path: root/arch/s390
2014-08-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights: 1) Steady transitioning of the BPF instructure to a generic spot so all kernel subsystems can make use of it, from Alexei Starovoitov. 2) SFC driver supports busy polling, from Alexandre Rames. 3) Take advantage of hash table in UDP multicast delivery, from David Held. 4) Lighten locking, in particular by getting rid of the LRU lists, in inet frag handling. From Florian Westphal. 5) Add support for various RFC6458 control messages in SCTP, from Geir Ola Vaagland. 6) Allow to filter bridge forwarding database dumps by device, from Jamal Hadi Salim. 7) virtio-net also now supports busy polling, from Jason Wang. 8) Some low level optimization tweaks in pktgen from Jesper Dangaard Brouer. 9) Add support for ipv6 address generation modes, so that userland can have some input into the process. From Jiri Pirko. 10) Consolidate common TCP connection request code in ipv4 and ipv6, from Octavian Purdila. 11) New ARP packet logger in netfilter, from Pablo Neira Ayuso. 12) Generic resizable RCU hash table, with intial users in netlink and nftables. From Thomas Graf. 13) Maintain a name assignment type so that userspace can see where a network device name came from (enumerated by kernel, assigned explicitly by userspace, etc.) From Tom Gundersen. 14) Automatic flow label generation on transmit in ipv6, from Tom Herbert. 15) New packet timestamping facilities from Willem de Bruijn, meant to assist in measuring latencies going into/out-of the packet scheduler, latency from TCP data transmission to ACK, etc" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1536 commits) cxgb4 : Disable recursive mailbox commands when enabling vi net: reduce USB network driver config options. tg3: Modify tg3_tso_bug() to handle multiple TX rings amd-xgbe: Perform phy connect/disconnect at dev open/stop amd-xgbe: Use dma_set_mask_and_coherent to set DMA mask net: sun4i-emac: fix memory leak on bad packet sctp: fix possible seqlock seadlock in sctp_packet_transmit() Revert "net: phy: Set the driver when registering an MDIO bus device" cxgb4vf: Turn off SGE RX/TX Callback Timers and interrupts in PCI shutdown routine team: Simplify return path of team_newlink bridge: Update outdated comment on promiscuous mode net-timestamp: ACK timestamp for bytestreams net-timestamp: TCP timestamping net-timestamp: SCHED timestamp on entering packet scheduler net-timestamp: add key to disambiguate concurrent datagrams net-timestamp: move timestamp flags out of sk_flags net-timestamp: extend SCM_TIMESTAMPING ancillary data struct cxgb4i : Move stray CPL definitions to cxgb4 driver tcp: reduce spurious retransmits due to transient SACK reneging qlcnic: Initialize dcbnl_ops before register_netdev ...
2014-08-05Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer and time updates from Thomas Gleixner: "A rather large update of timers, timekeeping & co - Core timekeeping code is year-2038 safe now for 32bit machines. Now we just need to fix all in kernel users and the gazillion of user space interfaces which rely on timespec/timeval :) - Better cache layout for the timekeeping internal data structures. - Proper nanosecond based interfaces for in kernel users. - Tree wide cleanup of code which wants nanoseconds but does hoops and loops to convert back and forth from timespecs. Some of it definitely belongs into the ugly code museum. - Consolidation of the timekeeping interface zoo. - A fast NMI safe accessor to clock monotonic for tracing. This is a long standing request to support correlated user/kernel space traces. With proper NTP frequency correction it's also suitable for correlation of traces accross separate machines. - Checkpoint/restart support for timerfd. - A few NOHZ[_FULL] improvements in the [hr]timer code. - Code move from kernel to kernel/time of all time* related code. - New clocksource/event drivers from the ARM universe. I'm really impressed that despite an architected timer in the newer chips SoC manufacturers insist on inventing new and differently broken SoC specific timers. [ Ed. "Impressed"? I don't think that word means what you think it means ] - Another round of code move from arch to drivers. Looks like most of the legacy mess in ARM regarding timers is sorted out except for a few obnoxious strongholds. - The usual updates and fixlets all over the place" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (114 commits) timekeeping: Fixup typo in update_vsyscall_old definition clocksource: document some basic timekeeping concepts timekeeping: Use cached ntp_tick_length when accumulating error timekeeping: Rework frequency adjustments to work better w/ nohz timekeeping: Minor fixup for timespec64->timespec assignment ftrace: Provide trace clocks monotonic timekeeping: Provide fast and NMI safe access to CLOCK_MONOTONIC seqcount: Add raw_write_seqcount_latch() seqcount: Provide raw_read_seqcount() timekeeping: Use tk_read_base as argument for timekeeping_get_ns() timekeeping: Create struct tk_read_base and use it in struct timekeeper timekeeping: Restructure the timekeeper some more clocksource: Get rid of cycle_last clocksource: Move cycle_last validation to core code clocksource: Make delta calculation a function wireless: ath9k: Get rid of timespec conversions drm: vmwgfx: Use nsec based interfaces drm: i915: Use nsec based interfaces timekeeping: Provide ktime_get_raw() hangcheck-timer: Use ktime_get_ns() ...
2014-08-04Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf changes from Ingo Molnar: "Kernel side changes: - Consolidate the PMU interrupt-disabled code amongst architectures (Vince Weaver) - misc fixes Tooling changes (new features, user visible changes): - Add support for pagefault tracing in 'trace', please see multiple examples in the changeset messages (Stanislav Fomichev). - Add pagefault statistics in 'trace' (Stanislav Fomichev) - Add header for columns in 'top' and 'report' TUI browsers (Jiri Olsa) - Add pagefault statistics in 'trace' (Stanislav Fomichev) - Add IO mode into timechart command (Stanislav Fomichev) - Fallback to syscalls:* when raw_syscalls:* is not available in the perl and python perf scripts. (Daniel Bristot de Oliveira) - Add --repeat global option to 'perf bench' to be used in benchmarks such as the existing 'futex' one, that was modified to use it instead of a local option. (Davidlohr Bueso) - Fix fd -> pathname resolution in 'trace', be it using /proc or a vfs_getname probe point. (Arnaldo Carvalho de Melo) - Add suggestion of how to set perf_event_paranoid sysctl, to help non-root users trying tools like 'trace' to get a working environment. (Arnaldo Carvalho de Melo) - Updates from trace-cmd for traceevent plugin_kvm plus args cleanup (Steven Rostedt, Jan Kiszka) - Support S/390 in 'perf kvm stat' (Alexander Yarygin) Tooling infrastructure changes: - Allow reserving a row for header purposes in the hists browser (Arnaldo Carvalho de Melo) - Various fixes and prep work related to supporting Intel PT (Adrian Hunter) - Introduce multiple debug variables control (Jiri Olsa) - Add callchain and additional sample information for python scripts (Joseph Schuchart) - More prep work to support Intel PT: (Adrian Hunter) - Polishing 'script' BTS output - 'inject' can specify --kallsym - VDSO is per machine, not a global var - Expose data addr lookup functions previously private to 'script' - Large mmap fixes in events processing - Include standard stringify macros in power pc code (Sukadev Bhattiprolu) Tooling cleanups: - Convert open coded equivalents to asprintf() (Andy Shevchenko) - Remove needless reassignments in 'trace' (Arnaldo Carvalho de Melo) - Cache the is_exit syscall test in 'trace) (Arnaldo Carvalho de Melo) - No need to reimplement err() in 'perf bench sched-messaging', drop barf(). (Davidlohr Bueso). - Remove ev_name argument from perf_evsel__hists_browse, can be obtained from the other parameters. (Jiri Olsa) Tooling fixes: - Fix memory leak in the 'sched-messaging' perf bench test. (Davidlohr Bueso) - The -o and -n 'perf bench mem' options are mutually exclusive, emit error when both are specified. (Davidlohr Bueso) - Fix scrollbar refresh row index in the ui browser, problem exposed now that headers will be added and will be allowed to be switched on/off. (Jiri Olsa) - Handle the num array type in python properly (Sebastian Andrzej Siewior) - Fix wrong condition for allocation failure (Jiri Olsa) - Adjust callchain based on DWARF debug info on powerpc (Sukadev Bhattiprolu) - Fix a risk for doing free on uninitialized pointer in traceevent lib (Rickard Strandqvist) - Update attr test with PERF_FLAG_FD_CLOEXEC flag (Jiri Olsa) - Enable close-on-exec flag on perf file descriptor (Yann Droneaud) - Fix build on gcc 4.4.7 (Arnaldo Carvalho de Melo) - Event ordering fixes (Jiri Olsa)" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (123 commits) Revert "perf tools: Fix jump label always changing during tracing" perf tools: Fix perf usage string leftover perf: Check permission only for parent tracepoint event perf record: Store PERF_RECORD_FINISHED_ROUND only for nonempty rounds perf record: Always force PERF_RECORD_FINISHED_ROUND event perf inject: Add --kallsyms parameter perf tools: Expose 'addr' functions so they can be reused perf session: Fix accounting of ordered samples queue perf powerpc: Include util/util.h and remove stringify macros perf tools: Fix build on gcc 4.4.7 perf tools: Add thread parameter to vdso__dso_findnew() perf tools: Add dso__type() perf tools: Separate the VDSO map name from the VDSO dso name perf tools: Add vdso__new() perf machine: Fix the lifetime of the VDSO temporary file perf tools: Group VDSO global variables into a structure perf session: Add ability to skip 4GiB or more perf session: Add ability to 'skip' a non-piped event stream perf tools: Pass machine to vdso__dso_findnew() perf tools: Add dso__data_size() ...
2014-08-04Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking updates from Ingo Molnar: "The main changes in this cycle are: - big rtmutex and futex cleanup and robustification from Thomas Gleixner - mutex optimizations and refinements from Jason Low - arch_mutex_cpu_relax() removal and related cleanups - smaller lockdep tweaks" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits) arch, locking: Ciao arch_mutex_cpu_relax() locking/lockdep: Only ask for /proc/lock_stat output when available locking/mutexes: Optimize mutex trylock slowpath locking/mutexes: Try to acquire mutex only if it is unlocked locking/mutexes: Delete the MUTEX_SHOW_NO_WAITER macro locking/mutexes: Correct documentation on mutex optimistic spinning rtmutex: Make the rtmutex tester depend on BROKEN futex: Simplify futex_lock_pi_atomic() and make it more robust futex: Split out the first waiter attachment from lookup_pi_state() futex: Split out the waiter check from lookup_pi_state() futex: Use futex_top_waiter() in lookup_pi_state() futex: Make unlock_pi more robust rtmutex: Avoid pointless requeueing in the deadlock detection chain walk rtmutex: Cleanup deadlock detector debug logic rtmutex: Confine deadlock logic to futex rtmutex: Simplify remove_waiter() rtmutex: Document pi chain walk rtmutex: Clarify the boost/deboost part rtmutex: No need to keep task ref for lock owner check rtmutex: Simplify and document try_to_take_rtmutex() ...
2014-08-04Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM changes from Paolo Bonzini: "These are the x86, MIPS and s390 changes; PPC and ARM will come in a few days. MIPS and s390 have little going on this release; just bugfixes, some small, some larger. The highlights for x86 are nested VMX improvements (Jan Kiszka), optimizations for old processor (up to Nehalem, by me and Bandan Das), and a lot of x86 emulator bugfixes (Nadav Amit). Stephen Rothwell reported a trivial conflict with the tracing branch" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (104 commits) x86/kvm: Resolve shadow warnings in macro expansion KVM: s390: rework broken SIGP STOP interrupt handling KVM: x86: always exit on EOIs for interrupts listed in the IOAPIC redir table KVM: vmx: remove duplicate vmx_mpx_supported() prototype KVM: s390: Fix memory leak on busy SIGP stop x86/kvm: Resolve shadow warning from min macro kvm: Resolve missing-field-initializers warnings Replace NR_VMX_MSR with its definition KVM: x86: Assertions to check no overrun in MSR lists KVM: x86: set rflags.rf during fault injection KVM: x86: Setting rflags.rf during rep-string emulation KVM: x86: DR6/7.RTM cannot be written KVM: nVMX: clean up nested_release_vmcs12 and code around it KVM: nVMX: fix lifetime issues for vmcs02 KVM: x86: Defining missing x86 vectors KVM: x86: emulator injects #DB when RFLAGS.RF is set KVM: x86: Cleanup of rflags.rf cleaning KVM: x86: Clear rflags.rf on emulated instructions KVM: x86: popf emulation should not change RF KVM: x86: Clearing rflags.rf upon skipped emulated instruction ...
2014-08-04Merge tag 'trace-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing updates from Steven Rostedt: "This pull request has a lot of work done. The main thing is the changes to the ftrace function callback infrastructure. It's introducing a way to allow different functions to call directly different trampolines instead of all calling the same "mcount" one. The only user of this for now is the function graph tracer, which always had a different trampoline, but the function tracer trampoline was called and did basically nothing, and then the function graph tracer trampoline was called. The difference now, is that the function graph tracer trampoline can be called directly if a function is only being traced by the function graph trampoline. If function tracing is also happening on the same function, the old way is still done. The accounting for this takes up more memory when function graph tracing is activated, as it needs to keep track of which functions it uses. I have a new way that wont take as much memory, but it's not ready yet for this merge window, and will have to wait for the next one. Another big change was the removal of the ftrace_start/stop() calls that were used by the suspend/resume code that stopped function tracing when entering into suspend and resume paths. The stop of ftrace was done because there was some function that would crash the system if one called smp_processor_id()! The stop/start was a big hammer to solve the issue at the time, which was when ftrace was first introduced into Linux. Now ftrace has better infrastructure to debug such issues, and I found the problem function and labeled it with "notrace" and function tracing can now safely be activated all the way down into the guts of suspend and resume Other changes include clean ups of uprobe code, clean up of the trace_seq() code, and other various small fixes and clean ups to ftrace and tracing" * tag 'trace-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (57 commits) ftrace: Add warning if tramp hash does not match nr_trampolines ftrace: Fix trampoline hash update check on rec->flags ring-buffer: Use rb_page_size() instead of open coded head_page size ftrace: Rename ftrace_ops field from trampolines to nr_trampolines tracing: Convert local function_graph functions to static ftrace: Do not copy old hash when resetting tracing: let user specify tracing_thresh after selecting function_graph ring-buffer: Always run per-cpu ring buffer resize with schedule_work_on() tracing: Remove function_trace_stop and HAVE_FUNCTION_TRACE_MCOUNT_TEST s390/ftrace: remove check of obsolete variable function_trace_stop arm64, ftrace: Remove check of obsolete variable function_trace_stop Blackfin: ftrace: Remove check of obsolete variable function_trace_stop metag: ftrace: Remove check of obsolete variable function_trace_stop microblaze: ftrace: Remove check of obsolete variable function_trace_stop MIPS: ftrace: Remove check of obsolete variable function_trace_stop parisc: ftrace: Remove check of obsolete variable function_trace_stop sh: ftrace: Remove check of obsolete variable function_trace_stop sparc64,ftrace: Remove check of obsolete variable function_trace_stop tile: ftrace: Remove check of obsolete variable function_trace_stop ftrace: x86: Remove check of obsolete variable function_trace_stop ...
2014-08-02net: filter: split 'struct sk_filter' into socket and bpf partsAlexei Starovoitov
clean up names related to socket filtering and bpf in the following way: - everything that deals with sockets keeps 'sk_*' prefix - everything that is pure BPF is changed to 'bpf_*' prefix split 'struct sk_filter' into struct sk_filter { atomic_t refcnt; struct rcu_head rcu; struct bpf_prog *prog; }; and struct bpf_prog { u32 jited:1, len:31; struct sock_fprog_kern *orig_prog; unsigned int (*bpf_func)(const struct sk_buff *skb, const struct bpf_insn *filter); union { struct sock_filter insns[0]; struct bpf_insn insnsi[0]; struct work_struct work; }; }; so that 'struct bpf_prog' can be used independent of sockets and cleans up 'unattached' bpf use cases split SK_RUN_FILTER macro into: SK_RUN_FILTER to be used with 'struct sk_filter *' and BPF_PROG_RUN to be used with 'struct bpf_prog *' __sk_filter_release(struct sk_filter *) gains __bpf_prog_release(struct bpf_prog *) helper function also perform related renames for the functions that work with 'struct bpf_prog *', since they're on the same lines: sk_filter_size -> bpf_prog_size sk_filter_select_runtime -> bpf_prog_select_runtime sk_filter_free -> bpf_prog_free sk_unattached_filter_create -> bpf_prog_create sk_unattached_filter_destroy -> bpf_prog_destroy sk_store_orig_filter -> bpf_prog_store_orig_filter sk_release_orig_filter -> bpf_release_orig_filter __sk_migrate_filter -> bpf_migrate_filter __sk_prepare_filter -> bpf_prepare_filter API for attaching classic BPF to a socket stays the same: sk_attach_filter(prog, struct sock *)/sk_detach_filter(struct sock *) and SK_RUN_FILTER(struct sk_filter *, ctx) to execute a program which is used by sockets, tun, af_packet API for 'unattached' BPF programs becomes: bpf_prog_create(struct bpf_prog **)/bpf_prog_destroy(struct bpf_prog *) and BPF_PROG_RUN(struct bpf_prog *, ctx) to execute a program which is used by isdn, ppp, team, seccomp, ptp, xt_bpf, cls_bpf, test_bpf Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-31KVM: s390: rework broken SIGP STOP interrupt handlingDavid Hildenbrand
A VCPU might never stop if it intercepts (for whatever reason) between "fake interrupt delivery" and execution of the stop function. Heart of the problem is that SIGP STOP is an interrupt that has to be processed on every SIE entry until the VCPU finally executes the stop function. This problem was made apparent by commit 7dfc63cf977447e09b1072911c2 (KVM: s390: allow only one SIGP STOP (AND STORE STATUS) at a time). With the old code, the guest could (incorrectly) inject SIGP STOPs multiple times. The bug of losing a sigp stop exists in KVM before 7dfc63cf97, but it was hidden by Linux guests doing a sigp stop loop. The new code (rightfully) returns CC=2 and does not queue a new interrupt. This patch is a simple fix of the problem. Longterm we are going to rework that code - e.g. get rid of the action bits and so on. Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com> Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> [some additional patch description]
2014-07-30KVM: s390: Fix memory leak on busy SIGP stopChristian Borntraeger
commit 7dfc63cf977447e09b1072911c22564f900fc578 (KVM: s390: allow only one SIGP STOP (AND STORE STATUS) at a time) introduced a memory leak if a sigp stop is already pending. Free the allocated inti structure. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Reviewed-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
2014-07-28Merge tag 'v3.16-rc7' into perf/core, to merge in the latest fixes before ↵Ingo Molnar
applying new changes Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-07-23timekeeping: Create struct tk_read_base and use it in struct timekeeperThomas Gleixner
The members of the new struct are the required ones for the new NMI safe accessor to clcok monotonic. In order to reuse the existing timekeeping code and to make the update of the fast NMI safe timekeepers a simple memcpy use the struct for the timekeeper as well and convert all users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: John Stultz <john.stultz@linaro.org>
2014-07-23clocksource: Get rid of cycle_lastThomas Gleixner
cycle_last was added to the clocksource to support the TSC validation. We moved that to the core code, so we can get rid of the extra copy. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org>
2014-07-23ktime: Kill non-scalar ktime_t implementation for 2038John Stultz
The non-scalar ktime_t implementation is basically a timespec which has to be changed to support dates past 2038 on 32bit systems. This patch removes the non-scalar ktime_t implementation, forcing the scalar s64 nanosecond version on all architectures. This may have additional performance overhead on some 32bit systems when converting between ktime_t and timespec structures, however the majority of 32bit systems (arm and i386) were already using scalar ktime_t, so no performance regressions will be seen on those platforms. On affected platforms, I'm open to finding optimizations, including avoiding converting to timespecs where possible. [ tglx: We can now cleanup the ktime_t.tv64 mess, but thats a different issue and we can throw a coccinelle script at it ] Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org>
2014-07-21KVM: s390: add ipte to trace event decodingChristian Borntraeger
IPTE intercept can happen, let's decode that. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com>
2014-07-21KVM: s390: advertise KVM_CAP_S390_IRQCHIPCornelia Huck
We should advertise all capabilities, including those that can be enabled. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Acked-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
2014-07-21KVM: s390: remove the tasklet used by the hrtimerDavid Hildenbrand
We can get rid of the tasklet used for waking up a VCPU in the hrtimer code but wakeup the VCPU directly. Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com> Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
2014-07-21KVM: s390: move vcpu wakeup code to a central pointDavid Hildenbrand
Let's move the vcpu wakeup code to a central point. We should set the vcpu->preempted flag only if the target is actually sleeping and before the real wakeup happens. Otherwise the preempted flag might be set, when not necessary. This may result in immediate reschedules after schedule() in some scenarios. The wakeup code doesn't require the local_int.lock to be held. Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com> Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
2014-07-21KVM: s390: remove _bh locking from start_stop_lockDavid Hildenbrand
The start_stop_lock is no longer acquired when in atomic context, therefore we can convert it into an ordinary spin_lock. Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com> Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
2014-07-21KVM: s390: remove _bh locking from local_int.lockDavid Hildenbrand
local_int.lock is not used in a bottom-half handler anymore, therefore we can turn it into an ordinary spin_lock at all occurrences. Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com> Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
2014-07-21KVM: s390: cleanup handle_wait by reusing kvm_vcpu_blockDavid Hildenbrand
This patch cleans up the code in handle_wait by reusing the common code function kvm_vcpu_block. signal_pending(), kvm_cpu_has_pending_timer() and kvm_arch_vcpu_runnable() are sufficient for checking if we need to wake-up that VCPU. kvm_vcpu_block uses these functions, so no checks are lost. The flag "timer_due" can be removed - kvm_cpu_has_pending_timer() tests whether the timer is pending, thus the vcpu is correctly woken up. Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com> Acked-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
2014-07-18s390/ftrace: remove check of obsolete variable function_trace_stopHeiko Carstens
Remove check of obsolete variable function_trace_stop as requested by Steven Rostedt. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-07-17arch, locking: Ciao arch_mutex_cpu_relax()Davidlohr Bueso
The arch_mutex_cpu_relax() function, introduced by 34b133f, is hacky and ugly. It was added a few years ago to address the fact that common cpu_relax() calls include yielding on s390, and thus impact the optimistic spinning functionality of mutexes. Nowadays we use this function well beyond mutexes: rwsem, qrwlock, mcs and lockref. Since the macro that defines the call is in the mutex header, any users must include mutex.h and the naming is misleading as well. This patch (i) renames the call to cpu_relax_lowlatency ("relax, but only if you can do it with very low latency") and (ii) defines it in each arch's asm/processor.h local header, just like for regular cpu_relax functions. On all archs, except s390, cpu_relax_lowlatency is simply cpu_relax, and thus we can take it out of mutex.h. While this can seem redundant, I believe it is a good choice as it allows us to move out arch specific logic from generic locking primitives and enables future(?) archs to transparently define it, similarly to System Z. Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Anton Blanchard <anton@samba.org> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Bharat Bhushan <r65777@freescale.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Chris Zankel <chris@zankel.net> Cc: David Howells <dhowells@redhat.com> Cc: David S. Miller <davem@davemloft.net> Cc: Deepthi Dharwar <deepthi@linux.vnet.ibm.com> Cc: Dominik Dingel <dingel@linux.vnet.ibm.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Helge Deller <deller@gmx.de> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jason Wang <jasowang@redhat.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Joe Perches <joe@perches.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: Joseph Myers <joseph@codesourcery.com> Cc: Kees Cook <keescook@chromium.org> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Michael Neuling <mikey@neuling.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Mikael Starvik <starvik@axis.com> Cc: Nicolas Pitre <nico@linaro.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Paul Burton <paul.burton@imgtec.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Qais Yousef <qais.yousef@imgtec.com> Cc: Qiaowei Ren <qiaowei.ren@intel.com> Cc: Rafael Wysocki <rafael.j.wysocki@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Steven Miao <realmz6@gmail.com> Cc: Steven Rostedt <srostedt@redhat.com> Cc: Stratos Karafotis <stratosk@semaphore.gr> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Vasily Kulikov <segoon@openwall.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com> Cc: Waiman Long <Waiman.Long@hp.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Wolfram Sang <wsa@the-dreams.de> Cc: adi-buildroot-devel@lists.sourceforge.net Cc: linux390@de.ibm.com Cc: linux-alpha@vger.kernel.org Cc: linux-am33-list@redhat.com Cc: linux-arm-kernel@lists.infradead.org Cc: linux-c6x-dev@linux-c6x.org Cc: linux-cris-kernel@axis.com Cc: linux-hexagon@vger.kernel.org Cc: linux-ia64@vger.kernel.org Cc: linux@lists.openrisc.net Cc: linux-m32r-ja@ml.linux-m32r.org Cc: linux-m32r@ml.linux-m32r.org Cc: linux-m68k@lists.linux-m68k.org Cc: linux-metag@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linux-parisc@vger.kernel.org Cc: linuxppc-dev@lists.ozlabs.org Cc: linux-s390@vger.kernel.org Cc: linux-sh@vger.kernel.org Cc: linux-xtensa@linux-xtensa.org Cc: sparclinux@vger.kernel.org Link: http://lkml.kernel.org/r/1404079773.2619.4.camel@buesod1.americas.hpqcorp.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-07-16perf kvm: Add stat support on s390Alexander Yarygin
On s390, the vmexit event has a tree-like structure: between exit_event_begin and exit_event_end several other events may happen and with each of them refining the previous ones. This patch adds a decoder for such events to the generic code and also the files <asm/kvm_perf.h> and kvm-stat.c for s390. Commands 'perf kvm stat record', 'report' and 'live' are supported. Reviewed-by: David Ahern <dsahern@gmail.com> Signed-off-by: Alexander Yarygin <yarygin@linux.vnet.ibm.com> Acked-by: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1404397747-20939-5-git-send-email-yarygin@linux.vnet.ibm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-07-16s390: fix restore of invalid floating-point-controlMartin Schwidefsky
The fixup of the inline assembly to restore the floating-point-control register needs to check for instruction address *after* the lfcp instruction as the specification and data exceptions are suppresssing. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-07-16s390/ptrace: fix PSW mask checkMartin Schwidefsky
The PSW mask check of the PTRACE_POKEUSR_AREA command is incorrect. The PSW_MASK_USER define contains the PSW_MASK_ASC bits, the ptrace interface accepts all combinations for the address-space-control bits. To protect the kernel space the PSW mask check in ptrace needs to reject the address-space-control bit combination for home space. Fixes CVE-2014-3534 Cc: stable@vger.kernel.org Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-07-16s390/MSI: Use standard mask and unmask funtionsYijing Wang
MSI irqchip in s390 has its own mask and unmask MSI irq functions, zpci_enable_irq() and zpci_disable_irq(). They mask and unmask MSI irq in standard ways, no arch special. MSI driver provides two global standard functions mask_msi_irq() and unmask_msi_irq(). Local zpci_enable_irq() and zpci_disable_irq() are almost the same as the standard two. the difference is local mask/unmask functions read the mask status before mask and unmask everytime. Then change the value and rewrite to hardware. In standard functions, save the mask status after mask and unmask msi irq, and use the cached status to change the mask status. When we mask or unmask a MSI irq, we always cache its mask status except we know need not to cache it, like in pci_msi_shutdown. So use the standard functions to replace the local is safe. Signed-off-by: Yijing Wang <wangyijing@huawei.com> [sebott: fixed inverted function pointers] Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-07-16s390: require mvcos facility, not tod clock steering facilityDavid Hildenbrand
Inlined uaccess functions require the mvcos facility (bit 27), not the tod clock steering facility (bit 28) for z10 and newer machines. Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-07-10KVM: s390: implement KVM_(S|G)ET_MP_STATE for user space state controlDavid Hildenbrand
This patch - adds s390 specific MP states to linux headers and documents them - implements the KVM_{SET,GET}_MP_STATE ioctls - enables KVM_CAP_MP_STATE - allows user space to control the VCPU state on s390. If user space sets the VCPU state using the ioctl KVM_SET_MP_STATE, we can disable manual changing of the VCPU state and trust user space to do the right thing. Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com> Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com> Acked-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
2014-07-10KVM: s390: remove __cpu_is_stopped and expose is_vcpu_stoppedDavid Hildenbrand
The function "__cpu_is_stopped" is not used any more. Let's remove it and expose the function "is_vcpu_stopped" instead, which is actually what we want. This patch also converts an open coded check for CPUSTAT_STOPPED to is_vcpu_stopped(). Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com> Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com> Acked-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
2014-07-10KVM: s390: move finalization of SIGP STOP orders to kvm_s390_vcpu_stopDavid Hildenbrand
Let's move the finalization of SIGP STOP and SIGP STOP AND STORE STATUS orders to the point where the VCPU is actually stopped. This change is needed to prepare for a user space driven VCPU state change. The action_bits may only be cleared when setting the cpu state to STOPPED while holding the local irq lock. Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com> Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com> Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
2014-07-10KVM: s390: allow only one SIGP STOP (AND STORE STATUS) at a timeDavid Hildenbrand
A SIGP STOP (AND STORE STATUS) order is complete as soon as the VCPU has been stopped. This patch makes sure that only one SIGP STOP (AND STORE STATUS) may be pending at a time (as defined by the architecture). If the action_bits are still set, a SIGP STOP has been issued but not completed yet. The VCPU is busy for further SIGP STOP orders. Also set the CPUSTAT_STOP_INT after the action_bits variable has been modified (the same order that is used when injecting a KVM_S390_SIGP_STOP from userspace). Both changes are needed in preparation for a user space driven VCPU state change (to avoid race conditions). Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com> Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com> Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
2014-07-01Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM fixes from Paolo Bonzini: "A bunch of one-liners (except the s390 one). The two more serious bugs ("KVM: SVM: Fix CPL export via SS.DPL" and "KVM: s390: add sie.h uapi header file to Kbuild and remove header dependency") were introduced in the 3.16 merge window" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: SVM: Fix CPL export via SS.DPL KVM: s390: add sie.h uapi header file to Kbuild and remove header dependency MIPS: KVM: Fix memory leak on VCPU KVM: x86: preserve the high 32-bits of the PAT register kvm: fix wrong address when writing Hyper-V tsc page KVM: x86: Increase the number of fixed MTRR regs to 10
2014-06-30Merge tag 'kvms390-20140626' of ↵Paolo Bonzini
git://git.kernel.org/pub/scm/linux/kernel/git/kvms390/linux into HEAD Fix sie.h header related problems introduced during the 3.16 development cycle.
2014-06-27Merge tag 'kvms390-20140626' of ↵Paolo Bonzini
git://git.kernel.org/pub/scm/linux/kernel/git/kvms390/linux into kvm-master Fix sie.h header related problems introduced during the 3.16 development cycle.
2014-06-26KVM: s390: add sie.h uapi header file to Kbuild and remove header dependencyHeiko Carstens
sie.h was missing in arch/s390/include/uapi/asm/Kbuild and therefore missed the "make headers_check" target. If added it reveals that also arch/s390/include/asm/sigp.h would become uapi. This is something we certainly do not want. So remove that dependency as well. The header file was merged with ceae283bb2e0176c "KVM: s390: add sie exit reasons tables", therefore we never had a kernel release with this commit and can still change anything. Acked-by: Alexander Yarygin <yarygin@linux.vnet.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
2014-06-25Merge branch 'perf/urgent' into perf/core, to pick up fixes and refresh the ↵Ingo Molnar
branch Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 patches from Martin Schwidefsky: "A couple of bug fixes, a debug change for qdio, an update for the default config, and one small extension. The watchdog module based on diagnose 0x288 is converted to the watchdog API and it now works under LPAR as well" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/ccwgroup: use ccwgroup_ungroup wrapper s390/ccwgroup: fix an uninitialized return code s390/ccwgroup: obtain extra reference for asynchronous processing qdio: Keep device-specific dbf entries s390/compat: correct ucontext layout for high gprs s390/cio: set device name as early as possible s390: update default configuration s390: avoid format strings leaking into names s390/airq: silence lockdep warning s390/watchdog: add support for LPAR operation (diag288) s390/watchdog: use watchdog API s390/sclp_vt220: Enable ASCII console per default s390/qdio: replace shift loop by ilog2 s390/cio: silence lockdep warning s390/uaccess: always load the kernel ASCE after task switch s390/ap_bus: Make modules parameters visible in sysfs
2014-06-19s390, perf: Use common PMU interrupt disabled codeVince Weaver
Transition to using the new generic PERF_PMU_CAP_NO_INTERRUPT method for failing a sampling event when no PMU interrupt is available. Signed-off-by: Vince Weaver <vincent.weaver@maine.edu> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Thomas Huth <thuth@linux.vnet.ibm.com> Cc: linux390@de.ibm.com Cc: linux-s390@vger.kernel.org Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1406150204290.16738@vincent-weaver-1.umelst.maine.edu Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-16s390/compat: correct ucontext layout for high gprsMartin Schwidefsky
The uc_sigmask definition in the kernel differs from the one in the glibc, the kernel uc_sigmask has 64 bits while the glibc verison is 1024 bits. The extension of the ucontext structure for 64-bit register support for 31-bit compat processes added a new field uc_gprs_high which starts 8 bytes after the uc_sigmask field. As the glibc view of the ucontext assumes a size of 128 bytes for uc_sigmask add a 120 byte padding to the kernel structure ucontext_extended after the 8 byte uc_sigmask. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-06-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) Seccomp BPF filters can now be JIT'd, from Alexei Starovoitov. 2) Multiqueue support in xen-netback and xen-netfront, from Andrew J Benniston. 3) Allow tweaking of aggregation settings in cdc_ncm driver, from Bjørn Mork. 4) BPF now has a "random" opcode, from Chema Gonzalez. 5) Add more BPF documentation and improve test framework, from Daniel Borkmann. 6) Support TCP fastopen over ipv6, from Daniel Lee. 7) Add software TSO helper functions and use them to support software TSO in mvneta and mv643xx_eth drivers. From Ezequiel Garcia. 8) Support software TSO in fec driver too, from Nimrod Andy. 9) Add Broadcom SYSTEMPORT driver, from Florian Fainelli. 10) Handle broadcasts more gracefully over macvlan when there are large numbers of interfaces configured, from Herbert Xu. 11) Allow more control over fwmark used for non-socket based responses, from Lorenzo Colitti. 12) Do TCP congestion window limiting based upon measurements, from Neal Cardwell. 13) Support busy polling in SCTP, from Neal Horman. 14) Allow RSS key to be configured via ethtool, from Venkata Duvvuru. 15) Bridge promisc mode handling improvements from Vlad Yasevich. 16) Don't use inetpeer entries to implement ID generation any more, it performs poorly, from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1522 commits) rtnetlink: fix userspace API breakage for iproute2 < v3.9.0 tcp: fixing TLP's FIN recovery net: fec: Add software TSO support net: fec: Add Scatter/gather support net: fec: Increase buffer descriptor entry number net: fec: Factorize feature setting net: fec: Enable IP header hardware checksum net: fec: Factorize the .xmit transmit function bridge: fix compile error when compiling without IPv6 support bridge: fix smatch warning / potential null pointer dereference via-rhine: fix full-duplex with autoneg disable bnx2x: Enlarge the dorq threshold for VFs bnx2x: Check for UNDI in uncommon branch bnx2x: Fix 1G-baseT link bnx2x: Fix link for KR with swapped polarity lane sctp: Fix sk_ack_backlog wrap-around problem net/core: Add VF link state control policy net/fsl: xgmac_mdio is dependent on OF_MDIO net/fsl: Make xgmac_mdio read error message useful net_sched: drr: warn when qdisc is not work conserving ...
2014-06-11s390: update default configurationHeiko Carstens
2014-06-10s390/watchdog: use watchdog APIPhilipp Hachtmann
Converted the vmwatchdog driver to use the kernel's watchdog API. Signed-off-by: Philipp Hachtmann <phacht@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-06-10s390/uaccess: always load the kernel ASCE after task switchMartin Schwidefsky
This patch fixes a problem introduced with git commit beef560b4cdfafb2 "s390/uaccess: simplify control register updates". The switch_mm function is not called if the next process is a kernel thread without an attached mm or is a nop if the mm does not change. But CR1 still needs to be loaded with the kernel ASCE in case the code returns to a uaccess function that uses the secondary space mode. In addition move the set_fs call from finish_arch_switch to finish_arch_post_lock_switch and then remove finish_arch_switch. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-06-04Merge branch 'akpm' (patchbomb from Andrew) into nextLinus Torvalds
Merge misc updates from Andrew Morton: - a few fixes for 3.16. Cc'ed to stable so they'll get there somehow. - various misc fixes and cleanups - most of the ocfs2 queue. Review is slow... - most of MM. The MM queue is pretty huge this time, but not much in the way of feature work. - some tweaks under kernel/ - printk maintenance work - updates to lib/ - checkpatch updates - tweaks to init/ * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (276 commits) fs/autofs4/dev-ioctl.c: add __init to autofs_dev_ioctl_init fs/ncpfs/getopt.c: replace simple_strtoul by kstrtoul init/main.c: remove an ifdef kthreads: kill CLONE_KERNEL, change kernel_thread(kernel_init) to avoid CLONE_SIGHAND init/main.c: add initcall_blacklist kernel parameter init/main.c: don't use pr_debug() fs/binfmt_flat.c: make old_reloc() static fs/binfmt_elf.c: fix bool assignements fs/efs: convert printk(KERN_DEBUG to pr_debug fs/efs: add pr_fmt / use __func__ fs/efs: convert printk to pr_foo() scripts/checkpatch.pl: device_initcall is not the only __initcall substitute checkpatch: check stable email address checkpatch: warn on unnecessary void function return statements checkpatch: prefer kstrto<foo> to sscanf(buf, "%<lhuidx>", &bar); checkpatch: add warning for kmalloc/kzalloc with multiply checkpatch: warn on #defines ending in semicolon checkpatch: make --strict a default for files in drivers/net and net/ checkpatch: always warn on missing blank line after variable declaration block checkpatch: fix wildcard DT compatible string checking ...
2014-06-04hugetlb: restrict hugepage_migration_support() to x86_64Naoya Horiguchi
Currently hugepage migration is available for all archs which support pmd-level hugepage, but testing is done only for x86_64 and there're bugs for other archs. So to avoid breaking such archs, this patch limits the availability strictly to x86_64 until developers of other archs get interested in enabling this feature. Simply disabling hugepage migration on non-x86_64 archs is not enough to fix the reported problem where sys_move_pages() hits the BUG_ON() in follow_page(FOLL_GET), so let's fix this by checking if hugepage migration is supported in vma_migratable(). Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reported-by: Michael Ellerman <mpe@ellerman.id.au> Tested-by: Michael Ellerman <mpe@ellerman.id.au> Acked-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Cc: <stable@vger.kernel.org> [3.12+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next Pull core irq updates from Thomas Gleixner: "The irq department delivers: - Another tree wide update to get rid of the horrible create_irq interface along with its even more horrible variants. That also gets rid of the last leftovers of the initial sparse irq hackery. arch/driver specific changes have been either acked or ignored. - A fix for the spurious interrupt detection logic with threaded interrupts. - A new ARM SoC interrupt controller - The usual pile of fixes and improvements all over the place" * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits) Documentation: brcmstb-l2: Add Broadcom STB Level-2 interrupt controller binding irqchip: brcmstb-l2: Add Broadcom Set Top Box Level-2 interrupt controller genirq: Improve documentation to match current implementation ARM: iop13xx: fix msi support with sparse IRQ genirq: Provide !SMP stub for irq_set_affinity_notifier() irqchip: armada-370-xp: Move the devicetree binding documentation irqchip: gic: Use mask field in GICC_IAR genirq: Remove dynamic_irq mess ia64: Use irq_init_desc genirq: Replace dynamic_irq_init/cleanup genirq: Remove irq_reserve_irq[s] genirq: Replace reserve_irqs in core code s390: Avoid call to irq_reserve_irqs() s390: Remove pointless arch_show_interrupts() s390: pci: Check return value of alloc_irq_desc() proper sh: intc: Remove pointless irq_reserve_irqs() invocation x86, irq: Remove pointless irq_reserve_irqs() call genirq: Make create/destroy_irq() ia64 private tile: Use SPARSE_IRQ tile: pci: Use irq_alloc/free_hwirq() ...
2014-06-04Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm into nextLinus Torvalds
Pull KVM updates from Paolo Bonzini: "At over 200 commits, covering almost all supported architectures, this was a pretty active cycle for KVM. Changes include: - a lot of s390 changes: optimizations, support for migration, GDB support and more - ARM changes are pretty small: support for the PSCI 0.2 hypercall interface on both the guest and the host (the latter acked by Catalin) - initial POWER8 and little-endian host support - support for running u-boot on embedded POWER targets - pretty large changes to MIPS too, completing the userspace interface and improving the handling of virtualized timer hardware - for x86, a larger set of changes is scheduled for 3.17. Still, we have a few emulator bugfixes and support for running nested fully-virtualized Xen guests (para-virtualized Xen guests have always worked). And some optimizations too. The only missing architecture here is ia64. It's not a coincidence that support for KVM on ia64 is scheduled for removal in 3.17" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (203 commits) KVM: add missing cleanup_srcu_struct KVM: PPC: Book3S PR: Rework SLB switching code KVM: PPC: Book3S PR: Use SLB entry 0 KVM: PPC: Book3S HV: Fix machine check delivery to guest KVM: PPC: Book3S HV: Work around POWER8 performance monitor bugs KVM: PPC: Book3S HV: Make sure we don't miss dirty pages KVM: PPC: Book3S HV: Fix dirty map for hugepages KVM: PPC: Book3S HV: Put huge-page HPTEs in rmap chain for base address KVM: PPC: Book3S HV: Fix check for running inside guest in global_invalidates() KVM: PPC: Book3S: Move KVM_REG_PPC_WORT to an unused register number KVM: PPC: Book3S: Add ONE_REG register names that were missed KVM: PPC: Add CAP to indicate hcall fixes KVM: PPC: MPIC: Reset IRQ source private members KVM: PPC: Graciously fail broken LE hypercalls PPC: ePAPR: Fix hypercall on LE guest KVM: PPC: BOOK3S: Remove open coded make_dsisr in alignment handler KVM: PPC: BOOK3S: Always use the saved DAR value PPC: KVM: Make NX bit available with magic page KVM: PPC: Disable NX for old magic page using guests KVM: PPC: BOOK3S: HV: Add mixed page-size support for guest ...
2014-06-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: include/net/inetpeer.h net/ipv6/output_core.c Changes in net were fixing bugs in code removed in net-next. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-03Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next Pull scheduler updates from Ingo Molnar: "The main scheduling related changes in this cycle were: - various sched/numa updates, for better performance - tree wide cleanup of open coded nice levels - nohz fix related to rq->nr_running use - cpuidle changes and continued consolidation to improve the kernel/sched/idle.c high level idle scheduling logic. As part of this effort I pulled cpuidle driver changes from Rafael as well. - standardized idle polling amongst architectures - continued work on preparing better power/energy aware scheduling - sched/rt updates - misc fixlets and cleanups" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (49 commits) sched/numa: Decay ->wakee_flips instead of zeroing sched/numa: Update migrate_improves/degrades_locality() sched/numa: Allow task switch if load imbalance improves sched/rt: Fix 'struct sched_dl_entity' and dl_task_time() comments, to match the current upstream code sched: Consolidate open coded implementations of nice level frobbing into nice_to_rlimit() and rlimit_to_nice() sched: Initialize rq->age_stamp on processor start sched, nohz: Change rq->nr_running to always use wrappers sched: Fix the rq->next_balance logic in rebalance_domains() and idle_balance() sched: Use clamp() and clamp_val() to make sys_nice() more readable sched: Do not zero sg->cpumask and sg->sgp->power in build_sched_groups() sched/numa: Fix initialization of sched_domain_topology for NUMA sched: Call select_idle_sibling() when not affine_sd sched: Simplify return logic in sched_read_attr() sched: Simplify return logic in sched_copy_attr() sched: Fix exec_start/task_hot on migrated tasks arm64: Remove TIF_POLLING_NRFLAG metag: Remove TIF_POLLING_NRFLAG sched/idle: Make cpuidle_idle_call() void sched/idle: Reflow cpuidle_idle_call() sched/idle: Delay clearing the polling bit ...
2014-06-03Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next Pull core locking updates from Ingo Molnar: "The main changes in this cycle were: - reduced/streamlined smp_mb__*() interface that allows more usecases and makes the existing ones less buggy, especially in rarer architectures - add rwsem implementation comments - bump up lockdep limits" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (33 commits) rwsem: Add comments to explain the meaning of the rwsem's count field lockdep: Increase static allocations arch: Mass conversion of smp_mb__*() arch,doc: Convert smp_mb__*() arch,xtensa: Convert smp_mb__*() arch,x86: Convert smp_mb__*() arch,tile: Convert smp_mb__*() arch,sparc: Convert smp_mb__*() arch,sh: Convert smp_mb__*() arch,score: Convert smp_mb__*() arch,s390: Convert smp_mb__*() arch,powerpc: Convert smp_mb__*() arch,parisc: Convert smp_mb__*() arch,openrisc: Convert smp_mb__*() arch,mn10300: Convert smp_mb__*() arch,mips: Convert smp_mb__*() arch,metag: Convert smp_mb__*() arch,m68k: Convert smp_mb__*() arch,m32r: Convert smp_mb__*() arch,ia64: Convert smp_mb__*() ...
