path: root/arch/sparc64/solaris/entry64.S
2008-04-21[SPARC]: Remove SunOS and Solaris binary support.David S. Miller
As per Documentation/feature-removal-schedule.txt Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-04[SPARC64]: Mark __ex_table section correctly.David S. Miller
We must use the "a" (allocate) attribute every time we emit an entry into the __ex_table section. For consistency, use "a" instead of #alloc which is some Solaris compat cruft GNU as provides on Sparc. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-19[SPARC]: Add support for *at(), ppoll, and pselect syscalls.David S. Miller
This also includes by necessity _TIF_RESTORE_SIGMASK support, which actually resulted in a lot of cleanups. The sparc signal handling code is quite a mess and I should clean it up some day. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-10[SPARC64]: Pass regs and entry/exit boolean to syscall_trace()David S. Miller
Also fix a bug in 32-bit syscall tracing. We forgot to update this code when we moved over to the convention that all 32-bit syscall arguments are zero extended by default. Signed-off-by: David S. Miller <davem@davemloft.net>
