Randomize mmap start address with 8MB.
Shuffle code around so it looks more like x86 and powerpc.
Historically 64 bit processes use the legacy address layout. However
there is no reason why 64 bit processes shouldn't benefit from the
flexible mmap layout advantages.
Therefore just enable it.
Reduce minimum gap between stack and mmap_base to 32MB. That way there
is a bit more space for heap and mmap for tight 31 bit address spaces.
Consider stack address randomization when calulating mmap_base for
flexible mmap layout . Because of address randomization the stack
address can be up to 8MB lower than STACK_TOP.
When calculating mmap_base this isn't taken into account, which could
lead to the case that the gap between the real stack top and mmap_base
is lower than what ulimit specifies for the maximum stack size.
Make sure compiler won't do weird things with limits. E.g. fetching
them twice may return 2 different values after writable limits are
implemented.
I.e. either use rlimit helpers added in
3e10e716abf3c71bdb5d86b8f507f9e72236c9cd
or ACCESS_ONCE if not applicable.
Cc: linux390@de.ibm.com
Cc: linux-s390@vger.kernel.org
Implement is_compat_task and use it all over the place.
After TASK_SIZE now gives the current size of the address space the
upgrade of a 64 bit process from 3 to 4 levels of page table needs
to use the arch_mmap_check hook to catch large mmap lengths. The
get_unmapped_area* functions need to check for -ENOMEM from the
arch_get_unmapped_area*, upgrade the page table and retry.
Make page table walking on s390 more robust. The current code requires
that the pgd/pud/pmd/pte loop is only done for address ranges that are
below the end address of the last vma of the address space. But this
is not always true, e.g. the generic page table walker does not guarantee
this. Change TASK_SIZE/TASK_SIZE_OF to reflect the current size of the
address space. This makes the generic page table walker happy but it
breaks the upgrade of a 3 level page table to a 4 level page table.
To make the upgrade work again another fix is required.
Add support for different number of page table levels dependent
on the highest address used for a process. This will cause a 31 bit
process to use a two level page table instead of the four level page
table that is the default after the pud has been introduced. Likewise
a normal 64 bit process will use three levels instead of four. Only
if a process runs out of the 4 tera bytes which can be addressed with
a three level page table the fourth level is dynamically added. Then
the process can use up to 8 peta byte.
Sanitize some s390 Kconfig options. We have ARCH_S390, ARCH_S390X,
ARCH_S390_31, 64BIT, S390_SUPPORT and COMPAT. Replace these 6 options by
S390, 64BIT and COMPAT.
infrastructure for it.
Let it rip!
