Power on the CN11 and CN12 SD/MMC slots on ecovec is controlled by GPIOs,
which makes it possible to use the fixed voltage regulator driver to switch
card power on and off.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
On se7724 provide a 3.3V supply for its SD/MMC-card interfaces.
On sdk7786 provide a dummy regulator for the smsc911x driver.
On rsk devices provide a dummy regulator for the smsc911x driver.
On migor provide a 3.3V supply for its SD/MMC-card interfaces.
On kfr2r09 provide a 3.3V supply for its SD/MMC-card interfaces.
On ap325rxa provide a 3.3V supply for its SD/MMC-card interfaces and a
On sh7757lcr provide a 3.3V supply for its SD/MMC-card interfaces.
On sh2007 provide a dummy regulator for the smsc911x driver for the two
SMSC 9118 devices.
On polaris provide a dummy regulator for the smsc911x driver.
On magicpanelr2 provide a dummy regulator for the smsc911x driver.
On apsh4ad0a provide a dummy regulator for the smsc911x driver.
On apsh4a3a provide a dummy regulator for the smsc911x driver.
and 'sh/trivial' into sh-fixes-for-linus
A few wrappers were overlooked in the initial conversion, take care of
them now.
CROSS_COMPILE must be setup before using e.g. cc-option (and a few other
as-*, cc-*, ld-* macros), else they will check against the wrong compiler
when cross-compiling, and may invoke the cross compiler with wrong or
suboptimal compiler options.
Cc: linux-sh@vger.kernel.org
sh-linux-gnu-ld:--defsym 'jiffies=jiffies_64': ignoring invalid character `'' in expression
For some reason ld has recently started complaining about the quotes, so just
get rid of them, we don't need them for anything anyways.
This discards both the _32 and _64 versions in favour of the consolidated
generic one.
This kills off the special sh32/64 versions and adopts the generic
version. It should be possible to optimize this for SH-4A unaligned
loads, but this is a corner case that can be supported incrementally.
Commit 7025bec9125b0a02edcaf22c2dce753bf2c95480 ("sh: Kill off dead UBC
headers.") skipped arch/sh/include/cpu-sh2a/cpu/ubc.h. Since nothing is
using that header either, kill it off too.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Pull mtd update from David Woodhouse:
- More robust parsing especially of xattr data in JFFS2
- Updates to mxc_nand and gpmi drivers to support new boards and device tree
- Improve consistency of information about ECC strength in NAND devices
- Clean up partition handling of plat_nand
- Support NAND drivers without dedicated access to OOB area
- BCH hardware ECC support for OMAP
- Other fixes and cleanups, and a few new device IDs
Fixed trivial conflict in drivers/mtd/nand/gpmi-nand/gpmi-nand.c due to
added include files next to each other.
* tag 'for-linus-3.5-20120601' of git://git.infradead.org/linux-mtd: (75 commits)
mtd: mxc_nand: move ecc strengh setup before nand_scan_tail
mtd: block2mtd: fix recursive call of mtd_writev
mtd: gpmi-nand: define ecc.strength
mtd: of_parts: fix breakage in Kconfig
mtd: nand: fix scan_read_raw_oob
mtd: docg3 fix in-middle of blocks reads
mtd: cfi_cmdset_0002: Slight cleanup of fixup messages
mtd: add fixup for S29NS512P NOR flash.
jffs2: allow to complete xattr integrity check on first GC scan
jffs2: allow to discriminate between recoverable and non-recoverable errors
mtd: nand: omap: add support for hardware BCH ecc
ARM: OMAP3: gpmc: add BCH ecc api and modes
mtd: nand: check the return code of 'read_oob/read_oob_raw'
mtd: nand: remove 'sndcmd' parameter of 'read_oob/read_oob_raw'
mtd: m25p80: Add support for Winbond W25Q80BW
jffs2: get rid of jffs2_sync_super
jffs2: remove unnecessary GC pass on sync
jffs2: remove unnecessary GC pass on umount
jffs2: remove lock_super
mtd: gpmi: add gpmi support for mx6q
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull third pile of signal handling patches from Al Viro:
"This time it's mostly helpers and conversions to them; there's a lot
of stuff remaining in the tree, but that'll either go in -rc2
(isolated bug fixes, ideally via arch maintainers' trees) or will sit
there until the next cycle."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
x86: get rid of calling do_notify_resume() when returning to kernel mode
blackfin: check __get_user() return value
whack-a-mole with TIF_FREEZE
FRV: Optimise the system call exit path in entry.S [ver #2]
FRV: Shrink TIF_WORK_MASK [ver #2]
FRV: Prevent syscall exit tracing and notify_resume at end of kernel exceptions
new helper: signal_delivered()
powerpc: get rid of restore_sigmask()
most of set_current_blocked() callers want SIGKILL/SIGSTOP removed from set
set_restore_sigmask() is never called without SIGPENDING (and never should be)
TIF_RESTORE_SIGMASK can be set only when TIF_SIGPENDING is set
don't call try_to_freeze() from do_signal()
pull clearing RESTORE_SIGMASK into block_sigmask()
sh64: failure to build sigframe != signal without handler
openrisc: tracehook_signal_handler() is supposed to be called on success
new helper: sigmask_to_save()
new helper: restore_saved_sigmask()
new helpers: {clear,test,test_and_clear}_restore_sigmask()
HAVE_RESTORE_SIGMASK is defined on all architectures now
Pull vfs changes from Al Viro.
"A lot of misc stuff. The obvious groups:
* Miklos' atomic_open series; kills the damn abuse of
->d_revalidate() by NFS, which was the major stumbling block for
all work in that area.
* ripping security_file_mmap() and dealing with deadlocks in the
area; sanitizing the neighborhood of vm_mmap()/vm_munmap() in
general.
* ->encode_fh() switched to saner API; insane fake dentry in
mm/cleancache.c gone.
* assorted annotations in fs (endianness, __user)
* parts of Artem's ->s_dirty work (jff2 and reiserfs parts)
* ->update_time() work from Josef.
* other bits and pieces all over the place.
Normally it would've been in two or three pull requests, but
signal.git stuff had eaten a lot of time during this cycle ;-/"
Fix up trivial conflicts in Documentation/filesystems/vfs.txt (the
'truncate_range' inode method was removed by the VM changes, the VFS
update adds an 'update_time()' method), and in fs/btrfs/ulist.[ch] (due
to sparse fix added twice, with other changes nearby).
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (95 commits)
nfs: don't open in ->d_revalidate
vfs: retry last component if opening stale dentry
vfs: nameidata_to_filp(): don't throw away file on error
vfs: nameidata_to_filp(): inline __dentry_open()
vfs: do_dentry_open(): don't put filp
vfs: split __dentry_open()
vfs: do_last() common post lookup
vfs: do_last(): add audit_inode before open
vfs: do_last(): only return EISDIR for O_CREAT
vfs: do_last(): check LOOKUP_DIRECTORY
vfs: do_last(): make ENOENT exit RCU safe
vfs: make follow_link check RCU safe
vfs: do_last(): use inode variable
vfs: do_last(): inline walk_component()
vfs: do_last(): make exit RCU safe
vfs: split do_lookup()
Btrfs: move over to use ->update_time
fs: introduce inode operation ->update_time
reiserfs: get rid of resierfs_sync_super
reiserfs: mark the superblock as dirty a bit later
Does block_sigmask() + tracehook_signal_handler(); called when
sigframe has been successfully built. All architectures converted
to it; block_sigmask() itself is gone now (merged into this one).
I'm still not too happy with the signature, but that's a separate
story (IMO we need a structure that would contain signal number +
siginfo + k_sigaction, so that get_signal_to_deliver() would fill one,
signal_delivered(), handle_signal() and probably setup...frame() -
take one).
Only 3 out of 63 do not. Renamed the current variant to __set_current_blocked(),
added set_current_blocked() that will exclude unblockable signals, switched
open-coded instances to it.
it's actually "send me SIGSEGV"...
replace boilerplate "should we use ->saved_sigmask or ->blocked?"
with calls of obvious inlined helper...
first fruits of ..._restore_sigmask() helpers: now we can take
boilerplate "signal didn't have a handler, clear RESTORE_SIGMASK
and restore the blocked mask from ->saved_mask" into a common
helper. Open-coded instances switched...
helpers parallel to set_restore_sigmask(), used in the next commits
Pull second pile of signal handling patches from Al Viro:
"This one is just task_work_add() series + remaining prereqs for it.
There probably will be another pull request from that tree this
cycle - at least for helpers, to get them out of the way for per-arch
fixes remaining in the tree."
Fix trivial conflict in kernel/irq/manage.c: the merge of Andrew's pile
had brought in commit 97fd75b7b8e0 ("kernel/irq/manage.c: use the
pr_foo() infrastructure to prefix printks") which changed one of the
pr_err() calls that this merge moves around.
keys: kill task_struct->replacement_session_keyring
keys: kill the dummy key_replace_session_keyring()
keys: change keyctl_session_to_parent() to use task_work_add()
genirq: reimplement exit_irq_thread() hook via task_work_add()
task_work_add: generic process-context callbacks
avr32: missed _TIF_NOTIFY_RESUME on one of do_notify_resume callers
parisc: need to check NOTIFY_RESUME when exiting from syscall
move key_repace_session_keyring() into tracehook_notify_resume()
TIF_NOTIFY_RESUME is defined on all targets now
Checking for process->mm is not enough because process' main thread may
exit or detach its mm via use_mm(), but other threads may still have a
valid mm.
To fix this we would need to use find_lock_task_mm(), which would walk up
all threads and returns an appropriate task (with task lock held).
clear_tasks_mm_cpumask() has the issue fixed, so let's use it.
Suggested-by: Oleg Nesterov <oleg@redhat.com>
Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org>
Straightforward change to get rid of all of the header wrapper stubs.
Pull KVM changes from Avi Kivity:
"Changes include additional instruction emulation, page-crossing MMIO,
faster dirty logging, preventing the watchdog from killing a stopped
guest, module autoload, a new MSI ABI, and some minor optimizations
and fixes. Outside x86 we have a small s390 and a very large ppc
update.
Regarding the new (for kvm) rebaseless workflow, some of the patches
that were merged before we switch trees had to be rebased, while
others are true pulls. In either case the signoffs should be correct
now."
Fix up trivial conflicts in Documentation/feature-removal-schedule.txt
arch/powerpc/kvm/book3s_segment.S and arch/x86/include/asm/kvm_para.h.
I suspect the kvm_para.h resolution ends up doing the "do I have cpuid"
check effectively twice (it was done differently in two different
commits), but better safe than sorry ;)
* 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (125 commits)
KVM: make asm-generic/kvm_para.h have an ifdef __KERNEL__ block
KVM: s390: onereg for timer related registers
KVM: s390: epoch difference and TOD programmable field
KVM: s390: KVM_GET/SET_ONEREG for s390
KVM: s390: add capability indicating COW support
KVM: Fix mmu_reload() clash with nested vmx event injection
KVM: MMU: Don't use RCU for lockless shadow walking
KVM: VMX: Optimize %ds, %es reload
KVM: VMX: Fix %ds/%es clobber
KVM: x86 emulator: convert bsf/bsr instructions to emulate_2op_SrcV_nobyte()
KVM: VMX: unlike vmcs on fail path
KVM: PPC: Emulator: clean up SPR reads and writes
KVM: PPC: Emulator: clean up instruction parsing
kvm/powerpc: Add new ioctl to retreive server MMU infos
kvm/book3s: Make kernel emulated H_PUT_TCE available for "PR" KVM
KVM: PPC: bookehv: Fix r8/r13 storing in level exception handler
KVM: PPC: Book3S: Enable IRQs during exit handling
KVM: PPC: Fix PR KVM on POWER7 bare metal
KVM: PPC: Fix stbux emulation
KVM: PPC: bookehv: Use lwz/stw instead of PPC_LL/PPC_STL for 32-bit fields
Pull GPIO driver changes from Grant Likely:
"Lots of gpio changes, both to core code and drivers.
Changes do touch architecture code to remove the need for separate
arm/gpio.h includes in most architectures.
Some new drivers are added, and a number of gpio drivers are converted
to use irq_domains for gpio inputs used as interrupts. Device tree
support has been amended to allow multiple gpio_chips to use the same
device tree node.
Remaining changes are primarily bug fixes."
* tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6: (33 commits)
gpio/generic: initialize basic_mmio_gpio shadow variables properly
gpiolib: Remove 'const' from data argument of gpiochip_find()
gpio/rc5t583: add gpio driver for RICOH PMIC RC5T583
gpiolib: quiet gpiochip_add boot message noise
gpio: mpc8xxx: Prevent NULL pointer deref in demux handler
gpio/lpc32xx: Add device tree support
gpio: Adjust of_xlate API to support multiple GPIO chips
gpiolib: Implement devm_gpio_request_one()
gpio-mcp23s08: dbg_show: fix pullup configuration display
Add support for TCA6424A
gpio/omap: (re)fix wakeups on level-triggered GPIOs
gpio/omap: fix broken context restore for non-OFF mode transitions
gpio/omap: fix missing check in *_runtime_suspend()
gpio/omap: remove cpu_is_omapxxxx() checks from *_runtime_resume()
gpio/omap: remove suspend/resume callbacks
gpio/omap: remove retrigger variable in gpio_irq_handler
gpio/omap: remove saved_wakeup field from struct gpio_bank
gpio/omap: remove suspend_wakeup field from struct gpio_bank
gpio/omap: remove saved_fallingdetect, saved_risingdetect
gpio/omap: remove virtual_irq_start variable
drivers/gpio/gpio-samsung.c
Pull timer updates from Thomas Gleixner.
Various trivial conflict fixups in arch Kconfig due to addition of
unrelated entries nearby. And one slightly more subtle one for sparc32
(new user of GENERIC_CLOCKEVENTS), fixed up as per Thomas.
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (31 commits)
timekeeping: Fix a few minor newline issues.
time: remove obsolete declaration
ntp: Fix a stale comment and a few stray newlines.
ntp: Correct TAI offset during leap second
timers: Fixup the Kconfig consolidation fallout
x86: Use generic time config
unicore32: Use generic time config
um: Use generic time config
tile: Use generic time config
sparc: Use: generic time config
sh: Use generic time config
score: Use generic time config
s390: Use generic time config
openrisc: Use generic time config
powerpc: Use generic time config
mn10300: Use generic time config
mips: Use generic time config
microblaze: Use generic time config
m68k: Use generic time config
m32r: Use generic time config
In the generic init_task migration sh64 silently lost its
fake_swapper_regs definition, resulting in link errors.
Linus tried to fix up sh fallout from the x86 fpu state cleanup merge and
failed. Add the missing include to get it building again.
CC arch/sh/kernel/process.o
arch/sh/kernel/process.c: In function 'arch_dup_task_struct':
arch/sh/kernel/process.c:23:2: error: implicit declaration of function 'unlazy_fpu'
Pull first series of signal handling cleanups from Al Viro:
"This is just the first part of the queue (about a half of it);
assorted fixes all over the place in signal handling.
This one ends with all sigsuspend() implementations switched to
generic one (->saved_sigmask-based).
With this, a bunch of assorted old buglets are fixed and most of the
missing bits of NOTIFY_RESUME hookup are in place. Two more fixes sit
in arm and um trees respectively, and there's a couple of broken ones
that need obvious fixes - parisc and avr32 check TIF_NOTIFY_RESUME
only on one of two codepaths; fixes for that will happen in the next
series"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (55 commits)
unicore32: if there's no handler we need to restore sigmask, syscall or no syscall
xtensa: add handling of TIF_NOTIFY_RESUME
microblaze: drop 'oldset' argument of do_notify_resume()
microblaze: handle TIF_NOTIFY_RESUME
score: add handling of NOTIFY_RESUME to do_notify_resume()
m68k: add TIF_NOTIFY_RESUME and handle it.
sparc: kill ancient comment in sparc_sigaction()
h8300: missing checks of __get_user()/__put_user() return values
frv: missing checks of __get_user()/__put_user() return values
cris: missing checks of __get_user()/__put_user() return values
powerpc: missing checks of __get_user()/__put_user() return values
sh: missing checks of __get_user()/__put_user() return values
sparc: missing checks of __get_user()/__put_user() return values
avr32: struct old_sigaction is never used
m32r: struct old_sigaction is never used
xtensa: xtensa_sigaction doesn't exist
alpha: tidy signal delivery up
score: don't open-code force_sigsegv()
cris: don't open-code force_sigsegv()
blackfin: don't open-code force_sigsegv()
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"This is the first big chunk for 3.5 merges of sound stuff.
There are a few big changes in different areas. First off, the
streaming logic of USB-audio endpoints has been largely rewritten for
the better support of "implicit feedback". If anything about USB got
broken, this change has to be checked.
For HD-audio, the resume procedure was changed; instead of delaying
the resume of the hardware until the first use, now waking up
immediately at resume. This is for buggy BIOS.
For ASoC, dynamic PCM support and the improved support for digital
links between off-SoC devices are major framework changes.
Some highlights are below:
* HD-audio
- Avoid accesses of invalid pin-control bits that may stall the codec
- V-ref setup cleanups
- Fix the races in power-saving code
- Fix the races in codec cache hashes and connection lists
- Split some common codes for BIOS auto-parser to hda_auto_parser.c
- Changed the PM resume code to wake up immediately for buggy BIOS
- Creative SoundCore3D support
- Add Conexant CX20751/2/3/4 codec support
* ASoC
- Dynamic PCM support, allowing support for SoCs with internal
routing through components with tight sequencing and formatting
constraints within their internal paths or where there are multiple
components connected with CPU managed DMA controllers inside the
SoC.
- Greatly improved support for direct digital links between off-SoC
devices, providing a much simpler way of connecting things like
digital basebands to CODECs.
- Much more fine grained and robust locking, cleaning up some of the
confusion that crept in with multi-component.
- CPU support for nVidia Tegra 30 I2S and audio hub controllers and
ST-Ericsson MSP I2S controolers
- New CODEC drivers for Cirrus CS42L52, LAPIS Semiconductor ML26124,
Texas Instruments LM49453.
- Some regmap changes needed by the Tegra I2S driver.
- mc13783 audio support.
* Misc
- Rewrite with module_pci_driver()
- Xonar DGX support for snd-oxygen
- Improvement of packet handling in snd-firewire driver
- New USB-endpoint streaming logic
- Enhanced M-audio FTU quirks and relevant cleanups
- Increment the support of OSS devices to 256
- snd-aloop accuracy improvement
There are a few more pending changes for 3.5, but they will be sent
slightly later as partly depending on the changes of DRM."
Fix up conflicts in regmap (due to duplicate patches, with some further
updates then having already come in from the regmap tree). Also some
fairly trivial context conflicts in the imx and mcx soc drivers.
* tag 'sound-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (280 commits)
ALSA: snd-usb: fix stream info output in /proc
ALSA: pcm - Add proper state checks to snd_pcm_drain()
ALSA: sh: Fix up namespace collision in sh_dac_audio.
ALSA: hda/realtek - Fix unused variable compile warning
ASoC: sh: fsi: enable chip specific data transfer mode
ASoC: sh: fsi: call fsi_hw_startup/shutdown from fsi_dai_trigger()
ASoC: sh: fsi: use same format for IN/OUT
ASoC: sh: fsi: add fsi_version() and removed meaningless version check
ASoC: sh: fsi: use register field macro name on IN/OUT_DMAC
ASoC: tegra: Add machine driver for WM8753 codec
ALSA: hda - Fix possible races of accesses to connection list array
ASoC: OMAP: HDMI: Introduce codec
ARM: mx31_3ds: Add sound support
ASoC: imx-mc13783 cleanup
mx31moboard: Add sound support
ASoC: mc13783 codec cleanups
ASoC: add imx-mc13783 sound support
ASoC: Add mc13783 codec
mfd: mc13xxx: add codec platform data
ASoC: don't flip master of DT-instantiated DAI links
Pull fpu state cleanups from Ingo Molnar:
"This tree streamlines further aspects of FPU handling by eliminating
the prepare_to_copy() complication and moving that logic to
arch_dup_task_struct().
It also fixes the FPU dumps in threaded core dumps, removes and old
(and now invalid) assumption plus micro-optimizes the exit path by
avoiding an FPU save for dead tasks."
Fixed up trivial add-add conflict in arch/sh/kernel/process.c that came
in because we now do the FPU handling in arch_dup_task_struct() rather
than the legacy (and now gone) prepare_to_copy().
* 'x86-fpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, fpu: drop the fpu state during thread exit
x86, xsave: remove thread_has_fpu() bug check in __sanitize_i387_state()
coredump: ensure the fpu state is flushed for proper multi-threaded core dump
fork: move the real prepare_to_copy() users to arch_dup_task_struct()
Pull SuperH updates from Paul Mundt:
- New CPUs: SH7734 (SH-4A), SH7264 and SH7269 (SH-2A)
- New boards: RSK2+SH7264, RSK2+SH7269
- Unbreaking kgdb for SMP
- Consolidation of _32/_64 page fault handling.
- watchdog and legacy DMA chainsawing, part 1
- Conversion to evt2irq() hwirq lookup, to support relocation of
vectored IRQs for irqdomains.
* tag 'sh-for-linus' of git://github.com/pmundt/linux-sh: (98 commits)
sh: intc: Kill off special reservation interface.
sh: Enable PIO API for hp6xx and se770x.
sh: Kill off machvec IRQ hinting.
sh: dma: More legacy cpu dma chainsawing.
sh: Kill off MAX_DMA_ADDRESS leftovers.
sh: Tidy up some of the cpu legacy dma header mess.
sh: Move sh4a dma header from cpu-sh4 to cpu-sh4a.
sh64: Fix up vmalloc fault range check.
Revert "sh: Ensure fixmap and store queue space can co-exist."
serial: sh-sci: Fix for port types without BRI interrupts.
sh: legacy PCI evt2irq migration.
sh: cpu dma evt2irq migration.
sh: sh7763rdp evt2irq migration.
sh: sdk7780 evt2irq migration.
sh: migor evt2irq migration.
sh: landisk evt2irq migration.
sh: kfr2r09 evt2irq migration.
sh: ecovec24 evt2irq migration.
sh: ap325rxa evt2irq migration.
sh: urquell evt2irq migration.
Pull trivial updates from Jiri Kosina:
"As usual, it's mostly typo fixes, redundant code elimination and some
documentation updates."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (57 commits)
edac, mips: don't change code that has been removed in edac/mips tree
xtensa: Change mail addresses of Hannes Weiner and Oskar Schirmer
lib: Change mail address of Oskar Schirmer
net: Change mail address of Oskar Schirmer
arm/m68k: Change mail address of Sebastian Hess
i2c: Change mail address of Oskar Schirmer
net: Fix tcp_build_and_update_options comment in struct tcp_sock
atomic64_32.h: fix parameter naming mismatch
Kconfig: replace "--- help ---" with "---help---"
c2port: fix bogus Kconfig "default no"
edac: Fix spelling errors.
qla1280: Remove redundant NULL check before release_firmware() call
remoteproc: remove redundant NULL check before release_firmware()
qla2xxx: Remove redundant NULL check before release_firmware() call.
aic94xx: Get rid of redundant NULL check before release_firmware() call
tehuti: delete redundant NULL check before release_firmware()
qlogic: get rid of a redundant test for NULL before call to release_firmware()
bna: remove redundant NULL test before release_firmware()
tg3: remove redundant NULL test before release_firmware() call
typhoon: get rid of redundant conditional before all to release_firmware()
Pull scheduler changes from Ingo Molnar:
"The biggest change is the cleanup/simplification of the load-balancer:
instead of the current practice of architectures twiddling scheduler
internal data structures and providing the scheduler domains in
colorfully inconsistent ways, we now have generic scheduler code in
kernel/sched/core.c:sched_init_numa() that looks at the architecture's
node_distance() parameters and (while not fully trusting it) deducts a
NUMA topology from it.
This inevitably changes balancing behavior - hopefully for the better.
There are various smaller optimizations, cleanups and fixlets as well"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched: Taint kernel with TAINT_WARN after sleep-in-atomic bug
sched: Remove stale power aware scheduling remnants and dysfunctional knobs
sched/debug: Fix printing large integers on 32-bit platforms
sched/fair: Improve the ->group_imb logic
sched/nohz: Fix rq->cpu_load[] calculations
sched/numa: Don't scale the imbalance
sched/fair: Revert sched-domain iteration breakage
sched/x86: Rewrite set_cpu_sibling_map()
sched/numa: Fix the new NUMA topology bits
sched/numa: Rewrite the CONFIG_NUMA sched domain support
sched/fair: Propagate 'struct lb_env' usage into find_busiest_group
sched/fair: Add some serialization to the sched_domain load-balance walk
sched/fair: Let minimally loaded cpu balance the group
sched: Change rq->nr_running to unsigned int
x86/numa: Check for nonsensical topologies on real hw as well
x86/numa: Hard partition cpu topology masks on node boundaries
x86/numa: Allow specifying node_distance() for numa=fake
x86/sched: Make mwait_usable() heed to "idle=" kernel parameters properly
sched: Update documentation and comments
sched_rt: Avoid unnecessary dequeue and enqueue of pushable tasks in set_cpus_allowed_rt()
Pull perf changes from Ingo Molnar:
"Lots of changes:
- (much) improved assembly annotation support in perf report, with
jump visualization, searching, navigation, visual output
improvements and more.
- kernel support for AMD IBS PMU hardware features. Notably 'perf
record -e cycles:p' and 'perf top -e cycles:p' should work without
skid now, like PEBS does on the Intel side, because it takes
advantage of IBS transparently.
- the libtracevents library: it is the first step towards unifying
tracing tooling and perf, and it also gives a tracing library for
external tools like powertop to rely on.
- infrastructure: various improvements and refactoring of the UI
modules and related code
- infrastructure: cleanup and simplification of the profiling
targets code (--uid, --pid, --tid, --cpu, --all-cpus, etc.)
- tons of robustness fixes all around
- various ftrace updates: speedups, cleanups, robustness
improvements.
- typing 'make' in tools/ will now give you a menu of projects to
build and a short help text to explain what each does.
- ... and lots of other changes I forgot to list.
The perf record make bzImage + perf report regression you reported
should be fixed."
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (166 commits)
tracing: Remove kernel_lock annotations
tracing: Fix initial buffer_size_kb state
ring-buffer: Merge separate resize loops
perf evsel: Create events initially disabled -- again
perf tools: Split term type into value type and term type
perf hists: Fix callchain ip printf format
perf target: Add uses_mmap field
ftrace: Remove selecting FRAME_POINTER with FUNCTION_TRACER
ftrace/x86: Have x86 ftrace use the ftrace_modify_all_code()
ftrace: Make ftrace_modify_all_code() global for archs to use
ftrace: Return record ip addr for ftrace_location()
ftrace: Consolidate ftrace_location() and ftrace_text_reserved()
ftrace: Speed up search by skipping pages by address
ftrace: Remove extra helper functions
ftrace: Sort all function addresses, not just per page
tracing: change CPU ring buffer state from tracing_cpumask
tracing: Check return value of tracing_dentry_percpu()
ring-buffer: Reset head page before running self test
ring-buffer: Add integrity check at end of iter read
ring-buffer: Make addition of pages in ring buffer atomic
At present reserving the IRLs in the IRQ bitmap in addition to the
dropping of the legacy IRQ pre-allocation prevent IRL IRQs from being
allocated for the x3proto board.
The only reason to permit reservations was to lock down possible hardware
vectors prior to dynamic IRQ scanning, but this doesn't matter much given
that the hardware controller configuration is sorted before we get around
to doing any dynamic IRQ allocation anyways. Beyond that, all of the
tables are __init annotated, so quite a bit more work would need to be
done to support reconfiguring things like IRL controllers on the fly,
much more than would ever make it worth the hassle.
