Fix following warning:
auxio_32.c:133:33: warning: cast removes address space of expression
To fix this auxio_power_register had to be defined as u8 _iomem.
Use proper sbus operations on the pointer.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Fix following warnings:
process_32.c:67:6: warning: symbol 'arch_cpu_idle' was not declared. Should it be static?
process_32.c:257:16: warning: symbol 'sparc_do_fork' was not declared. Should it be static?
process_32.c:411:5: warning: symbol 'dump_fpu' was not declared. Should it be static?
Add missing includes and add one missing prototype.
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
show_regs() is inherently arch-dependent but it does make sense to print
generic debug information and some archs already do albeit in slightly
different forms. This patch introduces a generic function to print debug
information from show_regs() so that different archs print out the same
information and it's much easier to modify what's printed.
show_regs_print_info() prints out the same debug info as dump_stack()
does plus task and thread_info pointers.
* Archs which didn't print debug info now do.
alpha, arc, blackfin, c6x, cris, frv, h8300, hexagon, ia64, m32r,
metag, microblaze, mn10300, openrisc, parisc, score, sh64, sparc,
um, xtensa
* Already prints debug info. Replaced with show_regs_print_info().
The printed information is superset of what used to be there.
arm, arm64, avr32, mips, powerpc, sh32, tile, unicore32, x86
* s390 is special in that it used to print arch-specific information
along with generic debug info. Heiko and Martin think that the
arch-specific extra isn't worth keeping s390 specfic implementation.
Converted to use the generic version.
Note that now all archs print the debug info before actual register
dumps.
An example BUG() dump follows.
kernel BUG at /work/os/work/kernel/workqueue.c:4841!
invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #7
Hardware name: empty empty/S3992, BIOS 080011 10/26/2007
task: ffff88007c85e040 ti: ffff88007c860000 task.ti: ffff88007c860000
RIP: 0010:[<ffffffff8234a07e>] [<ffffffff8234a07e>] init_workqueues+0x4/0x6
RSP: 0000:ffff88007c861ec8 EFLAGS: 00010246
RAX: ffff88007c861fd8 RBX: ffffffff824466a8 RCX: 0000000000000001
RDX: 0000000000000046 RSI: 0000000000000001 RDI: ffffffff8234a07a
RBP: ffff88007c861ec8 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000000 R12: ffffffff8234a07a
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff88007dc00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: ffff88015f7ff000 CR3: 00000000021f1000 CR4: 00000000000007f0
Stack:
ffff88007c861ef8 ffffffff81000312 ffffffff824466a8 ffff88007c85e650
0000000000000003 0000000000000000 ffff88007c861f38 ffffffff82335e5d
ffff88007c862080 ffffffff8223d8c0 ffff88007c862080 ffffffff81c47760
Call Trace:
[<ffffffff81000312>] do_one_initcall+0x122/0x170
[<ffffffff82335e5d>] kernel_init_freeable+0x9b/0x1c8
[<ffffffff81c47760>] ? rest_init+0x140/0x140
[<ffffffff81c4776e>] kernel_init+0xe/0xf0
[<ffffffff81c6be9c>] ret_from_fork+0x7c/0xb0
v2: Typo fix in x86-32.
v3: CPU number dropped from show_regs_print_info() as
dump_stack_print_info() has been updated to print it. s390
specific implementation dropped as requested by s390 maintainers.
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile bits]
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits]
Both dump_stack() and show_stack() are currently implemented by each
architecture. show_stack(NULL, NULL) dumps the backtrace for the
current task as does dump_stack(). On some archs, dump_stack() prints
extra information - pid, utsname and so on - in addition to the
backtrace while the two are identical on other archs.
The usages in arch-independent code of the two functions indicate
show_stack(NULL, NULL) should print out bare backtrace while
dump_stack() is used for debugging purposes when something went wrong,
so it does make sense to print additional information on the task which
triggered dump_stack().
There's no reason to require archs to implement two separate but mostly
identical functions. It leads to unnecessary subtle information.
This patch expands the dummy fallback dump_stack() implementation in
lib/dump_stack.c such that it prints out debug information (taken from
x86) and invokes show_stack(NULL, NULL) and drops arch-specific
dump_stack() implementations in all archs except blackfin. Blackfin's
dump_stack() does something wonky that I don't understand.
Debug information can be printed separately by calling
dump_stack_print_info() so that arch-specific dump_stack()
implementation can still emit the same debug information. This is used
in blackfin.
This patch brings the following behavior changes.
* On some archs, an extra level in backtrace for show_stack() could be
printed. This is because the top frame was determined in
dump_stack() on those archs while generic dump_stack() can't do that
reliably. It can be compensated by inlining dump_stack() but not
sure whether that'd be necessary.
* Most archs didn't use to print debug info on dump_stack(). They do
now.
An example WARN dump follows.
WARNING: at kernel/workqueue.c:4841 init_workqueues+0x35/0x505()
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #9
0000000000000009 ffff88007c861e08 ffffffff81c614dc ffff88007c861e48
ffffffff8108f50f ffffffff82228240 0000000000000040 ffffffff8234a03c
0000000000000000 0000000000000000 0000000000000000 ffff88007c861e58
Call Trace:
[<ffffffff81c614dc>] dump_stack+0x19/0x1b
[<ffffffff8108f50f>] warn_slowpath_common+0x7f/0xc0
[<ffffffff8108f56a>] warn_slowpath_null+0x1a/0x20
[<ffffffff8234a071>] init_workqueues+0x35/0x505
v2: CPU number added to the generic debug info as requested by s390
folks and dropped the s390 specific dump_stack(). This loses %ksp
from the debug message which the maintainers think isn't important
enough to keep the s390-specific dump_stack() implementation.
dump_stack_print_info() is moved to kernel/printk.c from
lib/dump_stack.c. Because linkage is per objecct file,
dump_stack_print_info() living in the same lib file as generic
dump_stack() means that archs which implement custom dump_stack()
- at this point, only blackfin - can't use dump_stack_print_info()
as that will bring in the generic version of dump_stack() too. v1
The v1 patch broke build on blackfin due to this issue. The build
breakage was reported by Fengguang Wu.
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390 bits]
show_stack(current or NULL, NULL) is used by arch-independent code to dump
backtrace of the current task; however, sparc32 show_stack() doesn't
implement it and wouldn't print any backtrace when NULL @_ksp is specfied.
Make show_stack() acquire and use %fp if @tsk is NULL or current and @_ksp
is NULL. This makes %fp fetching in dump_stack() unnecessary. Make it
use NULL for @_ksp instead.
Only compile tested.
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Add generic cpu_idle support
sparc32:
- replace call to cpu_idle() with cpu_startup_entry()
- add arch_cpu_idle()
sparc64:
- smp_callin() now include cpu_startup_entry() call so we can
skip calling cpu_idle from assembler
- add arch_cpu_idle() and arch_cpu_idle_dead()
Reviewed-by: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com>
Cc: torvalds@linux-foundation.org
Cc: rusty@rustcorp.com.au
Cc: paulmck@linux.vnet.ibm.com
Cc: peterz@infradead.org
Cc: magnus.damm@gmail.com
Acked-by: David Miller <davem@davemloft.net>
Link: http://lkml.kernel.org/r/20130411193850.GA2330@merkur.ravnborg.org
(pm_idle)() is being removed from linux/pm.h
because Linux does not have such a cross-architecture concept.
sparc uses an idle function pointer in its architecture
specific code. So we re-name sparc use of pm_idle to sparc_idle.
Signed-off-by: Len Brown <len.brown@intel.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
getname() is intended to copy pathname strings from userspace into a
kernel buffer. The result is just a string in kernel space. It would
however be quite helpful to be able to attach some ancillary info to
the string.
For instance, we could attach some audit-related info to reduce the
amount of audit-related processing needed. When auditing is enabled,
we could also call getname() on the string more than once and not
need to recopy it from userspace.
This patchset converts the getname()/putname() interfaces to return
a struct instead of a string. For now, the struct just tracks the
string in kernel space and the original userland pointer for it.
Later, we'll add other information to the struct as it becomes
convenient.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
FPU state is saved into task_struct of created task. Current task continues
use of the state, so it needs TIF_USEDFPU flag is not cleared.
Created task receives fresh FPU and cleared TIF_USEFPU flag is required for it.
Signed-off-by: Kirill Tkhai <tkhai@yandex.ru>
With the removal of sun4c we can use the same cpu_idle()
implementation on UP and SMP.
This also fix it so we use the same version independent on LEON
enabled or not.
V2: Fixed whitespace issue pointed out by Josip Rodin.
Cc: Josip Rodin <joy@entuzijast.net>
Cc: Daniel Hellstrom <daniel@gaisler.com>
Cc: Konrad Eisele <konrad@gaisler.com>
It is commented out using #ifdef 0 / #endif,
and has been so for a long time.
It is a noop for srmmu - so use a define as sparc64 does.
And drop all sparc callers - no need to confuse our-self
be calling a noop function.
Machines with sun4c support are very rare these days, and noone
is using them for any practical purposes.
The sun4c support has been know broken for quite some time too.
So rather than trying to keep it up-to-date, lets get rid of it.
This allows us to do some very welcome cleanup of sparc32 support.
Updated the former sun4c specifc nmi (which was also used
for sun4m UP) to be a generic UP NMI.
Disintegrate asm/system.h for Sparc.
cc: sparclinux@vger.kernel.org
Coccinelle based conversion.
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Link: http://lkml.kernel.org/n/tip-24swm5zut3h9c4a6s46x8rws@git.kernel.org
The address limit is already set in flush_old_exec() so this assignment of
USER_DS is redundant.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Signed-off-by: Andrew Morton <akpm@google.com>
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
Make do_execve() take a const filename pointer so that kernel_execve() compiles
correctly on ARM:
arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type
This also requires the argv and envp arguments to be consted twice, once for
the pointer array and once for the strings the array points to. This is
because do_execve() passes a pointer to the filename (now const) to
copy_strings_kernel(). A simpler alternative would be to cast the filename
pointer in do_execve() when it's passed to copy_strings_kernel().
do_execve() may not change any of the strings it is passed as part of the argv
or envp lists as they are some of them in .rodata, so marking these strings as
const should be fine.
Further kernel_execve() and sys_execve() need to be changed to match.
This has been test built on x86_64, frv, arm and mips.
Tested-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Should mask stack with 0xf not "0x15".
Noticed by Blue Swirl <blauwirbel@gmail.com>
This is mandatory for 64-bit processes, and doing it also for 32-bit
processes saves a conditional in the compat case.
This fixes the glibc/nptl/tst-stdio1 test case, as well
as many others, on 64-bit.
First argument unused since 2.3.11.
Cc: <linux-arch@vger.kernel.org>
Move all applicable EXPORT_SYMBOL()s to the file where the respective
symbol is defined.
Removed all the includes that are no longer needed in sparc_ksyms_32.c
Comment all remaining EXPORT_SYMBOL()s in sparc_ksyms_32.c
Two symbols are shared with sparc64 thus the exports were removed from
the sparc_ksyms_64.c too, along with the include their ommission made
redundant.
Additions by Julian Calaby:
* Moved EXPORT_SYMBOL()s for prom functions to their rightful places.
* Made some minor cleanups to the includes and comments of sparc_ksyms_32.c
* Made another subtraction from sparc_ksyms_64.c
* Updated and tidied commit message.
* Rebased patch over sparc-2.6.git HEAD.
* Ensured that all modified files have the correct includes.
Signed-off-by: Julian Calaby <julian.calaby@gmail.com>
Renaming a few types to contain a 32 suffix makes the
type names compatible with sparc64 and thus makes sharing
between the two a lot easier.
Note: None of these definitions are expected part of the
stable ABI towards userspace.
It is always equals y so no need to test for it
o sparc32 files with identical names to sparc64 renamed to <name>_32.S
o introduced a few Kconfig helpers to simplify Makefile logic
o refactored Makefile to prepare for unification
- use obj-$(CONFIG_SPARC32) for sparc32 specific files
- use <name>_$(BITS) for files where sparc64 has a _64 variant
- sparc64 directly include a few files where sparc32 builds them,
refer to these files directly (no BITS)
- sneaked in -Werror as used by sparc64
o modified sparc/Makefile to use the new names for head/init_task
