commit 42a0cc3478584d4d63f68f2f5af021ddbea771fa upstream.
Holding uts_sem as a writer while accessing userspace memory allows a
namespace admin to stall all processes that attempt to take uts_sem.
Instead, move data through stack buffers and don't access userspace memory
while uts_sem is held.
Cc: stable@vger.kernel.org
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Signed-off-by: Jann Horn <jannh@google.com>
commit 2dc77533f1e495788d73ffa4bee4323b2646d2bb upstream.
When building the kernel for Sparc using gcc 7.x, the build fails
with:
arch/sparc/kernel/pcic.c: In function ‘pcibios_fixup_bus’:
arch/sparc/kernel/pcic.c:647:8: error: ‘cmd’ may be used uninitialized in this function [-Werror=maybe-uninitialized]
cmd |= PCI_COMMAND_IO;
The simplified code looks like this:
unsigned int cmd;
pcic_read_config(dev->bus, dev->devfn, PCI_COMMAND, 2, &cmd);
I.e, the code assumes that pcic_read_config() will always initialize
cmd. But it's not the case. Looking at pcic_read_config(), if
bus->number is != 0 or if the size is not one of 1, 2 or 4, *val will
not be initialized.
As a simple fix, we initialize cmd to zero at the beginning of
pcibios_fixup_bus.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
commit 0fde7ad71ee371ede73b3f326e58f9e8d102feb6 upstream.
arch/sparc/kernel/ds.c: In function ‘register_services’:
arch/sparc/kernel/ds.c:912:3: error: ‘strcpy’: writing at least 1 byte
into a region of size 0 overflows the destination
Reported-by: Anatoly Pugachev <matorola@gmail.com>
[ Upstream commit 6c95483b768c62f8ee933ae08a1bdbcb78b5410f ]
Orabug: 20902628
When an ldc control-only packet is received during data exchange in
read_nonraw(), a new rx head is calculated but the rx queue head is not
actually advanced (rx_set_head() is not called) and a branch is taken to
'no_data' at which point two things can happen depending on the value
of the newly calculated rx head and the current rx tail:
- If the rx queue is determined to be not empty, then the wrong packet
is picked up.
- If the rx queue is determined to be empty, then a read error (EAGAIN)
is eventually returned since it is falsely assumed that more data was
expected.
The fix is to update the rx head and return in case of a control only
packet during data exchange.
Signed-off-by: Jagannathan Raman <jag.raman@oracle.com>
Reviewed-by: Aaron Young <aaron.young@oracle.com>
Reviewed-by: Alexandre Chartre <alexandre.chartre@oracle.com>
Reviewed-by: Bijan Mottahedeh <bijan.mottahedeh@oracle.com>
Reviewed-by: Liam Merwick <liam.merwick@oracle.com>
[ Upstream commit 7dd4fcf5b70694dc961eb6b954673e4fc9730dbd ]
On panic, all other CPUs are stopped except the one which had
hit panic. To keep console alive, we need to migrate hvcons irq
to panicked CPU.
Signed-off-by: Vijay Kumar <vijay.ac.kumar@oracle.com>
[ Upstream commit 6170a506899aee3dd4934c928426505e47b1b466 ]
There is no need to log message if ATU hvapi couldn't get register.
Unlike PCI hvapi, ATU hvapi registration failure is not hard error.
Even if ATU hvapi registration fails (on system with ATU or without
ATU) system continues with legacy IOMMU. So only log message when
ATU hvapi successfully get registered.
Signed-off-by: Tushar Dave <tushar.n.dave@oracle.com>
commit fc290a114fc6034b0f6a5a46e2fb7d54976cf87a upstream.
This fixes another cause of random segfaults and bus errors that may
occur while running perf with the callgraph option.
Critical sections beginning with spin_lock_irqsave() raise the interrupt
level to PIL_NORMAL_MAX (14) and intentionally do not block performance
counter interrupts, which arrive at PIL_NMI (15).
But some sections of code are "super critical" with respect to perf
because the perf_callchain_user() path accesses user space and may cause
TLB activity as well as faults as it unwinds the user stack.
One particular critical section occurs in switch_mm:
spin_lock_irqsave(&mm->context.lock, flags);
load_secondary_context(mm);
tsb_context_switch(mm);
spin_unlock_irqrestore(&mm->context.lock, flags);
If a perf interrupt arrives in between load_secondary_context() and
tsb_context_switch(), then perf_callchain_user() could execute with
the context ID of one process, but with an active TSB for a different
process. When the user stack is accessed, it is very likely to
incur a TLB miss, since the h/w context ID has been changed. The TLB
will then be reloaded with a translation from the TSB for one process,
but using a context ID for another process. This exposes memory from
one process to another, and since it is a mapping for stack memory,
this usually causes the new process to crash quickly.
This super critical section needs more protection than is provided
by spin_lock_irqsave() since perf interrupts must not be allowed in.
Since __tsb_context_switch already goes through the trouble of
disabling interrupts completely, we fix this by moving the secondary
context load down into this better protected region.
Orabug: 25577560
Signed-off-by: Dave Aldridge <david.j.aldridge@oracle.com>
Signed-off-by: Rob Gardner <rob.gardner@oracle.com>
[ Upstream commit 9d53caec84c7c5700e7c1ed744ea584fff55f9ac ]
A large sun4v SPARC system may have moments of intensive xcall activities,
usually caused by unmapping many pages on many CPUs concurrently. This can
flood receivers with CPU mondo interrupts for an extended period, causing
some unlucky senders to hit send-mondo timeout. This problem gets worse
as cpu count increases because sometimes mappings must be invalidated on
all CPUs, and sometimes all CPUs may gang up on a single CPU.
But a busy system is not a broken system. In the above scenario, as long
as the receiver is making forward progress processing mondo interrupts,
the sender should continue to retry.
This patch implements the receiver's forward progress meter by introducing
a per cpu counter 'cpu_mondo_counter[cpu]' where 'cpu' is in the range
of 0..NR_CPUS. The receiver increments its counter as soon as it receives
a mondo and the sender tracks the receiver's counter. If the receiver has
stopped making forward progress when the retry limit is reached, the sender
declares send-mondo-timeout and panic; otherwise, the receiver is allowed
to keep making forward progress.
In addition, it's been observed that PCIe hotplug events generate Correctable
Errors that are handled by hypervisor and then OS. Hypervisor 'borrows'
a guest cpu strand briefly to provide the service. If the cpu strand is
simultaneously the only cpu targeted by a mondo, it may not be available
for the mondo in 20msec, causing SUN4V mondo timeout. It appears that 1 second
is the agreed wait time between hypervisor and guest OS, this patch makes
the adjustment.
Orabug: 25476541
Orabug: 26417466
Signed-off-by: Jane Chu <jane.chu@oracle.com>
Reviewed-by: Steve Sistare <steven.sistare@oracle.com>
Reviewed-by: Anthony Yznaga <anthony.yznaga@oracle.com>
Reviewed-by: Rob Gardner <rob.gardner@oracle.com>
Reviewed-by: Thomas Tai <thomas.tai@oracle.com>
[ Upstream commit 7a7dc961a28b965a0d0303c2e989df17b411708b ]
Error queues use a non-zero first word to detect if the queues are full.
Using pages that have not been zeroed may result in false positive
overflow events. These queues are set up once during boot so zeroing
all mondo and error queue pages is safe.
Note that the false positive overflow does not always occur because the
page allocation for these queues is so early in the boot cycle that
higher number CPUs get fresh pages. It is only when traps are serviced
with lower number CPUs who were given already used pages that this issue
is exposed.
Signed-off-by: Liam R. Howlett <Liam.Howlett@Oracle.com>
[ Upstream commit 047487241ff59374fded8c477f21453681f5995c ]
User processes trying to access an invalid memory address via PIO will
receive a SIGBUS signal instead of causing a panic. Memory errors will
receive a SIGKILL since a SIGBUS may result in a coredump which may
attempt to repeat the faulting access.
commit 1be7107fbe18eed3e319a6c3e83c78254b693acb upstream.
Stack guard page is a useful feature to reduce a risk of stack smashing
into a different mapping. We have been using a single page gap which
is sufficient to prevent having stack adjacent to a different mapping.
But this seems to be insufficient in the light of the stack usage in
userspace. E.g. glibc uses as large as 64kB alloca() in many commonly
used functions. Others use constructs liks gid_t buffer[NGROUPS_MAX]
which is 256kB or stack strings with MAX_ARG_STRLEN.
This will become especially dangerous for suid binaries and the default
no limit for the stack size limit because those applications can be
tricked to consume a large portion of the stack and a single glibc call
could jump over the guard page. These attacks are not theoretical,
unfortunatelly.
Make those attacks less probable by increasing the stack guard gap
to 1MB (on systems with 4k pages; but make it depend on the page size
because systems with larger base pages might cap stack allocations in
the PAGE_SIZE units) which should cover larger alloca() and VLA stack
allocations. It is obviously not a full fix because the problem is
somehow inherent, but it should reduce attack space a lot.
One could argue that the gap size should be configurable from userspace,
but that can be done later when somebody finds that the new 1MB is wrong
for some special case applications. For now, add a kernel command line
option (stack_guard_gap) to specify the stack gap size (in page units).
Implementation wise, first delete all the old code for stack guard page:
because although we could get away with accounting one extra page in a
stack vma, accounting a larger gap can break userspace - case in point,
a program run with "ulimit -S -v 20000" failed when the 1MB gap was
counted for RLIMIT_AS; similar problems could come with RLIMIT_MLOCK
and strict non-overcommit mode.
Instead of keeping gap inside the stack vma, maintain the stack guard
gap as a gap between vmas: using vm_start_gap() in place of vm_start
(or vm_end_gap() in place of vm_end if VM_GROWSUP) in just those few
places which need to respect the gap - mainly arch_get_unmapped_area(),
and and the vma tree's subtree_gap support for that.
Original-patch-by: Oleg Nesterov <oleg@redhat.com>
Original-patch-by: Michal Hocko <mhocko@suse.com>
Tested-by: Helge Deller <deller@gmx.de> # parisc
[wt: backport to 4.11: adjust context]
[wt: backport to 4.9: adjust context ; kernel doc was not in admin-guide]
Signed-off-by: Willy Tarreau <w@1wt.eu>
commit b5c3206190f1fddd100b3060eb15f0d775ffeab8 upstream.
My static checker complains that if "lvl" is ULONG_MAX (this is 64 bit)
then some of the strings will overflow. I don't know if that's possible
but it seems simple enough to make the buffers slightly larger.
Cc: Waldemar Brodkorb <wbx@openadk.org>
[ Upstream commit c79a13734d104b5b147d7cb0870276ccdd660dae ]
Linux SPARC64 limits NR_CPUS to 4064 because init_cpu_send_mondo_info()
only allocates a single page for NR_CPUS mondo entries. Thus we cannot
use all 4096 CPUs on some SPARC platforms.
To fix, allocate (2^order) pages where order is set according to the size
of cpu_list for possible cpus. Since cpu_list_pa and cpu_mondo_block_pa
are not used in asm code, there are no imm13 offsets from the base PA
that will break because they can only reach one page.
Orabug: 25505750
Reviewed-by: Bob Picco <bob.picco@oracle.com>
Reviewed-by: Atish Patra <atish.patra@oracle.com>
[ Upstream commit 0197e41ce70511dc3b71f7fefa1a676e2b5cd60b ]
The old method that is using xcall and softint to get new context id is
deleted, as it is replaced by a method of using per_cpu_secondary_mm
without xcall to perform the context wrap.
Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com>
Reviewed-by: Steven Sistare <steven.sistare@oracle.com>
[ Upstream commit c982aa9c304bf0b9a7522fd118fed4afa5a0263c ]
VIO devices were being looked up by their index in the machine
description node block, but this often varies over time as devices are
added and removed. Instead, store the ID and look up using the type,
config handle and ID.
Signed-off-by: James Clarke <jrtc27@jrtc27.com>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=112541
[ Upstream commit 654f4807624a657f364417c2a7454f0df9961734 ]
When a TSB grows beyond its current capacity, a new TSB is allocated
and copy_tsb is called to copy entries from the old TSB to the new.
A hash shift based on page size is used to calculate the index of an
entry in the TSB. copy_tsb has hard coded PAGE_SHIFT in these
calculations. However, for huge page TSBs the value REAL_HPAGE_SHIFT
should be used. As a result, when copy_tsb is called for a huge page
TSB the entries are placed at the incorrect index in the newly
allocated TSB. When doing hardware table walk, the MMU does not
match these entries and we end up in the TSB miss handling code.
This code will then create and write an entry to the correct index
in the TSB. We take a performance hit for the table walk miss and
recreation of these entries.
Pass a new parameter to copy_tsb that is the page size shift to be
used when copying the TSB.
Suggested-by: Anthony Yznaga <anthony.yznaga@oracle.com>
Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com>
[ Upstream commit 48078d2dac0a26f84f5f3ec704f24f7c832cce14 ]
The ftrace function_graph time measurements of a given function is not
accurate according to those recorded by ftrace using the function
filters. This change pulls the x86_64 fix from 'commit 722b3c746953
("ftrace/graph: Trace function entry before updating index")' into the
sparc specific prepare_ftrace_return which stops ftrace from
counting interrupted tasks in the time measurement.
Example measurements for select_task_rq_fair running "hackbench 100
process 1000":
| tracing/trace_stat/function0 | function_graph
Before patch | 2.802 us | 4.255 us
After patch | 2.749 us | 3.094 us
commit 3c7f62212018b904ae17f5636ead18a4dca3a88f upstream.
When any of the functions contained in NGbzero.S and GENbzero.S
vector through *bzero_from_clear_user, we may end up taking a
fault when executing one of the store alternate address space
instructions. If this happens, the exception handler does not
restore the %asi register.
This commit fixes the issue by introducing a new exception
handler that ensures the %asi register is restored when
a fault is handled.
Orabug: 25577560
Reviewed-by: Babu Moger <babu.moger@oracle.com>
commit d3805c546b275c8cc7d40f759d029ae92c7175f2 upstream.
Ensure that if userspace supplies insufficient data to PTRACE_SETREGSET
to fill all the registers, the thread's old registers are preserved.
Signed-off-by: Dave Martin <Dave.Martin@arm.com>
Drop duplicate header scatterlist.h from iommu_common.h.
Signed-off-by: Geliang Tang <geliangtang@gmail.com>
ATU 64bit addressing allows PCIe devices with 64bit DMA capabilities
to use ATU for 64bit DMA.
Reviewed-by: chris hyser <chris.hyser@oracle.com>
Acked-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
Add Hypervisor IOMMU v2 APIs pci_iotsb_map(), pci_iotsb_demap() and
enable sun4v dma ops to use IOMMU v2 API for all PCIe devices with
64bit DMA mask.
In order to use Hypervisor (HV) IOMMU v2 API for map/demap, each PCIe
device has to be bound to IOTSB using HV API pci_iotsb_bind().
Like legacy IOMMU, use common iommu_map_table and iommu_pool for ATU.
This change initializes iommu_map_table and iommu_pool for ATU.
Reviewed-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
ATU (Address Translation Unit) is a new IOMMU in SPARC supported with
Hypervisor IOMMU v2 APIs.
Current SPARC IOMMU supports only 32bit address ranges and one TSB
per PCIe root complex that has a 2GB per root complex DVMA space
limit. The limit has become a scalability bottleneck nowadays that
a typical 10G/40G NIC can consume 300MB-500MB DVMA space per
instance. When DVMA resource is exhausted, devices will not be usable
since the driver can't allocate DVMA.
ATU removes bottleneck by allowing guest os to create IOTSB of size
32G (or more) with 64bit address ranges available in ATU HW. 32G is
more than enough DVMA space to be shared by all PCIe devices under
root complex contrast to 2G space provided by legacy IOMMU.
ATU allows PCIe devices to use 64bit DMA addressing. Devices
which choose to use 32bit DMA mask will continue to work with the
existing legacy IOMMU.
Signed-off-by: Andreas Larsson <andreas@gaisler.com>
Additionally, if the offset will overflow the immediate for a ba,pt
instruction, fall back on a standard ba to get an extra 3 bits.
All of __ret{,l}_mone{_asi,_fp,_asi_fpu} are now unused.
The fixup helper function mechanism for handling user copy fault
handling is not %100 accurrate, and can never be made so.
We are going to transition the code to return the running return
return length, which is always kept track in one or more registers
of each of these routines.
In order to convert them one by one, we have to allow the existing
behavior to continue functioning.
Therefore make all the copy code that wants the fixup helper to be
used return negative one.
After all of the user copy routines have been converted, this logic
and the fixup helpers themselves can be removed completely.
It is completely unused.
Individual scheduler domain should consist different hierarchy
consisting of cores sharing similar property. Currently, no
scheduler domain is defined separately for the cores that shares
the last level cache. As a result, the scheduler fails to take
advantage of cache locality while migrating tasks during load
balancing.
Here are the cpu masks currently present for sparc that are/can
be used in scheduler domain construction.
cpu_core_map : set based on the cores that shares l1 cache.
core_core_sib_map : is set based on the socket id.
The prior SPARC notion of socket was defined as highest level of
shared cache. However, the MD record on T7 platforms now describes
the CPUs that share the physical socket and this is no longer tied
to shared cache.
That's why a separate cpu mask needs to be created that truly
represent highest level of shared cache for all platforms.
Signed-off-by: Atish Patra <atish.patra@oracle.com>
Reviewed-by: Chris Hyser <chris.hyser@oracle.com>
Merge the gup_flags cleanups from Lorenzo Stoakes:
"This patch series adjusts functions in the get_user_pages* family such
that desired FOLL_* flags are passed as an argument rather than
implied by flags.
The purpose of this change is to make the use of FOLL_FORCE explicit
so it is easier to grep for and clearer to callers that this flag is
being used. The use of FOLL_FORCE is an issue as it overrides missing
VM_READ/VM_WRITE flags for the VMA whose pages we are reading
from/writing to, which can result in surprising behaviour.
The patch series came out of the discussion around commit 38e088546522
("mm: check VMA flags to avoid invalid PROT_NONE NUMA balancing"),
which addressed a BUG_ON() being triggered when a page was faulted in
with PROT_NONE set but having been overridden by FOLL_FORCE.
do_numa_page() was run on the assumption the page _must_ be one marked
for NUMA node migration as an actual PROT_NONE page would have been
dealt with prior to this code path, however FOLL_FORCE introduced a
situation where this assumption did not hold.
See
https://marc.info/?l=linux-mm&m=147585445805166
for the patch proposal"
Additionally, there's a fix for an ancient bug related to FOLL_FORCE and
FOLL_WRITE by me.
[ This branch was rebased recently to add a few more acked-by's and
reviewed-by's ]
* gup_flag-cleanups:
mm: replace access_process_vm() write parameter with gup_flags
mm: replace access_remote_vm() write parameter with gup_flags
mm: replace __access_remote_vm() write parameter with gup_flags
mm: replace get_user_pages_remote() write/force parameters with gup_flags
mm: replace get_user_pages() write/force parameters with gup_flags
mm: replace get_vaddr_frames() write/force parameters with gup_flags
mm: replace get_user_pages_locked() write/force parameters with gup_flags
mm: replace get_user_pages_unlocked() write/force parameters with gup_flags
mm: remove write/force parameters from __get_user_pages_unlocked()
mm: remove write/force parameters from __get_user_pages_locked()
mm: remove gup_flags FOLL_WRITE games from __get_user_pages()
This removes the 'write' argument from access_process_vm() and replaces
it with 'gup_flags' as use of this function previously silently implied
FOLL_FORCE, whereas after this patch callers explicitly pass this flag.
We make this explicit as use of FOLL_FORCE can result in surprising
behaviour (and hence bugs) within the mm subsystem.
Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Michael Ellerman <mpe@ellerman.id.au>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild updates from Michal Marek:
- EXPORT_SYMBOL for asm source by Al Viro.
This does bring a regression, because genksyms no longer generates
checksums for these symbols (CONFIG_MODVERSIONS). Nick Piggin is
working on a patch to fix this.
Plus, we are talking about functions like strcpy(), which rarely
change prototypes.
- Fixes for PPC fallout of the above by Stephen Rothwell and Nick
Piggin
- fixdep speedup by Alexey Dobriyan.
- preparatory work by Nick Piggin to allow architectures to build with
-ffunction-sections, -fdata-sections and --gc-sections
- CONFIG_THIN_ARCHIVES support by Stephen Rothwell
- fix for filenames with colons in the initramfs source by me.
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: (22 commits)
initramfs: Escape colons in depfile
ppc: there is no clear_pages to export
powerpc/64: whitelist unresolved modversions CRCs
kbuild: -ffunction-sections fix for archs with conflicting sections
kbuild: add arch specific post-link Makefile
kbuild: allow archs to select link dead code/data elimination
kbuild: allow architectures to use thin archives instead of ld -r
kbuild: Regenerate genksyms lexer
kbuild: genksyms fix for typeof handling
fixdep: faster CONFIG_ search
ia64: move exports to definitions
sparc32: debride memcpy.S a bit
[sparc] unify 32bit and 64bit string.h
sparc: move exports to definitions
ppc: move exports to definitions
arm: move exports to definitions
s390: move exports to definitions
m68k: move exports to definitions
alpha: move exports to actual definitions
x86: move exports to actual definitions
When doing an nmi backtrace of many cores, most of which are idle, the
output is a little overwhelming and very uninformative. Suppress
messages for cpus that are idling when they are interrupted and just
emit one line, "NMI backtrace for N skipped: idling at pc 0xNNN".
We do this by grouping all the cpuidle code together into a new
.cpuidle.text section, and then checking the address of the interrupted
PC to see if it lies within that section.
This commit suitably tags x86 and tile idle routines, and only adds in
the minimal framework for other architectures.
Link: http://lkml.kernel.org/r/1472487169-14923-5-git-send-email-cmetcalf@mellanox.com
Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Tested-by: Daniel Thompson <daniel.thompson@linaro.org> [arm]
Tested-by: Petr Mladek <pmladek@suse.com>
Cc: Aaron Tomlin <atomlin@redhat.com>
Cc: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Patch series "improvements to the nmi_backtrace code" v9.
This patch series modifies the trigger_xxx_backtrace() NMI-based remote
backtracing code to make it more flexible, and makes a few small
improvements along the way.
The motivation comes from the task isolation code, where there are
scenarios where we want to be able to diagnose a case where some cpu is
about to interrupt a task-isolated cpu. It can be helpful to see both
where the interrupting cpu is, and also an approximation of where the
cpu that is being interrupted is. The nmi_backtrace framework allows us
to discover the stack of the interrupted cpu.
I've tested that the change works as desired on tile, and build-tested
x86, arm, mips, and sparc64. For x86 I confirmed that the generic
cpuidle stuff as well as the architecture-specific routines are in the
new cpuidle section. For arm, mips, and sparc I just build-tested it
and made sure the generic cpuidle routines were in the new cpuidle
section, but I didn't attempt to figure out which the platform-specific
idle routines might be. That might be more usefully done by someone
with platform experience in follow-up patches.
This patch (of 4):
Currently you can only request a backtrace of either all cpus, or all
cpus but yourself. It can also be helpful to request a remote backtrace
of a single cpu, and since we want that, the logical extension is to
support a cpumask as the underlying primitive.
This change modifies the existing lib/nmi_backtrace.c code to take a
cpumask as its basic primitive, and modifies the linux/nmi.h code to use
the new "cpumask" method instead.
The existing clients of nmi_backtrace (arm and x86) are converted to
using the new cpumask approach in this change.
The other users of the backtracing API (sparc64 and mips) are converted
to use the cpumask approach rather than the all/allbutself approach.
The mips code ignored the "include_self" boolean but with this change it
will now also dump a local backtrace if requested.
Link: http://lkml.kernel.org/r/1472487169-14923-2-git-send-email-cmetcalf@mellanox.com
Reviewed-by: Aaron Tomlin <atomlin@redhat.com>
Reviewed-by: Petr Mladek <pmladek@suse.com>
Pull sparc updates from David Miller:
"Besides some cleanups the major thing here is supporting relaxed
ordering PCIe transactions on newer sparc64 machines, from Chris
Hyser"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc:
sparc: fixing ident and beautifying code
sparc64: Enable setting "relaxed ordering" in IOMMU mappings
sparc64: Enable PCI IOMMU version 2 API
sparc: migrate exception table users off module.h and onto extable.h
Enable relaxed ordering for memory writes in IOMMU TSB entry from
dma_4v_alloc_coherent(), dma_4v_map_page() and dma_4v_map_sg() when
dma_attrs DMA_ATTR_WEAK_ORDERING is set. This requires PCI IOMMU I/O
Translation Services version 2.0 API.
Many PCIe devices allow enabling relaxed-ordering (memory writes bypassing
other memory writes) for various DMA buffers. A notable exception is the
Mellanox mlx4 IB adapter. Due to the nature of x86 HW this appears to have
little performance impact there. On SPARC HW however, this results in major
performance degradation getting only about 3Gbps. Enabling RO in the IOMMU
entries corresponding to mlx4 data buffers increases the throughput to
about 13 Gbps.
Orabug: 19245907
Signed-off-by: Chris Hyser <chris.hyser@oracle.com>
Enable Version 2 of the PCI IOMMU API needed for advanced features
such as PCI Relaxed Ordering and greater than 2 GB DMA address
space per root complex.
These files were only including module.h for exception table
related functions. We've now separated that content out into its
own file "extable.h" so now move over to that and avoid all the
extra header content in module.h that we don't really need to compile
these files.
Cc: sparclinux@vger.kernel.org
Pull CPU hotplug updates from Thomas Gleixner:
"Yet another batch of cpu hotplug core updates and conversions:
- Provide core infrastructure for multi instance drivers so the
drivers do not have to keep custom lists.
- Convert custom lists to the new infrastructure. The block-mq custom
list conversion comes through the block tree and makes the diffstat
tip over to more lines removed than added.
- Handle unbalanced hotplug enable/disable calls more gracefully.
- Remove the obsolete CPU_STARTING/DYING notifier support.
- Convert another batch of notifier users.
The relayfs changes which conflicted with the conversion have been
shipped to me by Andrew.
The remaining lot is targeted for 4.10 so that we finally can remove
the rest of the notifiers"
* 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (46 commits)
cpufreq: Fix up conversion to hotplug state machine
blk/mq: Reserve hotplug states for block multiqueue
x86/apic/uv: Convert to hotplug state machine
s390/mm/pfault: Convert to hotplug state machine
mips/loongson/smp: Convert to hotplug state machine
mips/octeon/smp: Convert to hotplug state machine
fault-injection/cpu: Convert to hotplug state machine
padata: Convert to hotplug state machine
cpufreq: Convert to hotplug state machine
ACPI/processor: Convert to hotplug state machine
virtio scsi: Convert to hotplug state machine
oprofile/timer: Convert to hotplug state machine
block/softirq: Convert to hotplug state machine
lib/irq_poll: Convert to hotplug state machine
x86/microcode: Convert to hotplug state machine
sh/SH-X3 SMP: Convert to hotplug state machine
ia64/mca: Convert to hotplug state machine
ARM/OMAP/wakeupgen: Convert to hotplug state machine
ARM/shmobile: Convert to hotplug state machine
arm64/FP/SIMD: Convert to hotplug state machine
Pull low-level x86 updates from Ingo Molnar:
"In this cycle this topic tree has become one of those 'super topics'
that accumulated a lot of changes:
- Add CONFIG_VMAP_STACK=y support to the core kernel and enable it on
x86 - preceded by an array of changes. v4.8 saw preparatory changes
in this area already - this is the rest of the work. Includes the
thread stack caching performance optimization. (Andy Lutomirski)
- switch_to() cleanups and all around enhancements. (Brian Gerst)
- A large number of dumpstack infrastructure enhancements and an
unwinder abstraction. The secret long term plan is safe(r) live
patching plus maybe another attempt at debuginfo based unwinding -
but all these current bits are standalone enhancements in a frame
pointer based debug environment as well. (Josh Poimboeuf)
- More __ro_after_init and const annotations. (Kees Cook)
- Enable KASLR for the vmemmap memory region. (Thomas Garnier)"
[ The virtually mapped stack changes are pretty fundamental, and not
x86-specific per se, even if they are only used on x86 right now. ]
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (70 commits)
x86/asm: Get rid of __read_cr4_safe()
thread_info: Use unsigned long for flags
x86/alternatives: Add stack frame dependency to alternative_call_2()
x86/dumpstack: Fix show_stack() task pointer regression
x86/dumpstack: Remove dump_trace() and related callbacks
x86/dumpstack: Convert show_trace_log_lvl() to use the new unwinder
oprofile/x86: Convert x86_backtrace() to use the new unwinder
x86/stacktrace: Convert save_stack_trace_*() to use the new unwinder
perf/x86: Convert perf_callchain_kernel() to use the new unwinder
x86/unwind: Add new unwind interface and implementations
x86/dumpstack: Remove NULL task pointer convention
fork: Optimize task creation by caching two thread stacks per CPU if CONFIG_VMAP_STACK=y
sched/core: Free the stack early if CONFIG_THREAD_INFO_IN_TASK
lib/syscall: Pin the task stack in collect_syscall()
x86/process: Pin the target stack in get_wchan()
x86/dumpstack: Pin the target stack when dumping it
kthread: Pin the stack via try_get_task_stack()/put_task_stack() in to_live_kthread() function
sched/core: Add try_get_task_stack() and put_task_stack()
x86/entry/64: Fix a minor comment rebase error
iommu/amd: Don't put completion-wait semaphore on stack
Currently, irq stack bootmem is allocated for all possible cpus
before nr_cpus value changes the list of possible cpus. As a result,
there is unnecessary wastage of bootmemory.
Move the irq stack bootmem allocation so that it happens after
possible cpu list is modified based on nr_cpus value.
Reviewed-by: Vijay Kumar <vijay.ac.kumar@oracle.com>
If kernel boot parameter nr_cpus is set, it should define the number
of CPUs that can ever be available in the system i.e.
cpu_possible_mask. setup_nr_cpu_ids() overrides the nr_cpu_ids based
on the cpu_possible_mask during kernel initialization. If
cpu_possible_mask is not set based on the nr_cpus value, earlier part
of the kernel would be initialized using nr_cpus value leading to a
kernel crash.
Set cpu_possible_mask based on nr_cpus value. Thus setup_nr_cpu_ids()
becomes redundant and does not corrupt nr_cpu_ids value.
All users are converted to state machine, remove CPU_STARTING and the
corresponding CPU_DYING.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: rt@linutronix.de
Link: http://lkml.kernel.org/r/20160818125731.27256-2-bigeasy@linutronix.de
Storing this value will help prevent unwinders from getting out of sync
with the function graph tracer ret_stack. Now instead of needing a
stateful iterator, they can compare the return address pointer to find
the right ret_stack entry.
Note that an array of 50 ftrace_ret_stack structs is allocated for every
task. So when an arch implements this, it will add either 200 or 400
bytes of memory usage per task (depending on whether it's a 32-bit or
64-bit platform).
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Byungchul Park <byungchul.park@lge.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Nilay Vaish <nilayvaish@gmail.com>
Link: http://lkml.kernel.org/r/a95cfcc39e8f26b89a430c56926af0bb217bc0a1.1471607358.git.jpoimboe@redhat.com
The jump table can reference text found in an __exit section. Thus,
instead of discarding it at build/link time, include EXIT_TEXT as part
of __init and release it at system boot time.
Without this patch the link fails with:
`.exit.text' referenced in section `__jump_table' of xxx.o:
defined in discarded section `.exit.text' of xxx.o
Link: http://lkml.kernel.org/r/d822da427ab07a02a394602eca687104ff682f83.1467837322.git.jbaron@akamai.com
Signed-off-by: Jason Baron <jbaron@akamai.com>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Cc: Joe Perches <joe@perches.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
The dma-mapping core and the implementations do not change the DMA
attributes passed by pointer. Thus the pointer can point to const data.
However the attributes do not have to be a bitfield. Instead unsigned
long will do fine:
1. This is just simpler. Both in terms of reading the code and setting
attributes. Instead of initializing local attributes on the stack
and passing pointer to it to dma_set_attr(), just set the bits.
2. It brings safeness and checking for const correctness because the
attributes are passed by value.
Semantic patches for this change (at least most of them):
virtual patch
virtual context
@r@
identifier f, attrs;
f(...,
- struct dma_attrs *attrs
+ unsigned long attrs
identifier r.f;
f(...,
- NULL
+ 0
and
// Options: --all-includes
virtual patch
virtual context
@r@
type t;
t f(..., struct dma_attrs *attrs);
identifier r.f;
f(...,
- NULL
+ 0
Link: http://lkml.kernel.org/r/1468399300-5399-2-git-send-email-k.kozlowski@samsung.com
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Robin Murphy <robin.murphy@arm.com>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
Acked-by: Mark Salter <msalter@redhat.com> [c6x]
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> [cris]
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> [drm]
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Acked-by: Joerg Roedel <jroedel@suse.de> [iommu]
Acked-by: Fabien Dessenne <fabien.dessenne@st.com> [bdisp]
Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> [vb2-core]
Acked-by: David Vrabel <david.vrabel@citrix.com> [xen]
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen swiotlb]
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon]
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k]
Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> [s390]
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> [avr32]
Acked-by: Vineet Gupta <vgupta@synopsys.com> [arc]
Acked-by: Robin Murphy <robin.murphy@arm.com> [arm64 and dma-iommu]
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"Highlights:
- ARM64 support for ACPI host bridges
- new drivers for Axis ARTPEC-6 and Marvell Aardvark
- new pci_alloc_irq_vectors() interface for MSI-X, MSI, legacy INTx
- pci_resource_to_user() cleanup (more to come)
Detailed summary:
Enumeration:
- Move ecam.h to linux/include/pci-ecam.h (Jayachandran C)
- Add parent device field to ECAM struct pci_config_window (Jayachandran C)
- Add generic MCFG table handling (Tomasz Nowicki)
- Refactor pci_bus_assign_domain_nr() for CONFIG_PCI_DOMAINS_GENERIC (Tomasz Nowicki)
- Factor DT-specific pci_bus_find_domain_nr() code out (Tomasz Nowicki)
Resource management:
- Add devm_request_pci_bus_resources() (Bjorn Helgaas)
- Unify pci_resource_to_user() declarations (Bjorn Helgaas)
- Implement pci_resource_to_user() with pcibios_resource_to_bus() (microblaze, powerpc, sparc) (Bjorn Helgaas)
- Request host bridge window resources (designware, iproc, rcar, xgene, xilinx, xilinx-nwl) (Bjorn Helgaas)
- Make PCI I/O space optional on ARM32 (Bjorn Helgaas)
- Ignore write combining when mapping I/O port space (Bjorn Helgaas)
- Claim bus resources on MIPS PCI_PROBE_ONLY set-ups (Bjorn Helgaas)
- Remove unicore32 pci=firmware command line parameter handling (Bjorn Helgaas)
- Support I/O resources when parsing host bridge resources (Jayachandran C)
- Add helpers to request/release memory and I/O regions (Johannes Thumshirn)
- Use pci_(request|release)_mem_regions (NVMe, lpfc, GenWQE, ethernet/intel, alx) (Johannes Thumshirn)
- Extend pci=resource_alignment to specify device/vendor IDs (Koehrer Mathias (ETAS/ESW5))
- Add generic pci_bus_claim_resources() (Lorenzo Pieralisi)
- Claim bus resources on ARM32 PCI_PROBE_ONLY set-ups (Lorenzo Pieralisi)
- Remove ARM32 and ARM64 arch-specific pcibios_enable_device() (Lorenzo Pieralisi)
- Add pci_unmap_iospace() to unmap I/O resources (Sinan Kaya)
- Remove powerpc __pci_mmap_set_pgprot() (Yinghai Lu)
PCI device hotplug:
- Allow additional bus numbers for hotplug bridges (Keith Busch)
- Ignore interrupts during D3cold (Lukas Wunner)
Power management:
- Enforce type casting for pci_power_t (Andy Shevchenko)
- Don't clear d3cold_allowed for PCIe ports (Mika Westerberg)
- Put PCIe ports into D3 during suspend (Mika Westerberg)
- Power on bridges before scanning new devices (Mika Westerberg)
- Runtime resume bridge before rescan (Mika Westerberg)
- Add runtime PM support for PCIe ports (Mika Westerberg)
- Remove redundant check of pcie_set_clkpm (Shawn Lin)
Virtualization:
- Add function 1 DMA alias quirk for Marvell 88SE9182 (Aaron Sierra)
- Add DMA alias quirk for Adaptec 3805 (Alex Williamson)
- Mark Atheros AR9485 and QCA9882 to avoid bus reset (Chris Blake)
- Add ACS quirk for Solarflare SFC9220 (Edward Cree)
MSI:
- Fix PCI_MSI dependencies (Arnd Bergmann)
- Add pci_msix_desc_addr() helper (Christoph Hellwig)
- Switch msix_program_entries() to use pci_msix_desc_addr() (Christoph Hellwig)
- Make the "entries" argument to pci_enable_msix() optional (Christoph Hellwig)
- Provide sensible IRQ vector alloc/free routines (Christoph Hellwig)
- Spread interrupt vectors in pci_alloc_irq_vectors() (Christoph Hellwig)
Error Handling:
- Bind DPC to Root Ports as well as Downstream Ports (Keith Busch)
- Remove DPC tristate module option (Keith Busch)
- Convert Downstream Port Containment driver to use devm_* functions (Mika Westerberg)
Generic host bridge driver:
- Select IRQ_DOMAIN (Arnd Bergmann)
- Claim bus resources on PCI_PROBE_ONLY set-ups (Lorenzo Pieralisi)
ACPI host bridge driver:
- Add ARM64 acpi_pci_bus_find_domain_nr() (Tomasz Nowicki)
- Add ARM64 ACPI support for legacy IRQs parsing and consolidation with DT code (Tomasz Nowicki)
- Implement ARM64 AML accessors for PCI_Config region (Tomasz Nowicki)
- Support ARM64 ACPI-based PCI host controller (Tomasz Nowicki)
Altera host bridge driver:
- Check link status before retrain link (Ley Foon Tan)
- Poll for link up status after retraining the link (Ley Foon Tan)
Axis ARTPEC-6 host bridge driver:
- Add PCI_MSI_IRQ_DOMAIN dependency (Arnd Bergmann)
- Add DT binding for Axis ARTPEC-6 PCIe controller (Niklas Cassel)
- Add Axis ARTPEC-6 PCIe controller driver (Niklas Cassel)
Intel VMD host bridge driver:
- Use lock save/restore in interrupt enable path (Jon Derrick)
- Select device dma ops to override (Keith Busch)
- Initialize list item in IRQ disable (Keith Busch)
- Use x86_vector_domain as parent domain (Keith Busch)
- Separate MSI and MSI-X vector sharing (Keith Busch)
Marvell Aardvark host bridge driver:
- Add DT binding for the Aardvark PCIe controller (Thomas Petazzoni)
- Add Aardvark PCI host controller driver (Thomas Petazzoni)
- Add Aardvark PCIe support for Armada 3700 (Thomas Petazzoni)
Microsoft Hyper-V host bridge driver:
- Fix interrupt cleanup path (Cathy Avery)
- Don't leak buffer in hv_pci_onchannelcallback() (Vitaly Kuznetsov)
- Handle all pending messages in hv_pci_onchannelcallback() (Vitaly Kuznetsov)
NVIDIA Tegra host bridge driver:
- Program PADS_REFCLK_CFG* always, not just on legacy SoCs (Stephen Warren)
- Program PADS_REFCLK_CFG* registers with per-SoC values (Stephen Warren)
- Use lower-case hex consistently for register definitions (Thierry Reding)
- Use generic pci_remap_iospace() rather than ARM32-specific one (Thierry Reding)
- Stop setting pcibios_min_mem (Thierry Reding)
Renesas R-Car host bridge driver:
- Drop gen2 dummy I/O port region (Bjorn Helgaas)
TI DRA7xx host bridge driver:
- Fix return value in case of error (Christophe JAILLET)
Xilinx AXI host bridge driver:
Miscellaneous:
- Make bus_attr_resource_alignment static (Ben Dooks)
- Include <asm/dma.h> for isa_dma_bridge_buggy (Ben Dooks)
- MAINTAINERS: Add file patterns for PCI device tree bindings (Geert Uytterhoeven)
- Make host bridge drivers explicitly non-modular (Paul Gortmaker)"
* tag 'pci-v4.8-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (125 commits)
PCI: xgene: Make explicitly non-modular
PCI: thunder-pem: Make explicitly non-modular
PCI: thunder-ecam: Make explicitly non-modular
PCI: tegra: Make explicitly non-modular
PCI: rcar-gen2: Make explicitly non-modular
PCI: rcar: Make explicitly non-modular
PCI: mvebu: Make explicitly non-modular
PCI: layerscape: Make explicitly non-modular
PCI: keystone: Make explicitly non-modular
PCI: hisi: Make explicitly non-modular
PCI: generic: Make explicitly non-modular
PCI: designware-plat: Make it explicitly non-modular
PCI: artpec6: Make explicitly non-modular
PCI: armada8k: Make explicitly non-modular
PCI: artpec: Add PCI_MSI_IRQ_DOMAIN dependency
PCI: Add ACS quirk for Solarflare SFC9220
arm64: dts: marvell: Add Aardvark PCIe support for Armada 3700
PCI: aardvark: Add Aardvark PCI host controller driver
dt-bindings: add DT binding for the Aardvark PCIe controller
PCI: tegra: Program PADS_REFCLK_CFG* registers with per-SoC values
