path: root/arch/s390/lib/uaccess_mvcos.c
2009-12-07[S390] Improve address space mode selection.Martin Schwidefsky
Introduce user_mode to replace the two variables switch_amode and s390_noexec. There are three valid combinations of the old values: 1) switch_amode == 0 && s390_noexec == 0 2) switch_amode == 1 && s390_noexec == 0 3) switch_amode == 1 && s390_noexec == 1 They get replaced by 1) user_mode == HOME_SPACE_MODE 2) user_mode == PRIMARY_SPACE_MODE 3) user_mode == SECONDARY_SPACE_MODE The new kernel parameter user_mode=[primary,secondary,home] lets you choose the address space mode the user space processes should use. In addition the CONFIG_S390_SWITCH_AMODE config option is removed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-10-06[S390] Add EX_TABLE for addressing exception in usercopy functions.Gerald Schaefer
This patch adds an EX_TABLE entry to mvc{p|s|os} usercopy functions that may be called with KERNEL_DS. In combination with collaborative memory management, kernel pages marked as unused may trigger an adressing exception in the usercopy functions. This fixes an unhandled addressing exception bug where strncpy_from_user() is used with len > strnlen and KERNEL_DS, crossing a page boundary to an unused page. Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-04-30[S390] uaccess_mvcos: #ifdef config dependent code.Heiko Carstens
arch/s390/lib/uaccess_mvcos.c:166: warning: 'strnlen_user_mvcos' defined but not used arch/s390/lib/uaccess_mvcos.c:186: warning: 'strncpy_from_user_mvcos' defined but not used Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-02-05[S390] noexec protectionGerald Schaefer
This provides a noexec protection on s390 hardware. Our hardware does not have any bits left in the pte for a hw noexec bit, so this is a different approach using shadow page tables and a special addressing mode that allows separate address spaces for code and data. As a special feature of our "secondary-space" addressing mode, separate page tables can be specified for the translation of data addresses (storage operands) and instruction addresses. The shadow page table is used for the instruction addresses and the standard page table for the data addresses. The shadow page table is linked to the standard page table by a pointer in page->lru.next of the struct page corresponding to the page that contains the standard page table (since page->private is not really private with the pte_lock and the page table pages are not in the LRU list). Depending on the software bits of a pte, it is either inserted into both page tables or just into the standard (data) page table. Pages of a vma that does not have the VM_EXEC bit set get mapped only in the data address space. Any try to execute code on such a page will cause a page translation exception. The standard reaction to this is a SIGSEGV with two exceptions: the two system call opcodes 0x0a77 (sys_sigreturn) and 0x0aad (sys_rt_sigreturn) are allowed. They are stored by the kernel to the signal stack frame. Unfortunately, the signal return mechanism cannot be modified to use an SA_RESTORER because the exception unwinding code depends on the system call opcode stored behind the signal stack frame. This feature requires that user space is executed in secondary-space mode and the kernel in home-space mode, which means that the addressing modes need to be switched and that the noexec protection only works for user space. After switching the addressing modes, we cannot use the mvcp/mvcs instructions anymore to copy between kernel and user space. A new mvcos instruction has been added to the z9 EC/BC hardware which allows to copy between arbitrary address spaces, but on older hardware the page tables need to be walked manually. Signed-off-by: Gerald Schaefer <geraldsc@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-02-05[S390] Get rid of a lot of sparse warnings.Heiko Carstens
2006-12-04[S390] Add dynamic size check for usercopy functions.Gerald Schaefer
Use a wrapper for copy_to/from_user to chose the best usercopy method. The mvcos instruction is better for sizes greater than 256 bytes, if mvcos is not available a page table walk is better for sizes greater than 1024 bytes. Also removed the redundant copy_to/from_user_std_small functions. Signed-off-by: Gerald Schaefer <geraldsc@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-09-28[S390] user readable uninitialised kernel memory.Martin Schwidefsky
A user space program can read uninitialised kernel memory by appending to a file from a bad address and then reading the result back. The cause is the copy_from_user function that does not clear the remaining bytes of the kernel buffer after it got a fault on the user space address. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-09-20[S390] Use alternative user-copy operations for new hardware.Gerald Schaefer
This introduces new user-copy operations which are optimized for copying more than 256 Bytes on new hardware. Signed-off-by: Gerald Schaefer <geraldsc@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
