path: root/arch/s390/kernel/entry.h
2012-03-11[S390] irq: external interrupt code passingHeiko Carstens
The external interrupt handlers have a parameter called ext_int_code. Besides the name this paramter does not only contain the ext_int_code but in addition also the "cpu address" (POP) which caused the external interrupt. To make the code a bit more obvious pass a struct instead so the called function can easily distinguish between external interrupt code and cpu address. The cpu address field however is named "subcode" since some external interrupt sources do not pass a cpu address but a different parameter (or none at all). Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-03-11[S390] rework idle codeMartin Schwidefsky
Whenever the cpu loads an enabled wait PSW it will appear as idle to the underlying host system. The code in default_idle calls vtime_stop_cpu which does the necessary voodoo to get the cpu time accounting right. The udelay code just loads an enabled wait PSW. To correct this rework the vtime_stop_cpu/vtime_start_cpu logic and move the difficult parts to entry[64].S, vtime_stop_cpu can now be called from anywhere and vtime_start_cpu is gone. The correction of the cpu time during wakeup from an enabled wait PSW is done with a critical section in entry[64].S. As vtime_start_cpu is gone, s390_idle_check can be removed as well. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-03-11[S390] rework smp codeMartin Schwidefsky
Define struct pcpu and merge some of the NR_CPUS arrays into it, including __cpu_logical_map, current_set and smp_cpu_state. Split smp related functions to those operating on physical cpus and the functions operating on a logical cpu number. Make the functions for physical cpus use a pointer to a struct pcpu. This hides the knowledge about cpu addresses in smp.c, entry[64].S and swsusp_asm64.S, thus remove the sigp.h header. The PSW restart mechanism is used to start secondary cpus, calling a function on an online cpu, calling a function on the ipl cpu, and for the nmi signal. Replace the different assembler functions with a single function restart_int_handler. The new entry point calls a function whose pointer is stored in the lowcore of the target cpu and it can wait for the source cpu to stop. This covers all existing use cases. Overall the code is now simpler and there are ~380 lines less code. Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-12-27[S390] cleanup trap handlingMartin Schwidefsky
Move the program interruption code and the translation exception identifier to the pt_regs structure as 'int_code' and 'int_parm_long' and make the first level interrupt handler in entry[64].S store the two values. That makes it possible to drop 'prot_addr' and 'trap_no' from the thread_struct and to reduce the number of arguments to a lot of functions. Finally un-inline do_trap. Overall this saves 5812 bytes in the .text section of the 64 bit kernel. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-10-30[S390] sparse: fix sparse warnings about missing prototypesMartin Schwidefsky
Add prototypes and includes for functions used in different modules. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-07-24[S390] cleanup program check handler prototypesMartin Schwidefsky
2011-01-05[S390] ptrace cleanupMartin Schwidefsky
Overhaul program event recording and the code dealing with the ptrace user space interface. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-10-25[S390] cleanup lowcore access from external interruptsMartin Schwidefsky
Read external interrupts parameters from the lowcore in the first level interrupt handler in entry[64].S. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-10-25[S390] cleanup lowcore access from program checksMartin Schwidefsky
Read all required fields for program checks from the lowcore in the first level interrupt handler in entry[64].S. If the context that caused the fault was enabled for interrupts we can now re-enable the irqs in entry[64].S. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-08-24[S390] s390: fix build error (sys_execve)Sebastian Ott
fix this build error: arch/s390/kernel/process.c:272: error: conflicting types for 'sys_execve' arch/s390/kernel/entry.h:45: error: previous declaration of 'sys_execve' was here make[1]: *** [arch/s390/kernel/process.o] Error 1 make: *** [arch/s390/kernel] Error 2 introduced by d7627467b7a8dd6944885290a03a07ceb28c10eb Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-08-13Mark arguments to certain syscalls as being constDavid Howells
Mark arguments to certain system calls as being const where they should be but aren't. The list includes: (*) The filename arguments of various stat syscalls, execve(), various utimes syscalls and some mount syscalls. (*) The filename arguments of some syscall helpers relating to the above. (*) The buffer argument of various write syscalls. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-13[S390] sys_personality: follow u_long to unsigned int conversionHeiko Carstens
commit 485d527686850d68a0e9006dd9904f19f122485e "sys_personality: change sys_personality() to accept "unsigned int" instead of u_long" changed the syscall interface for sys_personality. Just follow the common code change in our arch code to avoid confusion. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-03-12improve sys_newuname() for compat architecturesChristoph Hellwig
On an architecture that supports 32-bit compat we need to override the reported machine in uname with the 32-bit value. Instead of doing this separately in every architecture introduce a COMPAT_UTS_MACHINE define in <asm/compat.h> and apply it directly in sys_newuname(). Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12Add generic sys_ipc wrapperChristoph Hellwig
Add a generic implementation of the ipc demultiplexer syscall. Except for s390 and sparc64 all implementations of the sys_ipc are nearly identical. There are slight differences in the types of the parameters, where mips and powerpc as the only 64-bit architectures with sys_ipc use unsigned long for the "third" argument as it gets casted to a pointer later, while it traditionally is an "int" like most other paramters. frv goes even further and uses unsigned long for all parameters execept for "ptr" which is a pointer type everywhere. The change from int to unsigned long for "third" and back to "int" for the others on frv should be fine due to the in-register calling conventions for syscalls (we already had a similar issue with the generic sys_ptrace), but I'd prefer to have the arch maintainers looks over this in details. Except for that h8300, m68k and m68knommu lack an impplementation of the semtimedop sub call which this patch adds, and various architectures have gets used - at least on i386 it seems superflous as the compat code on x86-64 and ia64 doesn't even bother to implement it. [akpm@linux-foundation.org: add sys_ipc to sys_ni.c] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12Add generic sys_old_mmap()Christoph Hellwig
Add a generic implementation of the old mmap() syscall, which expects its argument in a memory block and switch all architectures over to use it. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12Add generic sys_old_select()Christoph Hellwig
Add a generic implementation of the old select() syscall, which expects its argument in a memory block and switch all architectures over to use it. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Acked-by: Andreas Schwab <schwab@linux-m68k.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: David Howells <dhowells@redhat.com> Cc: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22[S390] Convert sys_execve to function with parameters.Heiko Carstens
Use function parameters instead of accessing the pt_regs structure to get the parameters. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-09-22[S390] Convert sys_clone to function with parameters.Heiko Carstens
Use function parameters instead of accessing the pt_regs structure to get the parameters. Also merge the 31 and 64 bit versions since they are identical. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-01-14[CVE-2009-0029] s390 specific system call wrappersHeiko Carstens
2009-01-14[CVE-2009-0029] Remove __attribute__((weak)) from sys_pipe/sys_pipe2Heiko Carstens
Remove __attribute__((weak)) from common code sys_pipe implemantation. IA64, ALPHA, SUPERH (32bit) and SPARC (32bit) have own implemantations with the same name. Just rename them. For sys_pipe2 there is no architecture specific implementation. Cc: Richard Henderson <rth@twiddle.net> Cc: David S. Miller <davem@davemloft.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-09[S390] remove code for oldselect system callHeiko Carstens
The system call isn't wired up on s390. Just delete the dead code. Also we use the common code sys_ptrace system call, so the sys_ptrace declaration is pointless is well. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-04-17[S390] Fix a lot of sparse warnings.Heiko Carstens
Most noteable part of this commit is the new local header file entry.h which contains all the function declarations of functions that get only called from asm code or are arch internal. That way we can avoid extern declarations in C files. This is more or less the same that was done for sparc64. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
