path: root/arch/sh/kernel/cpu
2008-09-05sh64: resume_kernel fix for kernel oops built with CONFIG_BKL_PREEMPT=y.Paul Mundt
Follows the SH change. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-08-11sh: export sh7723 VEU as VEU2HMagnus Damm
Export sh7723 VEU hardware blocks as VEU2H. The sh7723 VEU2H differs a bit from the sh7722 VEU so use different names for our UIO devices. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-08-04sh: Fix up broken kerneldoc comments.Paul Mundt
These were completely unparseable, so fix them up. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-08-02sh: Make syscall tracer use tracehook notifiers, add TIF_NOTIFY_RESUME.Paul Mundt
This follows the changes in commits: 7d6d637dac2050f30a1b57b0a3dc5de4a10616ba 4f72c4279eab1e5f3ed1ac4e55d4527617582392 on powerpc. Adding in TIF_NOTIFY_RESUME, and cleaning up the syscall tracing to be more generic. This is an incremental step to turning on tracehook, as well as unifying more of the ptrace and signal code across the 32/64 split. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-08-02sh: Tidy up the _TIF work masks, and fix syscall trace bug on singlestep.Paul Mundt
2008-07-29sh: migrate to arch/sh/include/Paul Mundt
This follows the sparc changes a439fe51a1f8eb087c22dd24d69cebae4a3addac. Most of the moving about was done with Sam's directions at: http://marc.info/?l=linux-sh&m=121724823706062&w=2 with subsequent hacking and fixups entirely my fault. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Use clk_always_enable() on sh7366Magnus Damm
Use clk_always_enable() in the sh7366 processor code. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Use clk_always_enable() on sh7343 / SE77343Magnus Damm
Use clk_always_enable() on the sh7343 processor and in the board code for Solution Engine 7343. Remove duplicate MSTPCR register definitions. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Use clk_always_enable() on sh7722 / Migo-R / SE7722Magnus Damm
Use clk_always_enable() on the sh7722 processor and in the board code for Migo-R and Solution Engine 7722. Remove duplicate MSTPCR register definitions. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Use clk_always_enable() on sh7723 / ap325rxaMagnus Damm
Use clk_always_enable() on the sh7723 processor and in the ap325rxa board code. Remove duplicate MSTPCR register definitions. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Show all clocks and their state in /proc/clocksMagnus Damm
Show all clocks in /proc/clocks, and also show if they are enabled or disabled. This is useful to show MSTPCR bits on SuperH Mobile processors. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Merge sh7343 and sh7722 clock codeMagnus Damm
This code makes sh7343 share the sh7722 clock code. Instead of just using the good and very old sh7343 clock implmentation, switch to the new MSTPCR enabled clock code. SIU clocks are disabled on sh7343 for now. With this change all SuperH Mobile devices now use the same clock code. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Add SuperH Mobile MSTPCR bits to clock frameworkMagnus Damm
Handle module stop clock bits in MSTPCRn through the clock framework. The clocks are named after the bits in the data sheet. The association between bit number and hardware block is processor specific. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Use arch_flags to simplify sh7722 siu clock codeMagnus Damm
Make use of arch_flags to simplify the SIU clock code. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Add memory chunks to SH-Mobile UIO devicesMagnus Damm
This patch adds physically contiguous memory chunks to the UIO devices. The same strategy can be used in the future for the CEU as well. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Export sh7366 VPU, VEU(1), VEU(2) using uio_pdrv_genirqMagnus Damm
This patch exports the VPU, VEU(1) and VEU(2) blocks of the sh7366 to user space using the uio_pdrv_genirq platform driver. While at it, fix up the VEU(2) interrupt vector. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Export sh7723 VPU, VEU2H0, VEU2H1 using uio_pdrv_genirqMagnus Damm
This patch exports the VPU, VEU2H0 and VEU2H1 blocks of the sh7723 to user space using the uio_pdrv_genirq platform driver. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Export sh7722 VPU and VEU using uio_pdrv_genirqMagnus Damm
This patch exports the VPU and VEU blocks of the sh7722 to user space using the uio_pdrv_genirq platform driver. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Export sh7343 VPU and VEU using uio_pdrv_genirqMagnus Damm
This patch exports the VPU and VEU blocks of the sh7343 to user space using the uio_pdrv_genirq platform driver. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh2(A) exception handler updateYoshinori Sato
This patch is By sh2 - Remove duplicate code - Reduce stack usage - Cleanup and little optimize By sh2a - Add missing handler(256 to 511) - Use sh2a instructions handler Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: update sh7343 codeYoshihiro Shimoda
updated the following codes for SH7343: - add register_intc_controller() - add EARLY_SCIF_CONSOLE_PORT - add define of CPG register Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: add SuperH Mobile I2C platform data to sh7366Magnus Damm
This patch adds platform data for the single I2C channel on sh7366. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: add SuperH Mobile I2C platform data to sh7723Magnus Damm
This patch adds platform data for the single I2C channel on sh7723. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: add SuperH Mobile I2C platform data to sh7343Magnus Damm
This patch adds platform data for two I2C channels to the sh7343. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: add interrupt ack code to sh4aYoshihiro Shimoda
This patch is based on interrupt acknowledge code for external interrupt sources on sh3 processors and adds on sh4a processors. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Record the major cut revision for probed SH-4A parts.Paul Mundt
2008-07-28sh: Stub in silicon cut in CPU info.Stuart Menefy
Signed-off-by: Stuart Menefy <stuart.menefy@st.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Tidy up the SH-3 exception vector table.Paul Mundt
2008-07-28SH7619 add ethernet controler supportYoshinori Sato
- Add EtherC + PHY resource define. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh/kernel/ cleanupsAdrian Bunk
This patch contains the following cleanups: - make the following needlessly global code static: - cf-enabler.c: cf_init() - cpu/clock.c: __clk_enable() - cpu/clock.c: __clk_disable() - process_32.c: default_idle() - time_32.c: struct clocksource_sh - timers/timer-tmu.c: struct tmu_timer_ops - remove the following unused functions (no CONFIG_BLK_DEV_FD on sh): - process_{32,64}.c: disable_hlt() - process_{32,64}.c: enable_hlt() Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Add SCIF2 support for SH7763.Nobuhiro Iwamatsu
SH7763 has 3 SCIF device. Current code supports SCIF0 and 1. SCIF0 and 1 are same register constitution, but only SCIF2 is different. I added support of SCIF2. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-06-09sh: add resource of USB host for SH7723Yoshihiro Shimoda
2008-06-09sh: Fix compile error SH7763 setup codeNobuhiro Iwamatsu
SH7763's setup code use old DECLARE_INTC_DESC. There was a compile error because of this. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-06-09sh: Add SH7723 SCIF supportYusuke.Goda
Signed-off-by: Yusuke Goda <goda.yusuke@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-06-02sh/kernel/cpu/irq/intc-sh5.c build fixAdrian Bunk
This patch fixes the following build error caused by commit a1dc4b59fa4af97ae68ee214d4d72bbd7c7ec1dc (sh: intc_sh5 depends on cayman board for IRQ priority table.): <-- snip --> ... CC arch/sh/kernel/cpu/irq/intc-sh5.o /home/bunk/linux/kernel-2.6/git/linux-2.6/arch/sh/kernel/cpu/irq/intc-sh5.c: In function 'plat_irq_setup': /home/bunk/linux/kernel-2.6/git/linux-2.6/arch/sh/kernel/cpu/irq/intc-sh5.c:257: error: expected declaration or statement at end of input make[4]: *** [arch/sh/kernel/cpu/irq/intc-sh5.o] Error 1 <-- snip --> Reported-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-26sh: Drop broken URAM support on SH7723.Paul Mundt
This was copied over from the previous MobileR bits, which doesn't apply to R2. The URAM block on R2 is recycled for the L2 instead. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-23sh: add probe support for new sh7723 cutMagnus Damm
This patch adds support for sh7723 silicon with a prr value of 0x51. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-23sh: fix VPU interrupt vector for sh7723Magnus Damm
This patch fixes a VPU vector typo for sh7723. The correct value is 0x980, the same as for sh7722. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-23sh: fix USBF resource for sh7722Magnus Damm
The USBF function on sh7722 is currently not working with the m66592_udc driver. The driver is using platform_get_resource_byname() so my commit a0d29798e568116aa6c32aef7bab2d9e620c88ad broke sh7722 support. The long term fix is to replace platform_get_resource_byname() in the driver with platform_get_resource(), but this helps until that happens. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-16sh: fix sh7785 master clock valueYoshihiro Shimoda
2008-05-09SH: catch negative denormal_subf1() retval in denormal_add()Roel Kluin
'ix' is unsigned but denormal_subf1() may return a negative int. Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: intc register modify fixMagnus Damm
Make sure register modifications stay atomic. Fixes processors with shared priority register masking. Dual bitmap masking is unaffected. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: no high level trigger on some sh3 cpusMagnus Damm
The processor models sh7706, sh7707 and sh7709 don't support high level trigger sense configuration. And the intc code looks like crap these days so what's the difference. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: clean up sh7710 and sh7720 intc tablesMagnus Damm
Clean up the intc tables by removing unneeded #ifdefs. The vector list is what selects which interrupt sources that should be added, having unsupported bitfields listed is ok as long as the vector is excluded from the list. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: add interrupt ack code to sh3Magnus Damm
This patch adds interrupt acknowledge code for external interrupt sources on sh3 processors. Only really required for edge triggered interrupts, but we ack regardless of sense configuration. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: unify external irq pin code for sh3Magnus Damm
This patch unifies the sh3 external irq pin code. It buys us some savings with reduced code redundancy, but the main feature with this change is irq sense selection support for all sh3 processors. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: fix sh7705 interrupt vector typoMagnus Damm
Fix sh7705 interrupt sources for vectors 0xc80 and 0xca0. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: intc_sh5 depends on cayman board for IRQ priority table.Paul Mundt
2008-05-08sh64: Setup I/D-TLB defaults in SH-5 probe path.Paul Mundt
2008-05-08sh64: Fixup the nommu build.Paul Mundt
