CONFIG_PREEMPTION is selected by CONFIG_PREEMPT and by CONFIG_PREEMPT_RT.
Both PREEMPT and PREEMPT_RT require the same functionality which today
depends on CONFIG_PREEMPT.
Switch the trap code over to use CONFIG_PREEMPTION.
[bigeasy: +Kconfig]
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: sparclinux@vger.kernel.org
Link: https://lore.kernel.org/r/20191015191821.11479-20-bigeasy@linutronix.de
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux; tag 'dma-mapping-5.5' of git://git.infradead.org/users/hch/dma-mapping
Pull dma-mapping updates from Christoph Hellwig:
- improve dma-debug scalability (Eric Dumazet)
- tiny dma-debug cleanup (Dan Carpenter)
- check for vmap memory in dma_map_single (Kees Cook)
- check for dma_addr_t overflows in dma-direct when using DMA offsets
(Nicolas Saenz Julienne)
- switch the x86 sta2x11 SOC to use more generic DMA code (Nicolas
Saenz Julienne)
- fix arm-nommu dma-ranges handling (Vladimir Murzin)
- use __initdata in CMA (Shyam Saini)
- replace the bus dma mask with a limit (Nicolas Saenz Julienne)
- merge the remapping helpers into the main dma-direct flow (me)
- switch xtensa to the generic dma remap handling (me)
- various cleanups around dma_capable (me)
- remove unused dev arguments to various dma-noncoherent helpers (me)
* 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux:
* tag 'dma-mapping-5.5' of git://git.infradead.org/users/hch/dma-mapping: (22 commits)
dma-mapping: treat dev->bus_dma_mask as a DMA limit
dma-direct: exclude dma_direct_map_resource from the min_low_pfn check
dma-direct: don't check swiotlb=force in dma_direct_map_resource
dma-debug: clean up put_hash_bucket()
powerpc: remove support for NULL dev in __phys_to_dma / __dma_to_phys
dma-direct: avoid a forward declaration for phys_to_dma
dma-direct: unify the dma_capable definitions
dma-mapping: drop the dev argument to arch_sync_dma_for_*
x86/PCI: sta2x11: use default DMA address translation
dma-direct: check for overflows on 32 bit DMA addresses
dma-debug: increase HASH_SIZE
dma-debug: reorder struct dma_debug_entry fields
xtensa: use the generic uncached segment support
dma-mapping: merge the generic remapping helpers into dma-direct
dma-direct: provide mmap and get_sgtable method overrides
dma-direct: remove the dma_handle argument to __dma_direct_alloc_pages
dma-direct: remove __dma_direct_free_pages
usb: core: Remove redundant vmap checks
kernel: dma-contiguous: mark CMA parameters __initdata/__initconst
dma-debug: add a schedule point in debug_dma_dump_mappings()
Pull x86 asm updates from Ingo Molnar:
"The main changes in this cycle were:
- Cross-arch changes to move the linker sections for NOTES and
EXCEPTION_TABLE into the RO_DATA area, where they belong on most
architectures. (Kees Cook)
- Switch the x86 linker fill byte from x90 (NOP) to 0xcc (INT3), to
trap jumps into the middle of those padding areas instead of
sliding execution. (Kees Cook)
- A thorough cleanup of symbol definitions within x86 assembler code.
The rather randomly named macros got streamlined around a
(hopefully) straightforward naming scheme:
SYM_START(name, linkage, align...)
SYM_END(name, sym_type)
SYM_FUNC_START(name)
SYM_FUNC_END(name)
SYM_CODE_START(name)
SYM_CODE_END(name)
SYM_DATA_START(name)
SYM_DATA_END(name)
etc - with about three times of these basic primitives with some
label, local symbol or attribute variant, expressed via postfixes.
No change in functionality intended. (Jiri Slaby)
- Misc other changes, cleanups and smaller fixes"
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (67 commits)
x86/entry/64: Remove pointless jump in paranoid_exit
x86/entry/32: Remove unused resume_userspace label
x86/build/vdso: Remove meaningless CFLAGS_REMOVE_*.o
m68k: Convert missed RODATA to RO_DATA
x86/vmlinux: Use INT3 instead of NOP for linker fill bytes
x86/mm: Report actual image regions in /proc/iomem
x86/mm: Report which part of kernel image is freed
x86/mm: Remove redundant address-of operators on addresses
xtensa: Move EXCEPTION_TABLE to RO_DATA segment
powerpc: Move EXCEPTION_TABLE to RO_DATA segment
parisc: Move EXCEPTION_TABLE to RO_DATA segment
microblaze: Move EXCEPTION_TABLE to RO_DATA segment
ia64: Move EXCEPTION_TABLE to RO_DATA segment
h8300: Move EXCEPTION_TABLE to RO_DATA segment
c6x: Move EXCEPTION_TABLE to RO_DATA segment
arm64: Move EXCEPTION_TABLE to RO_DATA segment
alpha: Move EXCEPTION_TABLE to RO_DATA segment
x86/vmlinux: Move EXCEPTION_TABLE to RO_DATA segment
x86/vmlinux: Actually use _etext for the end of the text segment
vmlinux.lds.h: Allow EXCEPTION_TABLE to live in RO_DATA
git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk
Pull printk updates from Petr Mladek:
- Allow to print symbolic error names via new %pe modifier.
- Use pr_warn() instead of the remaining pr_warning() calls. Fix
formatting of the related lines.
- Add VSPRINTF entry to MAINTAINERS.
* tag 'printk-for-5.5' of git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk: (32 commits)
checkpatch: don't warn about new vsprintf pointer extension '%pe'
MAINTAINERS: Add VSPRINTF
tools lib api: Renaming pr_warning to pr_warn
ASoC: samsung: Use pr_warn instead of pr_warning
lib: cpu_rmap: Use pr_warn instead of pr_warning
trace: Use pr_warn instead of pr_warning
dma-debug: Use pr_warn instead of pr_warning
vgacon: Use pr_warn instead of pr_warning
fs: afs: Use pr_warn instead of pr_warning
sh/intc: Use pr_warn instead of pr_warning
scsi: Use pr_warn instead of pr_warning
platform/x86: intel_oaktrail: Use pr_warn instead of pr_warning
platform/x86: asus-laptop: Use pr_warn instead of pr_warning
platform/x86: eeepc-laptop: Use pr_warn instead of pr_warning
oprofile: Use pr_warn instead of pr_warning
of: Use pr_warn instead of pr_warning
macintosh: Use pr_warn instead of pr_warning
idsn: Use pr_warn instead of pr_warning
ide: Use pr_warn instead of pr_warning
crypto: n2: Use pr_warn instead of pr_warning
These are pure cache maintainance routines, so drop the unused
struct device argument.
Suggested-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Rename RW_DATA_SECTION to RW_DATA. (Calling this a "section" is a lie,
since it's multiple sections and section flags cannot be applied to
the macro.)
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # s390
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> # m68k
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: linux-alpha@vger.kernel.org
Cc: linux-c6x-dev@linux-c6x.org
Cc: linux-ia64@vger.kernel.org
Cc: linux-s390@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Rick Edgecombe <rick.p.edgecombe@intel.com>
Cc: Segher Boessenkool <segher@kernel.crashing.org>
Cc: Will Deacon <will@kernel.org>
Cc: x86-ml <x86@kernel.org>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Link: https://lkml.kernel.org/r/20191029211351.13243-14-keescook@chromium.org
The .notes section should be non-executable read-only data. As such,
move it to the RO_DATA macro instead of being per-architecture defined.
Link: https://lkml.kernel.org/r/20191029211351.13243-11-keescook@chromium.org
As said in commit f2c2cbcc35d4 ("powerpc: Use pr_warn instead of
pr_warning"), removing pr_warning so all logging messages use a
consistent <prefix>_warn style. Let's do it.
Link: http://lkml.kernel.org/r/20191018031850.48498-6-wangkefeng.wang@huawei.com
To: linux-kernel@vger.kernel.org
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Signed-off-by: Petr Mladek <pmladek@suse.com>
Matt bisected a sparc64 specific issue with semctl, shmctl and msgctl
to a commit from my y2038 series in linux-5.1, as I missed the custom
sys_ipc() wrapper that sparc64 uses in place of the generic version that
I patched.
The problem is that the sys_{sem,shm,msg}ctl() functions in the kernel
now do not allow being called with the IPC_64 flag any more, resulting
in a -EINVAL error when they don't recognize the command.
Instead, the correct way to do this now is to call the internal
ksys_old_{sem,shm,msg}ctl() functions to select the API version.
As we generally move towards these functions anyway, change all of
sparc_ipc() to consistently use those in place of the sys_*() versions,
and move the required ksys_*() declarations into linux/syscalls.h
The IS_ENABLED(CONFIG_SYSVIPC) check is required to avoid link
errors when ipc is disabled.
Reported-by: Matt Turner <mattst88@gmail.com>
Fixes: 275f22148e87 ("ipc: rename old-style shmctl/semctl/msgctl syscalls")
Cc: stable@vger.kernel.org
Tested-by: Matt Turner <mattst88@gmail.com>
Tested-by: Anatoly Pugachev <matorola@gmail.com>
A while ago Arnd made it possible to give new system calls the same
syscall number on all architectures (except alpha). To not break this
nice new feature let's mark 435 for clone3 as reserved on all
architectures that do not yet implement it.
Even if an architecture does not plan to implement it this ensures that
new system calls coming after clone3 will have the same number on all
architectures.
Signed-off-by: Christian Brauner <christian@brauner.io>
Cc: linux-m68k@lists.linux-m68k.org
Cc: linux-mips@vger.kernel.org
Cc: linux-parisc@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Link: https://lore.kernel.org/r/20190714192205.27190-2-christian@brauner.io
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
git://git.kernel.org/pub/scm/linux/kernel/git/brauner/linux
Pull pidfd updates from Christian Brauner:
"This adds two main features.
- First, it adds polling support for pidfds. This allows process
managers to know when a (non-parent) process dies in a race-free
way.
The notification mechanism used follows the same logic that is
currently used when the parent of a task is notified of a child's
death. With this patchset it is possible to put pidfds in an
{e}poll loop and get reliable notifications for process (i.e.
thread-group) exit.
- The second feature compliments the first one by making it possible
to retrieve pollable pidfds for processes that were not created
using CLONE_PIDFD.
A lot of processes get created with traditional PID-based calls
such as fork() or clone() (without CLONE_PIDFD). For these
processes a caller can currently not create a pollable pidfd. This
is a problem for Android's low memory killer (LMK) and service
managers such as systemd.
Both patchsets are accompanied by selftests.
It's perhaps worth noting that the work done so far and the work done
in this branch for pidfd_open() and polling support do already see
some adoption:
- Android is in the process of backporting this work to all their LTS
kernels [1]
- Service managers make use of pidfd_send_signal but will need to
wait until we enable waiting on pidfds for full adoption.
- And projects I maintain make use of both pidfd_send_signal and
CLONE_PIDFD [2] and will use polling support and pidfd_open() too"
[1] https://android-review.googlesource.com/q/topic:%22pidfd+polling+support+4.9+backport%22
https://android-review.googlesource.com/q/topic:%22pidfd+polling+support+4.14+backport%22
https://android-review.googlesource.com/q/topic:%22pidfd+polling+support+4.19+backport%22
[2] https://github.com/lxc/lxc/blob/aab6e3eb73c343231cdde775db938994fc6f2803/src/lxc/start.c#L1753
* tag 'pidfd-updates-v5.3' of git://git.kernel.org/pub/scm/linux/kernel/git/brauner/linux:
tests: add pidfd_open() tests
arch: wire-up pidfd_open()
pid: add pidfd_open()
pidfd: add polling selftests
pidfd: add polling support
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull force_sig() argument change from Eric Biederman:
"A source of error over the years has been that force_sig has taken a
task parameter when it is only safe to use force_sig with the current
task.
The force_sig function is built for delivering synchronous signals
such as SIGSEGV where the userspace application caused a synchronous
fault (such as a page fault) and the kernel responded with a signal.
Because the name force_sig does not make this clear, and because the
force_sig takes a task parameter the function force_sig has been
abused for sending other kinds of signals over the years. Slowly those
have been fixed when the oopses have been tracked down.
This set of changes fixes the remaining abusers of force_sig and
carefully rips out the task parameter from force_sig and friends
making this kind of error almost impossible in the future"
* 'siginfo-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (27 commits)
signal/x86: Move tsk inside of CONFIG_MEMORY_FAILURE in do_sigbus
signal: Remove the signal number and task parameters from force_sig_info
signal: Factor force_sig_info_to_task out of force_sig_info
signal: Generate the siginfo in force_sig
signal: Move the computation of force into send_signal and correct it.
signal: Properly set TRACE_SIGNAL_LOSE_INFO in __send_signal
signal: Remove the task parameter from force_sig_fault
signal: Use force_sig_fault_to_task for the two calls that don't deliver to current
signal: Explicitly call force_sig_fault on current
signal/unicore32: Remove tsk parameter from __do_user_fault
signal/arm: Remove tsk parameter from __do_user_fault
signal/arm: Remove tsk parameter from ptrace_break
signal/nds32: Remove tsk parameter from send_sigtrap
signal/riscv: Remove tsk parameter from do_trap
signal/sh: Remove tsk parameter from force_sig_info_fault
signal/um: Remove task parameter from send_sigtrap
signal/x86: Remove task parameter from send_sigtrap
signal: Remove task parameter from force_sig_mceerr
signal: Remove task parameter from force_sigsegv
This wires up the pidfd_open() syscall into all arches at once.
Reviewed-by: David Howells <dhowells@redhat.com>
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Joel Fernandes (Google) <joel@joelfernandes.org>
Cc: Jann Horn <jannh@google.com>
Cc: Andy Lutomirsky <luto@kernel.org>
Cc: Aleksa Sarai <cyphar@cyphar.com>
Cc: linux-api@vger.kernel.org
Cc: linux-xtensa@linux-xtensa.org
Cc: x86@kernel.org
Based on 1 normalized pattern(s):
this work is licensed under the terms of the gnu gpl version 2
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 48 file(s).
Reviewed-by: Allison Randal <allison@lohutok.net>
Reviewed-by: Enrico Weigelt <info@metux.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190604081204.624030236@linutronix.de
The PERF_EVENT_IOC_PERIOD ioctl command can be used to change the
sample period of a running perf_event. Consequently, when calculating
the next event period, the new period will only be considered after the
previous one has overflowed.
This patch changes the calculation of the remaining event ticks so that
they are offset if the period has changed.
See commit 3581fe0ef37c ("ARM: 7556/1: perf: fix updated event period in
response to PERF_EVENT_IOC_PERIOD") for details.
Signed-off-by: Young Xiao <92siuyang@gmail.com>
In get_vdev_port_node_info(), 'node_info->vdev_port.name' is allcoated
by kstrdup_const(), and it returns NULL when fails. So
'node_info->vdev_port.name' should be checked.
Signed-off-by: Gen Zhang <blackgod016574@gmail.com>
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license as published by
the free software foundation either version 2 of the license or at
your option any later version
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 3029 file(s).
Link: https://lkml.kernel.org/r/20190527070032.746973796@linutronix.de
As synchronous exceptions really only make sense against the current
task (otherwise how are you synchronous) remove the task parameter
from from force_sig_fault to make it explicit that is what is going
on.
The two known exceptions that deliver a synchronous exception to a
stopped ptraced task have already been changed to
force_sig_fault_to_task.
The callers have been changed with the following emacs regular expression
(with obvious variations on the architectures that take more arguments)
to avoid typos:
force_sig_fault[(]\([^,]+\)[,]\([^,]+\)[,]\([^,]+\)[,]\W+current[)]
force_sig_fault(\1,\2,\3)
All of the remaining callers pass current into force_sig so
remove the task parameter to make this obvious and to make
misuse more difficult in the future.
This also makes it clear force_sig passes current into force_sig_info.
The function force_sigsegv is always called on the current task
so passing in current is redundant and not passing in current
makes this fact obvious.
This also makes it clear force_sigsegv always calls force_sig
on the current task.
Based on 2 normalized pattern(s):
your option any later version this program is distributed in the
hope that it will be useful but without any warranty without even
the implied warranty of merchantability or fitness for a particular
purpose see the gnu general public license for more details you
should have received a copy of the gnu general public license along
with this program if not see http www gnu org licenses
purpose see the gnu general public license for more details [based]
[from] [clk] [highbank] [c] you should have received a copy of the
gnu general public license along with this program if not see http
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 355 file(s).
Reviewed-by: Jilayne Lovejoy <opensource@jilayne.com>
Reviewed-by: Steve Winslow <swinslow@gmail.com>
Link: https://lkml.kernel.org/r/20190519154041.837383322@linutronix.de
Add SPDX license identifiers to all files which:
- Have no license information of any form
- Have MODULE_LICENCE("GPL*") inside which was used in the initial
scan/conversion to ignore the file
These files fall under the project license, GPL v2 only. The resulting SPDX
license identifier is:
GPL-2.0-only
- Have EXPORT_.*_SYMBOL_GPL inside which was used in the
initial scan/conversion to ignore the file
GPL-2.0-only
Pull more vfs mount updates from Al Viro:
"Propagation of new syscalls to other architectures + cosmetic change
from Christian (fscontext didn't follow the convention for anon inode
names)"
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
uapi: Wire up the mount API syscalls on non-x86 arches [ver #2]
uapi, x86: Fix the syscall numbering of the mount API syscalls [ver #2]
uapi, fsopen: use square brackets around "fscontext" [ver #2]
Wire up the mount API syscalls on non-x86 arches.
Pull more power management updates from Rafael Wysocki:
"These fix a recent regression causing kernels built with CONFIG_PM
unset to crash on systems that support the Performance and Energy Bias
Hint (EPB), clean up the cpufreq core and some users of transition
notifiers and introduce a new power domain flag into the generic power
domains framework (genpd).
Specifics:
- Fix recent regression causing kernels built with CONFIG_PM unset to
crash on systems that support the Performance and Energy Bias Hint
(EPB) by avoiding to compile the EPB-related code depending on
CONFIG_PM when it is unset (Rafael Wysocki).
- Clean up the transition notifier invocation code in the cpufreq
core and change some users of cpufreq transition notifiers
accordingly (Viresh Kumar).
- Change MAINTAINERS to cover the schedutil governor as part of
cpufreq (Viresh Kumar).
- Simplify cpufreq_init_policy() to avoid redundant computations (Yue
Hu).
- Add explanatory comment to the cpufreq core (Rafael Wysocki).
- Introduce a new flag, GENPD_FLAG_RPM_ALWAYS_ON, to the generic
power domains (genpd) framework along with the first user of it
(Leonard Crestez)"
* tag 'pm-5.2-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
soc: imx: gpc: Use GENPD_FLAG_RPM_ALWAYS_ON for ERR009619
PM / Domains: Add GENPD_FLAG_RPM_ALWAYS_ON flag
cpufreq: Update MAINTAINERS to include schedutil governor
cpufreq: Don't find governor for setpolicy drivers in cpufreq_init_policy()
cpufreq: Explain the kobject_put() in cpufreq_policy_alloc()
cpufreq: Call transition notifier only once for each policy
x86: intel_epb: Take CONFIG_PM into account
Currently, the notifiers are called once for each CPU of the policy->cpus
cpumask. It would be more optimal if the notifier can be called only
once and all the relevant information be provided to it. Out of the 23
drivers that register for the transition notifiers today, only 4 of them
do per-cpu updates and the callback for the rest can be called only once
for the policy without any impact.
This would also avoid multiple function calls to the notifier callbacks
and reduce multiple iterations of notifier core's code (which does
locking as well).
This patch adds pointer to the cpufreq policy to the struct
cpufreq_freqs, so the notifier callback has all the information
available to it with a single call. The five drivers which perform
per-cpu updates are updated to use the cpufreq policy. The freqs->cpu
field is redundant now and is removed.
Acked-by: David S. Miller <davem@davemloft.net> (sparc)
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
One of the more common cases of allocation size calculations is finding the
size of a structure that has a zero-sized array at the end, along with memory
for some number of elements for that array. For example:
struct foo {
int stuff;
void *entry[];
instance = kzalloc(sizeof(struct foo) + sizeof(void *) * count, GFP_KERNEL);
Instead of leaving these open-coded and prone to type mistakes, we can now
use the new struct_size() helper:
instance = kzalloc(struct_size(instance, entry, count), GFP_KERNEL);
This code was detected with the help of Coccinelle.
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Remove duplicate header which is included twice.
Signed-off-by: Jagadeesh Pagadala <jagdsh.linux@gmail.com>
Reviewed-by: Mukesh Ojha <mojha@codeaurora.org>
- Allow state reset of printk_once() calls.
- Prevent crashes when dereferencing invalid pointers in vsprintf().
Only the first byte is checked for simplicity.
- Make vsprintf warnings consistent and inlined.
- Treewide conversion of obsolete %pf, %pF to %ps, %pF printf
modifiers.
- Some clean up of vsprintf and test_printf code.
* tag 'printk-for-5.2' of git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk:
lib/vsprintf: Make function pointer_string static
vsprintf: Limit the length of inlined error messages
vsprintf: Avoid confusion between invalid address and value
vsprintf: Prevent crash when dereferencing invalid pointers
vsprintf: Consolidate handling of unknown pointer specifiers
vsprintf: Factor out %pO handler as kobject_string()
vsprintf: Factor out %pV handler as va_format()
vsprintf: Factor out %p[iI] handler as ip_addr_string()
vsprintf: Do not check address of well-known strings
vsprintf: Consistent %pK handling for kptr_restrict == 0
vsprintf: Shuffle restricted_pointer()
printk: Tie printk_once / printk_deferred_once into .data.once for reset
treewide: Switch printk users from %pf and %pF to %ps and %pS, respectively
lib/test_printf: Switch to bitmap_zalloc()
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic
Pull syscall numbering updates from Arnd Bergmann:
"arch: add pidfd and io_uring syscalls everywhere
This comes a bit late, but should be in 5.1 anyway: we want the newly
added system calls to be synchronized across all architectures in the
release.
I hope that in the future, any newly added system calls can be added
to all architectures at the same time, and tested there while they are
in linux-next, avoiding dependencies between the architecture
maintainer trees and the tree that contains the new system call"
* tag 'syscalls-5.1' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic:
Add the io_uring and pidfd_send_signal system calls to all architectures.
These system calls are designed to handle both native and compat tasks,
so all entries are the same across architectures, only arm-compat and
the generic tale still use an old format.
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> (s390)
Now that we allow drivers to always need to set larger than required
DMA masks we need to be a little more careful in the sun4v PCI iommu
driver to chose when to select the ATU support - a larger DMA mask
can be set even when the platform does not support ATU, so we always
have to check if it is avaiable before using it. Add a little helper
for that and use it in all the places where we make ATU usage decisions
based on the DMA mask.
Fixes: 24132a419c68 ("sparc64/pci_sun4v: allow large DMA masks")
Reported-by: Meelis Roos <mroos@linux.ee>
Tested-by: Meelis Roos <mroos@linux.ee>
%pF and %pf are functionally equivalent to %pS and %ps conversion
specifiers. The former are deprecated, therefore switch the current users
to use the preferred variant.
The changes have been produced by the following command:
git grep -l '%p[fF]' | grep -v '^\(tools\|Documentation\)/' | \
while read i; do perl -i -pe 's/%pf/%ps/g; s/%pF/%pS/g;' $i; done
And verifying the result.
Link: http://lkml.kernel.org/r/20190325193229.23390-1-sakari.ailus@linux.intel.com
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: linux-um@lists.infradead.org
Cc: xen-devel@lists.xenproject.org
Cc: linux-acpi@vger.kernel.org
Cc: linux-pm@vger.kernel.org
Cc: drbd-dev@lists.linbit.com
Cc: linux-block@vger.kernel.org
Cc: linux-mmc@vger.kernel.org
Cc: linux-nvdimm@lists.01.org
Cc: linux-pci@vger.kernel.org
Cc: linux-scsi@vger.kernel.org
Cc: linux-btrfs@vger.kernel.org
Cc: linux-f2fs-devel@lists.sourceforge.net
Cc: linux-mm@kvack.org
Cc: ceph-devel@vger.kernel.org
Cc: netdev@vger.kernel.org
Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Acked-by: David Sterba <dsterba@suse.com> (for btrfs)
Acked-by: Mike Rapoport <rppt@linux.ibm.com> (for mm/memblock.c)
Acked-by: Bjorn Helgaas <bhelgaas@google.com> (for drivers/pci)
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Add panic() calls if memblock_alloc*() returns NULL.
Most of the changes are simply addition of
if(!ptr)
panic();
statements after the calls to memblock_alloc*() variants.
Exceptions are pcpu_populate_pte() and kernel_map_range() that were
slightly refactored to accommodate the change.
Link: http://lkml.kernel.org/r/1548057848-15136-16-git-send-email-rppt@linux.ibm.com
Signed-off-by: Mike Rapoport <rppt@linux.ibm.com>
Cc: Christophe Leroy <christophe.leroy@c-s.fr>
Cc: Dennis Zhou <dennis@kernel.org>
Cc: Greentime Hu <green.hu@gmail.com>
Cc: Guan Xuetao <gxt@pku.edu.cn>
Cc: Guo Ren <guoren@kernel.org>
Cc: Guo Ren <ren_guo@c-sky.com> [c-sky]
Cc: Juergen Gross <jgross@suse.com> [Xen]
Cc: Mark Salter <msalter@redhat.com>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: Paul Burton <paul.burton@mips.com>
Cc: Petr Mladek <pmladek@suse.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Rich Felker <dalias@libc.org>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Rob Herring <robh@kernel.org>
Cc: Russell King <linux@armlinux.org.uk>
Cc: Stafford Horne <shorne@gmail.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
memblock_alloc() already clears the allocated memory, no point in doing
it twice.
Link: http://lkml.kernel.org/r/1548057848-15136-14-git-send-email-rppt@linux.ibm.com
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k]
The last parameter of memblock_alloc_from() is the lower limit for the
memory allocation. When it is 0, the call is equivalent to
memblock_alloc().
Link: http://lkml.kernel.org/r/1548057848-15136-13-git-send-email-rppt@linux.ibm.com
Acked-by: Paul Burton <paul.burton@mips.com> # MIPS part
Pull DMA mapping updates from Christoph Hellwig:
- add debugfs support for dumping dma-debug information (Corentin
Labbe)
- Kconfig cleanups (Andy Shevchenko and me)
- debugfs cleanups (Greg Kroah-Hartman)
- improve dma_map_resource and use it in the media code
- arch_setup_dma_ops / arch_teardown_dma_ops cleanups
- various small cleanups and improvements for the per-device coherent
allocator
- make the DMA mask an upper bound and don't fail "too large" dma mask
in the remaning two architectures - this will allow big driver
cleanups in the following merge windows
* tag 'dma-mapping-5.1' of git://git.infradead.org/users/hch/dma-mapping: (21 commits)
Documentation/DMA-API-HOWTO: update dma_mask sections
sparc64/iommu: allow large DMA masks
sparc64: refactor the ali DMA quirk
ccio: allow large DMA masks
dma-mapping: remove the DMA_MEMORY_EXCLUSIVE flag
dma-mapping: remove dma_mark_declared_memory_occupied
dma-mapping: move CONFIG_DMA_CMA to kernel/dma/Kconfig
dma-mapping: improve selection of dma_declare_coherent availability
dma-mapping: remove an incorrect __iommem annotation
of: select OF_RESERVED_MEM automatically
device.h: dma_mem is only needed for HAVE_GENERIC_DMA_COHERENT
mfd/sm501: depend on HAS_DMA
dma-mapping: add a kconfig symbol for arch_teardown_dma_ops availability
dma-mapping: add a kconfig symbol for arch_setup_dma_ops availability
dma-mapping: move debug configuration options to kernel/dma
dma-debug: add dumping facility via debugfs
dma: debug: no need to check return value of debugfs_create functions
videobuf2: replace a layering violation with dma_map_resource
dma-mapping: don't BUG when calling dma_map_resource on RAM
There are several early memory allocations in arch/ code that use
memblock_phys_alloc() to allocate memory, convert the returned physical
address to the virtual address and then set the allocated memory to
zero.
Exactly the same behaviour can be achieved simply by calling
memblock_alloc(): it allocates the memory in the same way as
memblock_phys_alloc(), then it performs the phys_to_virt() conversion
and clears the allocated memory.
Replace the longer sequence with a simpler call to memblock_alloc().
Link: http://lkml.kernel.org/r/1546248566-14910-6-git-send-email-rppt@linux.ibm.com
Cc: Jonas Bonn <jonas@southpole.se>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Cc: Vincent Chen <deanbo422@gmail.com>
Merge misc updates from Andrew Morton:
- a few misc things
- ocfs2 updates
- most of MM
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (159 commits)
tools/testing/selftests/proc/proc-self-syscall.c: remove duplicate include
proc: more robust bulk read test
proc: test /proc/*/maps, smaps, smaps_rollup, statm
proc: use seq_puts() everywhere
proc: read kernel cpu stat pointer once
proc: remove unused argument in proc_pid_lookup()
fs/proc/thread_self.c: code cleanup for proc_setup_thread_self()
fs/proc/self.c: code cleanup for proc_setup_self()
proc: return exit code 4 for skipped tests
mm,mremap: bail out earlier in mremap_to under map pressure
mm/sparse: fix a bad comparison
mm/memory.c: do_fault: avoid usage of stale vm_area_struct
writeback: fix inode cgroup switching comment
mm/huge_memory.c: fix "orig_pud" set but not used
mm/hotplug: fix an imbalance with DEBUG_PAGEALLOC
mm/memcontrol.c: fix bad line in comment
mm/cma.c: cma_declare_contiguous: correct err handling
mm/page_ext.c: fix an imbalance with kmemleak
mm/compaction: pass pgdat to too_many_isolated() instead of zone
mm: remove zone_lru_lock() function, access ->lru_lock directly
Patch series "Replace all open encodings for NUMA_NO_NODE", v3.
All these places for replacement were found by running the following
grep patterns on the entire kernel code. Please let me know if this
might have missed some instances. This might also have replaced some
false positives. I will appreciate suggestions, inputs and review.
1. git grep "nid == -1"
2. git grep "node == -1"
3. git grep "nid = -1"
4. git grep "node = -1"
This patch (of 2):
At present there are multiple places where invalid node number is
encoded as -1. Even though implicitly understood it is always better to
have macros in there. Replace these open encodings for an invalid node
number with the global macro NUMA_NO_NODE. This helps remove NUMA
related assumptions like 'invalid node' from various places redirecting
them to a common definition.
Link: http://lkml.kernel.org/r/1545127933-10711-2-git-send-email-anshuman.khandual@arm.com
Signed-off-by: Anshuman Khandual <anshuman.khandual@arm.com>
Reviewed-by: David Hildenbrand <david@redhat.com>
Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> [ixgbe]
Acked-by: Jens Axboe <axboe@kernel.dk> [mtip32xx]
Acked-by: Vinod Koul <vkoul@kernel.org> [dmaengine.c]
Acked-by: Michael Ellerman <mpe@ellerman.id.au> [powerpc]
Acked-by: Doug Ledford <dledford@redhat.com> [drivers/infiniband]
Cc: Joseph Qi <jiangqi903@gmail.com>
Cc: Hans Verkuil <hverkuil@xs4all.nl>
We've been moving to a model where the device just sets the DMA mask
supported by it, instead of having to fallback to something it thinks
the platform might support. Sparc64 is the remaining holdout forcing
drivers to supply a matching mask. Change dma_4v_supported to just
check if the supplied dma mask is large enough. and adjust the mapping
code to check ATU presence in addition to the DMA mask to decide on
the mapping method.
drivers to supply a matching mask. Change dma_4u_supported to just
check if the supplied dma mask is large enough as nothing in the
iommu.c code (or the core DMA code) actually looks at the DMA mask
later on.
Do the quirk first in the dma_supported routines, as we don't need
any of the other checks for it, and remove the duplicate mask checking
that is already done by the callers.
This adds 21 new system calls on each ABI that has 32-bit time_t
today. All of these have the exact same semantics as their existing
counterparts, and the new ones all have macro names that end in 'time64'
for clarification.
This gets us to the point of being able to safely use a C library
that has 64-bit time_t in user space. There are still a couple of
loose ends to tie up in various areas of the code, but this is the
big one, and should be entirely uncontroversial at this point.
In particular, there are four system calls (getitimer, setitimer,
waitid, and getrusage) that don't have a 64-bit counterpart yet,
but these can all be safely implemented in the C library by wrapping
around the existing system calls because the 32-bit time_t they
pass only counts elapsed time, not time since the epoch. They
will be dealt with later.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
The time, stime, utime, utimes, and futimesat system calls are only
used on older architectures, and we do not provide y2038 safe variants
of them, as they are replaced by clock_gettime64, clock_settime64,
and utimensat_time64.
However, for consistency it seems better to have the 32-bit architectures
that still use them call the "time32" entry points (leaving the
traditional handlers for the 64-bit architectures), like we do for system
calls that now require two versions.
Note: We used to always define __ARCH_WANT_SYS_TIME and
__ARCH_WANT_SYS_UTIME and only set __ARCH_WANT_COMPAT_SYS_TIME and
__ARCH_WANT_SYS_UTIME32 for compat mode on 64-bit kernels. Now this is
reversed: only 64-bit architectures set __ARCH_WANT_SYS_TIME/UTIME, while
we need __ARCH_WANT_SYS_TIME32/UTIME32 for 32-bit architectures and compat
mode. The resulting asm/unistd.h changes look a bit counterintuitive.
This is only a cleanup patch and it should not change any behavior.
This is the big flip, where all 32-bit architectures set COMPAT_32BIT_TIME
and use the _time32 system calls from the former compat layer instead
of the system calls that take __kernel_timespec and similar arguments.
The temporary redirects for __kernel_timespec, __kernel_itimerspec
and __kernel_timex can get removed with this.
It would be easy to split this commit by architecture, but with the new
generated system call tables, it's easy enough to do it all at once,
which makes it a little easier to check that the changes are the same
in each table.
A lot of system calls that pass a time_t somewhere have an implementation
using a COMPAT_SYSCALL_DEFINEx() on 64-bit architectures, and have
been reworked so that this implementation can now be used on 32-bit
architectures as well.
The missing step is to redefine them using the regular SYSCALL_DEFINEx()
to get them out of the compat namespace and make it possible to build them
on 32-bit architectures.
Any system call that ends in 'time' gets a '32' suffix on its name for
that version, while the others get a '_time32' suffix, to distinguish
them from the normal version, which takes a 64-bit time argument in the
future.
In this step, only 64-bit architectures are changed, doing this rename
first lets us avoid touching the 32-bit architectures twice.
struct timex is not y2038 safe.
Replace all uses of timex with y2038 safe __kernel_timex.
Note that struct __kernel_timex is an ABI interface definition.
We could define a new structure based on __kernel_timex that
is only available internally instead. Right now, there isn't
a strong motivation for this as the structure is isolated to
a few defined struct timex interfaces and such a structure would
be exactly the same as struct timex.
The patch was generated by the following coccinelle script:
virtual patch
@depends on patch forall@
identifier ts;
expression e;
- struct timex ts;
+ struct __kernel_timex ts;
- struct timex ts = {};
+ struct __kernel_timex ts = {};
- struct timex ts = e;
+ struct __kernel_timex ts = e;
- struct timex *ts;
+ struct __kernel_timex *ts;
(memset \| copy_from_user \| copy_to_user \)(...,
- sizeof(struct timex))
+ sizeof(struct __kernel_timex))
identifier ts;
identifier fn;
fn(...,
- struct timex *ts,
+ struct __kernel_timex *ts,
identifier ts;
identifier fn;
fn(...,
- struct timex *ts) {
+ struct __kernel_timex *ts) {
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
sparc64 is the only architecture on Linux that has a 'timeval'
definition with a 32-bit tv_usec but a 64-bit tv_sec. This causes
problems for sparc32 compat mode when we convert it to use the
new __kernel_timex type that has the same layout as all other
64-bit architectures.
To avoid adding sparc64 specific code into the generic adjtimex
implementation, this adds a wrapper in the sparc64 system call handling
that converts the sparc64 'timex' into the new '__kernel_timex'.
At this point, the two structures are defined to be identical,
but that will change in the next step once we convert sparc32.
