path: root/arch/sh/lib64
2020-06-01sh: remove sh5 supportArnd Bergmann
sh5 never became a product and has probably never really worked. Remove it by recursively deleting all associated Kconfig options and all corresponding files. Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Rich Felker <dalias@libc.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-14sh64: Kill off old exception debugging helpers.Paul Mundt
There's not much here that we can't get at through alternate means (aside from the TLB contents, but that doesn't belong here anyways). Most of this information is already provided by the sh32 routines, which we'll consolidate on next. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-08-04sh64: Kill off special clear_page() implementation.Paul Mundt
This can use the now generic clear_page() implementation, which is backed by the sh64 optimized memset routine. This also fixes up the case where PAGE_SIZE != 4kB. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-06-15sh: Convert sh64 to use the generic checksum code.Paul Mundt
This plugs in GENERIC_CSUM support on sh64, and kills off all of the old references. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-05-09sh: Provide an __sdivsi3_2 export for sh64.Paul Mundt
Newer code paths that are heavier in 64-bit math manage to get this generated by newer compilers, provide a definition and export accordingly. This is trivially wrapped around the existing __sdivsi3 code. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-05-08sh: Move out cayman-specific panic handler code to its own file.Paul Mundt
This moves out the cayman-specific panic handler code to a better location, and leaves the generic implementation a simple stub that is still used under emulation. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-05-08sh: Kill off unused sh64 debug code.Paul Mundt
None of the print_page() code and associated helpers are presently used by anything in-tree, so just kill it off. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-05-08sh: Kill off sh64's hand-rolled syscall tracer.Paul Mundt
This is no longer necessary, as there are now sufficient generic alternatives available. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-12-22sh: Provide sdivsi3/udivsi3/udivdi3 for sh64, kill off libgcc linking.Paul Mundt
This moves in the necessary libgcc bits and kills off the libgcc linking for sh64 kernels as well. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-12-22sh: Add SH-5 optimized memcpy()/memset()/strcpy()/strlen().Paul Mundt
Adopted from the uClibc optimized string versions. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-12-22Fix incorrect use of loose in c-checksum.cNick Andrew
Fix incorrect use of loose in c-checksum.c It should be 'lose', not 'loose'. Signed-off-by: Nick Andrew <nick@nick-andrew.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-29sh: migrate to arch/sh/include/Paul Mundt
This follows the sparc changes a439fe51a1f8eb087c22dd24d69cebae4a3addac. Most of the moving about was done with Sam's directions at: http://marc.info/?l=linux-sh&m=121724823706062&w=2 with subsequent hacking and fixups entirely my fault. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh64: Fix up compile warning in event tracer.Paul Mundt
2008-03-06sh: Fix up the sh64 build.Paul Mundt
2008-03-06sh: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-01-28sh: comment tidying for sh64->sh migration.Paul Mundt
2008-01-28sh: clear/copy_page renames in lib and lib64.Paul Mundt
2008-01-28sh: Tidy up various clear_page()/copy_page() definitions.Paul Mundt
2008-01-28sh: Tidy up lib64 udelay impl.Paul Mundt
2008-01-28sh: Fix up header reference for arch/sh/lib64/panic.c.Paul Mundt
2008-01-28sh: Kill off lib64 version of iomap wrappers.Paul Mundt
2008-01-28sh: Kill off lib64 version of io.c.Paul Mundt
2008-01-28sh: Move arch/sh64/lib to arch/sh/lib64.Paul Mundt
