Pull smp hotplug cleanups from Thomas Gleixner:
"This series is merily a cleanup of code copied around in arch/* and
not changing any of the real cpu hotplug horrors yet. I wish I'd had
something more substantial for 3.5, but I underestimated the lurking
horror..."
Fix up trivial conflicts in arch/{arm,sparc,x86}/Kconfig and
arch/sparc/include/asm/thread_info_32.h
* 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (79 commits)
um: Remove leftover declaration of alloc_task_struct_node()
task_allocator: Use config switches instead of magic defines
sparc: Use common threadinfo allocator
score: Use common threadinfo allocator
sh-use-common-threadinfo-allocator
mn10300: Use common threadinfo allocator
powerpc: Use common threadinfo allocator
mips: Use common threadinfo allocator
hexagon: Use common threadinfo allocator
m32r: Use common threadinfo allocator
frv: Use common threadinfo allocator
cris: Use common threadinfo allocator
x86: Use common threadinfo allocator
c6x: Use common threadinfo allocator
fork: Provide kmemcache based thread_info allocator
tile: Use common threadinfo allocator
fork: Provide weak arch_release_[task_struct|thread_info] functions
fork: Move thread info gfp flags to header
fork: Remove the weak insanity
sh: Remove cpu_idle_wait()
Davis S. Miller wrote:
The way we do that now is overkill. We only needed to use the MMU
cache ops when we had sun4c around because sun4c lacked support for
the "flush" instruction.
But all sun4m and later chips have it so we can use it
unconditionally.
So in the per_cpu_patch() code, get rid of the cache ops invocation,
and instead execute a "flush %reg" after each of the instruction patch
assignments, where %reg is set to the address of the instruction that
was stored into.
Perhaps take the flushi() definition from asm/cacheflush_64.h and
place it into asm/cacheflush.h, then you can simply use that.
Implemented as per suggestion.
Moved run-time patching before we call paging_init(),
so helper methods in paging_init() may utilise run-time patching too.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
One function was only used by leon - move it to a leon specific file.
Cc: Konrad Eisele <konrad@gaisler.com>
The registers are defined in leon_amba too.
Defines a sun4c register, thus completely unused.
Completely unused.
It is written, but never actually read.
GET_PROCESSOR4D_ID is completely unused, so delete it.
Move GET_PROCESSOR4M_ID to the sun4m specific trap code
which uses it.
We now no longer need to include asm/asi.h
- remove unused variables
- fix coding style issues that hurts my eyes
It's the one aberration in v8, the only cpu that
didn't actually have hardware multiply and divide
instructions.
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Reported-by: Josip Rodin <joy@entuzijast.net>
Reported-by: Sam Ravnborg <sam@ravnborg.org>
- remove all uses of btfixup header
- remove the btfixup header
- remove the btfixup code
Use sparc_config to hold the last two function pointers. There was no
point generating dedicated _ops structures only for these.
I ended up renaming set_cpu_int to send_ipi to
be consistent all way around.
send_ipi was moved to the *_smp.c files so
we could call the relevant method direct,
without any _ops indirection.
This is the last non-trivial user of btfixup.
Like sparc64, use a special patch section to resolve the various
implementations of how to read the current CPU's ID when we don't
have current_thread_info()->cpu necessarily available.
Tested-by: Sam Ravnborg <sam@ravnborg.org>
This eliminated most of the remaining users of btfixup.
There are some complications because of the special cases we
have for sun4d, leon, and some flavors of viking.
It was found that there are no cases where a flush_page_for_dma
method was not hooked up to something, so the "noflush" iommu
methods were removed.
Add some documentation to the viking_sun4d_smp_ops to describe exactly
the hardware bug which causes us to need special TLB flushing on
sun4d.
This set of changes displays one major danger of btfixup, interface
signatures are not always type checked fully. As seen here the iounit
variant of the map_dma_area routine had an incorrect type for one of
it's arguments.
It turns out to be harmless in this case, but just imagine trying to
debug something involving this kind of problem. No thanks.
These were used on sun4c during floppy data transfers since on that
chip we had to lock the cpu mappings into the TLB because we cannot
take a TLB miss during the assembler floppy interrupt handler that
does the data transfer.
That is no longer necessary since we've removed sun4c support, thus
this stuff can disappear completely.
The magic Swift SRMMU code in question has not been enabled for
something on the order of a decade, and it as well as it's comment
is there in the history in case we ever need it again.
Therefore all implementations are NOPs and we can kill this stuff
off.
We always have this instruction available, so no need to use
btfixup for it any more.
This also eradicates the whole of atomic_32.S and thus the
__atomic_begin and __atomic_end symbols completely.
Only one function left using btfixup.
pte_{filei,wrprotecti,mkcleani,mkoldi}
pte_{mkwrite,mkdirty,mkyoung}
And we can certainly get rid of the const function attributes, there
is no way that's needed any longer and no other arch uses this kind
of annotation here.
That lets us also get rid of the run-time initialization of
protection_map[] and all the ugly module workarounds for
PAGE_KERNEL and PAGE_SHARED to deal with the fact that we
can't do btfixups for modular code.
Also we can remove BTFIXUPCALL_SWAPO0G0 as that is no longer
used.
This was rather amusing, we were setting the btfixup vectors
based upon cpu type but all to the same exact generic srmmu
routines.
Furthermore, we were inconsistently marking the fixup as
either BTFIXUPCALL_SWAPO0G0 or BTFIXUPCALL_NORM.
What a mess, glad we could untangle this stuff.
Only one set of values exist, the SRMMU ones.
It is a noop for srmmu - so use a define as sparc64 does.
And drop all sparc callers - no need to confuse our-self
be calling a noop function.
This revealed that the implementation of switch_mm
had a bogus extra argument.
No harm as said argument was never used - but confusing.
Small cleanup to improve readability.
Dropped one test for sparc_cpu_model -
we already know that only sun4m support floppy.
Fix following warning:
arch/sparc/include/asm/floppy_32.h:342:5: warning: 'op' may be used uninitialized in this function
The warning are legitimite and we can end up using op uninitialized.
This fixes build with my gcc on UP.
I left some around, like the ones in the openprom headers, since
we need to think about which pieces of those datastructures and
code we can completely toss now.
All the remaining references are trivially removed since we've
just eliminated the final reference to sparc_cpu_model from
assembler code in commit b7d96ce189564e661909fbf8df39d7358149885b
("sparc32: Remove sparc_cpu_model read from floppy interrupt handler.")
These were for sharing some MMU code between sun4 and sun4c.
No longer used.
