Merge misc updates from Andrew Morton:
- a few hotfixes
- various misc updates
- ocfs2 updates
- most of MM
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (108 commits)
mm, memory_hotplug: move movable_node to the hotplug proper
mm, memory_hotplug: drop CONFIG_MOVABLE_NODE
mm, memory_hotplug: drop artificial restriction on online/offline
mm: memcontrol: account slab stats per lruvec
mm: memcontrol: per-lruvec stats infrastructure
mm: memcontrol: use generic mod_memcg_page_state for kmem pages
mm: memcontrol: use the node-native slab memory counters
mm: vmstat: move slab statistics from zone to node counters
mm/zswap.c: delete an error message for a failed memory allocation in zswap_dstmem_prepare()
mm/zswap.c: improve a size determination in zswap_frontswap_init()
mm/zswap.c: delete an error message for a failed memory allocation in zswap_pool_create()
mm/swapfile.c: sort swap entries before free
mm/oom_kill: count global and memory cgroup oom kills
mm: per-cgroup memory reclaim stats
mm: kmemleak: treat vm_struct as alternative reference to vmalloc'ed objects
mm: kmemleak: factor object reference updating out of scan_block()
mm: kmemleak: slightly reduce the size of some structures on 64-bit architectures
mm, mempolicy: don't check cpuset seqlock where it doesn't matter
mm, cpuset: always use seqlock when changing task's nodemask
mm, mempolicy: simplify rebinding mempolicies when updating cpusets
Pull user access str* updates from Al Viro:
"uaccess str...() dead code removal"
* 'uaccess.strlen' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
s390 keyboard.c: don't open-code strndup_user()
mips: get rid of unused __strnlen_user()
get rid of unused __strncpy_from_user() instances
kill strlen_user()
Pull misc compat stuff updates from Al Viro:
"This part is basically untangling various compat stuff. Compat
syscalls moved to their native counterparts, getting rid of quite a
bit of double-copying and/or set_fs() uses. A lot of field-by-field
copyin/copyout killed off.
- kernel/compat.c is much closer to containing just the
copyin/copyout of compat structs. Not all compat syscalls are gone
from it yet, but it's getting there.
- ipc/compat_mq.c killed off completely.
- block/compat_ioctl.c cleaned up; floppy compat ioctls moved to
drivers/block/floppy.c where they belong. Yes, there are several
drivers that implement some of the same ioctls. Some are m68k and
one is 32bit-only pmac. drivers/block/floppy.c is the only one in
that bunch that can be built on biarch"
* 'misc.compat' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
mqueue: move compat syscalls to native ones
usbdevfs: get rid of field-by-field copyin
compat_hdio_ioctl: get rid of set_fs()
take floppy compat ioctls to sodding floppy.c
ipmi: get rid of field-by-field __get_user()
ipmi: get COMPAT_IPMICTL_RECEIVE_MSG in sync with the native one
rt_sigtimedwait(): move compat to native
select: switch compat_{get,put}_fd_set() to compat_{get,put}_bitmap()
put_compat_rusage(): switch to copy_to_user()
sigpending(): move compat to native
getrlimit()/setrlimit(): move compat to native
times(2): move compat to native
compat_{get,put}_bitmap(): use unsafe_{get,put}_user()
fb_get_fscreeninfo(): don't bother with do_fb_ioctl()
do_sigaltstack(): lift copying to/from userland into callers
take compat_sys_old_getrlimit() to native syscall
trim __ARCH_WANT_SYS_OLD_GETRLIMIT
Pull dma-mapping infrastructure from Christoph Hellwig:
"This is the first pull request for the new dma-mapping subsystem
In this new subsystem we'll try to properly maintain all the generic
code related to dma-mapping, and will further consolidate arch code
into common helpers.
This pull request contains:
- removal of the DMA_ERROR_CODE macro, replacing it with calls to
->mapping_error so that the dma_map_ops instances are more self
contained and can be shared across architectures (me)
- removal of the ->set_dma_mask method, which duplicates the
->dma_capable one in terms of functionality, but requires more
duplicate code.
- various updates for the coherent dma pool and related arm code
(Vladimir)
- various smaller cleanups (me)"
* tag 'dma-mapping-4.13' of git://git.infradead.org/users/hch/dma-mapping: (56 commits)
ARM: dma-mapping: Remove traces of NOMMU code
ARM: NOMMU: Set ARM_DMA_MEM_BUFFERABLE for M-class cpus
ARM: NOMMU: Introduce dma operations for noMMU
drivers: dma-mapping: allow dma_common_mmap() for NOMMU
drivers: dma-coherent: Introduce default DMA pool
drivers: dma-coherent: Account dma_pfn_offset when used with device tree
dma: Take into account dma_pfn_offset
dma-mapping: replace dmam_alloc_noncoherent with dmam_alloc_attrs
dma-mapping: remove dmam_free_noncoherent
crypto: qat - avoid an uninitialized variable warning
au1100fb: remove a bogus dma_free_nonconsistent call
MAINTAINERS: add entry for dma mapping helpers
powerpc: merge __dma_set_mask into dma_set_mask
dma-mapping: remove the set_dma_mask method
powerpc/cell: use the dma_supported method for ops switching
powerpc/cell: clean up fixed mapping dma_ops initialization
tile: remove dma_supported and mapping_error methods
xen-swiotlb: remove xen_swiotlb_set_dma_mask
arm: implement ->dma_supported instead of ->set_dma_mask
mips/loongson64: implement ->dma_supported instead of ->set_dma_mask
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull more s390 updates from Martin Schwidefsky:
- The fixup for the blk-mq clash with the scm driver
- An improvement for the dasd driver in regard to raw I/O
- Bug fixes and cleanup
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux:
Update my email address
s390/syscalls: Fix out of bounds arguments access
s390/vfio_ccw: remove unused variable
s390/dasd: remove unneeded code
s390/crash: Remove unused KEXEC_NOTE_BYTES
s390/zcrypt: Fix missing newlines at some debug feature messages.
s390/dasd: Make raw I/O usable without prefix support
s390/dasd: Rename dasd_raw_build_cp()
s390/dasd: Refactor prefix_LRE() and related functions
s390: fix up for "blk-mq: switch ->queue_rq return value to blk_status_t"
Pull KVM updates from Paolo Bonzini:
"PPC:
- Better machine check handling for HV KVM
- Ability to support guests with threads=2, 4 or 8 on POWER9
- Fix for a race that could cause delayed recognition of signals
- Fix for a bug where POWER9 guests could sleep with interrupts pending.
ARM:
- VCPU request overhaul
- allow timer and PMU to have their interrupt number selected from userspace
- workaround for Cavium erratum 30115
- handling of memory poisonning
- the usual crop of fixes and cleanups
s390:
- initial machine check forwarding
- migration support for the CMMA page hinting information
- cleanups and fixes
x86:
- nested VMX bugfixes and improvements
- more reliable NMI window detection on AMD
- APIC timer optimizations
Generic:
- VCPU request overhaul + documentation of common code patterns
- kvm_stat improvements"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (124 commits)
kvm: vmx: allow host to access guest MSR_IA32_BNDCFGS
x86: kvm: mmu: use ept a/d in vmcs02 iff used in vmcs12
kvm: x86: mmu: allow A/D bits to be disabled in an mmu
x86: kvm: mmu: make spte mmio mask more explicit
x86: kvm: mmu: dead code thanks to access tracking
KVM: PPC: Book3S: Fix typo in XICS-on-XIVE state saving code
KVM: PPC: Book3S HV: Close race with testing for signals on guest entry
KVM: PPC: Book3S HV: Simplify dynamic micro-threading code
KVM: x86: remove ignored type attribute
KVM: LAPIC: Fix lapic timer injection delay
KVM: lapic: reorganize restart_apic_timer
KVM: lapic: reorganize start_hv_timer
kvm: nVMX: Check memory operand to INVVPID
KVM: s390: Inject machine check into the nested guest
KVM: s390: Inject machine check into the guest
tools/kvm_stat: add new interactive command 'b'
tools/kvm_stat: add new command line switch '-i'
tools/kvm_stat: fix error on interactive command 'g'
KVM: SVM: suppress unnecessary NMI singlestep on GIF=0 and nested exit
When unmapping a hugepage range, huge_pte_clear() is used to clear the
page table entries that are marked as not present. huge_pte_clear()
internally just ends up calling pte_clear() which does not correctly
deal with hugepages consisting of contiguous page table entries.
Add a size argument to address this issue and allow architectures to
override huge_pte_clear() by wrapping it in a #ifndef block.
Update s390 implementation with the size parameter as well.
Note that the change only affects huge_pte_clear() - the other generic
hugetlb functions don't need any change.
Link: http://lkml.kernel.org/r/20170522162555.4313-1-punit.agrawal@arm.com
Signed-off-by: Punit Agrawal <punit.agrawal@arm.com>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390 bits]
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: Mike Kravetz <mike.kravetz@oracle.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Steve Capper <steve.capper@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Hillf Danton <hillf.zj@alibaba-inc.com>
Cc: Michal Hocko <mhocko@suse.com>
A poisoned or migrated hugepage is stored as a swap entry in the page
tables. On architectures that support hugepages consisting of
contiguous page table entries (such as on arm64) this leads to ambiguity
in determining the page table entry to return in huge_pte_offset() when
a poisoned entry is encountered.
Let's remove the ambiguity by adding a size parameter to convey
additional information about the requested address. Also fixup the
definition/usage of huge_pte_offset() throughout the tree.
Link: http://lkml.kernel.org/r/20170522133604.11392-4-punit.agrawal@arm.com
Acked-by: Steve Capper <steve.capper@arm.com>
Cc: James Hogan <james.hogan@imgtec.com> (odd fixer:METAG ARCHITECTURE)
Cc: Ralf Baechle <ralf@linux-mips.org> (supporter:MIPS)
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Rich Felker <dalias@libc.org>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
This moves the #ifdef in C code to a Kconfig dependency. Also we move
the gigantic_page_supported() function to be arch specific.
This allows architectures to conditionally enable runtime allocation of
gigantic huge page. Architectures like ppc64 supports different
gigantic huge page size (16G and 1G) based on the translation mode
selected. This provides an opportunity for ppc64 to enable runtime
allocation only w.r.t 1G hugepage.
No functional change in this patch.
Link: http://lkml.kernel.org/r/1494995292-4443-1-git-send-email-aneesh.kumar@linux.vnet.ibm.com
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com>
arch_add_memory gets for_device argument which then controls whether we
want to create memblocks for created memory sections. Simplify the
logic by telling whether we want memblocks directly rather than going
through pointless negation. This also makes the api easier to
understand because it is clear what we want rather than nothing telling
for_device which can mean anything.
This shouldn't introduce any functional change.
Link: http://lkml.kernel.org/r/20170515085827.16474-13-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Tested-by: Dan Williams <dan.j.williams@intel.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Balbir Singh <bsingharora@gmail.com>
Cc: Daniel Kiper <daniel.kiper@oracle.com>
Cc: Igor Mammedov <imammedo@redhat.com>
Cc: Jerome Glisse <jglisse@redhat.com>
Cc: Joonsoo Kim <js1304@gmail.com>
Cc: Reza Arbab <arbab@linux.vnet.ibm.com>
Cc: Tobias Regnery <tobias.regnery@gmail.com>
Cc: Toshi Kani <toshi.kani@hpe.com>
Cc: Vitaly Kuznetsov <vkuznets@redhat.com>
Cc: Xishi Qiu <qiuxishi@huawei.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
The current memory hotplug implementation relies on having all the
struct pages associate with a zone/node during the physical hotplug
phase (arch_add_memory->__add_pages->__add_section->__add_zone). In the
vast majority of cases this means that they are added to ZONE_NORMAL.
This has been so since 9d99aaa31f59 ("[PATCH] x86_64: Support memory
hotadd without sparsemem") and it wasn't a big deal back then because
movable onlining didn't exist yet.
Much later memory hotplug wanted to (ab)use ZONE_MOVABLE for movable
onlining 511c2aba8f07 ("mm, memory-hotplug: dynamic configure movable
memory and portion memory") and then things got more complicated.
Rather than reconsidering the zone association which was no longer
needed (because the memory hotplug already depended on SPARSEMEM) a
convoluted semantic of zone shifting has been developed. Only the
currently last memblock or the one adjacent to the zone_movable can be
onlined movable. This essentially means that the online type changes as
the new memblocks are added.
Let's simulate memory hot online manually
$ echo 0x100000000 > /sys/devices/system/memory/probe
$ grep . /sys/devices/system/memory/memory32/valid_zones
Normal Movable
$ echo $((0x100000000+(128<<20))) > /sys/devices/system/memory/probe
$ grep . /sys/devices/system/memory/memory3?/valid_zones
/sys/devices/system/memory/memory32/valid_zones:Normal
/sys/devices/system/memory/memory33/valid_zones:Normal Movable
$ echo $((0x100000000+2*(128<<20))) > /sys/devices/system/memory/probe
/sys/devices/system/memory/memory34/valid_zones:Normal Movable
$ echo online_movable > /sys/devices/system/memory/memory34/state
/sys/devices/system/memory/memory34/valid_zones:Movable Normal
This is an awkward semantic because an udev event is sent as soon as the
block is onlined and an udev handler might want to online it based on
some policy (e.g. association with a node) but it will inherently race
with new blocks showing up.
This patch changes the physical online phase to not associate pages with
any zone at all. All the pages are just marked reserved and wait for
the onlining phase to be associated with the zone as per the online
request. There are only two requirements
- existing ZONE_NORMAL and ZONE_MOVABLE cannot overlap
- ZONE_NORMAL precedes ZONE_MOVABLE in physical addresses
the latter one is not an inherent requirement and can be changed in the
future. It preserves the current behavior and made the code slightly
simpler. This is subject to change in future.
This means that the same physical online steps as above will lead to the
following state: Normal Movable
/sys/devices/system/memory/memory32/valid_zones:Normal Movable
Implementation:
The current move_pfn_range is reimplemented to check the above
requirements (allow_online_pfn_range) and then updates the respective
zone (move_pfn_range_to_zone), the pgdat and links all the pages in the
pfn range with the zone/node. __add_pages is updated to not require the
zone and only initializes sections in the range. This allowed to
simplify the arch_add_memory code (s390 could get rid of quite some of
code).
devm_memremap_pages is the only user of arch_add_memory which relies on
the zone association because it only hooks into the memory hotplug only
half way. It uses it to associate the new memory with ZONE_DEVICE but
doesn't allow it to be {on,off}lined via sysfs. This means that this
particular code path has to call move_pfn_range_to_zone explicitly.
The original zone shifting code is kept in place and will be removed in
the follow up patch for an easier review.
Please note that this patch also changes the original behavior when
offlining a memory block adjacent to another zone (Normal vs. Movable)
used to allow to change its movable type. This will be handled later.
[richard.weiyang@gmail.com: simplify zone_intersects()]
Link: http://lkml.kernel.org/r/20170616092335.5177-1-richard.weiyang@gmail.com
[richard.weiyang@gmail.com: remove duplicate call for set_page_links]
Link: http://lkml.kernel.org/r/20170616092335.5177-2-richard.weiyang@gmail.com
[akpm@linux-foundation.org: remove unused local `i']
Link: http://lkml.kernel.org/r/20170515085827.16474-12-mhocko@kernel.org
Signed-off-by: Wei Yang <richard.weiyang@gmail.com>
Tested-by: Reza Arbab <arbab@linux.vnet.ibm.com>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # For s390 bits
Device memory hotplug hooks into regular memory hotplug only half way.
It needs memory sections to track struct pages but there is no
need/desire to associate those sections with memory blocks and export
them to the userspace via sysfs because they cannot be onlined anyway.
This is currently expressed by for_device argument to arch_add_memory
which then makes sure to associate the given memory range with
ZONE_DEVICE. register_new_memory then relies on is_zone_device_section
to distinguish special memory hotplug from the regular one. While this
works now, later patches in this series want to move __add_zone outside
of arch_add_memory path so we have to come up with something else.
Add want_memblock down the __add_pages path and use it to control
whether the section->memblock association should be done.
arch_add_memory then just trivially want memblock for everything but
for_device hotplug.
remove_memory_section doesn't need is_zone_device_section either. We
can simply skip all the memblock specific cleanup if there is no
memblock for the given section.
Link: http://lkml.kernel.org/r/20170515085827.16474-5-mhocko@kernel.org
Pull networking updates from David Miller:
"Reasonably busy this cycle, but perhaps not as busy as in the 4.12
merge window:
1) Several optimizations for UDP processing under high load from
Paolo Abeni.
2) Support pacing internally in TCP when using the sch_fq packet
scheduler for this is not practical. From Eric Dumazet.
3) Support mutliple filter chains per qdisc, from Jiri Pirko.
4) Move to 1ms TCP timestamp clock, from Eric Dumazet.
5) Add batch dequeueing to vhost_net, from Jason Wang.
6) Flesh out more completely SCTP checksum offload support, from
Davide Caratti.
7) More plumbing of extended netlink ACKs, from David Ahern, Pablo
Neira Ayuso, and Matthias Schiffer.
8) Add devlink support to nfp driver, from Simon Horman.
9) Add RTM_F_FIB_MATCH flag to RTM_GETROUTE queries, from Roopa
Prabhu.
10) Add stack depth tracking to BPF verifier and use this information
in the various eBPF JITs. From Alexei Starovoitov.
11) Support XDP on qed device VFs, from Yuval Mintz.
12) Introduce BPF PROG ID for better introspection of installed BPF
programs. From Martin KaFai Lau.
13) Add bpf_set_hash helper for TC bpf programs, from Daniel Borkmann.
14) For loads, allow narrower accesses in bpf verifier checking, from
Yonghong Song.
15) Support MIPS in the BPF selftests and samples infrastructure, the
MIPS eBPF JIT will be merged in via the MIPS GIT tree. From David
Daney.
16) Support kernel based TLS, from Dave Watson and others.
17) Remove completely DST garbage collection, from Wei Wang.
18) Allow installing TCP MD5 rules using prefixes, from Ivan
Delalande.
19) Add XDP support to Intel i40e driver, from Björn Töpel
20) Add support for TC flower offload in nfp driver, from Simon
Horman, Pieter Jansen van Vuuren, Benjamin LaHaise, Jakub
Kicinski, and Bert van Leeuwen.
21) IPSEC offloading support in mlx5, from Ilan Tayari.
22) Add HW PTP support to macb driver, from Rafal Ozieblo.
23) Networking refcount_t conversions, From Elena Reshetova.
24) Add sock_ops support to BPF, from Lawrence Brako. This is useful
for tuning the TCP sockopt settings of a group of applications,
currently via CGROUPs"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1899 commits)
net: phy: dp83867: add workaround for incorrect RX_CTRL pin strap
dt-bindings: phy: dp83867: provide a workaround for incorrect RX_CTRL pin strap
cxgb4: Support for get_ts_info ethtool method
cxgb4: Add PTP Hardware Clock (PHC) support
cxgb4: time stamping interface for PTP
nfp: default to chained metadata prepend format
nfp: remove legacy MAC address lookup
nfp: improve order of interfaces in breakout mode
net: macb: remove extraneous return when MACB_EXT_DESC is defined
bpf: add missing break in for the TCP_BPF_SNDCWND_CLAMP case
bpf: fix return in load_bpf_file
mpls: fix rtm policy in mpls_getroute
net, ax25: convert ax25_cb.refcount from atomic_t to refcount_t
net, ax25: convert ax25_route.refcount from atomic_t to refcount_t
net, ax25: convert ax25_uid_assoc.refcount from atomic_t to refcount_t
net, sctp: convert sctp_ep_common.refcnt from atomic_t to refcount_t
net, sctp: convert sctp_transport.refcnt from atomic_t to refcount_t
net, sctp: convert sctp_chunk.refcnt from atomic_t to refcount_t
net, sctp: convert sctp_datamsg.refcnt from atomic_t to refcount_t
net, sctp: convert sctp_auth_bytes.refcnt from atomic_t to refcount_t
Zorro reported following crash while having enabled
syscall tracing (CONFIG_FTRACE_SYSCALLS):
Unable to handle kernel pointer dereference at virtual ...
Oops: 0011 [#1] SMP DEBUG_PAGEALLOC
SNIP
Call Trace:
([<000000000024d79c>] ftrace_syscall_enter+0xec/0x1d8)
[<00000000001099c6>] do_syscall_trace_enter+0x236/0x2f8
[<0000000000730f1c>] sysc_tracesys+0x1a/0x32
[<000003fffcf946a2>] 0x3fffcf946a2
INFO: lockdep is turned off.
Last Breaking-Event-Address:
[<000000000022dd44>] rb_event_data+0x34/0x40
---[ end trace 8c795f86b1b3f7b9 ]---
The crash happens in syscall_get_arguments function for
syscalls with zero arguments, that will try to access
first argument (args[0]) in event entry, but it's not
allocated.
Bail out of there are no arguments.
Cc: stable@vger.kernel.org
Reported-by: Zorro Lang <zlang@redhat.com>
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
After commmit 692f66f26a4c19 ("crash: move crashkernel parsing and vmcore
related code under CONFIG_CRASH_CORE") the KEXEC_NOTE_BYTES macro is not
used anymore and for s390 we create the ELF header in the new kernel
anyway. Therefore remove the macro.
Reported-by: Xunlei Pang <xpang@redhat.com>
Reviewed-by: Mikhail Zaslonko <zaslonko@linux.vnet.ibm.com>
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Pull SMP hotplug updates from Thomas Gleixner:
"This update is primarily a cleanup of the CPU hotplug locking code.
The hotplug locking mechanism is an open coded RWSEM, which allows
recursive locking. The main problem with that is the recursive nature
as it evades the full lockdep coverage and hides potential deadlocks.
The rework replaces the open coded RWSEM with a percpu RWSEM and
establishes full lockdep coverage that way.
The bulk of the changes fix up recursive locking issues and address
the now fully reported potential deadlocks all over the place. Some of
these deadlocks have been observed in the RT tree, but on mainline the
probability was low enough to hide them away."
* 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (37 commits)
cpu/hotplug: Constify attribute_group structures
powerpc: Only obtain cpu_hotplug_lock if called by rtasd
ARM/hw_breakpoint: Fix possible recursive locking for arch_hw_breakpoint_init
cpu/hotplug: Remove unused check_for_tasks() function
perf/core: Don't release cred_guard_mutex if not taken
cpuhotplug: Link lock stacks for hotplug callbacks
acpi/processor: Prevent cpu hotplug deadlock
sched: Provide is_percpu_thread() helper
cpu/hotplug: Convert hotplug locking to percpu rwsem
s390: Prevent hotplug rwsem recursion
arm: Prevent hotplug rwsem recursion
arm64: Prevent cpu hotplug rwsem recursion
kprobes: Cure hotplug lock ordering issues
jump_label: Reorder hotplug lock and jump_label_lock
perf/tracing/cpuhotplug: Fix locking order
ACPI/processor: Use cpu_hotplug_disable() instead of get_online_cpus()
PCI: Replace the racy recursion prevention
PCI: Use cpu_hotplug_disable() instead of get_online_cpus()
perf/x86/intel: Drop get_online_cpus() in intel_snb_check_microcode()
x86/perf: Drop EXPORT of perf_check_microcode
Pull s390 updates from Martin Schwidefsky:
"The bulk of the s390 patches for 4.13. Some new things but mostly bug
fixes and cleanups. Noteworthy changes:
- The SCM block driver is converted to blk-mq
- Switch s390 to 5 level page tables. The virtual address space for a
user space process can now have up to 16EB-4KB.
- Introduce a ELF phdr flag for qemu to avoid the global
vm.alloc_pgste which forces all processes to large page tables
- A couple of PCI improvements to improve error recovery
- Included is the merge of the base support for proper machine checks
for KVM"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (52 commits)
s390/dasd: Fix faulty ENODEV for RO sysfs attribute
s390/pci: recognize name clashes with uids
s390/pci: provide more debug information
s390/pci: fix handling of PEC 306
s390/pci: improve pci hotplug
s390/pci: introduce clp_get_state
s390/pci: improve error handling during fmb (de)registration
s390/pci: improve unreg_ioat error handling
s390/pci: improve error handling during interrupt deregistration
s390/pci: don't cleanup in arch_setup_msi_irqs
KVM: s390: Backup the guest's machine check info
s390/nmi: s390: New low level handling for machine check happening in guest
s390/fpu: export save_fpu_regs for all configs
s390/kvm: avoid global config of vm.alloc_pgste=1
s390: rename struct psw_bits members
s390: rename psw_bits enums
s390/mm: use correct address space when enabling DAT
s390/cio: introduce io_subchannel_type
s390/ipl: revert Load Normal semantics for LPAR CCW-type re-IPL
s390/dumpstack: remove raw stack dump
Pull core block/IO updates from Jens Axboe:
"This is the main pull request for the block layer for 4.13. Not a huge
round in terms of features, but there's a lot of churn related to some
core cleanups.
Note this depends on the UUID tree pull request, that Christoph
already sent out.
- A series from Christoph, unifying the error/stats codes in the
block layer. We now use blk_status_t everywhere, instead of using
different schemes for different places.
- Also from Christoph, some cleanups around request allocation and IO
scheduler interactions in blk-mq.
- And yet another series from Christoph, cleaning up how we handle
and do bounce buffering in the block layer.
- A blk-mq debugfs series from Bart, further improving on the support
we have for exporting internal information to aid debugging IO
hangs or stalls.
- Also from Bart, a series that cleans up the request initialization
differences across types of devices.
- A series from Goldwyn Rodrigues, allowing the block layer to return
failure if we will block and the user asked for non-blocking.
- Patch from Hannes for supporting setting loop devices block size to
that of the underlying device.
- Two series of patches from Javier, fixing various issues with
lightnvm, particular around pblk.
- A series from me, adding support for write hints. This comes with
NVMe support as well, so applications can help guide data placement
on flash to improve performance, latencies, and write
amplification.
- A series from Ming, improving and hardening blk-mq support for
stopping/starting and quiescing hardware queues.
- Two pull requests for NVMe updates. Nothing major on the feature
side, but lots of cleanups and bug fixes. From the usual crew.
- A series from Neil Brown, greatly improving the bio rescue set
support. Most notably, this kills the bio rescue work queues, if we
don't really need them.
- Lots of other little bug fixes that are all over the place"
* 'for-4.13/block' of git://git.kernel.dk/linux-block: (217 commits)
lightnvm: pblk: set line bitmap check under debug
lightnvm: pblk: verify that cache read is still valid
lightnvm: pblk: add initialization check
lightnvm: pblk: remove target using async. I/Os
lightnvm: pblk: use vmalloc for GC data buffer
lightnvm: pblk: use right metadata buffer for recovery
lightnvm: pblk: schedule if data is not ready
lightnvm: pblk: remove unused return variable
lightnvm: pblk: fix double-free on pblk init
lightnvm: pblk: fix bad le64 assignations
nvme: Makefile: remove dead build rule
blk-mq: map all HWQ also in hyperthreaded system
nvmet-rdma: register ib_client to not deadlock in device removal
nvme_fc: fix error recovery on link down.
nvmet_fc: fix crashes on bad opcodes
nvme_fc: Fix crash when nvme controller connection fails.
nvme_fc: replace ioabort msleep loop with completion
nvme_fc: fix double calls to nvme_cleanup_cmd()
nvme-fabrics: verify that a controller returns the correct NQN
nvme: simplify nvme_dev_attrs_are_visible
Pull uuid subsystem from Christoph Hellwig:
"This is the new uuid subsystem, in which Amir, Andy and I have started
consolidating our uuid/guid helpers and improving the types used for
them. Note that various other subsystems have pulled in this tree, so
I'd like it to go in early.
UUID/GUID summary:
- introduce the new uuid_t/guid_t types that are going to replace the
somewhat confusing uuid_be/uuid_le types and make the terminology
fit the various specs, as well as the userspace libuuid library.
(me, based on a previous version from Amir)
- consolidated generic uuid/guid helper functions lifted from XFS and
libnvdimm (Amir and me)
- conversions to the new types and helpers (Amir, Andy and me)"
* tag 'uuid-for-4.13' of git://git.infradead.org/users/hch/uuid: (34 commits)
ACPI: hns_dsaf_acpi_dsm_guid can be static
mmc: sdhci-pci: make guid intel_dsm_guid static
uuid: Take const on input of uuid_is_null() and guid_is_null()
thermal: int340x_thermal: fix compile after the UUID API switch
thermal: int340x_thermal: Switch to use new generic UUID API
acpi: always include uuid.h
ACPI: Switch to use generic guid_t in acpi_evaluate_dsm()
ACPI / extlog: Switch to use new generic UUID API
ACPI / bus: Switch to use new generic UUID API
ACPI / APEI: Switch to use new generic UUID API
acpi, nfit: Switch to use new generic UUID API
MAINTAINERS: add uuid entry
tmpfs: generate random sb->s_uuid
scsi_debug: switch to uuid_t
nvme: switch to uuid_t
sysctl: switch to use uuid_t
partitions/ldm: switch to use uuid_t
overlayfs: use uuid_t instead of uuid_be
fs: switch ->s_uuid to uuid_t
ima/policy: switch to use uuid_t
A set of overlapping changes in macvlan and the rocker
driver, nothing serious.
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into HEAD
KVM/ARM updates for 4.13
- vcpu request overhaul
arch/s390/include/asm/kvm_host.h
The only user of thread_saved_pc() in non-arch-specific code was removed
in commit 8243d5597793 ("sched/core: Remove pointless printout in
sched_show_task()"). Remove the implementations as well.
Some architectures use thread_saved_pc() in their arch-specific code.
Leave their thread_saved_pc() intact.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
s390 can also use noop_dma_ops, and while that currently does not return
errors it will so in the future. Implementing the mapping_error method
is the proper way to have per-ops error conditions.
Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvms390/linux into features
Pull kvm patches from Christian Borntraeger:
"s390,kvm: provide plumbing for machines checks when running guests"
This provides the basic plumbing for handling machine checks when
running guests
With vsie feature enabled, kvm can support nested guests (guest-3).
So inject machine check to the guest-2 if it happens when the nested
guest is running. And guest-2 will detect the machine check belongs
to guest-3 and reinject it into guest-3.
The host (guest-1) tries to inject the machine check to the picked
destination vcpu if it's a floating machine check.
Signed-off-by: QingFeng Hao <haoqf@linux.vnet.ibm.com>
Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
If the exit flag of SIE indicates that a machine check has happened
during guest's running and needs to be injected, inject it to the guest
accordingly.
But some machine checks, e.g. Channel Report Pending (CRW), refer to
host conditions only (the guest's channel devices are not managed by
the kernel directly) and are therefore not injected into the guest.
External Damage (ED) is also not reinjected into the guest because ETR
conditions are gone in Linux and STP conditions are not enabled in the
guest, and ED contains only these 8 ETR and STP conditions.
In general, instruction-processing damage, system recovery,
storage error, service-processor damage and channel subsystem damage
will be reinjected into the guest, and the remain (System damage,
timing-facility damage, warning, ED and CRW) will be handled on the host.
git://git.kernel.org/pub/scm/linux/kernel/git/kvms390/linux into kernelorgnext
running guests
When uid checking is enabled firmware guarantees uniqueness of the uids
and we use them for device enumeration. Tests have shown that uid checking
can be toggled at runtime. This is unfortunate since it can lead to name
clashes.
Recognize these name clashes by allocating bits in zpci_domain even for
firmware provided ids.
Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
Reviewed-by: Pierre Morel <pmorel@linux.vnet.ibm.com>
Reviewed-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Add some debug data to observe the lifetime of the
architecture specific device information.
In contrast to other hotplug events PEC 0x306 isn't about a single
but multiple devices. Also there's no information on what happened
to these devices. We correctly handled hotplug that way but failed
to handle hot-unplug. This patch addresses that and implements
hot-unplug of multiple devices via PEC 306.
PCI hotplug events basically notify about the new state of a
function. Unfortunately some hypervisors implement hotplug
events in a way where it is not clear what the new state of
the function should be.
Use clp_get_state to find the current state of the function
and handle accordingly.
Code handling pci hotplug needs to determine the configuration
state of a pci function. Implement clp_get_state as a wrapper
for list pci functions.
Also change enum zpci_state to match the configuration state
values.
Cleanup in zpci_fmb_enable_device when fmb registration fails. Also
don't free the fmb when deregistration fails in zpci_fmb_disable_device
but handle error situations when a function was hot-unplugged.
Also remove the mod_pci helper since it is no longer used.
DMA tables are freed in zpci_dma_exit_device regardless of the return
code of zpci_unregister_ioat. This could lead to a use after free. On
the other hand during function hot-unplug, zpci_unregister_ioat will
always fail since the function is already gone.
So let zpci_unregister_ioat report success when the function is gone
but don't cleanup the dma table when a function could still have it
in access.
When we ask a function to stop creating interrupts this may fail
due to the function being already gone (e.g. after hot-unplug).
Consequently we don't free associated resources like summary bits
and bit vectors used for irq processing. This could lead to
situations where we ran out of these resources and fail to setup
new interrupts.
The fix is to just ignore the errors in cases where we can be
sure no new interrupts are generated.
After failures in arch_setup_msi_irqs common code calls
arch_teardown_msi_irqs. Thus, remove cleanup code from
arch_setup_msi_irqs.
When a machine check happens in the guest, related mcck info (mcic,
external damage code, ...) is stored in the vcpu's lowcore on the host.
Then the machine check handler's low-level part is executed, followed
by the high-level part.
If the high-level part's execution is interrupted by a new machine check
happening on the same vcpu on the host, the mcck info in the lowcore is
overwritten with the new machine check's data.
If the high-level part's execution is scheduled to a different cpu,
the mcck info in the lowcore is uncertain.
Therefore, for both cases, the further reinjection to the guest will use
the wrong data.
Let's backup the mcck info in the lowcore to the sie page
for further reinjection, so that the right data will be used.
Add new member into struct sie_page to store related machine check's
info of mcic, failing storage address and external damage code.
Add the logic to check if the machine check happens when the guest is
running. If yes, set the exit reason -EINTR in the machine check's
interrupt handler. Refactor s390_do_machine_check to avoid panicing
the host for some kinds of machine checks which happen
when guest is running.
Reinject the instruction processing damage's machine checks including
Delayed Access Exception instead of damaging the host if it happens
in the guest because it could be caused by improper update on TLB entry
or other software case and impacts the guest only.
Pull s390 bugfix from Martin Schwidefsky:
"One last s390 patch for 4.12
Revert the re-IPL semantics back to the v4.7 state. It turned out that
the memory layout may change due to memory hotplug if load-normal is
used"
Pull in the fix for shared tags, as it conflicts with the pending
changes in for-4.13/block. We already pulled in v4.12-rc5 to solve
other conflicts or get fixes that went into 4.12, so not a lot
of changes in this merge.
KVM: s390: fix shadow table handling for nested guests
Some odd-ball cases (real-space designation ASCEs) are handled wrong
for the shadow page tables. Fix it.
For real-space designation asces the asce origin part is only a token.
The asce token origin must not be used to generate an effective
address for storage references. This however is erroneously done
within kvm_s390_shadow_tables().
Furthermore within the same function the wrong parts of virtual
addresses are used to generate a corresponding real address
(e.g. the region second index is used as region first index).
Both of the above can result in incorrect address translations. Only
for real space designations with a token origin of zero and addresses
below one megabyte the translation was correct.
Furthermore replace a "!asce.r" statement with a "!*fake" statement to
make it more obvious that a specific condition has nothing to do with
the architecture, but with the fake handling of real space designations.
Fixes: 3218f7094b6b ("s390/mm: support real-space for gmap shadows")
Cc: David Hildenbrand <david@redhat.com>
Reviewed-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
For naturally aligned and sized data structures avoid superfluous
packed and aligned attributes.
Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com>
In some cases, userspace needs to get or set all ais states for example
migration. So we introduce a new group KVM_DEV_FLIC_AISM_ALL to provide
interfaces to get or set the adapter-interruption-suppression mode for
all ISCs. The corresponding documentation is updated.
Signed-off-by: Yi Min Zhao <zyimin@linux.vnet.ibm.com>
Reviewed-by: Halil Pasic <pasic@linux.vnet.ibm.com>
ifetch
While currently only used to fetch the original instruction on failure
for getting the instruction length code, we should make the page table
walking code future proof.
Suggested-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com>
* Add the struct used in the ioctls to get and set CMMA attributes.
* Add the two functions needed to get and set the CMMA attributes for
guest pages.
* Add the two ioctls that use the aforementioned functions.
Signed-off-by: Claudio Imbrenda <imbrenda@linux.vnet.ibm.com>
Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com>
* Add a migration state bitmap to keep track of which pages have dirty
CMMA information.
* Disable CMMA by default, so we can track if it's used or not. Enable
it on first use like we do for storage keys (unless we are doing a
migration).
* Creates a VM attribute to enter and leave migration mode.
* In migration mode, CMMA is disabled in the SIE block, so ESSA is
always interpreted and emulated in software.
* Free the migration state on VM destroy.
Two entries being added at the same time to the IFLA
policy table, whilst parallel bug fixes to decnet
routing dst handling overlapping with the dst gc removal
in net-next.
This adds the new getsockopt(2) option SO_PEERGROUPS on SOL_SOCKET to
retrieve the auxiliary groups of the remote peer. It is designed to
naturally extend SO_PEERCRED. That is, the underlying data is from the
same credentials. Regarding its syntax, it is based on SO_PEERSEC. That
is, if the provided buffer is too small, ERANGE is returned and @optlen
is updated. Otherwise, the information is copied, @optlen is set to the
actual size, and 0 is returned.
While SO_PEERCRED (and thus `struct ucred') already returns the primary
group, it lacks the auxiliary group vector. However, nearly all access
controls (including kernel side VFS and SYSVIPC, but also user-space
polkit, DBus, ...) consider the entire set of groups, rather than just
the primary group. But this is currently not possible with pure
SO_PEERCRED. Instead, user-space has to work around this and query the
system database for the auxiliary groups of a UID retrieved via
SO_PEERCRED.
Unfortunately, there is no race-free way to query the auxiliary groups
of the PID/UID retrieved via SO_PEERCRED. Hence, the current user-space
solution is to use getgrouplist(3p), which itself falls back to NSS and
whatever is configured in nsswitch.conf(3). This effectively checks
which groups we *would* assign to the user if it logged in *now*. On
normal systems it is as easy as reading /etc/group, but with NSS it can
resort to quering network databases (eg., LDAP), using IPC or network
communication.
Long story short: Whenever we want to use auxiliary groups for access
checks on IPC, we need further IPC to talk to the user/group databases,
rather than just relying on SO_PEERCRED and the incoming socket. This
is unfortunate, and might even result in dead-locks if the database
query uses the same IPC as the original request.
So far, those recursions / dead-locks have been avoided by using
primitive IPC for all crucial NSS modules. However, we want to avoid
re-inventing the wheel for each NSS module that might be involved in
user/group queries. Hence, we would preferably make DBus (and other IPC
that supports access-management based on groups) work without resorting
to the user/group database. This new SO_PEERGROUPS ioctl would allow us
to make dbus-daemon work without ever calling into NSS.
Cc: Michal Sekletar <msekleta@redhat.com>
Cc: Simon McVittie <simon.mcvittie@collabora.co.uk>
Reviewed-by: Tom Gundersen <teg@jklm.no>
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
Implement support for the hypervisor diagnose 0x26c
('Access Certain System Information').
It passes a request buffer and a subfunction code, and receives
a response buffer and a return code.
Also add the scaffolding for the 'MAC Services' subfunction.
It may be used by network devices to obtain a hypervisor-managed
MAC address.
Signed-off-by: Julian Wiedmann <jwi@linux.vnet.ibm.com>
