path: root/arch/s390/math-emu
2008-04-30[S390] remove -traditionalMathieu Desnoyers
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> CC: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-02-05[S390] Calibrate delay and bogomips.Martin Schwidefsky
Preset the bogomips number to the cpu capacity value reported by store system information in SYSIB 1.2.2. This value is constant for a particular machine model and can be used to determine relative performance differences between machines. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-09-28[S390] Inline assembly cleanup.Martin Schwidefsky
Major cleanup of all s390 inline assemblies. They now have a common coding style. Quite a few have been shortened, mainly by using register asm variables. Use of the EX_TABLE macro helps as well. The atomic ops, bit ops and locking inlines new use the Q-constraint if a newer gcc is used. That results in slightly better code. Thanks to Christian Borntraeger for proof reading the changes. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
