path: root/arch/sparc64/kernel/prom.c
2007-06-07[SPARC64]: Fix SBUS IRQ regression caused by PCI-E driver.David S. Miller
We used to access the 64-bit IRQ IMAP and ICLR registers of bus controllers 4-bytes in and as a 32-bit register word, since only the low 32-bits were relevant. This seemed like a good idea at the time. But the PCI-E controller requires full 8-byte 64-bit access to these registers, so we switched over to accessing them fully. SBUS was not adjusted properly, which broke interrupts completely. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-04[SPARC64]: Fix {mc,smt}_capable().David S. Miller
It's not just sun4v hypervisor platforms that should return true for this, sun4u with UltraSPARC-IV should return true too. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-04[SPARC64]: Make core and sibling groups equal on UltraSPARC-IV.David S. Miller
2007-06-04[SPARC64]: Proper multi-core scheduling support.David S. Miller
The scheduling domain hierarchy is: all cpus --> cpus that share an instruction cache --> cpus that share an integer execution unit Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-29[SPARC64]: Use machine description and OBP properly for cpu probing.David S. Miller
2007-05-11[SPARC64]: Spelling fixes.Simon Arlott
Spelling fixes in arch/sparc64/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-10[SPARC64]: Fix recursion in PROM tree building.David S. Miller
Use iteration for scanning of PROM node siblings. Based upon a patch by Greg Onufer, who found this bug. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-07[SPARC64]: Fix section mismatch warnings in arch/sparc64/kernel/prom.cDavid S. Miller
The IRQ translation init routines should all be __init. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-06[SPARC64]: SUN4U PCI-E controller support.David S. Miller
Some minor refactoring in the generic code was necessary for this: 1) This controller requires 8-byte access to the interrupt map and clear register. They are 64-bits on all the other SBUS and PCI controllers anyways, so this was easy to cure. 2) The IMAP register has a different layout and some bits that we need to preserve, so use a read/modify/write when making changes to the IMAP register in generic code. 3) Flushing the entire IOMMU TLB is best done with a single write to a register on this PCI controller, add a iommu->iommu_flushinv for this. Still lacks MSI support, that will come later. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[SPARC64]: constify some paramaters of OF routinesStephen Rothwell
This starts bringing the PowerPC and Sparc64 implemetations back closer together. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[SPARC]: Use strcasecmp for OFW property name comparisons.David S. Miller
This allows us to simplify sharing code with powerpc which has properties that have various forms of capitalization when on the sparc64 side the property is all lower-case. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[SPARC/64]: constify of_get_property returnStephen Rothwell
Finally, we actually change the functions themselves. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[SPARC64]: constify of_get_property return: arch/sparc64Stephen Rothwell
2006-10-30[SPARC64]: Fix Tomatillo/Schizo IRQ handling.David S. Miller
The code in schizo_irq_trans_init() should set irq_data->sync_reg to the location of the SYNC register if this is Tomatillo, and set it to zero otherwise. But that is not what it is doing. As a result, non-Tomatillo systems were trying to access a non-existent register resulting in bus errors at the first PCI interrupt. Thanks to Roland Stigge for the bug report. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-25[SPARC64]: Fix central/FHC bus handling on Ex000 systems.David S. Miller
1) probe_other_fhcs() wants to see only non-central FHC busses, so skip FHCs that don't sit off the root 2) Like SBUS, FHC can lack the appropriate address and size cell count properties, so add an of_busses[] entry and handlers for that. 3) Central FHC irq translator probing was buggy. We were trying to use dp->child in irq_trans_init but that linkage is not setup at this point. So instead, pass in the parent of "dp" and look for the child "fhc" with parent "central". Thanks to the tireless assistence of Ben Collins in tracking down these problems and testing out these fixes. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
2006-07-21[SPARC64]: Fix more of_device layer IRQ bugs, and correct PROMREG_MAX.David S. Miller
Sabre and Psycho PCI controllers can have partial interrupt-map properties, meaning that on-board devices don't match up to any entries. Instead, they are fully specified from the beginning and we should pass them directly to the IRQ translator as-is. Also, fill in the necessary translator slots for the "graphics" and "expansion UPA" interrupts on Sabre, Psycho, and SYSIO SBUS. Increase PROMREG_MAX to 24, as seen on SUNW,ffb devices. Finally, prevent accidentally writing past the end of the of_device struct resource[] and irqs[] arrays. Spit out a log message when we ignore some entries because there are too many of them. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-13[SPARC64]: Refine Sabre wsync logic.David S. Miller
It is only needed when there is a PCI-PCI bridge sitting between the device and the PCI host controller which is not a Simba APB bridge. Add logic to handle two special cases: 1) device behind EBUS, which sits on PCI 2) PCI controller interrupts Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-13[SPARC64]: Fix 2 bugs in sabre_irq_build()David S. Miller
When installing the IRQ pre-handler, we were not setting up the second argument correctly. It should be a pointer to the sabre_irq_data, not the config space PIO address. Furthermore, we only need this pre-handler installed if the device sits behind a PCI bridge that is not Sabre or Simba/APB. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-05[SPARC64]: Fix sparc64 build errors when CONFIG_PCI=n.Randy Dunlap
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-30[SPARC64]: Kill sun4v virtual device layer.David S. Miller
Replace with a simple IRQ translater in the PROM device tree builder. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-29[SPARC64]: of_device layer IRQ resolutionDavid S. Miller
Do IRQ determination generically by parsing the PROM properties, and using IRQ controller drivers for final resolution. One immediate positive effect is that all of the IRQ frobbing in the EBUS, ISA, and PCI controller layers has been eliminated. We just look up the of_device and use the properly computed value. The PCI controller irq_build() routines are gone and no longer used. Unfortunately sbus_build_irq() has to remain as there is a direct reference to this in the sunzilog driver. That can be killed off once the sparc32 side of this is written and the sunzilog driver is transformed into an "of" bus driver. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-29[SPARC]: Add of_n_{addr,size}_cells().David S. Miller
2006-06-25[SPARC]: Add unique device_node IDs and a ".node" property.David S. Miller
2006-06-25[SPARC]: Add of_set_property() interface.David S. Miller
2006-06-23[SPARC64]: Expand of_*() interfaces some more.David S. Miller
Import some more stuff from powerpc. Add of_device_is_compatible(), and of_find_compatible_node(). Export some more of the other routines to modules. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-23[SPARC64]: Use in-kernel PROM tree for EBUS and ISA.David S. Miller
2006-06-23[SPARC64]: Convert sparc64 PCI layer to in-kernel device tree.David S. Miller
One thing this change pointed out was that we really should pull the "get 'local-mac-address' property" logic into a helper function all the network drivers can call. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-23[SPARC64]: Add of_getintprop_default().David S. Miller
This encodes a common idiomatic coding pattern used when dealing with integer properties. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-23[SPARC64]: Add of_find_node_by_{name,type}().David S. Miller
2006-06-23[SPARC64]: Import OBP device tree into kernel data structures.David S. Miller
The basic framework is based on the PowerPC OF code. This code even tries to get the device addressing components correct in the full path names. Signed-off-by: David S. Miller <davem@davemloft.net>
