path: root/arch/s390/appldata/appldata_os.c
2010-06-08[S390] appldata/extmem/kvm: add missing GFP_KERNEL flagHeiko Carstens
Add missing GFP flag to memory allocations. The part in cio only changes a comment. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] convert appldata printks to pr_xxx macros.Gerald Schaefer
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-07-14[S390] Cleanup appldata printk messages.Gerald Schaefer
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2007-11-20[S390] appldata: remove unused binary sysctls.Heiko Carstens
Remove binary sysctls that never worked due to missing strategy functions. Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Gerald Schaefer <geraldsc@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-09-20[S390] cleanup appldata.Gerald Schaefer
Introduce asm header that contains the appldata data structures and the diag inline assembly. Signed-off-by: Gerald Schaefer <geraldsc@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-06-29[S390] appldata enhancements.Gerald Schaefer
Add CPU ID and steal time, and make OS record size variable. Signed-off-by: Gerald Schaefer <geraldsc@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-01-06[PATCH] s390: cputime_t fixesMartin Schwidefsky
There are some more places where the use of cputime_t instead of an integer type and the associated macros is necessary for the virtual cputime accounting on s390. Affected are the s390 specific appldata code and BSD process accounting. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-04[PATCH] s390: deadlock in appldataGerald Schaefer
The system might hang when using appldata_mem with high I/O traffic and a large number of devices. The spinlocks bdev_lock and swaplock are acquired via calls to si_meminfo() and si_swapinfo() from a tasklet, i.e. interrupt context, which can lead to a deadlock. Replace tasklet with work queue. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
