f_op is never NULL
locks: break delegations on any attribute modification
locks: break delegations on link
locks: break delegations on rename
locks: helper functions for delegation breaking
locks: break delegations on unlink
namei: minor vfs_unlink cleanup
locks: implement delegations
locks: introduce new FL_DELEG lock flag
vfs: take i_mutex on renamed file
vfs: rename I_MUTEX_QUOTA now that it's not used for quotas
vfs: don't use PARENT/CHILD lock classes for non-directories
vfs: pull ext4's double-i_mutex-locking into common code
exportfs: fix quadratic behavior in filehandle lookup
exportfs: better variable name
exportfs: move most of reconnect_path to helper function
exportfs: eliminate unused "noprogress" counter
exportfs: stop retrying once we race with rename/remove
exportfs: clear DISCONNECTED on all parents sooner
exportfs: more detailed comment for path_reconnect
glibc recently changed the error string for ESTALE to remove "NFS" -
https://sourceware.org/git/?p=glibc.git;a=commitdiff;h=96945714ec61951cc748da2b4b8a80cf02127ee9
from: [ERR_REMAP (ESTALE)] = N_("Stale NFS file handle"),
to: [ERR_REMAP (ESTALE)] = N_("Stale file handle"),
And some have expressed concern that the kernel's errno.h
comments still refer to NFS.
So make that change... note that this is a comment-only change,
and has no functional difference.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Use more appropriate NUMA_NO_NODE instead of -1 in all archs' module_alloc()
Signed-off-by: Jianguo Wu <wujianguo@huawei.com>
Acked-by: David Rientjes <rientjes@google.com>
To make the page tables compact, we were using 32-bit PGDs and PMDs.
We only had to support <= 43 bits of physical addresses so this was
quite feasible.
In order to support larger physical addresses we have to move to
Most of the changes are straight-forward:
1) {pgd,pmd}_t --> unsigned long
2) Anything that tries to use plain "unsigned int" types with pgd/pmd
values needs to be adjusted. In particular things like "0U" become
"0UL".
3) {PGDIR,PMD}_BITS decrease by one.
4) In the assembler page table walkers, use "ldxa" instead of "lduwa"
and adjust the low bit masks to clear out the low 3 bits instead of
just the low 2 bits during pgd/pmd address formation.
Also, use PTRS_PER_PGD and PTRS_PER_PMD in the sizing of the
swapper_{pg_dir,low_pmd_dir} arrays.
This patch does not try to take advantage of having 64-bits in the
PMDs to simplify the hugepage code, that will come in a subsequent
change.
The impetus for this is that we would like to move to 64-bit PMDs and
PGDs, but that would result in only supporting a 42-bit address space
with the current page table layout. It'd be nice to support at least
43-bits.
The reason we'd end up with only 42-bits after making PMDs and PGDs
64-bit is that we only use half-page sized PTE tables in order to make
PMDs line up to 4MB, the hardware huge page size we use.
So what we do here is we make huge pages 8MB, and fabricate them using
4MB hw TLB entries.
Facilitate this by providing a "REAL_HPAGE_SHIFT" which is used in
places that really need to operate on hardware 4MB pages.
Use full pages (512 entries) for PTE tables, and adjust PMD_SHIFT,
PGD_SHIFT, and the build time CPP test as needed. Use a CPP test to
make sure REAL_HPAGE_SHIFT and the _PAGE_SZHUGE_* we use match up.
This makes the pgtable cache completely unused, so remove the code
managing it and the state used in mm_context_t. Now we have less
spinlocks taken in the page table allocation path.
The technique we use to fabricate the 8MB pages is to transfer bit 22
from the missing virtual address into the PTEs physical address field.
That takes care of the transparent huge pages case.
For hugetlb, we fill things in at the PTE level and that code already
puts the sub huge page physical bits into the PTEs, based upon the
offset, so there is nothing special we need to do. It all just works
out.
So, a small amount of complexity in the THP case, but this code is
about to get much simpler when we move the 64-bit PMDs as we can move
away from the fancy 32-bit huge PMD encoding and just put a real PTE
value in there.
With bug fixes and help from Bob Picco.
Choose PAGE_OFFSET dynamically based upon cpu type.
Original UltraSPARC-I (spitfire) chips only supported a 44-bit
virtual address space.
Newer chips (T4 and later) support 52-bit virtual addresses
and up to 47-bits of physical memory space.
Therefore we have to adjust PAGE_SIZE dynamically based upon
the capabilities of the chip.
Note that this change alone does not allow us to support > 43-bit
physical memory, to do that we need to re-arrange our page table
support. The current encodings of the pmd_t and pgd_t pointers
restricts us to "32 + 11" == 43 bits.
This change can waste quite a bit of memory for the various tables.
In particular, a future change should work to size and allocate
kern_linear_bitmap[] and sparc64_valid_addr_bitmap[] dynamically.
This isn't easy as we really cannot take a TLB miss when accessing
kern_linear_bitmap[]. We'd have to lock it into the TLB or similar.
Acked-by: Bob Picco <bob.picco@oracle.com>
Some parts of the code use '41' others use '42', make them
all use the same value.
This way we can see exactly what they are derived from, and in particular
how they would change if we were to use a different PAGE_OFFSET value.
This makes clearer the implications for a given choosen
value.
Based upon patches by Bob Picco.
This pertains to all of the computations of the kernel fast
TLB miss xor values.
Based upon a patch by Bob Picco.
Older UltraSPARC chips had an address space hole due to the MMU only
supporting 44-bit virtual addresses.
The top end of this hole also has the same value as the current
definition of PAGE_OFFSET, so this can be confusing.
Consolidate the defines for the userspace mmap exclusion range into
page_64.h and use them in sys_sparc_64.c and hugetlbpage.c
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull devicetree updates from Rob Herring:
"DeviceTree updates for 3.13. This is a bit larger pull request than
usual for this cycle with lots of clean-up.
- Cross arch clean-up and consolidation of early DT scanning code.
- Clean-up and removal of arch prom.h headers. Makes arch specific
prom.h optional on all but Sparc.
- Addition of interrupts-extended property for devices connected to
multiple interrupt controllers.
- Refactoring of DT interrupt parsing code in preparation for
deferred probe of interrupts.
- ARM cpu and cpu topology bindings documentation.
- Various DT vendor binding documentation updates"
* tag 'devicetree-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (82 commits)
powerpc: add missing explicit OF includes for ppc
dt/irq: add empty of_irq_count for !OF_IRQ
dt: disable self-tests for !OF_IRQ
of: irq: Fix interrupt-map entry matching
MIPS: Netlogic: replace early_init_devtree() call
of: Add Panasonic Corporation vendor prefix
of: Add Chunghwa Picture Tubes Ltd. vendor prefix
of: Add AU Optronics Corporation vendor prefix
of/irq: Fix potential buffer overflow
of/irq: Fix bug in interrupt parsing refactor.
of: set dma_mask to point to coherent_dma_mask
of: add vendor prefix for PHYTEC Messtechnik GmbH
DT: sort vendor-prefixes.txt
of: Add vendor prefix for Cadence
of: Add empty for_each_available_child_of_node() macro definition
arm/versatile: Fix versatile irq specifications.
of/irq: create interrupts-extended property
microblaze/pci: Drop PowerPC-ism from irq parsing
of/irq: Create of_irq_parse_and_map_pci() to consolidate arch code.
of/irq: Use irq_of_parse_and_map()
Pull scheduler changes from Ingo Molnar:
"The main changes in this cycle are:
- (much) improved CONFIG_NUMA_BALANCING support from Mel Gorman, Rik
van Riel, Peter Zijlstra et al. Yay!
- optimize preemption counter handling: merge the NEED_RESCHED flag
into the preempt_count variable, by Peter Zijlstra.
- wait.h fixes and code reorganization from Peter Zijlstra
- cfs_bandwidth fixes from Ben Segall
- SMP load-balancer cleanups from Peter Zijstra
- idle balancer improvements from Jason Low
- other fixes and cleanups"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (129 commits)
ftrace, sched: Add TRACE_FLAG_PREEMPT_RESCHED
stop_machine: Fix race between stop_two_cpus() and stop_cpus()
sched: Remove unnecessary iteration over sched domains to update nr_busy_cpus
sched: Fix asymmetric scheduling for POWER7
sched: Move completion code from core.c to completion.c
sched: Move wait code from core.c to wait.c
sched: Move wait.c into kernel/sched/
sched/wait: Fix __wait_event_interruptible_lock_irq_timeout()
sched: Avoid throttle_cfs_rq() racing with period_timer stopping
sched: Guarantee new group-entities always have weight
sched: Fix hrtimer_cancel()/rq->lock deadlock
sched: Fix cfs_bandwidth misuse of hrtimer_expires_remaining
sched: Fix race on toggling cfs_bandwidth_used
sched: Remove extra put_online_cpus() inside sched_setaffinity()
sched/rt: Fix task_tick_rt() comment
sched/wait: Fix build breakage
sched/wait: Introduce prepare_to_wait_event()
sched/wait: Add ___wait_cond_timeout() to wait_event*_timeout() too
sched: Remove get_online_cpus() usage
sched: Fix race in migrate_swap_stop()
Pull IRQ changes from Ingo Molnar:
"The biggest change this cycle are the softirq/hardirq stack
interaction and nesting fixes, cleanups and reorganizations from
Frederic. This is the longer followup story to the softirq nesting
fix that is already upstream (commit ded797547548: "irq: Force hardirq
exit's softirq processing on its own stack")"
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
irqchip: bcm2835: Convert to use IRQCHIP_DECLARE macro
powerpc: Tell about irq stack coverage
x86: Tell about irq stack coverage
irq: Optimize softirq stack selection in irq exit
irq: Justify the various softirq stack choices
irq: Improve a bit softirq debugging
irq: Optimize call to softirq on hardirq exit
irq: Consolidate do_softirq() arch overriden implementations
x86/irq: Correct comment about i8259 initialization
