path: root/arch/ppc/platforms
2008-06-10powerpc: Remove arch/ppc and include/asm-ppcPaul Mackerras
All the maintained platforms are now in arch/powerpc, so the old arch/ppc stuff can now go away. Acked-by: Adrian Bunk <bunk@kernel.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Becky Bruce <becky.bruce@freescale.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Jochen Friedrich <jochen@scram.de> Acked-by: John Linn <john.linn@xilinx.com> Acked-by: Jon Loeliger <jdl@freescale.com> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Scott Wood <scottwood@freescale.com> Acked-by: Sean MacLennan <smaclennan@pikatech.com> Acked-by: Segher Boessenkool <segher@kernel.crashing.org> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-05-12[POWERPC] ppc: More compile fixesPaul Mackerras
This fixes a few more miscellaneous compile problems with ARCH=ppc. 1. Don't compile devres.c on ARCH=ppc, it doesn't have ioremap_flags. 2. Include <asm/irq.h> in setup.c for the __DO_IRQ_CANON definition. 3. Include <linux/proc_fs.h> in residual.c for the definition of create_proc_read_entry. 4. Fix xchg_ptr to be a static inline to eliminate a compiler warning. Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-29proper extern for late_time_initAdrian Bunk
Add a proper extern for late_time_init in include/linux/init.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-24Merge branch 'powerpc-next' of ↵Paul Mackerras
master.kernel.org:/pub/scm/linux/kernel/git/galak/powerpc
2008-04-21Merge branch 'irq-cleanups-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/misc-2.6 * 'irq-cleanups-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/misc-2.6: [ISDN] minor irq handler cleanups drivers/char: minor irq handler cleanups [PPC] minor irq handler cleanups [BLACKFIN] minor irq handler cleanups [SPARC] minor irq handler cleanups ARM minor irq handler cleanup: avoid passing unused info to irq
2008-04-21Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (202 commits) [POWERPC] Fix compile breakage for 64-bit UP configs [POWERPC] Define copy_siginfo_from_user32 [POWERPC] Add compat handler for PTRACE_GETSIGINFO [POWERPC] i2c: Fix build breakage introduced by OF helpers [POWERPC] Optimize fls64() on 64-bit processors [POWERPC] irqtrace support for 64-bit powerpc [POWERPC] Stacktrace support for lockdep [POWERPC] Move stackframe definitions to common header [POWERPC] Fix device-tree locking vs. interrupts [POWERPC] Make pci_bus_to_host()'s struct pci_bus * argument const [POWERPC] Remove unused __max_memory variable [POWERPC] Simplify xics direct/lpar irq_host setup [POWERPC] Use pseries_setup_i8259_cascade() in pseries_mpic_init_IRQ() [POWERPC] Turn xics_setup_8259_cascade() into a generic pseries_setup_i8259_cascade() [POWERPC] Move xics_setup_8259_cascade() into platforms/pseries/setup.c [POWERPC] Use asm-generic/bitops/find.h in bitops.h [POWERPC] 83xx: mpc8315 - fix USB UTMI Host setup [POWERPC] 85xx: Fix the size of qe muram for MPC8568E [POWERPC] 86xx: mpc86xx_hpcn - Temporarily accept old dts node identifier. [POWERPC] 86xx: mark functions static, other minor cleanups ...
2008-04-21[PPC] Remove mpc885ads and mpc86x ads boards from arch/ppcKumar Gala
We have a board port in arch/powerpc so we dont need this one anymore. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-21[PPC] Remove mpc8272 ads board from arch/ppcKumar Gala
2008-04-20[PPC] minor irq handler cleanupsJeff Garzik
- whitespace cleanups - remove pointless prototype (uses always follow func implementation) - 'irq' argument is used here purely as a local variable. rename argument to 'dummy' and define 'irq' as local to make this plain. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-18ppc: don't include <linux/ide.h>Bartlomiej Zolnierkiewicz
Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ppc: remove ppc_ide_mdBartlomiej Zolnierkiewicz
* Add special cases for pplus and prep to ide_default_{irq,io_base}() (+ FIXMEs about the need to use IDE platform host driver instead). * Remove no longer needed ppc_ide_md and struct ide_machdep_calls. * Then remove <linux/ide.h> include from: - arch/powerpc/kernel/setup_32.c - arch/ppc/kernel/ppc_ksyms.c - arch/ppc/kernel/setup.c - arch/ppc/platforms/pplus.c - arch/ppc/platforms/prep_setup.c There should be no functional changes caused by this patch. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ppc/pplus: remove ppc_ide_md.ide_init_hwif hookBartlomiej Zolnierkiewicz
* Call ide_init_default_irq() for pplus in init_ide_data(). * Remove no longer needed pplus_ide_init_hwif_ports(). There should be no functional changes caused by this patch. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ppc/sandpoint: remove ppc_ide_md hooksBartlomiej Zolnierkiewicz
* Add IDE_HFLAG_FORCE_LEGACY_IRQS host flag for Motorola-Sandpoint platform to sl82c105 host driver. * Disable ide_generic host driver in arch/ppc/configs/sandpoint_defconfig and enable sl82c105 one. * Remove ppc_ide_md hooks from arch/ppc/platforms/sandpoint.c - no need for them (sl82c105 host driver takes care of all this setup). * Then remove no longer needed <linux/ide.h> include. * Also update arch/ppc/platforms/sandpoint.h. Unfortunately (unlike lopec's case) sl82c105 host driver was not enabled in defconfing so there is a funcionality change. [ Not a big deal since sl82c105 is superior over ide_generic. ] Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ppc/lopec: remove ppc_ide_md hooksBartlomiej Zolnierkiewicz
* Add IDE_HFLAG_FORCE_LEGACY_IRQS host flag for Motorola-LoPEC platform to sl82c105 host driver. * Remove ppc_ide_md hooks from arch/ppc/platforms/lopec.c - no need for them (sl82c105 host driver takes care of all this setup). * Then remove no longer needed <linux/ide.h> include. Looking at arch/ppc/configs/lopec_defconfig: ... CONFIG_IDE_GENERIC=y CONFIG_BLK_DEV_IDEPCI=y # CONFIG_IDEPCI_SHARE_IRQ is not set # CONFIG_BLK_DEV_OFFBOARD is not set CONFIG_BLK_DEV_GENERIC=y # CONFIG_BLK_DEV_OPTI621 is not set CONFIG_BLK_DEV_SL82C105=y ... there should be no functional changes unless somebody preferred to disable sl82c105 host driver and use only ide_generic one (but why would anybody want to do such thing :-). PS It seems that lopec_defconfig hasn't been updated for ages but if somebody is going to do it please look into disabling IDE_GENERIC and BLK_DEV_GENERIC config options. Thanks. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ppc/hdpu: remove dead IDE codeBartlomiej Zolnierkiewicz
Also remove now not needed <linux/ide.h> include. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-01[POWERPC] ppc: Replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-15[POWERPC] PPC440EP Interrupt Triggering and Level SettingsWolfgang Ocker
Corrected IRQ triggering and level settings according to latest revision of the 440EP User Manual (rev 1.24 nov 16, 2007). The incorrect settings might cause a failure of the network if both onchip ethernet ports are under heavy load. Signed-off-by: Wolfgang Ocker <weo@reccoware.de> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-02-06scheduled OSS driver removalAdrian Bunk
This patch contains the scheduled removal of OSS drivers whose config options have been removed in 2.6.23. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-31Merge branch 'linux-2.6'Paul Mackerras
2008-01-28[PPC] Remove 85xx from arch/ppcKumar Gala
85xx exists in arch/powerpc as well as cuImage support to boot from a u-boot that doesn't support device trees. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-28[PPC] Remove 83xx from arch/ppcKumar Gala
83xx exists in arch/powerpc as well as cuImage support to boot from a u-boot that doesn't support device trees. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-28[POWERPC] CPM: Rename commproc to cpm1 and cpm2_common.c to cpm2.cJochen Friedrich
Rename commproc.[ch] to cpm1.[ch] to be more consistent with cpm2. Also rename cpm2_common.c to cpm2.c as suggested by Scott Wood. Adjust the includes accordingly. Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-27i2c: the scheduled I2C RTC driver removalAdrian Bunk
This patch contains the scheduled removal of legacy I2C RTC drivers with replacement drivers. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-23[POWERPC] Move RapidIO support code from arch/ppcKumar Gala
Do just enough to move the RapidIO support code for 85xx over from arch/ppc into arch/powerpc and make it still build. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-20[POWERPC] arch/ppc: Remove an unnecessary pci_dev_putJulia Lawall
Remove an unnecessary pci_dev_put. pci_dev_put is called implicitly by the subsequent call to pci_get_device. The problem was detected using the following semantic patch, and corrected by hand. @@ expression dev; expression E; @@ - pci_dev_put(dev) ... when != dev = E - pci_get_device(...,dev) Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-20[POWERPC] arch/ppc: Remove duplicate includesLucas Woods
Signed-off-by: Lucas Woods <woodzy@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-10Merge branch 'linux-2.6'Paul Mackerras
2007-12-07[POWERPC] virtex bug fix: Use canonical value for AC97 interrupt xparamsGrant Likely
The ml300 and ml403 xparameters.h files use different macros for the AC97 interrupt pin assignments. This normalizes them to a canonical value similar to what EDK generates for most other devices. This is needed to get ml300 support to compile in arch/ppc. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-03[POWERPC] Add missing spaces in printk formats in arch/ppcjoe@perches.com
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-11-19[POWERPC] 4xx: balance ioremap/ioumap calls for YuccaRoel Kluin
Call iounmap before returning from an error case. Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-11-01[POWERPC] 4xx: Fix 4xx flush_tlb_page()Benjamin Herrenschmidt
On 4xx CPUs, the current implementation of flush_tlb_page() uses a low level _tlbie() assembly function that only works for the current PID. Thus, invalidations caused by, for example, a COW fault triggered by get_user_pages() from a different context will not work properly, causing among other things, gdb breakpoints to fail. This patch adds a "pid" argument to _tlbie() on 4xx processors, and uses it to flush entries in the right context. FSL BookE also gets the argument but it seems they don't need it (their tlbivax form ignores the PID when invalidating according to the document I have). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-11-01[POWERPC] allocation fix in ppc/platforms/4xx/luan.cRoel Kluin
Don't allocate hose2 when when hose1 can't be allocated and free hose1 when hose2 can't be allocated. Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-10-19define global BIT macroJiri Slaby
define global BIT macro move all local BIT defines to the new globally define macro. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Russell King <rmk@arm.linux.org.uk> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-09[POWERPC] Remove redundant reference to non-existent CONFIG_BOOTIMGRobert P. J. Day
There is no BOOTIMG Kconfig variable, not to mention that there is no include/linux/bootimg.h header file. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-09-17[POWERPC] Remove APUS support from arch/ppcAdrian Bunk
Current status of APUS: - arch/powerpc/: removed in 2.6.23 - arch/ppc/: marked BROKEN since 2 years This therefore removes the remaining parts of APUS support from arch/ppc, include/asm-ppc, arch/powerpc and include/asm-powerpc. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-07-18serial: add early_serial_setup() back to header fileYinghai Lu
early_serial_setup was removed from serial.h, but forgot to put in serial_8250.h Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-28[POWERPC] Abolish unused ucBoardRev variablesDavid Gibson
asm-powerpc/processor.h declares, and arch/ppc/platforms/prep_setup.c defines variables ucBoardRev, ucBoardRevMaj and ucBoardRevMin which are used nowhere in the current kernel (neither in arch/ppc nor arch/powerpc). This removes them. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-12[POWERPC] Spelling fixes: arch/ppc/Simon Arlott
Spelling fixes in arch/ppc/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-09fix file specification in commentsUwe Kleine-König
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-30Merge branch 'linux-2.6' into for-2.6.22Paul Mackerras
2007-04-30[POWERPC] Remove the unused HTDMSOUND driverAdrian Bunk
Recently, someone fixed a syntax error in the HTDMSOUND driver introduced 4 years ago. Unfortunately not by trying to compile this driver for his hardware but by code inspection - which seems to be a strong indication that there are no users left for this OSS sound driver. This patch therefore removes it. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Dan Malek <dan@embeddedalley.com> Acked-by: Marcelo Tosatti <marcelo@kvack.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-30[POWERPC] Don't define a custom bd_t for Xilixn Virtex based boards.Grant Likely
Why create a platform specific board_info structure that is hacked together, ugly, and dangerous, when we've got a perfectly fine common board_info structure that is hacked-together, ugly and dangerous. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-30[POWERPC] Add sane defaults for Xilinx EDK generated xparameters filesGrant Likely
2007-04-30[POWERPC] Stop using ppc_sys for Xilinx Virtex boardsGrant Likely
The arch/ppc/syslib/ppc_sys.c infrastructure does not work well for the virtex ports. Move the ml300 and ml403 board ports over to use the new virtex_devices infrastructure. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-30[POWERPC] Merge common virtex header filesGrant Likely
The header files for the ml403 and ml300 are virtually identical, merge them into a single file. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-30[POWERPC] Rework Kconfig dependancies for Xilinx Virtex ppc405 platformGrant Likely
Reverse dependency order for Xilinx Virtex parts. For these parts, It makes more sense for boards/chips to specify which features they provide instead of the features listing the parts they are implemented in. I think it also makes adding new board ports simpler. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-13[POWERPC] Ocotea board: ntpd complains that the frequency error exceeds the ↵Bart Van Assche
tolerance Lifted from http://bugzilla.kernel.org/show_bug.cgi?id=8182 Steps to reproduce: - Boot an Ocotea board with the mainline 2.6.20.1 kernel. - Create an /etc/ntp.conf file with at least one NTP server and iburst mode set. - Issue the command "ntpd -g". - Wait about two minutes. - Verify ntpd's status via "ntpq -pn" and by looking in /var/log/ntp. This fixes this problem by adjusting the expected clock frequency. Cc: Kumar Gala <galak@gate.crashing.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-12[PPC] Fix compilation and linking errors of mpc86xads build.Vitaly Bordug
Fix compilation of mpc866ads_setup.c Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-04-12[PPC] Fix compilation and linking errors of mpc885ads build.Vitaly Bordug
Fix compilation of mpc885ads_setup.c Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-04-12[PPC] MPC8272 ADS compile fixed, defconfig refreshed.Vitaly Bordug
Fix compilation of mpc8272ads_setup.c Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
