Pull fbdev changes from Tomi Valkeinen:
"OMAPDSS changes, including:
- use dynanic debug prints
- OMAP platform dependency removals
- Creation of compat-layer, helping us to improve omapdrm
- Misc cleanups, aiming to make omadss more in line with the upcoming
common display framework
Exynos DP changes for the 3.8 merge window:
- Device Tree support for Samsung Exynos DP
- SW Link training is cleaned up.
- HPD interrupt is supported.
Samsung Framebuffer changes for the 3.8 merge window:
- The bit definitions of header file are updated.
- Some minor typos are fixed.
- Some minor bugs of s3c_fb_check_var() are fixed.
FB related changes for SH Mobile, Freescale DIU
Add support for the Solomon SSD1307 OLED Controller"
* tag 'fbdev-for-3.8' of git://gitorious.org/linux-omap-dss2/linux: (191 commits)
OMAPDSS: fix TV-out issue with DSI PLL
Revert "OMAPFB: simplify locking"
OMAPFB: remove silly loop in fb2display()
OMAPFB: fix error handling in omapfb_find_best_mode()
OMAPFB: use devm_kzalloc to allocate omapfb2_device
OMAPDSS: DISPC: remove dispc fck uses
OMAPDSS: DISPC: get dss clock rate from dss driver
drivers/video/console/softcursor.c: remove redundant NULL check before kfree()
drivers/video: add support for the Solomon SSD1307 OLED Controller
OMAPDSS: use omapdss_compat_init() in other drivers
OMAPDSS: export dispc functions
OMAPDSS: export dss_feat functions
OMAPDSS: export dss_mgr_ops functions
OMAPDSS: separate compat files in the Makefile
OMAPDSS: move display sysfs init to compat layer
OMAPDSS: DPI: use dispc's check_timings
OMAPDSS: DISPC: add dispc_ovl_check()
OMAPDSS: move irq handling to dispc-compat
OMAPDSS: move omap_dispc_wait_for_irq_interruptible_timeout to dispc-compat.c
OMAPDSS: move blocking mgr enable/disable to compat layer
arch/arm/mach-davinci/devices-da8xx.c
arch/arm/plat-omap/common.c
drivers/media/platform/omap/omap_vout.c
Don't hook up brightness control in the display on/off operations, use
the backlight API instead.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
renesas_usbhs driver can control both USB Host/Gadget,
but it needs VBUS output if Host mode.
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Pull trivial tree from Jiri Kosina:
"Trivial updates all over the place as usual."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (29 commits)
Fix typo in include/linux/clk.h .
pci: hotplug: Fix typo in pci
iommu: Fix typo in iommu
video: Fix typo in drivers/video
Documentation: Add newline at end-of-file to files lacking one
arm,unicore32: Remove obsolete "select MISC_DEVICES"
module.c: spelling s/postition/position/g
cpufreq: Fix typo in cpufreq driver
trivial: typo in comment in mksysmap
mach-omap2: Fix typo in debug message and comment
scsi: aha152x: Fix sparse warning and make printing pointer address more portable.
Change email address for Steve Glendinning
Btrfs: fix typo in convert_extent_bit
via: Remove bogus if check
netprio_cgroup.c: fix comment typo
backlight: fix memory leak on obscure error path
Documentation: asus-laptop.txt references an obsolete Kconfig item
Documentation: ManagementStyle: fixed typo
mm/vmscan: cleanup comment error in balance_pgdat
mm: cleanup on the comments of zone_reclaim_stat
I no longer have a mailbox at smsc.com, and I've had two reports
that that email address now bounces from people trying to
contact me. This patch updates all references to that invalid
address to one that I can be contacted on more permanently.
This patch also updates the maintainer status to reflect
the fact I'm no longer directly paid to maintain these drivers.
Signed-off-by: Steve Glendinning <steve.glendinning@shawell.net>
On systems, using regulators to supply power to devices, if the REGULATOR
Kconfig option is disabled, regulator API stubs will be used, which often
suffices to bring a default configuration up. If REGULATOR is enabled but
respective regulator drivers are inactive, the real regulator API calls
will be used, which in the absence of drivers will fail to provide
services. This patch prevents such a problem on sh-mobile boards by
forcing REGULATOR_FIXED_VOLTAGE on if REGULATOR is selected.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Power on the CN11 and CN12 SD/MMC slots on ecovec is controlled by GPIOs,
which makes it possible to use the fixed voltage regulator driver to switch
card power on and off.
On se7724 provide a 3.3V supply for its SD/MMC-card interfaces.
On sdk7786 provide a dummy regulator for the smsc911x driver.
On rsk devices provide a dummy regulator for the smsc911x driver.
On migor provide a 3.3V supply for its SD/MMC-card interfaces.
On kfr2r09 provide a 3.3V supply for its SD/MMC-card interfaces.
On ap325rxa provide a 3.3V supply for its SD/MMC-card interfaces and a
On sh7757lcr provide a 3.3V supply for its SD/MMC-card interfaces.
On sh2007 provide a dummy regulator for the smsc911x driver for the two
SMSC 9118 devices.
On polaris provide a dummy regulator for the smsc911x driver.
On magicpanelr2 provide a dummy regulator for the smsc911x driver.
On apsh4ad0a provide a dummy regulator for the smsc911x driver.
On apsh4a3a provide a dummy regulator for the smsc911x driver.
Fix compile breakage caused by
commit aa82f9fcd0062782dcbe29a2c820ba7c04dbe572
Author: Paul Mundt <lethal@linux-sh.org>
sh: kfr2r09 evt2irq migration.
drivers/sh/intc/dynamic.c
Pull mtd update from David Woodhouse:
- More robust parsing especially of xattr data in JFFS2
- Updates to mxc_nand and gpmi drivers to support new boards and device tree
- Improve consistency of information about ECC strength in NAND devices
- Clean up partition handling of plat_nand
- Support NAND drivers without dedicated access to OOB area
- BCH hardware ECC support for OMAP
- Other fixes and cleanups, and a few new device IDs
Fixed trivial conflict in drivers/mtd/nand/gpmi-nand/gpmi-nand.c due to
added include files next to each other.
* tag 'for-linus-3.5-20120601' of git://git.infradead.org/linux-mtd: (75 commits)
mtd: mxc_nand: move ecc strengh setup before nand_scan_tail
mtd: block2mtd: fix recursive call of mtd_writev
mtd: gpmi-nand: define ecc.strength
mtd: of_parts: fix breakage in Kconfig
mtd: nand: fix scan_read_raw_oob
mtd: docg3 fix in-middle of blocks reads
mtd: cfi_cmdset_0002: Slight cleanup of fixup messages
mtd: add fixup for S29NS512P NOR flash.
jffs2: allow to complete xattr integrity check on first GC scan
jffs2: allow to discriminate between recoverable and non-recoverable errors
mtd: nand: omap: add support for hardware BCH ecc
ARM: OMAP3: gpmc: add BCH ecc api and modes
mtd: nand: check the return code of 'read_oob/read_oob_raw'
mtd: nand: remove 'sndcmd' parameter of 'read_oob/read_oob_raw'
mtd: m25p80: Add support for Winbond W25Q80BW
jffs2: get rid of jffs2_sync_super
jffs2: remove unnecessary GC pass on sync
jffs2: remove unnecessary GC pass on umount
jffs2: remove lock_super
mtd: gpmi: add gpmi support for mx6q
Follows the se7722 change, see there for more information.
This implements a total rewrite of the rather buggy SE7722 FPGA IRQ code,
utilizing a linear irq domain as well as the generic irq chip type.
While the interaction between the two APIs is a bit clunky (ie, revmap
lookup for gc irq_base), they work well enough together that it's easy
enough to work with going forward.
While we're at it, deal with irq_mask_ack/unmask of the chained IRQ in
the demux handler to prevent smc91x screaming about spurious interrupts.
There's also some more improvement that can be made to the irqdomain code
to create backing irqdescs for the entire linear range in one bang
instead of iterating over the number of hwirqs and doing it
irq-at-a-time. This is easily dealt with at a later point, though.
In the interest of getting off of the create_irq() API we can get all of
the functionality we're interested in through a linear IRQ domain. Fairly
straightforward conversion utilizing a single linear domain.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"This is the first big chunk for 3.5 merges of sound stuff.
There are a few big changes in different areas. First off, the
streaming logic of USB-audio endpoints has been largely rewritten for
the better support of "implicit feedback". If anything about USB got
broken, this change has to be checked.
For HD-audio, the resume procedure was changed; instead of delaying
the resume of the hardware until the first use, now waking up
immediately at resume. This is for buggy BIOS.
For ASoC, dynamic PCM support and the improved support for digital
links between off-SoC devices are major framework changes.
Some highlights are below:
* HD-audio
- Avoid accesses of invalid pin-control bits that may stall the codec
- V-ref setup cleanups
- Fix the races in power-saving code
- Fix the races in codec cache hashes and connection lists
- Split some common codes for BIOS auto-parser to hda_auto_parser.c
- Changed the PM resume code to wake up immediately for buggy BIOS
- Creative SoundCore3D support
- Add Conexant CX20751/2/3/4 codec support
* ASoC
- Dynamic PCM support, allowing support for SoCs with internal
routing through components with tight sequencing and formatting
constraints within their internal paths or where there are multiple
components connected with CPU managed DMA controllers inside the
SoC.
- Greatly improved support for direct digital links between off-SoC
devices, providing a much simpler way of connecting things like
digital basebands to CODECs.
- Much more fine grained and robust locking, cleaning up some of the
confusion that crept in with multi-component.
- CPU support for nVidia Tegra 30 I2S and audio hub controllers and
ST-Ericsson MSP I2S controolers
- New CODEC drivers for Cirrus CS42L52, LAPIS Semiconductor ML26124,
Texas Instruments LM49453.
- Some regmap changes needed by the Tegra I2S driver.
- mc13783 audio support.
* Misc
- Rewrite with module_pci_driver()
- Xonar DGX support for snd-oxygen
- Improvement of packet handling in snd-firewire driver
- New USB-endpoint streaming logic
- Enhanced M-audio FTU quirks and relevant cleanups
- Increment the support of OSS devices to 256
- snd-aloop accuracy improvement
There are a few more pending changes for 3.5, but they will be sent
slightly later as partly depending on the changes of DRM."
Fix up conflicts in regmap (due to duplicate patches, with some further
updates then having already come in from the regmap tree). Also some
fairly trivial context conflicts in the imx and mcx soc drivers.
* tag 'sound-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (280 commits)
ALSA: snd-usb: fix stream info output in /proc
ALSA: pcm - Add proper state checks to snd_pcm_drain()
ALSA: sh: Fix up namespace collision in sh_dac_audio.
ALSA: hda/realtek - Fix unused variable compile warning
ASoC: sh: fsi: enable chip specific data transfer mode
ASoC: sh: fsi: call fsi_hw_startup/shutdown from fsi_dai_trigger()
ASoC: sh: fsi: use same format for IN/OUT
ASoC: sh: fsi: add fsi_version() and removed meaningless version check
ASoC: sh: fsi: use register field macro name on IN/OUT_DMAC
ASoC: tegra: Add machine driver for WM8753 codec
ALSA: hda - Fix possible races of accesses to connection list array
ASoC: OMAP: HDMI: Introduce codec
ARM: mx31_3ds: Add sound support
ASoC: imx-mc13783 cleanup
mx31moboard: Add sound support
ASoC: mc13783 codec cleanups
ASoC: add imx-mc13783 sound support
ASoC: Add mc13783 codec
mfd: mc13xxx: add codec platform data
ASoC: don't flip master of DT-instantiated DAI links
Everything is using sparseirq these days, so we have no need to
arbitrarily size nr_irqs ahead of time. The legacy IRQ pre-allocation
likewise has no meaning for us, so that's killed off too. We now depend
on nr_irqs expansion by the generic hardirq layer instead.
It's also worth noting that the majority of boards had completely bogus
values for their nr_irqs relative to their CPU and configurations, so
this ends up correcting behaviour for quite a few platforms.
Switches from create_irq_nr() to irq_alloc_descs().
arch/sh/kernel/cpu/sh3/setup-sh770x.c
arch/sh/kernel/cpu/sh3/setup-sh7710.c
arch/sh/kernel/cpu/sh3/setup-sh7720.c
arch/sh/kernel/cpu/sh4/setup-sh7750.c
arch/sh/kernel/cpu/sh4a/setup-sh7343.c
arch/sh/kernel/cpu/sh4a/setup-sh7366.c
arch/sh/kernel/cpu/sh4a/setup-sh7722.c
arch/sh/kernel/cpu/sh4a/setup-sh7723.c
arch/sh/kernel/cpu/sh4a/setup-sh7724.c
arch/sh/kernel/cpu/sh4a/setup-sh7757.c
arch/sh/kernel/cpu/sh4a/setup-sh7763.c
arch/sh/kernel/cpu/sh4a/setup-sh7770.c
arch/sh/kernel/cpu/sh4a/setup-sh7785.c
arch/sh/kernel/cpu/sh4a/setup-sh7786.c
Migrate sh7763rdp to evt2irq backed hwirq lookups.
Migrate migor to evt2irq backed hwirq lookups.
Migrate kfr2r09 to evt2irq backed hwirq lookups.
Migrate ecovec24 to evt2irq backed hwirq lookups.
Migrate ap325rxa to evt2irq backed hwirq lookups.
Migrate urquell to evt2irq backed hwirq lookups.
Migrate sh7785lcr to evt2irq backed hwirq lookups.
Migrate hp6xx to evt2irq backed hwirq lookups.
Migrate Solution Engine boards to evt2irq backed hwirq lookups.
Migrate sh7757lcr to evt2irq() backed hwirq lookups.
Migrate magicpanelr2 to evt2irq() backed hwirq lookups.
Migrate espt to evt2irq() backed hwirq lookups.
Migrate edosk7760 to evt2irq() backed hwirq lookups.
Migrate edosk7705 to evt2irq() backed hwirq lookups.
The generic hardirq layer provides all of the routines that we need these
days, so we don't require any of the dynamic IRQ API wrapping, and can
call in to irq_alloc_descs() directly.
Use the default partition parser, cmdlinepart, provided by the plat_nand driver.
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
