path: root/arch/s390
2013-07-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 fixes from Martin Schwidefsky: "An update for the BFP jit to the latest and greatest, two patches to get kdump working again, the random-abort ptrace extention for transactional execution, the z90crypt module alias for ap and a tiny cleanup" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/zcrypt: Alias for new zcrypt device driver base module s390/kdump: Allow copy_oldmem_page() copy to virtual memory s390/kdump: Disable mmap for s390 s390/bpf,jit: add pkt_type support s390/bpf,jit: address randomize and write protect jit code s390/bpf,jit: use generic jit dumper s390/bpf,jit: call module_free() from any context s390/qdio: remove unused variable s390/ptrace: PTRACE_TE_ABORT_RAND
2013-07-18s390/kdump: Allow copy_oldmem_page() copy to virtual memoryMichael Holzheu
The kdump mmap patch series (git commit 83086978c63afd7c73e1c) changed the requirements for copy_oldmem_page(). Now this function is used for copying to virtual memory. So implement vmalloc support for the s390 version of copy_oldmem_page(). Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-18s390/bpf,jit: add pkt_type supportHeiko Carstens
s390 version of 3b58908a "x86: bpf_jit_comp: add pkt_type support". Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2013-07-18s390/bpf,jit: address randomize and write protect jit codeHeiko Carstens
This is the s390 variant of 314beb9b "x86: bpf_jit_comp: secure bpf jit against spraying attacks". With this change the whole jit code and literal pool will be write protected after creation. In addition the start address of the jit code won't be always on a page boundary anymore. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-18s390/bpf,jit: use generic jit dumperHeiko Carstens
This is the s390 backend of 79617801 "filter: bpf_jit_comp: refactor and unify BPF JIT image dump output". Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-18s390/bpf,jit: call module_free() from any contextHeiko Carstens
The workqueue workaround is no longer needed. Same as 5199dfe531 "sparc: bpf_jit_comp: can call module_free() from any context". Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-16s390/ptrace: PTRACE_TE_ABORT_RANDMichael Mueller
The patch implements a s390 specific ptrace request PTRACE_TE_ABORT_RAND to modify the randomness of spontaneous aborts of memory transactions of the transaction execution facility. The data argument of the ptrace request is used to specify the levels of randomness, 0 for normal operation, 1 to abort every transaction at a random instruction, and 2 to abort a random transaction at a random instruction. The default is 0 for normal operation. Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Michael Mueller <mimu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-14s390: delete __cpuinit usage from all s390 filesPaul Gortmaker
The __cpuinit type of throwaway sections might have made sense some time ago when RAM was more constrained, but now the savings do not offset the cost and complications. For example, the fix in commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time") is a good example of the nasty type of bugs that can be created with improper use of the various __init prefixes. After a discussion on LKML[1] it was decided that cpuinit should go the way of devinit and be phased out. Once all the users are gone, we can then finally remove the macros themselves from linux/init.h. Note that some harmless section mismatch warnings may result, since notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c) are flagged as __cpuinit -- so if we remove the __cpuinit from arch specific callers, we will also get section mismatch warnings. As an intermediate step, we intend to turn the linux/init.h cpuinit content into no-ops as early as possible, since that will get rid of these warnings. In any case, they are temporary and harmless. This removes all the arch/s390 uses of the __cpuinit macros from all C files. Currently s390 does not have any __CPUINIT used in assembly files. [1] https://lkml.org/lkml/2013/5/20/589 Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: linux390@de.ibm.com Cc: linux-s390@vger.kernel.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2013-07-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Just a bunch of small fixes and tidy ups: 1) Finish the "busy_poll" renames, from Eliezer Tamir. 2) Fix RCU stalls in IFB driver, from Ding Tianhong. 3) Linearize buffers properly in tun/macvtap zerocopy code. 4) Don't crash on rmmod in vxlan, from Pravin B Shelar. 5) Spinlock used before init in alx driver, from Maarten Lankhorst. 6) A sparse warning fix in bnx2x broke TSO checksums, fix from Dmitry Kravkov. 7) Dummy and ifb driver load failure paths can oops, fixes from Tan Xiaojun and Ding Tianhong. 8) Correct MTU calculations in IP tunnels, from Alexander Duyck. 9) Account all TCP retransmits in SNMP stats properly, from Yuchung Cheng. 10) atl1e and via-rhine do not handle DMA mapping failures properly, from Neil Horman. 11) Various equal-cost multipath route fixes in ipv6 from Hannes Frederic Sowa" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (36 commits) ipv6: only static routes qualify for equal cost multipathing via-rhine: fix dma mapping errors atl1e: fix dma mapping warnings tcp: account all retransmit failures usb/net/r815x: fix cast to restricted __le32 usb/net/r8152: fix integer overflow in expression net: access page->private by using page_private net: strict_strtoul is obsolete, use kstrtoul instead drivers/net/ieee802154: don't use devm_pinctrl_get_select_default() in probe drivers/net/ethernet/cadence: don't use devm_pinctrl_get_select_default() in probe drivers/net/can/c_can: don't use devm_pinctrl_get_select_default() in probe net/usb: add relative mii functions for r815x net/tipc: use %*phC to dump small buffers in hex form qlcnic: Adding Maintainers. gre: Fix MTU sizing check for gretap tunnels pkt_sched: sch_qfq: remove forward declaration of qfq_update_agg_ts pkt_sched: sch_qfq: improve efficiency of make_eligible gso: Update tunnel segmentation to support Tx checksum offload inet: fix spacing in assignment ifb: fix oops when loading the ifb failed ...
2013-07-10mm: remove free_area_cacheMichel Lespinasse
Since all architectures have been converted to use vm_unmapped_area(), there is no remaining use for the free_area_cache. Signed-off-by: Michel Lespinasse <walken@google.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Helge Deller <deller@gmx.de> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-10net: rename busy poll socket op and globalsEliezer Tamir
Rename LL_SO to BUSY_POLL_SO Rename sysctl_net_ll_{read,poll} to sysctl_busy_{read,poll} Fix up users of these variables. Fix documentation for sysctl. a patch for the socket.7 man page will follow separately, because of limitations of my mail setup. Signed-off-by: Eliezer Tamir <eliezer.tamir@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "This is a re-do of the net-next pull request for the current merge window. The only difference from the one I made the other day is that this has Eliezer's interface renames and the timeout handling changes made based upon your feedback, as well as a few bug fixes that have trickeled in. Highlights: 1) Low latency device polling, eliminating the cost of interrupt handling and context switches. Allows direct polling of a network device from socket operations, such as recvmsg() and poll(). Currently ixgbe, mlx4, and bnx2x support this feature. Full high level description, performance numbers, and design in commit 0a4db187a999 ("Merge branch 'll_poll'") From Eliezer Tamir. 2) With the routing cache removed, ip_check_mc_rcu() gets exercised more than ever before in the case where we have lots of multicast addresses. Use a hash table instead of a simple linked list, from Eric Dumazet. 3) Add driver for Atheros CQA98xx 802.11ac wireless devices, from Bartosz Markowski, Janusz Dziedzic, Kalle Valo, Marek Kwaczynski, Marek Puzyniak, Michal Kazior, and Sujith Manoharan. 4) Support reporting the TUN device persist flag to userspace, from Pavel Emelyanov. 5) Allow controlling network device VF link state using netlink, from Rony Efraim. 6) Support GRE tunneling in openvswitch, from Pravin B Shelar. 7) Adjust SOCK_MIN_RCVBUF and SOCK_MIN_SNDBUF for modern times, from Daniel Borkmann and Eric Dumazet. 8) Allow controlling of TCP quickack behavior on a per-route basis, from Cong Wang. 9) Several bug fixes and improvements to vxlan from Stephen Hemminger, Pravin B Shelar, and Mike Rapoport. In particular, support receiving on multiple UDP ports. 10) Major cleanups, particular in the area of debugging and cookie lifetime handline, to the SCTP protocol code. From Daniel Borkmann. 11) Allow packets to cross network namespaces when traversing tunnel devices. From Nicolas Dichtel. 12) Allow monitoring netlink traffic via AF_PACKET sockets, in a manner akin to how we monitor real network traffic via ptype_all. From Daniel Borkmann. 13) Several bug fixes and improvements for the new alx device driver, from Johannes Berg. 14) Fix scalability issues in the netem packet scheduler's time queue, by using an rbtree. From Eric Dumazet. 15) Several bug fixes in TCP loss recovery handling, from Yuchung Cheng. 16) Add support for GSO segmentation of MPLS packets, from Simon Horman. 17) Make network notifiers have a real data type for the opaque pointer that's passed into them. Use this to properly handle network device flag changes in arp_netdev_event(). From Jiri Pirko and Timo Teräs. 18) Convert several drivers over to module_pci_driver(), from Peter Huewe. 19) tcp_fixup_rcvbuf() can loop 500 times over loopback, just use a O(1) calculation instead. From Eric Dumazet. 20) Support setting of explicit tunnel peer addresses in ipv6, just like ipv4. From Nicolas Dichtel. 21) Protect x86 BPF JIT against spraying attacks, from Eric Dumazet. 22) Prevent a single high rate flow from overruning an individual cpu during RX packet processing via selective flow shedding. From Willem de Bruijn. 23) Don't use spinlocks in TCP md5 signing fast paths, from Eric Dumazet. 24) Don't just drop GSO packets which are above the TBF scheduler's burst limit, chop them up so they are in-bounds instead. Also from Eric Dumazet. 25) VLAN offloads are missed when configured on top of a bridge, fix from Vlad Yasevich. 26) Support IPV6 in ping sockets. From Lorenzo Colitti. 27) Receive flow steering targets should be updated at poll() time too, from David Majnemer. 28) Fix several corner case regressions in PMTU/redirect handling due to the routing cache removal, from Timo Teräs. 29) We have to be mindful of ipv4 mapped ipv6 sockets in upd_v6_push_pending_frames(). From Hannes Frederic Sowa. 30) Fix L2TP sequence number handling bugs, from James Chapman." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1214 commits) drivers/net: caif: fix wrong rtnl_is_locked() usage drivers/net: enic: release rtnl_lock on error-path vhost-net: fix use-after-free in vhost_net_flush net: mv643xx_eth: do not use port number as platform device id net: sctp: confirm route during forward progress virtio_net: fix race in RX VQ processing virtio: support unlocked queue poll net/cadence/macb: fix bug/typo in extracting gem_irq_read_clear bit Documentation: Fix references to defunct linux-net@vger.kernel.org net/fs: change busy poll time accounting net: rename low latency sockets functions to busy poll bridge: fix some kernel warning in multicast timer sfc: Fix memory leak when discarding scattered packets sit: fix tunnel update via netlink dt:net:stmmac: Add dt specific phy reset callback support. dt:net:stmmac: Add support to dwmac version 3.610 and 3.710 dt:net:stmmac: Allocate platform data only if its NULL. net:stmmac: fix memleak in the open method ipv6: rt6_check_neigh should successfully verify neigh if no NUD information are available net: ipv6: fix wrong ping_v6_sendmsg return value ...
2013-07-04Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc updates from Ben Herrenschmidt: "This is the powerpc changes for the 3.11 merge window. In addition to the usual bug fixes and small updates, the main highlights are: - Support for transparent huge pages by Aneesh Kumar for 64-bit server processors. This allows the use of 16M pages as transparent huge pages on kernels compiled with a 64K base page size. - Base VFIO support for KVM on power by Alexey Kardashevskiy - Wiring up of our nvram to the pstore infrastructure, including putting compressed oopses in there by Aruna Balakrishnaiah - Move, rework and improve our "EEH" (basically PCI error handling and recovery) infrastructure. It is no longer specific to pseries but is now usable by the new "powernv" platform as well (no hypervisor) by Gavin Shan. - I fixed some bugs in our math-emu instruction decoding and made it usable to emulate some optional FP instructions on processors with hard FP that lack them (such as fsqrt on Freescale embedded processors). - Support for Power8 "Event Based Branch" facility by Michael Ellerman. This facility allows what is basically "userspace interrupts" for performance monitor events. - A bunch of Transactional Memory vs. Signals bug fixes and HW breakpoint/watchpoint fixes by Michael Neuling. And more ... I appologize in advance if I've failed to highlight something that somebody deemed worth it." * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (156 commits) pstore: Add hsize argument in write_buf call of pstore_ftrace_call powerpc/fsl: add MPIC timer wakeup support powerpc/mpic: create mpic subsystem object powerpc/mpic: add global timer support powerpc/mpic: add irq_set_wake support powerpc/85xx: enable coreint for all the 64bit boards powerpc/8xx: Erroneous double irq_eoi() on CPM IRQ in MPC8xx powerpc/fsl: Enable CONFIG_E1000E in mpc85xx_smp_defconfig powerpc/mpic: Add get_version API both for internal and external use powerpc: Handle both new style and old style reserve maps powerpc/hw_brk: Fix off by one error when validating DAWR region end powerpc/pseries: Support compression of oops text via pstore powerpc/pseries: Re-organise the oops compression code pstore: Pass header size in the pstore write callback powerpc/powernv: Fix iommu initialization again powerpc/pseries: Inform the hypervisor we are using EBB regs powerpc/perf: Add power8 EBB support powerpc/perf: Core EBB support for 64-bit book3s powerpc/perf: Drop MMCRA from thread_struct powerpc/perf: Don't enable if we have zero events ...
2013-07-03Merge branch 'akpm' (updates from Andrew Morton)Linus Torvalds
Merge first patch-bomb from Andrew Morton: - various misc bits - I'm been patchmonkeying ocfs2 for a while, as Joel and Mark have been distracted. There has been quite a bit of activity. - About half the MM queue - Some backlight bits - Various lib/ updates - checkpatch updates - zillions more little rtc patches - ptrace - signals - exec - procfs - rapidio - nbd - aoe - pps - memstick - tools/testing/selftests updates * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (445 commits) tools/testing/selftests: don't assume the x bit is set on scripts selftests: add .gitignore for kcmp selftests: fix clean target in kcmp Makefile selftests: add .gitignore for vm selftests: add hugetlbfstest self-test: fix make clean selftests: exit 1 on failure kernel/resource.c: remove the unneeded assignment in function __find_resource aio: fix wrong comment in aio_complete() drivers/w1/slaves/w1_ds2408.c: add magic sequence to disable P0 test mode drivers/memstick/host/r592.c: convert to module_pci_driver drivers/memstick/host/jmb38x_ms: convert to module_pci_driver pps-gpio: add device-tree binding and support drivers/pps/clients/pps-gpio.c: convert to module_platform_driver drivers/pps/clients/pps-gpio.c: convert to devm_* helpers drivers/parport/share.c: use kzalloc Documentation/accounting/getdelays.c: avoid strncpy in accounting tool aoe: update internal version number to v83 aoe: update copyright date aoe: perform I/O completions in parallel ...
2013-07-03s390: remove setting for saved_max_pfnZhang Yanfei
The only user of saved_max_pfn in s390 is read_oldmem interface but we have removed that interface, so saved_max_pfn is now unneeded in s390, and we needn't set it anymore. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dave Hansen <dave@sr71.net> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Matt Fleming <matt.fleming@intel.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm/s390: prepare for removing num_physpages and simplify mem_init()Jiang Liu
Prepare for removing num_physpages and simplify mem_init(). Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: concentrate modification of totalram_pages into the mm coreJiang Liu
Concentrate code to modify totalram_pages into the mm core, so the arch memory initialized code doesn't need to take care of it. With these changes applied, only following functions from mm core modify global variable totalram_pages: free_bootmem_late(), free_all_bootmem(), free_all_bootmem_node(), adjust_managed_page_count(). With this patch applied, it will be much more easier for us to keep totalram_pages and zone->managed_pages in consistence. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Acked-by: David Howells <dhowells@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: <sworddragon2@aol.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michel Lespinasse <walken@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: enhance free_reserved_area() to support poisoning memory with zeroJiang Liu
Address more review comments from last round of code review. 1) Enhance free_reserved_area() to support poisoning freed memory with pattern '0'. This could be used to get rid of poison_init_mem() on ARM64. 2) A previous patch has disabled memory poison for initmem on s390 by mistake, so restore to the original behavior. 3) Remove redundant PAGE_ALIGN() when calling free_reserved_area(). Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: <sworddragon2@aol.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michel Lespinasse <walken@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: change signature of free_reserved_area() to fix building warningsJiang Liu
Change signature of free_reserved_area() according to Russell King's suggestion to fix following build warnings: arch/arm/mm/init.c: In function 'mem_init': arch/arm/mm/init.c:603:2: warning: passing argument 1 of 'free_reserved_area' makes integer from pointer without a cast [enabled by default] free_reserved_area(__va(PHYS_PFN_OFFSET), swapper_pg_dir, 0, NULL); ^ In file included from include/linux/mman.h:4:0, from arch/arm/mm/init.c:15: include/linux/mm.h:1301:22: note: expected 'long unsigned int' but argument is of type 'void *' extern unsigned long free_reserved_area(unsigned long start, unsigned long end, mm/page_alloc.c: In function 'free_reserved_area': >> mm/page_alloc.c:5134:3: warning: passing argument 1 of 'virt_to_phys' makes pointer from integer without a cast [enabled by default] In file included from arch/mips/include/asm/page.h:49:0, from include/linux/mmzone.h:20, from include/linux/gfp.h:4, from include/linux/mm.h:8, from mm/page_alloc.c:18: arch/mips/include/asm/io.h:119:29: note: expected 'const volatile void *' but argument is of type 'long unsigned int' mm/page_alloc.c: In function 'free_area_init_nodes': mm/page_alloc.c:5030:34: warning: array subscript is below array bounds [-Warray-bounds] Also address some minor code review comments. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Reported-by: Arnd Bergmann <arnd@arndb.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: <sworddragon2@aol.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michel Lespinasse <walken@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/freescale/fec_main.c drivers/net/ethernet/renesas/sh_eth.c net/ipv4/gre.c The GRE conflict is between a bug fix (kfree_skb --> kfree_skb_list) and the splitting of the gre.c code into seperate files. The FEC conflict was two sets of changes adding ethtool support code in an "!CONFIG_M5272" CPP protected block. Finally the sh_eth.c conflict was between one commit add bits set in the .eesr_err_check mask whilst another commit removed the .tx_error_check member and assignments. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-03Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM fixes from Paolo Bonzini: "On the x86 side, there are some optimizations and documentation updates. The big ARM/KVM change for 3.11, support for AArch64, will come through Catalin Marinas's tree. s390 and PPC have misc cleanups and bugfixes" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (87 commits) KVM: PPC: Ignore PIR writes KVM: PPC: Book3S PR: Invalidate SLB entries properly KVM: PPC: Book3S PR: Allow guest to use 1TB segments KVM: PPC: Book3S PR: Don't keep scanning HPTEG after we find a match KVM: PPC: Book3S PR: Fix invalidation of SLB entry 0 on guest entry KVM: PPC: Book3S PR: Fix proto-VSID calculations KVM: PPC: Guard doorbell exception with CONFIG_PPC_DOORBELL KVM: Fix RTC interrupt coalescing tracking kvm: Add a tracepoint write_tsc_offset KVM: MMU: Inform users of mmio generation wraparound KVM: MMU: document fast invalidate all mmio sptes KVM: MMU: document fast invalidate all pages KVM: MMU: document fast page fault KVM: MMU: document mmio page fault KVM: MMU: document write_flooding_count KVM: MMU: document clear_spte_count KVM: MMU: drop kvm_mmu_zap_mmio_sptes KVM: MMU: init kvm generation close to mmio wrap-around value KVM: MMU: add tracepoint for check_mmio_spte KVM: MMU: fast invalidate all mmio sptes ...
2013-07-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 updates from Martin Schwidefsky: "This is the bulk of the s390 patches for the 3.11 merge window. Notable enhancements are: the block timeout patches for dasd from Hannes, and more work on the PCI support front. In addition some cleanup and the usual bug fixing." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (42 commits) s390/dasd: Fail all requests when DASD_FLAG_ABORTIO is set s390/dasd: Add 'timeout' attribute block: check for timeout function in blk_rq_timed_out() block/dasd: detailed I/O errors s390/dasd: Reduce amount of messages for specific errors s390/dasd: Implement block timeout handling s390/dasd: process all requests in the device tasklet s390/dasd: make number of retries configurable s390/dasd: Clarify comment s390/hwsampler: Updated misleading member names in hws_data_entry s390/appldata_net_sum: do not use static data s390/appldata_mem: do not use static data s390/vmwatchdog: do not use static data s390/airq: simplify adapter interrupt code s390/pci: remove per device debug attribute s390/dma: remove gratuitous brackets s390/facility: decompose test_facility() s390/sclp: remove duplicated include from sclp_ctl.c s390/irq: store interrupt information in pt_regs s390/drivers: Cocci spatch "ptr_ret.spatch" ...
2013-07-02Merge tag 'driver-core-3.11-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg KH: "Here's the big driver core merge for 3.11-rc1 Lots of little things, and larger firmware subsystem updates, all described in the shortlog. Nice thing here is that we finally get rid of CONFIG_HOTPLUG, after 10+ years, thanks to Stephen Rohtwell (it had been always on for a number of kernel releases, now it's just removed)" * tag 'driver-core-3.11-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (27 commits) driver core: device.h: fix doc compilation warnings firmware loader: fix another compile warning with PM_SLEEP unset build some drivers only when compile-testing firmware loader: fix compile warning with PM_SLEEP set kobject: sanitize argument for format string sysfs_notify is only possible on file attributes firmware loader: simplify holding module for request_firmware firmware loader: don't export cache_firmware and uncache_firmware drivers/base: Use attribute groups to create sysfs memory files firmware loader: fix compile warning firmware loader: fix build failure with !CONFIG_FW_LOADER_USER_HELPER Documentation: Updated broken link in HOWTO Finally eradicate CONFIG_HOTPLUG driver core: firmware loader: kill FW_ACTION_NOHOTPLUG requests before suspend driver core: firmware loader: don't cache FW_ACTION_NOHOTPLUG firmware Documentation: Tidy up some drivers/base/core.c kerneldoc content. platform_device: use a macro instead of platform_driver_register firmware: move EXPORT_SYMBOL annotations firmware: Avoid deadlock of usermodehelper lock at shutdown dell_rbu: Select CONFIG_FW_LOADER_USER_HELPER explicitly ...
2013-07-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS patches (part 1) from Al Viro: "The major change in this pile is ->readdir() replacement with ->iterate(), dealing with ->f_pos races in ->readdir() instances for good. There's a lot more, but I'd prefer to split the pull request into several stages and this is the first obvious cutoff point." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (67 commits) [readdir] constify ->actor [readdir] ->readdir() is gone [readdir] convert ecryptfs [readdir] convert coda [readdir] convert ocfs2 [readdir] convert fatfs [readdir] convert xfs [readdir] convert btrfs [readdir] convert hostfs [readdir] convert afs [readdir] convert ncpfs [readdir] convert hfsplus [readdir] convert hfs [readdir] convert befs [readdir] convert cifs [readdir] convert freevxfs [readdir] convert fuse [readdir] convert hpfs reiserfs: switch reiserfs_readdir_dentry to inode reiserfs: is_privroot_deh() needs only directory inode, actually ...
2013-07-01s390/dasd: Fail all requests when DASD_FLAG_ABORTIO is setHannes Reinecke
Whenever a DASD request encounters a timeout we might need to abort all outstanding requests on this or even other devices. This is especially useful if one wants to fail all devices on one side of a RAID10 configuration, even though only one device exhibited an error. To handle this I've introduced a new device flag DASD_FLAG_ABORTIO. This flag is evaluated in __dasd_process_request_queue() and will invoke blk_abort_request() for all outstanding requests with DASD_CQR_FLAGS_FAILFAST set. This will cause any of these requests to be aborted immediately if the blk_timeout function is activated. The DASD_FLAG_ABORTIO is also evaluated in __dasd_process_request_queue to abort all new request which would have the DASD_CQR_FLAGS_FAILFAST bit set. The flag can be set with the new ioctls 'BIODASDABORTIO' and removed with 'BIODASDALLOWIO'. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-01s390/hwsampler: Updated misleading member names in hws_data_entryHendrik Brueckner
There is a misleading naming of the program parameter fields, so correct them according to their names as outlined in "The Load-Program-Parameter and the CPU-measurement Facilities" (SA23-2260-03). Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-01Merge tag 'v3.10' into nextBenjamin Herrenschmidt
Merge 3.10 in order to get some of the last minute powerpc changes, resolve conflicts and add additional fixes on top of them.
2013-06-29consolidate io_remap_pfn_range definitionsAl Viro
2013-06-26s390/appldata_net_sum: do not use static dataSebastian Ott
Using static data for fields which are accessed by HW will fail if the driver is build as a module (since this would be vmalloc'ed memory). This Bug was revealed via "s390: remove virt_to_phys implementation" - the old virt_to_phys implementation would have translated the address but it was not guaranteed that the memory was contiguous. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Reviewed-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/appldata_mem: do not use static dataSebastian Ott
2013-06-26s390/airq: simplify adapter interrupt codeMartin Schwidefsky
There are three users of adapter interrupts: AP, QDIO and PCI. Each registers a single adapter interrupt with independent ISCs. Define a "struct airq" with the interrupt handler, a pointer and a mask for the local summary indicator and the ISC for the adapter interrupt source. Convert the indicator array with its fixed number of adapter interrupt sources per ISE to an array of hlists. This removes the limitation to 32 adapter interrupts per ISC and allows for arbitrary memory locations for the local summary indicator. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/pci: remove per device debug attributeMartin Schwidefsky
The per-pci-device 'debug' attribute is ill defined. For each device it prints the same information, the adapter interrupt bit vector for irq numbers 0 & 1, the start of the global interrupt summary vector and the global irq retries counter. Just remove the attribute and the associated code. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/dma: remove gratuitous bracketsSebastian Ott
Remove gratuitous brackets in dma_mapping_error. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/facility: decompose test_facility()Michael Mueller
The patch decomposes the function test_facility() into its API test_facility() and its implementation __test_facility(). This allows to reuse the implementation with a different API. Patch is used to prepare checkin of SIE satellite code. Signed-off-by: Michael Mueller <mimu@linux.vnet.ibm.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Acked-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/irq: store interrupt information in pt_regsMartin Schwidefsky
Copy the interrupt parameters from the lowcore to the pt_regs structure in entry[64].S and reduce the arguments of the low level interrupt handler to the pt_regs pointer only. In addition move the test-pending-interrupt loop from do_IRQ to entry[64].S to make sure that interrupt information is always delivered via pt_regs. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/hypfs: Cocci spatch "ptr_ret.spatch"Thomas Meyer
Signed-off-by: Thomas Meyer <thomas@m3y3r.de> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/sclp: Add SCLP character device driverMichael Holzheu
Add a character misc device "sclp_ctl" that allows to run SCCBs from user space using the SCLP_CTL_SCCB ioctl. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/cio: Introduce on-close CHSC IOCTLsMichael Holzheu
Introduce two new ioctls CHSC_ON_CLOSE_SET and CHSC_ON_CLOSE_REMOVE that allow to add and remove one CHSC that is unconditionally executed when the CHSC device node is closed. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/cio: Introduce generic synchronous CHSC IOCTLMichael Holzheu
This patch adds a new ioctl CHSC_START_SYNC that allows to execute any synchronous CHSC that is provided by user space. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/pci: sysfs remove strlenSebastian Ott
Get rid of the strlen calls, use the return value of sprintf instead. Reviewed-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/pci: remove pdev during unplugSebastian Ott
The disable slot implementation on s390 currently just detaches the pci function from the partition - without informing the pci layer. Fix this by calling pci_stop_and_remove_bus_device prior to the operation. Reviewed-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/pci: cleanup hotplug codeSebastian Ott
Provide wrappers for the [de]configure operations, add some error handling, and use pci_scan_slot instead of pci_scan_single_device. Reviewed-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/pci: implement pcibios_release_deviceSebastian Ott
Use pcibios_release_device to implement architecture-specific functionality when a pci device is released. This function will be called during pci_release_dev. Reviewed-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/kvm: Provide function for setting the guest storage keyChristian Borntraeger
From time to time we need to set the guest storage key. Lets provide a helper function that handles the changes with all the right locking and checking. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390: remove virt_to_phys implementationSebastian Ott
virt_to_phys on s390 currently uses the LRA instruction to translate virtual to physical addresses. This creates an unnecessary overhead and caused trouble with dma debugging code (when called with an address pointing to a already unmapped page). Just get rid of s390's implementation and use the one from asm-generic/io.h . Note: with this change virt_to_phys will no longer work on vmalloc'ed addresses. Reviewed-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/smp: get rid of generic_smp_call_function_interruptHeiko Carstens
Since 9a46ad6d6 "smp: make smp_call_function_many() use logic similar to smp_call_function_single()" generic_smp_call_function_interrupt() is only an alias to generic_smp_call_function_single_interrupt(). So remove the superfluous variant. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-26s390/pci: use to_pci_devSebastian Ott
Use the to_pci_dev macro to fetch a pci_dev from a struct device pointer. Reviewed-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-24s390/ipl: Fix FCP WWPN and LUN format strings for readMichael Holzheu
The following git commit changed the behavior of sscanf: commit 53809751ac230a3611b5cdd375f3389f3207d471 Author: Jan Beulich <JBeulich@suse.com> Date: Mon Dec 17 16:01:31 2012 -0800 sscanf: don't ignore field widths for numeric conversions This broke the WWPN and LUN sysfs attributes for s390 reipl and dump on panic. Example: $ echo 0x0123456701234567 > /sys/firmware/reipl/fcp/wwpn $ cat /sys/firmware/reipl/fcp/wwpn 0x0001234567012345 So fix this and use format strings that work also with the new sscanf implementation: $ echo 0x012345670123456789 > /sys/firmware/reipl/fcp/wwpn $ cat /sys/firmware/reipl/fcp/wwpn 0x0123456701234567 Cc: stable@vger.kernel.org # 3.8+ Reviewed-by: Steffen Maier <maier@linux.vnet.ibm.com> Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-06-20KVM: s390: Fixed priority of execution in STSIThomas Huth
Added some missing validity checks for the operands and fixed the priority of exceptions for some function codes according to the "Principles of Operation" document. Signed-off-by: Thomas Huth <thuth@linux.vnet.ibm.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-06-20KVM: s390: Reworked LCTL and LCTLG instructionsThomas Huth
LCTL and LCTLG are also privileged instructions, thus there is no need for treating them separately from the other instructions in priv.c. So this patch moves these two instructions to priv.c, adds a check for supervisor state and simplifies the "handle_eb" instruction decoding by merging the two eb_handlers jump tables from intercept.c and priv.c into one table only. Signed-off-by: Thomas Huth <thuth@linux.vnet.ibm.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
