path: root/arch/sh/kernel/relocate_kernel.S
2009-03-18sh: add kexec jump supportMagnus Damm
Add kexec jump support to the SuperH architecture. Similar to the x86 implementation, with the following exceptions: - Instead of separating the assembly code flow into two parts for regular kexec and kexec jump we use a single code path. In the assembly snippet regular kexec is just kexec jump that never comes back. - Instead of using a swap page when moving data between pages the page copy assembly routine has been modified to exchange the data between the pages using registers. - We walk the page list twice in machine_kexec() to do and undo physical to virtual address conversion. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-03-18sh: rework kexec segment codeMagnus Damm
Rework the kexec code to avoid using P2SEG. Instead we walk the page list in machine_kexec() and convert the addresses from physical to virtual using C. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-03-18sh: simplify kexec vbr codeMagnus Damm
Setup the vbr register in machine_kexec(). This instead of passing values to the assembly snippet. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-12-06sh: Fixup various PAGE_SIZE == 4096 assumptions.Paul Mundt
There were a number of places that made evil PAGE_SIZE == 4k assumptions that ended up breaking when trying to play with 8k and 64k page sizes, this fixes those up. The most significant change is the way we load THREAD_SIZE, previously this was done via: mov #(THREAD_SIZE >> 8), reg shll8 reg to avoid a memory access and allow the immediate load. With a 64k PAGE_SIZE, we're out of range for the immediate load size without resorting to special instructions available in later ISAs (movi20s and so on). The "workaround" for this is to bump up the shift to 10 and insert a shll2, which gives a bit more flexibility while still being much cheaper than a memory access. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-01-16[PATCH] sh: kexec() supportkogiidena
This adds kexec() support for SH. Signed-off-by: kogiidena <kogiidena@eggplant.ddo.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org> Cc: <fastboot@lists.osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
