path: root/arch/ppc
2008-01-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6.25Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6.25: (1470 commits) [IPV6] ADDRLABEL: Fix double free on label deletion. [PPP]: Sparse warning fixes. [IPV4] fib_trie: remove unneeded NULL check [IPV4] fib_trie: More whitespace cleanup. [NET_SCHED]: Use nla_policy for attribute validation in ematches [NET_SCHED]: Use nla_policy for attribute validation in actions [NET_SCHED]: Use nla_policy for attribute validation in classifiers [NET_SCHED]: Use nla_policy for attribute validation in packet schedulers [NET_SCHED]: sch_api: introduce constant for rate table size [NET_SCHED]: Use typeful attribute parsing helpers [NET_SCHED]: Use typeful attribute construction helpers [NET_SCHED]: Use NLA_PUT_STRING for string dumping [NET_SCHED]: Use nla_nest_start/nla_nest_end [NET_SCHED]: Propagate nla_parse return value [NET_SCHED]: act_api: use PTR_ERR in tcf_action_init/tcf_action_get [NET_SCHED]: act_api: use nlmsg_parse [NET_SCHED]: act_api: fix netlink API conversion bug [NET_SCHED]: sch_netem: use nla_parse_nested_compat [NET_SCHED]: sch_atm: fix format string warning [NETNS]: Add namespace for ICMP replying code. ...
2008-01-28[netdrvr] irq handler minor cleanups in several driversJeff Garzik
* use irq_handler_t where appropriate * no need to use 'irq' function arg, its already stored in a data struct * rename irq handler 'irq' argument to 'dummy', where the function has been analyzed and proven not to use its first argument. * remove always-false "dev_id == NULL" test from irq handlers * remove pointless casts from void* * declance: irq argument is not const * add KERN_xxx printk prefix * fix minor whitespace weirdness Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-01-28all archs: consolidate init and exit sections in vmlinux.lds.hSam Ravnborg
This patch consolidate all definitions of .init.text, .init.data and .exit.text, .exit.data section definitions in the generic vmlinux.lds.h. This is a preparational patch - alone it does not buy us much good. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28[PPC] Remove 85xx from arch/ppcKumar Gala
85xx exists in arch/powerpc as well as cuImage support to boot from a u-boot that doesn't support device trees. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-28[PPC] Remove 83xx from arch/ppcKumar Gala
83xx exists in arch/powerpc as well as cuImage support to boot from a u-boot that doesn't support device trees. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-28[POWERPC] CPM: Rename commproc to cpm1 and cpm2_common.c to cpm2.cJochen Friedrich
Rename commproc.[ch] to cpm1.[ch] to be more consistent with cpm2. Also rename cpm2_common.c to cpm2.c as suggested by Scott Wood. Adjust the includes accordingly. Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-28[POWERPC] 8xx: Rename m8xx_pic_init to mpc8xx_pics_initJochen Friedrich
m8xx_pic_init calls both mpc8xx_pic_init and cpm_pic_init. Renaming the function to use the same name space as the rest of the mpc8xx specific funtions and to be more meaningful. m8xx_pic_init is declared in ppc8xx_pic.h but defined nowhere in the ppc tree. Remove it. Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-28[POWERPC] 8xx: Remove unused m8xx_cpm_hostalloc/free/dump()Jochen Friedrich
m8xx_cpm_hostalloc is still defined in commproc.c, but no users are left in the kernel tree. m8xx_cpm_hostfree and m8xx_cpm_hostdump are only defined in the headers. Remove this dead code. Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-28Merge branch 'orion' into develRussell King
* orion: (26 commits) [ARM] Orion: implement power-off method for QNAP TS-109/209 [ARM] Orion: add support for QNAP TS-109/TS-209 [ARM] Orion: I2C support [I2C] i2c-mv64xxx: Don't set i2c_adapter.retries [I2C] Split mv643xx I2C platform support [ARM] Orion: enable CONFIG_RTC_DRV_M41T80 for D-Link DNS-323 [ARM] Orion defconfig [ARM] Orion: add support for Orion/MV88F5181 based D-Link DNS-323 [ARM] Orion: MV88F5181 support bits [ARM] Orion: Buffalo/Revogear Kurobox Pro support [ARM] OrionNAS RD board support [ARM] Orion: support for Marvell Orion-2 (88F5281) Development Board [ARM] Orion: common platform setup for Gigabit Ethernet port [ARM] Orion: platform device registration for UART, USB and NAND [ARM] Orion: system timer support [ARM] Orion edge GPIO IRQ support [ARM] Orion: IRQ support [ARM] Orion: provide GPIO method for enabling hardware assisted blinking [ARM] Orion: GPIO support [ARM] Orion: programable address map support ... Conflicts: arch/arm/Kconfig arch/arm/Makefile Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-27i2c: the scheduled I2C RTC driver removalAdrian Bunk
This patch contains the scheduled removal of legacy I2C RTC drivers with replacement drivers. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-26[POWERPC] Add common clock setting routine mpc52xx_psc_set_clkdiv()Grant Likely
PSC drivers should not access the CDM registers directly. Instead provide a common routine for setting the PSC clock parameters with the required locking. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-01-26[I2C] i2c-mv64xxx: Don't set i2c_adapter.retriesJean Delvare
I2C adapter drivers are supposed to handle retries on nack by themselves if they do, so there's no point in setting .retries if they don't. As this retry mechanism is going away (at least in its current form), clean this up now so that we don't get build failures later. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Mark A. Greer <mgreer@mvista.com>
2008-01-24Driver core: change sysdev classes to use dynamic kobject namesKay Sievers
All kobjects require a dynamically allocated name now. We no longer need to keep track if the name is statically assigned, we can just unconditionally free() all kobject names on cleanup. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24sysctl: kill binary sysctl KERN_PPC_L2CREric W. Biederman
: Stefan Roese <sr@denx.de> said: > ppc: 4xx: sysctl table check failed: /kernel/l2cr .1.31 Missing strategy > > I'm seeing this error message when booting an recent arch/ppc kernel on > 4xx platforms (tested on Ocotea and other 4xx platforms). Booting NFS > rootfs still works fine, but this message kind of makes me "nervous". > This is not seen on 4xx arch/powerpc platforms. Here the bootlog: Because the data field was never filled and a binary sysctl handler was never written this sysctl has never been usable through the sys_sysctl interface. So just remove the binary sysctl number. Making the kernel sanity checks happy. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Reported-by: Stefan Roese <sr@denx.de> Cc: Josh Boyer <jwboyer@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-23[POWERPC] Move RapidIO support code from arch/ppcKumar Gala
Do just enough to move the RapidIO support code for 85xx over from arch/ppc into arch/powerpc and make it still build. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-23[POWERPC] 4xx: Fix TLB 0 problem with CONFIG_SERIAL_TEXT_DEBUGStefan Roese
Right now TLB entry 0 ist used as UART0 mapping for the early debug output (via CONFIG_SERIAL_TEXT_DEBUG). This causes problems when many TLB's get used upon Linux bootup (e.g. while PCIe scanning behind bridges and/or switches on 440SPe platforms). This will overwrite the TLB 0 entry and further debug output's may crash/hang the system. This patch moves the early debug UART0 TLB entry from 0 to 62 as done in arch/powerpc. This way it is in the "pinned" area and will not get overwritten. Also the arch/ppc/mm/44x_mmu.c code is now synced with the newer code from arch/powerpc. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-12-23[POWERPC] Reworking machine check handling and Fix 440/440ABenjamin Herrenschmidt
This adds a cputable function pointer for the CPU-side machine check handling. The semantic is still the same as the old one, the one in ppc_md. overrides the one in cputable, though ultimately we'll want to change that so the CPU gets first. This removes CONFIG_440A which was a problem for multiplatform kernels and instead fixes up the IVOR at runtime from a setup_cpu function. The "A" version of the machine check also tweaks the regs->trap value to differenciate the 2 versions at the C level. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-12-20[POWERPC] arch/ppc: Remove an unnecessary pci_dev_putJulia Lawall
Remove an unnecessary pci_dev_put. pci_dev_put is called implicitly by the subsequent call to pci_get_device. The problem was detected using the following semantic patch, and corrected by hand. @@ expression dev; expression E; @@ - pci_dev_put(dev) ... when != dev = E - pci_get_device(...,dev) Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-20[POWERPC] arch/ppc: Remove duplicate includesLucas Woods
Signed-off-by: Lucas Woods <woodzy@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-20[POWERPC] Don't cast a struct pointer to list_head pointerLi Zefan
The casting is safe only when the list_head member is the first member of the structure, and even then it is better to use the address of the list_head structure member. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-20[POWERPC] arch/ppc/: Spelling fixesjoe@perches.com
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-10Merge branch 'linux-2.6'Paul Mackerras
2007-12-07[POWERPC] virtex bug fix: Use canonical value for AC97 interrupt xparamsGrant Likely
The ml300 and ml403 xparameters.h files use different macros for the AC97 interrupt pin assignments. This normalizes them to a canonical value similar to what EDK generates for most other devices. This is needed to get ml300 support to compile in arch/ppc. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-03[POWERPC] Add missing spaces in printk formats in arch/ppcjoe@perches.com
2007-12-03[POWERPC] Remove xmon from ml300 and ml403 defconfig in arch/ppcGrant Likely
xmon is broken under arch/ppc so remove it from the defconfig. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-11-20[POWERPC] Fix 8xx build breakage due to _tlbie changesBenjamin Herrenschmidt
My changes to _tlbie to fix 4xx unfortunately broke 8xx build in a couple of places. This fixes it. Spotted by Olof Johansson. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Vitaly Bordug <vitb@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-11-20Merge branch 'for-2.6.24' of ↵Paul Mackerras
master.kernel.org:/pub/scm/linux/kernel/git/jwboyer/powerpc-4xx into merge
2007-11-19[POWERPC] 4xx: Use virtual PVR value to init FPU on arch/ppc 440EPJosh Boyer
This fixes arch/ppc 440EP platforms to setup the FPU correctly. A virtual PVR is used, as 440GR platforms share an identical hardware PVR value and do not have an FPU. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-11-19[POWERPC] 4xx: balance ioremap/ioumap calls for YuccaRoel Kluin
Call iounmap before returning from an error case. Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-11-19[POWERPC] Xilinx: Register AC97 Controller Reference with the platform busJoachim Foerster
Add AC97 platform bus registration for Xilinx Virtex platforms. Signed-off-by: Joachim Foerster <JOFT@gmx.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-11-13[POWERPC] Avoid unpaired stwcx. on some processorsBecky Bruce
The context switch code in the kernel issues a dummy stwcx. to clear the reservation, as recommended by the architecture. However, some processors can have issues if this stwcx to address A occurs while the reservation is already held to a different address B. To avoid this problem, the dummy stwcx. needs to be paired with a dummy lwarx to the same address. This adds the dummy lwarx, and creates a cpu feature bit to indicate which cpus are affected. Tested on mpc8641_hpcn_defconfig in arch/powerpc; build tested in arch/ppc. Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-11-08Merge branch 'for-2.6.24' of ↵Paul Mackerras
2007-11-08[POWERPC] i8259: Add disable methodAurelien Jarno
Since commit 76d2160147f43f982dfe881404cfde9fd0a9da21, the NE2000 card is not working anymore on PPC and POWERPC and produces WATCHDOG timeouts. The patch below fixes that the same way it has been done on x86, x86_64 and MIPS. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-11-08[POWERPC] Fix build break in arch/ppc/syslib/m8260_setup.cOlof Johansson
Fix build break and warnings in current mainline git: arch/ppc/syslib/m8260_setup.c: In function 'm8260_setup_arch': arch/ppc/syslib/m8260_setup.c:63: error: implicit declaration of function 'identify_ppc_sys_by_name_and_id' arch/ppc/syslib/m8260_setup.c:64: warning: passing argument 1 of 'in_be32' makes pointer from integer without a cast arch/ppc/syslib/m8260_setup.c: In function 'm8260_show_cpuinfo': arch/ppc/syslib/m8260_setup.c:158: warning: format '%08x' expects type 'unsigned int', but argument 5 has type 'long unsigned int' arch/ppc/syslib/m8260_setup.c:158: warning: format '%d' expects type 'int', but argument 6 has type 'long unsigned int' arch/ppc/syslib/m8260_setup.c:158: warning: format '%u' expects type 'unsigned int', but argument 7 has type 'long unsigned int' arch/ppc/syslib/m8260_setup.c:158: warning: format '%u' expects type 'unsigned int', but argument 8 has type 'long unsigned int' arch/ppc/syslib/m8260_setup.c:158: warning: format '%u' expects type 'unsigned int', but argument 9 has type 'long unsigned int' make[1]: *** [arch/ppc/syslib/m8260_setup.o] Error 1 make[1]: *** Waiting for unfinished jobs.... Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-11-01[POWERPC] ppc405 Fix arithmatic rollover bug when memory size under 16MGrant Likely
mmu_mapin_ram() loops over total_lowmem to setup page tables. However, if total_lowmem is less that 16M, the subtraction rolls over and results in a number just under 4G (because total_lowmem is an unsigned value). This patch rejigs the loop from countup to countdown to eliminate the bug. Special thanks to Magnus Hjorth who wrote the original patch to fix this bug. This patch improves on his by making the loop code simpler (which also eliminates the possibility of another rollover at the high end) and also applies the change to arch/powerpc. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-11-01[POWERPC] 4xx: Deal with 44x virtually tagged icacheBenjamin Herrenschmidt
The 44x family has an interesting "feature" which is a virtually tagged instruction cache (yuck !). So far, we haven't dealt with it properly, which means we've been mostly lucky or people didn't report the problems, unless people have been running custom patches in their distro... This is an attempt at fixing it properly. I chose to do it by setting a global flag whenever we change a PTE that was previously marked executable, and flush the entire instruction cache upon return to user space when that happens. This is a bit heavy handed, but it's hard to do more fine grained flushes as the icbi instruction, on those processor, for some very strange reasons (since the cache is virtually mapped) still requires a valid TLB entry for reading in the target address space, which isn't something I want to deal with. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-11-01[POWERPC] 4xx: Fix 4xx flush_tlb_page()Benjamin Herrenschmidt
On 4xx CPUs, the current implementation of flush_tlb_page() uses a low level _tlbie() assembly function that only works for the current PID. Thus, invalidations caused by, for example, a COW fault triggered by get_user_pages() from a different context will not work properly, causing among other things, gdb breakpoints to fail. This patch adds a "pid" argument to _tlbie() on 4xx processors, and uses it to flush entries in the right context. FSL BookE also gets the argument but it seems they don't need it (their tlbivax form ignores the PID when invalidating according to the document I have). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-11-01[POWERPC] allocation fix in ppc/platforms/4xx/luan.cRoel Kluin
Don't allocate hose2 when when hose1 can't be allocated and free hose1 when hose2 can't be allocated. Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-10-20kbuild: restore arch/{ppc/xtensa}/boot cflagsMilton Miller
Commit 9a39e273d4df0560c724c5fe71f6314a0583ca2b removed the boot directory addition to CFLAGS that was being used by the subdirectory builds. For the other files, that patch set EXTRA_CFLAGS, but Makefile.build explicitly sets that to empty as it is explicitly for a single directory only. Append to KBUILD_CFLAGS instead. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-19Combine instrumentation menus in kernel/Kconfig.instrumentationMathieu Desnoyers
Quoting Randy: "It seems sad that this patch sources Kconfig.marker, a 7-line file, 20-something times. Yes, you (we) don't want to put those 7 lines into 20-something different files, so sourcing is the right thing. However, what you did for avr32 seems more on the right track to me: make _one_ Instrumentation support menu that includes PROFILING, OPROFILE, KPROBES, and MARKERS and then use (source) that in all of the arches." Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19define global BIT macroJiri Slaby
define global BIT macro move all local BIT defines to the new globally define macro. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Russell King <rmk@arm.linux.org.uk> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: define is_global_init() and is_container_init()Serge E. Hallyn
is_init() is an ambiguous name for the pid==1 check. Split it into is_global_init() and is_container_init(). A cgroup init has it's tsk->pid == 1. A global init also has it's tsk->pid == 1 and it's active pid namespace is the init_pid_ns. But rather than check the active pid namespace, compare the task structure with 'init_pid_ns.child_reaper', which is initialized during boot to the /sbin/init process and never changes. Changelog: 2.6.22-rc4-mm2-pidns1: - Use 'init_pid_ns.child_reaper' to determine if a given task is the global init (/sbin/init) process. This would improve performance and remove dependence on the task_pid(). 2.6.21-mm2-pidns2: - [Sukadev Bhattiprolu] Changed is_container_init() calls in {powerpc, ppc,avr32}/traps.c for the _exception() call to is_global_init(). This way, we kill only the cgroup if the cgroup's init has a bug rather than force a kernel panic. [akpm@linux-foundation.org: fix comment] [sukadev@us.ibm.com: Use is_global_init() in arch/m32r/mm/fault.c] [bunk@stusta.de: kernel/pid.c: remove unused exports] [sukadev@us.ibm.com: Fix capability.c to work with threaded init] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Acked-by: Pavel Emelianov <xemul@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Herbert Poetzel <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Merge branch 'for-2.6.24' of git://git.secretlab.ca/git/linux-2.6-mpc52xx ↵Paul Mackerras
into merge
2007-10-16[POWERPC] rheap: Changes config mechanismSylvain Munaut
Instead of having in the makefile all the option that requires rheap, we define a configuration symbol and when needed we make sure it's selected. Signed-off-by: Sylvain Munaut <tnt@246tNt.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-10-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (40 commits) kbuild: introduce ccflags-y, asflags-y and ldflags-y kbuild: enable 'make CPPFLAGS=...' to add additional options to CPP kbuild: enable use of AFLAGS and CFLAGS on commandline kbuild: enable 'make AFLAGS=...' to add additional options to AS kbuild: fix AFLAGS use in h8300 and m68knommu kbuild: check for wrong use of CFLAGS kbuild: enable 'make CFLAGS=...' to add additional options to CC kbuild: fix up CFLAGS usage kbuild: make modpost detect unterminated device id lists kbuild: call export_report from the Makefile kbuild: move Kai Germaschewski to CREDITS kconfig/menuconfig: distinguish between selected-by-another options and comments kconfig: tristate choices with mixed tristate and boolean values include/linux/Kbuild: remove duplicate entries kbuild: kill backward compatibility checks kbuild: kill EXTRA_ARFLAGS kbuild: fix documentation in makefiles.txt kbuild: call make once for all targets when O=.. is used kbuild: pass -g to assembler under CONFIG_DEBUG_INFO kbuild: update _shipped files for kconfig syntax cleanup ... Fix up conflicts in arch/um/sys-{x86_64,i386}/Makefile manually.
2007-10-16During VM oom condition, kill all threads in process groupWill Schmidt
We have had complaints where a threaded application is left in a bad state after one of it's threads is killed when we hit a VM: out_of_memory condition. Killing just one of the process threads can leave the application in a bad state, whereas killing the entire process group would allow for the application to restart, or be otherwise handled, and makes it very obvious that something has gone wrong. This change allows the entire process group to be taken down, rather than just the one thread. Signed-off-by: Will Schmidt <will_schmidt@vnet.ibm.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-15kbuild: enable 'make CPPFLAGS=...' to add additional options to CPPSam Ravnborg
The variable CPPFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. This patch replace use of CPPFLAGS with KBUILD_CPPFLAGS all over the tree and enabling one to use: make CPPFLAGS=... to specify additional CPP commandline options. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k, s390 Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-15kbuild: enable 'make AFLAGS=...' to add additional options to ASSam Ravnborg
The variable AFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. On top of that several people over time has asked for a way to pass in additional flags to gcc. This patch replace use of AFLAGS with KBUILD_AFLAGS all over the tree. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k, s390 Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-14kbuild: enable 'make CFLAGS=...' to add additional options to CCSam Ravnborg
The variable CFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. On top of that several people over time has asked for a way to pass in additional flags to gcc. This patch replace use of CFLAGS with KBUILD_CFLAGS all over the tree and enabling one to use: make CFLAGS=... to specify additional gcc commandline options. One usecase is when trying to find gcc bugs but other use cases has been requested too. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k Test was simple to do a defconfig build, apply the patch and check that nothing got rebuild. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-14kbuild: fix up CFLAGS usageSam Ravnborg
Only in very rare cases is it needed to change CFLAGS outside of arch/*/Makefile. Fix up all wrong cases - in most cases the use of EXTRA_CFLAGS is the only thing needed. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
