* 'for-upstream' of git://openrisc.net/jonas/linux: (24 commits)
OpenRISC: Add MAINTAINERS entry
OpenRISC: Miscellaneous
OpenRISC: Library routines
OpenRISC: Headers
OpenRISC: Traps
OpenRISC: Module support
OpenRISC: GPIO
OpenRISC: Scheduling/Process management
OpenRISC: Idle/Power management
OpenRISC: System calls
OpenRISC: IRQ
OpenRISC: Timekeeping
OpenRISC: DMA
OpenRISC: PTrace
OpenRISC: Build infrastructure
OpenRISC: Signal handling
OpenRISC: Memory management
OpenRISC: Device tree
OpenRISC: Boot code
iomap: make IOPORT/PCI mapping functions conditional
This patch removes all the module loader hook implementations in the
architecture specific code where the functionality is the same as that
now provided by the recently added default hooks.
Signed-off-by: Jonas Bonn <jonas@southpole.se>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Tested-by: Michal Simek <monstr@monstr.eu>
virtio has been so far used only in the context of virtualization,
and the virtio Kconfig was sourced directly by the relevant arch
Kconfigs when VIRTUALIZATION was selected.
Now that we start using virtio for inter-processor communications,
we need to source the virtio Kconfig outside of the virtualization
scope too.
Moreover, some architectures might use virtio for both virtualization
and inter-processor communications, so directly sourcing virtio
might yield unexpected results due to conflicting selections.
The simple solution offered by this patch is to always source virtio's
Kconfig in drivers/Kconfig, and remove it from the appropriate arch
Kconfigs. Additionally, a virtio menu entry has been added so virtio
drivers don't show up in the general drivers menu.
This way anyone can use virtio, though it's arguably less accessible
(and neat!) for virtualization users now.
Note: some architectures (mips and sh) seem to have a VIRTUALIZATION
menu merely for sourcing virtio's Kconfig, so that menu is removed too.
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (123 commits)
perf: Remove the nmi parameter from the oprofile_perf backend
x86, perf: Make copy_from_user_nmi() a library function
perf: Remove perf_event_attr::type check
x86, perf: P4 PMU - Fix typos in comments and style cleanup
perf tools: Make test use the preset debugfs path
perf tools: Add automated tests for events parsing
perf tools: De-opt the parse_events function
perf script: Fix display of IP address for non-callchain path
perf tools: Fix endian conversion reading event attr from file header
perf tools: Add missing 'node' alias to the hw_cache[] array
perf probe: Support adding probes on offline kernel modules
perf probe: Add probed module in front of function
perf probe: Introduce debuginfo to encapsulate dwarf information
perf-probe: Move dwarf library routines to dwarf-aux.{c, h}
perf probe: Remove redundant dwarf functions
perf probe: Move strtailcmp to string.c
perf probe: Rename DIE_FIND_CB_FOUND to DIE_FIND_CB_END
tracing/kprobe: Update symbol reference when loading module
tracing/kprobes: Support module init function probing
kprobes: Return -ENOENT if probe point doesn't exist
This patch moves the in-tree architectures that were using the 'generic'
delay.h over to using the header file in asm-generic.
This is not done using the generic-y mechanism as none of these arch's
have started using that mechanism yet. This is a trivial change to make
later when the arch begins using generic-y.
Note the subtle change to the avr32 and SH architectures where the argument
to __const_udelay was previously using the rounded down constant value
instead of the rounded up value.
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
The naming convention used by commit 7538e3db6e015e890825fbd9f86599b
(PM: Add support for device power domains), which introduced the
struct dev_power_domain type for representing device power domains,
evidently confuses some developers who tend to think that objects
of this type must correspond to "power domains" as defined by
hardware, which is not the case. Namely, at the kernel level, a
struct dev_power_domain object can represent arbitrary set of devices
that are mutually dependent power management-wise and need not belong
to one hardware power domain. To avoid that confusion, rename struct
dev_power_domain to struct dev_pm_domain and rename the related
pointers in struct device and struct pm_clk_notifier_block from
pwr_domain to pm_domain.
Acked-by: Kevin Hilman <khilman@ti.com>
The perf_event overflow handler does not receive any caller-derived
argument, so many callers need to resort to looking up the perf_event
in their local data structure. This is ugly and doesn't scale if a
single callback services many perf_events.
Fix by adding a context parameter to perf_event_create_kernel_counter()
(and derived hardware breakpoints APIs) and storing it in the perf_event.
The field can be accessed from the callback as event->overflow_handler_context.
All callers are updated.
Signed-off-by: Avi Kivity <avi@redhat.com>
Link: http://lkml.kernel.org/r/1309362157-6596-2-git-send-email-avi@redhat.com
Add a NODE level to the generic cache events which is used to measure
local vs remote memory accesses. Like all other cache events, an
ACCESS is HIT+MISS, if there is no way to distinguish between reads
and writes do reads only etc..
The below needs filling out for !x86 (which I filled out with
unsupported events).
I'm fairly sure ARM can leave it like that since it doesn't strike me as
an architecture that even has NUMA support. SH might have something since
it does appear to have some NUMA bits.
Sparc64, PowerPC and MIPS certainly want a good look there since they
clearly are NUMA capable.
Cc: David Daney <ddaney@caviumnetworks.com>
Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com>
Cc: Robert Richter <robert.richter@amd.com>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/1303508226.4865.8.camel@laptop
The nmi parameter indicated if we could do wakeups from the current
context, if not, we would set some state and self-IPI and let the
resulting interrupt do the wakeup.
For the various event classes:
- hardware: nmi=0; PMI is in fact an NMI or we run irq_work_run from
the PMI-tail (ARM etc.)
- tracepoint: nmi=0; since tracepoint could be from NMI context.
- software: nmi=[0,1]; some, like the schedule thing cannot
perform wakeups, and hence need 0.
As one can see, there is very little nmi=1 usage, and the down-side of
not using it is that on some platforms some software events can have a
jiffy delay in wakeup (when arch_irq_work_raise isn't implemented).
The up-side however is that we can remove the nmi parameter and save a
bunch of conditionals in fast paths.
Cc: Michael Cree <mcree@orcon.net.nz>
Cc: Eric B Munson <emunson@mgebm.net>
Cc: Jason Wessel <jason.wessel@windriver.com>
Cc: Don Zickus <dzickus@redhat.com>
Link: http://lkml.kernel.org/n/tip-agjev8eu666tvknpb3iaj0fg@git.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x
* 'sh-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x:
sh: use printk_ratelimited instead of printk_ratelimit
sh: Fix up unmet dependency warnings with USB EHCI/OHCI selects.
sh: fix the value of sh_dmae_slave_config in setup-sh7757
sh: fix the INTC vector for IRQ and IRL in setup-sh7757
sh: add to select the new configuration for USB EHCI/OHCI
sh: add platform_device of EHCI/OHCI to setup-sh7757
sh: fix compile error using sh7757lcr_defconfig
Follows the powerpc change, for much the same rationale.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Fix the value of chcr for SCIF[2-4]_RX and RIIC[0-9]_RX and
the value of mid_rid for some RIIC.
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
commit 21a3c96 uses node_start/end_pfn(nid) for detection start/end
of nodes. But, it's not defined in linux/mmzone.h but defined in
/arch/???/include/mmzone.h which is included only under
CONFIG_NEED_MULTIPLE_NODES=y.
Then, we see
mm/page_cgroup.c: In function 'page_cgroup_init':
mm/page_cgroup.c:308: error: implicit declaration of function 'node_start_pfn'
mm/page_cgroup.c:309: error: implicit declaration of function 'node_end_pfn'
So, fixiing page_cgroup.c is an idea...
But node_start_pfn()/node_end_pfn() is a very generic macro and
should be implemented in the same manner for all archs.
(m32r has different implementation...)
This patch removes definitions of node_start/end_pfn() in each archs
and defines a unified one in linux/mmzone.h. It's not under
CONFIG_NEED_MULTIPLE_NODES, now.
A result of macro expansion is here (mm/page_cgroup.c)
for !NUMA
start_pfn = ((&contig_page_data)->node_start_pfn);
end_pfn = ({ pg_data_t *__pgdat = (&contig_page_data); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;});
for NUMA (x86-64)
start_pfn = ((node_data[nid])->node_start_pfn);
end_pfn = ({ pg_data_t *__pgdat = (node_data[nid]); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;});
Changelog:
- fixed to avoid using "nid" twice in node_end_pfn() macro.
Reported-and-acked-by: Randy Dunlap <randy.dunlap@oracle.com>
Reported-and-tested-by: Ingo Molnar <mingo@elte.hu>
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Because the USB EHCI/OHCI driver has new configuration for SH,
the patch enables the EHCI and/or OHCI driver of the on-chip for
some CPUs.
Fix the complie error in ehci-hcd.c because it needs an additional
configuration.
CC drivers/usb/host/ehci-hcd.o
drivers/usb/host/ehci-hcd.c:1288:2: error: #error "missing bus glue for ehci-hcd"
make[3]: *** [drivers/usb/host/ehci-hcd.o] Error 1
make[2]: *** [drivers/usb/host] Error 2
make[1]: *** [drivers/usb] Error 2
make: *** [drivers] Error 2
sh: sh7724: Add USBHS DMAEngine support
sh: ecovec: Add renesas_usbhs support
sh, exec: remove redundant set_fs(USER_DS)
drivers: sh: resume enabled clocks fix
dmaengine: shdma: SH_DMAC_MAX_CHANNELS message fix
sh: Fix up xchg/cmpxchg corruption with gUSA RB.
sh: Remove compressed kernel libgcc dependency.
sh: fix wrong icache/dcache address-array start addr in cache-debugfs.
Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com>
RTC_CLASS is changed to bool, so 'm' is invalid.
Signed-off-by: Wanlong Gao <wanlong.gao@gmail.com>
Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
The address limit is already set in flush_old_exec() so those calls to
set_fs(USER_DS) are redundant.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
gUSA special cases r15 for part of its login/out sequence, meaning that
any parameters need to be explicitly prohibited from accidentally being
assigned that particular register, and the compiler ultimately needs to
use a temporary instead.
Certain configurations have begun generating code paths that do indeed
get allocated r15, resulting in immediate corruption of the exchanged
value. This was observed in (amongst others) exit_mm() code generation
where the xchg_u32 call was immediately corrupting a structure address.
As this is a general gUSA restriction, the rest of the users likewise
need to be updated to ensure sensible constraints.
References: https://bugzilla.stlinux.com/show_bug.cgi?id=11229
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com>
Reviewed-by: Stuart Menefy <stuart.menefy@st.com>
SH-2A is unable to combine the kernel and libgcc objects due to
fundamental disagreements over FDPIC settings. As the kernel already
contains all of the libgcc bits broken out, there's not much need to
bother with the linking anymore, as everything can already be derived
from the lib dir.
This simply plugs in the necessary bits to ensure that everything is
built uniformly, enabling us to wean the compressed build off of explicit
libgcc linking.
Reported-by: Phil Edworthy <phil.edworthy@renesas.com>
This patch fixes a icache/dcache address-array start address while
dumping its entires in debugfs. Perviously the code was attempting to
remember the address in static variable, which is no more required
for debugfs, as the function can be executed in one pass.
Without this patch the start address ends up in wrong place and the
/sys/kernel/debug/sh/icache or dcache debugfs contents may not be correct.
Cc: Stuart Menefy <stuart.menefy@st.com>
There was an ordering issue with regards to instruction_pointer() being
used in profile_pc() prior to the asm-generic/ptrace.h include, which
subsequently provided the instruction_pointer() definition. In the
interest of simplicity we simply open-code the regs->pc deref for the
profile_pc() definition instead.
The FP functions were also broken due to a lack of a common regs->fp,
so provide a common GET_FP() that is safe for both architectures in order
to fix up the frame pointer helpers too.
sh64 doesn't define a P1SEGADDR, resulting in a build failure. The proper
mapping can be attained for both sh32 and 64 via the CAC_ADDR macro, so
switch to that instead.
Needed to satisfy the __in_29bit_mode() check.
Commit 1e56a56410bb64bce62d44563e35a143fc2d515f introduced the mmu_gather
rework for sh, but missed a linux/swap.h include:
CC arch/sh/mm/tlb-urb.o
In file included from arch/sh/mm/tlb-urb.c:14:0:
arch/sh/include/asm/tlb.h: In function '__tlb_remove_page':
arch/sh/include/asm/tlb.h:92:2: error: implicit declaration of function 'free_page_and_swap_cache'
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
CC: Peter Zijlstra <a.p.zijlstra@chello.nl>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into sh-fixes-for-linus
* setns:
ns: Wire up the setns system call
Done as a merge to make it easier to fix up conflicts in arm due to
addition of sendmmsg system call
32bit and 64bit on x86 are tested and working. The rest I have looked
at closely and I can't find any problems.
setns is an easy system call to wire up. It just takes two ints so I
don't expect any weird architecture porting problems.
While doing this I have noticed that we have some architectures that are
very slow to get new system calls. cris seems to be the slowest where
the last system calls wired up were preadv and pwritev. avr32 is weird
in that recvmmsg was wired up but never declared in unistd.h. frv is
behind with perf_event_open being the last syscall wired up. On h8300
the last system call wired up was epoll_wait. On m32r the last system
call wired up was fallocate. mn10300 has recvmmsg as the last system
call wired up. The rest seem to at least have syncfs wired up which was
new in the 2.6.39.
v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com>
v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com>
v4: Moved wiring up of the system call to another patch
v5: ported to v2.6.39-rc6
v6: rebased onto parisc-next and net-next to avoid syscall conflicts.
v7: ported to Linus's latest post 2.6.39 tree.
> arch/blackfin/include/asm/unistd.h | 3 ++-
> arch/blackfin/mach-common/entry.S | 1 +
Oh - ia64 wiring looks good.
Acked-by: Tony Luck <tony.luck@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6:
PM: Fix PM QOS's user mode interface to work with ASCII input
PM / Hibernate: Update kerneldoc comments in hibernate.c
PM / Hibernate: Remove arch_prepare_suspend()
PM / Hibernate: Update some comments in core hibernate code
By the previous style change, CONFIG_GENERIC_FIND_NEXT_BIT,
CONFIG_GENERIC_FIND_BIT_LE, and CONFIG_GENERIC_FIND_LAST_BIT are not used
to test for existence of find bitops anymore.
Acked-by: Greg Ungerer <gerg@uclinux.org>
The Blackfin arch, like the x86 arch, needs to adjust the PC manually
after a breakpoint is hit as normally this is handled by the remote gdb.
However, rather than starting another arch ifdef mess, create a common
GDB_ADJUSTS_BREAK_OFFSET define for any arch to opt-in via their kgdb.h.
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Dongdong Deng <dongdong.deng@windriver.com>
Cc: Sergei Shtylyov <sshtylyov@mvista.com>
Cc: Dongdong Deng <dongdong.deng@windriver.com>
The ns_cgroup is an annoying cgroup at the namespace / cgroup frontier and
leads to some problems:
* cgroup creation is out-of-control
* cgroup name can conflict when pids are looping
* it is not possible to have a single process handling a lot of
namespaces without falling in a exponential creation time
* we may want to create a namespace without creating a cgroup
The ns_cgroup was replaced by a compatibility flag 'clone_children',
where a newly created cgroup will copy the parent cgroup values.
The userspace has to manually create a cgroup and add a task to
the 'tasks' file.
This patch removes the ns_cgroup as suggested in the following thread:
https://lists.linux-foundation.org/pipermail/containers/2009-June/018616.html
The 'cgroup_clone' function is removed because it is no longer used.
This is a userspace-visible change. Commit 45531757b45c ("cgroup: notify
ns_cgroup deprecated") (merged into 2.6.27) caused the kernel to emit a
printk warning users that the feature is planned for removal. Since that
time we have heard from XXX users who were affected by this.
Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr>
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Jamal Hadi Salim <hadi@cyberus.ca>
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
Acked-by: Paul Menage <menage@google.com>
Acked-by: Matt Helsley <matthltc@us.ibm.com>
Most arches define CONFIG_DEBUG_STACK_USAGE exactly the same way. Move it
to lib/Kconfig.debug so each arch doesn't have to define it. This
obviously makes the option generic, but that's fine because the config is
already used in generic code.
It's not obvious to me that sysrq-P actually does anything caution by
keeping the most inclusive wording.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Acked-by: Richard Weinberger <richard@nod.at>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Cc: Chen Liqin <liqin.chen@sunplusct.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Fold all the mmu_gather rework patches into one for submission
Reported-by: Hugh Dickins <hughd@google.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Namhyung Kim <namhyung@gmail.com>
Fix up the sh mmu_gather code to conform to the new API.
This makes it possible to leave DMA slave IDs in the platform data
at default 0 value without hitting DMA channel allocation error paths.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
All architectures supporting hibernation define
arch_prepare_suspend() as an empty function, so remove it.
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-2.6.40' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: Unify input section names
percpu: Avoid extra NOP in percpu_cmpxchg16b_double
percpu: Cast away printk format warning
percpu: Always align percpu output section to PAGE_SIZE
Fix up fairly trivial conflict in arch/x86/include/asm/percpu.h as per Tejun
shmin uses __set_io_port_base() for legacy I/O mapping that ethernet and
other SuperI/O functions depend on. Ensure that PIO support is built in
until the board is updated for MMIO properly.
Trivial build fix for certain configurations that don't grab
linux/prefetch.h via alternate means (specifically SH-2 and SH-3 parts).
Cc: Simon Horman <horms@verge.net.au>
Cc: Magnus Damm <damm@opensource.se>
Use soc_camera_platform helper functions to dynamically manage the
camera device.
Some modules may end up with R_SH_NONE relocs with the right combination
of compiler/kernel config (specifically dwarf unwinder), so simply trap
and ignore them instead of letting them get down to the error path.
Reported-by: Carmelo AMOROSO <carmelo.amoroso@st.com>
