path: root/arch/s390/defconfig
2008-08-21[S390] Update default configuration.Martin Schwidefsky
2008-05-30[S390] Update default configuration.Martin Schwidefsky
2008-04-30[S390] Update default configuration.Martin Schwidefsky
2008-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6.26Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6.26: (1090 commits) [NET]: Fix and allocate less memory for ->priv'less netdevices [IPV6]: Fix dangling references on error in fib6_add(). [NETLABEL]: Fix NULL deref in netlbl_unlabel_staticlist_gen() if ifindex not found [PKT_SCHED]: Fix datalen check in tcf_simp_init(). [INET]: Uninline the __inet_inherit_port call. [INET]: Drop the inet_inherit_port() call. SCTP: Initialize partial_bytes_acked to 0, when all of the data is acked. [netdrvr] forcedeth: internal simplifications; changelog removal phylib: factor out get_phy_id from within get_phy_device PHY: add BCM5464 support to broadcom PHY driver cxgb3: Fix __must_check warning with dev_dbg. tc35815: Statistics cleanup natsemi: fix MMIO for PPC 44x platforms [TIPC]: Cleanup of TIPC reference table code [TIPC]: Optimized initialization of TIPC reference table [TIPC]: Remove inlining of reference table locking routines e1000: convert uint16_t style integers to u16 ixgb: convert uint16_t style integers to u16 sb1000.c: make const arrays static sb1000.c: stop inlining largish static functions ...
2008-04-17[S390] cpu topology support for s390.Heiko Carstens
Add s390 backend so we can give the scheduler some hints about the cpu topology. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-03-17qeth: new qeth device driverFrank Blaschka
List of major changes and improvements: no manipulation of the global ARP constructor clean code split into core, layer 2 and layer 3 functionality better exploitation of the ethtool interface better representation of the various hardware capabilities fix packet socket support (tcpdump), no fake_ll required osasnmpd notification via udev events coding style and beautification Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-05[S390] Update default configuration.Martin Schwidefsky
2008-02-09[S390] Update default configuration.Martin Schwidefsky
2007-10-22[S390] Update default configuration.Martin Schwidefsky
2007-07-17[S390] z/VM unit record device driverFrank Munzert
z/VM Unit record character device driver to access VM reader, punch, and printer. Signed-off-by: Frank Munzert <munzert@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-07-17[S390] Update default configuration.Martin Schwidefsky
2007-05-10[S390] update default configuration.Martin Schwidefsky
2007-04-27[S390] zfcpdump support.Michael Holzheu
s390 machines provide hardware support for creating Linux dumps on SCSI disks. For creating a dump a special purpose dump Linux is used. The first 32 MB of memory are saved by the hardware before the dump Linux is booted. Via an SCLP interface, the saved memory can be accessed from Linux. This patch exports memory and registers of the crashed Linux to userspace via a debugfs file. For more information refer to Documentation/s390/zfcpdump.txt, which is included in this patch. Signed-off-by: Michael Holzheu <holzheu@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2007-04-27[S390] Use generic bug.Heiko Carstens
Generic bug implementation for s390. Will increase the value of the console output on BUG() statements since registers r0-r5,r14 will not be clobbered by a printk() call that was previously done before the illegal instruction of BUG() was hit. Also implements an architecture specific WARN_ON(). Output of that could be increased but requires common code change. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2007-02-21[S390] update default configurationMartin Schwidefsky
2007-02-08[S390]: Add AF_IUCV socket supportJennifer Hunt
From: Jennifer Hunt <jenhunt@us.ibm.com> This patch adds AF_IUCV socket support. Signed-off-by: Frank Pavlic <fpavlic@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[S390]: Rewrite of the IUCV base code, part 2Martin Schwidefsky
Add rewritten IUCV base code to net/iucv. Signed-off-by: Frank Pavlic <fpavlic@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[S390]: Rewrite of the IUCV base code, part 1Martin Schwidefsky
Remove the old IUCV code from drivers/s390/net Remove approprirate IUCV entries from drivers/s390/net/Makefile, drivers/s390/net/Kconfig and arch/s390/defconfig Signed-off-by: Frank Pavlic <fpavlic@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-05[S390] Convert memory detection into C code.Heiko Carstens
Hopefully this will make it more maintainable and less error prone. Code makes use of search_exception_tables(). Since it calls this function before the kernel exeception table is sorted, there is an early call to sort_main_extable(). This way it's easy to use the already present infrastructure of fixup sections. Also this would allows to easily convert the rest of head[31|64].S into C code. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-02-05[S390] Support for s390 Pseudo Random Number GeneratorJan Glauber
Starting with the z9 the CPU Cryptographic Assist Facility comes with an integrated Pseudo Random Number Generator. The generator creates random numbers by an algorithm similar to the ANSI X9.17 standard. The pseudo-random numbers can be accessed via a character device driver node called /dev/prandom. Similar to /dev/urandom any amount of bytes can be read from the device without blocking. Signed-off-by: Jan Glauber <jan.glauber@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-02-05[S390] noexec protectionGerald Schaefer
This provides a noexec protection on s390 hardware. Our hardware does not have any bits left in the pte for a hw noexec bit, so this is a different approach using shadow page tables and a special addressing mode that allows separate address spaces for code and data. As a special feature of our "secondary-space" addressing mode, separate page tables can be specified for the translation of data addresses (storage operands) and instruction addresses. The shadow page table is used for the instruction addresses and the standard page table for the data addresses. The shadow page table is linked to the standard page table by a pointer in page->lru.next of the struct page corresponding to the page that contains the standard page table (since page->private is not really private with the pte_lock and the page table pages are not in the LRU list). Depending on the software bits of a pte, it is either inserted into both page tables or just into the standard (data) page table. Pages of a vma that does not have the VM_EXEC bit set get mapped only in the data address space. Any try to execute code on such a page will cause a page translation exception. The standard reaction to this is a SIGSEGV with two exceptions: the two system call opcodes 0x0a77 (sys_sigreturn) and 0x0aad (sys_rt_sigreturn) are allowed. They are stored by the kernel to the signal stack frame. Unfortunately, the signal return mechanism cannot be modified to use an SA_RESTORER because the exception unwinding code depends on the system call opcode stored behind the signal stack frame. This feature requires that user space is executed in secondary-space mode and the kernel in home-space mode, which means that the addressing modes need to be switched and that the noexec protection only works for user space. After switching the addressing modes, we cannot use the mvcp/mvcs instructions anymore to copy between kernel and user space. A new mvcos instruction has been added to the z9 EC/BC hardware which allows to copy between arbitrary address spaces, but on older hardware the page tables need to be walked manually. Signed-off-by: Gerald Schaefer <geraldsc@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-02-05[S390] move crypto options and some cleanup.Jan Glauber
This patch moves the config options for the s390 crypto instructions to the standard "Hardware crypto devices" menu. In addition some cleanup has been done: use a flag for supported keylengths, add a warning about machien limitation, return ENOTSUPP in case the hardware has no support, remove superfluous printks and update email addresses. Signed-off-by: Jan Glauber <jan.glauber@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-15[S390] update default configurationMartin Schwidefsky
2006-12-08[S390] runtime switch for qdio performance statisticsUrsula Braun
Remove CONFIG_QETH_PERF_STATS and use a sysfs attribute instead. We want to have the ability to turn the statistics on/off at runtime. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-11-06[S390] revert add_active_range() usage patch.Heiko Carstens
Commit 7676bef9c183fd573822cac9992927ef596d584c breaks DCSS support on s390. DCSS needs initialized struct pages to work. With the usage of add_active_range() only the struct pages for physically present pages are initialized. This could be fixed if the DCSS driver would initiliaze the struct pages itself, but this doesn't work too. This is because the mem_map array does not include holes after the last present memory area and therefore there is nothing that could be initialized. To fix this and to avoid some dirty hacks revert this patch for now. Will be added later when we move to a virtual mem_map. Cc: Carsten Otte <cotte@de.ibm.com> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-10-18[S390] update default configurationMartin Schwidefsky
2006-10-06[S390] Use CONFIG_GENERIC_TIME and define TOD clock source.Martin Schwidefsky
Fix too slow clock by using CONFIG_GENERIC_TIME and adding a clock source for the s390 time-of-day clock. As added benefit we get rid of the s390 specific definition of do_gettimeofday and do_settimeofday. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-10-04[S390] Have s390 use add_active_range() and free_area_init_nodes.Heiko Carstens
Size zones and holes in an architecture independent manner for s390. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2006-10-04[S390] update default configurationMartin Schwidefsky
2006-09-20[S390] Linux API for writing z/VM APPLDATA Monitor records.Melissa Howland
This patch delivers a new Linux API in the form of a misc char device that is useable from user space and allows write access to the z/VM APPLDATA Monitor Records collected by the *MONITOR System Service of z/VM. Signed-off-by: Melissa Howland <melissah@us.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-07-27[S390] update default configurationMartin Schwidefsky
2006-04-11[PATCH] s390: update default configurationMartin Schwidefsky
Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-11[PATCH] s390: update default configurationHeiko Carstens
Switch on CONFIG_DEBUG_FS again. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] s390: New default configurationHeiko Carstens
New default configuration. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] s390: cleanup KconfigMartin Schwidefsky
Sanitize some s390 Kconfig options. We have ARCH_S390, ARCH_S390X, ARCH_S390_31, 64BIT, S390_SUPPORT and COMPAT. Replace these 6 options by S390, 64BIT and COMPAT. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] s390: aes supportJan Glauber
Add support for the hardware accelerated AES crypto algorithm. Signed-off-by: Jan Glauber <jan.glauber@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] s390: sha256 supportJan Glauber
Add support for the hardware accelerated sha256 crypto algorithm. Signed-off-by: Jan Glauber <jan.glauber@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] s390: in-kernel crypto renameJan Glauber
Replace all references to z990 by s390 in the in-kernel crypto files in arch/s390/crypto. The code is not specific to a particular machine (z990) but to the s390 platform. Big diff, does nothing.. Signed-off-by: Jan Glauber <jan.glauber@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] s390: update default configurationMartin Schwidefsky
2005-09-17[PATCH] s390: default configurationMartin Schwidefsky
Update default configuration of s390. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-29[PATCH] s390: default configurationMartin Schwidefsky
2005-06-25[PATCH] s390: add vmcp interfaceChristian Borntraeger
Add interface to issue VM control program commands. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] s390: regenerate defconfigMartin Schwidefsky
Regenerate the default configuration for s390. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
