This flattens out the board directories in to individual mach groups,
we will use this for getting rid of unneeded directories, simplifying
the build system, and becoming more coherent with the refactored
arch/sh/include topology.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
When I compiled Solution Engine, this become compile error
because plaform device of sh_eth device becomes enable.
When sh7710/sh7712 which could use sh_eth was chosen,
revised it so that platform device of sh_eth device became enable.
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
sh_pcic_io_xxx function are very old.
In linux-2.4, mrshpc_ss socket driver used this function.
But there is not this driver to the present kernel.
I deleted these cords and checked operation.
Add support SH-Ether for Hitachi Solution Engine.
Access size to LED is not added on Solution Engine series.
LED doesn't work. Fixed this problem.
We were abusing the resource size for the number of bits, this
has been reworked using proper platform data, so this can be
tidied up now. Boards in general only have a 1-byte wide resource,
which the ioremap_nocache() case already handles.
Add some flags for the heartbeat driver, and kill off some duplication
in the bit positions for the boards that don't have special cases.
This also allows for variable access widths and inversion.
This patch reworks the ipr code by grouping the offset array together
with the ipr_data structure in a new data structure called ipr_desc.
This new structure also contains the name of the controller in struct
irq_chip. The idea behind putting struct irq_chip in there is that we
can use offsetof() to locate the base addresses in the irq_chip
callbacks. This strategy has much in common with the recently merged
intc2 code.
One logic change has been made - the original ipr code enabled the
interrupts by default but with this patch they are all disabled by
default.
Signed-off-by: Magnus Damm <damm@igel.co.jp>
We now throw all of the machvecs in to .machvec.init and either
select one on the command line, or copy out the first (and
usually only) one to sh_mv. The rest are freed as usual.
This gets rid of all of the silly sh_mv aliasing and makes the
selection explicit rather than link-order dependent.
This fixes up SH7705 CPU support and the SE7705 board
for some of the recent changes.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.zh@hitachi.com>
Support the SH7712 (SH3-DSP) Solution Engine reference board.
This enables pata_platform support for the PCMCIA slot on the
SolutionEngine.
Signed-off-by: Nobuhiro Iwamatsu <hemamu@t-base.ne.jp>
This consolidates the various board heartbeat LED implementations,
used for strobing the load average across a LED bank. Those boards
not implementing a full bank can hook in via the LED class.
We leave the compat hook in the machvec for now until those non-banked
boards are able to migrate to the drivers/leds.
Fixups for external IPR IRQs for the SE770x FPGA.
The conversion from IPR-IRQ to IRQ-chip resulted in the
ipr data being allocated in a local variable in
make_ipr_irq - breaking anything using IPR interrupts.
This changes all of the callers of make_ipr_irq to
allocate a static structure containing the IPR data which
is then passed to make_ipr_irq. This removes the need for
make_ipr_irq to allocate any additional space for the IPR
information.
Signed-off-by: Jamie Lenehan <lenehan@twibble.org>
Many files include the filename at the beginning, serveral used a wrong one.
Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com>
Get all of the defconfigs building again.
Some more machvec overhauling and setup code cleanup. Kill off
get_system_type() and platform_setup(), we can do these both
through the machvec. While we're add it, kill off more useless
mach.c's and drop some legacy cruft from setup.c.
This cleans up quite a lot of the PCI mess that we
currently have, and attempts to consolidate the
duplication in the SH7780 and SH7751 PCI controllers.
This updates the various boards for some of the recent I/O routine
updates.
Some of these have suffered some bitrot, and so there is
some degree of dead code that has been left sitting around,
clean it up..
SystemH needs this header as well, not just 770x SE.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
infrastructure for it.
Let it rip!
