If of_get_property() fails, it returns NULL and the 'len'
parameter is undefined. So we need to explicitly set len
to zero in such cases.
Noticed by Al Viro.
When NR_CPUS is smaller than the cpu probed, let the user
know that the cpu won't be used.
Suggested by Al Viro.
As noted by Al Viro, when we try to call prom_set_trap_table()
in the SMP trampoline code we try to take the PROM call spinlock
which doesn't work because the current thread pointer isn't
valid yet and lockdep depends upon that being correct.
Furthermore, we cannot set the current thread pointer register
because it can't be properly dereferenced until we return from
prom_set_trap_table(). Kernel TLB misses only work after that
call.
So do the PROM call to set the trap table directly instead of
going through the OBP library C code, and thus avoid the lock
altogether.
These calls are guarenteed to be serialized fully.
Since there are now no calls to the prom_set_trap_table{_sun4v}()
library functions, they can be deleted.
On the root PCI bus, the OBP device tree lists device 3 twice.
Once as 'pm' and once as 'lomp'.
Everything goes downhill from there.
Ignore the second instance to workaround this.
Thanks to Kövedi_Krisztián for the bug report and
testing the fix.
1) sun4{u,v}_build_msi() have improper return value handling.
We should always return negative error codes, instead of
using the magic value "0" which could in fact be a valid
MSI number.
2) sun4{u,v}_build_msi() should return -ENOMEM instead of
calling prom_prom() halt with kzalloc() of the interrupt
data fails.
3) We 'remembered' the MSI number using a singleton in the
struct device archdata area, this doesn't work for MSI-X
which can cause multiple MSIs assosciated with one device.
Delete that archdata member, and instead store the MSI
number in the IRQ chip data area.
Sometimes we were using 32-bit values and the top bits were
getting inadvertantly chopped off. This will matter for the
forthcoming Fire controller MSI support.
This register is not a part of the sun4v architecture.
Niagara 1 and 2 happened to leave it around.
The bzero/memset implementation stays the same as Niagara-1.
Like the OF device tree, it's useful to let userland get
at the machine description so it can pretty print the
graph etc.
The implementation is a simple MISC device with a read method.
Every time a cpu is added via hotplug, we allocate the per-cpu MONDO
queues but we never free them up. Freeing isn't easy since the first
cpu gets this memory from bootmem.
Therefore, the simplest thing to do to fix this bug is to allocate the
queues for all possible cpus at boot time.
Check the cpu type in the OBP device tree before committing to
using the optimized Niagara memcpy and memset implementation.
If we don't recognize the cpu type, use a completely generic
version.
It didn't handle that case at all, and now dump_stack()
can be implemented directly as show_stack(current, NULL)
Fully unify all of the DMA ops so that subordinate bus types to
the DMA operation providers (such as ebus, isa, of_device) can
work transparently.
Basically, we just make sure that for every system device we
create, the dev->archdata 'iommu' and 'stc' fields are filled
in.
Then we have two platform variants of the DMA ops, one for SUN4U which
actually programs the real hardware, and one for SUN4V which makes
hypervisor calls.
This also fixes the crashes in parport_pc on sparc64, reported by
Meelis Roos.
Now that drivers/sbus/char/rtc.c is sparc32 only, we need this.
Don't provide fake PCI config space for sun4u.
Also, put back the funny host controller space handling that
at least Sabre needs. You have to read PCI host controller
registers at their nature size otherwise you get zeros instead
of correct values.
Remove fs.h from mm.h. For this,
1) Uninline vma_wants_writenotify(). It's pretty huge anyway.
2) Add back fs.h or less bloated headers (err.h) to files that need it.
As result, on x86_64 allyesconfig, fs.h dependencies cut down from 3929 files
rebuilt down to 3444 (-12.3%).
Cross-compile tested without regressions on my two usual configs and (sigh):
alpha arm-mx1ads mips-bigsur powerpc-ebony
alpha-allnoconfig arm-neponset mips-capcella powerpc-g5
alpha-defconfig arm-netwinder mips-cobalt powerpc-holly
alpha-up arm-netx mips-db1000 powerpc-iseries
arm arm-ns9xxx mips-db1100 powerpc-linkstation
arm-assabet arm-omap_h2_1610 mips-db1200 powerpc-lite5200
arm-at91rm9200dk arm-onearm mips-db1500 powerpc-maple
arm-at91rm9200ek arm-picotux200 mips-db1550 powerpc-mpc7448_hpc2
arm-at91sam9260ek arm-pleb mips-ddb5477 powerpc-mpc8272_ads
arm-at91sam9261ek arm-pnx4008 mips-decstation powerpc-mpc8313_rdb
arm-at91sam9263ek arm-pxa255-idp mips-e55 powerpc-mpc832x_mds
arm-at91sam9rlek arm-realview mips-emma2rh powerpc-mpc832x_rdb
arm-ateb9200 arm-realview-smp mips-excite powerpc-mpc834x_itx
arm-badge4 arm-rpc mips-fulong powerpc-mpc834x_itxgp
arm-carmeva arm-s3c2410 mips-ip22 powerpc-mpc834x_mds
arm-cerfcube arm-shannon mips-ip27 powerpc-mpc836x_mds
arm-clps7500 arm-shark mips-ip32 powerpc-mpc8540_ads
arm-collie arm-simpad mips-jazz powerpc-mpc8544_ds
arm-corgi arm-spitz mips-jmr3927 powerpc-mpc8560_ads
arm-csb337 arm-trizeps4 mips-malta powerpc-mpc8568mds
arm-csb637 arm-versatile mips-mipssim powerpc-mpc85xx_cds
arm-ebsa110 i386 mips-mpc30x powerpc-mpc8641_hpcn
arm-edb7211 i386-allnoconfig mips-msp71xx powerpc-mpc866_ads
arm-em_x270 i386-defconfig mips-ocelot powerpc-mpc885_ads
arm-ep93xx i386-up mips-pb1100 powerpc-pasemi
arm-footbridge ia64 mips-pb1500 powerpc-pmac32
arm-fortunet ia64-allnoconfig mips-pb1550 powerpc-ppc64
arm-h3600 ia64-bigsur mips-pnx8550-jbs powerpc-prpmc2800
arm-h7201 ia64-defconfig mips-pnx8550-stb810 powerpc-ps3
arm-h7202 ia64-gensparse mips-qemu powerpc-pseries
arm-hackkit ia64-sim mips-rbhma4200 powerpc-up
arm-integrator ia64-sn2 mips-rbhma4500 s390
arm-iop13xx ia64-tiger mips-rm200 s390-allnoconfig
arm-iop32x ia64-up mips-sb1250-swarm s390-defconfig
arm-iop33x ia64-zx1 mips-sead s390-up
arm-ixp2000 m68k mips-tb0219 sparc
arm-ixp23xx m68k-amiga mips-tb0226 sparc-allnoconfig
arm-ixp4xx m68k-apollo mips-tb0287 sparc-defconfig
arm-jornada720 m68k-atari mips-workpad sparc-up
arm-kafa m68k-bvme6000 mips-wrppmc sparc64
arm-kb9202 m68k-hp300 mips-yosemite sparc64-allnoconfig
arm-ks8695 m68k-mac parisc sparc64-defconfig
arm-lart m68k-mvme147 parisc-allnoconfig sparc64-up
arm-lpd270 m68k-mvme16x parisc-defconfig um-x86_64
arm-lpd7a400 m68k-q40 parisc-up x86_64
arm-lpd7a404 m68k-sun3 powerpc x86_64-allnoconfig
arm-lubbock m68k-sun3x powerpc-cell x86_64-defconfig
arm-lusl7200 mips powerpc-celleb x86_64-up
arm-mainstone mips-atlas powerpc-chrp32
We can't mark the whole thing init because there are dependencies
in bootloaders that assume that _start, or whatever the image
entry value, is 2 instructions before the "HdrS" signature.
In fact, TILO assumes this entry is always at 0x4000, yikes!
Also, right after the bootloader info area there are OBP strings and
values that get used later in the boot process, and those are not all
provably .init yet.
This fixes boot failures when the build-id LD option is
actually used, because without it we end up with multiple
PT_LOAD sections which the SILO boot loader cannot handle.
master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6
* 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6:
[SPARC64]: ERROR: "sys_ioctl" [arch/sparc64/solaris/solaris.ko] undefined!
[SPARC32]: Make PAGE_SHARED a read-mostly variable.
[SPARC32]: Take enable_irq/disable_irq out of line.
[SPARC32]: clean include/asm-sparc/irq.h
[SPARC32]: Fix rounding errors in ndelay/udelay implementation.
On Fri, Jul 20, 2007 at 09:24:42AM -0400, Horst H. von Brand wrote:
> When building v2.6.22-3478-g275afca on sparc64 (.config attached) I get:
> MODPOST vmlinux
> Building modules, stage 2.
> MODPOST 463 modules
Sorry, my fault.
It looked to me like sparc64 exports sys_ioctl on it's own, but it
only exports compat_sys_ioctl on it's own.
i386 and sparc64 have the identical code to update the cmos clock. Move it
into kernel/time/ntp.c as there are other architectures coming along with the
same requirements.
[akpm@linux-foundation.org: build fixes]
Cc: Chris Wright <chrisw@sous-sol.org>
Cc: john stultz <johnstul@us.ibm.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
We need to make sure, that the clockevent devices are resumed, before
the tick is resumed. The current resume logic does not guarantee this.
Add CLOCK_EVT_MODE_RESUME and call the set mode functions of the clock
event devices before resuming the tick / oneshot functionality.
Fixup the existing users.
Thanks to Nigel Cunningham for tracking down a long standing thinko,
which affected the jinxed VAIO.
[akpm@linux-foundation.org: xen build fix]
Fix following warning:
WARNING: vmlinux.o(.text+0x35264): Section mismatch: reference to .init.text:__alloc_bootmem (between 'mdesc_bootmem_alloc' and 'mdesc_bootmem_free')
Rename mdesc_mem_ops to *_ops so modpost ignores __init references
and declare mdesc_bootmem_alloc __init since it is only used
during __init context.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
WARNING: vmlinux.o(.text+0x3cf50): Section mismatch: reference to .init.text:page_in_phys_avail (between 'pci_sun4v_pbm_init' and 'sun4v_pci_init')
pci_sun4v_pbm_init and sun4v_pci_init was only used under __init
context so declare them _init.
The existing sparc64 mini_rtc driver can handle CMOS based
rtcs trivially with just a few lines of code and the simplifies
things tremendously.
Tested on SB1500.
The dev_handle and dev_ino fields don't match up exactly to
the traditional IMAP_IGN and IMAP_INO masks.
So store them away in a table and look them up directly.
When booting up a control node it's quite common to
not be able to register several service types.
And likewise on guests at least one or two are going
to not be there.
The best scheme to get uniqueness seems to be:
FOO -- If node lacks "id" property
FOO-$(ID) -- If node has "id" but parent lacks "cfg-handle"
FOO-$(ID)-$(CFG_HANDLE) -- If node has both
The current scheme works on static interpretation of text names, which
is wrong.
The output-device setting, for example, must be resolved via an alias
or similar to a full path name to the console device.
Paths also contain an optional set of 'options', which starts with a
colon at the end of the path. The option area is used to specify
which of two serial ports ('a' or 'b') the path refers to when a
device node drives multiple ports. 'a' is assumed if the option
specification is missing.
This was caught by the UltraSPARC-T1 simulator. The 'output-device'
property was set to 'ttya' and we didn't pick upon the fact that this
is an OBP alias set to '/virtual-devices/console'. Instead we saw it
as the first serial console device, instead of the hypervisor console.
The infrastructure is now there to take advantage of this to resolve
the console correctly even in multi-head situations in fbcon too.
Thanks to Greg Onufer for the bug report.
git://git.kernel.org/pub/scm/linux/kernel/git/sfr/ofcons
* 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/sfr/ofcons:
Create drivers/of/platform.c
Create linux/of_platorm.h
[SPARC/64] Rename some functions like PowerPC
Begin consolidation of of_device.h
Begin to consolidate of_device.c
Consolidate of_find_node_by routines
Consolidate of_get_next_child
Consolidate of_get_parent
Consolidate of_find_property
Consolidate of_device_is_compatible
Start split out of common open firmware code
Split out common parts of prom.h
We try to fetch the CIF entry pointer from %o4, but that
can get clobbered by the early OBP calls. It is saved
in %l7 already, so actually this "mov %o4, %l7" can just
be completely removed with no other changes.
They are too strict.
Use KERN_INFO, add missing newline, etc.
The "id" property in vdc-port nodes are not unique, they
are all zero. Therefore assign ID's using the parent's
"cfg-handle" property which will be unique.
with the recent renames, we forgot to update the matches for
devspec. This is required to keep udev working and autoload modules.
and populate it with the common parts from PowerPC and Sparc[64].
Acked-by: Paul Mackerras <paulus@samba.org>
This is to make the of merge easier. Also rename of_bus_type.
This moves all the common parts for the Sparc, Sparc64 and PowerPC
of_device.c files into drivers/of/device.c.
Apart from the simple move, Sparc gains of_match_node() and a call to
of_node_put in of_release_dev(). PowerPC gains better recovery if
device_create_file() fails in of_device_register().
This consolidates the routines of_find_node_by_path, of_find_node_by_name,
of_find_node_by_type and of_find_compatible_device. Again, the comparison
of strings are done differently by Sparc and PowerPC and also these add
read_locks around the iterations.
This adds a read_lock around the child/next accesses on Sparc.
