path: root/arch/sh
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
2010-10-21Merge branch 'core-memblock-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-memblock-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (74 commits) x86-64: Only set max_pfn_mapped to 512 MiB if we enter via head_64.S xen: Cope with unmapped pages when initializing kernel pagetable memblock, bootmem: Round pfn properly for memory and reserved regions memblock: Annotate memblock functions with __init_memblock memblock: Allow memblock_init to be called early memblock/arm: Fix memblock_region_is_memory() typo x86, memblock: Remove __memblock_x86_find_in_range_size() memblock: Fix wraparound in find_region() x86-32, memblock: Make add_highpages honor early reserved ranges x86, memblock: Fix crashkernel allocation arm, memblock: Fix the sparsemem build memblock: Fix section mismatch warnings powerpc, memblock: Fix memblock API change fallout memblock, microblaze: Fix memblock API change fallout x86: Remove old bootmem code x86, memblock: Use memblock_memory_size()/memblock_free_memory_size() to get correct dma_reserve x86: Remove not used early_res code x86, memblock: Replace e820_/_early string with memblock_ x86: Use memblock to replace early_res x86, memblock: Use memblock_debug to control debug message print out ... Fix up trivial conflicts in arch/x86/kernel/setup.c and kernel/Makefile
2010-10-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-irqflagsLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-irqflags: Fix IRQ flag handling naming MIPS: Add missing #inclusions of <linux/irq.h> smc91x: Add missing #inclusion of <linux/irq.h> Drop a couple of unnecessary asm/system.h inclusions SH: Add missing consts to sys_execve() declaration Blackfin: Rename IRQ flags handling functions Blackfin: Add missing dep to asm/irqflags.h Blackfin: Rename DES PC2() symbol to avoid collision Blackfin: Split the BF532 BFIN_*_FIO_FLAG() functions to their own header Blackfin: Split PLL code from mach-specific cdef headers
2010-10-21Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (96 commits) apic, x86: Use BIOS settings for IBS and MCE threshold interrupt LVT offsets apic, x86: Check if EILVT APIC registers are available (AMD only) x86: ioapic: Call free_irte only if interrupt remapping enabled arm: Use ARCH_IRQ_INIT_FLAGS genirq, ARM: Fix boot on ARM platforms genirq: Fix CONFIG_GENIRQ_NO_DEPRECATED=y build x86: Switch sparse_irq allocations to GFP_KERNEL genirq: Switch sparse_irq allocator to GFP_KERNEL genirq: Make sparse_lock a mutex x86: lguest: Use new irq allocator genirq: Remove the now unused sparse irq leftovers genirq: Sanitize dynamic irq handling genirq: Remove arch_init_chip_data() x86: xen: Sanitise sparse_irq handling x86: Use sane enumeration x86: uv: Clean up the direct access to irq_desc x86: Make io_apic.c local functions static genirq: Remove irq_2_iommu x86: Speed up the irq_remapped check in hot pathes intr_remap: Simplify the code further ... Fix up trivial conflicts in arch/x86/Kconfig
2010-10-20Merge branch 'linus' into irq/coreIngo Molnar
Merge reason: update to almost-final-.36 Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-18irq_work: Add generic hardirq context callbacksPeter Zijlstra
Provide a mechanism that allows running code in IRQ context. It is most useful for NMI code that needs to interact with the rest of the system -- like wakeup a task to drain buffers. Perf currently has such a mechanism, so extract that and provide it as a generic feature, independent of perf so that others may also benefit. The IRQ context callback is generated through self-IPIs where possible, or on architectures like powerpc the decrementer (the built-in timer facility) is set to generate an interrupt immediately. Architectures that don't have anything like this get to do with a callback from the timer tick. These architectures can call irq_work_run() at the tail of any IRQ handlers that might enqueue such work (like the perf IRQ handler) to avoid undue latencies in processing the work. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [ various fixes ] Signed-off-by: Huang Ying <ying.huang@intel.com> LKML-Reference: <1287036094.7768.291.camel@yhuang-dev> Signed-off-by: Ingo Molnar <mingo@elte.hu>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-10-15Merge remote branch 'tip/perf/core' into oprofile/coreRobert Richter
Conflicts: arch/arm/oprofile/common.c kernel/perf_event.c
2010-10-12memblock, bootmem: Round pfn properly for memory and reserved regionsYinghai Lu
We need to round memory regions correctly -- specifically, we need to round reserved region in the more expansive direction (lower limit down, upper limit up) whereas usable memory regions need to be rounded in the more restrictive direction (lower limit up, upper limit down). This introduces two set of inlines: memblock_region_memory_base_pfn() memblock_region_memory_end_pfn() memblock_region_reserved_base_pfn() memblock_region_reserved_end_pfn() Although they are antisymmetric (and therefore are technically duplicates) the use of the different inlines explicitly documents the programmer's intention. The lack of proper rounding caused a bug on ARM, which was then found to also affect other architectures. Reported-by: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <4CB4CDFD.4020105@kernel.org> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-10-12genirq: Query arch for number of early descriptorsThomas Gleixner
sparse irq sets up NR_IRQS_LEGACY irq descriptors and archs then go ahead and allocate more. Use the unused return value of arch_probe_nr_irqs() to let the architecture return the number of early allocations. Fix up all users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-11sh: oprofile: Use perf-events oprofile backendMatt Fleming
Now that we've got a generic perf-events based oprofile backend we might as well make use of it seeing as SH doesn't do anything special with its oprofile backend. Also introduce a new CONFIG_HW_PERF_EVENTS symbol so that we can fallback to using the timer interrupt for oprofile if the CPU doesn't support perf events. Also, to avoid a section mismatch warning we need to annotate oprofile_arch_exit() with an __exit marker. Signed-off-by: Matt Fleming <matt@console-pimps.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Robert Richter <robert.richter@amd.com>
2010-10-11perf: New helper function for pmu nameMatt Fleming
Introduce perf_pmu_name() helper function that returns the name of the pmu. This gives us a generic way to get the name of a pmu regardless of how an architecture identifies it internally. Signed-off-by: Matt Fleming <matt@console-pimps.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Robert Richter <robert.richter@amd.com>
2010-10-11perf: Add helper function to return number of countersMatt Fleming
The number of counters for the registered pmu is needed in a few places so provide a helper function that returns this number. Signed-off-by: Matt Fleming <matt@console-pimps.org> Tested-by: Will Deacon <will.deacon@arm.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Robert Richter <robert.richter@amd.com>
2010-10-08Merge commit 'v2.6.36-rc7' into perf/coreIngo Molnar
Conflicts: arch/x86/kernel/module.c Merge reason: Resolve the conflict, pick up fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-08Merge commit 'v2.6.36-rc7' into core/memblockIngo Molnar
Merge reason: Update from -rc3 to -rc7. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-07Fix IRQ flag handling namingDavid Howells
Fix the IRQ flag handling naming. In linux/irqflags.h under one configuration, it maps: local_irq_enable() -> raw_local_irq_enable() local_irq_disable() -> raw_local_irq_disable() local_irq_save() -> raw_local_irq_save() ... and under the other configuration, it maps: raw_local_irq_enable() -> local_irq_enable() raw_local_irq_disable() -> local_irq_disable() raw_local_irq_save() -> local_irq_save() ... This is quite confusing. There should be one set of names expected of the arch, and this should be wrapped to give another set of names that are expected by users of this facility. Change this to have the arch provide: flags = arch_local_save_flags() flags = arch_local_irq_save() arch_local_irq_restore(flags) arch_local_irq_disable() arch_local_irq_enable() arch_irqs_disabled_flags(flags) arch_irqs_disabled() arch_safe_halt() Then linux/irqflags.h wraps these to provide: raw_local_save_flags(flags) raw_local_irq_save(flags) raw_local_irq_restore(flags) raw_local_irq_disable() raw_local_irq_enable() raw_irqs_disabled_flags(flags) raw_irqs_disabled() raw_safe_halt() with type checking on the flags 'arguments', and then wraps those to provide: local_save_flags(flags) local_irq_save(flags) local_irq_restore(flags) local_irq_disable() local_irq_enable() irqs_disabled_flags(flags) irqs_disabled() safe_halt() with tracing included if enabled. The arch functions can now all be inline functions rather than some of them having to be macros. Signed-off-by: David Howells <dhowells@redhat.com> [X86, FRV, MN10300] Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> [Tile] Signed-off-by: Michal Simek <monstr@monstr.eu> [Microblaze] Tested-by: Catalin Marinas <catalin.marinas@arm.com> [ARM] Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> [AVR] Acked-by: Tony Luck <tony.luck@intel.com> [IA-64] Acked-by: Hirokazu Takata <takata@linux-m32r.org> [M32R] Acked-by: Greg Ungerer <gerg@uclinux.org> [M68K/M68KNOMMU] Acked-by: Ralf Baechle <ralf@linux-mips.org> [MIPS] Acked-by: Kyle McMartin <kyle@mcmartin.ca> [PA-RISC] Acked-by: Paul Mackerras <paulus@samba.org> [PowerPC] Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [S390] Acked-by: Chen Liqin <liqin.chen@sunplusct.com> [Score] Acked-by: Matt Fleming <matt@console-pimps.org> [SH] Acked-by: David S. Miller <davem@davemloft.net> [Sparc] Acked-by: Chris Zankel <chris@zankel.net> [Xtensa] Reviewed-by: Richard Henderson <rth@twiddle.net> [Alpha] Reviewed-by: Yoshinori Sato <ysato@users.sourceforge.jp> [H8300] Cc: starvik@axis.com [CRIS] Cc: jesper.nilsson@axis.com [CRIS] Cc: linux-cris-kernel@axis.com
2010-10-07SH: Add missing consts to sys_execve() declarationDavid Howells
Add missing consts to the sys_execve() declaration which result in the following error: arch/sh/kernel/process_32.c:303: error: conflicting types for 'sys_execve' /warthog/nfs/linux-2.6-fscache/arch/sh/include/asm/syscalls_32.h:24: error: previous declaration of 'sys_execve' was here Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-05modules: Fix module_bug_list list corruption raceLinus Torvalds
With all the recent module loading cleanups, we've minimized the code that sits under module_mutex, fixing various deadlocks and making it possible to do most of the module loading in parallel. However, that whole conversion totally missed the rather obscure code that adds a new module to the list for BUG() handling. That code was doubly obscure because (a) the code itself lives in lib/bugs.c (for dubious reasons) and (b) it gets called from the architecture-specific "module_finalize()" rather than from generic code. Calling it from arch-specific code makes no sense what-so-ever to begin with, and is now actively wrong since that code isn't protected by the module loading lock any more. So this commit moves the "module_bug_{finalize,cleanup}()" calls away from the arch-specific code, and into the generic code - and in the process protects it with the module_mutex so that the list operations are now safe. Future fixups: - move the module list handling code into kernel/module.c where it belongs. - get rid of 'module_bug_list' and just use the regular list of modules (called 'modules' - imagine that) that we already create and maintain for other reasons. Reported-and-tested-by: Thomas Gleixner <tglx@linutronix.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Adrian Bunk <bunk@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-15perf, sh: Fix patch merge foul-upMatt Fleming
3f6da390 ("perf: Rework and fix the arch CPU-hotplug hooks") introduced this breakage. sh_pmu_setup() is missing an opening curly brace. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20100913191729.GA6440@console-pimps.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-09-09perf: Rework the PMU methodsPeter Zijlstra
Replace pmu::{enable,disable,start,stop,unthrottle} with pmu::{add,del,start,stop}, all of which take a flags argument. The new interface extends the capability to stop a counter while keeping it scheduled on the PMU. We replace the throttled state with the generic stopped state. This also allows us to efficiently stop/start counters over certain code paths (like IRQ handlers). It also allows scheduling a counter without it starting, allowing for a generic frozen state (useful for rotating stopped counters). The stopped state is implemented in two different ways, depending on how the architecture implemented the throttled state: 1) We disable the counter: a) the pmu has per-counter enable bits, we flip that b) we program a NOP event, preserving the counter state 2) We store the counter state and ignore all read/overflow events Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: paulus <paulus@samba.org> Cc: stephane eranian <eranian@googlemail.com> Cc: Robert Richter <robert.richter@amd.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Lin Ming <ming.m.lin@intel.com> Cc: Yanmin <yanmin_zhang@linux.intel.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> Cc: David Miller <davem@davemloft.net> Cc: Michael Cree <mcree@orcon.net.nz> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-09-09perf: Per PMU disablePeter Zijlstra
Changes perf_disable() into perf_pmu_disable(). Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: paulus <paulus@samba.org> Cc: stephane eranian <eranian@googlemail.com> Cc: Robert Richter <robert.richter@amd.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Lin Ming <ming.m.lin@intel.com> Cc: Yanmin <yanmin_zhang@linux.intel.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> Cc: David Miller <davem@davemloft.net> Cc: Michael Cree <mcree@orcon.net.nz> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-09-09perf: Reduce perf_disable() usagePeter Zijlstra
Since the current perf_disable() usage is only an optimization, remove it for now. This eases the removal of the __weak hw_perf_enable() interface. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: paulus <paulus@samba.org> Cc: stephane eranian <eranian@googlemail.com> Cc: Robert Richter <robert.richter@amd.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Lin Ming <ming.m.lin@intel.com> Cc: Yanmin <yanmin_zhang@linux.intel.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> Cc: David Miller <davem@davemloft.net> Cc: Michael Cree <mcree@orcon.net.nz> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-09-09perf: Register PMU implementationsPeter Zijlstra
Simple registration interface for struct pmu, this provides the infrastructure for removing all the weak functions. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: paulus <paulus@samba.org> Cc: stephane eranian <eranian@googlemail.com> Cc: Robert Richter <robert.richter@amd.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Lin Ming <ming.m.lin@intel.com> Cc: Yanmin <yanmin_zhang@linux.intel.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> Cc: David Miller <davem@davemloft.net> Cc: Michael Cree <mcree@orcon.net.nz> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-09-09perf: Deconstify struct pmuPeter Zijlstra
sed -ie 's/const struct pmu\>/struct pmu/g' `git grep -l "const struct pmu\>"` Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: paulus <paulus@samba.org> Cc: stephane eranian <eranian@googlemail.com> Cc: Robert Richter <robert.richter@amd.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Lin Ming <ming.m.lin@intel.com> Cc: Yanmin <yanmin_zhang@linux.intel.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> Cc: David Miller <davem@davemloft.net> Cc: Michael Cree <mcree@orcon.net.nz> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-08-31Merge commit 'v2.6.36-rc3' into x86/memblockIngo Molnar
Conflicts: arch/x86/kernel/trampoline.c mm/memblock.c Merge reason: Resolve the conflicts, update to latest upstream. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-08-25Merge branch 'linus' into perf/coreIngo Molnar
Merge reason: pick up perf fixes Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-08-19Merge branch 'tip/perf/urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/core
2010-08-19perf: Factorize callchain context handlingFrederic Weisbecker
Store the kernel and user contexts from the generic layer instead of archs, this gathers some repetitive code. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Paul Mackerras <paulus@samba.org> Tested-by: Will Deacon <will.deacon@arm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Stephane Eranian <eranian@google.com> Cc: David Miller <davem@davemloft.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Borislav Petkov <bp@amd64.org>
2010-08-19perf: Generalize some arch callchain codeFrederic Weisbecker
- Most archs use one callchain buffer per cpu, except x86 that needs to deal with NMIs. Provide a default perf_callchain_buffer() implementation that x86 overrides. - Centralize all the kernel/user regs handling and invoke new arch handlers from there: perf_callchain_user() / perf_callchain_kernel() That avoid all the user_mode(), current->mm checks and so... - Invert some parameters in perf_callchain_*() helpers: entry to the left, regs to the right, following the traditional (dst, src). Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Paul Mackerras <paulus@samba.org> Tested-by: Will Deacon <will.deacon@arm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Stephane Eranian <eranian@google.com> Cc: David Miller <davem@davemloft.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Borislav Petkov <bp@amd64.org>
2010-08-19perf: Generalize callchain_store()Frederic Weisbecker
callchain_store() is the same on every archs, inline it in perf_event.h and rename it to perf_callchain_store() to avoid any collision. This removes repetitive code. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Paul Mackerras <paulus@samba.org> Tested-by: Will Deacon <will.deacon@arm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Stephane Eranian <eranian@google.com> Cc: David Miller <davem@davemloft.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Borislav Petkov <bp@amd64.org>
2010-08-19perf: Drop unappropriate tests on arch callchainsFrederic Weisbecker
Drop the TASK_RUNNING test on user tasks for callchains as this check doesn't seem to make any sense. Also remove the tests for !current that is not supposed to happen and current->pid as this should be handled at the generic level, with exclude_idle attribute. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Tested-by: Will Deacon <will.deacon@arm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Stephane Eranian <eranian@google.com> Cc: David Miller <davem@davemloft.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Borislav Petkov <bp@amd64.org>
2010-08-17Make do_execve() take a const filename pointerDavid Howells
Make do_execve() take a const filename pointer so that kernel_execve() compiles correctly on ARM: arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type This also requires the argv and envp arguments to be consted twice, once for the pointer array and once for the strings the array points to. This is because do_execve() passes a pointer to the filename (now const) to copy_strings_kernel(). A simpler alternative would be to cast the filename pointer in do_execve() when it's passed to copy_strings_kernel(). do_execve() may not change any of the strings it is passed as part of the argv or envp lists as they are some of them in .rodata, so marking these strings as const should be fine. Further kernel_execve() and sys_execve() need to be changed to match. This has been test built on x86_64, frv, arm and mips. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-14defconfig reductionSam Ravnborg
Use the defconfig files generated by "make savedefconfig" for remaining defconfig files. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2010-08-14archs: replace unifdef-y with header-ySam Ravnborg
unifdef-y and header-y have same semantic, so drop unifdef-y Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2010-08-13Mark arguments to certain syscalls as being constDavid Howells
Mark arguments to certain system calls as being const where they should be but aren't. The list includes: (*) The filename arguments of various stat syscalls, execve(), various utimes syscalls and some mount syscalls. (*) The filename arguments of some syscall helpers relating to the above. (*) The buffer argument of various write syscalls. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (226 commits) ARM: 6323/1: cam60: don't use __init for cam60_spi_{flash_platform_data,partitions} ARM: 6324/1: cam60: move cam60_spi_devices to .init.data ARM: 6322/1: imx/pca100: Fix name of spi platform data ARM: 6321/1: fix syntax error in main Kconfig file ARM: 6297/1: move U300 timer to dynamic clock lookup ARM: 6296/1: clock U300 intcon and timer properly ARM: 6295/1: fix U300 apb_pclk split ARM: 6306/1: fix inverted MMC card detect in U300 ARM: 6299/1: errata: TLBIASIDIS and TLBIMVAIS operations can broadcast a faulty ASID ARM: 6294/1: etm: do a dummy read from OSSRR during initialization ARM: 6292/1: coresight: add ETM management registers ARM: 6288/1: ftrace: document mcount formats ARM: 6287/1: ftrace: clean up mcount assembly indentation ARM: 6286/1: fix Thumb-2 decompressor broken by "Auto calculate ZRELADDR" ARM: 6281/1: video/imxfb.c: allow usage without BACKLIGHT_CLASS_DEVICE ARM: 6280/1: imx: Fix build failure when including <mach/gpio.h> without <linux/spinlock.h> ARM: S5PV210: Fix on missing s3c-sdhci card detection method for hsmmc3 ARM: S5P: Fix on missing S5P_DEV_FIMC in plat-s5p/Kconfig ARM: S5PV210: Override FIMC driver name on Aquila board ARM: S5PC100: enable FIMC on SMDKC100 ... Fix up conflicts in arch/arm/mach-{s5pc100,s5pv210}/cpu.c due to different subsystem 'setname' calls, and trivial port types in include/linux/serial_core.h
2010-08-11dma-mapping: remove dma_is_consistent APIFUJITA Tomonori
Architectures implement dma_is_consistent() in different ways (some misinterpret the definition of API in DMA-API.txt). So it hasn't been so useful for drivers. We have only one user of the API in tree. Unlikely out-of-tree drivers use the API. Even if we fix dma_is_consistent() in some architectures, it doesn't look useful at all. It was invented long ago for some old systems that can't allocate coherent memory at all. It's better to export only APIs that are definitely necessary for drivers. Let's remove this API. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11dma-mapping: unify dma_get_cache_alignment implementationsFUJITA Tomonori
dma_get_cache_alignment returns the minimum DMA alignment. Architectures defines it as ARCH_DMA_MINALIGN (formally ARCH_KMALLOC_MINALIGN). So we can unify dma_get_cache_alignment implementations. Note that some architectures implement dma_get_cache_alignment wrongly. dma_get_cache_alignment() should return the minimum DMA alignment. So fully-coherent architectures should return 1. This patch also fixes this issue. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11dma-mapping: rename ARCH_KMALLOC_MINALIGN to ARCH_DMA_MINALIGNFUJITA Tomonori
Now each architecture has the own dma_get_cache_alignment implementation. dma_get_cache_alignment returns the minimum DMA alignment. Architectures define it as ARCH_KMALLOC_MINALIGN (it's used to make sure that malloc'ed buffer is DMA-safe; the buffer doesn't share a cache with the others). So we can unify dma_get_cache_alignment implementations. This patch: dma_get_cache_alignment() needs to know if an architecture defines ARCH_KMALLOC_MINALIGN or not (needs to know if architecture has DMA alignment restriction). However, slab.h define ARCH_KMALLOC_MINALIGN if architectures doesn't define it. Let's rename ARCH_KMALLOC_MINALIGN to ARCH_DMA_MINALIGN. ARCH_KMALLOC_MINALIGN is used only in the internals of slab/slob/slub (except for crypto). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10Merge branch 'for-2.6.36' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.36' of git://git.kernel.dk/linux-2.6-block: (149 commits) block: make sure that REQ_* types are seen even with CONFIG_BLOCK=n xen-blkfront: fix missing out label blkdev: fix blkdev_issue_zeroout return value block: update request stacking methods to support discards block: fix missing export of blk_types.h writeback: fix bad _bh spinlock nesting drbd: revert "delay probes", feature is being re-implemented differently drbd: Initialize all members of sync_conf to their defaults [Bugz 315] drbd: Disable delay probes for the upcomming release writeback: cleanup bdi_register writeback: add new tracepoints writeback: remove unnecessary init_timer call writeback: optimize periodic bdi thread wakeups writeback: prevent unnecessary bdi threads wakeups writeback: move bdi threads exiting logic to the forker thread writeback: restructure bdi forker loop a little writeback: move last_active to bdi writeback: do not remove bdi from bdi_list writeback: simplify bdi code a little writeback: do not lose wake-ups in bdi threads ... Fixed up pretty trivial conflicts in drivers/block/virtio_blk.c and drivers/scsi/scsi_error.c as per Jens.
2010-08-10Merge branches 'master' and 'devel' into for-linusRussell King
Conflicts: arch/arm/Kconfig arch/arm/mm/Kconfig
2010-08-10tty: Add EXTPROC support for LINEMODEhyc@symas.com
This patch is against the 2.6.34 source. Paraphrased from the 1989 BSD patch by David Borman @ cray.com: These are the changes needed for the kernel to support LINEMODE in the server. There is a new bit in the termios local flag word, EXTPROC. When this bit is set, several aspects of the terminal driver are disabled. Input line editing, character echo, and mapping of signals are all disabled. This allows the telnetd to turn off these functions when in linemode, but still keep track of what state the user wants the terminal to be in. New ioctl: TIOCSIG Generate a signal to processes in the current process group of the pty. There is a new mode for packet driver, the TIOCPKT_IOCTL bit. When packet mode is turned on in the pty, and the EXTPROC bit is set, then whenever the state of the pty is changed, the next read on the master side of the pty will have the TIOCPKT_IOCTL bit set. This allows the process on the server side of the pty to know when the state of the terminal has changed; it can then issue the appropriate ioctl to retrieve the new state. Since the original BSD patches accompanied the source code for telnet I've left that reference here, but obviously the feature is useful for any remote terminal protocol, including ssh. The corresponding feature has existed in the BSD tty driver since 1989. For historical reference, a good copy of the relevant files can be found here: http://anonsvn.mit.edu/viewvc/krb5/trunk/src/appl/telnet/?pathrev=17741 Signed-off-by: Howard Chu <hyc@symas.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-07remove needless ISA_DMA_THRESHOLDFUJITA Tomonori
Architectures don't need to define ISA_DMA_THRESHOLD anymore. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: James Bottomley <James.Bottomley@suse.de> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-06Merge branch 'timers-timekeeping-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-timekeeping-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: um: Fix read_persistent_clock fallout kgdb: Do not access xtime directly powerpc: Clean up obsolete code relating to decrementer and timebase powerpc: Rework VDSO gettimeofday to prevent time going backwards clocksource: Add __clocksource_updatefreq_hz/khz methods x86: Convert common clocksources to use clocksource_register_hz/khz timekeeping: Make xtime and wall_to_monotonic static hrtimer: Cleanup direct access to wall_to_monotonic um: Convert to use read_persistent_clock timkeeping: Fix update_vsyscall to provide wall_to_monotonic offset powerpc: Cleanup xtime usage powerpc: Simplify update_vsyscall time: Kill off CONFIG_GENERIC_TIME time: Implement timespec_add x86: Fix vtime/file timestamp inconsistencies Trivial conflicts in Documentation/feature-removal-schedule.txt Much less trivial conflicts in arch/powerpc/kernel/time.c resolved as per Thomas' earlier merge commit 47916be4e28c ("Merge branch 'powerpc.cherry-picks' into timers/clocksource")
2010-08-06Merge master.kernel.org:/pub/scm/linux/kernel/git/lethal/genesis-2.6 into ↵Russell King
devel-stable Conflicts: drivers/net/irda/sh_irda.c
2010-08-06Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (162 commits) tracing/kprobes: unregister_trace_probe needs to be called under mutex perf: expose event__process function perf events: Fix mmap offset determination perf, powerpc: fsl_emb: Restore setting perf_sample_data.period perf, powerpc: Convert the FSL driver to use local64_t perf tools: Don't keep unreferenced maps when unmaps are detected perf session: Invalidate last_match when removing threads from rb_tree perf session: Free the ref_reloc_sym memory at the right place x86,mmiotrace: Add support for tracing STOS instruction perf, sched migration: Librarize task states and event headers helpers perf, sched migration: Librarize the GUI class perf, sched migration: Make the GUI class client agnostic perf, sched migration: Make it vertically scrollable perf, sched migration: Parameterize cpu height and spacing perf, sched migration: Fix key bindings perf, sched migration: Ignore unhandled task states perf, sched migration: Handle ignored migrate out events perf: New migration tool overview tracing: Drop cpparg() macro perf: Use tracepoint_synchronize_unregister() to flush any pending tracepoint call ... Fix up trivial conflicts in Makefile and drivers/cpufreq/cpufreq.c
2010-08-05memblock: Introduce default allocation limit and use it to replace explicit onesBenjamin Herrenschmidt
This introduce memblock.current_limit which is used to limit allocations from memblock_alloc() or memblock_alloc_base(..., MEMBLOCK_ALLOC_ACCESSIBLE). The old MEMBLOCK_ALLOC_ANYWHERE changes value from 0 to ~(u64)0 and can still be used with memblock_alloc_base() to allocate really anywhere. It is -no-longer- cropped to MEMBLOCK_REAL_LIMIT which disappears. Note to archs: I'm leaving the default limit to MEMBLOCK_ALLOC_ANYWHERE. I strongly recommend that you ensure that you set an appropriate limit during boot in order to guarantee that an memblock_alloc() at any time results in something that is accessible with a simple __va(). The reason is that a subsequent patch will introduce the ability for the array to resize itself by reallocating itself. The MEMBLOCK core will honor the current limit when performing those allocations. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits) Documentation: update broken web addresses. fix comment typo "choosed" -> "chosen" hostap:hostap_hw.c Fix typo in comment Fix spelling contorller -> controller in comments Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault fs/Kconfig: Fix typo Userpace -> Userspace Removing dead MACH_U300_BS26 drivers/infiniband: Remove unnecessary casts of private_data fs/ocfs2: Remove unnecessary casts of private_data libfc: use ARRAY_SIZE scsi: bfa: use ARRAY_SIZE drm: i915: use ARRAY_SIZE drm: drm_edid: use ARRAY_SIZE synclink: use ARRAY_SIZE block: cciss: use ARRAY_SIZE comment typo fixes: charater => character fix comment typos concerning "challenge" arm: plat-spear: fix typo in kerneldoc reiserfs: typo comment fix update email address ...
2010-08-04Merge branch 'master' into for-nextJiri Kosina
2010-08-04sh: add a parameter to LCDC driver's .display_on() callbackGuennadi Liakhovetski
HDMI support for the sh_mobile_lcdc framebuffer driver will require a 'struct fb_info *' pointer for its .display_on() callback. While at it fix kfr2r09 framebuffer modular build. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
